[U-Boot] Changed syntax for dumpimage, failing tests
The syntax for dumpimage was changed since v2019.01, but test/image/test-imagetools.sh wasn't updated with the new syntax.
While the change may make sense, it breaks existing behavior, and that has it's drawbacks...
In any case, the tests shouldn't fail.
I believe this is the commit that changed it:
commit 12b831879a765722c1a94ca75c6adb6f80759cd9 Author: Martyn Welch martyn.welch@collabora.com Date: Sat Jan 26 02:31:51 2019 +0000
tools: dumpimage: Simplify arguments
The dump image utility has very confusing syntax. If called to list image contents ("-l") it takes the image name as a positional argument. If the utility is called to extract something from the image, the image must be provided via the optional argument "-i" as well as the positional argument but the value passed in the positional argument will be completely ignored.
Simplify dumpimage by always providing the image as the first positional argument. Assume we want to dump something from the image if we do not provide the "-l" option for now.
live well, vagrant
The syntax of dumpimage was simplified in commit 12b831879a76 ("tools: dumpimage: Simplify arguments"), but the test (test/image/test-imagetools.sh) was not updated and is now failing.
Update the test to use the new syntax.
Reported-by: Vagrant Cascadian vagrant@debian.org Signed-off-by: Martyn Welch martyn.welch@collabora.com
test/image/test-imagetools.sh | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/test/image/test-imagetools.sh b/test/image/test-imagetools.sh index 256af71d42..907f46a7b5 100755 --- a/test/image/test-imagetools.sh +++ b/test/image/test-imagetools.sh @@ -102,10 +102,10 @@ create_multi_image() extract_multi_image() { echo -e "\nExtracting multi-file image contents..." - do_cmd ${DUMPIMAGE} -T multi -i ${IMAGE_MULTI} -p 0 ${DATAFILE0} - do_cmd ${DUMPIMAGE} -T multi -i ${IMAGE_MULTI} -p 1 ${DATAFILE1} - do_cmd ${DUMPIMAGE} -T multi -i ${IMAGE_MULTI} -p 2 ${DATAFILE2} - do_cmd ${DUMPIMAGE} -T multi -i ${IMAGE_MULTI} -p 2 ${DATAFILE2} -o ${TEST_OUT} + do_cmd ${DUMPIMAGE} -T multi -p 0 -o ${DATAFILE0} ${IMAGE_MULTI} + do_cmd ${DUMPIMAGE} -T multi -p 1 -o ${DATAFILE1} ${IMAGE_MULTI} + do_cmd ${DUMPIMAGE} -T multi -p 2 -o ${DATAFILE2} ${IMAGE_MULTI} + do_cmd ${DUMPIMAGE} -T multi -p 2 -o ${TEST_OUT} ${IMAGE_MULTI} echo "done." }
@@ -166,10 +166,10 @@ create_fit_image() extract_fit_image() { echo -e "\nExtracting FIT image contents..." - do_cmd ${DUMPIMAGE} -T flat_dt -i ${IMAGE_FIT_ITB} -p 0 ${DATAFILE0} - do_cmd ${DUMPIMAGE} -T flat_dt -i ${IMAGE_FIT_ITB} -p 1 ${DATAFILE1} - do_cmd ${DUMPIMAGE} -T flat_dt -i ${IMAGE_FIT_ITB} -p 2 ${DATAFILE2} - do_cmd ${DUMPIMAGE} -T flat_dt -i ${IMAGE_FIT_ITB} -p 2 ${DATAFILE2} -o ${TEST_OUT} + do_cmd ${DUMPIMAGE} -T flat_dt -p 0 -o ${DATAFILE0} ${IMAGE_FIT_ITB} + do_cmd ${DUMPIMAGE} -T flat_dt -p 1 -o ${DATAFILE1} ${IMAGE_FIT_ITB} + do_cmd ${DUMPIMAGE} -T flat_dt -p 2 -o ${DATAFILE2} ${IMAGE_FIT_ITB} + do_cmd ${DUMPIMAGE} -T flat_dt -p 2 -o ${TEST_OUT} ${IMAGE_FIT_ITB} echo "done." }
This does fix the tests with the new syntax, so:
Tested-by: Vagrant Cascadian vagrant@debian.org
It doesn't address the changed syntax of the command. All users of dumpimage outside of u-boot will have to update to the new syntax, and detect the version if they for some reason need to support both old and new dumpimage syntax. Maybe that's not a deal-breaker; I'm not sure how to cleanly handle that.
live well, vagrant
- do_cmd ${DUMPIMAGE} -T multi -p 0 -o ${DATAFILE0} ${IMAGE_MULTI}
- do_cmd ${DUMPIMAGE} -T multi -p 1 -o ${DATAFILE1} ${IMAGE_MULTI}
- do_cmd ${DUMPIMAGE} -T multi -p 2 -o ${DATAFILE2} ${IMAGE_MULTI}
- do_cmd ${DUMPIMAGE} -T multi -p 2 -o ${TEST_OUT} ${IMAGE_MULTI} echo "done."
- do_cmd ${DUMPIMAGE} -T flat_dt -p 0 -o ${DATAFILE0} ${IMAGE_FIT_ITB}
- do_cmd ${DUMPIMAGE} -T flat_dt -p 1 -o ${DATAFILE1} ${IMAGE_FIT_ITB}
- do_cmd ${DUMPIMAGE} -T flat_dt -p 2 -o ${DATAFILE2} ${IMAGE_FIT_ITB}
- do_cmd ${DUMPIMAGE} -T flat_dt -p 2 -o ${TEST_OUT} ${IMAGE_FIT_ITB} echo "done."
-- 2.20.1
Thanks for the Tested-by.
The syntax of dumpimage seemed horribly broken to me when I attempted to use it, hence deciding to scratch that itch.
This seems to be a developer tool and I can't think of any uses for this where I'd feel the need to script it. Of course I might be wrong and others may have very different workflows to me. :-)
There's the "-V" option that's been present since the first commit of this tool, so if necessary it would be possible to check that and make decisions based on what it returns.
Martyn
live well, vagrant
diff --git a/test/image/test-imagetools.sh b/test/image/test- imagetools.sh index 256af71d42..907f46a7b5 100755 --- a/test/image/test-imagetools.sh +++ b/test/image/test-imagetools.sh @@ -102,10 +102,10 @@ create_multi_image() extract_multi_image() { echo -e "\nExtracting multi-file image contents..."
${DATAFILE0}
${DATAFILE1}
${DATAFILE2}
${IMAGE_MULTI}
${IMAGE_MULTI}
${IMAGE_MULTI}
${DATAFILE0}
${DATAFILE1}
${DATAFILE2}
${IMAGE_FIT_ITB}
${IMAGE_FIT_ITB}
${IMAGE_FIT_ITB}
-- 2.20.1
Reported-by: Vagrant Cascadian vagrant@debian.org Signed-off-by: Martyn Welch martyn.welch@collabora.com Tested-by: Vagrant Cascadian vagrant@debian.org
Martyn Welch
Vagrant Cascadian
