[U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
I am Manohar,started boot the X86-64 (Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz) using u-boot to work for TIZEN .
As I am unable to configure/build my pc using u-boot-x86 .
I request you please help me how to configure it/build the u-boot-x86 on my pc as my pc is loaded with Ubuntu 11.10 and my aim is to make my PC as host and target are the same.
Please resolve the issue/is my PC support for the u-boot.
Best Regards, Manohar 8790215215
Dear manohar.betham@smartplayin.com,
You need to compile it on a 32bit machine ... or install 32bit cross compiler ... u-boot doesn't support x86/64. Patches are welcome though.
Best regards, Marek Vasut
Dear Marek,
Thank you for the reply.
Can you please send me the steps/procedure to build/support u-boot on x86_64 bit (Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz.
We need help from you is there any documentation to enable x86_64 bit pc or links to post my query.
What are the config/code i need to change to make my pc as host & target are the same.
Please help us to build the u-boot on x86_64.
Thank you! Best Regards, Manohar 8790215215
-----Original Message----- From: "Marek Vasut" marex@denx.de Sent: Friday, November 23, 2012 6:08am To: u-boot@lists.denx.de Cc: manohar.betham@smartplayin.com, "Graeme Russ" graeme.russ@gmail.com Subject: Re: [U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
Hi Manohar,
On 11/23/2012 04:46 PM, manohar.betham@smartplayin.com wrote:
Dear Marek,
I build the x86 U-Boot target on an x86_64 i7 Linux (Fedora) system using the standard GNU gcc package. There was an issue with the Makefile and there was a need to manually create some toolchain symlinks, but the was rectified some time ago. Are you using the latest mainline U-Boot from git.denx.de? If so, what errors are you getting - please provide a copy of your build output.
Are you planning on running U-Boot on an x86_64 machine? If so, you will need to create code to support that - Current U-Boot only supports 32-bit x86 targets. The sandbox target (designed for testing on a Linux host, not for downloading onto a board) should run on an x86_64 host.
Please provide more detail - what have you tried? What was the result? The build scripts should work as is on a properly configured x86_64 build machine
Regards,
Graeme
P.S. Please stop top posting - thanks
Dear Graeme,
Thank you!
I downloaded the u-boot-x86 on Ubuntu 11.10 loaded(Linux smart-OptiPlex-390 3.0.0-26-generic x86_64 GNU/Linux) intel i5 M1H61R-MB montherboard from the given below link.
http://git.denx.de/?p=u-boot/u-boot-x86.git;a=summary
and yes I am planning to run u-boot on x86_64 machine and my target is also x86_64 machine are the same . cd u-boot-x86 opened the boards.config file and appended my board details in the config file .
MIH61R-MB x86 x86 MIH61R-MB GenuineIntel - # Target ARCH CPU Board name Vendor SoC Options
and then run the below commands and i didnot modify any code other than that above line. .....................................................................................................................................
manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/u-boot-x86$ vim boards.cfg manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/u-boot-x86$ make distclean /bin/bash: i386-linux-gcc: command not found /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. /bin/bash: i386-linux-gcc: command not found basename: missing operand Try `basename --help' for more information. manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/u-boot-x86$ make MIH61R-MB_config Configuring for MIH61R-MB board... ln: creating symbolic link `asm/arch': No such file or directory make: *** [MIH61R-MB_config] Error 1 manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/u-boot-x86$ ...............................................................................................................................................................................................................................................................................................................................................
Please help me what are the files i need to modify and provide me the documentation.
-----Original Message----- From: "Graeme Russ" graeme.russ@gmail.com Sent: Friday, November 23, 2012 12:12pm To: manohar.betham@smartplayin.com Cc: "Marek Vasut" marex@denx.de, u-boot@lists.denx.de Subject: Re: [U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
Hi Manohar,
Dear Marek,
Regards,
Graeme
Hi Manohar,
On 11/23/2012 09:10 PM, manohar.betham@smartplayin.com wrote:
Dear Graeme,
Thank you!
Depending on when you downloaded it, you may not have the latest mainline which is at:
http://git.denx.de/?p=u-boot.git;a=summary
Nevertheless, you will have the latest x86 patches
Hmm, I don't think U-Boot is what your after. There are a few problems you will be faced with: - There is no ACPI support (no power management) - No System Management Mode (SMM) support - No chipset support (No RAM initialisation) - No Cache-As-RAM init code
Unless you have at least these covered, you will brick your board if you try to flash U-Boot. You might instead take a look at coreboot
[snip]
Ah, I now see that the patch I thought had been applied has not :(
You will need this patch:
http://patchwork.ozlabs.org/patch/155727/
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
Dear Graeme,
Thank you!
As of now I will try it for coreboot target on x86_64 machine.
I followed the steps given in patch file for x86 machine and modified and getting the below error.
manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/latest/u-boot$ make coreboot_config make: *** No rule to make target `coreboot_config'. Stop. make: *** [coreboot_config] Error 1
Please help me to build u-boot for coreboot.
Happy Weekend! Thank you! Best Regards, Manohar
8790215215
-----Original Message----- From: "Graeme Russ" graeme.russ@gmail.com Sent: Friday, November 23, 2012 4:23pm To: manohar.betham@smartplayin.com Cc: "Marek Vasut" marex@denx.de, u-boot@lists.denx.de, "Simon Glass" sjg@chromium.org Subject: Re: [U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
Hi Manohar,
Dear Graeme,
Thank you!
[snip]
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
Dear Graeme,
I am getting the below error once after build with coreboot.Please help me. ..................................................only error part copied..... ld.bfd --emit-relocs -Bsymbolic -Bsymbolic-functions -m elf_i386 -r -o libserial.o ns16550.o serial.o serial_ns16550.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/serial' make -C drivers/spi/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/spi' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/spi' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/spi' rm -f libspi.o; ar rcs libspi.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/spi' make -C drivers/twserial/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/twserial' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/twserial' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/twserial' rm -f libtws.o; ar rcs libtws.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/twserial' make -C drivers/usb/eth/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/eth' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/eth' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/eth' rm -f libusb_eth.o; ar rcs libusb_eth.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/eth' make -C drivers/usb/gadget/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/gadget' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/gadget' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/gadget' rm -f libusb_gadget.o; ar rcs libusb_gadget.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/gadget' make -C drivers/usb/host/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/host' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/host' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/host' rm -f libusb_host.o; ar rcs libusb_host.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/host' make -C drivers/usb/musb/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/musb' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/musb' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/musb' rm -f libusb_musb.o; ar rcs libusb_musb.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/musb' make -C drivers/usb/phy/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/phy' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/phy' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/phy' rm -f libusb_phy.o; ar rcs libusb_phy.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/phy' make -C drivers/usb/ulpi/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/ulpi' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/ulpi' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/ulpi' rm -f libusb_ulpi.o; ar rcs libusb_ulpi.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/usb/ulpi' make -C drivers/video/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/video' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/video' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/video' rm -f libvideo.o; ar rcs libvideo.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/video' make -C drivers/watchdog/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/watchdog' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/watchdog' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/watchdog' rm -f libwatchdog.o; ar rcs libwatchdog.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/drivers/watchdog' make -C fs/cbfs/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cbfs' gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ cbfs.o cbfs.c >.depend.cbfs cat /dev/null .depend.cbfs >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cbfs' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cbfs' gcc -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -fstack-usage -o cbfs.o cbfs.c -c ld.bfd --emit-relocs -Bsymbolic -Bsymbolic-functions -m elf_i386 -r -o libcbfs.o cbfs.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cbfs' make -C fs/cramfs/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cramfs' cat /dev/null >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cramfs' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cramfs' rm -f libcramfs.o; ar rcs libcramfs.o make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/cramfs' make -C fs/ext4/ make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/ext4' gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ ext4fs.o ext4fs.c >.depend.ext4fs gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ ext4_common.o ext4_common.c >.depend.ext4_common gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ dev.o dev.c >.depend.dev gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ ext4_journal.o ext4_journal.c >.depend.ext4_journal gcc -M -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -MQ crc16.o crc16.c >.depend.crc16 cat /dev/null .depend.ext4fs .depend.ext4_common .depend.dev .depend.ext4_journal .depend.crc16 >.depend make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/ext4' make[1]: Entering directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/ext4' gcc -g -Os -ffunction-sections -fvisibility=hidden -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0xFC0000 -I/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.6.1/include -pipe -fno-strict-aliasing -Wstrict-prototypes -mregparm=3 -fomit-frame-pointer -ffreestanding -fno-toplevel-reorder -fno-stack-protector -mpreferred-stack-boundary=2 -fno-dwarf2-cfi-asm -DREALMODE_BASE=0x7c0 -DCONFIG_X86 -D__I386__ -march=i386 -Werror -m32 -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -fstack-usage -o ext4fs.o ext4fs.c -c ext4fs.c: In function ‘ext4fs_write_file’: ext4fs.c:933:6: error: variable ‘delayed_skipfirst’ set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors
make[1]: *** [ext4fs.o] Error 1 make[1]: Leaving directory `/home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/fs/ext4' make: *** [fs/ext4/libext4fs.o] Error 2 ...........................
-----Original Message----- From: manohar.betham@smartplayin.com Sent: Friday, November 23, 2012 7:14pm To: "Graeme Russ" graeme.russ@gmail.com Cc: "Marek Vasut" marex@denx.de, u-boot@lists.denx.de, "Simon Glass" sjg@chromium.org Subject: Re: [U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
Dear Graeme,
Thank you!
8790215215
Hi Manohar,
Dear Graeme,
Thank you!
[snip]
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
I am getting the following error after running make all for coreboot target,from /usr/bin/ld.bfd.real: skipping incompatible /home/manoharb/Kernel_Tizen/intel_tizen/latest/u-boot/arch/x86/lib/libgcc.a when searching for -lgcc /usr/bin/ld.bfd.real: cannot find -lgcc make: *** [u-boot] Error 1
Please help me.
Hi Manohar,
Dear Graeme,
Thank you!
[snip]
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
Hi Manohar,
What toolchain (and version) are you using? I've never seen ld.bfd.real before
Regards,
Graeme
Please help me.
Hi Manohar,
Dear Graeme,
Thank you!
[snip]
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
Hi Graeme,
Thank you!
I am compiling on x86_64 bit for coreboot-x86 32 bit target ,gcc compiler version is (manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/latest/u-boot$ gcc -v Using built-in specs. COLLECT_GCC=/usr/bin/gcc-4.6.real COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6.1/lto-wrapper Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.1-9ubuntu3' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++,go --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Thread model: posix gcc version 4.6.1 (Ubuntu/Linaro 4.6.1-9ubuntu3) ) ... manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/latest/u-boot$ ls /usr/bin/ld* /usr/bin/ld /usr/bin/ld.bfd /usr/bin/ld.bfd.real /usr/bin/ldd /usr/bin/ld.gold /usr/bin/ld.gold.real manoharb@smart-OptiPlex-390:~/Kernel_Tizen/intel_tizen/latest/u-boot$
Please let me know the soln.
-----Original Message----- From: "Graeme Russ" graeme.russ@gmail.com Sent: Sunday, November 25, 2012 7:52am To: manohar.betham@smartplayin.com Cc: "Marek Vasut" marex@denx.de, u-boot@lists.denx.de, "Simon Glass" sjg@chromium.org Subject: Re: [U-Boot] Reg Bootstrapping u-boot on x86-64 for tizen
Hi Manohar,
Regards,
Graeme
Please help me.
Hi Manohar,
Dear Graeme,
Thank you!
[snip]
Regards,
Graeme
Hi Manohar,
Dear Marek,
Regards,
Graeme
Graeme Russ
