[U-Boot] [PATCH] gpio: at91_gpio: Add bank names
Make the at91_gpio driver set sensible GPIO bank names in the platform data. This makes the 'gpio status' command a lot more useful.
Signed-off-by: James Byrne james.byrne@origamienergy.com
drivers/gpio/at91_gpio.c | 29 ++++++++++++++++++++++++++--- 1 file changed, 26 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/at91_gpio.c b/drivers/gpio/at91_gpio.c index 965becf77a..94b2b63a04 100644 --- a/drivers/gpio/at91_gpio.c +++ b/drivers/gpio/at91_gpio.c @@ -19,6 +19,28 @@
#define GPIO_PER_BANK 32
+static const char *at91_get_bank_name(uint32_t base_addr) +{ + switch (base_addr) { + case ATMEL_BASE_PIOA: + return "PIOA"; + case ATMEL_BASE_PIOB: + return "PIOB"; + case ATMEL_BASE_PIOC: + return "PIOC"; +#if (ATMEL_PIO_PORTS > 3) + case ATMEL_BASE_PIOD: + return "PIOD"; +#if (ATMEL_PIO_PORTS > 4) + case ATMEL_BASE_PIOE: + return "PIOE"; +#endif +#endif + } + + return ""; +} + static struct at91_port *at91_pio_get_port(unsigned port) { switch (port) { @@ -582,14 +604,15 @@ static int at91_gpio_probe(struct udevice *dev)
clk_free(&clk);
- uc_priv->bank_name = plat->bank_name; - uc_priv->gpio_count = GPIO_PER_BANK; - #if CONFIG_IS_ENABLED(OF_CONTROL) plat->base_addr = (uint32_t)devfdt_get_addr_ptr(dev); #endif + plat->bank_name = at91_get_bank_name(plat->base_addr); port->regs = (struct at91_port *)plat->base_addr;
+ uc_priv->bank_name = plat->bank_name; + uc_priv->gpio_count = GPIO_PER_BANK; + return 0; }
return "PIOA";
return "PIOB";
return "PIOC";
return "PIOD";
return "PIOE";
+#endif +#endif
return "";
- static struct at91_port *at91_pio_get_port(unsigned port) { switch (port) {
clk_free(&clk);
Hello James,
Here you are rewriting the plat->bank_name... What was the old name that comes from the platform struct ?
Thanks for the patch,
Eugen
}return 0;
-- 2.24.0
Hi Eugen,
clk_free(&clk);
Hello James,
It was unset (null).
Regards,
James
On 19.11.2019 16:17, James Byrne wrote:
Hi Eugen,
clk_free(&clk);
Hello James,
Ok. Can you make the default name go to something like 'undefined' instead of an empty string ? Maybe it would be more meaningful, what do you think ? (and easier to spot in the CLI )
Thanks
Regards,
James
James Byrne
