[U-Boot] [PATCH] CRITICAL error in v2013.04-rc2 (true and false not working)
Hello,
with this version of gcc which is default in ubuntu 12.10:
$ arm-linux-gnueabi-gcc -v Using built-in specs. COLLECT_GCC=arm-linux-gnueabi-gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabi/4.7/lto-wrapper Target: arm-linux-gnueabi Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.7.2-1ubuntu1' --with- bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program- suffix=-4.7 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable- threads=posix --with-gxx-include-dir=/usr/arm-linux-gnueabi/include/c++/4.7.2 --libdir=/usr/lib --enable-nls --enable- clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --enable-plugin --enable-objc-gc --enable-multilib --disable-sjlj-exceptions --with-arch=armv5t --with-float=soft --disable-werror --enable- checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabi --program-prefix=arm-linux- gnueabi- --includedir=/usr/arm-linux-gnueabi/include --with-headers=/usr/arm-linux-gnueabi/include --with-libs=/usr/arm-linux- gnueabi/lib Thread model: posix gcc version 4.7.2 (Ubuntu/Linaro 4.7.2-1ubuntu1)
u-boot "true" and "false" hush commands are copiled incorrectly in uboot v2013.04-rc2 (c8142633e169665b246352918df5b76fd243bb71)
when I run help in u-boot it show:
# help 0 - do nothing, unsuccessfully 1 - do nothing, successfully ? - alias for 'help' base - print or set address offset ...
Instead "0" and "1" there should be "false" and "true" command.
This happen when stdbool.h from C99 compiler is included in cmd_test.c and then true and false macros are expanded to 1 and 0. Quick fix for this is adding #undef before U_BOOT_CMD:
diff --git a/common/cmd_test.c b/common/cmd_test.c index d4ec186..a7ec8ac 100644 --- a/common/cmd_test.c +++ b/common/cmd_test.c @@ -155,6 +155,7 @@ static int do_false(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
+#undef false U_BOOT_CMD( false, CONFIG_SYS_MAXARGS, 1, do_false, "do nothing, unsuccessfully", @@ -166,6 +167,7 @@ static int do_true(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+#undef true U_BOOT_CMD( true, CONFIG_SYS_MAXARGS, 1, do_true, "do nothing, successfully",
Without above patch and with gcc 4.7.2 it is not possible to use u-boot on Nokia RX-51, becuase it has true and false commands in preboot env.
Please fix this problem in u-boot v2013.04.
Dear Pali Rohár,
I confirm the problem.
York, your commit 472d546 "Consolidate bool type" is causing this issue, so I suggest you send a fix, please.
Please check for other, similar use cases.
Thanks.
On 04/04/2013 01:33 PM, Wolfgang Denk wrote:
Dear Pali Rohár,
Thanks.
Thanks for catching it. I am working on the fix now.
York
Dear Pali Rohár,
I found the cause but I don't know the best fix. Please help.
This is cause by common/cmd_test.c. It has command "true" and "false". Shall I undef true and false before the U_BOOT_CMD in this file, or use True and False as the names? If there is a better way to do that, please enlighten me.
York
Dear Pali Rohár,
York
If you rename commands "true" and "false" to "True" and "False" you will break all code which using it. Now RX-51 board do not booting due to missing "true" and "false" commands...
Dear Pali Rohár,
York
Would this fix be acceptable?
diff --git a/common/cmd_test.c b/common/cmd_test.c index d4ec186..2ce3d3d 100644 --- a/common/cmd_test.c +++ b/common/cmd_test.c @@ -155,6 +155,10 @@ static int do_false(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
+#ifdef true +#undef true +#undef false + U_BOOT_CMD( false, CONFIG_SYS_MAXARGS, 1, do_false, "do nothing, unsuccessfully", @@ -171,3 +175,5 @@ U_BOOT_CMD( "do nothing, successfully", NULL ); + +#endif
York
Dear Pali Rohár,
York
York
I already proposed patch in first email: http://lists.denx.de/pipermail/u-boot/2013-April/151009.html
Adding #undef true and #undef false fixing this problem.
Dear Pali Rohár,
York
York
Thanks, Pali.
Wolfgang, shall we change U_BOOT_CMD to take string instead of stringifying or use the local undef?
York
Dear York,
I tend to prefer Pali Rohar's fix.
On 04/04/2013 02:50 PM, Wolfgang Denk wrote:
Dear York,
I sent out two fixes. No strong feeling of either one.
York
Dear York Sun,
No...
... as it would completely remove the command entries if "true" was not defined.
On 04/04/2013 02:47 PM, Wolfgang Denk wrote:
Dear York Sun,
No...
Right. I will go with Tom's suggestion.
York
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Dear Pali Rohár,
The problem is with how U_BOOT_CMD is constructed. We pass in the command name as the first arg, but don't stringify it until some levels later. I can't think of a better work-around than #define _STDBOOL_H at the top, with a big fat comment.
- -- Tom
Pali Rohár
York Sun
