[U-Boot] [PATCH 2/2] net: bootp: Add BOOTP specific config for timeout value
There is currently one config option (CONFIG_NET_RETRY_COUNT) that is available to tune the retries of the network stack. Unfortunately, it is global to all protocols, and the value is interpreted differently in all of them.
Add a new config option that sets directly the timeout delay used by BOOTP, instead of it being derived from CONFIG_NET_RETRY_COUNT.
Signed-off-by: Alexandre Messier amessier@tycoint.com --- README | 6 ++++++ net/bootp.c | 4 ++++ 2 files changed, 10 insertions(+)
diff --git a/README b/README index 05966ab..9703f83 100644 --- a/README +++ b/README @@ -2191,6 +2191,7 @@ CBFS (Coreboot Filesystem) support CONFIG_BOOTP_TIMEOFFSET CONFIG_BOOTP_VENDOREX CONFIG_BOOTP_MAY_FAIL + CONFIG_BOOTP_TIMEOUT_MS CONFIG_BOOTP_DHCPREQ_BOOTFILE
CONFIG_BOOTP_SERVERIP - TFTP server will be the serverip @@ -2232,6 +2233,11 @@ CBFS (Coreboot Filesystem) support the DHCP timeout and retry process takes a longer than this delay.
+ CONFIG_BOOTP_TIMEOUT_MS - Explicitly configure the BOOTP + timeout in milliseconds, instead of basing it on the configured + number of retries, which is either CONFIG_NET_RETRY_COUNT or + the BOOTP default value of 5 retries. + CONFIG_BOOTP_DHCPREQ_BOOTFILE - Set the bootfile name in DHCPREQUEST packet, in addition to DHCPDISCOVER. This may be needed by some DHCP servers in specific cases. diff --git a/net/bootp.c b/net/bootp.c index 8da94cf..edb0b39 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -33,12 +33,16 @@ * execute that many retries, and keep sending retry packets until that time * is reached. */ +#ifndef CONFIG_BOOTP_TIMEOUT_MS #ifndef CONFIG_NET_RETRY_COUNT # define TIMEOUT_COUNT 5 /* # of timeouts before giving up */ #else # define TIMEOUT_COUNT (CONFIG_NET_RETRY_COUNT) #endif #define TIMEOUT_MS ((3 + (TIMEOUT_COUNT * 5)) * 1000) +#else +#define TIMEOUT_MS CONFIG_BOOTP_TIMEOUT_MS +#endif
#define PORT_BOOTPS 67 /* BOOTP server UDP port */ #define PORT_BOOTPC 68 /* BOOTP client UDP port */
CONFIG_BOOTP_TIMEOUT_MS CONFIG_BOOTP_DHCPREQ_BOOTFILE CONFIG_BOOTP_SERVERIP - TFTP server will be the serverip
Please add new config options to the Kconfig system.
- execute that many retries, and keep sending retry packets until that time
- is reached.
1.8.3.1
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: January-22-16 2:36 PM To: amessier.tyco@gmail.com Cc: u-boot; Joe Hershberger; MESSIER, ALEXANDRE Subject: Re: [U-Boot] [PATCH 2/2] net: bootp: Add BOOTP specific config for timeout value
OK will do.
time
- is reached.
1.8.3.1
U-Boot mailing list U-Boot@lists.denx.de https://urldefense.proofpoint.com/v2/url?u=http-
3A__lists.denx.de_mailman_listinfo_u-2Dboot&d=CwIBaQ&c=0YGvTs3tT- VMy8_v51yLDw&r=adEdfGeVvAp5D3jUKeOClnVoZZOSb93LtGg4Qgmpmjw& m=6vGNQE7IhCTnhn7IpITPEZMxcbzm9xD4_yl1dmVGsI0&s=M78bwo2zLUHN Avjy5n53KfWdSKM8CRGsFU1SSog0LKw&e=
________________________________
This e-mail contains privileged and confidential information intended for the use of the addressees named above. If you are not the intended recipient of this e-mail, you are hereby notified that you must not disseminate, copy or take any action in respect of any information contained in it. If you have received this e-mail in error, please notify the sender immediately by e-mail and immediately destroy this e-mail and its attachments.
amessier.tycoï¼ gmail.com
Joe Hershberger
MESSIER, ALEXANDRE
