[U-Boot] [PATCH] net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used together
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips.
This commit contains the following changes:
- The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'.
Signed-off-by: James Byrne james.byrne@origamienergy.com
configs/alt_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/flea3_defconfig | 1 + configs/gose_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/phycore_pcl063_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/pico-pi-imx6ul_defconfig | 1 + configs/porter_defconfig | 1 + configs/silk_defconfig | 1 + configs/stout_defconfig | 1 + configs/stv0991_defconfig | 1 + configs/udoo_neo_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + drivers/net/phy/Kconfig | 19 +++++-------------- drivers/net/phy/micrel_ksz8xxx.c | 8 +++++--- drivers/net/phy/micrel_ksz90x1.c | 2 +- 37 files changed, 45 insertions(+), 18 deletions(-)
diff --git a/configs/alt_defconfig b/configs/alt_defconfig index c4ece79507..44f25a4b94 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -67,6 +67,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 950f9f6baa..0f71f4621e 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -44,6 +44,7 @@ CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_SPI=y CONFIG_MXC_SPI=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 9e31b4ac97..5608110c3a 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -39,6 +39,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_RTC_M41T62=y CONFIG_DM_SERIAL=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 2072281354..4127a47115 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -57,6 +57,7 @@ CONFIG_DFU_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig index 5e9490bc42..b1609b8b7e 100644 --- a/configs/colibri_imx6_nospl_defconfig +++ b/configs/colibri_imx6_nospl_defconfig @@ -46,6 +46,7 @@ CONFIG_DFU_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 7a52361a2a..f4c78dfa1d 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -57,6 +57,7 @@ CONFIG_NAND_MXS_DT=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index 5e2a204a88..18c92fafbd 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 4192501257..17199d98bc 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -55,6 +55,7 @@ CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 19c96768db..f6e8048b60 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -33,6 +33,7 @@ CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_SPI=y CONFIG_MXC_SPI=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 39e4cfdfc2..4c0f25a38c 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index f3661c0a76..07fe95ce84 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index a4766063ca..81132352d0 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 838b6f14b6..6fe483fcca 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 93fa2360ad..110c896350 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 75beab4cce..fad36415d7 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 686aa2c171..d26814865c 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -68,6 +68,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 5555e05030..6ded039c7e 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -56,6 +56,7 @@ CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_RTC_M41T62=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 4a3c56faa6..7f6edc63a6 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 185f543df6..e3dc672e3a 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 3660eaad61..d4897ef22f 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -70,6 +70,7 @@ CONFIG_PWRSEQ=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index e207df51a8..a11ba69e58 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -34,6 +34,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_RTC_M41T62=y CONFIG_DM_SERIAL=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 75058f664a..ab318a6122 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -41,6 +41,7 @@ CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index e6454e5fce..aa75b59766 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -43,6 +43,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index a740016d9e..7fbdb8e2be 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -45,6 +45,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 09deca4064..6ce0b492f4 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -43,6 +43,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index ce309b6d86..ed2410149b 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 0291a7c981..86a012284f 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -68,6 +68,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 1c92cb6117..8204b51c6c 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index 78810529c8..834a75fde3 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -26,6 +26,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_CADENCE_QSPI=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index eac1dc9aee..15bb61ce2f 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -30,5 +30,6 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_OF_LIBFDT=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 24f8243300..dc67ddc0bf 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -37,6 +37,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 4dc8b82e6a..7fcb630ff1 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -37,6 +37,7 @@ CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index a5cc579ce5..bb74542b67 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -38,6 +38,7 @@ CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_SPI=y CONFIG_MXC_SPI=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 00c219f046..b71f3fa776 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -49,6 +49,7 @@ CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_MII=y CONFIG_SPI=y CONFIG_MXC_SPI=y diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 3dc0822d9c..d0f5dd0c79 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -119,21 +119,19 @@ config PHY_MICREL bool "Micrel Ethernet PHYs support" help Enable support for the GbE PHYs manufactured by Micrel (now - a part of Microchip). This includes drivers for the KSZ804, - KSZ8031, KSZ8051, KSZ8081, KSZ8895, KSZ886x, KSZ8721 - either/or KSZ9021 (see the "Micrel KSZ9021 family support" - config option for details), and KSZ9031 (if configured). + a part of Microchip). This includes drivers for the KSZ804, KSZ8031, + KSZ8051, KSZ8081, KSZ8895, KSZ886x and KSZ8721 (if "Micrel KSZ8xxx + family support" is selected) and the KSZ9021 and KSZ9031 (if "Micrel + KSZ90x1 family support" is selected).
if PHY_MICREL
config PHY_MICREL_KSZ9021 bool - select PHY_GIGE select PHY_MICREL_KSZ90X1
config PHY_MICREL_KSZ9031 bool - select PHY_GIGE select PHY_MICREL_KSZ90X1
config PHY_MICREL_KSZ90X1 @@ -146,20 +144,13 @@ config PHY_MICREL_KSZ90X1 delays configured in the device tree will be applied to the PHY during initialization.
- This should not be enabled at the same time with PHY_MICREL_KSZ8XXX - as the KSZ9021 and KS8721 share the same ID. - config PHY_MICREL_KSZ8XXX bool "Micrel KSZ8xxx family support" - default y if !PHY_MICREL_KSZ90X1 help - Enable support for the 8000 series GbE PHYs manufactured by Micrel + Enable support for the 8000 series 10/100 PHYs manufactured by Micrel (now a part of Microchip). This includes drivers for the KSZ804, KSZ8031, KSZ8051, KSZ8081, KSZ8895, KSZ886x, and KSZ8721.
- This should not be enabled at the same time with PHY_MICREL_KSZ90X1 - as the KSZ9021 and KS8721 share the same ID. - endif # PHY_MICREL
config PHY_MSCC diff --git a/drivers/net/phy/micrel_ksz8xxx.c b/drivers/net/phy/micrel_ksz8xxx.c index 3411150ab9..daa57ce33c 100644 --- a/drivers/net/phy/micrel_ksz8xxx.c +++ b/drivers/net/phy/micrel_ksz8xxx.c @@ -147,11 +147,13 @@ static struct phy_driver ksz8895_driver = { .shutdown = &genphy_shutdown, };
-/* Micrel used the exact same part number for the KSZ9021. */ +/* Micrel used the exact same model number for the KSZ9021, + * so the revision number is used to distinguish them. + */ static struct phy_driver KS8721_driver = { .name = "Micrel KS8721BL", - .uid = 0x221610, - .mask = 0xfffff0, + .uid = 0x221618, + .mask = 0xfffffc, .features = PHY_BASIC_FEATURES, .config = &genphy_config, .startup = &genphy_startup, diff --git a/drivers/net/phy/micrel_ksz90x1.c b/drivers/net/phy/micrel_ksz90x1.c index 63e7b0242b..aa2a9ac87e 100644 --- a/drivers/net/phy/micrel_ksz90x1.c +++ b/drivers/net/phy/micrel_ksz90x1.c @@ -271,7 +271,7 @@ static int ksz9021_config(struct phy_device *phydev) static struct phy_driver ksz9021_driver = { .name = "Micrel ksz9021", .uid = 0x221610, - .mask = 0xfffff0, + .mask = 0xfffffe, .features = PHY_GBIT_FEATURES, .config = &ksz9021_config, .startup = &ksz90xx_startup,
On Wed, Mar 6, 2019 at 6:48 AM James Byrne james.byrne@origamienergy.com wrote:
Hi James,
https://patchwork.ozlabs.org/patch/1052351/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
James Byrne
Joe Hershberger
