[U-Boot] Too Much Email
How can I go about configuring u-boot email to only send emails that pertain to a response to my question?
Thanks Jack
John M Moran General Dynamics C4S 77 "A" St. Needham, MA, 02494 Phone: 781-455-4071 Email: jack.moran@gdc4s.com
Dear "Moran, Jack",
In message 3DFFB0670A395946974CE996C72073241BF283C5@NDHMC4SXCH.gdc4s.com you wrote:
You cannot. This is a mailing list.
If you don;t want to receive thelist messages, you can always unsubscribe.
Hello Moran, Jack,
Am 2010-07-18 09:08:05, hacktest Du folgendes herunter:
You can't.
But maybe you setup a local filter (procmail, maildrop, sieve, ...) and filter <u-boot> messages to a seperated folder?
Thanks, Greetings and nice Day/Evening Michelle Konzack
Hi Moran.
create one message filter in your email client. :)
Thanks Jack
get_timer_masked() should return current timestamp, not current ticks from hardware register.
Tested on one custom board with NAND flash. Without this patch, NAND write always TIMEOUT because get_timer(0) return a big value.
This patch applies for u-boot-2010.06
Signed-off-by: Li Haibo hbli@sinocastel.com --- arch/arm/cpu/arm_cortexa8/mx51/timer.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm_cortexa8/mx51/timer.c b/arch/arm/cpu/arm_cortexa8/mx51/timer.c index 81c4a06..110edbf 100644 --- a/arch/arm/cpu/arm_cortexa8/mx51/timer.c +++ b/arch/arm/cpu/arm_cortexa8/mx51/timer.c @@ -89,7 +89,7 @@ ulong get_timer_masked(void) timestamp += ((0xFFFFFFFF / (CONFIG_MX51_CLK32 / CONFIG_SYS_HZ)) - lastinc) + val; lastinc = val; - return val; + return timestamp; }
ulong get_timer(ulong base)
Dear Stefano,
Can you please have a look at this, and eventually send a pull req? Thanks.
Wolfgang Denk wrote:
Dear Stefano,
Hi Wolfgang,
Thanks, I missed it. I would change the name of the maintainer and I will set myself for the MX51EVK, because Fred Fan resigned as maintainer for this board.
Li, could you please resend your patch as text ? It was sent as base-64 encoded, and I cannot directly apply it.
Thanks, Stefano Babic
Dear Stefano,
Hi Wolfgang,
Dear Stefano,
Hi Wolfgang,
Hi Haibo Li
I am try to help on test patch. :) you should not include the reply in your patch. those reply message will goto git commit message which is not needed.
Dear Stefano,
Hi Wolfgang,
Hi Haibo Li
Dear Stefano,
Hi Wolfgang,
Hi Liu: Thanks for you help, but I need more :) I'm newbie to such maillist. I post this small patch to check if everything is OK, but...
There are something I want know: 1. Does "base-64 encoded" problem still exist in this message? 2. Should I follow this thread, or resend a new one?
Hi
- Does "base-64 encoded" problem still exist in this message?
the last two emails you send are same. first one is "base-64 encoded" second is good.
- Should I follow this thread, or resend a new one?
I think send a new one title with "[PATCH] v2". you should use "git send-email" to send patch emails.
participants (7)
"Xiangfu Liu(刘向富)"
Li Haibo
Michelle Konzack
Moran, Jack
Stefano Babic
Xiangfu Liu
