[U-Boot-Users] [PATCH] ppc_4xx resubmit: Netstal HCU5 board. Added POST. Various fixes
- Various fixes - Reduced rom_size from 384 to 320 kB - Environment is now in flash - Added POST - Support for OF
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- board/netstal/hcu5/config.mk | 2 +- board/netstal/hcu5/u-boot.lds | 2 +- include/configs/hcu5.h | 136 +++++++++++++++++++++++++--------------- 3 files changed, 87 insertions(+), 53 deletions(-)
diff --git a/board/netstal/hcu5/config.mk b/board/netstal/hcu5/config.mk index cfd5744..51ddb76 100644 --- a/board/netstal/hcu5/config.mk +++ b/board/netstal/hcu5/config.mk @@ -21,7 +21,7 @@ # Netstal Maschinen AG: HCU5 boards #
-TEXT_BASE = 0xFFFa0000 +TEXT_BASE = 0xFFFB0000
PLATFORM_CPPFLAGS += -DCONFIG_440=1
diff --git a/board/netstal/hcu5/u-boot.lds b/board/netstal/hcu5/u-boot.lds index c517f7b..2c48316 100644 --- a/board/netstal/hcu5/u-boot.lds +++ b/board/netstal/hcu5/u-boot.lds @@ -137,7 +137,7 @@ SECTIONS *(COMMON) }
- ppcenv_assert = ASSERT(. < 0xFFFF8000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + ppcenv_assert = ASSERT(. < 0xFFFFB000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified.");
_end = . ; PROVIDE (end = .); diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h index 1214bc3..d66c47a 100644 --- a/include/configs/hcu5.h +++ b/include/configs/hcu5.h @@ -48,14 +48,16 @@ * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) *----------------------------------------------------------------------*/ -#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ -#define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */ +#define CFG_MONITOR_LEN (320 * 1024) /* Reserve 320 kB for Monitor */ +#define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */
+#define CFG_TLB_FOR_BOOT_FLASH 3 #define CFG_BOOT_BASE_ADDR 0xfff00000 #define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ #define CFG_FLASH_BASE 0xfff80000 /* start of FLASH */ #define CFG_MONITOR_BASE TEXT_BASE #define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_OCM_DATA_ADDR CFG_OCM_BASE #define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ #define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ #define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 @@ -78,14 +80,15 @@ #define CFG_INIT_RAM_END (4 << 10) #define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) -#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET +#define CFG_INIT_SP_OFFSET CFG_POST_WORD_ADDR
/*----------------------------------------------------------------------- * Serial Port *----------------------------------------------------------------------*/ #undef CFG_EXT_SERIAL_CLOCK /* external serial clock */ #define CONFIG_BAUDRATE 9600 -#undef CONFIG_SERIAL_MULTI /* needed to be able to define +#define CONFIG_SERIAL_MULTI 1 +/* needed to be able to define CONFIG_SERIAL_SOFTWARE_FIFO, but CONFIG_SERIAL_SOFTWARE_FIFO (16) does not work */ /* Size (bytes) of interrupt driven serial port buffer. @@ -95,6 +98,7 @@ #undef CONFIG_SERIAL_SOFTWARE_FIFO #undef CONFIG_UART1_CONSOLE
+#undef CONFIG_CMD_HWFLOW #define CFG_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
@@ -103,8 +107,8 @@ *----------------------------------------------------------------------*/
#undef CFG_ENV_IS_IN_NVRAM -#undef CFG_ENV_IS_IN_FLASH -#define CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_IS_IN_FLASH +#undef CFG_ENV_IS_IN_EEPROM #undef CFG_ENV_IS_NOWHERE
#ifdef CFG_ENV_IS_IN_EEPROM @@ -117,22 +121,28 @@
#ifdef CFG_ENV_IS_IN_FLASH /* Put the environment in Flash */ -#define CFG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ +#define CFG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ #define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) -#define CFG_ENV_SIZE 0x10000 /* Total Size of Environment Sector */ +#define CFG_ENV_SIZE 8*1024 /* 8 KB Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) + #endif
/*----------------------------------------------------------------------- * DDR SDRAM *----------------------------------------------------------------------*/ -#define CFG_MBYTES_SDRAM (128) /* 128 MB or 256 MB */ -#define CFG_DDR_CACHED_ADDR 0x40000000 /* setup 2nd TLB cached here */ -#undef CONFIG_DDR_DATA_EYE /* Do not use DDR2 optimization */ -#define CONFIG_DDR_ECC 1 /* enable ECC */ +#define CFG_MBYTES_SDRAM (128) /* 128 MB or 256 MB */ +#define CFG_DDR_CACHED_ADDR 0x50000000 /* setup 2nd TLB cached here */ +#undef CONFIG_DDR_DATA_EYE /* Do not use DDR2 optimization */ +#define CONFIG_DDR_ECC 1 /* enable ECC */ + +/* Following two definitions must be kept in sync with config.h of vxWorks */ +#define USER_RESERVED_MEM ( 0) /* in kB */ +#define PM_RESERVED_MEM ( 64) /* in kB: pmLib reserved area size */ +#define CONFIG_PRAM ( USER_RESERVED_MEM + PM_RESERVED_MEM )
/*----------------------------------------------------------------------- * I2C stuff for a ATMEL AT24C16 (2kB holding ENV, we are using the @@ -165,8 +175,8 @@
/* Setup some board specific values for the default environment variables */ #define CONFIG_HOSTNAME hcu5 -#define CONFIG_IPADDR 172.25.1.42 -#define CONFIG_ETHADDR 00:60:13:00:00:00 /* Netstal Machines AG MAC */ +#define CONFIG_IPADDR 172.25.1.99 +#define CONFIG_ETHADDR 00:60:13:00:00:00 /* Netstal Machines AG MAC */ #define CONFIG_OVERWRITE_ETHADDR_ONCE #define CONFIG_SERVERIP 172.25.1.3
@@ -187,21 +197,27 @@ "bootfile=hcu5/uImage\0" \ "rootpath=/home/hcu/eldk/ppc_4xxFP\0" \ "load=tftp 100000 hcu5/u-boot.bin\0" \ - "update=protect off FFFa0000 FFFFFFFF;era FFFa0000 FFFFFFFF;" \ - "cp.b 100000 FFFa0000 60000\0" \ + "update=protect off FFFb0000 FFFFFFFF;era FFFb0000 FFFFFFFF;" \ + "cp.b 100000 FFFb0000 50000\0" \ "upd=run load;run update\0" \ - "vx=tftp ${loadaddr} hcu5/hcu5_vx_rom;" \ - "setenv bootargs emac(0,0)hcu5_vx_rom e=${ipaddr} " \ - " h=${serverip} u=dpu pw=netstal8752 tn=hcu5 f=0x3008;" \ - "bootvx ${loadaddr}\0" \ + "vx=tftp ${loadaddr} hcu5/hcu5_vx_rom; run vxboot\0" \ + "vxusb=usb start; fatload usb 0 ${loadaddr} vxWorks.st; run vxboot\0" \ + "vxargs=emac(0,0)c:hcu5/hcu5_vx_rom e=${ipaddr} h=${serverip}" \ + " u=dpu pw=netstal8752 tn=hcu5 f=0x3008\0" \ + "vxboot=setenv bootargs $(vxargs); bootvx ${loadaddr}\0" \ + "usbargs=setenv bootargs root=/dev/sda1 ro\0" \ + "linux=usb start; ext2load usb 0 ${loadaddr} /boot/uImage;" \ + "run usbargs addip addtty; bootm\0" \ + "net_nfs_fdt=tftp 200000 ${bootfile};" \ + "tftp ${fdt_addr} ${fdt_file};" \ + "run nfsargs addip addtty;" \ + "bootm 200000 - ${fdt_addr}\0" \ + "fdt_file=hcu5/hcu5.dtb\0" \ + "fdt_addr=400000\0" \ "" #define CONFIG_BOOTCOMMAND "run vx"
-#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ @@ -214,7 +230,7 @@ #define CONFIG_PHY_RESET 1 /* reset phy upon startup */
#define CONFIG_HAS_ETH0 -#define CFG_RX_ETH_BUFFER 32 /* Number of ethernet rx buffers & descriptors */ +#define CFG_RX_ETH_BUFFER 32 /* Number of ethernet rx buffers & desc. */
#define CONFIG_NET_MULTI 1 #define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ @@ -246,7 +262,6 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BSP #define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM @@ -264,6 +279,21 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_USB
+/* POST support */ +#define CONFIG_POST (CFG_POST_MEMORY | \ + CFG_POST_CPU | \ + CFG_POST_UART | \ + CFG_POST_I2C | \ + CFG_POST_CACHE | \ + CFG_POST_FPU | \ + CFG_POST_ETHER | \ + CFG_POST_SPR) +#define CFG_POST_UART_TABLE {UART0_BASE} + +#define CFG_POST_WORD_ADDR (CFG_GBL_DATA_OFFSET - 0x4) +#define CFG_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */ +#define CFG_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ + #define CONFIG_SUPPORT_VFAT
/*----------------------------------------------------------------------- @@ -276,7 +306,7 @@ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #endif -#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
@@ -291,17 +321,16 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
/*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ /* General PCI */ -#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI 1 /* include pci support */ #undef CONFIG_PCI_PNP /* do (not) pci plug-and-play */ -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE*/ +#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr map to CFG_PCI_MEMBASE*/
/* Board-specific PCI */ #define CFG_PCI_TARGET_INIT @@ -315,7 +344,17 @@ * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * Flash + *----------------------------------------------------------------------*/ + +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 8 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup @@ -324,40 +363,30 @@ #define CFG_CS_1 0xC8000000 /* CAN */ #define CFG_CS_2 0xCC000000 /* CPLD and IMC-Bus Standard */ #define CFG_CPLD CFG_CS_2 -#define CFG_CS_3 0xCD000000 /* CPLD and IMC-Bus Fast */ +#define CFG_CS_3 0xCE000000 /* CPLD and IMC-Bus Fast */
-/*----------------------------------------------------------------------- - * FLASH organization - * Memory Bank 0 (BOOT-FLASH) initialization - */ -#define CFG_BOOTFLASH_CS 0 /* Boot Flash chip connected to CSx */ +#define CFG_BOOTFLASH_CS 0 /* Boot Flash chip connected to CSx */ #define CFG_EBC_PB0AP 0x02005400 #define CFG_EBC_PB0CR 0xFFF18000 /* (CFG_FLASH | 0xda000) */ #define FLASH_BASE0_PRELIM CFG_FLASH_BASE /* FLASH bank #0 */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 32 /* max number of sectors on one chip */ -
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -/* Memory Bank 1 CAN-Chips initialization */ +/* Memory Bank 1 CAN-Chips initialization */ #define CFG_EBC_PB1AP 0x02054500 #define CFG_EBC_PB1CR 0xC8018000
-/* Memory Bank 2 CPLD/IMC-Bus standard initialization */ +/* Memory Bank 2 CPLD/IMC-Bus standard initialization */ #define CFG_EBC_PB2AP 0x01840300 #define CFG_EBC_PB2CR 0xCC0BA000
-/* Memory Bank 3 IMC-Bus fast mode initialization */ +/* Memory Bank 3 IMC-Bus fast mode initialization */ #define CFG_EBC_PB3AP 0x01800300 #define CFG_EBC_PB3CR 0xCE0BA000
-/* Memory Bank 4 (not used) initialization */ +/* Memory Bank 4 (not used) initialization */ #undef CFG_EBC_PB4AP #undef CFG_EBC_PB4CR
-/* Memory Bank 5 (not used) initialization */ +/* Memory Bank 5 (not used) initialization */ #undef CFG_EBC_PB5AP #undef CFG_EBC_PB5CR
@@ -369,8 +398,8 @@ * * Boot Flags */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */
#define CFG_HUSH_PARSER /* use "hush" command parser */ #ifdef CFG_HUSH_PARSER @@ -381,4 +410,9 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + #endif /* __CONFIG_H */
On Wednesday 16 January 2008, Niklaus Giger wrote:
- Various fixes
- Added POST
- Support for OF
Applied, thanks.
Best regards, Stefan
Niklaus Giger
Stefan Roese
