[PATCH v2 1/2] configs: keystone2: Unwind KERNEL_MTD_PARTS definition
This is more complex than it needs to be and makes converting these boards over to plain text env files more difficult. Remove setting mtdparts as the DTS already contain the partitions. While here also drop the conflicting definitions from the K2 defconfigs.
Signed-off-by: Andrew Davis afd@ti.com ---
Changes for v2: - Remove mtdparts completely for K2
configs/k2e_evm_defconfig | 1 - configs/k2e_hs_evm_defconfig | 1 - configs/k2g_evm_defconfig | 1 - configs/k2g_hs_evm_defconfig | 1 - configs/k2hk_evm_defconfig | 1 - configs/k2hk_hs_evm_defconfig | 1 - configs/k2l_evm_defconfig | 1 - configs/k2l_hs_evm_defconfig | 1 - include/configs/k2e_evm.h | 4 ---- include/configs/k2g_evm.h | 3 --- include/configs/k2hk_evm.h | 4 ---- include/configs/k2l_evm.h | 4 ---- include/configs/ti_armv7_keystone2.h | 7 +------ include/environment/ti/spi.h | 14 -------------- 14 files changed, 1 insertion(+), 43 deletions(-) delete mode 100644 include/environment/ti/spi.h
diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 6d9d82594e1..44bed00ec97 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -58,7 +58,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index c782bf11830..55c0182f874 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 756e7502a19..45c7fade320 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -56,7 +56,6 @@ CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index f0de3232e9d..54a980cab54 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 74ef0668d86..a2651780484 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -58,7 +58,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 5bd8c28f546..8c0472dcc2b 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 378a71f94e1..55ddd3cce96 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -58,7 +58,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 31ec3029d76..ce7aa3a39ef 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 630dfdc5b7f..604b85084ca 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_K2E_EVM_H #define __CONFIG_K2E_EVM_H
-#include <environment/ti/spi.h> - /* U-Boot general configuration */ #define ENV_KS2_BOARD_SETTINGS \ DEFAULT_FW_INITRAMFS_BOOT_ENV \ @@ -27,8 +25,6 @@
#include <configs/ti_armv7_keystone2.h>
-#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS - /* Network */ #define CFG_KSNET_CPSW_NUM_PORTS 9
diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index d0634a99f49..186145edc4c 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -10,7 +10,6 @@ #define __CONFIG_K2G_EVM_H
#include <environment/ti/mmc.h> -#include <environment/ti/spi.h>
/* U-Boot general configuration */ #define ENV_KS2_BOARD_SETTINGS \ @@ -54,8 +53,6 @@ #define CFG_KSNET_CPSW_NUM_PORTS 2 #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
-#define SPI_MTD_PARTS KEYSTONE_SPI1_MTD_PARTS - #include <configs/ti_armv7_keystone2.h>
#endif /* __CONFIG_K2G_EVM_H */ diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index ed54be839ff..44a47995b73 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_K2HK_EVM_H #define __CONFIG_K2HK_EVM_H
-#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS - /* Network */ #define CFG_KSNET_CPSW_NUM_PORTS 5
diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index 69d42eaf9f1..43d4049cd9c 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_K2L_EVM_H #define __CONFIG_K2L_EVM_H
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index a47f0902a26..586ccaacd3f 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -78,10 +78,6 @@
/* EDMA3 */
-#define KERNEL_MTD_PARTS \ - "mtdparts=" \ - SPI_MTD_PARTS - #define DEFAULT_FW_INITRAMFS_BOOT_ENV \ "name_fw_rd=k2-fw-initrd.cpio.gz\0" \ "set_rd_spec=setenv rd_spec ${rdaddr}:${filesize}\0" \ @@ -148,8 +144,7 @@ "sf write ${loadaddr} 0 ${filesize}\0" \ "burn_uboot_nand=nand erase 0 0x100000; " \ "nand write ${loadaddr} 0 ${filesize}\0" \ - "args_all=setenv bootargs console=ttyS0,115200n8 rootwait " \ - KERNEL_MTD_PARTS \ + "args_all=setenv bootargs console=ttyS0,115200n8 rootwait\0" \ "args_net=setenv bootargs ${bootargs} rootfstype=nfs " \ "root=/dev/nfs rw nfsroot=${serverip}:${nfs_root}," \ "${nfs_options} ip=dhcp\0" \ diff --git a/include/environment/ti/spi.h b/include/environment/ti/spi.h deleted file mode 100644 index 1681dc8635e..00000000000 --- a/include/environment/ti/spi.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com - * - * Environment variable definitions for SPI on TI boards. - */ - -#ifndef __TI_SPI_H -#define __TI_SPI_H - -#define KEYSTONE_SPI0_MTD_PARTS "spi0.0:1m(u-boot-spl)ro,-(misc);\0" -#define KEYSTONE_SPI1_MTD_PARTS "spi1.0:1m(u-boot-spl)ro,-(misc);\0" - -#endif
Move to using .env file for setting up environment variables for K2x_evm.
Signed-off-by: Andrew Davis afd@ti.com --- board/ti/ks2_evm/Kconfig | 12 +++ board/ti/ks2_evm/k2e_evm.env | 12 +++ board/ti/ks2_evm/k2g_evm.env | 45 +++++++++ board/ti/ks2_evm/k2hk_evm.env | 12 +++ board/ti/ks2_evm/k2l_evm.env | 12 +++ include/configs/k2e_evm.h | 14 --- include/configs/k2g_evm.h | 40 -------- include/configs/k2hk_evm.h | 14 --- include/configs/k2l_evm.h | 14 --- include/configs/ti_armv7_keystone2.h | 94 ------------------- include/environment/ti/ti_armv7_keystone2.env | 61 ++++++++++++ 11 files changed, 154 insertions(+), 176 deletions(-) create mode 100644 board/ti/ks2_evm/k2e_evm.env create mode 100644 board/ti/ks2_evm/k2g_evm.env create mode 100644 board/ti/ks2_evm/k2hk_evm.env create mode 100644 board/ti/ks2_evm/k2l_evm.env create mode 100644 include/environment/ti/ti_armv7_keystone2.env
diff --git a/board/ti/ks2_evm/Kconfig b/board/ti/ks2_evm/Kconfig index 9477f5336b8..8b3a43a5aa8 100644 --- a/board/ti/ks2_evm/Kconfig +++ b/board/ti/ks2_evm/Kconfig @@ -9,6 +9,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "k2e_evm"
+config ENV_SOURCE_FILE + default "k2e_evm" + endif
if TARGET_K2HK_EVM @@ -22,6 +25,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "k2hk_evm"
+config ENV_SOURCE_FILE + default "k2hk_evm" + endif
if TARGET_K2L_EVM @@ -35,6 +41,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "k2l_evm"
+config ENV_SOURCE_FILE + default "k2l_evm" + endif
if TARGET_K2G_EVM @@ -48,6 +57,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "k2g_evm"
+config ENV_SOURCE_FILE + default "k2g_evm" + endif
source "board/ti/common/Kconfig" diff --git a/board/ti/ks2_evm/k2e_evm.env b/board/ti/ks2_evm/k2e_evm.env new file mode 100644 index 00000000000..746e4065a2c --- /dev/null +++ b/board/ti/ks2_evm/k2e_evm.env @@ -0,0 +1,12 @@ +#include <environment/ti/ti_armv7_common.env> +#include <environment/ti/ti_armv7_keystone2.env> + +findfdt=setenv fdtfile ${name_fdt} +boot=ubi +args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048 + +name_fdt=keystone-k2e-evm.dtb +name_mon=skern-k2e.bin +name_ubi=k2e-evm-ubifs.ubi +name_uboot=u-boot-spi-k2e-evm.gph +name_fs=arago-console-image-k2e-evm.cpio.gz diff --git a/board/ti/ks2_evm/k2g_evm.env b/board/ti/ks2_evm/k2g_evm.env new file mode 100644 index 00000000000..72807ac87a6 --- /dev/null +++ b/board/ti/ks2_evm/k2g_evm.env @@ -0,0 +1,45 @@ +#include <environment/ti/ti_armv7_common.env> +#include <environment/ti/ti_armv7_keystone2.env> +#include <environment/ti/mmc.env> + +set_name_pmmc=setenv name_pmmc ti-sci-firmware-k2g.bin +dev_pmmc=0 +get_pmmc_net=dhcp ${loadaddr} ${tftp_root}/${name_pmmc} +get_pmmc_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_pmmc} +get_pmmc_ramfs=run get_pmmc_net +get_pmmc_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_pmmc} +get_pmmc_ubi=ubifsload ${loadaddr} ${bootdir}/${name_pmmc} +run_pmmc=rproc init; + rproc list; + rproc load ${dev_pmmc} ${loadaddr} 0x${filesize}; + rproc start ${dev_pmmc} + +boot=mmc +console=ttyS0,115200n8 +bootpart=0:2 +bootdir=/boot +rd_spec=- +args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048 + +findfdt= + if test $board_name = 66AK2GGP; then + setenv name_fdt keystone-k2g-evm.dtb; fi; + if test $board_name = 66AK2GG1; then + setenv name_fdt keystone-k2g-evm.dtb; fi; + if test $board_name = 66AK2GIC; then + setenv name_fdt keystone-k2g-ice.dtb; fi; + if test $board_name = 66AK2GI1; then + setenv name_fdt keystone-k2g-ice.dtb; fi; + if test $name_fdt = undefined; then + echo WARNING: Could not determine device tree to use; fi; + setenv fdtfile ${name_fdt} + +name_mon=skern-k2g.bin +name_ubi=k2g-evm-ubifs.ubi +name_uboot=u-boot-spi-k2g-evm.gph +init_mmc=run args_all args_mmc +init_fw_rd_mmc=load mmc ${bootpart} ${rdaddr} ${bootdir}/${name_fw_rd}; run set_rd_spec +get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt} +get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern} +get_mon_mmc=load mmc ${bootpart} ${addr_mon} ${bootdir}/${name_mon} +name_fs=arago-base-tisdk-image-k2g-evm.cpio diff --git a/board/ti/ks2_evm/k2hk_evm.env b/board/ti/ks2_evm/k2hk_evm.env new file mode 100644 index 00000000000..f1cdc706036 --- /dev/null +++ b/board/ti/ks2_evm/k2hk_evm.env @@ -0,0 +1,12 @@ +#include <environment/ti/ti_armv7_common.env> +#include <environment/ti/ti_armv7_keystone2.env> + +findfdt=setenv fdtfile ${name_fdt} +boot=ubi +args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048 + +name_fdt=keystone-k2hk-evm.dtb +name_mon=skern-k2hk.bin +name_ubi=k2hk-evm-ubifs.ubi +name_uboot=u-boot-spi-k2hk-evm.gph +name_fs=arago-console-image-k2hk-evm.cpio.gz diff --git a/board/ti/ks2_evm/k2l_evm.env b/board/ti/ks2_evm/k2l_evm.env new file mode 100644 index 00000000000..ddb5cd4aadc --- /dev/null +++ b/board/ti/ks2_evm/k2l_evm.env @@ -0,0 +1,12 @@ +#include <environment/ti/ti_armv7_common.env> +#include <environment/ti/ti_armv7_keystone2.env> + +findfdt=setenv fdtfile ${name_fdt} +boot=ubi +args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,4096 + +name_fdt=keystone-k2l-evm.dtb +name_mon=skern-k2l.bin +name_ubi=k2l-evm-ubifs.ubi +name_uboot=u-boot-spi-k2l-evm.gph +name_fs=arago-console-image-k2l-evm.cpio.gz\0" diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 604b85084ca..5cdd87c0a17 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -9,20 +9,6 @@ #ifndef __CONFIG_K2E_EVM_H #define __CONFIG_K2E_EVM_H
-/* U-Boot general configuration */ -#define ENV_KS2_BOARD_SETTINGS \ - DEFAULT_FW_INITRAMFS_BOOT_ENV \ - DEFAULT_FIT_TI_ARGS \ - "findfdt=setenv fdtfile ${name_fdt}\0" \ - "boot=ubi\0" \ - "args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs " \ - "root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048\0" \ - "name_fdt=keystone-k2e-evm.dtb\0" \ - "name_mon=skern-k2e.bin\0" \ - "name_ubi=k2e-evm-ubifs.ubi\0" \ - "name_uboot=u-boot-spi-k2e-evm.gph\0" \ - "name_fs=arago-console-image-k2e-evm.cpio.gz\0" - #include <configs/ti_armv7_keystone2.h>
/* Network */ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 186145edc4c..2f25d393a37 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -9,46 +9,6 @@ #ifndef __CONFIG_K2G_EVM_H #define __CONFIG_K2G_EVM_H
-#include <environment/ti/mmc.h> - -/* U-Boot general configuration */ -#define ENV_KS2_BOARD_SETTINGS \ - DEFAULT_MMC_TI_ARGS \ - DEFAULT_PMMC_BOOT_ENV \ - DEFAULT_FW_INITRAMFS_BOOT_ENV \ - DEFAULT_FIT_TI_ARGS \ - "boot=mmc\0" \ - "console=ttyS0,115200n8\0" \ - "bootpart=0:2\0" \ - "bootdir=/boot\0" \ - "rd_spec=-\0" \ - "args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs " \ - "root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048\0" \ - "findfdt="\ - "if test $board_name = 66AK2GGP; then " \ - "setenv name_fdt keystone-k2g-evm.dtb; " \ - "else if test $board_name = 66AK2GG1; then " \ - "setenv name_fdt keystone-k2g-evm.dtb; " \ - "else if test $board_name = 66AK2GIC; then " \ - "setenv name_fdt keystone-k2g-ice.dtb; " \ - "else if test $board_name = 66AK2GI1; then " \ - "setenv name_fdt keystone-k2g-ice.dtb; " \ - "else if test $name_fdt = undefined; then " \ - "echo WARNING: Could not determine device tree to use;"\ - "fi;fi;fi;fi; setenv fdtfile ${name_fdt}\0" \ - "name_mon=skern-k2g.bin\0" \ - "name_ubi=k2g-evm-ubifs.ubi\0" \ - "name_uboot=u-boot-spi-k2g-evm.gph\0" \ - "init_mmc=run args_all args_mmc\0" \ - "init_fw_rd_mmc=load mmc ${bootpart} ${rdaddr} " \ - "${bootdir}/${name_fw_rd}; run set_rd_spec\0" \ - "soc_variant=k2g\0" \ - "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}\0"\ - "get_kern_mmc=load mmc ${bootpart} ${loadaddr} " \ - "${bootdir}/${name_kern}\0" \ - "get_mon_mmc=load mmc ${bootpart} ${addr_mon} ${bootdir}/${name_mon}\0"\ - "name_fs=arago-base-tisdk-image-k2g-evm.cpio\0" - /* Network */ #define CFG_KSNET_CPSW_NUM_PORTS 2 #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */ diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 44a47995b73..5e52bbb98f8 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -9,20 +9,6 @@ #ifndef __CONFIG_K2HK_EVM_H #define __CONFIG_K2HK_EVM_H
-/* U-Boot general configuration */ -#define ENV_KS2_BOARD_SETTINGS \ - DEFAULT_FW_INITRAMFS_BOOT_ENV \ - DEFAULT_FIT_TI_ARGS \ - "findfdt=setenv fdtfile ${name_fdt}\0" \ - "boot=ubi\0" \ - "args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs " \ - "root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048\0" \ - "name_fdt=keystone-k2hk-evm.dtb\0" \ - "name_mon=skern-k2hk.bin\0" \ - "name_ubi=k2hk-evm-ubifs.ubi\0" \ - "name_uboot=u-boot-spi-k2hk-evm.gph\0" \ - "name_fs=arago-console-image-k2hk-evm.cpio.gz\0" - #include <configs/ti_armv7_keystone2.h>
/* Network */ diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index 43d4049cd9c..199959fbd42 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -9,20 +9,6 @@ #ifndef __CONFIG_K2L_EVM_H #define __CONFIG_K2L_EVM_H
-/* U-Boot general configuration */ -#define ENV_KS2_BOARD_SETTINGS \ - DEFAULT_FW_INITRAMFS_BOOT_ENV \ - DEFAULT_FIT_TI_ARGS \ - "findfdt=setenv fdtfile ${name_fdt}\0" \ - "boot=ubi\0" \ - "args_ubi=setenv bootargs ${bootargs} rootfstype=ubifs " \ - "root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,4096\0" \ - "name_fdt=keystone-k2l-evm.dtb\0" \ - "name_mon=skern-k2l.bin\0" \ - "name_ubi=k2l-evm-ubifs.ubi\0" \ - "name_uboot=u-boot-spi-k2l-evm.gph\0" \ - "name_fs=arago-console-image-k2l-evm.cpio.gz\0" - #include <configs/ti_armv7_keystone2.h>
/* Network */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 586ccaacd3f..72c04d8a994 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -63,106 +63,12 @@ #define CFG_SYS_NAND_LARGEPAGE #define CFG_SYS_NAND_BASE_LIST { 0x30000000, }
-#define DFU_ALT_INFO_MMC \ - "dfu_alt_info_mmc=" \ - "MLO fat 0 1;" \ - "u-boot.img fat 0 1;" \ - "uEnv.txt fat 0 1\0"
-/* DFU settings */ -#define DFUARGS \ - "dfu_bufsiz=0x10000\0" \ - DFU_ALT_INFO_MMC \
/* EDMA3 */
-#define DEFAULT_FW_INITRAMFS_BOOT_ENV \ - "name_fw_rd=k2-fw-initrd.cpio.gz\0" \ - "set_rd_spec=setenv rd_spec ${rdaddr}:${filesize}\0" \ - "init_fw_rd_net=dhcp ${rdaddr} ${tftp_root}/${name_fw_rd}; " \ - "run set_rd_spec\0" \ - "init_fw_rd_nfs=nfs ${rdaddr} ${nfs_root}/boot/${name_fw_rd}; " \ - "run set_rd_spec\0" \ - "init_fw_rd_ramfs=setenv rd_spec -\0" \ - "init_fw_rd_ubi=ubifsload ${rdaddr} ${bootdir}/${name_fw_rd}; " \ - "run set_rd_spec\0" \ - -#define DEFAULT_PMMC_BOOT_ENV \ - "set_name_pmmc=setenv name_pmmc ti-sci-firmware-${soc_variant}.bin\0" \ - "dev_pmmc=0\0" \ - "get_pmmc_net=dhcp ${loadaddr} ${tftp_root}/${name_pmmc}\0" \ - "get_pmmc_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_pmmc}\0" \ - "get_pmmc_ramfs=run get_pmmc_net\0" \ - "get_pmmc_mmc=load mmc ${bootpart} ${loadaddr} " \ - "${bootdir}/${name_pmmc}\0" \ - "get_pmmc_ubi=ubifsload ${loadaddr} ${bootdir}/${name_pmmc}\0" \ - "run_pmmc=rproc init; rproc list; " \ - "rproc load ${dev_pmmc} ${loadaddr} 0x${filesize}; " \ - "rproc start ${dev_pmmc}\0" \ - -#define CFG_EXTRA_ENV_SETTINGS \ - DEFAULT_LINUX_BOOT_ENV \ - ENV_KS2_BOARD_SETTINGS \ - DFUARGS \ - "bootdir=/boot\0" \ - "tftp_root=/\0" \ - "nfs_root=/export\0" \ - "mem_lpae=1\0" \ - "uinitrd_fixup=1\0" \ - "addr_ubi=0x82000000\0" \ - "addr_secdb_key=0xc000000\0" \ - "name_kern=zImage\0" \ - "addr_mon=0x87000000\0" \ - "addr_non_sec_mon=0x0c097fc0\0" \ - "addr_load_sec_bm=0x0c09c000\0" \ - "run_mon=mon_install ${addr_mon}\0" \ - "run_mon_hs=mon_install ${addr_non_sec_mon} " \ - "${addr_load_sec_bm}\0" \ - "run_kern=bootz ${loadaddr} ${rd_spec} ${fdtaddr}\0" \ - "init_net=run args_all args_net\0" \ - "init_nfs=setenv autoload no; dhcp; run args_all args_net\0" \ - "init_ubi=run args_all args_ubi; " \ - "ubi part ubifs; ubifsmount ubi:rootfs;\0" \ - "get_fdt_net=dhcp ${fdtaddr} ${tftp_root}/${name_fdt}\0" \ - "get_fdt_nfs=nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt}\0" \ - "get_fdt_ubi=ubifsload ${fdtaddr} ${bootdir}/${name_fdt}\0" \ - "get_kern_net=dhcp ${loadaddr} ${tftp_root}/${name_kern}\0" \ - "get_kern_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_kern}\0" \ - "get_kern_ubi=ubifsload ${loadaddr} ${bootdir}/${name_kern}\0" \ - "get_mon_net=dhcp ${addr_mon} ${tftp_root}/${name_mon}\0" \ - "get_mon_nfs=nfs ${addr_mon} ${nfs_root}/boot/${name_mon}\0" \ - "get_mon_ubi=ubifsload ${addr_mon} ${bootdir}/${name_mon}\0" \ - "get_fit_net=dhcp ${addr_fit} ${tftp_root}/${name_fit}\0" \ - "get_fit_nfs=nfs ${addr_fit} ${nfs_root}/boot/${name_fit}\0" \ - "get_fit_ubi=ubifsload ${addr_fit} ${bootdir}/${name_fit}\0" \ - "get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}\0" \ - "get_uboot_net=dhcp ${loadaddr} ${tftp_root}/${name_uboot}\0" \ - "get_uboot_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_uboot}\0" \ - "burn_uboot_spi=sf probe; sf erase 0 0x100000; " \ - "sf write ${loadaddr} 0 ${filesize}\0" \ - "burn_uboot_nand=nand erase 0 0x100000; " \ - "nand write ${loadaddr} 0 ${filesize}\0" \ - "args_all=setenv bootargs console=ttyS0,115200n8 rootwait\0" \ - "args_net=setenv bootargs ${bootargs} rootfstype=nfs " \ - "root=/dev/nfs rw nfsroot=${serverip}:${nfs_root}," \ - "${nfs_options} ip=dhcp\0" \ - "nfs_options=v3,tcp,rsize=4096,wsize=4096\0" \ - "get_fdt_ramfs=dhcp ${fdtaddr} ${tftp_root}/${name_fdt}\0" \ - "get_kern_ramfs=dhcp ${loadaddr} ${tftp_root}/${name_kern}\0" \ - "get_mon_ramfs=dhcp ${addr_mon} ${tftp_root}/${name_mon}\0" \ - "get_fit_ramfs=dhcp ${addr_fit} ${tftp_root}/${name_fit}\0" \ - "get_fs_ramfs=dhcp ${rdaddr} ${tftp_root}/${name_fs}\0" \ - "get_ubi_net=dhcp ${addr_ubi} ${tftp_root}/${name_ubi}\0" \ - "get_ubi_nfs=nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi}\0" \ - "burn_ubi=nand erase.part ubifs; " \ - "nand write ${addr_ubi} ubifs ${filesize}\0" \ - "init_ramfs=run args_all args_ramfs get_fs_ramfs\0" \ - "args_ramfs=setenv bootargs ${bootargs} " \ - "rdinit=/sbin/init rw root=/dev/ram0 " \ - "initrd=0x808080000,80M\0" \ - "no_post=1\0"
/* Now for the remaining common defines */ #include <configs/ti_armv7_common.h> diff --git a/include/environment/ti/ti_armv7_keystone2.env b/include/environment/ti/ti_armv7_keystone2.env new file mode 100644 index 00000000000..e0395d302cb --- /dev/null +++ b/include/environment/ti/ti_armv7_keystone2.env @@ -0,0 +1,61 @@ +name_fw_rd=k2-fw-initrd.cpio.gz +set_rd_spec=setenv rd_spec ${rdaddr}:${filesize} +init_fw_rd_net=dhcp ${rdaddr} ${tftp_root}/${name_fw_rd}; run set_rd_spec +init_fw_rd_nfs=nfs ${rdaddr} ${nfs_root}/boot/${name_fw_rd}; run set_rd_spec +init_fw_rd_ramfs=setenv rd_spec - +init_fw_rd_ubi=ubifsload ${rdaddr} ${bootdir}/${name_fw_rd}; run set_rd_spec + +dfu_bufsiz=0x10000 +dfu_alt_info_mmc= + MLO fat 0 1; + u-boot.img fat 0 1; + uEnv.txt fat 0 1 + +bootdir=/boot +tftp_root=/ +nfs_root=/export +mem_lpae=1 +uinitrd_fixup=1 +addr_ubi=0x82000000 +addr_secdb_key=0xc000000 +name_kern=zImage +addr_mon=0x87000000 +addr_non_sec_mon=0x0c097fc0 +addr_load_sec_bm=0x0c09c000 +run_mon=mon_install ${addr_mon} +run_mon_hs=mon_install ${addr_non_sec_mon} ${addr_load_sec_bm} +run_kern=bootz ${loadaddr} ${rd_spec} ${fdtaddr} +init_net=run args_all args_net +init_nfs=setenv autoload no; dhcp; run args_all args_net +init_ubi=run args_all args_ubi; ubi part ubifs; ubifsmount ubi:rootfs; +get_fdt_net=dhcp ${fdtaddr} ${tftp_root}/${name_fdt} +get_fdt_nfs=nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt} +get_fdt_ubi=ubifsload ${fdtaddr} ${bootdir}/${name_fdt} +get_kern_net=dhcp ${loadaddr} ${tftp_root}/${name_kern} +get_kern_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_kern} +get_kern_ubi=ubifsload ${loadaddr} ${bootdir}/${name_kern} +get_mon_net=dhcp ${addr_mon} ${tftp_root}/${name_mon} +get_mon_nfs=nfs ${addr_mon} ${nfs_root}/boot/${name_mon} +get_mon_ubi=ubifsload ${addr_mon} ${bootdir}/${name_mon} +get_fit_net=dhcp ${addr_fit} ${tftp_root}/${name_fit} +get_fit_nfs=nfs ${addr_fit} ${nfs_root}/boot/${name_fit} +get_fit_ubi=ubifsload ${addr_fit} ${bootdir}/${name_fit} +get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit} +get_uboot_net=dhcp ${loadaddr} ${tftp_root}/${name_uboot} +get_uboot_nfs=nfs ${loadaddr} ${nfs_root}/boot/${name_uboot} +burn_uboot_spi=sf probe; sf erase 0 0x100000; sf write ${loadaddr} 0 ${filesize} +burn_uboot_nand=nand erase 0 0x100000; nand write ${loadaddr} 0 ${filesize} +args_all=setenv bootargs console=ttyS0,115200n8 rootwait +args_net=setenv bootargs ${bootargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp +nfs_options=v3,tcp,rsize=4096,wsize=4096 +get_fdt_ramfs=dhcp ${fdtaddr} ${tftp_root}/${name_fdt} +get_kern_ramfs=dhcp ${loadaddr} ${tftp_root}/${name_kern} +get_mon_ramfs=dhcp ${addr_mon} ${tftp_root}/${name_mon} +get_fit_ramfs=dhcp ${addr_fit} ${tftp_root}/${name_fit} +get_fs_ramfs=dhcp ${rdaddr} ${tftp_root}/${name_fs} +get_ubi_net=dhcp ${addr_ubi} ${tftp_root}/${name_ubi} +get_ubi_nfs=nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi} +burn_ubi=nand erase.part ubifs; nand write ${addr_ubi} ubifs ${filesize} +init_ramfs=run args_all args_ramfs get_fs_ramfs +args_ramfs=setenv bootargs ${bootargs} rdinit=/sbin/init rw root=/dev/ram0 initrd=0x808080000,80M +no_post=1
Signed-off-by: Andrew Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Andrew Davis
