[U-Boot] [PATCH] env_nand: fix incorrect size parameter to ALLOC_CACHE_ALIGN_BUFFER
The third parameter to ALLOC_CACHE_ALIGN_BUFFER is not size (as named), but rather count (number of elements of the type to allocate). The current code ends up allocating one copy of env_t for each byte in its size, which quite possibly ends up overflowing RAM.
This fixes a bug in commit 3801a15 "env_nand: align NAND buffers".
Reported-by: Prabhakar Lad prabhakar.csengg@gmail.com Signed-off-by: Stephen Warren swarren@nvidia.com --- common/env_nand.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/env_nand.c b/common/env_nand.c index e635472..79e8033 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -226,7 +226,7 @@ int saveenv(void) int saveenv(void) { int ret = 0; - ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, sizeof(env_t)); + ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); ssize_t len; char *res; nand_erase_options_t nand_erase_options;
Hi Stephen,
Thanks for the patch.
Reported-by: Prabhakar Lad prabhakar.lad@ti.com
Regards, --Prabhakar Lad
-- 1.7.0.4
Reported-by: Prabhakar Lad prabhakar.csengg@gmail.com Signed-off-by: Stephen Warren swarren@nvidia.com Reported-by: Prabhakar Lad prabhakar.lad@ti.com
Prabhakar Lad
Stephen Warren
