[U-Boot] [PATCH v2 1/2] ARM: at91sam9m10g45ek: enable mci0 support
Also we enable the mmc command in configuration file.
As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION, so remove the redundant CONFIG_DOS_PARTITION definition.
Signed-off-by: Josh Wu josh.wu@atmel.com --- v1 -> v2: 1. refined the comment for the pins. 2. remove detected pin initialization. 3. move the mci initialization code to devices.c 4. remove useless header file: mmc.h
.../cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 17 +++++++++++++++++ board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 10 ++++++++++ include/configs/at91sam9m10g45ek.h | 15 ++++++++++++++- 3 files changed, 41 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 7d7725c..0e6c0da 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -165,3 +165,20 @@ void at91_macb_hw_init(void) #endif } #endif + +#ifdef CONFIG_GENERIC_ATMEL_MCI +void at91_mci_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI0 CLK */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI0 CDA */ + at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI0 DA0 */ + at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* MCI0 DA1 */ + at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI0 DA2 */ + at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI0 DA3 */ + + /* Enable clock */ + writel(1 << ATMEL_ID_MCI0, &pmc->pcer); +} +#endif diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index b7e2efd..5788116 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -16,6 +16,7 @@ #include <asm/arch/clk.h> #include <lcd.h> #include <atmel_lcdc.h> +#include <atmel_mci.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -217,6 +218,15 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif
+#ifdef CONFIG_GENERIC_ATMEL_MCI +int board_mmc_init(bd_t *bis) +{ + at91_mci_hw_init(); + + return atmel_mci_init((void *)ATMEL_BASE_MCI0); +} +#endif + int board_early_init_f(void) { at91_seriald_hw_init(); diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index ccfda71..df277e7 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -115,6 +115,20 @@
#endif
+/* MMC */ +#define CONFIG_CMD_MMC + +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#endif + +#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII @@ -126,7 +140,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION #define CONFIG_USB_STORAGE
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
In this configuration the environment will save in file: uboot.env of mmc card.
Signed-off-by: Josh Wu josh.wu@atmel.com --- v1 -> v2: 1. remove mem=128m and roottype in bootargs. 2. default boot command use zImage instead of uImage.
boards.cfg | 1 + include/configs/at91sam9m10g45ek.h | 19 +++++++++++++++++++ 2 files changed, 20 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 3a59686..9f7cfd8 100644 --- a/boards.cfg +++ b/boards.cfg @@ -102,6 +102,7 @@ Active arm arm926ejs at91 atmel at91sam9263ek Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH Stelian Pop stelian@popies.net Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash_boot at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH Stelian Pop stelian@popies.net Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_nandflash at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH Bo Shenvoice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_mmc at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_MMC Bo Shenvoice.shen@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_mmc at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC Josh Wu josh.wu@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_nandflash at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH Josh Wu josh.wu@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_spiflash at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH Josh Wu josh.wu@atmel.com diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index df277e7..cab3bb5 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -147,6 +147,7 @@ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END 0x23e00000
+#ifdef CONFIG_SYS_USE_NANDFLASH /* bootstrap + u-boot + env in nandflash */ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0xc0000 @@ -162,6 +163,24 @@ "256k(env),256k(env_redundant),256k(spare)," \ "512k(dtb),6M(kernel)ro,-(rootfs) " \ "root=/dev/mtdblock7 rw rootfstype=jffs2" +#elif CONFIG_SYS_USE_MMC +/* bootstrap + u-boot + env + linux in mmc */ +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_DEVICE 0 +#define FAT_ENV_PART 1 +#define FAT_ENV_FILE "uboot.env" +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define CONFIG_ENV_SIZE 0x4000 + +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mmcblk0p2 rw rootwait" +#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x71000000 dtb; " \ + "fatload mmc 0:1 0x72000000 zImage; " \ + "bootz 0x72000000 - 0x71000000" +#endif
#define CONFIG_BAUDRATE 115200
Hi Josh,
Acked-by: Bo Shen voice.shen@atmel.com
v1 -> v2:
- remove mem=128m and roottype in bootargs.
- default boot command use zImage instead of uImage.
Best Regards, Bo Shen
Dear Josh Wu,
Josh Wu Josh.wu@atmel.com writes:
v1 -> v2:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Hi Josh,
v1 -> v2:
- refined the comment for the pins.
- remove detected pin initialization.
- move the mci initialization code to devices.c
- remove useless header file: mmc.h
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI0 CLK */
- at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI0 CDA */
- at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI0 DA0 */
- at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* MCI0 DA1 */
- at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI0 DA2 */
- at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI0 DA3 */
- /* Enable clock */
- writel(1 << ATMEL_ID_MCI0, &pmc->pcer);
- at91_mci_hw_init();
- return atmel_mci_init((void *)ATMEL_BASE_MCI0);
+} +#endif
- int board_early_init_f(void) { at91_seriald_hw_init();
#endif
- /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII
Dear Josh Wu,
v1 -> v2:
Andreas Bießmann
Bo Shen
Josh Wu
