[U-Boot] [PATCH 1/2] mx6sabresd: README: Adjust the binary name after DM conversion
After the conversion to DM the U-Boot binary is called u-boot-dtb.imx, so fix the README file accordingly.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/mx6sabresd/README | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/board/freescale/mx6sabresd/README b/board/freescale/mx6sabresd/README index 4b4df06330..4ea4454b9f 100644 --- a/board/freescale/mx6sabresd/README +++ b/board/freescale/mx6sabresd/README @@ -21,15 +21,15 @@ $ make mx6sabresd_defconfig
$ make
-This will generate the SPL and u-boot.img binaries. +This will generate the SPL and u-boot-dtb.img binaries.
- Flash the SPL binary into the SD card:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync
-- Flash the u-boot.img binary into the SD card: +- Flash the u-boot-dtb.img binary into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdX bs=1K seek=69 && sync
2. Booting from eMMC @@ -39,7 +39,7 @@ $ make mx6sabresd_defconfig
$ make
- Boot first from SD card as shown in the previous section
@@ -51,10 +51,10 @@ Mount the eMMC in the host PC:
=> ums 0 mmc 2
-- Flash SPL and u-boot.img binaries into the eMMC: +- Flash SPL and u-boot-dtb.img binaries into the eMMC:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync -$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdX bs=1K seek=69 && sync
Set SW6 to eMMC 8-bit boot: 11010110
@@ -65,15 +65,15 @@ Set SW6 to eMMC 8-bit boot: 11010110 $ make mx6sabresd_defconfig $ make
-This will generate the SPL image called SPL and the u-boot.img. +This will generate the SPL image called SPL and the u-boot-dtb.img.
- Flash the SPL image into the SD card:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 oflag=sync status=none && sync
-- Flash the u-boot.img image into the SD card: +- Flash the u-boot-dtb.img image into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync
Create a partition for root file system and extract it there:
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/mx6sabreauto/README | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/freescale/mx6sabreauto/README b/board/freescale/mx6sabreauto/README index e8c589b92a..4c0fda1a2d 100644 --- a/board/freescale/mx6sabreauto/README +++ b/board/freescale/mx6sabreauto/README @@ -9,15 +9,15 @@ $ make mx6sabreauto_defconfig
$ make
Booting via Falcon mode ----------------------- @@ -32,15 +32,15 @@ $ make mx6sabreauto_defconfig
$ make
$ sudo dd if=SPL of=/dev/sdb bs=1K seek=1 && sync
-$ sudo dd if=u-boot.img of=/dev/sdb bs=1K seek=69 && sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdb bs=1K seek=69 && sync
Create a FAT16 boot partition to store uImage and the dtb file, then copy the files there:
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2019年2月26日 20:36 To: sbabic@denx.de Cc: dl-uboot-imx uboot-imx@nxp.com; Peng Fan peng.fan@nxp.com; Abel Vesa abel.vesa@nxp.com; u-boot@lists.denx.de; Fabio Estevam festevam@gmail.com Subject: [PATCH 2/2] mx6sabreauto: README: Adjust the binary name after DM conversion
Acked-by: Peng Fan peng.fan@nxp.com
$ make
$ make
-- 2.17.1
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2019年2月26日 20:36 To: sbabic@denx.de Cc: dl-uboot-imx uboot-imx@nxp.com; Peng Fan peng.fan@nxp.com; Abel Vesa abel.vesa@nxp.com; u-boot@lists.denx.de; Fabio Estevam festevam@gmail.com Subject: [PATCH 1/2] mx6sabresd: README: Adjust the binary name after DM conversion
$ make
- Booting from eMMC
$ make
=> ums 0 mmc 2
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdX bs=1K seek=69 oflag=sync +status=none && sync
-- 2.17.1
Fabio Estevam
Peng Fan
