[U-Boot] [PATCH] powerpc/913x: Add config flag for bootdelay
Signed-off-by: Harninder Rai harninder.rai@freescale.com --- include/configs/BSC9131RDB.h | 1 + include/configs/BSC9132QDS.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index adb8146..6f1022e 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -430,6 +430,7 @@ extern unsigned long get_sdram_size(void); #define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server */
#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 10 /* -1 disable auto-boot */
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 2722a32..66ca461 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -672,6 +672,7 @@ combinations. this should be removed later #define CONFIG_UBOOTPATH "u-boot.bin"
#ifdef CONFIG_SDCARD #define CONFIG_DEF_HWCONFIG "hwconfig=usb1:dr_mode=host,phy_type=ulpi\0"
The change is trivial. Do you mind to explain why you need this change?
York
Thanks for the review. This change is required to give user some time to interrupt the booting process Also, this will allow the system to boot from flash after power-on (does help in automation testing) Is this sufficient for a commit message?
Harry++
York
You understand this is the default value of the said variable. You can save your environmental variable when you boot up. You can save it to any value you want, and this default value doesn't matter any more, until you erase it.
York
________________________________ From: Rai Harninder-B01044 Sent: Mon, 15/12/2014 22:07 To: Sun York-R58495 yorksun@freescale.com; u-boot@lists.denx.de Subject: RE: [PATCH] powerpc/913x: Add config flag for bootdelay
Harry++
York
I am not sure I followed you completely but if I just use CONFIG_BOOTDELAY then I get the following compilation error
common/autoboot.c: In function 'bootdelay_process': common/autoboot.c:247:68: error: expected expression before ';' token
Is there something which I am missing?
Thanks and Regards Harry++
From: Sun York-R58495 Sent: Tuesday, December 16, 2014 11:46 AM To: Rai Harninder-B01044; u-boot@lists.denx.de Subject: RE: [PATCH] powerpc/913x: Add config flag for bootdelay
York
________________________________ From: Rai Harninder-B01044 Sent: Mon, 15/12/2014 22:07 To: Sun York-R58495 <yorksun@freescale.commailto:yorksun@freescale.com>; u-boot@lists.denx.demailto:u-boot@lists.denx.de Subject: RE: [PATCH] powerpc/913x: Add config flag for bootdelay
Harry++
York
I am guessing you has some extra character for the CONFIG_BOOTDELAY. Anyway, since you are on this line common/autoboot.c:247, you can see the "bootdelay" variable one line above. Your purpose of adding delay to boot is easily implemented by these command under u-boot
setenv bootdelay 10 saveenv
There is no need to change the code for this purpose.
York
Thanks for the review. Let me look into this
Harry++
York
I took another look at this patch. It is harmless and adding the default value is correct. I will accept this patch and add commit message.
York
Applied to u-boot-mpc85xx master branch, awaiting upstream.
York
Harninder Rai
York Sun
