[U-Boot] [PATCH] common:usb_kbd:Add key values of F1~F12
When you press the F1~F12 button from the USB keyboard, the reference Fn key table(usb_kbd_fn_key[]),the key value(0xf0~0xfb) will be returned, and you can use it to do more things.
Signed-off-by: Leo Wen leo.wen@rock-chips.com --- common/usb_kbd.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index d2d29cc..7c96c78 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -73,6 +73,10 @@ static const unsigned char usb_kbd_num_keypad[] = { '1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '.', 0, 0, 0, '=' }; +static const unsigned char usb_kbd_fn_key[] = { + 0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, + 0xf6, 0xf7, 0xf8, 0xf9, 0xfa, 0xfb +};
/* * map arrow keys to ^F/^B ^N/^P, can't really use the proper @@ -206,6 +210,9 @@ static int usb_kbd_translate(struct usb_kbd_pdata *data, unsigned char scancode, else keycode = usb_kbd_numkey[scancode - 0x1e]; } + /* Fn keys pressed */ + if ((scancode >= 0x3a) && (scancode <= 0x45)) + keycode = usb_kbd_fn_key[scancode - 0x3a];
/* Arrow keys */ if ((scancode >= 0x4f) && (scancode <= 0x52))
How does doing this code (in usb_kbd.c) relate to the translation matrices in drivers/input/input.c (which maps from a scancode—i.e. ’typical AT-101 position’ column in the USB HUT document—to the internal character value in U-Boot)?
And should we even expose the function keys via getc() instead of generating escape sequences? The key values 0xf0 through 0xfb are usually not associated with F1 through F12.
Note that with drivers/input/input.c, I would expect escapes to be generated for KEY_F1 (\033OP) through KEY_F12 (\033[24~)… which would need to be added to the kbd_to_ansi364 table.
- 0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5,
- 0xf6, 0xf7, 0xf8, 0xf9, 0xfa, 0xfb
Why did you choose these values to encode F1 through F12? Is there some precedent for using these character codes for these keys?
- map arrow keys to ^F/^B ^N/^P, can't really use the proper
-- 2.7.4
On 9 August 2017 at 04:33, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
There is no relation unfortunately. The usb protocol uses a different encoding I believe.
I think escape codes should be used, but I am not an expert on this.
keycode = usb_kbd_fn_key[scancode - 0x3a]; /* Arrow keys */ if ((scancode >= 0x4f) && (scancode <= 0x52))
-- 2.7.4
Dr. Philipp Tomsich
Leo Wen
