Re: [PATCH] mmc: dw_mmc: Fixes timeout issue for FIFO mode
On 1/12/22 3:17 PM, gtXfined H. wrote:
I switched back to master branch and only made the following changes.
--- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -167,6 +167,10 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) len = 0; if (data->flags == MMC_DATA_READ && (mask & (DWMCI_INTMSK_RXDR | DWMCI_INTMSK_DTO))) {
if (!(mask & DWMCI_INTMSK_DTO) &&
(dwmci_readl(host, DWMCI_RINTSTS) &
DWMCI_INTMSK_DTO)) {
printf("warn: DTO changed to 1\n");
} dwmci_writel(host, DWMCI_RINTSTS, DWMCI_INTMSK_RXDR |
You need to set your email-client environment. https://www.kernel.org/doc/html/v5.16/process/email-clients.html?highlight=e...
DWMCI_INTMSK_DTO); while (size) { @@ -224,6 +228,11 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data)
dwmci_writel(host, DWMCI_RINTSTS, mask);
+#ifdef CONFIG_SPL_BUILD
printf("mmc: transfer %8p, %5d, in %4ld (%d, %02x)\n",
buf, data->blocks, get_timer(start), size, mask);
return ret;
Then tried the same test and reproduced the timeout issue with the following logs.
U-Boot SPL 2022.01-00373-gfe04d885fb-dirty (Jan 12 2022 - 13:52:15 +0800) Trying to boot from MMC1 mmc: transfer 3fffac8, 1, in 0 (0, 0c) mmc: transfer 3fffb80, 1, in 2 (0, 0c) mmc: transfer 3fffd00, 1, in 1 (0, 0c) warn: DTO changed to 1 mmc: transfer 2001c0, 1, in 1001 (0, 04) mmc_load_image_raw_sector: mmc block read error Trying to boot from MMC1 warn: DTO changed to 1 mmc: transfer 2001c0, 1, in 1001 (0, 04) mmc_load_image_raw_sector: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
According to the logs, you can see that the DTO interrupt was unintentionally cleared
I had been tested after set the fifo-mode. It's occurred timeout error. But your patch doesn't work, too. It's not solution to solve this problem.
Well, I have checked some code. It seems that there are some bugs about fifo-mode.
Best Regards, Jaehoon Chung
BR, Jensen, Huang
On Wed, Jan 12, 2022 at 7:04 AM Jaehoon Chung jh80.chung@samsung.com wrote:
On 1/11/22 8:05 PM, gtXfined H. wrote:
Which board did you test? When you do power-on, is it reproduced every
time?
I am using Rockchip RK3399 based board - NanoPi R4S for this test. It doesn't appear every time, but it should be encountered once about 20 times. I have run "setenv bootcmd reset; saveenv; reset" for automated testing.
This patch doesn't clarify.
The below commit had been fixed that doesn't work when data read. "mmc: dw_mmc: Fixes data read when receiving DTO interrupt in FIFO mode"
It seems that not clearing during reset card. (power glitch or other problem..?)
Could you change from your ID to your name?
This is my first time sending a patch, sorry I didn't notice this, do I need to resend this patch?
BR, Jensen, Huang
On Tue, Jan 11, 2022 at 6:38 PM Jaehoon Chung jh80.chung@samsung.com wrote:
On 1/11/22 7:24 PM, hmz007 wrote:
Clearing the DTO interrupt should be unnecessary, and it would potentially result in never receiving this interrupt again.
Do power-on or reset from uboot for a while can reproduce the issue: dwmci_data_transfer: Timeout waiting for data! mmc_load_image_raw_sector: mmc block read error
Which board did you test? When you do power-on, is it reproduced every time?
Tested on NanoPi R4S with SanDisk Extreme PRO 32GB.
Fixes: 8cb9d3ed3a ("mmc: dw_mmc: Fixes data read when receiving DTO
interrupt in FIFO mode")
Signed-off-by: hmz007 hmz007@gmail.com
drivers/mmc/dw_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index a949dad574..8fa26b340b 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -168,7 +168,7 @@ static int dwmci_data_transfer(struct dwmci_host
DWMCI_INTMSK_RXDR |
DWMCI_INTMSK_DTO);
DWMCI_INTMSK_RXDR); while (size) { ret = dwmci_fifo_ready(host, DWMCI_FIFO_EMPTY,
The modification in the last email is just to debug the timeout error and get a clearer understanding of the timeout error, it doesn't solve the problem.
But the patch in my first email (sent by git), from what I've tested, does solve the timeout error.
BR, Jensen, Huang
1\n");
return ret;
BR, Jensen, Huang
every
time?
20
testing.
BR, Jensen, Huang
DWMCI_INTMSK_RXDR |
DWMCI_INTMSK_DTO);
DWMCI_FIFO_EMPTY,
gtXfined H.
Jaehoon Chung
