[U-Boot] [PATCH v2] rockchip: sdram-common: fix wrong size for 4GB in 32bit SoC
This is workaround for issue we can't get correct size for 4GB ram in 32bit system and available before we really need ram space out of 4GB, eg.enable ARM LAPE(rk3288 supports 8GB ram). The size of 4GB is '0x1 00000000', and this value will be truncated to 0 in 32bit system, and system can not get correct ram size. Rockchip SoCs reserve a blob of space for peripheral near 4GB, and we are now setting SDRAM_MAX_SIZE as max available space for ram in 4GB, so we can use this directly to workaround the issue.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - update the commit message and comment to show this is a workaround.
arch/arm/mach-rockchip/sdram_common.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/mach-rockchip/sdram_common.c b/arch/arm/mach-rockchip/sdram_common.c index 650d53e4d9..a27138083a 100644 --- a/arch/arm/mach-rockchip/sdram_common.c +++ b/arch/arm/mach-rockchip/sdram_common.c @@ -48,6 +48,24 @@ size_t rockchip_sdram_size(phys_addr_t reg) rank, col, bk, cs0_row, bw, row_3_4); }
+ /* + * This is workaround for issue we can't get correct size for 4GB ram + * in 32bit system and available before we really need ram space + * out of 4GB, eg.enable ARM LAPE(rk3288 supports 8GB ram). + * The size of 4GB is '0x1 00000000', and this value will be truncated + * to 0 in 32bit system, and system can not get correct ram size. + * Rockchip SoCs reserve a blob of space for peripheral near 4GB, + * and we are now setting SDRAM_MAX_SIZE as max available space for + * ram in 4GB, so we can use this directly to workaround the issue. + * TODO: + * 1. update correct value for SDRAM_MAX_SIZE as what dram + * controller sees. + * 2. update board_get_usable_ram_top() and dram_init_banksize() + * to reserve memory for peripheral space after previous update. + */ + if (size_mb > (SDRAM_MAX_SIZE >> 20)) + size_mb = (SDRAM_MAX_SIZE >> 20); + return (size_t)size_mb << 20; }
U-Boot SPL 2019.01-rc2+dfsg-1~20181228~1 (Dec 28 2018 - 23:14:06 +0000) Returning to boot ROM...
U-Boot 2019.01-rc2+dfsg-1~20181228~1 (Dec 28 2018 - 23:14:06 +0000)
Model: Firefly-RK3288 DRAM: 4 GiB MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Model: Firefly-RK3288 Net: Warning: ethernet@ff290000 (eth0) using random MAC address - 92:d3:c4:69:51:2c eth0: ethernet@ff290000 Hit any key to stop autoboot: 0
And it boots! First time I've seen u-boot working on the firefly-rk3288 since ... v2018.01
Thanks for all the fixes everyone!
Tested-By: Vagrant Cascadian vagrant@debian.org
live well, vagrant
Changes in v2:
* TODO:
* controller sees.
- if (size_mb > (SDRAM_MAX_SIZE >> 20))
- return (size_t)size_mb << 20;
-- 2.20.1
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Currently running on Travis … let’s see whether I need to remove the ‘TODO’ to get it to pass ;-)
Kever,
I agree that getting LPAE enabled on the RK3288 (in one of the next releases) would be great. We could then turn on PHYS64_BIT, never worry about this again (and not need a workaround at all) and have the hardware’s capabilities accurately modelled.
Let me know if I can do anything to help towards that goal.
Thanks, Philipp.
Changes in v2:
* TODO:
* controller sees.
-- 2.20.1
Changes in v2:
Reviewed-by: Simon Glass sjg@chromium.org Tested on chromebook_minnie: Tested-by: Simon Glass sjg@chromium.org
Kever Yang
Philipp Tomsich
Vagrant Cascadian
