[U-Boot] [PATCH 0/6] board: atmel: Add new board: SAMA5D27-SOM1-EK board.
It is based on [PATCH v2 0/8] sf: improve support of (Q)SPI flash memories https://lists.denx.de/pipermail/u-boot/2017-July/298806.html
Wenyou Yang (6): ARM: at91: spl: Adjust switching to oscillator for SAMA5D2 ARM: at91: spl: Add mck function to lower rate while switching ARM: at91: spl: Add boot device for boot from QSPI ARM: at91: mach: Add missing defines of MPDDRC ARM: at91: Get the Chip ID of SAMA5D2 SiP board: atmel: Add SAMA5D27 SOM1 EK board
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-sama5d27_som1_ek.dts | 155 ++++++++++++++++++ arch/arm/dts/sama5d2.dtsi | 20 +++ arch/arm/dts/sama5d27_som1.dtsi | 154 ++++++++++++++++++ arch/arm/mach-at91/Kconfig | 7 + arch/arm/mach-at91/armv7/clock.c | 36 +++++ arch/arm/mach-at91/armv7/sama5d2_devices.c | 26 ++- arch/arm/mach-at91/include/mach/at91_common.h | 1 + arch/arm/mach-at91/include/mach/at91_pmc.h | 2 + arch/arm/mach-at91/include/mach/atmel_mpddrc.h | 4 + arch/arm/mach-at91/include/mach/sama5d2.h | 7 +- arch/arm/mach-at91/spl.c | 2 + arch/arm/mach-at91/spl_atmel.c | 18 ++- board/atmel/sama5d27_som1_ek/Kconfig | 15 ++ board/atmel/sama5d27_som1_ek/MAINTAINERS | 6 + board/atmel/sama5d27_som1_ek/Makefile | 8 + board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 206 ++++++++++++++++++++++++ configs/sama5d27_som1_ek_mmc_defconfig | 82 ++++++++++ configs/sama5d27_som1_ek_spiflash_defconfig | 82 ++++++++++ include/configs/sama5d27_som1_ek.h | 100 ++++++++++++ 20 files changed, 930 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/at91-sama5d27_som1_ek.dts create mode 100644 arch/arm/dts/sama5d27_som1.dtsi create mode 100644 board/atmel/sama5d27_som1_ek/Kconfig create mode 100644 board/atmel/sama5d27_som1_ek/MAINTAINERS create mode 100644 board/atmel/sama5d27_som1_ek/Makefile create mode 100644 board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c create mode 100644 configs/sama5d27_som1_ek_mmc_defconfig create mode 100644 configs/sama5d27_som1_ek_spiflash_defconfig create mode 100644 include/configs/sama5d27_som1_ek.h
As said in 29.5.7 section of SAMA5D2 datasheet, before switching to the crystal oscillator, a check must be carried out to ensure that the oscillator is present and that its freqency is valid.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com ---
arch/arm/mach-at91/include/mach/at91_pmc.h | 2 ++ arch/arm/mach-at91/spl_atmel.c | 18 +++++++++++++++++- 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index 2875ff20b1..08ad1bf2d0 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -87,6 +87,8 @@ typedef struct at91_pmc {
#define AT91_PMC_MCFR_MAINRDY 0x00010000 #define AT91_PMC_MCFR_MAINF_MASK 0x0000FFFF +#define AT91_PMC_MCFR_RCMEAS 0x00100000 +#define AT91_PMC_MCFR_CCSS_XTAL_OSC 0x01000000
#define AT91_PMC_MCKR_CSS_SLOW 0x00000000 #define AT91_PMC_MCKR_CSS_MAIN 0x00000001 diff --git a/arch/arm/mach-at91/spl_atmel.c b/arch/arm/mach-at91/spl_atmel.c index b75c2ccefd..ce16ef3bdb 100644 --- a/arch/arm/mach-at91/spl_atmel.c +++ b/arch/arm/mach-at91/spl_atmel.c @@ -32,6 +32,20 @@ static void switch_to_main_crystal_osc(void) while (!(readl(&pmc->sr) & AT91_PMC_IXR_MOSCS)) ;
+#if defined(CONFIG_SAMA5D2) + /* Enable a measurement of the external oscillator */ + tmp = readl(&pmc->mcfr); + tmp |= AT91_PMC_MCFR_CCSS_XTAL_OSC; + tmp |= AT91_PMC_MCFR_RCMEAS; + writel(tmp, &pmc->mcfr); + + while (!(readl(&pmc->mcfr) & AT91_PMC_MCFR_MAINRDY)) + ; + + if (!(readl(&pmc->mcfr) & AT91_PMC_MCFR_MAINF_MASK)) + hang(); +#endif + tmp = readl(&pmc->mor); tmp &= ~AT91_PMC_MOR_OSCBYPASS; tmp &= ~AT91_PMC_MOR_KEY(0xff); @@ -47,11 +61,13 @@ static void switch_to_main_crystal_osc(void) while (!(readl(&pmc->sr) & AT91_PMC_IXR_MOSCSELS)) ;
+#if !defined(CONFIG_SAMA5D2) /* Wait until MAINRDY field is set to make sure main clock is stable */ while (!(readl(&pmc->mcfr) & AT91_PMC_MAINRDY)) ; +#endif
-#ifndef CONFIG_SAMA5D4 +#if !defined(CONFIG_SAMA5D4) && !defined(CONFIG_SAMA5D2) tmp = readl(&pmc->mor); tmp &= ~AT91_PMC_MOR_MOSCRCEN; tmp &= ~AT91_PMC_MOR_KEY(0xff);
Refer to the commit 70f8c8316ad(PMC: add new mck function to lower rate while switching) from AT91Bootstrap.
While switching to a lower clock source, we must switch the clock source first instead of last. Otherwise, we could end up with too high frequency on internal bus and peripherals. This happen on SAMA5D2 as we exit from ROM code @396MHz.
Add a function pmc_mck_init_down() to allow this sequence.
arch/arm/mach-at91/armv7/clock.c | 36 +++++++++++++++++++++++++++ arch/arm/mach-at91/include/mach/at91_common.h | 1 + 2 files changed, 37 insertions(+)
diff --git a/arch/arm/mach-at91/armv7/clock.c b/arch/arm/mach-at91/armv7/clock.c index 2e55953799..8ae01f4020 100644 --- a/arch/arm/mach-at91/armv7/clock.c +++ b/arch/arm/mach-at91/armv7/clock.c @@ -150,6 +150,42 @@ void at91_mck_init(u32 mckr) ; }
+void at91_mck_init_down(u32 mckr) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + u32 tmp; + + tmp = readl(&pmc->mckr); + tmp &= (~AT91_PMC_MCKR_CSS_MASK); + tmp |= (mckr & AT91_PMC_MCKR_CSS_MASK); + writel(tmp, &pmc->mckr); + + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; + +#ifdef CPU_HAS_H32MXDIV + tmp = readl(&pmc->mckr); + tmp &= (~AT91_PMC_MCKR_H32MXDIV); + tmp |= (mckr & AT91_PMC_MCKR_H32MXDIV); + writel(tmp, &pmc->mckr); +#endif + + tmp = readl(&pmc->mckr); + tmp &= (~AT91_PMC_MCKR_PLLADIV_MASK); + tmp |= (mckr & AT91_PMC_MCKR_PLLADIV_MASK); + writel(tmp, &pmc->mckr); + + tmp = readl(&pmc->mckr); + tmp &= (~AT91_PMC_MCKR_MDIV_MASK); + tmp |= (mckr & AT91_PMC_MCKR_MDIV_MASK); + writel(tmp, &pmc->mckr); + + tmp = readl(&pmc->mckr); + tmp &= (~AT91_PMC_MCKR_PRES_MASK); + tmp |= (mckr & AT91_PMC_MCKR_PRES_MASK); + writel(tmp, &pmc->mckr); +} + int at91_enable_periph_generated_clk(u32 id, u32 clk_source, u32 div) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; diff --git a/arch/arm/mach-at91/include/mach/at91_common.h b/arch/arm/mach-at91/include/mach/at91_common.h index 0742ffc56f..381312709f 100644 --- a/arch/arm/mach-at91/include/mach/at91_common.h +++ b/arch/arm/mach-at91/include/mach/at91_common.h @@ -25,6 +25,7 @@ void at91_lcd_hw_init(void); void at91_plla_init(u32 pllar); void at91_pllb_init(u32 pllar); void at91_mck_init(u32 mckr); +void at91_mck_init_down(u32 mckr); void at91_pmc_init(void); void mem_init(void); void at91_phy_reset(void);
Hi Wenyou,
Can this move into a clock driver instead?
Hi Simon,
On 2017/7/28 12:20, Simon Glass wrote:
Hi Wenyou,
This is used for SPL, due to the limitation of the size of SRAM, it is not easy to move to the clock driver.
Best Regards, Wenyou Yang
Add the boot device for booting from the QSPI flash.
arch/arm/mach-at91/spl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-at91/spl.c b/arch/arm/mach-at91/spl.c index e113336b7b..98337aebbe 100644 --- a/arch/arm/mach-at91/spl.c +++ b/arch/arm/mach-at91/spl.c @@ -56,6 +56,8 @@ u32 spl_boot_device(void) if (dev == ATMEL_SAMA5_BOOT_FROM_SPI) return BOOT_DEVICE_SPI; #endif + if (dev == ATMEL_SAMA5_BOOT_FROM_QSPI) + return BOOT_DEVICE_SPI;
if (dev == ATMEL_SAMA5_BOOT_FROM_SMC) return BOOT_DEVICE_NAND;
Add missing defines of Multiport DDR-SDRAM Controller (MPDDRC).
arch/arm/mach-at91/include/mach/atmel_mpddrc.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/mach-at91/include/mach/atmel_mpddrc.h b/arch/arm/mach-at91/include/mach/atmel_mpddrc.h index 803501f5cf..40e1cf0a0a 100644 --- a/arch/arm/mach-at91/include/mach/atmel_mpddrc.h +++ b/arch/arm/mach-at91/include/mach/atmel_mpddrc.h @@ -96,6 +96,10 @@ int ddr3_init(const unsigned int base, #define ATMEL_MPDDRC_CR_DLL_RESET_ENABLED (0x1 << 7) #define ATMEL_MPDDRC_CR_DIC_DS (0x1 << 8) #define ATMEL_MPDDRC_CR_DIS_DLL (0x1 << 9) +#define ATMEL_MPDDRC_CR_ZQ_INIT (0x0 << 10) +#define ATMEL_MPDDRC_CR_ZQ_LONG (0x1 << 10) +#define ATMEL_MPDDRC_CR_ZQ_SHORT (0x2 << 10) +#define ATMEL_MPDDRC_CR_ZQ_RESET (0x3 << 10) #define ATMEL_MPDDRC_CR_OCD_DEFAULT (0x7 << 12) #define ATMEL_MPDDRC_CR_DQMS_SHARED (0x1 << 16) #define ATMEL_MPDDRC_CR_ENRDM_ON (0x1 << 17)
The SAMA5D2 SiP(System in Package) has different Chip IDs in the CHIPID and CHIP_EXID registers.
arch/arm/mach-at91/armv7/sama5d2_devices.c | 26 ++++++++++++++++++++++++-- arch/arm/mach-at91/include/mach/sama5d2.h | 7 ++++++- 2 files changed, 30 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-at91/armv7/sama5d2_devices.c b/arch/arm/mach-at91/armv7/sama5d2_devices.c index 978eac29bd..de1d9b5bfb 100644 --- a/arch/arm/mach-at91/armv7/sama5d2_devices.c +++ b/arch/arm/mach-at91/armv7/sama5d2_devices.c @@ -10,11 +10,20 @@ #include <asm/arch/clk.h> #include <asm/arch/sama5d2.h>
-char *get_cpu_name() +int cpu_is_sama5d2(void) { + unsigned int chip_id = get_chip_id(); + + return ((chip_id == ARCH_ID_SAMA5D2) || + (chip_id == ARCH_ID_SAMA5D2_SIP)) ? 1 : 0; +} + +char *get_cpu_name(void) +{ + unsigned int chip_id = get_chip_id(); unsigned int extension_id = get_extension_chip_id();
- if (cpu_is_sama5d2()) { + if (chip_id == ARCH_ID_SAMA5D2) { switch (extension_id) { case ARCH_EXID_SAMA5D21CU: return "SAMA5D21"; @@ -41,6 +50,19 @@ char *get_cpu_name() } }
+ if ((chip_id == ARCH_ID_SAMA5D2) || (chip_id == ARCH_ID_SAMA5D2_SIP)) { + switch (extension_id) { + case ARCH_EXID_SAMA5D225C_D1M: + return "SAMA5D225 128M bits DDR2 SDRAM"; + case ARCH_EXID_SAMA5D27C_D5M: + return "SAMA5D27 512M bits DDR2 SDRAM"; + case ARCH_EXID_SAMA5D27C_D1G: + return "SAMA5D27 1G bits DDR2 SDRAM"; + case ARCH_EXID_SAMA5D28C_D1G: + return "SAMA5D28 1G bits DDR2 SDRAM"; + } + } + return "Unknown CPU type"; }
diff --git a/arch/arm/mach-at91/include/mach/sama5d2.h b/arch/arm/mach-at91/include/mach/sama5d2.h index 25c85411e5..49283ed86b 100644 --- a/arch/arm/mach-at91/include/mach/sama5d2.h +++ b/arch/arm/mach-at91/include/mach/sama5d2.h @@ -222,7 +222,11 @@ #define ARCH_EXID_SAMA5D28CU 0x00000010 #define ARCH_EXID_SAMA5D28CN 0x00000020
-#define cpu_is_sama5d2() (get_chip_id() == ARCH_ID_SAMA5D2) +#define ARCH_ID_SAMA5D2_SIP 0x8a5c08c2 +#define ARCH_EXID_SAMA5D225C_D1M 0x00000053 +#define ARCH_EXID_SAMA5D27C_D5M 0x00000032 +#define ARCH_EXID_SAMA5D27C_D1G 0x00000033 +#define ARCH_EXID_SAMA5D28C_D1G 0x00000013
/* PIT Timer(PIT_PIIR) */ #define CONFIG_SYS_TIMER_COUNTER 0xf804803c @@ -233,6 +237,7 @@ #ifndef __ASSEMBLY__ unsigned int get_chip_id(void); unsigned int get_extension_chip_id(void); +int cpu_is_sama5d2(void); unsigned int has_lcdc(void); char *get_cpu_name(void); #endif
The SAMA5D27-SiP (System in Package) integrates the SAMA5D2 with 1Gbit DDR2-SDRAM in a single package.
The SAMA5D27 SOM1 embeds a 64Mbit QSPI flash, KSZ8081 Phy and Mac-address EEPROM.
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-sama5d27_som1_ek.dts | 155 ++++++++++++++++++ arch/arm/dts/sama5d2.dtsi | 20 +++ arch/arm/dts/sama5d27_som1.dtsi | 154 ++++++++++++++++++ arch/arm/mach-at91/Kconfig | 7 + board/atmel/sama5d27_som1_ek/Kconfig | 15 ++ board/atmel/sama5d27_som1_ek/MAINTAINERS | 6 + board/atmel/sama5d27_som1_ek/Makefile | 8 + board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 206 ++++++++++++++++++++++++ configs/sama5d27_som1_ek_mmc_defconfig | 82 ++++++++++ configs/sama5d27_som1_ek_spiflash_defconfig | 82 ++++++++++ include/configs/sama5d27_som1_ek.h | 100 ++++++++++++ 12 files changed, 838 insertions(+) create mode 100644 arch/arm/dts/at91-sama5d27_som1_ek.dts create mode 100644 arch/arm/dts/sama5d27_som1.dtsi create mode 100644 board/atmel/sama5d27_som1_ek/Kconfig create mode 100644 board/atmel/sama5d27_som1_ek/MAINTAINERS create mode 100644 board/atmel/sama5d27_som1_ek/Makefile create mode 100644 board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c create mode 100644 configs/sama5d27_som1_ek_mmc_defconfig create mode 100644 configs/sama5d27_som1_ek_spiflash_defconfig create mode 100644 include/configs/sama5d27_som1_ek.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 132fa69fe5..0a68663e9f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -404,6 +404,9 @@ dtb-$(CONFIG_TARGET_OMAP3_LOGIC) += \ dtb-$(CONFIG_TARGET_SAMA5D2_XPLAINED) += \ at91-sama5d2_xplained.dtb
+dtb-$(CONFIG_TARGET_SAMA5D27_SOM1_EK) += \ + at91-sama5d27_som1_ek.dtb + dtb-$(CONFIG_TARGET_SAMA5D3XEK) += \ sama5d31ek.dtb \ sama5d33ek.dtb \ diff --git a/arch/arm/dts/at91-sama5d27_som1_ek.dts b/arch/arm/dts/at91-sama5d27_som1_ek.dts new file mode 100644 index 0000000000..e4384cdf85 --- /dev/null +++ b/arch/arm/dts/at91-sama5d27_som1_ek.dts @@ -0,0 +1,155 @@ +/* + * at91-sama5d27_som1_ek.dts - Device Tree file for SAMA5D27 SOM1 EK board + * + * Copyright (C) 2017 Microchip Corporation + * Wenyou Yang wenyou.yang@microchip.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ +/dts-v1/; +#include "sama5d27_som1.dtsi" + +/ { + model = "Atmel SAMA5D27 SOM1 EK"; + compatible = "atmel,sama5d27-som1-ek", "atmel,sama5d2", "atmel,sama5"; + + chosen { + u-boot,dm-pre-reloc; + stdout-path = &uart1; + }; + + ahb { + usb1: ohci@00400000 { + num-ports = <3>; + atmel,vbus-gpio = <&pioA 42 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + status = "okay"; + }; + + usb2: ehci@00500000 { + status = "okay"; + }; + + sdmmc0: sdio-host@a0000000 { + bus-width = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc0_cmd_dat_default &pinctrl_sdmmc0_ck_cd_default>; + status = "okay"; + u-boot,dm-pre-reloc; + }; + + sdmmc1: sdio-host@b0000000 { + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc1_cmd_dat_default &pinctrl_sdmmc1_ck_cd_default>; + status = "okay"; /* conflict with qspi0 */ + u-boot,dm-pre-reloc; + }; + + apb { + uart1: serial@f8020000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1_default>; + status = "okay"; + u-boot,dm-pre-reloc; + }; + + pioA: gpio@fc038000 { + pinctrl { + pinctrl_sdmmc0_cmd_dat_default: sdmmc0_cmd_dat_default { + pinmux = <PIN_PA1__SDMMC0_CMD>, + <PIN_PA2__SDMMC0_DAT0>, + <PIN_PA3__SDMMC0_DAT1>, + <PIN_PA4__SDMMC0_DAT2>, + <PIN_PA5__SDMMC0_DAT3>, + <PIN_PA6__SDMMC0_DAT4>, + <PIN_PA7__SDMMC0_DAT5>, + <PIN_PA8__SDMMC0_DAT6>, + <PIN_PA9__SDMMC0_DAT7>; + bias-pull-up; + u-boot,dm-pre-reloc; + }; + + pinctrl_sdmmc0_ck_cd_default: sdmmc0_ck_cd_default { + pinmux = <PIN_PA0__SDMMC0_CK>, + <PIN_PA10__SDMMC0_RSTN>, + <PIN_PA13__SDMMC0_CD>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_sdmmc1_cmd_dat_default: sdmmc1_cmd_dat_default { + pinmux = <PIN_PA28__SDMMC1_CMD>, + <PIN_PA18__SDMMC1_DAT0>, + <PIN_PA19__SDMMC1_DAT1>, + <PIN_PA20__SDMMC1_DAT2>, + <PIN_PA21__SDMMC1_DAT3>; + bias-pull-up; + u-boot,dm-pre-reloc; + }; + + pinctrl_sdmmc1_ck_cd_default: sdmmc1_ck_cd_default { + pinmux = <PIN_PA22__SDMMC1_CK>, + <PIN_PA30__SDMMC1_CD>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_uart1_default: uart1_default { + pinmux = <PIN_PD2__URXD1>, + <PIN_PD3__UTXD1>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_usb_default: usb_default { + pinmux = <PIN_PB10__GPIO>; + bias-disable; + }; + + pinctrl_usba_vbus: usba_vbus { + pinmux = <PIN_PA31__GPIO>; + bias-disable; + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index 8d89b83b53..2a1d64d446 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -504,11 +504,13 @@ qspi0_clk: qspi0_clk@52 { #clock-cells = <0>; reg = <52>; + u-boot,dm-pre-reloc; };
qspi1_clk: qspi1_clk@53 { #clock-cells = <0>; reg = <53>; + u-boot,dm-pre-reloc; }; };
@@ -595,6 +597,16 @@ status = "disabled"; };
+ qspi1: spi@f0024000 { + compatible = "atmel,sama5d2-qspi"; + reg = <0xf0024000 0x100>, <0xd8000000 0x08000000>; + reg-names = "qspi_base", "qspi_mmap"; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&qspi1_clk>; + status = "disabled"; + }; + spi0: spi@f8000000 { compatible = "atmel,at91rm9200-spi"; reg = <0xf8000000 0x100>; @@ -666,6 +678,14 @@ status = "disabled"; };
+ uart3: serial@fc008000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xfc008000 0x100>; + clocks = <&uart3_clk>; + clock-names = "usart"; + status = "disabled"; + }; + i2c1: i2c@fc028000 { compatible = "atmel,sama5d2-i2c"; reg = <0xfc028000 0x100>; diff --git a/arch/arm/dts/sama5d27_som1.dtsi b/arch/arm/dts/sama5d27_som1.dtsi new file mode 100644 index 0000000000..23f7f38135 --- /dev/null +++ b/arch/arm/dts/sama5d27_som1.dtsi @@ -0,0 +1,154 @@ +/* + * sama5d27_som1.dtsi - Device Tree file for SAMA5D27 SOM1 + * + * Copyright (C) 2017 Microchip Corporation + * Wenyou Yang wenyou.yang@microchip.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "sama5d2.dtsi" +#include "sama5d2-pinfunc.h" +/ { + model = "Atmel SAMA5D27 SOM1 EK"; + compatible = "atmel,sama5d27-som1-ek", "atmel,sama5d2", "atmel,sama5"; + + memory { + reg = <0x20000000 0x8000000>; + }; + + aliases { + spi0 = &qspi1; + u-boot,dm-pre-reloc; + }; + + ahb { + apb { + qspi1: spi@f0024000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi1_sck_cs_default &pinctrl_qspi1_dat_default>; + status = "okay"; + u-boot,dm-pre-reloc; + + spi_flash@0 { + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <50000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + u-boot,dm-pre-reloc; + }; + }; + + macb0: ethernet@f8008000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb0_rmii &pinctrl_macb0_phy_irq>; + phy-mode = "rmii"; + status = "okay"; + + ethernet-phy@1 { + reg = <0x1>; + }; + }; + + i2c0: i2c@f8028000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0_default>; + status = "okay"; + }; + + i2c1: i2c@fc028000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1_default>; + status = "okay"; + }; + + pioA: gpio@fc038000 { + pinctrl { + pinctrl_i2c0_default: i2c0_default { + pinmux = <PIN_PD21__TWD0>, + <PIN_PD22__TWCK0>; + bias-disable; + }; + + pinctrl_i2c1_default: i2c1_default { + pinmux = <PIN_PD4__TWD1>, + <PIN_PD5__TWCK1>; + bias-disable; + }; + + pinctrl_macb0_phy_irq: macb0_phy_irq { + pinmux = <PIN_PD31__GPIO>; + bias-disable; + }; + + pinctrl_macb0_rmii: macb0_rmii { + pinmux = <PIN_PD9__GTXCK>, + <PIN_PD10__GTXEN>, + <PIN_PD11__GRXDV>, + <PIN_PD12__GRXER>, + <PIN_PD13__GRX0>, + <PIN_PD14__GRX1>, + <PIN_PD15__GTX0>, + <PIN_PD16__GTX1>, + <PIN_PD17__GMDC>, + <PIN_PD18__GMDIO>; + bias-disable; + }; + + pinctrl_qspi1_sck_cs_default: qspi1_sck_cs_default { + pinmux = <PIN_PB5__QSPI1_SCK>, + <PIN_PB6__QSPI1_CS>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_qspi1_dat_default: qspi1_dat_default { + pinmux = <PIN_PB7__QSPI1_IO0>, + <PIN_PB8__QSPI1_IO1>, + <PIN_PB9__QSPI1_IO2>, + <PIN_PB10__QSPI1_IO3>; + bias-pull-up; + u-boot,dm-pre-reloc; + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 033c1efd2b..a9fd0fae2b 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -98,6 +98,12 @@ config TARGET_SAMA5D2_XPLAINED select SUPPORT_SPL select BOARD_EARLY_INIT_F
+config TARGET_SAMA5D27_SOM1_EK + bool "SAMA5D27 SOM1 EK board" + select CPU_V7 + select SUPPORT_SPL + select BOARD_EARLY_INIT_F + config TARGET_SAMA5D3_XPLAINED bool "SAMA5D3 Xplained board" select CPU_V7 @@ -180,6 +186,7 @@ source "board/atmel/at91sam9rlek/Kconfig" source "board/atmel/at91sam9x5ek/Kconfig" source "board/atmel/sama5d2_ptc/Kconfig" source "board/atmel/sama5d2_xplained/Kconfig" +source "board/atmel/sama5d27_som1_ek/Kconfig" source "board/atmel/sama5d3_xplained/Kconfig" source "board/atmel/sama5d3xek/Kconfig" source "board/atmel/sama5d4_xplained/Kconfig" diff --git a/board/atmel/sama5d27_som1_ek/Kconfig b/board/atmel/sama5d27_som1_ek/Kconfig new file mode 100644 index 0000000000..3276214d8c --- /dev/null +++ b/board/atmel/sama5d27_som1_ek/Kconfig @@ -0,0 +1,15 @@ +if TARGET_SAMA5D27_SOM1_EK + +config SYS_BOARD + default "sama5d27_som1_ek" + +config SYS_VENDOR + default "atmel" + +config SYS_SOC + default "at91" + +config SYS_CONFIG_NAME + default "sama5d27_som1_ek" + +endif diff --git a/board/atmel/sama5d27_som1_ek/MAINTAINERS b/board/atmel/sama5d27_som1_ek/MAINTAINERS new file mode 100644 index 0000000000..609583c341 --- /dev/null +++ b/board/atmel/sama5d27_som1_ek/MAINTAINERS @@ -0,0 +1,6 @@ +SAMA5D27 SOM1 EK BOARD +M: Wenyou Yang wenyou.yang@microchip.com +S: Maintained +F: board/atmel/sama5d27_som1_ek/ +F: include/configs/sama5d27_som1_ek.h +F: configs/sama5d27_som1_ek_mmc_defconfig diff --git a/board/atmel/sama5d27_som1_ek/Makefile b/board/atmel/sama5d27_som1_ek/Makefile new file mode 100644 index 0000000000..4ab242c4ac --- /dev/null +++ b/board/atmel/sama5d27_som1_ek/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2017 Microchip Corporation +# Wenyou Yang wenyou.yang@microchip.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += sama5d27_som1_ek.o diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c new file mode 100644 index 0000000000..1d39b65a99 --- /dev/null +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2017 Microchip Corporation + * Wenyou.Yang wenyou.yang@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/atmel_pio4.h> +#include <asm/arch/atmel_mpddrc.h> +#include <asm/arch/atmel_sdhci.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/sama5d2.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void board_usb_hw_init(void) +{ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 10, 1); +} + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +static void board_uart1_hw_init(void) +{ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 2, 1); /* URXD1 */ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 3, 0); /* UTXD1 */ + + at91_periph_clk_enable(ATMEL_ID_UART1); +} + +void board_debug_uart_init(void) +{ + board_uart1_hw_init(); +} +#endif + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + + return 0; +} +#endif + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_CMD_USB + board_usb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +#ifdef CONFIG_CMD_I2C +static int set_ethaddr_from_eeprom(void) +{ + const int eth_addr_len = 6; + unsigned char ethaddr[eth_addr_len]; + const char *ethaddr_name = "ethaddr"; + struct udevice *bus, *dev; + + if (getenv(ethaddr_name)) + return 0; + + if (uclass_get_device_by_seq(UCLASS_I2C, MAC24AA_I2C_BUS_NUM, &bus)) + return -1; + + if (dm_i2c_probe(bus, MAC24AA_ADDR, 0, &dev)) + return -1; + + if (dm_i2c_read(dev, MAC24AA_REG, ethaddr, eth_addr_len)) + return -1; + + if (!is_valid_ethaddr(ethaddr)) + return -1; + + return eth_setenv_enetaddr(ethaddr_name, ethaddr); +} +#endif + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +#ifdef CONFIG_CMD_I2C + set_ethaddr_from_eeprom(); +#endif + return 0; +} +#endif + +/* SPL */ +#ifdef CONFIG_SPL_BUILD +void spl_board_init(void) +{ +} + +static void ddrc_conf(struct atmel_mpddrc_config *ddrc) +{ + ddrc->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddrc->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_DIC_DS | + ATMEL_MPDDRC_CR_ZQ_LONG | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_UNAL_SUPPORTED); + + ddrc->rtr = 0x511; + + ddrc->tpr0 = ((7 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TWR_OFFSET) | + (9 << ATMEL_MPDDRC_TPR0_TRC_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRP_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET) | + (2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET)); + + ddrc->tpr1 = ((22 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET) | + (23 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET) | + (200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR1_TXP_OFFSET)); + + ddrc->tpr2 = ((2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + struct atmel_mpddrc_config ddrc_config; + u32 reg; + + ddrc_conf(&ddrc_config); + + at91_periph_clk_enable(ATMEL_ID_MPDDRC); + writel(AT91_PMC_DDR, &pmc->scer); + + reg = readl(&mpddrc->io_calibr); + reg &= ~ATMEL_MPDDRC_IO_CALIBR_RDIV; + reg |= ATMEL_MPDDRC_IO_CALIBR_DDR3_RZQ_55; + reg &= ~ATMEL_MPDDRC_IO_CALIBR_TZQIO; + reg |= ATMEL_MPDDRC_IO_CALIBR_TZQIO_(101); + writel(reg, &mpddrc->io_calibr); + + writel(ATMEL_MPDDRC_RD_DATA_PATH_SHIFT_ONE_CYCLE, + &mpddrc->rd_data_path); + + ddr3_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddrc_config); + + writel(0x3, &mpddrc->cal_mr4); + writel(64, &mpddrc->tim_cal); +} + +void at91_pmc_init(void) +{ + u32 tmp; + + /* + * while coming from the ROM code, we run on PLLA @ 492 MHz / 164 MHz + * so we need to slow down and configure MCKR accordingly. + * This is why we have a special flavor of the switching function. + */ + tmp = AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_MAIN; + at91_mck_init_down(tmp); + + tmp = AT91_PMC_PLLAR_29 | + AT91_PMC_PLLXR_PLLCOUNT(0x3f) | + AT91_PMC_PLLXR_MUL(40) | + AT91_PMC_PLLXR_DIV(1); + at91_plla_init(tmp); + + tmp = AT91_PMC_MCKR_H32MXDIV | + AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_PLLA; + at91_mck_init(tmp); +} +#endif diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig new file mode 100644 index 0000000000..b6b84952f4 --- /dev/null +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TARGET_SAMA5D27_SOM1_EK=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_FAT_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_ATMEL_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y diff --git a/configs/sama5d27_som1_ek_spiflash_defconfig b/configs/sama5d27_som1_ek_spiflash_defconfig new file mode 100644 index 0000000000..a543142df7 --- /dev/null +++ b/configs/sama5d27_som1_ek_spiflash_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TARGET_SAMA5D27_SOM1_EK=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL=y +# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_OF_TRANSLATE is not set +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_ATMEL_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h new file mode 100644 index 0000000000..063d214bed --- /dev/null +++ b/include/configs/sama5d27_som1_ek.h @@ -0,0 +1,100 @@ +/* + * Configuration file for the SAMA5D27 SOM1 EK Board. + * + * Copyright (C) 2017 Microchip Corporation + * Wenyou Yang wenyou.yang@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "at91-sama5_common.h" + +#undef CONFIG_SYS_TEXT_BASE +#undef CONFIG_SYS_AT91_MAIN_CLOCK +#define CONFIG_SYS_TEXT_BASE 0x23f00000 +#define CONFIG_SYS_AT91_MAIN_CLOCK 24000000 /* from 24 MHz crystal */ + +#define CONFIG_MISC_INIT_R + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_DDRCS +#define CONFIG_SYS_SDRAM_SIZE 0x8000000 + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR 0x218000 +#else +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 16 * 1024 - GENERATED_GBL_DATA_SIZE) +#endif + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +/* NAND flash */ +#undef CONFIG_CMD_NAND + +/* SPI flash */ +#define CONFIG_SF_DEFAULT_SPEED 66000000 + +/* EEPROM MAC */ +#define MAC24AA_I2C_BUS_NUM 0 +#define MAC24AA_ADDR 0x50 +#define MAC24AA_REG 0xfa + +#ifdef CONFIG_SD_BOOT +/* u-boot env in sd/mmc card */ +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_DEVICE_AND_PART "0" +#define FAT_ENV_FILE "uboot.env" +#define CONFIG_ENV_SIZE 0x4000 +/* bootstrap + u-boot + env in sd card */ +#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 at91-sama5d27_som1_ek.dtb; " \ + "fatload mmc 0:1 0x22000000 zImage; " \ + "bootz 0x22000000 - 0x21000000" +#undef CONFIG_BOOTARGS +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +#endif + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0xb0000 +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_BOOTCOMMAND "sf probe 0; " \ + "sf read 0x21000000 0xc0000 0x20000; " \ + "sf read 0x22000000 0xe0000 0x400000; " \ + "bootz 0x22000000 - 0x21000000" +#undef CONFIG_BOOTARGS +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +#endif + +/* SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x200000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SYS_MONITOR_LEN (512 << 10) + +#ifdef CONFIG_SD_BOOT +#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/armv7/u-boot-spl.lds +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#endif + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000 +#endif + +#endif
Hi Wenyou,
select CPU_V7
select SUPPORT_SPL
Add help here to describe the board and peripherals.
+config SYS_BOARD
+config SYS_VENDOR
default "atmel"
+config SYS_SOC
default "at91"
- Copyright (C) 2017 Microchip Corporation
Wenyou.Yang <wenyou.yang@microchip.com>
+} +#endif
debug_uart_init();
+} +#endif
return -1;
return -1;
Is this an i2c eeprom? If so there is a DM driver for this.
return -1;
return -1;
+} +#endif
+} +#endif
ddrc->rtr = 0x511;
Looks like this should be in drivers/ram?
u32 reg;
u32 tmp;
at91_mck_init(tmp);
Should this be in the clock driver?
Hi Simon,
Hi Wenyou,
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-sama5d27_som1_ek.dts | 155 ++++++++++++++++++ arch/arm/dts/sama5d2.dtsi | 20 +++ arch/arm/dts/sama5d27_som1.dtsi | 154 ++++++++++++++++++ arch/arm/mach-at91/Kconfig | 7 + board/atmel/sama5d27_som1_ek/Kconfig | 15 ++ board/atmel/sama5d27_som1_ek/MAINTAINERS | 6 + board/atmel/sama5d27_som1_ek/Makefile | 8 + board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 206 ++++++++++++++++++++++++ configs/sama5d27_som1_ek_mmc_defconfig | 82 ++++++++++ configs/sama5d27_som1_ek_spiflash_defconfig | 82 ++++++++++ include/configs/sama5d27_som1_ek.h | 100 ++++++++++++ 12 files changed, 838 insertions(+) create mode 100644 arch/arm/dts/at91-sama5d27_som1_ek.dts create mode 100644 arch/arm/dts/sama5d27_som1.dtsi create mode 100644 board/atmel/sama5d27_som1_ek/Kconfig create mode 100644 board/atmel/sama5d27_som1_ek/MAINTAINERS create mode 100644 board/atmel/sama5d27_som1_ek/Makefile create mode 100644 board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c create mode 100644 configs/sama5d27_som1_ek_mmc_defconfig create mode 100644 configs/sama5d27_som1_ek_spiflash_defconfig create mode 100644 include/configs/sama5d27_som1_ek.h diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 033c1efd2b..a9fd0fae2b 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -98,6 +98,12 @@ config TARGET_SAMA5D2_XPLAINED select SUPPORT_SPL select BOARD_EARLY_INIT_F
select CPU_V7
select SUPPORT_SPL
Will add in next version.
+config SYS_BOARD
+config SYS_VENDOR
default "atmel"
+config SYS_SOC
default "at91"
+} +#endif
debug_uart_init();
+} +#endif
return -1;
return -1;
Yes, it is an i2c eeprom. I will put these code to common folder and use the i2c_eeprom driver in a new patch series.
return -1;
return -1;
+} +#endif
+} +#endif
ddrc->rtr = 0x511;
The code is used to configure the parameter, not driver, so it is okay to put here.
u32 reg;
u32 tmp;
at91_mck_init(tmp);
This is used by SPL, it is not easy to put it in the clock driver, maybe in the future.
Wenyou Yang
Yang, Wenyou
