[U-Boot] [PATCH V2 01/13] ARM: dts: rmobile: Add soc label to Gen3
Add label to the /soc node, so it can be referenced from the U-Boot DTs.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7796.dtsi | 2 +- arch/arm/dts/r8a77965.dtsi | 2 +- arch/arm/dts/r8a77970.dtsi | 2 +- arch/arm/dts/r8a77995.dtsi | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/r8a7796.dtsi b/arch/arm/dts/r8a7796.dtsi index 011f0e596a..2b25a1d146 100644 --- a/arch/arm/dts/r8a7796.dtsi +++ b/arch/arm/dts/r8a7796.dtsi @@ -259,7 +259,7 @@ clock-frequency = <0>; };
- soc { + soc: soc { compatible = "simple-bus"; interrupt-parent = <&gic>; #address-cells = <2>; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi index 7a5d68be13..f28a82c1d4 100644 --- a/arch/arm/dts/r8a77965.dtsi +++ b/arch/arm/dts/r8a77965.dtsi @@ -144,7 +144,7 @@ <&a57_1>; };
- soc { + soc: soc { compatible = "simple-bus"; interrupt-parent = <&gic>; #address-cells = <2>; diff --git a/arch/arm/dts/r8a77970.dtsi b/arch/arm/dts/r8a77970.dtsi index 8dc599edfa..4f9f8ba3c1 100644 --- a/arch/arm/dts/r8a77970.dtsi +++ b/arch/arm/dts/r8a77970.dtsi @@ -72,7 +72,7 @@ clock-frequency = <0>; };
diff --git a/arch/arm/dts/r8a77995.dtsi b/arch/arm/dts/r8a77995.dtsi index 1d49279ac9..5ae37c60fd 100644 --- a/arch/arm/dts/r8a77995.dtsi +++ b/arch/arm/dts/r8a77995.dtsi @@ -66,7 +66,7 @@ clock-frequency = <0>; };
The RPC DT bindings are still work in progress. Extract the RPC DT node from the DT to allow easier update and so it can be replaced once the DT bindings are stable.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7795-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a7795.dtsi | 8 -------- arch/arm/dts/r8a7796-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a7796.dtsi | 8 -------- arch/arm/dts/r8a77965-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a77965.dtsi | 8 -------- arch/arm/dts/r8a77970-eagle-u-boot.dts | 25 +++++++++++++++++++++++++ arch/arm/dts/r8a77970-eagle.dts | 20 -------------------- arch/arm/dts/r8a77970-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a77970.dtsi | 8 -------- arch/arm/dts/r8a77990-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a77990.dtsi | 8 -------- arch/arm/dts/r8a77995-u-boot.dtsi | 10 ++++++++++ arch/arm/dts/r8a77995.dtsi | 8 -------- 14 files changed, 85 insertions(+), 68 deletions(-)
diff --git a/arch/arm/dts/r8a7795-u-boot.dtsi b/arch/arm/dts/r8a7795-u-boot.dtsi index 526966ab24..cc22c57ae3 100644 --- a/arch/arm/dts/r8a7795-u-boot.dtsi +++ b/arch/arm/dts/r8a7795-u-boot.dtsi @@ -10,3 +10,13 @@ &extalr_clk { u-boot,dm-pre-reloc; }; + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a7795", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a7795.dtsi b/arch/arm/dts/r8a7795.dtsi index af77bfe4e4..e2713eea48 100644 --- a/arch/arm/dts/r8a7795.dtsi +++ b/arch/arm/dts/r8a7795.dtsi @@ -1812,14 +1812,6 @@ dma-channels = <2>; };
- rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a7795", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; - sdhi0: sd@ee100000 { compatible = "renesas,sdhi-r8a7795", "renesas,rcar-gen3-sdhi"; diff --git a/arch/arm/dts/r8a7796-u-boot.dtsi b/arch/arm/dts/r8a7796-u-boot.dtsi index 7cc60bc54a..4655259afe 100644 --- a/arch/arm/dts/r8a7796-u-boot.dtsi +++ b/arch/arm/dts/r8a7796-u-boot.dtsi @@ -10,3 +10,13 @@ &extalr_clk { u-boot,dm-pre-reloc; }; + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a7796", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a7796.dtsi b/arch/arm/dts/r8a7796.dtsi index 2b25a1d146..903fef7284 100644 --- a/arch/arm/dts/r8a7796.dtsi +++ b/arch/arm/dts/r8a7796.dtsi @@ -1588,14 +1588,6 @@ status = "disabled"; };
- rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a7796", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; - sdhi0: sd@ee100000 { compatible = "renesas,sdhi-r8a7796", "renesas,rcar-gen3-sdhi"; diff --git a/arch/arm/dts/r8a77965-u-boot.dtsi b/arch/arm/dts/r8a77965-u-boot.dtsi index f0023114d1..ca80ef8f29 100644 --- a/arch/arm/dts/r8a77965-u-boot.dtsi +++ b/arch/arm/dts/r8a77965-u-boot.dtsi @@ -10,3 +10,13 @@ &extalr_clk { u-boot,dm-pre-reloc; }; + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a77965", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi index f28a82c1d4..840512ecfa 100644 --- a/arch/arm/dts/r8a77965.dtsi +++ b/arch/arm/dts/r8a77965.dtsi @@ -863,14 +863,6 @@ status = "disabled"; };
- rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a77965", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; - sdhi0: sd@ee100000 { compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee100000 0 0x2000>; diff --git a/arch/arm/dts/r8a77970-eagle-u-boot.dts b/arch/arm/dts/r8a77970-eagle-u-boot.dts index 7ab71a1c65..0c716deb6f 100644 --- a/arch/arm/dts/r8a77970-eagle-u-boot.dts +++ b/arch/arm/dts/r8a77970-eagle-u-boot.dts @@ -7,3 +7,28 @@
#include "r8a77970-eagle.dts" #include "r8a77970-u-boot.dtsi" + +/ { + aliases { + spi0 = &rpc; + }; +}; + +&rpc { + num-cs = <1>; + status = "okay"; + spi-max-frequency = <50000000>; + #address-cells = <1>; + #size-cells = <0>; + + flash0: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "s25fs512s", "spi-flash", "jedec,spi-nor"; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <1>; + reg = <0>; + status = "okay"; + }; +}; diff --git a/arch/arm/dts/r8a77970-eagle.dts b/arch/arm/dts/r8a77970-eagle.dts index 5dcad63492..107ac5d393 100644 --- a/arch/arm/dts/r8a77970-eagle.dts +++ b/arch/arm/dts/r8a77970-eagle.dts @@ -17,7 +17,6 @@ aliases { serial0 = &scif0; ethernet0 = &avb; - spi0 = &rpc; };
chosen { @@ -91,25 +90,6 @@ }; };
-&rpc { - num-cs = <1>; - status = "okay"; - spi-max-frequency = <50000000>; - #address-cells = <1>; - #size-cells = <0>; - - flash0: spi-flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "s25fs512s", "spi-flash", "jedec,spi-nor"; - spi-max-frequency = <50000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <1>; - reg = <0>; - status = "okay"; - }; -}; - &rwdt { timeout-sec = <60>; status = "okay"; diff --git a/arch/arm/dts/r8a77970-u-boot.dtsi b/arch/arm/dts/r8a77970-u-boot.dtsi index 8fb7fe92db..2903fdb523 100644 --- a/arch/arm/dts/r8a77970-u-boot.dtsi +++ b/arch/arm/dts/r8a77970-u-boot.dtsi @@ -10,3 +10,13 @@ &extalr_clk { u-boot,dm-pre-reloc; }; + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a77970", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a77970.dtsi b/arch/arm/dts/r8a77970.dtsi index 4f9f8ba3c1..9205da2acd 100644 --- a/arch/arm/dts/r8a77970.dtsi +++ b/arch/arm/dts/r8a77970.dtsi @@ -614,14 +614,6 @@ #address-cells = <1>; #size-cells = <0>; }; - - rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a77970", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; };
timer { diff --git a/arch/arm/dts/r8a77990-u-boot.dtsi b/arch/arm/dts/r8a77990-u-boot.dtsi index 564c258e92..052caa720d 100644 --- a/arch/arm/dts/r8a77990-u-boot.dtsi +++ b/arch/arm/dts/r8a77990-u-boot.dtsi @@ -6,3 +6,13 @@ */
#include "r8a779x-u-boot.dtsi" + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a77990", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a77990.dtsi b/arch/arm/dts/r8a77990.dtsi index ad20ea14cd..87625870e6 100644 --- a/arch/arm/dts/r8a77990.dtsi +++ b/arch/arm/dts/r8a77990.dtsi @@ -331,14 +331,6 @@ compatible = "renesas,prr"; reg = <0 0xfff00044 0 4>; }; - - rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a77990", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; };
timer { diff --git a/arch/arm/dts/r8a77995-u-boot.dtsi b/arch/arm/dts/r8a77995-u-boot.dtsi index e0852c8df2..1f6efafb8b 100644 --- a/arch/arm/dts/r8a77995-u-boot.dtsi +++ b/arch/arm/dts/r8a77995-u-boot.dtsi @@ -6,3 +6,13 @@ */
#include "r8a779x-u-boot.dtsi" + +&soc { + rpc: rpc@0xee200000 { + compatible = "renesas,rpc-r8a77995", "renesas,rpc"; + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; + clocks = <&cpg CPG_MOD 917>; + bank-width = <2>; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/r8a77995.dtsi b/arch/arm/dts/r8a77995.dtsi index 5ae37c60fd..d191d8ad70 100644 --- a/arch/arm/dts/r8a77995.dtsi +++ b/arch/arm/dts/r8a77995.dtsi @@ -780,14 +780,6 @@ }; }; }; - - rpc: rpc@0xee200000 { - compatible = "renesas,rpc-r8a77995", "renesas,rpc"; - reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; - clocks = <&cpg CPG_MOD 917>; - bank-width = <2>; - status = "disabled"; - }; };
timer {
The USB nodes are not in Linux 4.17 DTs in M3N, pull them into U-Boot specific DT extras until they hit mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a77965-u-boot.dtsi | 55 +++++++++++++++++++++++++++++++ arch/arm/dts/r8a77965.dtsi | 53 +++++------------------------ 2 files changed, 64 insertions(+), 44 deletions(-)
diff --git a/arch/arm/dts/r8a77965-u-boot.dtsi b/arch/arm/dts/r8a77965-u-boot.dtsi index ca80ef8f29..15d9467ec0 100644 --- a/arch/arm/dts/r8a77965-u-boot.dtsi +++ b/arch/arm/dts/r8a77965-u-boot.dtsi @@ -19,4 +19,59 @@ bank-width = <2>; status = "disabled"; }; + + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + companion= <&ohci0>; + power-domains = <&sysc 32>; + resets = <&cpg 703>; + }; + + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a77965", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + power-domains = <&sysc 32>; + resets = <&cpg 703>; + #phy-cells = <0>; + }; + + ehci1: usb@ee0a0100 { + compatible = "generic-ehci"; + reg = <0 0xee0a0100 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; + companion= <&ohci1>; + power-domains = <&sysc 32>; + resets = <&cpg 702>; + }; + + usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a77965", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0a0200 0 0x700>; + clocks = <&cpg CPG_MOD 702>; + power-domains = <&sysc 32>; + resets = <&cpg 702>; + #phy-cells = <0>; + }; + + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a77965", + "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc 32>; + resets = <&cpg 328>; + }; }; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi index 840512ecfa..a47f079c02 100644 --- a/arch/arm/dts/r8a77965.dtsi +++ b/arch/arm/dts/r8a77965.dtsi @@ -645,28 +645,18 @@ };
ehci0: usb@ee080100 { - compatible = "generic-ehci"; reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; - companion= <&ohci0>; - power-domains = <&sysc 32>; - resets = <&cpg 703>; - status = "disabled"; + /* placeholder */ };
usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a77965", - "renesas,rcar-gen3-usb2-phy"; reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc 32>; - resets = <&cpg 703>; - #phy-cells = <0>; - status = "disabled"; + /* placeholder */ + }; + + usb2_phy1: usb-phy@ee0a0200 { + reg = <0 0xee0a0200 0 0x700>; + /* placeholder */ };
ohci1: usb@ee0a0000 { @@ -675,16 +665,8 @@ };
ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1>; - phy-names = "usb"; - companion= <&ohci1>; - power-domains = <&sysc 32>; - resets = <&cpg 702>; - status = "disabled"; + /* placeholder */ };
i2c0: i2c@e6500000 { @@ -852,17 +834,6 @@ }; };
- usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a77965", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc 32>; - resets = <&cpg 702>; - #phy-cells = <0>; - status = "disabled"; - }; - sdhi0: sd@ee100000 { compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee100000 0 0x2000>; @@ -919,14 +890,8 @@ };
xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a77965", - "renesas,rcar-gen3-xhci"; reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc 32>; - resets = <&cpg 328>; - status = "disabled"; + /* placeholder */ };
wdt0: watchdog@e6020000 {
The SDHI nodes are not in Linux 4.17 DTs in M3N, pull them into U-Boot specific DT extras until they hit mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a77965-u-boot.dtsi | 44 +++++++++++++++++++++++++++++++ arch/arm/dts/r8a77965.dtsi | 32 +++------------------- 2 files changed, 48 insertions(+), 28 deletions(-)
diff --git a/arch/arm/dts/r8a77965-u-boot.dtsi b/arch/arm/dts/r8a77965-u-boot.dtsi index 15d9467ec0..cbd29b3aed 100644 --- a/arch/arm/dts/r8a77965-u-boot.dtsi +++ b/arch/arm/dts/r8a77965-u-boot.dtsi @@ -20,6 +20,50 @@ status = "disabled"; };
+ sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a77965"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + power-domains = <&sysc 32>; + resets = <&cpg 314>; + status = "disabled"; + }; + + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a77965"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + power-domains = <&sysc 32>; + resets = <&cpg 313>; + status = "disabled"; + }; + + sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a77965"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc 32>; + resets = <&cpg 312>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a77965"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc 32>; + resets = <&cpg 311>; + status = "disabled"; + }; + ehci0: usb@ee080100 { compatible = "generic-ehci"; reg = <0 0xee080100 0 0x100>; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi index a47f079c02..84ecb4631f 100644 --- a/arch/arm/dts/r8a77965.dtsi +++ b/arch/arm/dts/r8a77965.dtsi @@ -835,47 +835,23 @@ };
sdhi0: sd@ee100000 { - compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - max-frequency = <200000000>; - power-domains = <&sysc 32>; - resets = <&cpg 314>; - status = "disabled"; + /* placeholder */ };
sdhi1: sd@ee120000 { - compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>; - max-frequency = <200000000>; - power-domains = <&sysc 32>; - resets = <&cpg 313>; - status = "disabled"; + /* placeholder */ };
sdhi2: sd@ee140000 { - compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - max-frequency = <200000000>; - power-domains = <&sysc 32>; - resets = <&cpg 312>; - status = "disabled"; + /* placeholder */ };
sdhi3: sd@ee160000 { - compatible = "renesas,sdhi-r8a77965"; reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - max-frequency = <200000000>; - power-domains = <&sysc 32>; - resets = <&cpg 311>; - status = "disabled"; + /* placeholder */ };
usb3_phy0: usb-phy@e65ee000 {
The AVB node is not complete in Linux 4.17 DTs on V3M Eagle, pull the AVB node extras into U-Boot specific DT until they hit mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a77970-eagle-u-boot.dts | 20 ++++++++++++++++++++ arch/arm/dts/r8a77970-eagle.dts | 11 ----------- 2 files changed, 20 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/r8a77970-eagle-u-boot.dts b/arch/arm/dts/r8a77970-eagle-u-boot.dts index 0c716deb6f..5b17f1d1f0 100644 --- a/arch/arm/dts/r8a77970-eagle-u-boot.dts +++ b/arch/arm/dts/r8a77970-eagle-u-boot.dts @@ -7,6 +7,7 @@
#include "r8a77970-eagle.dts" #include "r8a77970-u-boot.dtsi" +#include <dt-bindings/gpio/gpio.h>
/ { aliases { @@ -14,6 +15,25 @@ }; };
+&avb { + pinctrl-0 = <&avb0_pins>; + pinctrl-names = "default"; + +}; + +&phy0 { + reset-gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; +}; + +&pfc { + avb0_pins: avb { + mux { + groups = "avb0_link", "avb0_mdio", "avb0_rgmii", "avb0_txcrefclk"; + function = "avb0"; + }; + }; +}; + &rpc { num-cs = <1>; status = "okay"; diff --git a/arch/arm/dts/r8a77970-eagle.dts b/arch/arm/dts/r8a77970-eagle.dts index 107ac5d393..7fee1aa1ac 100644 --- a/arch/arm/dts/r8a77970-eagle.dts +++ b/arch/arm/dts/r8a77970-eagle.dts @@ -8,7 +8,6 @@
/dts-v1/; #include "r8a77970.dtsi" -#include <dt-bindings/gpio/gpio.h>
/ { model = "Renesas Eagle board based on r8a77970"; @@ -32,8 +31,6 @@ };
&avb { - pinctrl-0 = <&avb0_pins>; - pinctrl-names = "default"; renesas,no-ether-link; phy-handle = <&phy0>; phy-mode = "rgmii-id"; @@ -44,7 +41,6 @@ reg = <0>; interrupt-parent = <&gpio1>; interrupts = <17 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; }; };
@@ -72,13 +68,6 @@ };
&pfc { - avb0_pins: avb { - mux { - groups = "avb0_link", "avb0_mdio", "avb0_rgmii", "avb0_txcrefclk"; - function = "avb0"; - }; - }; - i2c0_pins: i2c0 { groups = "i2c0"; function = "i2c0";
The CPLD node is missing in Linux 4.17 DTs on H3/M3W ULCB, pull the node into U-Boot specific DT until it hits mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7795-h3ulcb-u-boot.dts | 11 +++++++++++ arch/arm/dts/r8a7796-m3ulcb-u-boot.dts | 11 +++++++++++ arch/arm/dts/ulcb.dtsi | 9 --------- 3 files changed, 22 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts b/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts index 06bd4f24ca..5cb5e9c6fb 100644 --- a/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts +++ b/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts @@ -7,3 +7,14 @@
#include "r8a7795-h3ulcb.dts" #include "r8a7795-u-boot.dtsi" + +/ { + cpld { + compatible = "renesas,ulcb-cpld"; + status = "okay"; + gpio-sck = <&gpio6 8 0>; + gpio-mosi = <&gpio6 7 0>; + gpio-miso = <&gpio6 10 0>; + gpio-sstbz = <&gpio2 3 0>; + }; +}; diff --git a/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts b/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts index a1d13ccf28..78bd4f26bd 100644 --- a/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts +++ b/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts @@ -7,3 +7,14 @@
#include "r8a7796-m3ulcb.dts" #include "r8a7796-u-boot.dtsi" + +/ { + cpld { + compatible = "renesas,ulcb-cpld"; + status = "okay"; + gpio-sck = <&gpio6 8 0>; + gpio-mosi = <&gpio6 7 0>; + gpio-miso = <&gpio6 10 0>; + gpio-sstbz = <&gpio2 3 0>; + }; +}; diff --git a/arch/arm/dts/ulcb.dtsi b/arch/arm/dts/ulcb.dtsi index e16c7f245e..c805265343 100644 --- a/arch/arm/dts/ulcb.dtsi +++ b/arch/arm/dts/ulcb.dtsi @@ -24,15 +24,6 @@ stdout-path = "serial0:115200n8"; };
- cpld { - compatible = "renesas,ulcb-cpld"; - status = "okay"; - gpio-sck = <&gpio6 8 0>; - gpio-mosi = <&gpio6 7 0>; - gpio-miso = <&gpio6 10 0>; - gpio-sstbz = <&gpio2 3 0>; - }; - audio_clkout: audio-clkout { /* * This is same as <&rcar_sound 0>
The SDHI nodes are missing features supported in upstream U-Boot, like mode support properties. Pull the extras into U-Boot specific DT until it hits mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7795-h3ulcb-u-boot.dts | 21 +++++++++++++++++++++ arch/arm/dts/r8a7796-m3ulcb-u-boot.dts | 21 +++++++++++++++++++++ arch/arm/dts/ulcb.dtsi | 12 +++--------- 3 files changed, 45 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts b/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts index 5cb5e9c6fb..ebbd234d78 100644 --- a/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts +++ b/arch/arm/dts/r8a7795-h3ulcb-u-boot.dts @@ -18,3 +18,24 @@ gpio-sstbz = <&gpio2 3 0>; }; }; + +&sdhi2_pins { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + power-source = <1800>; +}; + +&sdhi2_pins_uhs { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; +}; + +&sdhi0 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + mmc-hs400-1_8v; + max-frequency = <200000000>; +}; diff --git a/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts b/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts index 78bd4f26bd..4e960081f9 100644 --- a/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts +++ b/arch/arm/dts/r8a7796-m3ulcb-u-boot.dts @@ -18,3 +18,24 @@ gpio-sstbz = <&gpio2 3 0>; }; }; + +&sdhi2_pins { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + power-source = <1800>; +}; + +&sdhi2_pins_uhs { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; +}; + +&sdhi0 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + mmc-hs400-1_8v; + max-frequency = <200000000>; +}; diff --git a/arch/arm/dts/ulcb.dtsi b/arch/arm/dts/ulcb.dtsi index c805265343..6f814845f8 100644 --- a/arch/arm/dts/ulcb.dtsi +++ b/arch/arm/dts/ulcb.dtsi @@ -299,13 +299,13 @@ };
sdhi2_pins: sd2 { - groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + groups = "sdhi2_data8", "sdhi2_ctrl"; function = "sdhi2"; - power-source = <1800>; + power-source = <3300>; };
sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + groups = "sdhi2_data8", "sdhi2_ctrl"; function = "sdhi2"; power-source = <1800>; }; @@ -387,12 +387,8 @@ vqmmc-supply = <&vccq_sdhi0>; cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; bus-width = <4>; - sd-uhs-sdr12; - sd-uhs-sdr25; sd-uhs-sdr50; - sd-uhs-sdr104; status = "okay"; - max-frequency = <208000000>; };
&sdhi2 { @@ -405,10 +401,8 @@ vqmmc-supply = <®_1p8v>; bus-width = <8>; mmc-hs200-1_8v; - mmc-hs400-1_8v; non-removable; status = "okay"; - max-frequency = <200000000>; };
&ssi1 {
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7795-salvator-x-u-boot.dts | 28 +++++++++++++++++++ arch/arm/dts/r8a7796-salvator-x-u-boot.dts | 28 +++++++++++++++++++ arch/arm/dts/r8a77965-salvator-x-u-boot.dts | 31 +++++++++++++++++++++ arch/arm/dts/salvator-common.dtsi | 17 ++--------- 4 files changed, 90 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/r8a7795-salvator-x-u-boot.dts b/arch/arm/dts/r8a7795-salvator-x-u-boot.dts index 666fbf5a83..8be5e41a51 100644 --- a/arch/arm/dts/r8a7795-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a7795-salvator-x-u-boot.dts @@ -7,3 +7,31 @@
#include "r8a7795-salvator-x.dts" #include "r8a7795-u-boot.dtsi" + +&sdhi2_pins { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + power-source = <1800>; +}; + +&sdhi2_pins_uhs { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; +}; + +&sdhi0 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + mmc-hs400-1_8v; + max-frequency = <200000000>; +}; + +&sdhi3 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; diff --git a/arch/arm/dts/r8a7796-salvator-x-u-boot.dts b/arch/arm/dts/r8a7796-salvator-x-u-boot.dts index 7a8ad27795..44b2f9fb37 100644 --- a/arch/arm/dts/r8a7796-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a7796-salvator-x-u-boot.dts @@ -7,3 +7,31 @@
#include "r8a7796-salvator-x.dts" #include "r8a7796-u-boot.dtsi" + +&sdhi2_pins { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + power-source = <1800>; +}; + +&sdhi2_pins_uhs { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; +}; + +&sdhi0 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + mmc-hs400-1_8v; + max-frequency = <200000000>; +}; + +&sdhi3 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; diff --git a/arch/arm/dts/r8a77965-salvator-x-u-boot.dts b/arch/arm/dts/r8a77965-salvator-x-u-boot.dts index 06002b629a..9e0cd26f40 100644 --- a/arch/arm/dts/r8a77965-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a77965-salvator-x-u-boot.dts @@ -7,3 +7,34 @@
#include "r8a77965-salvator-x.dts" #include "r8a77965-u-boot.dtsi" + +&sdhi2_pins { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + power-source = <1800>; +}; + +&sdhi2_pins_uhs { + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; +}; + +&sdhi0 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; + status = "okay"; +}; + +&sdhi2 { + mmc-hs400-1_8v; + max-frequency = <200000000>; + status = "okay"; +}; + +&sdhi3 { + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; + status = "okay"; +}; diff --git a/arch/arm/dts/salvator-common.dtsi b/arch/arm/dts/salvator-common.dtsi index b036a713ea..2a7f36abd2 100644 --- a/arch/arm/dts/salvator-common.dtsi +++ b/arch/arm/dts/salvator-common.dtsi @@ -480,13 +480,13 @@ };
sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; + groups = "sdhi2_data8", "sdhi2_ctrl"; function = "sdhi2"; power-source = <1800>; }; @@ -618,13 +618,8 @@ cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; wp-gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; bus-width = <4>; - sd-uhs-sdr12; - sd-uhs-sdr25; sd-uhs-sdr50; - sd-uhs-sdr104; status = "okay"; - - max-frequency = <208000000>; };
&sdhi2 { @@ -637,11 +632,9 @@ vqmmc-supply = <®_1p8v>; bus-width = <8>; mmc-hs200-1_8v; - mmc-hs400-1_8v; non-removable; fixed-emmc-driver-type = <1>; status = "okay"; - max-frequency = <200000000>; };
&sdhi3 { @@ -654,12 +647,8 @@ cd-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; wp-gpios = <&gpio4 16 GPIO_ACTIVE_HIGH>; bus-width = <4>; - sd-uhs-sdr12; - sd-uhs-sdr25; sd-uhs-sdr50; - sd-uhs-sdr104; status = "okay"; - max-frequency = <208000000>; };
&ssi1 {
The SDHI nodes are not in Linux 4.17 DTs in E3, pull them into U-Boot specific DT extras until they hit mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a77990-ebisu-u-boot.dts | 158 +++++++++++++++++++++++++ arch/arm/dts/r8a77990-ebisu.dts | 36 ------ arch/arm/dts/r8a77990-u-boot.dtsi | 24 ++++ arch/arm/dts/r8a77990.dtsi | 24 ---- 4 files changed, 182 insertions(+), 60 deletions(-)
diff --git a/arch/arm/dts/r8a77990-ebisu-u-boot.dts b/arch/arm/dts/r8a77990-ebisu-u-boot.dts index 8d4ea88a91..17b749545f 100644 --- a/arch/arm/dts/r8a77990-ebisu-u-boot.dts +++ b/arch/arm/dts/r8a77990-ebisu-u-boot.dts @@ -7,3 +7,161 @@
#include "r8a77990-ebisu.dts" #include "r8a77990-u-boot.dtsi" + +/ { + reg_1p8v: regulator0 { + compatible = "regulator-fixed"; + regulator-name = "fixed-1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + reg_3p3v: regulator1 { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + vcc_sdhi0: regulator-vcc-sdhi0 { + compatible = "regulator-fixed"; + + regulator-name = "SDHI0 Vcc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&gpio5 17 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vccq_sdhi0: regulator-vccq-sdhi0 { + compatible = "regulator-gpio"; + + regulator-name = "SDHI0 VccQ"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; + gpios-states = <1>; + states = <3300000 1 + 1800000 0>; + }; + + vcc_sdhi1: regulator-vcc-sdhi1 { + compatible = "regulator-fixed"; + + regulator-name = "SDHI1 Vcc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&gpio0 4 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vccq_sdhi1: regulator-vccq-sdhi1 { + compatible = "regulator-gpio"; + + regulator-name = "SDHI1 VccQ"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio3 15 GPIO_ACTIVE_HIGH>; + gpios-states = <1>; + states = <3300000 1 + 1800000 0>; + }; +}; + +&pfc { + sdhi0_pins: sd0 { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <3300>; + }; + + sdhi0_pins_uhs: sd0_uhs { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <1800>; + }; + + sdhi1_pins: sd1 { + groups = "sdhi1_data4", "sdhi1_ctrl"; + function = "sdhi1"; + power-source = <3300>; + }; + + sdhi1_pins_uhs: sd1_uhs { + groups = "sdhi1_data4", "sdhi1_ctrl"; + function = "sdhi1"; + power-source = <1800>; + }; + + sdhi3_pins: sd2 { + groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds"; + function = "sdhi3"; + power-source = <1800>; + }; + + sdhi3_pins_uhs: sd2_uhs { + groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds"; + function = "sdhi3"; + power-source = <1800>; + }; +}; + +&sdhi0 { + /* full size SD */ + pinctrl-0 = <&sdhi0_pins>; + pinctrl-1 = <&sdhi0_pins_uhs>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <&vcc_sdhi0>; + vqmmc-supply = <&vccq_sdhi0>; + cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; + bus-width = <4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + status = "okay"; + max-frequency = <208000000>; +}; + +&sdhi1 { + /* microSD */ + pinctrl-0 = <&sdhi1_pins>; + pinctrl-1 = <&sdhi1_pins_uhs>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <&vcc_sdhi1>; + vqmmc-supply = <&vccq_sdhi1>; + cd-gpios = <&gpio3 14 GPIO_ACTIVE_LOW>; + bus-width = <4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + status = "okay"; + max-frequency = <208000000>; +}; + +&sdhi3 { + /* used for on-board 8bit eMMC */ + pinctrl-0 = <&sdhi3_pins>; + pinctrl-1 = <&sdhi3_pins_uhs>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_1p8v>; + bus-width = <8>; + mmc-hs200-1_8v; + mmc-hs400-1_8v; + non-removable; + status = "okay"; +}; diff --git a/arch/arm/dts/r8a77990-ebisu.dts b/arch/arm/dts/r8a77990-ebisu.dts index 0f269d0469..cea08d7488 100644 --- a/arch/arm/dts/r8a77990-ebisu.dts +++ b/arch/arm/dts/r8a77990-ebisu.dts @@ -142,42 +142,6 @@ function = "scif_clk"; };
- sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi1_pins: sd1 { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <3300>; - }; - - sdhi1_pins_uhs: sd1_uhs { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <1800>; - }; - - sdhi3_pins: sd2 { - groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds"; - function = "sdhi3"; - power-source = <1800>; - }; - - sdhi3_pins_uhs: sd2_uhs { - groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds"; - function = "sdhi3"; - power-source = <1800>; - }; - usb0_pins: usb0 { groups = "usb0"; function = "usb0"; diff --git a/arch/arm/dts/r8a77990-u-boot.dtsi b/arch/arm/dts/r8a77990-u-boot.dtsi index 052caa720d..288e57e4bc 100644 --- a/arch/arm/dts/r8a77990-u-boot.dtsi +++ b/arch/arm/dts/r8a77990-u-boot.dtsi @@ -15,4 +15,28 @@ bank-width = <2>; status = "disabled"; }; + + sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a77990"; + reg = <0 0xee100000 0 0x2000>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + status = "disabled"; + }; + + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a77990"; + reg = <0 0xee120000 0 0x2000>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a77990"; + reg = <0 0xee160000 0 0x2000>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + status = "disabled"; + }; }; diff --git a/arch/arm/dts/r8a77990.dtsi b/arch/arm/dts/r8a77990.dtsi index 87625870e6..593d35a267 100644 --- a/arch/arm/dts/r8a77990.dtsi +++ b/arch/arm/dts/r8a77990.dtsi @@ -223,30 +223,6 @@ reg = <0 0xe6160000 0 0x0200>; };
- sdhi0: sd@ee100000 { - compatible = "renesas,sdhi-r8a77990"; - reg = <0 0xee100000 0 0x2000>; - clocks = <&cpg CPG_MOD 314>; - max-frequency = <200000000>; - status = "disabled"; - }; - - sdhi1: sd@ee120000 { - compatible = "renesas,sdhi-r8a77990"; - reg = <0 0xee120000 0 0x2000>; - clocks = <&cpg CPG_MOD 313>; - max-frequency = <200000000>; - status = "disabled"; - }; - - sdhi3: sd@ee160000 { - compatible = "renesas,sdhi-r8a77990"; - reg = <0 0xee160000 0 0x2000>; - clocks = <&cpg CPG_MOD 311>; - max-frequency = <200000000>; - status = "disabled"; - }; - sysc: system-controller@e6180000 { compatible = "renesas,r8a77990-sysc"; reg = <0 0xe6180000 0 0x0400>;
The SCIF2 node is not in Linux 4.17 DTs on E3, pull it into U-Boot specific DT extras until it hits mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a77990-ebisu-u-boot.dts | 19 +++++++++++++++++++ arch/arm/dts/r8a77990-ebisu.dts | 16 ---------------- 2 files changed, 19 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/r8a77990-ebisu-u-boot.dts b/arch/arm/dts/r8a77990-ebisu-u-boot.dts index 17b749545f..b030d5c649 100644 --- a/arch/arm/dts/r8a77990-ebisu-u-boot.dts +++ b/arch/arm/dts/r8a77990-ebisu-u-boot.dts @@ -77,6 +77,19 @@ };
&pfc { + pinctrl-0 = <&scif_clk_pins>; + pinctrl-names = "default"; + + scif2_pins: scif2 { + groups = "scif2_data_a"; + function = "scif2"; + }; + + scif_clk_pins: scif_clk { + groups = "scif_clk_a"; + function = "scif_clk"; + }; + sdhi0_pins: sd0 { groups = "sdhi0_data4", "sdhi0_ctrl"; function = "sdhi0"; @@ -114,6 +127,12 @@ }; };
+&scif2 { + pinctrl-0 = <&scif2_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + &sdhi0 { /* full size SD */ pinctrl-0 = <&sdhi0_pins>; diff --git a/arch/arm/dts/r8a77990-ebisu.dts b/arch/arm/dts/r8a77990-ebisu.dts index cea08d7488..e337c902cb 100644 --- a/arch/arm/dts/r8a77990-ebisu.dts +++ b/arch/arm/dts/r8a77990-ebisu.dts @@ -122,9 +122,6 @@ };
&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - avb_pins: avb { mux { groups = "avb_link", "avb_mii"; @@ -132,16 +129,6 @@ }; };
- scif2_pins: scif2 { - groups = "scif2_data_a"; - function = "scif2"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk_a"; - function = "scif_clk"; - }; - usb0_pins: usb0 { groups = "usb0"; function = "usb0"; @@ -208,8 +195,5 @@ };
&scif2 { - pinctrl-0 = <&scif2_pins>; - pinctrl-names = "default"; - status = "okay"; };
The i2c6 node is missing in mainline Linux thus far, pull it into U-Boot specific DT until it hits mainline Linux, to make syncing of DTs easier.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7791-porter-u-boot.dts | 5 +++++ arch/arm/dts/r8a7791-porter.dts | 5 ----- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/r8a7791-porter-u-boot.dts b/arch/arm/dts/r8a7791-porter-u-boot.dts index 797fa9d6e7..275f6b4375 100644 --- a/arch/arm/dts/r8a7791-porter-u-boot.dts +++ b/arch/arm/dts/r8a7791-porter-u-boot.dts @@ -11,3 +11,8 @@ &scif0 { u-boot,dm-pre-reloc; }; + +&i2c6 { + status = "okay"; + clock-frequency = <400000>; +}; diff --git a/arch/arm/dts/r8a7791-porter.dts b/arch/arm/dts/r8a7791-porter.dts index fa9a57d770..f2d5723fbd 100644 --- a/arch/arm/dts/r8a7791-porter.dts +++ b/arch/arm/dts/r8a7791-porter.dts @@ -372,11 +372,6 @@ clock-frequency = <400000>; };
-&i2c6 { - status = "okay"; - clock-frequency = <400000>; -}; - &sata0 { status = "okay"; };
Synchronize DTs with mainline Linux 4.19.6 , commit 96db90800c06d3fe3fa08eb6222fe201286bb778
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7790-lager.dts | 8 ++- arch/arm/dts/r8a7790.dtsi | 101 ++++++++++++++++++++++++++++--- arch/arm/dts/r8a7791-koelsch.dts | 11 ++-- arch/arm/dts/r8a7791-porter.dts | 41 ++++++++++++- arch/arm/dts/r8a7791.dtsi | 51 +++++++++++++++- arch/arm/dts/r8a7792-blanche.dts | 5 ++ arch/arm/dts/r8a7792.dtsi | 19 +++++- arch/arm/dts/r8a7793-gose.dts | 11 ++-- arch/arm/dts/r8a7793.dtsi | 52 +++++++++++++++- arch/arm/dts/r8a7794-alt.dts | 14 ++++- arch/arm/dts/r8a7794-silk.dts | 8 ++- arch/arm/dts/r8a7794.dtsi | 28 ++++++++- 12 files changed, 309 insertions(+), 40 deletions(-)
diff --git a/arch/arm/dts/r8a7790-lager.dts b/arch/arm/dts/r8a7790-lager.dts index dcda98c6ae..50312e752e 100644 --- a/arch/arm/dts/r8a7790-lager.dts +++ b/arch/arm/dts/r8a7790-lager.dts @@ -899,9 +899,6 @@ status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - vin1ep0: endpoint { remote-endpoint = <&adv7180>; bus-width = <8>; @@ -926,6 +923,11 @@ }; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &ssi1 { shared-pin; }; diff --git a/arch/arm/dts/r8a7790.dtsi b/arch/arm/dts/r8a7790.dtsi index ed09e56c36..0925bdca43 100644 --- a/arch/arm/dts/r8a7790.dtsi +++ b/arch/arm/dts/r8a7790.dtsi @@ -76,12 +76,12 @@ compatible = "arm,cortex-a15"; reg = <0>; clock-frequency = <1300000000>; - voltage-tolerance = <1>; /* 1% */ clocks = <&cpg CPG_CORE R8A7790_CLK_Z>; - clock-latency = <300000>; /* 300 us */ power-domains = <&sysc R8A7790_PD_CA15_CPU0>; next-level-cache = <&L2_CA15>; capacity-dmips-mhz = <1024>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */
/* kHz - uV - OPPs unknown yet */ operating-points = <1400000 1000000>, @@ -101,6 +101,16 @@ power-domains = <&sysc R8A7790_PD_CA15_CPU1>; next-level-cache = <&L2_CA15>; capacity-dmips-mhz = <1024>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */ + + /* kHz - uV - OPPs unknown yet */ + operating-points = <1400000 1000000>, + <1225000 1000000>, + <1050000 1000000>, + < 875000 1000000>, + < 700000 1000000>, + < 350000 1000000>; };
cpu2: cpu@2 { @@ -112,6 +122,16 @@ power-domains = <&sysc R8A7790_PD_CA15_CPU2>; next-level-cache = <&L2_CA15>; capacity-dmips-mhz = <1024>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */ + + /* kHz - uV - OPPs unknown yet */ + operating-points = <1400000 1000000>, + <1225000 1000000>, + <1050000 1000000>, + < 875000 1000000>, + < 700000 1000000>, + < 350000 1000000>; };
cpu3: cpu@3 { @@ -123,6 +143,16 @@ power-domains = <&sysc R8A7790_PD_CA15_CPU3>; next-level-cache = <&L2_CA15>; capacity-dmips-mhz = <1024>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */ + + /* kHz - uV - OPPs unknown yet */ + operating-points = <1400000 1000000>, + <1225000 1000000>, + <1050000 1000000>, + < 875000 1000000>, + < 700000 1000000>, + < 350000 1000000>; };
cpu4: cpu@100 { @@ -199,6 +229,24 @@ clock-frequency = <0>; };
+ pmu-0 { + compatible = "arm,cortex-a15-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + pmu-1 { + compatible = "arm,cortex-a7-pmu"; + interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu4>, <&cpu5>, <&cpu6>, <&cpu7>; + }; + /* External SCIF clock */ scif_clk: scif { compatible = "fixed-clock"; @@ -215,6 +263,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a7790-wdt", + "renesas,rcar-gen2-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a7790", "renesas,rcar-gen2-gpio"; @@ -440,7 +498,7 @@
smp-sram@0 { compatible = "renesas,smp-sram"; - reg = <0 0x10>; + reg = <0 0x100>; }; };
@@ -1541,7 +1599,7 @@ interrupt-controller; reg = <0 0xf1001000 0 0x1000>, <0 0xf1002000 0 0x2000>, <0 0xf1004000 0 0x2000>, <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&cpg CPG_MOD 408>; clock-names = "clk"; power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; @@ -1612,6 +1670,33 @@ resets = <&cpg 127>; };
+ fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; + resets = <&cpg 119>; + }; + + fdp1@fe944000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe944000 0 0x2400>; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 118>; + power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; + resets = <&cpg 118>; + }; + + fdp1@fe948000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe948000 0 0x2400>; + interrupts = <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 117>; + power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; + resets = <&cpg 117>; + }; + jpu: jpeg-codec@fe980000 { compatible = "renesas,jpu-r8a7790", "renesas,rcar-gen2-jpu"; @@ -1770,10 +1855,10 @@
timer { compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; };
/* External USB clock - can be overridden by the board */ diff --git a/arch/arm/dts/r8a7791-koelsch.dts b/arch/arm/dts/r8a7791-koelsch.dts index be96bfd4f3..ce22db01fb 100644 --- a/arch/arm/dts/r8a7791-koelsch.dts +++ b/arch/arm/dts/r8a7791-koelsch.dts @@ -640,6 +640,11 @@ status = "okay"; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &sata0 { status = "okay"; }; @@ -847,9 +852,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin0ep2: endpoint { remote-endpoint = <&adv7612_out>; bus-width = <24>; @@ -868,9 +870,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin1ep: endpoint { remote-endpoint = <&adv7180>; bus-width = <8>; diff --git a/arch/arm/dts/r8a7791-porter.dts b/arch/arm/dts/r8a7791-porter.dts index f2d5723fbd..f02036e5de 100644 --- a/arch/arm/dts/r8a7791-porter.dts +++ b/arch/arm/dts/r8a7791-porter.dts @@ -372,10 +372,43 @@ clock-frequency = <400000>; };
+&i2c6 { + status = "okay"; + clock-frequency = <100000>; + + pmic@5a { + compatible = "dlg,da9063l"; + reg = <0x5a>; + interrupt-parent = <&irqc0>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; + interrupt-controller; + + wdt { + compatible = "dlg,da9063-watchdog"; + }; + }; + + vdd_dvfs: regulator@68 { + compatible = "dlg,da9210"; + reg = <0x68>; + interrupt-parent = <&irqc0>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; + + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + }; +}; + &sata0 { status = "okay"; };
+&cpu0 { + cpu0-supply = <&vdd_dvfs>; +}; + /* composite video input */ &vin0 { status = "okay"; @@ -383,9 +416,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin0ep: endpoint { remote-endpoint = <&adv7180>; bus-width = <8>; @@ -478,6 +508,11 @@ }; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &ssi1 { shared-pin; }; diff --git a/arch/arm/dts/r8a7791.dtsi b/arch/arm/dts/r8a7791.dtsi index d728738ba8..991ac6feed 100644 --- a/arch/arm/dts/r8a7791.dtsi +++ b/arch/arm/dts/r8a7791.dtsi @@ -75,11 +75,11 @@ compatible = "arm,cortex-a15"; reg = <0>; clock-frequency = <1500000000>; - voltage-tolerance = <1>; /* 1% */ clocks = <&cpg CPG_CORE R8A7791_CLK_Z>; - clock-latency = <300000>; /* 300 us */ power-domains = <&sysc R8A7791_PD_CA15_CPU0>; next-level-cache = <&L2_CA15>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */
/* kHz - uV - OPPs unknown yet */ operating-points = <1500000 1000000>, @@ -98,6 +98,16 @@ clocks = <&cpg CPG_CORE R8A7791_CLK_Z>; power-domains = <&sysc R8A7791_PD_CA15_CPU1>; next-level-cache = <&L2_CA15>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */ + + /* kHz - uV - OPPs unknown yet */ + operating-points = <1500000 1000000>, + <1312500 1000000>, + <1125000 1000000>, + < 937500 1000000>, + < 750000 1000000>, + < 375000 1000000>; };
L2_CA15: cache-controller-0 { @@ -123,6 +133,13 @@ clock-frequency = <0>; };
+ pmu { + compatible = "arm,cortex-a15-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; + /* External SCIF clock */ scif_clk: scif { compatible = "fixed-clock"; @@ -139,6 +156,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a7791-wdt", + "renesas,rcar-gen2-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a7791", "renesas,rcar-gen2-gpio"; @@ -404,7 +431,7 @@
@@ -1618,6 +1645,24 @@ resets = <&cpg 127>; };
+ fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; + resets = <&cpg 119>; + }; + + fdp1@fe944000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe944000 0 0x2400>; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 118>; + power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; + resets = <&cpg 118>; + }; + jpu: jpeg-codec@fe980000 { compatible = "renesas,jpu-r8a7791", "renesas,rcar-gen2-jpu"; diff --git a/arch/arm/dts/r8a7792-blanche.dts b/arch/arm/dts/r8a7792-blanche.dts index 023d870bed..f92301290b 100644 --- a/arch/arm/dts/r8a7792-blanche.dts +++ b/arch/arm/dts/r8a7792-blanche.dts @@ -236,6 +236,11 @@ }; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &scif0 { pinctrl-0 = <&scif0_pins>; pinctrl-names = "default"; diff --git a/arch/arm/dts/r8a7792.dtsi b/arch/arm/dts/r8a7792.dtsi index 8e26dede30..63a978ec81 100644 --- a/arch/arm/dts/r8a7792.dtsi +++ b/arch/arm/dts/r8a7792.dtsi @@ -82,6 +82,13 @@ clock-frequency = <0>; };
+ pmu { + compatible = "arm,cortex-a15-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; + /* External SCIF clock */ scif_clk: scif { compatible = "fixed-clock"; @@ -98,6 +105,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a7792-wdt", + "renesas,rcar-gen2-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a7792", "renesas,rcar-gen2-gpio"; @@ -338,7 +355,7 @@
diff --git a/arch/arm/dts/r8a7793-gose.dts b/arch/arm/dts/r8a7793-gose.dts index 9c893458ce..6b2f3a4fd1 100644 --- a/arch/arm/dts/r8a7793-gose.dts +++ b/arch/arm/dts/r8a7793-gose.dts @@ -596,6 +596,11 @@ status = "okay"; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &scif0 { pinctrl-0 = <&scif0_pins>; pinctrl-names = "default"; @@ -755,9 +760,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin0ep2: endpoint { remote-endpoint = <&adv7612_out>; bus-width = <24>; @@ -777,9 +779,6 @@ status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - vin1ep: endpoint { remote-endpoint = <&adv7180_out>; bus-width = <8>; diff --git a/arch/arm/dts/r8a7793.dtsi b/arch/arm/dts/r8a7793.dtsi index 8201b4e8d1..620a570307 100644 --- a/arch/arm/dts/r8a7793.dtsi +++ b/arch/arm/dts/r8a7793.dtsi @@ -67,10 +67,10 @@ compatible = "arm,cortex-a15"; reg = <0>; clock-frequency = <1500000000>; - voltage-tolerance = <1>; /* 1% */ clocks = <&cpg CPG_CORE R8A7793_CLK_Z>; - clock-latency = <300000>; /* 300 us */ power-domains = <&sysc R8A7793_PD_CA15_CPU0>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */
/* kHz - uV - OPPs unknown yet */ operating-points = <1500000 1000000>, @@ -89,6 +89,17 @@ clock-frequency = <1500000000>; clocks = <&cpg CPG_CORE R8A7793_CLK_Z>; power-domains = <&sysc R8A7793_PD_CA15_CPU1>; + voltage-tolerance = <1>; /* 1% */ + clock-latency = <300000>; /* 300 us */ + + /* kHz - uV - OPPs unknown yet */ + operating-points = <1500000 1000000>, + <1312500 1000000>, + <1125000 1000000>, + < 937500 1000000>, + < 750000 1000000>, + < 375000 1000000>; + next-level-cache = <&L2_CA15>; };
L2_CA15: cache-controller-0 { @@ -107,6 +118,13 @@ clock-frequency = <0>; };
+ pmu { + compatible = "arm,cortex-a15-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; + /* External SCIF clock */ scif_clk: scif { compatible = "fixed-clock"; @@ -123,6 +141,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a7793-wdt", + "renesas,rcar-gen2-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a7793", "renesas,rcar-gen2-gpio"; @@ -389,7 +417,7 @@
@@ -1287,6 +1315,24 @@ resets = <&cpg 408>; };
+ fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; + resets = <&cpg 119>; + }; + + fdp1@fe944000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe944000 0 0x2400>; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 118>; + power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; + resets = <&cpg 118>; + }; + du: display@feb00000 { compatible = "renesas,du-r8a7793"; reg = <0 0xfeb00000 0 0x40000>; diff --git a/arch/arm/dts/r8a7794-alt.dts b/arch/arm/dts/r8a7794-alt.dts index af3c67eb02..ef7e2a837d 100644 --- a/arch/arm/dts/r8a7794-alt.dts +++ b/arch/arm/dts/r8a7794-alt.dts @@ -178,6 +178,12 @@ }; }; }; + + eeprom@50 { + compatible = "renesas,r1ex24002", "atmel,24c02"; + reg = <0x50>; + pagesize = <16>; + }; };
/* @@ -327,6 +333,11 @@ status = "okay"; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &sdhi0 { pinctrl-0 = <&sdhi0_pins>; pinctrl-1 = <&sdhi0_pins_uhs>; @@ -372,9 +383,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin0ep: endpoint { remote-endpoint = <&adv7180>; bus-width = <8>; diff --git a/arch/arm/dts/r8a7794-silk.dts b/arch/arm/dts/r8a7794-silk.dts index 50dad43c10..daec965889 100644 --- a/arch/arm/dts/r8a7794-silk.dts +++ b/arch/arm/dts/r8a7794-silk.dts @@ -472,9 +472,6 @@ pinctrl-names = "default";
port { - #address-cells = <1>; - #size-cells = <0>; - vin0ep: endpoint { remote-endpoint = <&adv7180>; bus-width = <8>; @@ -537,6 +534,11 @@ }; };
+&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + &ssi1 { shared-pin; }; diff --git a/arch/arm/dts/r8a7794.dtsi b/arch/arm/dts/r8a7794.dtsi index 0cc07b30d1..ea2ca4bdaf 100644 --- a/arch/arm/dts/r8a7794.dtsi +++ b/arch/arm/dts/r8a7794.dtsi @@ -100,6 +100,13 @@ clock-frequency = <0>; };
+ pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; + /* External SCIF clock */ scif_clk: scif { compatible = "fixed-clock"; @@ -116,6 +123,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a7794-wdt", + "renesas,rcar-gen2-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a7794", "renesas,rcar-gen2-gpio"; @@ -345,7 +362,7 @@
@@ -1320,6 +1337,15 @@ resets = <&cpg 128>; };
+ fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; + resets = <&cpg 119>; + }; + du: display@feb00000 { compatible = "renesas,du-r8a7794"; reg = <0 0xfeb00000 0 0x40000>;
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V2: Rebase on u-boot/master --- arch/arm/dts/r8a7795-salvator-x.dts | 48 +- arch/arm/dts/r8a7795.dtsi | 2512 ++++++++++------- arch/arm/dts/r8a7796-salvator-x.dts | 30 +- arch/arm/dts/r8a7796.dtsi | 2453 +++++++++------- arch/arm/dts/r8a77965-salvator-x.dts | 28 + arch/arm/dts/r8a77965.dtsi | 1970 ++++++++++--- arch/arm/dts/r8a77970-eagle.dts | 116 + arch/arm/dts/r8a77970.dtsi | 661 +++-- arch/arm/dts/r8a77990-ebisu.dts | 139 +- arch/arm/dts/r8a77990.dtsi | 205 +- arch/arm/dts/r8a77995-draak.dts | 130 +- arch/arm/dts/r8a77995.dtsi | 976 ++++--- arch/arm/dts/salvator-common.dtsi | 217 +- arch/arm/dts/salvator-x.dtsi | 7 +- arch/arm/dts/ulcb.dtsi | 48 +- include/dt-bindings/clock/r8a77965-cpg-mssr.h | 62 + include/dt-bindings/clock/r8a77990-cpg-mssr.h | 5 +- include/dt-bindings/power/r8a77990-sysc.h | 8 +- 18 files changed, 6286 insertions(+), 3329 deletions(-) create mode 100644 include/dt-bindings/clock/r8a77965-cpg-mssr.h
diff --git a/arch/arm/dts/r8a7795-salvator-x.dts b/arch/arm/dts/r8a7795-salvator-x.dts index 36373d6cce..446822f575 100644 --- a/arch/arm/dts/r8a7795-salvator-x.dts +++ b/arch/arm/dts/r8a7795-salvator-x.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Device Tree Source for the Salvator-X board + * Device Tree Source for the Salvator-X board with R-Car H3 ES2.0 * * Copyright (C) 2015 Renesas Electronics Corp. */ @@ -53,6 +53,12 @@ status = "okay"; };
+&sound_card { + dais = <&rsnd_port0 /* ak4613 */ + &rsnd_port1 /* HDMI0 */ + &rsnd_port2>; /* HDMI1 */ +}; + &hdmi0 { status = "okay";
@@ -63,6 +69,12 @@ remote-endpoint = <&hdmi0_con>; }; }; + port@2 { + reg = <2>; + dw_hdmi0_snd_in: endpoint { + remote-endpoint = <&rsnd_endpoint1>; + }; + }; }; };
@@ -80,6 +92,12 @@ remote-endpoint = <&hdmi1_con>; }; }; + port@2 { + reg = <2>; + dw_hdmi1_snd_in: endpoint { + remote-endpoint = <&rsnd_endpoint2>; + }; + }; }; };
@@ -91,6 +109,34 @@ status = "okay"; };
+&rcar_sound { + ports { + /* rsnd_port0 is on salvator-common */ + rsnd_port1: port@1 { + rsnd_endpoint1: endpoint { + remote-endpoint = <&dw_hdmi0_snd_in>; + + dai-format = "i2s"; + bitclock-master = <&rsnd_endpoint1>; + frame-master = <&rsnd_endpoint1>; + + playback = <&ssi2>; + }; + }; + rsnd_port2: port@2 { + rsnd_endpoint2: endpoint { + remote-endpoint = <&dw_hdmi1_snd_in>; + + dai-format = "i2s"; + bitclock-master = <&rsnd_endpoint2>; + frame-master = <&rsnd_endpoint2>; + + playback = <&ssi3>; + }; + }; + }; +}; + &pfc { usb2_pins: usb2 { groups = "usb2"; diff --git a/arch/arm/dts/r8a7795.dtsi b/arch/arm/dts/r8a7795.dtsi index e2713eea48..c87eed77de 100644 --- a/arch/arm/dts/r8a7795.dtsi +++ b/arch/arm/dts/r8a7795.dtsi @@ -27,6 +27,91 @@ i2c7 = &i2c_dvfs; };
+ /* + * The external audio clocks are configured as 0 Hz fixed frequency + * clocks by default. + * Boards that provide audio clocks should override them. + */ + audio_clk_a: audio_clk_a { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_b: audio_clk_b { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_c: audio_clk_c { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + cluster0_opp: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <830000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <830000>; + clock-latency-ns = <300000>; + }; + opp-1500000000 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <830000>; + clock-latency-ns = <300000>; + opp-suspend; + }; + opp-1600000000 { + opp-hz = /bits/ 64 <1600000000>; + opp-microvolt = <900000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + opp-1700000000 { + opp-hz = /bits/ 64 <1700000000>; + opp-microvolt = <960000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + }; + + cluster1_opp: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -44,7 +129,7 @@ };
a57_1: cpu@1 { - compatible = "arm,cortex-a57","arm,armv8"; + compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x1>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA57_CPU1>; @@ -56,7 +141,7 @@ };
a57_2: cpu@2 { - compatible = "arm,cortex-a57","arm,armv8"; + compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x2>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA57_CPU2>; @@ -68,7 +153,7 @@ };
a57_3: cpu@3 { - compatible = "arm,cortex-a57","arm,armv8"; + compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x3>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA57_CPU3>; @@ -91,7 +176,7 @@ };
a53_1: cpu@101 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x101>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA53_CPU1>; @@ -102,7 +187,7 @@ };
a53_2: cpu@102 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x102>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA53_CPU2>; @@ -113,7 +198,7 @@ };
a53_3: cpu@103 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x103>; device_type = "cpu"; power-domains = <&sysc R8A7795_PD_CA53_CPU3>; @@ -152,91 +237,6 @@ clock-frequency = <0>; };
- /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp_table0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - opp-1600000000 { - opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <960000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cluster1_opp: opp_table1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - }; - /* External PCIe clock - can be overridden by the board */ pcie_bus_clk: pcie_bus { compatible = "fixed-clock"; @@ -244,18 +244,6 @@ clock-frequency = <0>; };
- pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, - <&a57_1>, - <&a57_2>, - <&a57_3>; - }; - pmu_a53 { compatible = "arm,cortex-a53-pmu"; interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, @@ -268,6 +256,18 @@ <&a53_3>; };
+ pmu_a57 { + compatible = "arm,cortex-a57-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a57_0>, + <&a57_1>, + <&a57_2>, + <&a57_3>; + }; + psci { compatible = "arm,psci-1.0", "arm,psci-0.2"; method = "smc"; @@ -288,24 +288,7 @@ #size-cells = <2>; ranges;
- gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - wdt0: watchdog@e6020000 { + rwdt: watchdog@e6020000 { compatible = "renesas,r8a7795-wdt", "renesas,rcar-gen3-wdt"; reg = <0 0xe6020000 0 0x0c>; clocks = <&cpg CPG_MOD 402>; @@ -434,6 +417,11 @@ resets = <&cpg 905>; };
+ pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a7795"; + reg = <0 0xe6060000 0 0x50c>; + }; + cpg: clock-controller@e6150000 { compatible = "renesas,r8a7795-cpg-mssr"; reg = <0 0xe6150000 0 0x1000>; @@ -449,20 +437,25 @@ reg = <0 0xe6160000 0 0x0200>; };
- prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - sysc: system-controller@e6180000 { compatible = "renesas,r8a7795-sysc"; reg = <0 0xe6180000 0 0x0400>; #power-domain-cells = <1>; };
- pfc: pin-controller@e6060000 { - compatible = "renesas,pfc-r8a7795"; - reg = <0 0xe6060000 0 0x50c>; + tsc: thermal@e6198000 { + compatible = "renesas,r8a7795-thermal"; + reg = <0 0xe6198000 0 0x100>, + <0 0xe61a0000 0 0x100>, + <0 0xe61a8000 0 0x100>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 522>; + #thermal-sensor-cells = <1>; + status = "okay"; };
intc_ex: interrupt-controller@e61c0000 { @@ -481,153 +474,335 @@ resets = <&cpg 407>; };
- ipmmu_vi0: mmu@febd0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi1: mmu@febe0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfebe0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 15>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c1: i2c@e6508000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6508000 0 0x40>; + interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 930>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 930>; + dmas = <&dmac1 0x93>, <&dmac1 0x92>, + <&dmac2 0x93>, <&dmac2 0x92>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; status = "disabled"; };
- ipmmu_vp0: mmu@fe990000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A7795_PD_A3VP>; - #iommu-cells = <1>; + i2c2: i2c@e6510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6510000 0 0x40>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 929>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 929>; + dmas = <&dmac1 0x95>, <&dmac1 0x94>, + <&dmac2 0x95>, <&dmac2 0x94>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; status = "disabled"; };
- ipmmu_vp1: mmu@fe980000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe980000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 17>; - power-domains = <&sysc R8A7795_PD_A3VP>; - #iommu-cells = <1>; + arm_cc630p: crypto@e6601000 { + compatible = "arm,cryptocell-630p-ree"; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0 0xe6601000 0 0x1000>; + clocks = <&cpg CPG_MOD 229>; + resets = <&cpg 229>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; };
- ipmmu_vc0: mmu@fe6b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A7795_PD_A3VC>; - #iommu-cells = <1>; + i2c3: i2c@e66d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d0000 0 0x40>; + interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 928>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 928>; + dmas = <&dmac0 0x97>, <&dmac0 0x96>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; status = "disabled"; };
- ipmmu_vc1: mmu@fe6f0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe6f0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 13>; - power-domains = <&sysc R8A7795_PD_A3VC>; - #iommu-cells = <1>; + i2c4: i2c@e66d8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d8000 0 0x40>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 927>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 927>; + dmas = <&dmac0 0x99>, <&dmac0 0x98>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; status = "disabled"; };
- ipmmu_pv0: mmu@fd800000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; + i2c5: i2c@e66e0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e0000 0 0x40>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 919>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 919>; + dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; status = "disabled"; };
- ipmmu_pv1: mmu@fd950000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; + i2c6: i2c@e66e8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7795", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e8000 0 0x40>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 918>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 918>; + dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; status = "disabled"; };
- ipmmu_pv2: mmu@fd960000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd960000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; + i2c_dvfs: i2c@e60b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,iic-r8a7795", + "renesas,rcar-gen3-iic", + "renesas,rmobile-iic"; + reg = <0 0xe60b0000 0 0x425>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 926>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 926>; + dmas = <&dmac0 0x11>, <&dmac0 0x10>; + dma-names = "tx", "rx"; status = "disabled"; };
- ipmmu_pv3: mmu@fd970000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd970000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a7795", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 96>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 520>; status = "disabled"; };
- ipmmu_ir: mmu@ff8b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A7795_PD_A3IR>; - #iommu-cells = <1>; + hscif1: serial@e6550000 { + compatible = "renesas,hscif-r8a7795", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6550000 0 96>; + interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 519>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x33>, <&dmac1 0x32>, + <&dmac2 0x33>, <&dmac2 0x32>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 519>; status = "disabled"; };
- ipmmu_hc: mmu@e6570000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; + hscif2: serial@e6560000 { + compatible = "renesas,hscif-r8a7795", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6560000 0 96>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 518>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x35>, <&dmac1 0x34>, + <&dmac2 0x35>, <&dmac2 0x34>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 518>; status = "disabled"; };
- ipmmu_rt: mmu@ffc80000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; + hscif3: serial@e66a0000 { + compatible = "renesas,hscif-r8a7795", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66a0000 0 96>; + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 517>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dma-names = "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 517>; status = "disabled"; };
- ipmmu_mp0: mmu@ec670000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; + hscif4: serial@e66b0000 { + compatible = "renesas,hscif-r8a7795", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66b0000 0 96>; + interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 516>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x39>, <&dmac0 0x38>; + dma-names = "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 516>; status = "disabled"; };
- ipmmu_ds0: mmu@e6740000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; + hsusb: usb@e6590000 { + compatible = "renesas,usbhs-r8a7795", + "renesas,rcar-gen3-usbhs"; + reg = <0 0xe6590000 0 0x100>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 704>; + dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, + <&usb_dmac1 0>, <&usb_dmac1 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy0>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 704>; + status = "disabled"; };
- ipmmu_ds1: mmu@e7740000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; + hsusb3: usb@e659c000 { + compatible = "renesas,usbhs-r8a7795", + "renesas,rcar-gen3-usbhs"; + reg = <0 0xe659c000 0 0x100>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 705>; + dmas = <&usb_dmac2 0>, <&usb_dmac2 1>, + <&usb_dmac3 0>, <&usb_dmac3 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy3>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 705>; + status = "disabled"; };
- ipmmu_mm: mmu@e67b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + usb_dmac0: dma-controller@e65a0000 { + compatible = "renesas,r8a7795-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65a0000 0 0x100>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 330>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 330>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac1: dma-controller@e65b0000 { + compatible = "renesas,r8a7795-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65b0000 0 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 331>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 331>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac2: dma-controller@e6460000 { + compatible = "renesas,r8a7795-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe6460000 0 0x100>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 326>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 326>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac3: dma-controller@e6470000 { + compatible = "renesas,r8a7795-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe6470000 0 0x100>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 329>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 329>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb3_phy0: usb-phy@e65ee000 { + compatible = "renesas,r8a7795-usb3-phy", + "renesas,rcar-gen3-usb3-phy"; + reg = <0 0xe65ee000 0 0x90>; + clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, + <&usb_extal_clk>; + clock-names = "usb3-if", "usb3s_clk", "usb_extal"; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 328>; + #phy-cells = <0>; + status = "disabled"; };
dmac0: dma-controller@e6700000 { @@ -756,154 +931,207 @@ <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; };
- audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; + ipmmu_ds0: mmu@e6740000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>, - <&ipmmu_mp0 2>, <&ipmmu_mp0 3>, - <&ipmmu_mp0 4>, <&ipmmu_mp0 5>, - <&ipmmu_mp0 6>, <&ipmmu_mp0 7>, - <&ipmmu_mp0 8>, <&ipmmu_mp0 9>, - <&ipmmu_mp0 10>, <&ipmmu_mp0 11>, - <&ipmmu_mp0 12>, <&ipmmu_mp0 13>, - <&ipmmu_mp0 14>, <&ipmmu_mp0 15>; + #iommu-cells = <1>; };
- audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>, - <&ipmmu_mp0 18>, <&ipmmu_mp0 19>, - <&ipmmu_mp0 20>, <&ipmmu_mp0 21>, - <&ipmmu_mp0 22>, <&ipmmu_mp0 23>, - <&ipmmu_mp0 24>, <&ipmmu_mp0 25>, - <&ipmmu_mp0 26>, <&ipmmu_mp0 27>, - <&ipmmu_mp0 28>, <&ipmmu_mp0 29>, - <&ipmmu_mp0 30>, <&ipmmu_mp0 31>; + #iommu-cells = <1>; };
- avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7795", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; + ipmmu_hc: mmu@e6570000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; + #iommu-cells = <1>; };
- can0: can@e6c30000 { - compatible = "renesas,can-r8a7795", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7795_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>; - assigned-clock-rates = <40000000>; + ipmmu_ir: mmu@ff8b0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xff8b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 3>; + power-domains = <&sysc R8A7795_PD_A3IR>; + #iommu-cells = <1>; + }; + + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; + #iommu-cells = <1>; };
- can1: can@e6c38000 { - compatible = "renesas,can-r8a7795", + ipmmu_mp0: mmu@ec670000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: mmu@fd800000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv1: mmu@fd950000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfd950000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 7>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv2: mmu@fd960000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfd960000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 8>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv3: mmu@fd970000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfd970000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 9>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 10>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: mmu@fe6b0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 12>; + power-domains = <&sysc R8A7795_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vc1: mmu@fe6f0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfe6f0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 13>; + power-domains = <&sysc R8A7795_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 14>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vi1: mmu@febe0000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfebe0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 15>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vp0: mmu@fe990000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfe990000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 16>; + power-domains = <&sysc R8A7795_PD_A3VP>; + #iommu-cells = <1>; + }; + + ipmmu_vp1: mmu@fe980000 { + compatible = "renesas,ipmmu-r8a7795"; + reg = <0 0xfe980000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 17>; + power-domains = <&sysc R8A7795_PD_A3VP>; + #iommu-cells = <1>; + }; + + avb: ethernet@e6800000 { + compatible = "renesas,etheravb-r8a7795", + "renesas,etheravb-rcar-gen3"; + reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15", + "ch16", "ch17", "ch18", "ch19", + "ch20", "ch21", "ch22", "ch23", + "ch24"; + clocks = <&cpg CPG_MOD 812>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 812>; + phy-mode = "rgmii"; + iommus = <&ipmmu_ds0 16>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can0: can@e6c30000 { + compatible = "renesas,can-r8a7795", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c30000 0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 916>, + <&cpg CPG_CORE R8A7795_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 916>; + status = "disabled"; + }; + + can1: can@e6c38000 { + compatible = "renesas,can-r8a7795", "renesas,rcar-gen3-can"; reg = <0 0xe6c38000 0 0x1000>; interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; @@ -943,211 +1171,173 @@ }; };
- drif00: rif@e6f40000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x64>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; + pwm0: pwm@e6e30000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e30000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif01: rif@e6f50000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x64>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; + pwm1: pwm@e6e31000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e31000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif10: rif@e6f60000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x64>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; + pwm2: pwm@e6e32000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e32000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif11: rif@e6f70000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x64>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; + pwm3: pwm@e6e33000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e33000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif20: rif@e6f80000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac1 0x28>, <&dmac2 0x28>; - dma-names = "rx", "rx"; + pwm4: pwm@e6e34000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e34000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif21: rif@e6f90000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; + pwm5: pwm@e6e35000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e35000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif30: rif@e6fa0000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x64>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; - dma-names = "rx", "rx"; + pwm6: pwm@e6e36000 { + compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; + reg = <0 0xe6e36000 0 0x8>; + clocks = <&cpg CPG_MOD 523>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; + resets = <&cpg 523>; + #pwm-cells = <2>; status = "disabled"; };
- drif31: rif@e6fb0000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x64>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; - dma-names = "rx", "rx"; + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 64>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A7795_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; + resets = <&cpg 207>; status = "disabled"; };
- hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 64>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, <&cpg CPG_CORE R8A7795_CLK_S3D1>, <&scif_clk>; clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 520>; + resets = <&cpg 206>; status = "disabled"; };
- hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 64>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, <&cpg CPG_CORE R8A7795_CLK_S3D1>, <&scif_clk>; clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; + dmas = <&dmac1 0x13>, <&dmac1 0x12>, + <&dmac2 0x13>, <&dmac2 0x12>; dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 519>; + resets = <&cpg 310>; status = "disabled"; };
- hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 96>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 64>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, <&cpg CPG_CORE R8A7795_CLK_S3D1>, <&scif_clk>; clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 518>; + resets = <&cpg 204>; status = "disabled"; };
- hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 96>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 64>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, <&cpg CPG_CORE R8A7795_CLK_S3D1>, <&scif_clk>; clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; dma-names = "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 517>; + resets = <&cpg 203>; status = "disabled"; };
- hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 96>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a7795", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 64>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, <&cpg CPG_CORE R8A7795_CLK_S3D1>, <&scif_clk>; clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 516>; + resets = <&cpg 202>; status = "disabled"; };
@@ -1213,304 +1403,379 @@ status = "disabled"; };
- scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; + vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 207>; + resets = <&cpg 811>; + renesas,id = <0>; status = "disabled"; - };
- scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; + ports { + #address-cells = <1>; + #size-cells = <0>;
- scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; + port@1 { + #address-cells = <1>; + #size-cells = <0>;
- scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; + reg = <1>;
- scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; + vin0csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin0>; + }; + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin0>; + }; + }; + }; };
- scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 202>; + resets = <&cpg 810>; + renesas,id = <1>; status = "disabled"; - };
- i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7795", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin1csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin1>; + }; + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin1>; + }; + }; + }; };
- i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; + vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef2000 0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; + resets = <&cpg 809>; + renesas,id = <2>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin2>; + }; + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin2>; + }; + }; + }; };
- i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; + vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; + resets = <&cpg 808>; + renesas,id = <3>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin3>; + }; + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin3>; + }; + }; + }; };
- i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; + resets = <&cpg 807>; + renesas,id = <4>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin4csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin4>; + }; + vin4csi41: endpoint@3 { + reg = <3>; + remote-endpoint= <&csi41vin4>; + }; + }; + }; };
- i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; + vin5: video@e6ef5000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef5000 0 0x1000>; + interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 806>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; + resets = <&cpg 806>; + renesas,id = <5>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin5csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin5>; + }; + vin5csi41: endpoint@3 { + reg = <3>; + remote-endpoint= <&csi41vin5>; + }; + }; + }; };
- i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; + vin6: video@e6ef6000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef6000 0 0x1000>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 805>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; + resets = <&cpg 805>; + renesas,id = <6>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin6csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin6>; + }; + vin6csi41: endpoint@3 { + reg = <3>; + remote-endpoint= <&csi41vin6>; + }; + }; + }; };
- i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; + vin7: video@e6ef7000 { + compatible = "renesas,vin-r8a7795"; + reg = <0 0xe6ef7000 0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 804>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; + resets = <&cpg 804>; + renesas,id = <7>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin7csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin7>; + }; + vin7csi41: endpoint@3 { + reg = <3>; + remote-endpoint= <&csi41vin7>; + }; + }; + }; };
- i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; + drif00: rif@e6f40000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f40000 0 0x64>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 515>; + clock-names = "fck"; + dmas = <&dmac1 0x20>, <&dmac2 0x20>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; + resets = <&cpg 515>; + renesas,bonding = <&drif01>; status = "disabled"; };
- pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif01: rif@e6f50000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f50000 0 0x64>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 514>; + clock-names = "fck"; + dmas = <&dmac1 0x22>, <&dmac2 0x22>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 514>; + renesas,bonding = <&drif00>; status = "disabled"; };
- pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif10: rif@e6f60000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f60000 0 0x64>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 513>; + clock-names = "fck"; + dmas = <&dmac1 0x24>, <&dmac2 0x24>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 513>; + renesas,bonding = <&drif11>; status = "disabled"; };
- pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif11: rif@e6f70000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f70000 0 0x64>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 512>; + clock-names = "fck"; + dmas = <&dmac1 0x26>, <&dmac2 0x26>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 512>; + renesas,bonding = <&drif10>; status = "disabled"; };
- pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif20: rif@e6f80000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f80000 0 0x64>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 511>; + clock-names = "fck"; + dmas = <&dmac1 0x28>, <&dmac2 0x28>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 511>; + renesas,bonding = <&drif21>; status = "disabled"; };
- pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif21: rif@e6f90000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f90000 0 0x64>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 510>; + clock-names = "fck"; + dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 510>; + renesas,bonding = <&drif20>; status = "disabled"; };
- pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif30: rif@e6fa0000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6fa0000 0 0x64>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 509>; + clock-names = "fck"; + dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 509>; + renesas,bonding = <&drif31>; status = "disabled"; };
- pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; + drif31: rif@e6fb0000 { + compatible = "renesas,r8a7795-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6fb0000 0 0x64>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 508>; + clock-names = "fck"; + dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; + resets = <&cpg 508>; + renesas,bonding = <&drif30>; status = "disabled"; };
@@ -1708,201 +1973,172 @@ dma-names = "rx", "tx", "rxu", "txu"; }; }; - }; - - sata: sata@ee300000 { - compatible = "renesas,sata-r8a7795", - "renesas,rcar-gen3-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - iommus = <&ipmmu_hc 2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a7795-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a7795", "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a7795-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - };
- usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + }; + port@1 { + reg = <1>; + }; + port@2 { + reg = <2>; + }; + }; };
- usb_dmac2: dma-controller@e6460000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe6460000 0 0x100>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 326>; + audma0: dma-controller@ec700000 { + compatible = "renesas,dmac-r8a7795", + "renesas,rcar-dmac"; + reg = <0 0xec700000 0 0x10000>; + interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 502>; + clock-names = "fck"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 326>; + resets = <&cpg 502>; #dma-cells = <1>; - dma-channels = <2>; + dma-channels = <16>; + iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>, + <&ipmmu_mp0 2>, <&ipmmu_mp0 3>, + <&ipmmu_mp0 4>, <&ipmmu_mp0 5>, + <&ipmmu_mp0 6>, <&ipmmu_mp0 7>, + <&ipmmu_mp0 8>, <&ipmmu_mp0 9>, + <&ipmmu_mp0 10>, <&ipmmu_mp0 11>, + <&ipmmu_mp0 12>, <&ipmmu_mp0 13>, + <&ipmmu_mp0 14>, <&ipmmu_mp0 15>; };
- usb_dmac3: dma-controller@e6470000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe6470000 0 0x100>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 329>; + audma1: dma-controller@ec720000 { + compatible = "renesas,dmac-r8a7795", + "renesas,rcar-dmac"; + reg = <0 0xec720000 0 0x10000>; + interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 501>; + clock-names = "fck"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 329>; + resets = <&cpg 501>; #dma-cells = <1>; - dma-channels = <2>; - }; - - sdhi0: sd@ee100000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: sd@ee120000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 313>; - status = "disabled"; + dma-channels = <16>; + iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>, + <&ipmmu_mp0 18>, <&ipmmu_mp0 19>, + <&ipmmu_mp0 20>, <&ipmmu_mp0 21>, + <&ipmmu_mp0 22>, <&ipmmu_mp0 23>, + <&ipmmu_mp0 24>, <&ipmmu_mp0 25>, + <&ipmmu_mp0 26>, <&ipmmu_mp0 27>, + <&ipmmu_mp0 28>, <&ipmmu_mp0 29>, + <&ipmmu_mp0 30>, <&ipmmu_mp0 31>; };
- sdhi2: sd@ee140000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - max-frequency = <200000000>; + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a7795", "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 312>; + resets = <&cpg 328>; status = "disabled"; };
- sdhi3: sd@ee160000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - max-frequency = <200000000>; + usb3_peri0: usb@ee020000 { + compatible = "renesas,r8a7795-usb3-peri", + "renesas,rcar-gen3-usb3-peri"; + reg = <0 0xee020000 0 0x400>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 311>; + resets = <&cpg 328>; status = "disabled"; };
- usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 703>; - #phy-cells = <0>; status = "disabled"; };
- usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; + ohci1: usb@ee0a0000 { + compatible = "generic-ohci"; + reg = <0 0xee0a0000 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 702>; - #phy-cells = <0>; status = "disabled"; };
- usb2_phy2: usb-phy@ee0c0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0c0200 0 0x700>; + ohci2: usb@ee0c0000 { + compatible = "generic-ohci"; + reg = <0 0xee0c0000 0 0x100>; + interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 701>; + phys = <&usb2_phy2>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 701>; - #phy-cells = <0>; status = "disabled"; };
- usb2_phy3: usb-phy@ee0e0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0e0200 0 0x700>; + ohci3: usb@ee0e0000 { + compatible = "generic-ohci"; + reg = <0 0xee0e0000 0 0x100>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 700>; + phys = <&usb2_phy3>; + phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 700>; - #phy-cells = <0>; status = "disabled"; };
@@ -1958,88 +2194,129 @@ status = "disabled"; };
- ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a7795", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 703>; + #phy-cells = <0>; status = "disabled"; };
- ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a7795", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0a0200 0 0x700>; clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1>; - phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 702>; + #phy-cells = <0>; status = "disabled"; };
- ohci2: usb@ee0c0000 { - compatible = "generic-ohci"; - reg = <0 0xee0c0000 0 0x100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; + usb2_phy2: usb-phy@ee0c0200 { + compatible = "renesas,usb2-phy-r8a7795", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0c0200 0 0x700>; clocks = <&cpg CPG_MOD 701>; - phys = <&usb2_phy2>; - phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 701>; + #phy-cells = <0>; status = "disabled"; };
- ohci3: usb@ee0e0000 { - compatible = "generic-ohci"; - reg = <0 0xee0e0000 0 0x100>; + usb2_phy3: usb-phy@ee0e0200 { + compatible = "renesas,usb2-phy-r8a7795", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0e0200 0 0x700>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 700>; - phys = <&usb2_phy3>; - phy-names = "usb"; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; resets = <&cpg 700>; + #phy-cells = <0>; status = "disabled"; };
- hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7795", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0>; - phy-names = "usb"; + sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a7795", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 704>; + resets = <&cpg 314>; status = "disabled"; };
- hsusb3: usb@e659c000 { - compatible = "renesas,usbhs-r8a7795", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe659c000 0 0x100>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 705>; - dmas = <&usb_dmac2 0>, <&usb_dmac2 1>, - <&usb_dmac3 0>, <&usb_dmac3 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy3>; - phy-names = "usb"; + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a7795", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 705>; + resets = <&cpg 313>; status = "disabled"; };
+ sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a7795", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 312>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a7795", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 311>; + status = "disabled"; + }; + + sata: sata@ee300000 { + compatible = "renesas,sata-r8a7795", + "renesas,rcar-gen3-sata"; + reg = <0 0xee300000 0 0x200000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 815>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 815>; + status = "disabled"; + iommus = <&ipmmu_hc 2>; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 408>; + }; + pciec0: pcie@fe000000 { compatible = "renesas,pcie-r8a7795", "renesas,pcie-rcar-gen3"; @@ -2130,28 +2407,28 @@ reg = <0 0xfe890000 0 0x2000>; interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 820>; - power-domains = <&sysc R8A7795_PD_A3VC>; - resets = <&cpg 820>; - }; - - vspbc: vsp@fe920000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe920000 0 0x8000>; - interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 624>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 624>; + power-domains = <&sysc R8A7795_PD_A3VC>; + resets = <&cpg 820>; + };
- renesas,fcp = <&fcpvb1>; + fdp1@fe940000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe940000 0 0x2400>; + interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 119>; + power-domains = <&sysc R8A7795_PD_A3VP>; + resets = <&cpg 119>; + renesas,fcp = <&fcpf0>; };
- fcpvb1: fcp@fe92f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe92f000 0 0x200>; - clocks = <&cpg CPG_MOD 606>; + fdp1@fe944000 { + compatible = "renesas,fdp1"; + reg = <0 0xfe944000 0 0x2400>; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 118>; power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 606>; - iommus = <&ipmmu_vp1 7>; + resets = <&cpg 118>; + renesas,fcp = <&fcpf1>; };
fcpf0: fcp@fe950000 { @@ -2172,17 +2449,6 @@ iommus = <&ipmmu_vp1 1>; };
- vspbd: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - fcpvb0: fcp@fe96f000 { compatible = "renesas,fcpv"; reg = <0 0xfe96f000 0 0x200>; @@ -2192,15 +2458,13 @@ iommus = <&ipmmu_vp0 5>; };
- vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; + fcpvb1: fcp@fe92f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe92f000 0 0x200>; + clocks = <&cpg CPG_MOD 606>; power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; + resets = <&cpg 606>; + iommus = <&ipmmu_vp1 7>; };
fcpvi0: fcp@fe9af000 { @@ -2212,17 +2476,6 @@ iommus = <&ipmmu_vp0 8>; };
- vspi1: vsp@fe9b0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9b0000 0 0x8000>; - interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 630>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 630>; - - renesas,fcp = <&fcpvi1>; - }; - fcpvi1: fcp@fe9bf000 { compatible = "renesas,fcpv"; reg = <0 0xfe9bf000 0 0x200>; @@ -2232,9 +2485,58 @@ iommus = <&ipmmu_vp1 9>; };
+ fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 603>; + iommus = <&ipmmu_vi0 8>; + }; + + fcpvd1: fcp@fea2f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea2f000 0 0x200>; + clocks = <&cpg CPG_MOD 602>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 602>; + iommus = <&ipmmu_vi0 9>; + }; + + fcpvd2: fcp@fea37000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea37000 0 0x200>; + clocks = <&cpg CPG_MOD 601>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 601>; + iommus = <&ipmmu_vi1 10>; + }; + + vspbd: vsp@fe960000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe960000 0 0x8000>; + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 626>; + power-domains = <&sysc R8A7795_PD_A3VP>; + resets = <&cpg 626>; + + renesas,fcp = <&fcpvb0>; + }; + + vspbc: vsp@fe920000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe920000 0 0x8000>; + interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 624>; + power-domains = <&sysc R8A7795_PD_A3VP>; + resets = <&cpg 624>; + + renesas,fcp = <&fcpvb1>; + }; + vspd0: vsp@fea20000 { compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x8000>; + reg = <0 0xfea20000 0 0x5000>; interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 623>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; @@ -2243,18 +2545,9 @@ renesas,fcp = <&fcpvd0>; };
- fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - vspd1: vsp@fea28000 { compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x8000>; + reg = <0 0xfea28000 0 0x5000>; interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 622>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; @@ -2263,18 +2556,9 @@ renesas,fcp = <&fcpvd1>; };
- fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - vspd2: vsp@fea30000 { compatible = "renesas,vsp2"; - reg = <0 0xfea30000 0 0x8000>; + reg = <0 0xfea30000 0 0x5000>; interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 621>; power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; @@ -2283,33 +2567,159 @@ renesas,fcp = <&fcpvd2>; };
- fcpvd2: fcp@fea37000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea37000 0 0x200>; - clocks = <&cpg CPG_MOD 601>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 601>; - iommus = <&ipmmu_vi1 10>; + vspi0: vsp@fe9a0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9a0000 0 0x8000>; + interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 631>; + power-domains = <&sysc R8A7795_PD_A3VP>; + resets = <&cpg 631>; + + renesas,fcp = <&fcpvi0>; };
- fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; + vspi1: vsp@fe9b0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9b0000 0 0x8000>; + interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 630>; power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; + resets = <&cpg 630>; + + renesas,fcp = <&fcpvi1>; };
- fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 118>; - renesas,fcp = <&fcpf1>; + csi20: csi2@fea80000 { + compatible = "renesas,r8a7795-csi2"; + reg = <0 0xfea80000 0 0x10000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 714>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 714>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi20vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi20>; + }; + csi20vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi20>; + }; + csi20vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi20>; + }; + csi20vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi20>; + }; + csi20vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi20>; + }; + csi20vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi20>; + }; + csi20vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi20>; + }; + csi20vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi20>; + }; + }; + }; + }; + + csi40: csi2@feaa0000 { + compatible = "renesas,r8a7795-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + }; + }; + }; + + csi41: csi2@feab0000 { + compatible = "renesas,r8a7795-csi2"; + reg = <0 0xfeab0000 0 0x10000>; + interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 715>; + power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; + resets = <&cpg 715>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi41vin4: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin4csi41>; + }; + csi41vin5: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin5csi41>; + }; + csi41vin6: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin6csi41>; + }; + csi41vin7: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin7csi41>; + }; + }; + }; };
hdmi0: hdmi@fead0000 { @@ -2334,6 +2744,10 @@ port@1 { reg = <1>; }; + port@2 { + /* HDMI sound */ + reg = <2>; + }; }; };
@@ -2359,6 +2773,10 @@ port@1 { reg = <1>; }; + port@2 { + /* HDMI sound */ + reg = <2>; + }; }; };
@@ -2409,38 +2827,12 @@ }; };
- tsc: thermal@e6198000 { - compatible = "renesas,r8a7795-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - status = "okay"; + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; }; };
- timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 - (GIC_CPU_MASK_SIMPLE(8) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 - (GIC_CPU_MASK_SIMPLE(8) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 - (GIC_CPU_MASK_SIMPLE(8) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 - (GIC_CPU_MASK_SIMPLE(8) | - IRQ_TYPE_LEVEL_LOW)>; - }; - thermal-zones { sensor_thermal1: sensor-thermal1 { polling-delay-passive = <250>; @@ -2450,12 +2842,12 @@ trips { sensor1_passive: sensor1-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor1_crit: sensor1-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2476,12 +2868,12 @@ trips { sensor2_passive: sensor2-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor2_crit: sensor2-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2502,12 +2894,12 @@ trips { sensor3_passive: sensor3-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor3_crit: sensor3-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2521,6 +2913,14 @@ }; };
+ timer { + compatible = "arm,armv8-timer"; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; + }; + /* External USB clocks - can be overridden by the board */ usb3s0_clk: usb3s0 { compatible = "fixed-clock"; diff --git a/arch/arm/dts/r8a7796-salvator-x.dts b/arch/arm/dts/r8a7796-salvator-x.dts index 62aa27dbfd..052d72acc8 100644 --- a/arch/arm/dts/r8a7796-salvator-x.dts +++ b/arch/arm/dts/r8a7796-salvator-x.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Device Tree Source for the Salvator-X board + * Device Tree Source for the Salvator-X board with R-Car M3-W * * Copyright (C) 2016 Renesas Electronics Corp. */ @@ -37,6 +37,11 @@ "dclkin.0", "dclkin.1", "dclkin.2"; };
+&sound_card { + dais = <&rsnd_port0 /* ak4613 */ + &rsnd_port1>; /* HDMI0 */ +}; + &hdmi0 { status = "okay";
@@ -47,9 +52,32 @@ remote-endpoint = <&hdmi0_con>; }; }; + port@2 { + reg = <2>; + dw_hdmi0_snd_in: endpoint { + remote-endpoint = <&rsnd_endpoint1>; + }; + }; }; };
&hdmi0_con { remote-endpoint = <&rcar_dw_hdmi0_out>; }; + +&rcar_sound { + ports { + /* rsnd_port0 is on salvator-common */ + rsnd_port1: port@1 { + rsnd_endpoint1: endpoint { + remote-endpoint = <&dw_hdmi0_snd_in>; + + dai-format = "i2s"; + bitclock-master = <&rsnd_endpoint1>; + frame-master = <&rsnd_endpoint1>; + + playback = <&ssi2>; + }; + }; + }; +}; diff --git a/arch/arm/dts/r8a7796.dtsi b/arch/arm/dts/r8a7796.dtsi index 903fef7284..bf860f06d6 100644 --- a/arch/arm/dts/r8a7796.dtsi +++ b/arch/arm/dts/r8a7796.dtsi @@ -2,7 +2,7 @@ /* * Device Tree Source for the r8a7796 SoC * - * Copyright (C) 2016 Renesas Electronics Corp. + * Copyright (C) 2016-2017 Renesas Electronics Corp. */
#include <dt-bindings/clock/r8a7796-cpg-mssr.h> @@ -57,6 +57,72 @@ clock-frequency = <0>; };
+ cluster0_opp: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1500000000 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1600000000 { + opp-hz = /bits/ 64 <1600000000>; + opp-microvolt = <900000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + opp-1700000000 { + opp-hz = /bits/ 64 <1700000000>; + opp-microvolt = <900000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <960000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + }; + + cluster1_opp: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1300000000 { + opp-hz = /bits/ 64 <1300000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + turbo-mode; + }; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -74,7 +140,7 @@ };
a57_1: cpu@1 { - compatible = "arm,cortex-a57","arm,armv8"; + compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x1>; device_type = "cpu"; power-domains = <&sysc R8A7796_PD_CA57_CPU1>; @@ -97,7 +163,7 @@ };
a53_1: cpu@101 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x101>; device_type = "cpu"; power-domains = <&sysc R8A7796_PD_CA53_CPU1>; @@ -108,7 +174,7 @@ };
a53_2: cpu@102 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x102>; device_type = "cpu"; power-domains = <&sysc R8A7796_PD_CA53_CPU2>; @@ -119,7 +185,7 @@ };
a53_3: cpu@103 { - compatible = "arm,cortex-a53","arm,armv8"; + compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x103>; device_type = "cpu"; power-domains = <&sysc R8A7796_PD_CA53_CPU3>; @@ -158,72 +224,6 @@ clock-frequency = <0>; };
- cluster0_opp: opp_table0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1600000000 { - opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - opp-1800000000 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <960000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cluster1_opp: opp_table1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1300000000 { - opp-hz = /bits/ 64 <1300000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - /* External PCIe clock - can be overridden by the board */ pcie_bus_clk: pcie_bus { compatible = "fixed-clock"; @@ -231,13 +231,6 @@ clock-frequency = <0>; };
- pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, <&a57_1>; - }; - pmu_a53 { compatible = "arm,cortex-a53-pmu"; interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, @@ -247,6 +240,13 @@ interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; };
+ pmu_a57 { + compatible = "arm,cortex-a57-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a57_0>, <&a57_1>; + }; + psci { compatible = "arm,psci-1.0", "arm,psci-0.2"; method = "smc"; @@ -266,24 +266,7 @@ #size-cells = <2>; ranges;
- gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - wdt0: watchdog@e6020000 { + rwdt: watchdog@e6020000 { compatible = "renesas,r8a7796-wdt", "renesas,rcar-gen3-wdt"; reg = <0 0xe6020000 0 0x0c>; @@ -418,242 +401,72 @@ reg = <0 0xe6060000 0 0x50c>; };
- ipmmu_vi0: mmu@febd0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a7796-cpg-mssr"; + reg = <0 0xe6150000 0 0x1000>; + clocks = <&extal_clk>, <&extalr_clk>; + clock-names = "extal", "extalr"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; };
- ipmmu_vc0: mmu@fe6b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A7796_PD_A3VC>; - #iommu-cells = <1>; - status = "disabled"; + rst: reset-controller@e6160000 { + compatible = "renesas,r8a7796-rst"; + reg = <0 0xe6160000 0 0x0200>; };
- ipmmu_pv0: mmu@fd800000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 5>; + sysc: system-controller@e6180000 { + compatible = "renesas,r8a7796-sysc"; + reg = <0 0xe6180000 0 0x0400>; + #power-domain-cells = <1>; + }; + + tsc: thermal@e6198000 { + compatible = "renesas,r8a7796-thermal"; + reg = <0 0xe6198000 0 0x100>, + <0 0xe61a0000 0 0x100>, + <0 0xe61a8000 0 0x100>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; + resets = <&cpg 522>; + #thermal-sensor-cells = <1>; + status = "okay"; };
- ipmmu_pv1: mmu@fd950000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; + intc_ex: interrupt-controller@e61c0000 { + compatible = "renesas,intc-ex-r8a7796", "renesas,irqc"; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0 0xe61c0000 0 0x200>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 407>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - status = "disabled"; + resets = <&cpg 407>; };
- ipmmu_ir: mmu@ff8b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A7796_PD_A3IR>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_hc: mmu@e6570000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: mmu@ffc80000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: mmu@ec670000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds0: mmu@e6740000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: mmu@e7740000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: mmu@e67b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7796-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7796-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7796-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a7796", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7796", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a7796", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; status = "disabled"; };
@@ -755,244 +568,37 @@ status = "disabled"; };
- can0: can@e6c30000 { - compatible = "renesas,can-r8a7796", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; + i2c_dvfs: i2c@e60b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,iic-r8a7796", + "renesas,rcar-gen3-iic", + "renesas,rmobile-iic"; + reg = <0 0xe60b0000 0 0x425>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 926>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 916>; + resets = <&cpg 926>; + dmas = <&dmac0 0x11>, <&dmac0 0x10>; + dma-names = "tx", "rx"; status = "disabled"; };
- can1: can@e6c38000 { - compatible = "renesas,can-r8a7796", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a7796", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 0x60>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a7796-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - drif00: rif@e6f40000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x64>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; - status = "disabled"; - }; - - drif01: rif@e6f50000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x64>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; - status = "disabled"; - }; - - drif10: rif@e6f60000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x64>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; - status = "disabled"; - }; - - drif11: rif@e6f70000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x64>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; - status = "disabled"; - }; - - drif20: rif@e6f80000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac1 0x28>, <&dmac2 0x28>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; - status = "disabled"; - }; - - drif21: rif@e6f90000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; - status = "disabled"; - }; - - drif30: rif@e6fa0000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x64>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; - status = "disabled"; - }; - - drif31: rif@e6fb0000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x64>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; - status = "disabled"; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7796", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 520>; + resets = <&cpg 520>; status = "disabled"; };
@@ -1066,162 +672,61 @@ status = "disabled"; };
- scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; + hsusb: usb@e6590000 { + compatible = "renesas,usbhs-r8a7796", + "renesas,rcar-gen3-usbhs"; + reg = <0 0xe6590000 0 0x100>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 704>; + dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, + <&usb_dmac1 0>, <&usb_dmac1 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy0>; + phy-names = "usb"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 207>; + resets = <&cpg 704>; status = "disabled"; };
- scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; + usb_dmac0: dma-controller@e65a0000 { + compatible = "renesas,r8a7796-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65a0000 0 0x100>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 330>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; + resets = <&cpg 330>; + #dma-cells = <1>; + dma-channels = <2>; };
- scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; + usb_dmac1: dma-controller@e65b0000 { + compatible = "renesas,r8a7796-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65b0000 0 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 331>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; + resets = <&cpg 331>; + #dma-cells = <1>; + dma-channels = <2>; };
- msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; + usb3_phy0: usb-phy@e65ee000 { + compatible = "renesas,r8a7796-usb3-phy", + "renesas,rcar-gen3-usb3-phy"; + reg = <0 0xe65ee000 0 0x90>; + clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, + <&usb_extal_clk>; + clock-names = "usb3-if", "usb3s_clk", "usb_extal"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; + resets = <&cpg 328>; + #phy-cells = <0>; status = "disabled"; };
@@ -1351,306 +856,803 @@ <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; };
- audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; + ipmmu_ds0: mmu@e6740000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; + #iommu-cells = <1>; };
- audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>, - <&ipmmu_mp 18>, <&ipmmu_mp 19>, - <&ipmmu_mp 20>, <&ipmmu_mp 21>, - <&ipmmu_mp 22>, <&ipmmu_mp 23>, - <&ipmmu_mp 24>, <&ipmmu_mp 25>, - <&ipmmu_mp 26>, <&ipmmu_mp 27>, - <&ipmmu_mp 28>, <&ipmmu_mp 29>, - <&ipmmu_mp 30>, <&ipmmu_mp 31>; + #iommu-cells = <1>; };
- usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7796-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; + ipmmu_hc: mmu@e6570000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; + #iommu-cells = <1>; };
- usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7796-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; + ipmmu_ir: mmu@ff8b0000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xff8b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 3>; + power-domains = <&sysc R8A7796_PD_A3IR>; + #iommu-cells = <1>; };
- hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7796", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0>; - phy-names = "usb"; + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mp: mmu@ec670000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: mmu@fd800000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 5>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv1: mmu@fd950000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xfd950000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 7>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: mmu@fe6b0000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 8>; + power-domains = <&sysc R8A7796_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a7796"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 9>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + avb: ethernet@e6800000 { + compatible = "renesas,etheravb-r8a7796", + "renesas,etheravb-rcar-gen3"; + reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15", + "ch16", "ch17", "ch18", "ch19", + "ch20", "ch21", "ch22", "ch23", + "ch24"; + clocks = <&cpg CPG_MOD 812>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 812>; + phy-mode = "rgmii"; + iommus = <&ipmmu_ds0 16>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can0: can@e6c30000 { + compatible = "renesas,can-r8a7796", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c30000 0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 916>, + <&cpg CPG_CORE R8A7796_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 916>; + status = "disabled"; + }; + + can1: can@e6c38000 { + compatible = "renesas,can-r8a7796", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c38000 0 0x1000>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 915>, + <&cpg CPG_CORE R8A7796_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 915>; + status = "disabled"; + }; + + canfd: can@e66c0000 { + compatible = "renesas,r8a7796-canfd", + "renesas,rcar-gen3-canfd"; + reg = <0 0xe66c0000 0 0x8000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 914>, + <&cpg CPG_CORE R8A7796_CLK_CANFD>, + <&can_clk>; + clock-names = "fck", "canfd", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 914>; + status = "disabled"; + + channel0 { + status = "disabled"; + }; + + channel1 { + status = "disabled"; + }; + }; + + pwm0: pwm@e6e30000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e30000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm1: pwm@e6e31000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e31000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm2: pwm@e6e32000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e32000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm3: pwm@e6e33000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e33000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm4: pwm@e6e34000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e34000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm5: pwm@e6e35000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e35000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm6: pwm@e6e36000 { + compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; + reg = <0 0xe6e36000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + status = "disabled"; + }; + + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 64>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 207>; + status = "disabled"; + }; + + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 64>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 206>; + status = "disabled"; + }; + + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 64>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 310>; + status = "disabled"; + }; + + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 64>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 204>; + status = "disabled"; + }; + + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 64>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 203>; + status = "disabled"; + }; + + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a7796", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 64>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, + <&cpg CPG_CORE R8A7796_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 202>; + status = "disabled"; + }; + + msiof0: spi@e6e90000 { + compatible = "renesas,msiof-r8a7796", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6e90000 0 0x0064>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 211>; + dmas = <&dmac1 0x41>, <&dmac1 0x40>, + <&dmac2 0x41>, <&dmac2 0x40>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 211>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof1: spi@e6ea0000 { + compatible = "renesas,msiof-r8a7796", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6ea0000 0 0x0064>; + interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 210>; + dmas = <&dmac1 0x43>, <&dmac1 0x42>, + <&dmac2 0x43>, <&dmac2 0x42>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 210>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof2: spi@e6c00000 { + compatible = "renesas,msiof-r8a7796", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c00000 0 0x0064>; + interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 209>; + dmas = <&dmac0 0x45>, <&dmac0 0x44>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 209>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof3: spi@e6c10000 { + compatible = "renesas,msiof-r8a7796", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c10000 0 0x0064>; + interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 208>; + dmas = <&dmac0 0x47>, <&dmac0 0x46>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 208>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 811>; + renesas,id = <0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin0csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin0>; + }; + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin0>; + }; + }; + }; + }; + + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 704>; + resets = <&cpg 810>; + renesas,id = <1>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin1csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin1>; + }; + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin1>; + }; + }; + }; };
- usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a7796-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; + vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef2000 0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; + resets = <&cpg 809>; + renesas,id = <2>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin2>; + }; + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin2>; + }; + }; + }; };
- xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a7796", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; + vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; + resets = <&cpg 808>; + renesas,id = <3>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin3>; + }; + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin3>; + }; + }; + }; };
- usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a7796-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; + resets = <&cpg 807>; + renesas,id = <4>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin4csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin4>; + }; + vin4csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin4>; + }; + }; + }; };
- ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; + vin5: video@e6ef5000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef5000 0 0x1000>; + interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 806>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>; + resets = <&cpg 806>; + renesas,id = <5>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin5csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin5>; + }; + vin5csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin5>; + }; + }; + }; };
- ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; - companion= <&ohci0>; + vin6: video@e6ef6000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef6000 0 0x1000>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 805>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>; + resets = <&cpg 805>; + renesas,id = <6>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin6csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin6>; + }; + vin6csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin6>; + }; + }; + }; + }; + + vin7: video@e6ef7000 { + compatible = "renesas,vin-r8a7796"; + reg = <0 0xe6ef7000 0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 804>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 804>; + renesas,id = <7>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin7csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin7>; + }; + vin7csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin7>; + }; + }; + }; };
- usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a7796", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; + drif00: rif@e6f40000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f40000 0 0x64>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 515>; + clock-names = "fck"; + dmas = <&dmac1 0x20>, <&dmac2 0x20>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>; - #phy-cells = <0>; + resets = <&cpg 515>; + renesas,bonding = <&drif01>; status = "disabled"; };
- ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1>; - phy-names = "usb"; + drif01: rif@e6f50000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f50000 0 0x64>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 514>; + clock-names = "fck"; + dmas = <&dmac1 0x22>, <&dmac2 0x22>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; + resets = <&cpg 514>; + renesas,bonding = <&drif00>; status = "disabled"; };
- ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1>; - phy-names = "usb"; - companion= <&ohci1>; + drif10: rif@e6f60000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f60000 0 0x64>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 513>; + clock-names = "fck"; + dmas = <&dmac1 0x24>, <&dmac2 0x24>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; + resets = <&cpg 513>; + renesas,bonding = <&drif11>; status = "disabled"; };
- usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a7796", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; + drif11: rif@e6f70000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f70000 0 0x64>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 512>; + clock-names = "fck"; + dmas = <&dmac1 0x26>, <&dmac2 0x26>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <0>; + resets = <&cpg 512>; + renesas,bonding = <&drif10>; status = "disabled"; };
- sdhi0: sd@ee100000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - max-frequency = <200000000>; + drif20: rif@e6f80000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f80000 0 0x64>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 511>; + clock-names = "fck"; + dmas = <&dmac1 0x28>, <&dmac2 0x28>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 314>; + resets = <&cpg 511>; + renesas,bonding = <&drif21>; status = "disabled"; };
- sdhi1: sd@ee120000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>; - max-frequency = <200000000>; + drif21: rif@e6f90000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6f90000 0 0x64>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 510>; + clock-names = "fck"; + dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 313>; + resets = <&cpg 510>; + renesas,bonding = <&drif20>; status = "disabled"; };
- sdhi2: sd@ee140000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - max-frequency = <200000000>; + drif30: rif@e6fa0000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6fa0000 0 0x64>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 509>; + clock-names = "fck"; + dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 312>; + resets = <&cpg 509>; + renesas,bonding = <&drif31>; status = "disabled"; };
- sdhi3: sd@ee160000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - max-frequency = <200000000>; + drif31: rif@e6fb0000 { + compatible = "renesas,r8a7796-drif", + "renesas,rcar-gen3-drif"; + reg = <0 0xe6fb0000 0 0x64>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 508>; + clock-names = "fck"; + dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; + dma-names = "rx", "rx"; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 311>; + resets = <&cpg 508>; + renesas,bonding = <&drif30>; status = "disabled"; };
- tsc: thermal@e6198000 { - compatible = "renesas,r8a7796-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - status = "okay"; - }; - rcar_sound: sound@ec500000 { /* * #sound-dai-cells is required @@ -1845,16 +1847,335 @@ dma-names = "rx", "tx", "rxu", "txu"; }; }; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + }; + port@1 { + reg = <1>; + }; + }; + }; + + audma0: dma-controller@ec700000 { + compatible = "renesas,dmac-r8a7796", + "renesas,rcar-dmac"; + reg = <0 0xec700000 0 0x10000>; + interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 502>; + clock-names = "fck"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 502>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, + <&ipmmu_mp 2>, <&ipmmu_mp 3>, + <&ipmmu_mp 4>, <&ipmmu_mp 5>, + <&ipmmu_mp 6>, <&ipmmu_mp 7>, + <&ipmmu_mp 8>, <&ipmmu_mp 9>, + <&ipmmu_mp 10>, <&ipmmu_mp 11>, + <&ipmmu_mp 12>, <&ipmmu_mp 13>, + <&ipmmu_mp 14>, <&ipmmu_mp 15>; + }; + + audma1: dma-controller@ec720000 { + compatible = "renesas,dmac-r8a7796", + "renesas,rcar-dmac"; + reg = <0 0xec720000 0 0x10000>; + interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 501>; + clock-names = "fck"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 501>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>, + <&ipmmu_mp 18>, <&ipmmu_mp 19>, + <&ipmmu_mp 20>, <&ipmmu_mp 21>, + <&ipmmu_mp 22>, <&ipmmu_mp 23>, + <&ipmmu_mp 24>, <&ipmmu_mp 25>, + <&ipmmu_mp 26>, <&ipmmu_mp 27>, + <&ipmmu_mp 28>, <&ipmmu_mp 29>, + <&ipmmu_mp 30>, <&ipmmu_mp 31>; + }; + + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a7796", + "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + usb3_peri0: usb@ee020000 { + compatible = "renesas,r8a7796-usb3-peri", + "renesas,rcar-gen3-usb3-peri"; + reg = <0 0xee020000 0 0x400>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 703>; + status = "disabled"; + }; + + ohci1: usb@ee0a0000 { + compatible = "generic-ohci"; + reg = <0 0xee0a0000 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + companion= <&ohci0>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 703>; + status = "disabled"; + }; + + ehci1: usb@ee0a0100 { + compatible = "generic-ehci"; + reg = <0 0xee0a0100 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; + companion= <&ohci1>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a7796", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 703>; + #phy-cells = <0>; + status = "disabled"; + }; + + usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a7796", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0a0200 0 0x700>; + clocks = <&cpg CPG_MOD 702>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 702>; + #phy-cells = <0>; + status = "disabled"; + }; + + sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a7796", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 314>; + status = "disabled"; + }; + + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a7796", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 313>; + status = "disabled"; + }; + + sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a7796", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 312>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a7796", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 311>; + status = "disabled"; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 408>; };
pciec0: pcie@fe000000 { + compatible = "renesas,pcie-r8a7796", + "renesas,pcie-rcar-gen3"; reg = <0 0xfe000000 0 0x80000>; - /* placeholder */ + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000 + 0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000 + 0x02000000 0 0x30000000 0 0x30000000 0 0x08000000 + 0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 319>; + status = "disabled"; };
pciec1: pcie@ee800000 { + compatible = "renesas,pcie-r8a7796", + "renesas,pcie-rcar-gen3"; reg = <0 0xee800000 0 0x80000>; - /* placeholder */ + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000 + 0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000 + 0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000 + 0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 318>; + status = "disabled"; + }; + + imr-lx4@fe860000 { + compatible = "renesas,r8a7796-imr-lx4", + "renesas,imr-lx4"; + reg = <0 0xfe860000 0 0x2000>; + interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 823>; + power-domains = <&sysc R8A7796_PD_A3VC>; + resets = <&cpg 823>; + }; + + imr-lx4@fe870000 { + compatible = "renesas,r8a7796-imr-lx4", + "renesas,imr-lx4"; + reg = <0 0xfe870000 0 0x2000>; + interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 822>; + power-domains = <&sysc R8A7796_PD_A3VC>; + resets = <&cpg 822>; };
fdp1@fe940000 { @@ -1875,17 +2196,6 @@ resets = <&cpg 615>; };
- vspb: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - fcpvb0: fcp@fe96f000 { compatible = "renesas,fcpv"; reg = <0 0xfe96f000 0 0x200>; @@ -1894,17 +2204,6 @@ resets = <&cpg 607>; };
- vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - fcpvi0: fcp@fe9af000 { compatible = "renesas,fcpv"; reg = <0 0xfe9af000 0 0x200>; @@ -1914,9 +2213,47 @@ iommus = <&ipmmu_vc0 19>; };
+ fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 603>; + iommus = <&ipmmu_vi0 8>; + }; + + fcpvd1: fcp@fea2f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea2f000 0 0x200>; + clocks = <&cpg CPG_MOD 602>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 602>; + iommus = <&ipmmu_vi0 9>; + }; + + fcpvd2: fcp@fea37000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea37000 0 0x200>; + clocks = <&cpg CPG_MOD 601>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 601>; + iommus = <&ipmmu_vi0 10>; + }; + + vspb: vsp@fe960000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe960000 0 0x8000>; + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 626>; + power-domains = <&sysc R8A7796_PD_A3VC>; + resets = <&cpg 626>; + + renesas,fcp = <&fcpvb0>; + }; + vspd0: vsp@fea20000 { compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x8000>; + reg = <0 0xfea20000 0 0x5000>; interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 623>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; @@ -1925,18 +2262,9 @@ renesas,fcp = <&fcpvd0>; };
- fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - vspd1: vsp@fea28000 { compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x8000>; + reg = <0 0xfea28000 0 0x5000>; interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 622>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; @@ -1945,18 +2273,9 @@ renesas,fcp = <&fcpvd1>; };
- fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - vspd2: vsp@fea30000 { compatible = "renesas,vsp2"; - reg = <0 0xfea30000 0 0x8000>; + reg = <0 0xfea30000 0 0x5000>; interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 621>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; @@ -1965,13 +2284,126 @@ renesas,fcp = <&fcpvd2>; };
- fcpvd2: fcp@fea37000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea37000 0 0x200>; - clocks = <&cpg CPG_MOD 601>; + vspi0: vsp@fe9a0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9a0000 0 0x8000>; + interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 631>; + power-domains = <&sysc R8A7796_PD_A3VC>; + resets = <&cpg 631>; + + renesas,fcp = <&fcpvi0>; + }; + + csi20: csi2@fea80000 { + compatible = "renesas,r8a7796-csi2"; + reg = <0 0xfea80000 0 0x10000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 714>; power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 601>; - iommus = <&ipmmu_vi0 10>; + resets = <&cpg 714>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi20vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi20>; + }; + csi20vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi20>; + }; + csi20vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi20>; + }; + csi20vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi20>; + }; + csi20vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi20>; + }; + csi20vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi20>; + }; + csi20vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi20>; + }; + csi20vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi20>; + }; + }; + }; + }; + + csi40: csi2@feaa0000 { + compatible = "renesas,r8a7796-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + csi40vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi40>; + }; + csi40vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi40>; + }; + csi40vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi40>; + }; + csi40vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi40>; + }; + }; + + }; };
hdmi0: hdmi@fead0000 { @@ -1996,6 +2428,10 @@ port@1 { reg = <1>; }; + port@2 { + /* HDMI sound */ + reg = <2>; + }; }; };
@@ -2039,35 +2475,12 @@ }; };
- imr-lx4@fe860000 { - compatible = "renesas,r8a7796-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe860000 0 0x2000>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 823>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 823>; - }; - - imr-lx4@fe870000 { - compatible = "renesas,r8a7796-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe870000 0 0x2000>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 822>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 822>; + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; }; };
- timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; - }; - thermal-zones { sensor_thermal1: sensor-thermal1 { polling-delay-passive = <250>; @@ -2077,12 +2490,12 @@ trips { sensor1_passive: sensor1-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor1_crit: sensor1-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2103,12 +2516,12 @@ trips { sensor2_passive: sensor2-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor2_crit: sensor2-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2129,12 +2542,12 @@ trips { sensor3_passive: sensor3-passive { temperature = <95000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "passive"; }; sensor3_crit: sensor3-crit { temperature = <120000>; - hysteresis = <2000>; + hysteresis = <1000>; type = "critical"; }; }; @@ -2148,6 +2561,14 @@ }; };
+ timer { + compatible = "arm,armv8-timer"; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; + }; + /* External USB clocks - can be overridden by the board */ usb3s0_clk: usb3s0 { compatible = "fixed-clock"; diff --git a/arch/arm/dts/r8a77965-salvator-x.dts b/arch/arm/dts/r8a77965-salvator-x.dts index 75d890d91d..340a3c72b6 100644 --- a/arch/arm/dts/r8a77965-salvator-x.dts +++ b/arch/arm/dts/r8a77965-salvator-x.dts @@ -19,3 +19,31 @@ reg = <0x0 0x48000000 0x0 0x78000000>; }; }; + +&du { + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>, + <&versaclock5 1>, + <&x21_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.3", + "dclkin.0", "dclkin.1", "dclkin.3"; +}; + +&hdmi0 { + status = "okay"; + + ports { + port@1 { + reg = <1>; + rcar_dw_hdmi0_out: endpoint { + remote-endpoint = <&hdmi0_con>; + }; + }; + }; +}; + +&hdmi0_con { + remote-endpoint = <&rcar_dw_hdmi0_out>; +}; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi index 84ecb4631f..ef8cdc6a16 100644 --- a/arch/arm/dts/r8a77965.dtsi +++ b/arch/arm/dts/r8a77965.dtsi @@ -8,8 +8,9 @@ * Copyright (C) 2016 Renesas Electronics Corp. */
-#include <dt-bindings/clock/renesas-cpg-mssr.h> +#include <dt-bindings/clock/r8a77965-cpg-mssr.h> #include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/power/r8a77965-sysc.h>
#define CPG_AUDIO_CLK_I 10
@@ -19,12 +20,44 @@ #size-cells = <2>;
aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; i2c7 = &i2c_dvfs; };
- psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; + /* + * The external audio clocks are configured as 0 Hz fixed frequency + * clocks by default. + * Boards that provide audio clocks should override them. + */ + audio_clk_a: audio_clk_a { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_b: audio_clk_b { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_c: audio_clk_c { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; };
cpus { @@ -35,23 +68,23 @@ compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x0>; device_type = "cpu"; - power-domains = <&sysc 0>; + power-domains = <&sysc R8A77965_PD_CA57_CPU0>; next-level-cache = <&L2_CA57>; enable-method = "psci"; };
a57_1: cpu@1 { - compatible = "arm,cortex-a57","arm,armv8"; + compatible = "arm,cortex-a57", "arm,armv8"; reg = <0x1>; device_type = "cpu"; - power-domains = <&sysc 1>; + power-domains = <&sysc R8A77965_PD_CA57_CPU1>; next-level-cache = <&L2_CA57>; enable-method = "psci"; };
L2_CA57: cache-controller-0 { compatible = "cache"; - power-domains = <&sysc 12>; + power-domains = <&sysc R8A77965_PD_CA57_SCU>; cache-unified; cache-level = <2>; }; @@ -71,34 +104,24 @@ clock-frequency = <0>; };
- /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { + /* External PCIe clock - can be overridden by the board */ + pcie_bus_clk: pcie_bus { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <0>; };
- audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; + pmu_a57 { + compatible = "arm,cortex-a57-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a57_0>, + <&a57_1>; };
- /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; + psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; };
/* External SCIF clock - to be overridden by boards that provide it */ @@ -108,42 +131,6 @@ clock-frequency = <0>; };
- /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, - <&a57_1>; - }; - soc: soc { compatible = "simple-bus"; interrupt-parent = <&gic>; @@ -151,52 +138,14 @@ #size-cells = <2>; ranges;
- gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc 32>; - resets = <&cpg 408>; - }; - - pfc: pin-controller@e6060000 { - compatible = "renesas,pfc-r8a77965"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77965-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77965-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77965-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; + rwdt: watchdog@e6020000 { + compatible = "renesas,r8a77965-wdt", + "renesas,rcar-gen3-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; };
gpio0: gpio@e6050000 { @@ -210,7 +159,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 912>; };
@@ -225,7 +174,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 911>; };
@@ -240,7 +189,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 910>; };
@@ -255,7 +204,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 909>; };
@@ -270,7 +219,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 908>; };
@@ -285,7 +234,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 907>; };
@@ -300,7 +249,7 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 906>; };
@@ -315,10 +264,51 @@ #interrupt-cells = <2>; interrupt-controller; clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 905>; };
+ pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a77965"; + reg = <0 0xe6060000 0 0x50c>; + }; + + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a77965-cpg-mssr"; + reg = <0 0xe6150000 0 0x1000>; + clocks = <&extal_clk>, <&extalr_clk>; + clock-names = "extal", "extalr"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; + }; + + rst: reset-controller@e6160000 { + compatible = "renesas,r8a77965-rst"; + reg = <0 0xe6160000 0 0x0200>; + }; + + sysc: system-controller@e6180000 { + compatible = "renesas,r8a77965-sysc"; + reg = <0 0xe6180000 0 0x0400>; + #power-domain-cells = <1>; + }; + + tsc: thermal@e6198000 { + compatible = "renesas,r8a77965-thermal"; + reg = <0 0xe6198000 0 0x100>, + <0 0xe61a0000 0 0x100>, + <0 0xe61a8000 0 0x100>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 522>; + #thermal-sensor-cells = <1>; + status = "okay"; + }; + intc_ex: interrupt-controller@e61c0000 { compatible = "renesas,intc-ex-r8a77965", "renesas,irqc"; #interrupt-cells = <2>; @@ -331,85 +321,362 @@ GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 407>; };
- dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc 32>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; };
- dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc 32>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; + i2c1: i2c@e6508000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6508000 0 0x40>; + interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 930>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 930>; + dmas = <&dmac1 0x93>, <&dmac1 0x92>, + <&dmac2 0x93>, <&dmac2 0x92>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; };
- dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH + i2c2: i2c@e6510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6510000 0 0x40>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 929>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 929>; + dmas = <&dmac1 0x95>, <&dmac1 0x94>, + <&dmac2 0x95>, <&dmac2 0x94>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c3: i2c@e66d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d0000 0 0x40>; + interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 928>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 928>; + dmas = <&dmac0 0x97>, <&dmac0 0x96>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c4: i2c@e66d8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d8000 0 0x40>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 927>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 927>; + dmas = <&dmac0 0x99>, <&dmac0 0x98>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c5: i2c@e66e0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e0000 0 0x40>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 919>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 919>; + dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c6: i2c@e66e8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77965", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e8000 0 0x40>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 918>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 918>; + dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c_dvfs: i2c@e60b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,iic-r8a77965", + "renesas,rcar-gen3-iic", + "renesas,rmobile-iic"; + reg = <0 0xe60b0000 0 0x425>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 926>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 926>; + dmas = <&dmac0 0x11>, <&dmac0 0x10>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a77965", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 0x60>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 520>; + status = "disabled"; + }; + + hscif1: serial@e6550000 { + compatible = "renesas,hscif-r8a77965", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6550000 0 0x60>; + interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 519>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x33>, <&dmac1 0x32>, + <&dmac2 0x33>, <&dmac2 0x32>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 519>; + status = "disabled"; + }; + + hscif2: serial@e6560000 { + compatible = "renesas,hscif-r8a77965", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6560000 0 0x60>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 518>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x35>, <&dmac1 0x34>, + <&dmac2 0x35>, <&dmac2 0x34>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 518>; + status = "disabled"; + }; + + hscif3: serial@e66a0000 { + compatible = "renesas,hscif-r8a77965", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66a0000 0 0x60>; + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 517>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 517>; + status = "disabled"; + }; + + hscif4: serial@e66b0000 { + compatible = "renesas,hscif-r8a77965", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66b0000 0 0x60>; + interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 516>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x39>, <&dmac0 0x38>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 516>; + status = "disabled"; + }; + + hsusb: usb@e6590000 { + compatible = "renesas,usbhs-r8a7796", + "renesas,rcar-gen3-usbhs"; + reg = <0 0xe6590000 0 0x100>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 704>; + dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, + <&usb_dmac1 0>, <&usb_dmac1 1>; + dma-names = "ch0", "ch1", "ch2", "ch3"; + renesas,buswait = <11>; + phys = <&usb2_phy0>; + phy-names = "usb"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 704>; + status = "disabled"; + }; + + usb_dmac0: dma-controller@e65a0000 { + compatible = "renesas,r8a77965-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65a0000 0 0x100>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 330>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 330>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb_dmac1: dma-controller@e65b0000 { + compatible = "renesas,r8a77965-usb-dmac", + "renesas,usb-dmac"; + reg = <0 0xe65b0000 0 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1"; + clocks = <&cpg CPG_MOD 331>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 331>; + #dma-cells = <1>; + dma-channels = <2>; + }; + + usb3_phy0: usb-phy@e65ee000 { + compatible = "renesas,r8a77965-usb3-phy", + "renesas,rcar-gen3-usb3-phy"; + reg = <0 0xe65ee000 0 0x90>; + clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, + <&usb_extal_clk>; + clock-names = "usb3-if", "usb3s_clk", "usb_extal"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 328>; + #phy-cells = <0>; + status = "disabled"; + }; + + dmac0: dma-controller@e6700000 { + compatible = "renesas,dmac-r8a77965", + "renesas,rcar-dmac"; + reg = <0 0xe6700000 0 0x10000>; + interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 219>; + clock-names = "fck"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 219>; + #dma-cells = <1>; + dma-channels = <16>; + }; + + dmac1: dma-controller@e7300000 { + compatible = "renesas,dmac-r8a77965", + "renesas,rcar-dmac"; + reg = <0 0xe7300000 0 0x10000>; + interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 218>; + clock-names = "fck"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 218>; + #dma-cells = <1>; + dma-channels = <16>; + }; + + dmac2: dma-controller@e7310000 { + compatible = "renesas,dmac-r8a77965", + "renesas,rcar-dmac"; + reg = <0 0xe7310000 0 0x10000>; + interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH @@ -431,107 +698,99 @@ "ch12", "ch13", "ch14", "ch15"; clocks = <&cpg CPG_MOD 217>; clock-names = "fck"; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 217>; #dma-cells = <1>; dma-channels = <16>; };
- scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc 32>; - resets = <&cpg 207>; - status = "disabled"; + ipmmu_ds0: mmu@e6740000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; };
- scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc 32>; - resets = <&cpg 206>; - status = "disabled"; + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; };
- scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - power-domains = <&sysc 32>; - resets = <&cpg 310>; - status = "disabled"; + ipmmu_hc: mmu@e6570000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; };
- scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc 32>; - resets = <&cpg 204>; - status = "disabled"; + ipmmu_ir: mmu@ff8b0000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xff8b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 3>; + power-domains = <&sysc R8A77965_PD_A3IR>; + #iommu-cells = <1>; };
- scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc 32>; - resets = <&cpg 203>; - status = "disabled"; + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; };
- scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE 20>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc 32>; - resets = <&cpg 202>; - status = "disabled"; + ipmmu_mp: mmu@ec670000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: mmu@fd800000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 10>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: mmu@fe6b0000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 12>; + power-domains = <&sysc R8A77965_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 14>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vp0: mmu@fe990000 { + compatible = "renesas,ipmmu-r8a77965"; + reg = <0 0xfe990000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 16>; + power-domains = <&sysc R8A77965_PD_A3VP>; + #iommu-cells = <1>; };
avb: ethernet@e6800000 { @@ -571,7 +830,7 @@ "ch20", "ch21", "ch22", "ch23", "ch24"; clocks = <&cpg CPG_MOD 812>; - power-domains = <&sysc 32>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; resets = <&cpg 812>; phy-mode = "rgmii"; #address-cells = <1>; @@ -579,193 +838,981 @@ status = "disabled"; };
- csi20: csi2@fea80000 { - reg = <0 0xfea80000 0 0x10000>; - /* placeholder */ + pwm0: pwm@e6e30000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e30000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm1: pwm@e6e31000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e31000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm2: pwm@e6e32000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e32000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm3: pwm@e6e33000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e33000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm4: pwm@e6e34000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e34000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm5: pwm@e6e35000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e35000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + pwm6: pwm@e6e36000 { + compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; + reg = <0 0xe6e36000 0 8>; + #pwm-cells = <2>; + clocks = <&cpg CPG_MOD 523>; + resets = <&cpg 523>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + status = "disabled"; + }; + + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 64>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 207>; + status = "disabled"; + }; + + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 64>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 206>; + status = "disabled"; + }; + + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 64>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 310>; + status = "disabled"; + }; + + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 64>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 204>; + status = "disabled"; + }; + + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 64>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 203>; + status = "disabled"; + }; + + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a77965", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 64>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, + <&cpg CPG_CORE R8A77965_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 202>; + status = "disabled"; + }; + + msiof0: spi@e6e90000 { + compatible = "renesas,msiof-r8a77965", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6e90000 0 0x0064>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 211>; + dmas = <&dmac1 0x41>, <&dmac1 0x40>, + <&dmac2 0x41>, <&dmac2 0x40>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 211>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof1: spi@e6ea0000 { + compatible = "renesas,msiof-r8a77965", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6ea0000 0 0x0064>; + interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 210>; + dmas = <&dmac1 0x43>, <&dmac1 0x42>, + <&dmac2 0x43>, <&dmac2 0x42>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 210>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof2: spi@e6c00000 { + compatible = "renesas,msiof-r8a77965", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c00000 0 0x0064>; + interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 209>; + dmas = <&dmac0 0x45>, <&dmac0 0x44>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 209>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof3: spi@e6c10000 { + compatible = "renesas,msiof-r8a77965", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c10000 0 0x0064>; + interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 208>; + dmas = <&dmac0 0x47>, <&dmac0 0x46>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 208>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 811>; + renesas,id = <0>; + status = "disabled";
ports { #address-cells = <1>; #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin0csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin0>; + }; + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin0>; + }; + }; }; };
- csi40: csi2@feaa0000 { - reg = <0 0xfeaa0000 0 0x10000>; - /* placeholder */ + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 810>; + renesas,id = <1>; + status = "disabled";
ports { #address-cells = <1>; #size-cells = <0>; - }; - };
- vin0: video@e6ef0000 { - reg = <0 0xe6ef0000 0 0x1000>; - /* placeholder */ - }; + port@1 { + #address-cells = <1>; + #size-cells = <0>;
- vin1: video@e6ef1000 { - reg = <0 0xe6ef1000 0 0x1000>; - /* placeholder */ + reg = <1>; + + vin1csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin1>; + }; + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin1>; + }; + }; + }; };
vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a77965"; reg = <0 0xe6ef2000 0 0x1000>; - /* placeholder */ + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 809>; + renesas,id = <2>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin2>; + }; + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin2>; + }; + }; + }; };
vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a77965"; reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 808>; + renesas,id = <3>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin3>; + }; + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin3>; + }; + }; + }; + }; + + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 807>; + renesas,id = <4>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin4csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin4>; + }; + vin4csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin4>; + }; + }; + }; + }; + + vin5: video@e6ef5000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef5000 0 0x1000>; + interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 806>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 806>; + renesas,id = <5>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin5csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin5>; + }; + vin5csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin5>; + }; + }; + }; + }; + + vin6: video@e6ef6000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef6000 0 0x1000>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 805>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 805>; + renesas,id = <6>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin6csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin6>; + }; + vin6csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin6>; + }; + }; + }; + }; + + vin7: video@e6ef7000 { + compatible = "renesas,vin-r8a77965"; + reg = <0 0xe6ef7000 0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 804>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 804>; + renesas,id = <7>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin7csi20: endpoint@0 { + reg = <0>; + remote-endpoint= <&csi20vin7>; + }; + vin7csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin7>; + }; + }; + }; + }; + + rcar_sound: sound@ec500000 { + reg = <0 0xec500000 0 0x1000>, /* SCU */ + <0 0xec5a0000 0 0x100>, /* ADG */ + <0 0xec540000 0 0x1000>, /* SSIU */ + <0 0xec541000 0 0x280>, /* SSI */ + <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ /* placeholder */ + + rcar_sound,dvc { + dvc0: dvc-0 { + }; + dvc1: dvc-1 { + }; + }; + + rcar_sound,src { + src0: src-0 { + }; + src1: src-1 { + }; + }; + + rcar_sound,ssi { + ssi0: ssi-0 { + }; + ssi1: ssi-1 { + }; + }; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + }; + port@1 { + reg = <1>; + }; + }; + }; + + xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a77965", + "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + usb3_peri0: usb@ee020000 { + compatible = "renesas,r8a77965-usb3-peri", + "renesas,rcar-gen3-usb3-peri"; + reg = <0 0xee020000 0 0x400>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 703>; + status = "disabled"; + }; + + ohci1: usb@ee0a0000 { + compatible = "generic-ohci"; + reg = <0 0xee0a0000 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + companion = <&ohci0>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 703>; + status = "disabled"; + }; + + ehci1: usb@ee0a0100 { + compatible = "generic-ehci"; + reg = <0 0xee0a0100 0 0x100>; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 702>; + phys = <&usb2_phy1>; + phy-names = "usb"; + companion = <&ohci1>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 702>; + status = "disabled"; + }; + + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a77965", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 703>; + #phy-cells = <0>; + status = "disabled"; + }; + + usb2_phy1: usb-phy@ee0a0200 { + compatible = "renesas,usb2-phy-r8a77965", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee0a0200 0 0x700>; + clocks = <&cpg CPG_MOD 703>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 703>; + #phy-cells = <0>; + status = "disabled"; + }; + + sdhi0: sd@ee100000 { + compatible = "renesas,sdhi-r8a77965", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 314>; + status = "disabled"; + }; + + sdhi1: sd@ee120000 { + compatible = "renesas,sdhi-r8a77965", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 313>; + status = "disabled"; + }; + + sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a77965", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 312>; + status = "disabled"; + }; + + sdhi3: sd@ee160000 { + compatible = "renesas,sdhi-r8a77965", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 311>; + status = "disabled"; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 408>; };
- vin4: video@e6ef4000 { - reg = <0 0xe6ef4000 0 0x1000>; - /* placeholder */ + pciec0: pcie@fe000000 { + compatible = "renesas,pcie-r8a77965", + "renesas,pcie-rcar-gen3"; + reg = <0 0xfe000000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000 + 0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000 + 0x02000000 0 0x30000000 0 0x30000000 0 0x08000000 + 0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 319>; + status = "disabled"; };
- vin5: video@e6ef5000 { - reg = <0 0xe6ef5000 0 0x1000>; - /* placeholder */ + pciec1: pcie@ee800000 { + compatible = "renesas,pcie-r8a77965", + "renesas,pcie-rcar-gen3"; + reg = <0 0xee800000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0xff>; + device_type = "pci"; + ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000 + 0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000 + 0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000 + 0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; + /* Map all possible DDR as inbound ranges */ + dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; + clock-names = "pcie", "pcie_bus"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 318>; + status = "disabled"; };
- vin6: video@e6ef6000 { - reg = <0 0xe6ef6000 0 0x1000>; - /* placeholder */ + fcpf0: fcp@fe950000 { + compatible = "renesas,fcpf"; + reg = <0 0xfe950000 0 0x200>; + clocks = <&cpg CPG_MOD 615>; + power-domains = <&sysc R8A77965_PD_A3VP>; + resets = <&cpg 615>; };
- vin7: video@e6ef7000 { - reg = <0 0xe6ef7000 0 0x1000>; - /* placeholder */ - }; + vspb: vsp@fe960000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe960000 0 0x8000>; + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 626>; + power-domains = <&sysc R8A77965_PD_A3VP>; + resets = <&cpg 626>;
- ohci0: usb@ee080000 { - reg = <0 0xee080000 0 0x100>; - /* placeholder */ + renesas,fcp = <&fcpvb0>; };
- ehci0: usb@ee080100 { - reg = <0 0xee080100 0 0x100>; - /* placeholder */ + fcpvb0: fcp@fe96f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe96f000 0 0x200>; + clocks = <&cpg CPG_MOD 607>; + power-domains = <&sysc R8A77965_PD_A3VP>; + resets = <&cpg 607>; };
- usb2_phy0: usb-phy@ee080200 { - reg = <0 0xee080200 0 0x700>; - /* placeholder */ - }; + vspi0: vsp@fe9a0000 { + compatible = "renesas,vsp2"; + reg = <0 0xfe9a0000 0 0x8000>; + interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 631>; + power-domains = <&sysc R8A77965_PD_A3VP>; + resets = <&cpg 631>;
- usb2_phy1: usb-phy@ee0a0200 { - reg = <0 0xee0a0200 0 0x700>; - /* placeholder */ + renesas,fcp = <&fcpvi0>; };
- ohci1: usb@ee0a0000 { - reg = <0 0xee0a0000 0 0x100>; - /* placeholder */ + fcpvi0: fcp@fe9af000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe9af000 0 0x200>; + clocks = <&cpg CPG_MOD 611>; + power-domains = <&sysc R8A77965_PD_A3VP>; + resets = <&cpg 611>; };
- ehci1: usb@ee0a0100 { - reg = <0 0xee0a0100 0 0x100>; - /* placeholder */ - }; + vspd0: vsp@fea20000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea20000 0 0x5000>; + interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 623>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 623>;
- i2c0: i2c@e6500000 { - reg = <0 0xe6500000 0 0x40>; - /* placeholder */ + renesas,fcp = <&fcpvd0>; };
- i2c1: i2c@e6508000 { - reg = <0 0xe6508000 0 0x40>; - /* placeholder */ + fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 603>; };
- i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; + vspd1: vsp@fea28000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea28000 0 0x5000>; + interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 622>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 622>;
- reg = <0 0xe6510000 0 0x40>; - /* placeholder */ + renesas,fcp = <&fcpvd1>; };
- i2c3: i2c@e66d0000 { - reg = <0 0xe66d0000 0 0x40>; - /* placeholder */ + fcpvd1: fcp@fea2f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea2f000 0 0x200>; + clocks = <&cpg CPG_MOD 602>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 602>; };
- i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; + csi20: csi2@fea80000 { + compatible = "renesas,r8a77965-csi2"; + reg = <0 0xfea80000 0 0x10000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 714>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 714>; + status = "disabled";
- reg = <0 0xe66d8000 0 0x40>; - /* placeholder */ - }; + ports { + #address-cells = <1>; + #size-cells = <0>;
- i2c5: i2c@e66e0000 { - reg = <0 0xe66e0000 0 0x40>; - /* placeholder */ - }; + port@1 { + #address-cells = <1>; + #size-cells = <0>;
- i2c6: i2c@e66e8000 { - reg = <0 0xe66e8000 0 0x40>; - /* placeholder */ - }; + reg = <1>;
- i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a77965", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc 32>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; + csi20vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi20>; + }; + csi20vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi20>; + }; + csi20vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi20>; + }; + csi20vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi20>; + }; + csi20vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi20>; + }; + csi20vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi20>; + }; + csi20vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi20>; + }; + csi20vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi20>; + }; + }; + }; };
- pwm0: pwm@e6e30000 { - reg = <0 0xe6e30000 0 8>; - /* placeholder */ - }; + csi40: csi2@feaa0000 { + compatible = "renesas,r8a77965-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled";
- pwm1: pwm@e6e31000 { - reg = <0 0xe6e31000 0 8>; - #pwm-cells = <2>; - /* placeholder */ - }; + ports { + #address-cells = <1>; + #size-cells = <0>;
- pwm2: pwm@e6e32000 { - reg = <0 0xe6e32000 0 8>; - /* placeholder */ - }; + port@1 { + #address-cells = <1>; + #size-cells = <0>;
- pwm3: pwm@e6e33000 { - reg = <0 0xe6e33000 0 8>; - /* placeholder */ - }; + reg = <1>;
- pwm4: pwm@e6e34000 { - reg = <0 0xe6e34000 0 8>; - /* placeholder */ + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + csi40vin4: endpoint@4 { + reg = <4>; + remote-endpoint = <&vin4csi40>; + }; + csi40vin5: endpoint@5 { + reg = <5>; + remote-endpoint = <&vin5csi40>; + }; + csi40vin6: endpoint@6 { + reg = <6>; + remote-endpoint = <&vin6csi40>; + }; + csi40vin7: endpoint@7 { + reg = <7>; + remote-endpoint = <&vin7csi40>; + }; + }; + }; };
- pwm5: pwm@e6e35000 { - reg = <0 0xe6e35000 0 8>; - /* placeholder */ - }; + hdmi0: hdmi@fead0000 { + compatible = "renesas,r8a77965-hdmi", + "renesas,rcar-gen3-hdmi"; + reg = <0 0xfead0000 0 0x10000>; + interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 729>, + <&cpg CPG_CORE R8A77965_CLK_HDMI>; + clock-names = "iahb", "isfr"; + power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; + resets = <&cpg 729>; + status = "disabled";
- pwm6: pwm@e6e36000 { - reg = <0 0xe6e36000 0 8>; - /* placeholder */ + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + dw_hdmi0_in: endpoint { + remote-endpoint = <&du_out_hdmi0>; + }; + }; + port@1 { + reg = <1>; + }; + }; };
du: display@feb00000 { - reg = <0 0xfeb00000 0 0x80000>, - <0 0xfeb90000 0 0x14>; - /* placeholder */ + compatible = "renesas,du-r8a77965"; + reg = <0 0xfeb00000 0 0x80000>; + reg-names = "du"; + interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 721>; + clock-names = "du.0", "du.1", "du.3"; + status = "disabled"; + + vsps = <&vspd0 0 &vspd1 0 &vspd0 1>;
ports { #address-cells = <1>; @@ -779,6 +1826,7 @@ port@1 { reg = <1>; du_out_hdmi0: endpoint { + remote-endpoint = <&dw_hdmi0_in>; }; }; port@2 { @@ -789,90 +1837,74 @@ }; };
- hsusb: usb@e6590000 { - reg = <0 0xe6590000 0 0x100>; - /* placeholder */ - }; - - pciec0: pcie@fe000000 { - reg = <0 0xfe000000 0 0x80000>; - /* placeholder */ - }; - - pciec1: pcie@ee800000 { - reg = <0 0xee800000 0 0x80000>; - /* placeholder */ + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; }; + };
- rcar_sound: sound@ec500000 { - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ - /* placeholder */ + timer { + compatible = "arm,armv8-timer"; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; + };
- rcar_sound,dvc { - dvc0: dvc-0 { - }; - dvc1: dvc-1 { + thermal-zones { + sensor_thermal1: sensor-thermal1 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 0>; + + trips { + sensor1_crit: sensor1-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; }; }; + };
- rcar_sound,src { - src0: src-0 { - }; - src1: src-1 { - }; - }; + sensor_thermal2: sensor-thermal2 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 1>;
- rcar_sound,ssi { - ssi0: ssi-0 { - }; - ssi1: ssi-1 { + trips { + sensor2_crit: sensor2-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; }; }; };
- sdhi0: sd@ee100000 { - reg = <0 0xee100000 0 0x2000>; - /* placeholder */ - }; - - sdhi1: sd@ee120000 { - reg = <0 0xee120000 0 0x2000>; - /* placeholder */ - }; - - sdhi2: sd@ee140000 { - reg = <0 0xee140000 0 0x2000>; - /* placeholder */ - }; - - sdhi3: sd@ee160000 { - reg = <0 0xee160000 0 0x2000>; - /* placeholder */ - }; - - usb3_phy0: usb-phy@e65ee000 { - reg = <0 0xe65ee000 0 0x90>; - #phy-cells = <0>; - /* placeholder */ - }; + sensor_thermal3: sensor-thermal3 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 2>;
- usb3_peri0: usb@ee020000 { - reg = <0 0xee020000 0 0x400>; - /* placeholder */ + trips { + sensor3_crit: sensor3-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; }; + };
- xhci0: usb@ee000000 { - reg = <0 0xee000000 0 0xc00>; - /* placeholder */ - }; + /* External USB clocks - can be overridden by the board */ + usb3s0_clk: usb3s0 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + };
- wdt0: watchdog@e6020000 { - reg = <0 0xe6020000 0 0x0c>; - /* placeholder */ - }; + usb_extal_clk: usb_extal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; }; }; diff --git a/arch/arm/dts/r8a77970-eagle.dts b/arch/arm/dts/r8a77970-eagle.dts index 7fee1aa1ac..b6d5332157 100644 --- a/arch/arm/dts/r8a77970-eagle.dts +++ b/arch/arm/dts/r8a77970-eagle.dts @@ -28,9 +28,57 @@ /* first 128MB is reserved for secure area. */ reg = <0x0 0x48000000 0x0 0x38000000>; }; + + hdmi-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_out: endpoint { + remote-endpoint = <&adv7511_out>; + }; + }; + }; + + d3p3: regulator-fixed { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + lvds-decoder { + compatible = "thine,thc63lvd1024"; + + vcc-supply = <&d3p3>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + thc63lvd1024_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + + port@2 { + reg = <2>; + thc63lvd1024_out: endpoint { + remote-endpoint = <&adv7511_in>; + }; + }; + }; + }; };
&avb { + pinctrl-0 = <&avb_pins>; + pinctrl-names = "default"; + renesas,no-ether-link; phy-handle = <&phy0>; phy-mode = "rgmii-id"; @@ -44,6 +92,16 @@ }; };
+&canfd { + pinctrl-0 = <&canfd0_pins>; + pinctrl-names = "default"; + status = "okay"; + + channel0 { + status = "okay"; + }; +}; + &extal_clk { clock-frequency = <16666666>; }; @@ -65,9 +123,51 @@ gpio-controller; #gpio-cells = <2>; }; + + hdmi@39 { + compatible = "adi,adv7511w"; + reg = <0x39>; + interrupt-parent = <&gpio1>; + interrupts = <20 IRQ_TYPE_LEVEL_LOW>; + + adi,input-depth = <8>; + adi,input-colorspace = "rgb"; + adi,input-clock = "1x"; + adi,input-style = <1>; + adi,input-justification = "evenly"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + adv7511_in: endpoint { + remote-endpoint = <&thc63lvd1024_out>; + }; + }; + + port@1 { + reg = <1>; + adv7511_out: endpoint { + remote-endpoint = <&hdmi_con_out>; + }; + }; + }; + }; };
&pfc { + avb_pins: avb0 { + groups = "avb0_mdio", "avb0_rgmii", "avb0_txcrefclk"; + function = "avb0"; + }; + + canfd0_pins: canfd0 { + groups = "canfd0_data_a"; + function = "canfd0"; + }; + i2c0_pins: i2c0 { groups = "i2c0"; function = "i2c0"; @@ -90,3 +190,19 @@
status = "okay"; }; + +&du { + status = "okay"; +}; + +&lvds0 { + status = "okay"; + + ports { + port@1 { + lvds0_out: endpoint { + remote-endpoint = <&thc63lvd1024_in>; + }; + }; + }; +}; diff --git a/arch/arm/dts/r8a77970.dtsi b/arch/arm/dts/r8a77970.dtsi index 9205da2acd..a0808c90ab 100644 --- a/arch/arm/dts/r8a77970.dtsi +++ b/arch/arm/dts/r8a77970.dtsi @@ -38,6 +38,16 @@ enable-method = "psci"; };
+ a53_1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <1>; + clocks = <&cpg CPG_CORE R8A77970_CLK_Z2>; + power-domains = <&sysc R8A77970_PD_CA53_CPU1>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + }; + L2_CA53: cache-controller { compatible = "cache"; power-domains = <&sysc R8A77970_PD_CA53_SCU>; @@ -60,11 +70,25 @@ clock-frequency = <0>; };
+ pmu_a53 { + compatible = "arm,cortex-a53-pmu"; + interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a53_0>, <&a53_1>; + }; + psci { compatible = "arm,psci-1.0", "arm,psci-0.2"; method = "smc"; };
+ /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + /* External SCIF clock - to be overridden by boards that provide it */ scif_clk: scif { compatible = "fixed-clock"; @@ -80,23 +104,6 @@ #size-cells = <2>; ranges;
- gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1010000 0 0x1000>, - <0 0xf1020000 0 0x20000>, - <0 0xf1040000 0 0x20000>, - <0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(1) | - IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - rwdt: watchdog@e6020000 { compatible = "renesas,r8a77970-wdt", "renesas,rcar-gen3-wdt"; @@ -107,75 +114,6 @@ status = "disabled"; };
- cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77970-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77970-rst"; - reg = <0 0xe6160000 0 0x200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77970-sysc"; - reg = <0 0xe6180000 0 0x440>; - #power-domain-cells = <1>; - }; - - ipmmu_vi0: mmu@febd0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ir: mmu@ff8b0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A77970_PD_A3IR>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: mmu@ffc80000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: mmu@e7740000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: mmu@e67b0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - pfc: pin-controller@e6060000 { - compatible = "renesas,pfc-r8a77970"; - reg = <0 0xe6060000 0 0x504>; - }; - gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a77970", "renesas,rcar-gen3-gpio"; @@ -266,6 +204,32 @@ resets = <&cpg 907>; };
+ pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a77970"; + reg = <0 0xe6060000 0 0x504>; + }; + + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a77970-cpg-mssr"; + reg = <0 0xe6150000 0 0x1000>; + clocks = <&extal_clk>, <&extalr_clk>; + clock-names = "extal", "extalr"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; + }; + + rst: reset-controller@e6160000 { + compatible = "renesas,r8a77970-rst"; + reg = <0 0xe6160000 0 0x200>; + }; + + sysc: system-controller@e6180000 { + compatible = "renesas,r8a77970-sysc"; + reg = <0 0xe6180000 0 0x440>; + #power-domain-cells = <1>; + }; + intc_ex: interrupt-controller@e61c0000 { compatible = "renesas,intc-ex-r8a77970", "renesas,irqc"; #interrupt-cells = <2>; @@ -282,67 +246,6 @@ resets = <&cpg 407>; };
- prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77970", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77970", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>; - }; - i2c0: i2c@e6500000 { compatible = "renesas,i2c-r8a77970", "renesas,rcar-gen3-i2c"; @@ -499,6 +402,77 @@ status = "disabled"; };
+ canfd: can@e66c0000 { + compatible = "renesas,r8a77970-canfd", + "renesas,rcar-gen3-canfd"; + reg = <0 0xe66c0000 0 0x8000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 914>, + <&cpg CPG_CORE R8A77970_CLK_CANFD>, + <&can_clk>; + clock-names = "fck", "canfd", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A77970_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 914>; + status = "disabled"; + + channel0 { + status = "disabled"; + }; + + channel1 { + status = "disabled"; + }; + }; + + avb: ethernet@e6800000 { + compatible = "renesas,etheravb-r8a77970", + "renesas,etheravb-rcar-gen3"; + reg = <0 0xe6800000 0 0x800>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15", + "ch16", "ch17", "ch18", "ch19", + "ch20", "ch21", "ch22", "ch23", + "ch24"; + clocks = <&cpg CPG_MOD 812>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 812>; + phy-mode = "rgmii"; + iommus = <&ipmmu_rt 3>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + scif0: serial@e6e60000 { compatible = "renesas,scif-r8a77970", "renesas,rcar-gen3-scif", @@ -570,57 +544,358 @@ status = "disabled"; };
- avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77970", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; + + vin0: video@e6ef0000 { + compatible = "renesas,vin-r8a77970"; + reg = <0 0xe6ef0000 0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 811>; power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - iommus = <&ipmmu_rt 3>; - #address-cells = <1>; - #size-cells = <0>; + resets = <&cpg 811>; + renesas,id = <0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin0csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin0>; + }; + }; + }; + }; + + vin1: video@e6ef1000 { + compatible = "renesas,vin-r8a77970"; + reg = <0 0xe6ef1000 0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 810>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 810>; + renesas,id = <1>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin1csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin1>; + }; + }; + }; + }; + + vin2: video@e6ef2000 { + compatible = "renesas,vin-r8a77970"; + reg = <0 0xe6ef2000 0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 809>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 809>; + renesas,id = <2>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin2csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin2>; + }; + }; + }; + }; + + vin3: video@e6ef3000 { + compatible = "renesas,vin-r8a77970"; + reg = <0 0xe6ef3000 0 0x1000>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 808>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 808>; + renesas,id = <3>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + vin3csi40: endpoint@2 { + reg = <2>; + remote-endpoint= <&csi40vin3>; + }; + }; + }; + }; + + dmac1: dma-controller@e7300000 { + compatible = "renesas,dmac-r8a77970", + "renesas,rcar-dmac"; + reg = <0 0xe7300000 0 0x10000>; + interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7"; + clocks = <&cpg CPG_MOD 218>; + clock-names = "fck"; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 218>; + #dma-cells = <1>; + dma-channels = <8>; + iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, + <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, + <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, + <&ipmmu_ds1 6>, <&ipmmu_ds1 7>; + }; + + dmac2: dma-controller@e7310000 { + compatible = "renesas,dmac-r8a77970", + "renesas,rcar-dmac"; + reg = <0 0xe7310000 0 0x10000>; + interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7"; + clocks = <&cpg CPG_MOD 217>; + clock-names = "fck"; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 217>; + #dma-cells = <1>; + dma-channels = <8>; + iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, + <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, + <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, + <&ipmmu_ds1 22>, <&ipmmu_ds1 23>; + }; + + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a77970"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_ir: mmu@ff8b0000 { + compatible = "renesas,ipmmu-r8a77970"; + reg = <0 0xff8b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 3>; + power-domains = <&sysc R8A77970_PD_A3IR>; + #iommu-cells = <1>; + }; + + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a77970"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a77970"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 7>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a77970"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 9>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0 0xf1010000 0 0x1000>, + <0 0xf1020000 0 0x20000>, + <0 0xf1040000 0 0x20000>, + <0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | + IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 408>; + }; + + vspd0: vsp@fea20000 { + compatible = "renesas,vsp2"; + reg = <0 0xfea20000 0 0x5000>; + interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 623>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 623>; + renesas,fcp = <&fcpvd0>; + }; + + fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 603>; + }; + + csi40: csi2@feaa0000 { + compatible = "renesas,r8a77970-csi2"; + reg = <0 0xfeaa0000 0 0x10000>; + interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 716>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 716>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + #address-cells = <1>; + #size-cells = <0>; + + reg = <1>; + + csi40vin0: endpoint@0 { + reg = <0>; + remote-endpoint = <&vin0csi40>; + }; + csi40vin1: endpoint@1 { + reg = <1>; + remote-endpoint = <&vin1csi40>; + }; + csi40vin2: endpoint@2 { + reg = <2>; + remote-endpoint = <&vin2csi40>; + }; + csi40vin3: endpoint@3 { + reg = <3>; + remote-endpoint = <&vin3csi40>; + }; + }; + }; + }; + + du: display@feb00000 { + compatible = "renesas,du-r8a77970"; + reg = <0 0xfeb00000 0 0x80000>; + interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 724>; + clock-names = "du.0"; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 724>; + vsps = <&vspd0>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + du_out_rgb: endpoint { + }; + }; + + port@1 { + reg = <1>; + du_out_lvds0: endpoint { + remote-endpoint = <&lvds0_in>; + }; + }; + }; + }; + + lvds0: lvds-encoder@feb90000 { + compatible = "renesas,r8a77970-lvds"; + reg = <0 0xfeb90000 0 0x14>; + clocks = <&cpg CPG_MOD 727>; + power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; + resets = <&cpg 727>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + lvds0_in: endpoint { + remote-endpoint = + <&du_out_lvds0>; + }; + }; + port@1 { + reg = <1>; + lvds0_out: endpoint { + }; + }; + }; + }; + + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; }; };
timer { compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; }; }; diff --git a/arch/arm/dts/r8a77990-ebisu.dts b/arch/arm/dts/r8a77990-ebisu.dts index e337c902cb..2bc3a4884b 100644 --- a/arch/arm/dts/r8a77990-ebisu.dts +++ b/arch/arm/dts/r8a77990-ebisu.dts @@ -28,72 +28,6 @@ /* first 128MB is reserved for secure area. */ reg = <0x0 0x48000000 0x0 0x38000000>; }; - - reg_1p8v: regulator0 { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_3p3v: regulator1 { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio5 17 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1 - 1800000 0>; - }; - - vcc_sdhi1: regulator-vcc-sdhi1 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI1 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio0 4 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio3 15 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1 - 1800000 0>; - }; };
&avb { @@ -121,6 +55,10 @@ clock-frequency = <48000000>; };
+&ohci0 { + status = "okay"; +}; + &pfc { avb_pins: avb { mux { @@ -129,71 +67,36 @@ }; };
- usb0_pins: usb0 { - groups = "usb0"; + usb0_pins: usb { + groups = "usb0_b"; function = "usb0"; }; -};
-&usb2_phy0 { - pinctrl-0 = <&usb0_pins>; - pinctrl-name = "default"; - - status = "okay"; + usb30_pins: usb30 { + groups = "usb30"; + function = "usb30"; + }; };
-&sdhi0 { - /* full size SD */ - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; - bus-width = <4>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; +&rwdt { + timeout-sec = <60>; status = "okay"; - max-frequency = <208000000>; };
-&sdhi1 { - /* microSD */ - pinctrl-0 = <&sdhi1_pins>; - pinctrl-1 = <&sdhi1_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi1>; - vqmmc-supply = <&vccq_sdhi1>; - cd-gpios = <&gpio3 14 GPIO_ACTIVE_LOW>; - bus-width = <4>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; +&scif2 { status = "okay"; - max-frequency = <208000000>; };
-&sdhi3 { - /* used for on-board 8bit eMMC */ - pinctrl-0 = <&sdhi3_pins>; - pinctrl-1 = <&sdhi3_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <®_1p8v>; - bus-width = <8>; - mmc-hs200-1_8v; - mmc-hs400-1_8v; - non-removable; +&usb2_phy0 { + pinctrl-0 = <&usb0_pins>; + pinctrl-names = "default"; + status = "okay"; };
-&scif2 { +&xhci0 { + pinctrl-0 = <&usb30_pins>; + pinctrl-names = "default"; + status = "okay"; }; diff --git a/arch/arm/dts/r8a77990.dtsi b/arch/arm/dts/r8a77990.dtsi index 593d35a267..ae89260baa 100644 --- a/arch/arm/dts/r8a77990.dtsi +++ b/arch/arm/dts/r8a77990.dtsi @@ -18,16 +18,24 @@ #address-cells = <1>; #size-cells = <0>;
- /* 1 core only at this point */ a53_0: cpu@0 { compatible = "arm,cortex-a53", "arm,armv8"; - reg = <0x0>; + reg = <0>; device_type = "cpu"; power-domains = <&sysc 5>; next-level-cache = <&L2_CA53>; enable-method = "psci"; };
+ a53_1: cpu@1 { + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <1>; + device_type = "cpu"; + power-domains = <&sysc 6>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + }; + L2_CA53: cache-controller-0 { compatible = "cache"; power-domains = <&sysc 21>; @@ -45,8 +53,9 @@
pmu_a53 { compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>; + interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a53_0>, <&a53_1>; };
psci { @@ -61,6 +70,16 @@ #size-cells = <2>; ranges;
+ rwdt: watchdog@e6020000 { + compatible = "renesas,r8a77990-wdt", + "renesas,rcar-gen3-wdt"; + reg = <0 0xe6020000 0 0x0c>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc 32>; + resets = <&cpg 402>; + status = "disabled"; + }; + gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a77990", "renesas,rcar-gen3-gpio"; @@ -166,43 +185,6 @@ resets = <&cpg 906>; };
- ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - phys = <&usb2_phy0>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a7790", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>; - #phy-cells = <0>; - status = "disabled"; - }; - pfc: pin-controller@e6060000 { compatible = "renesas,pfc-r8a77990"; reg = <0 0xe6060000 0 0x508>; @@ -229,10 +211,91 @@ #power-domain-cells = <1>; };
+ ipmmu_ds0: mmu@e6740000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_hc: mmu@e6570000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mp: mmu@ec670000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: mmu@fd800000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 10>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: mmu@fe6b0000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 12>; + power-domains = <&sysc R8A77990_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 14>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vp0: mmu@fe990000 { + compatible = "renesas,ipmmu-r8a77990"; + reg = <0 0xfe990000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 16>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + avb: ethernet@e6800000 { compatible = "renesas,etheravb-r8a77990", "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; + reg = <0 0xe6800000 0 0x800>; interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, @@ -286,6 +349,54 @@ status = "disabled"; };
+ xhci0: usb@ee000000 { + compatible = "renesas,xhci-r8a77990", + "renesas,rcar-gen3-xhci"; + reg = <0 0xee000000 0 0xc00>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 328>; + power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; + resets = <&cpg 328>; + status = "disabled"; + }; + + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + power-domains = <&sysc 32>; + resets = <&cpg 703>; + status = "disabled"; + }; + + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + phys = <&usb2_phy0>; + phy-names = "usb"; + companion = <&ohci0>; + power-domains = <&sysc 32>; + resets = <&cpg 703>; + status = "disabled"; + }; + + usb2_phy0: usb-phy@ee080200 { + compatible = "renesas,usb2-phy-r8a77990", + "renesas,rcar-gen3-usb2-phy"; + reg = <0 0xee080200 0 0x700>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 703>; + power-domains = <&sysc 32>; + resets = <&cpg 703>; + #phy-cells = <0>; + status = "disabled"; + }; + gic: interrupt-controller@f1010000 { compatible = "arm,gic-400"; #interrupt-cells = <3>; @@ -296,7 +407,7 @@ <0x0 0xf1040000 0 0x20000>, <0x0 0xf1060000 0 0x20000>; interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; + (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; clocks = <&cpg CPG_MOD 408>; clock-names = "clk"; power-domains = <&sysc 32>; @@ -311,9 +422,9 @@
timer { compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; }; }; diff --git a/arch/arm/dts/r8a77995-draak.dts b/arch/arm/dts/r8a77995-draak.dts index 711d487a8e..a8e8f2669d 100644 --- a/arch/arm/dts/r8a77995-draak.dts +++ b/arch/arm/dts/r8a77995-draak.dts @@ -56,6 +56,27 @@ }; };
+ composite-in { + compatible = "composite-video-connector"; + + port { + composite_con_in: endpoint { + remote-endpoint = <&adv7180_in>; + }; + }; + }; + + hdmi-in { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&adv7612_in>; + }; + }; + }; + memory@48000000 { device_type = "memory"; /* first 128MB is reserved for secure area. */ @@ -79,6 +100,12 @@ regulator-boot-on; regulator-always-on; }; + + x12_clk: x12 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <74250000>; + }; };
&extal_clk { @@ -88,7 +115,7 @@ &pfc { avb0_pins: avb { mux { - groups = "avb0_link", "avb0_mdc", "avb0_mii"; + groups = "avb0_link", "avb0_mdio", "avb0_mii"; function = "avb0"; }; }; @@ -139,6 +166,11 @@ groups = "usb0"; function = "usb0"; }; + + vin4_pins_cvbs: vin4 { + groups = "vin4_data8", "vin4_sync", "vin4_clk"; + function = "vin4"; + }; };
&i2c0 { @@ -151,6 +183,77 @@ reg = <0x50>; pagesize = <8>; }; + + composite-in@20 { + compatible = "adi,adv7180cp"; + reg = <0x20>; + + port { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + adv7180_in: endpoint { + remote-endpoint = <&composite_con_in>; + }; + }; + + port@3 { + reg = <3>; + + /* + * The VIN4 video input path is shared between + * CVBS and HDMI inputs through SW[49-53] + * switches. + * + * CVBS is the default selection, link it to + * VIN4 here. + */ + adv7180_out: endpoint { + remote-endpoint = <&vin4_in>; + }; + }; + }; + + }; + + hdmi-decoder@4c { + compatible = "adi,adv7612"; + reg = <0x4c>; + default-input = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + adv7612_in: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; + }; + + port@2 { + reg = <2>; + + /* + * The VIN4 video input path is shared between + * CVBS and HDMI inputs through SW[49-53] + * switches. + * + * CVBS is the default selection, leave HDMI + * not connected here. + */ + adv7612_out: endpoint { + pclk-sample = <0>; + hsync-active = <0>; + vsync-active = <0>; + }; + }; + }; + }; };
&i2c1 { @@ -164,6 +267,11 @@ pinctrl-names = "default"; status = "okay";
+ clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&x12_clk>; + clock-names = "du.0", "du.1", "dclkin.0"; + ports { port@0 { endpoint { @@ -243,3 +351,23 @@ timeout-sec = <60>; status = "okay"; }; + +&vin4 { + pinctrl-0 = <&vin4_pins_cvbs>; + pinctrl-names = "default"; + + status = "okay"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + vin4_in: endpoint { + remote-endpoint = <&adv7180_out>; + }; + }; + }; +}; diff --git a/arch/arm/dts/r8a77995.dtsi b/arch/arm/dts/r8a77995.dtsi index d191d8ad70..1efef62182 100644 --- a/arch/arm/dts/r8a77995.dtsi +++ b/arch/arm/dts/r8a77995.dtsi @@ -15,9 +15,11 @@ #address-cells = <2>; #size-cells = <2>;
- psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; + /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; };
cpus { @@ -48,18 +50,16 @@ clock-frequency = <0>; };
- /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - pmu_a53 { compatible = "arm,cortex-a53-pmu"; interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; };
+ psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; + }; + scif_clk: scif { compatible = "fixed-clock"; #clock-cells = <0>; @@ -73,23 +73,6 @@ #size-cells = <2>; ranges;
- gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - rwdt: watchdog@e6020000 { compatible = "renesas,r8a77995-wdt", "renesas,rcar-gen3-wdt"; @@ -100,211 +83,9 @@ status = "disabled"; };
- ipmmu_vi0: mmu@febd0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_vp0: mmu@fe990000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_vc0: mmu@fe6b0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_pv0: mmu@fd800000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_hc: mmu@e6570000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: mmu@ffc80000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: mmu@ec670000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds0: mmu@e6740000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds1: mmu@e7740000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mm: mmu@e67b0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77995-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77995-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - pfc: pin-controller@e6060000 { - compatible = "renesas,pfc-r8a77995"; - reg = <0 0xe6060000 0 0x508>; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77995-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77995", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <8>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <8>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH - GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <8>; - }; - gpio0: gpio@e6050000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6050000 0 0x50>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -319,8 +100,7 @@
gpio1: gpio@e6051000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6051000 0 0x50>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -335,8 +115,7 @@
gpio2: gpio@e6052000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6052000 0 0x50>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -351,8 +130,7 @@
gpio3: gpio@e6053000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6053000 0 0x50>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -367,8 +145,7 @@
gpio4: gpio@e6054000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6054000 0 0x50>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -383,8 +160,7 @@
gpio5: gpio@e6055000 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6055000 0 0x50>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -399,8 +175,7 @@
gpio6: gpio@e6055400 { compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio", - "renesas,gpio-rcar"; + "renesas,rcar-gen3-gpio"; reg = <0 0xe6055400 0 0x50>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; @@ -413,35 +188,159 @@ resets = <&cpg 906>; };
- can0: can@e6c30000 { - compatible = "renesas,can-r8a77995", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A77995_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; + pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a77995"; + reg = <0 0xe6060000 0 0x508>; };
- can1: can@e6c38000 { - compatible = "renesas,can-r8a77995", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A77995_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; - assigned-clock-rates = <40000000>; + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a77995-cpg-mssr"; + reg = <0 0xe6150000 0 0x1000>; + clocks = <&extal_clk>; + clock-names = "extal"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; + }; + + rst: reset-controller@e6160000 { + compatible = "renesas,r8a77995-rst"; + reg = <0 0xe6160000 0 0x0200>; + }; + + sysc: system-controller@e6180000 { + compatible = "renesas,r8a77995-sysc"; + reg = <0 0xe6180000 0 0x0400>; + #power-domain-cells = <1>; + }; + + thermal: thermal@e6190000 { + compatible = "renesas,thermal-r8a77995"; + reg = <0 0xe6190000 0 0x10>, <0 0xe6190100 0 0x38>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 915>; + resets = <&cpg 522>; + #thermal-sensor-cells = <0>; + }; + + intc_ex: interrupt-controller@e61c0000 { + compatible = "renesas,intc-ex-r8a77995", "renesas,irqc"; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0 0xe61c0000 0 0x200>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 407>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 407>; + }; + + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a77995", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 0x60>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 520>; + status = "disabled"; + }; + + hscif3: serial@e66a0000 { + compatible = "renesas,hscif-r8a77995", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66a0000 0 0x60>; + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 517>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 517>; + status = "disabled"; + }; + + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77995", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c1: i2c@e6508000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77995", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6508000 0 0x40>; + interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 930>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 930>; + dmas = <&dmac1 0x93>, <&dmac1 0x92>, + <&dmac2 0x93>, <&dmac2 0x92>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c2: i2c@e6510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77995", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6510000 0 0x40>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 929>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 929>; + dmas = <&dmac1 0x95>, <&dmac1 0x94>, + <&dmac2 0x95>, <&dmac2 0x94>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c3: i2c@e66d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a77995", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d0000 0 0x40>; + interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 928>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 928>; + dmas = <&dmac0 0x97>, <&dmac0 0x96>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; status = "disabled"; };
@@ -470,6 +369,159 @@ }; };
+ dmac0: dma-controller@e6700000 { + compatible = "renesas,dmac-r8a77995", + "renesas,rcar-dmac"; + reg = <0 0xe6700000 0 0x10000>; + interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7"; + clocks = <&cpg CPG_MOD 219>; + clock-names = "fck"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 219>; + #dma-cells = <1>; + dma-channels = <8>; + }; + + dmac1: dma-controller@e7300000 { + compatible = "renesas,dmac-r8a77995", + "renesas,rcar-dmac"; + reg = <0 0xe7300000 0 0x10000>; + interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7"; + clocks = <&cpg CPG_MOD 218>; + clock-names = "fck"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 218>; + #dma-cells = <1>; + dma-channels = <8>; + }; + + dmac2: dma-controller@e7310000 { + compatible = "renesas,dmac-r8a77995", + "renesas,rcar-dmac"; + reg = <0 0xe7310000 0 0x10000>; + interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH + GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7"; + clocks = <&cpg CPG_MOD 217>; + clock-names = "fck"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 217>; + #dma-cells = <1>; + dma-channels = <8>; + }; + + ipmmu_ds0: mmu@e6740000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_ds1: mmu@e7740000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_hc: mmu@e6570000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mm: mmu@e67b0000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mp: mmu@ec670000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: mmu@fd800000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_rt: mmu@ffc80000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xffc80000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 10>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: mmu@fe6b0000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 12>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: mmu@febd0000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 14>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vp0: mmu@fe990000 { + compatible = "renesas,ipmmu-r8a77995"; + reg = <0 0xfe990000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 16>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + avb: ethernet@e6800000 { compatible = "renesas,etheravb-r8a77995", "renesas,etheravb-rcar-gen3"; @@ -509,94 +561,42 @@ clocks = <&cpg CPG_MOD 812>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; resets = <&cpg 812>; - phy-mode = "rgmii"; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { + phy-mode = "rgmii"; + iommus = <&ipmmu_ds0 16>; #address-cells = <1>; #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; status = "disabled"; };
- i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; + can0: can@e6c30000 { + compatible = "renesas,can-r8a77995", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c30000 0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 916>, + <&cpg CPG_CORE R8A77995_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; + assigned-clock-rates = <40000000>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; + resets = <&cpg 916>; status = "disabled"; };
- i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; + can1: can@e6c38000 { + compatible = "renesas,can-r8a77995", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c38000 0 0x1000>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 915>, + <&cpg CPG_CORE R8A77995_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; + assigned-clock-rates = <40000000>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; + resets = <&cpg 915>; status = "disabled"; };
@@ -640,38 +640,199 @@ status = "disabled"; };
- sdhi2: sd@ee140000 { - compatible = "renesas,sdhi-r8a77995", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - max-frequency = <200000000>; + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 64>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 312>; + resets = <&cpg 207>; status = "disabled"; };
- ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 64>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 206>; + status = "disabled"; + }; + + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 64>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x13>, <&dmac1 0x12>, + <&dmac2 0x13>, <&dmac2 0x12>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 310>; + status = "disabled"; + }; + + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 64>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 204>; + status = "disabled"; + }; + + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 64>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 203>; + status = "disabled"; + }; + + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a77995", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 64>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, + <&cpg CPG_CORE R8A77995_CLK_S3D1C>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 202>; + status = "disabled"; + }; + + msiof0: spi@e6e90000 { + compatible = "renesas,msiof-r8a77995", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6e90000 0 0x64>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 211>; + dmas = <&dmac1 0x41>, <&dmac1 0x40>, + <&dmac2 0x41>, <&dmac2 0x40>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 211>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof1: spi@e6ea0000 { + compatible = "renesas,msiof-r8a77995", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6ea0000 0 0x64>; + interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 210>; + dmas = <&dmac1 0x43>, <&dmac1 0x42>, + <&dmac2 0x43>, <&dmac2 0x42>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 210>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof2: spi@e6c00000 { + compatible = "renesas,msiof-r8a77995", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c00000 0 0x64>; + interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 209>; + dmas = <&dmac0 0x45>, <&dmac0 0x44>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 209>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof3: spi@e6c10000 { + compatible = "renesas,msiof-r8a77995", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c10000 0 0x64>; + interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 208>; + dmas = <&dmac0 0x47>, <&dmac0 0x46>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 208>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + vin4: video@e6ef4000 { + compatible = "renesas,vin-r8a77995"; + reg = <0 0xe6ef4000 0 0x1000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 807>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 807>; + renesas,id = <4>; + status = "disabled"; + }; + + ohci0: usb@ee080000 { + compatible = "generic-ohci"; + reg = <0 0xee080000 0 0x100>; interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 703>; phys = <&usb2_phy0>; phy-names = "usb"; - companion = <&ohci0>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; resets = <&cpg 703>; status = "disabled"; };
- ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; + ehci0: usb@ee080100 { + compatible = "generic-ehci"; + reg = <0 0xee080100 0 0x100>; interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 703>; phys = <&usb2_phy0>; phy-names = "usb"; + companion = <&ohci0>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; resets = <&cpg 703>; status = "disabled"; @@ -689,6 +850,35 @@ status = "disabled"; };
+ sdhi2: sd@ee140000 { + compatible = "renesas,sdhi-r8a77995", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 312>; + status = "disabled"; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 408>; + }; + vspbs: vsp@fe960000 { compatible = "renesas,vsp2"; reg = <0 0xfe960000 0 0x8000>; @@ -699,18 +889,9 @@ renesas,fcp = <&fcpvb0>; };
- fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 607>; - iommus = <&ipmmu_vp0 5>; - }; - vspd0: vsp@fea20000 { compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x8000>; + reg = <0 0xfea20000 0 0x5000>; interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 623>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; @@ -718,18 +899,9 @@ renesas,fcp = <&fcpvd0>; };
- fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - vspd1: vsp@fea28000 { compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x8000>; + reg = <0 0xfea28000 0 0x5000>; interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cpg CPG_MOD 622>; power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; @@ -737,6 +909,24 @@ renesas,fcp = <&fcpvd1>; };
+ fcpvb0: fcp@fe96f000 { + compatible = "renesas,fcpv"; + reg = <0 0xfe96f000 0 0x200>; + clocks = <&cpg CPG_MOD 607>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 607>; + iommus = <&ipmmu_vp0 5>; + }; + + fcpvd0: fcp@fea27000 { + compatible = "renesas,fcpv"; + reg = <0 0xfea27000 0 0x200>; + clocks = <&cpg CPG_MOD 603>; + power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; + resets = <&cpg 603>; + iommus = <&ipmmu_vi0 8>; + }; + fcpvd1: fcp@fea2f000 { compatible = "renesas,fcpv"; reg = <0 0xfea2f000 0 0x200>; @@ -780,6 +970,30 @@ }; }; }; + + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; + }; + }; + + thermal-zones { + cpu_thermal: cpu-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&thermal>; + + trips { + cpu-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + }; + }; };
timer { diff --git a/arch/arm/dts/salvator-common.dtsi b/arch/arm/dts/salvator-common.dtsi index 2a7f36abd2..7d3d866a00 100644 --- a/arch/arm/dts/salvator-common.dtsi +++ b/arch/arm/dts/salvator-common.dtsi @@ -1,11 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 /* * Device Tree Source for common parts of Salvator-X board variants * * Copyright (C) 2015-2016 Renesas Electronics Corp. - * - * This file is licensed under the terms of the GNU General Public License - * version 2. This program is licensed "as is" without any warranty of any - * kind, whether express or implied. */
/* @@ -36,7 +33,7 @@ / { aliases { serial0 = &scif2; - serial1 = &scif1; + serial1 = &hscif1; ethernet0 = &avb; };
@@ -66,6 +63,29 @@ enable-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>; };
+ cvbs-in { + compatible = "composite-video-connector"; + label = "CVBS IN"; + + port { + cvbs_con: endpoint { + remote-endpoint = <&adv7482_ain7>; + }; + }; + }; + + hdmi-in { + compatible = "hdmi-connector"; + label = "HDMI IN"; + type = "a"; + + port { + hdmi_in_con: endpoint { + remote-endpoint = <&adv7482_hdmi>; + }; + }; + }; + reg_1p8v: regulator0 { compatible = "regulator-fixed"; regulator-name = "fixed-1.8V"; @@ -93,20 +113,12 @@ regulator-always-on; };
- rsnd_ak4613: sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&sndcpu>; - simple-audio-card,frame-master = <&sndcpu>; + sound_card: sound { + compatible = "audio-graph-card";
- sndcpu: simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; + label = "rcar-sound";
- sndcodec: simple-audio-card,codec { - sound-dai = <&ak4613>; - }; + dais = <&rsnd_port0>; };
vbus0_usb2: regulator-vbus0-usb2 { @@ -268,6 +280,37 @@ }; };
+&csi20 { + status = "okay"; + + ports { + port@0 { + reg = <0>; + csi20_in: endpoint { + clock-lanes = <0>; + data-lanes = <1>; + remote-endpoint = <&adv7482_txb>; + }; + }; + }; +}; + +&csi40 { + status = "okay"; + + ports { + port@0 { + reg = <0>; + + csi40_in: endpoint { + clock-lanes = <0>; + data-lanes = <1 2 3 4>; + remote-endpoint = <&adv7482_txa>; + }; + }; + }; +}; + &du { pinctrl-0 = <&du_pins>; pinctrl-names = "default"; @@ -295,6 +338,15 @@ clock-frequency = <32768>; };
+&hscif1 { + pinctrl-0 = <&hscif1_pins>; + pinctrl-names = "default"; + + uart-has-rtscts; + /* Please only enable hscif1 or scif1 */ + status = "okay"; +}; + &hsusb { dr_mode = "otg"; status = "okay"; @@ -322,6 +374,12 @@ asahi-kasei,out4-single-end; asahi-kasei,out5-single-end; asahi-kasei,out6-single-end; + + port { + ak4613_endpoint: endpoint { + remote-endpoint = <&rsnd_endpoint0>; + }; + }; };
cs2000: clk_multiplier@4f { @@ -359,6 +417,55 @@
shunt-resistor-micro-ohms = <5000>; }; + + video-receiver@70 { + compatible = "adi,adv7482"; + reg = <0x70>; + + #address-cells = <1>; + #size-cells = <0>; + + interrupt-parent = <&gpio6>; + interrupt-names = "intrq1", "intrq2"; + interrupts = <30 IRQ_TYPE_LEVEL_LOW>, + <31 IRQ_TYPE_LEVEL_LOW>; + + port@7 { + reg = <7>; + + adv7482_ain7: endpoint { + remote-endpoint = <&cvbs_con>; + }; + }; + + port@8 { + reg = <8>; + + adv7482_hdmi: endpoint { + remote-endpoint = <&hdmi_in_con>; + }; + }; + + port@a { + reg = <10>; + + adv7482_txa: endpoint { + clock-lanes = <0>; + data-lanes = <1 2 3 4>; + remote-endpoint = <&csi40_in>; + }; + }; + + port@b { + reg = <11>; + + adv7482_txb: endpoint { + clock-lanes = <0>; + data-lanes = <1>; + remote-endpoint = <&csi20_in>; + }; + }; + }; };
&i2c_dvfs { @@ -376,6 +483,8 @@ #interrupt-cells = <2>; gpio-controller; #gpio-cells = <2>; + rohm,ddr-backup-power = <0xf>; + rohm,rstbmode-level;
regulators { dvfs: dvfs { @@ -387,6 +496,12 @@ }; }; }; + + eeprom@50 { + compatible = "rohm,br24t01", "atmel,24c01"; + reg = <0x50>; + pagesize = <8>; + }; };
&ohci0 { @@ -416,12 +531,12 @@
avb_pins: avb { mux { - groups = "avb_link", "avb_mdc", "avb_mii"; + groups = "avb_link", "avb_mdio", "avb_mii"; function = "avb"; };
- pins_mdc { - groups = "avb_mdc"; + pins_mdio { + groups = "avb_mdio"; drive-strength = <24>; };
@@ -437,6 +552,11 @@ function = "du"; };
+ hscif1_pins: hscif1 { + groups = "hscif1_data_a", "hscif1_ctrl_a"; + function = "hscif1"; + }; + i2c2_pins: i2c2 { groups = "i2c2_a"; function = "i2c2"; @@ -480,13 +600,13 @@ };
sdhi2_pins: sd2 { - groups = "sdhi2_data8", "sdhi2_ctrl"; + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; function = "sdhi2"; power-source = <3300>; };
sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data8", "sdhi2_ctrl"; + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; function = "sdhi2"; power-source = <1800>; }; @@ -581,10 +701,18 @@ <&audio_clk_c>, <&cpg CPG_CORE CPG_AUDIO_CLK_I>;
- rcar_sound,dai { - dai0 { - playback = <&ssi0 &src0 &dvc0>; - capture = <&ssi1 &src1 &dvc1>; + ports { + rsnd_port0: port@0 { + rsnd_endpoint0: endpoint { + remote-endpoint = <&ak4613_endpoint>; + + dai-format = "left_j"; + bitclock-master = <&rsnd_endpoint0>; + frame-master = <&rsnd_endpoint0>; + + playback = <&ssi0 &src0 &dvc0>; + capture = <&ssi1 &src1 &dvc1>; + }; }; }; }; @@ -594,7 +722,8 @@ pinctrl-names = "default";
uart-has-rtscts; - status = "okay"; + /* Please only enable hscif1 or scif1 */ + /* status = "okay"; */ };
&scif2 { @@ -689,7 +818,39 @@ clock-frequency = <100000000>; };
-&wdt0 { +&vin0 { + status = "okay"; +}; + +&vin1 { + status = "okay"; +}; + +&vin2 { + status = "okay"; +}; + +&vin3 { + status = "okay"; +}; + +&vin4 { + status = "okay"; +}; + +&vin5 { + status = "okay"; +}; + +&vin6 { + status = "okay"; +}; + +&vin7 { + status = "okay"; +}; + +&rwdt { timeout-sec = <60>; status = "okay"; }; diff --git a/arch/arm/dts/salvator-x.dtsi b/arch/arm/dts/salvator-x.dtsi index 468868c8ed..ddee50e646 100644 --- a/arch/arm/dts/salvator-x.dtsi +++ b/arch/arm/dts/salvator-x.dtsi @@ -1,11 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 /* * Device Tree Source for the Salvator-X board * * Copyright (C) 2015-2016 Renesas Electronics Corp. - * - * This file is licensed under the terms of the GNU General Public License - * version 2. This program is licensed "as is" without any warranty of any - * kind, whether express or implied. */
#include "salvator-common.dtsi" @@ -20,6 +17,8 @@ };
&i2c4 { + clock-frequency = <400000>; + versaclock5: clock-generator@6a { compatible = "idt,5p49v5923"; reg = <0x6a>; diff --git a/arch/arm/dts/ulcb.dtsi b/arch/arm/dts/ulcb.dtsi index 6f814845f8..0ead552d7e 100644 --- a/arch/arm/dts/ulcb.dtsi +++ b/arch/arm/dts/ulcb.dtsi @@ -1,12 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 /* * Device Tree Source for the R-Car Gen3 ULCB board * * Copyright (C) 2016 Renesas Electronics Corp. * Copyright (C) 2016 Cogent Embedded, Inc. - * - * This file is licensed under the terms of the GNU General Public License - * version 2. This program is licensed "as is" without any warranty of any - * kind, whether express or implied. */
#include <dt-bindings/gpio/gpio.h> @@ -243,6 +240,32 @@
&i2c_dvfs { status = "okay"; + + pmic: pmic@30 { + pinctrl-0 = <&irq0_pins>; + pinctrl-names = "default"; + + compatible = "rohm,bd9571mwv"; + reg = <0x30>; + interrupt-parent = <&intc_ex>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + rohm,ddr-backup-power = <0xf>; + rohm,rstbmode-pulse; + + regulators { + dvfs: dvfs { + regulator-name = "dvfs"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1030000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; };
&ohci1 { @@ -255,12 +278,12 @@
@@ -276,6 +299,11 @@ function = "i2c2"; };
+ irq0_pins: irq0 { + groups = "intc_ex_irq0"; + function = "intc_ex"; + }; + scif2_pins: scif2 { groups = "scif2_data_a"; function = "scif2"; @@ -299,13 +327,13 @@ };
sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data8", "sdhi2_ctrl"; + groups = "sdhi2_data8", "sdhi2_ctrl", "sdhi2_ds"; function = "sdhi2"; power-source = <1800>; }; @@ -416,7 +444,7 @@ status = "okay"; };
-&wdt0 { +&rwdt { timeout-sec = <60>; status = "okay"; }; diff --git a/include/dt-bindings/clock/r8a77965-cpg-mssr.h b/include/dt-bindings/clock/r8a77965-cpg-mssr.h new file mode 100644 index 0000000000..6d3b5a9a60 --- /dev/null +++ b/include/dt-bindings/clock/r8a77965-cpg-mssr.h @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 Jacopo Mondi jacopo+renesas@jmondi.org + */ +#ifndef __DT_BINDINGS_CLOCK_R8A77965_CPG_MSSR_H__ +#define __DT_BINDINGS_CLOCK_R8A77965_CPG_MSSR_H__ + +#include <dt-bindings/clock/renesas-cpg-mssr.h> + +/* r8a77965 CPG Core Clocks */ +#define R8A77965_CLK_Z 0 +#define R8A77965_CLK_ZR 1 +#define R8A77965_CLK_ZG 2 +#define R8A77965_CLK_ZTR 3 +#define R8A77965_CLK_ZTRD2 4 +#define R8A77965_CLK_ZT 5 +#define R8A77965_CLK_ZX 6 +#define R8A77965_CLK_S0D1 7 +#define R8A77965_CLK_S0D2 8 +#define R8A77965_CLK_S0D3 9 +#define R8A77965_CLK_S0D4 10 +#define R8A77965_CLK_S0D6 11 +#define R8A77965_CLK_S0D8 12 +#define R8A77965_CLK_S0D12 13 +#define R8A77965_CLK_S1D1 14 +#define R8A77965_CLK_S1D2 15 +#define R8A77965_CLK_S1D4 16 +#define R8A77965_CLK_S2D1 17 +#define R8A77965_CLK_S2D2 18 +#define R8A77965_CLK_S2D4 19 +#define R8A77965_CLK_S3D1 20 +#define R8A77965_CLK_S3D2 21 +#define R8A77965_CLK_S3D4 22 +#define R8A77965_CLK_LB 23 +#define R8A77965_CLK_CL 24 +#define R8A77965_CLK_ZB3 25 +#define R8A77965_CLK_ZB3D2 26 +#define R8A77965_CLK_CR 27 +#define R8A77965_CLK_CRD2 28 +#define R8A77965_CLK_SD0H 29 +#define R8A77965_CLK_SD0 30 +#define R8A77965_CLK_SD1H 31 +#define R8A77965_CLK_SD1 32 +#define R8A77965_CLK_SD2H 33 +#define R8A77965_CLK_SD2 34 +#define R8A77965_CLK_SD3H 35 +#define R8A77965_CLK_SD3 36 +#define R8A77965_CLK_SSP2 37 +#define R8A77965_CLK_SSP1 38 +#define R8A77965_CLK_SSPRS 39 +#define R8A77965_CLK_RPC 40 +#define R8A77965_CLK_RPCD2 41 +#define R8A77965_CLK_MSO 42 +#define R8A77965_CLK_CANFD 43 +#define R8A77965_CLK_HDMI 44 +#define R8A77965_CLK_CSI0 45 +#define R8A77965_CLK_CP 46 +#define R8A77965_CLK_CPEX 47 +#define R8A77965_CLK_R 48 +#define R8A77965_CLK_OSC 49 + +#endif /* __DT_BINDINGS_CLOCK_R8A77965_CPG_MSSR_H__ */ diff --git a/include/dt-bindings/clock/r8a77990-cpg-mssr.h b/include/dt-bindings/clock/r8a77990-cpg-mssr.h index c806fce449..a596a482f3 100644 --- a/include/dt-bindings/clock/r8a77990-cpg-mssr.h +++ b/include/dt-bindings/clock/r8a77990-cpg-mssr.h @@ -56,8 +56,7 @@ #define R8A77990_CLK_LV0 45 #define R8A77990_CLK_LV1 46 #define R8A77990_CLK_CSI0 47 -#define R8A77990_CLK_POST3 48 -#define R8A77990_CLK_CP 49 -#define R8A77990_CLK_CPEX 50 +#define R8A77990_CLK_CP 48 +#define R8A77990_CLK_CPEX 49
#endif /* __DT_BINDINGS_CLOCK_R8A77990_CPG_MSSR_H__ */ diff --git a/include/dt-bindings/power/r8a77990-sysc.h b/include/dt-bindings/power/r8a77990-sysc.h index 1409c73a57..944d85beec 100644 --- a/include/dt-bindings/power/r8a77990-sysc.h +++ b/include/dt-bindings/power/r8a77990-sysc.h @@ -11,8 +11,14 @@ * (e.g. SYSCISR, Interrupt Status Register) */
-#define R8A77990_PD_CA53_CPU0 5 +#define R8A77990_PD_CA53_CPU0 5 +#define R8A77990_PD_CA53_CPU1 6 +#define R8A77990_PD_CR7 13 +#define R8A77990_PD_A3VC 14 +#define R8A77990_PD_3DG_A 17 +#define R8A77990_PD_3DG_B 18 #define R8A77990_PD_CA53_SCU 21 +#define R8A77990_PD_A2VC1 26
/* Always-on power area */ #define R8A77990_PD_ALWAYS_ON 32
