[PATCH v2] imx: power-domain: Add i.MX8MP HSIOMIX driver
Add trivial driver for i.MX8MP HSIOMIX handling. This is responsible for enabling the GPCv2 power domains and clock for USB 3.0 and PCIe in the correct order. Currently supported is the USB 3.0 part which can be tested, PCIe support should be easy to add.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- V2: Drop two left over unused variables which triggered build warning --- drivers/power/domain/Kconfig | 7 ++ drivers/power/domain/Makefile | 1 + drivers/power/domain/imx8mp-hsiomix.c | 159 ++++++++++++++++++++++++++ 3 files changed, 167 insertions(+) create mode 100644 drivers/power/domain/imx8mp-hsiomix.c
diff --git a/drivers/power/domain/Kconfig b/drivers/power/domain/Kconfig index 04fc0054323..7e1b8c072fa 100644 --- a/drivers/power/domain/Kconfig +++ b/drivers/power/domain/Kconfig @@ -40,6 +40,13 @@ config IMX8M_POWER_DOMAIN Enable support for manipulating NXP i.MX8M on-SoC power domains via requests to the ATF.
+config IMX8MP_HSIOMIX_BLKCTRL + bool "Enable i.MX8MP HSIOMIX domain driver" + depends on POWER_DOMAIN && IMX8MP + select CLK + help + Enable support for manipulating NXP i.MX8MP on-SoC HSIOMIX block controller. + config MTK_POWER_DOMAIN bool "Enable the MediaTek power domain driver" depends on POWER_DOMAIN && ARCH_MEDIATEK diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index 7c8af67dbd6..e6244776216 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_APPLE_PMGR_POWER_DOMAIN) += apple-pmgr.o obj-$(CONFIG_BCM6328_POWER_DOMAIN) += bcm6328-power-domain.o obj-$(CONFIG_IMX8_POWER_DOMAIN) += imx8-power-domain-legacy.o imx8-power-domain.o obj-$(CONFIG_IMX8M_POWER_DOMAIN) += imx8m-power-domain.o +obj-$(CONFIG_IMX8MP_HSIOMIX_BLKCTRL) += imx8mp-hsiomix.o obj-$(CONFIG_MTK_POWER_DOMAIN) += mtk-power-domain.o obj-$(CONFIG_MESON_GX_VPU_POWER_DOMAIN) += meson-gx-pwrc-vpu.o obj-$(CONFIG_MESON_EE_POWER_DOMAIN) += meson-ee-pwrc.o diff --git a/drivers/power/domain/imx8mp-hsiomix.c b/drivers/power/domain/imx8mp-hsiomix.c new file mode 100644 index 00000000000..6a721a934a7 --- /dev/null +++ b/drivers/power/domain/imx8mp-hsiomix.c @@ -0,0 +1,159 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Marek Vasut marex@denx.de + */ + +#include <common.h> +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <power-domain-uclass.h> + +#include <dt-bindings/power/imx8mp-power.h> + +#define GPR_REG0 0x0 +#define PCIE_CLOCK_MODULE_EN BIT(0) +#define USB_CLOCK_MODULE_EN BIT(1) + +struct imx8mp_hsiomix_priv { + void __iomem *base; + struct clk clk_usb; + struct power_domain pd_bus; + struct power_domain pd_usb; + struct power_domain pd_usb_phy1; + struct power_domain pd_usb_phy2; +}; + +static int imx8mp_hsiomix_on(struct power_domain *power_domain) +{ + struct udevice *dev = power_domain->dev; + struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); + struct power_domain *domain; + int ret; + + ret = power_domain_on(&priv->pd_bus); + if (ret) + return ret; + + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) { + domain = &priv->pd_usb; + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY1) { + domain = &priv->pd_usb_phy1; + } else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) { + domain = &priv->pd_usb_phy2; + } else { + ret = -EINVAL; + goto err_pd; + } + + ret = power_domain_on(domain); + if (ret) + goto err_pd; + + ret = clk_enable(&priv->clk_usb); + if (ret) + goto err_clk; + + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + setbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); + + return 0; + +err_clk: + power_domain_off(domain); +err_pd: + power_domain_off(&priv->pd_bus); + return ret; +} + +static int imx8mp_hsiomix_off(struct power_domain *power_domain) +{ + struct udevice *dev = power_domain->dev; + struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); + + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + clrbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); + + clk_disable(&priv->clk_usb); + + if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + power_domain_off(&priv->pd_usb); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY1) + power_domain_off(&priv->pd_usb_phy1); + else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) + power_domain_off(&priv->pd_usb_phy2); + + power_domain_off(&priv->pd_bus); + + return 0; +} + +static int imx8mp_hsiomix_of_xlate(struct power_domain *power_domain, + struct ofnode_phandle_args *args) +{ + power_domain->id = args->args[0]; + + return 0; +} + +static int imx8mp_hsiomix_probe(struct udevice *dev) +{ + struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); + int ret; + + priv->base = dev_read_addr_ptr(dev); + + ret = clk_get_by_name(dev, "usb", &priv->clk_usb); + if (ret < 0) + return ret; + + ret = power_domain_get_by_name(dev, &priv->pd_bus, "bus"); + if (ret < 0) + goto err_pd_bus; + + ret = power_domain_get_by_name(dev, &priv->pd_usb, "usb"); + if (ret < 0) + goto err_pd_usb; + + ret = power_domain_get_by_name(dev, &priv->pd_usb_phy1, "usb-phy1"); + if (ret < 0) + goto err_pd_usb_phy1; + + ret = power_domain_get_by_name(dev, &priv->pd_usb_phy2, "usb-phy2"); + if (ret < 0) + goto err_pd_usb_phy2; + + return 0; + +err_pd_usb_phy2: + power_domain_free(&priv->pd_usb_phy1); +err_pd_usb_phy1: + power_domain_free(&priv->pd_usb); +err_pd_usb: + power_domain_free(&priv->pd_bus); +err_pd_bus: + clk_free(&priv->clk_usb); + return ret; +} + +static const struct udevice_id imx8mp_hsiomix_ids[] = { + { .compatible = "fsl,imx8mp-hsio-blk-ctrl" }, + { } +}; + +struct power_domain_ops imx8mp_hsiomix_ops = { + .on = imx8mp_hsiomix_on, + .off = imx8mp_hsiomix_off, + .of_xlate = imx8mp_hsiomix_of_xlate, +}; + +U_BOOT_DRIVER(imx8mp_hsiomix) = { + .name = "imx8mp_hsiomix", + .id = UCLASS_POWER_DOMAIN, + .of_match = imx8mp_hsiomix_ids, + .probe = imx8mp_hsiomix_probe, + .priv_auto = sizeof(struct imx8mp_hsiomix_priv), + .ops = &imx8mp_hsiomix_ops, +};
select CLK
help
- Copyright (C) 2022 Marek Vasut marex@denx.de
void __iomem *base;
struct clk clk_usb;
int ret;
if (ret)
return ret;
} else {
ret = -EINVAL;
goto err_pd;
if (ret)
goto err_pd;
if (ret)
goto err_clk;
+err_clk:
+err_pd:
return ret;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
goto err_pd_bus;
if (ret < 0)
goto err_pd_usb;
if (ret < 0)
if (ret < 0)
+err_pd_usb_phy2:
+err_pd_usb_phy1:
+err_pd_usb:
+err_pd_bus:
return ret;
2.35.1
Marek,
Thanks for submitting this!
Tested-By: Tim Harvey tharvey@gateworks.com #imx8mp-venice-gw74xx
Best Regards,
Tim
Tim Harvey
