[U-Boot] [PATCH] elf: use program header for loading
The section header address is a VMA whereas the address found in the program header is a physical one. With this change it is possible to load and start a vx7 intel generic based image.
$ readelf -l /tmp/vx7
Elf file type is EXEC (Executable file) Entry point 0x408000 There are 2 program headers, starting at offset 52
Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x001000 0x00408000 0x00408000 0x04000 0x04000 RWE 0x1000 LOAD 0x005000 0xe040c000 0x0040c000 0x583a84 0x5ccc70 RWE 0x1000
Section to Segment mapping: Segment Sections... 00 .text.locore .data.locore 01 .text .eh_frame .wrs_build_vars .data .tls_data .tls_vars .bss
$ readelf -S /tmp/vx7 There are 13 section headers, starting at offset 0x588af8:
Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text.locore PROGBITS 00408000 001000 00011e 00 AX 0 0 16 [ 2] .data.locore PROGBITS 00409000 002000 003000 00 WA 0 0 4096 [ 3] .text PROGBITS e040c000 005000 4802a0 00 WAX 0 0 32 [ 4] .eh_frame PROGBITS e088c2a0 4852a0 0a1ed0 00 A 0 0 4 [ 5] .wrs_build_vars PROGBITS e092e170 527170 000190 00 Ax 0 0 1 [ 6] .data PROGBITS e092f000 528000 060a70 00 WA 0 0 4096 [ 7] .tls_data PROGBITS e098fa70 588a70 000004 00 A 0 0 4 [ 8] .tls_vars PROGBITS e098fa78 588a78 00000c 00 WA 0 0 4 [ 9] .bss NOBITS e098faa0 588a84 0491d0 00 WA 0 0 32 [10] .shstrtab STRTAB 00000000 588a84 000074 00 0 0 1 [11] .symtab SYMTAB 00000000 588d00 056ee0 10 12 9758 4 [12] .strtab STRTAB 00000000 5dfbe0 05f48a 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific)
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- cmd/elf.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/elf.c b/cmd/elf.c index 5190cc6..445daa0 100644 --- a/cmd/elf.c +++ b/cmd/elf.c @@ -376,7 +376,7 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * binary image. */ if (valid_elf_image(addr)) - addr = load_elf_image_shdr(addr); + addr = load_elf_image_phdr(addr); else puts("## Not an ELF image, assuming binary\n");
First, this is within the realm of 'bootvx' and not 'bootelf', this needs to be clear from the commit message.
Have you tested this with an older VxWorks image as well? Thanks!
Sorry for the late reply.. had some days off.
Okay.. will send a V2 shortly.
Yes.. a vx5.5 based image boots too and here is the readelf output:
$ readelf -l /tmp/vx5
Elf file type is EXEC (Executable file) Entry point 0x308000 There are 1 program headers, starting at offset 52
Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x000060 0x00308000 0x00308000 0x3513a0 0x757860 RWE 0x20
Section to Segment mapping: Segment Sections... 00 .text .data .bss [christian@chgm-pc ~]$ readelf -S /tmp/vx5 There are 12 section headers, starting at offset 0x356580:
Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text PROGBITS 00308000 000060 319b10 00 WAX 0 0 32 [ 2] .data PROGBITS 00621b20 319b80 037880 00 WA 0 0 32 [ 3] .bss NOBITS 006593a0 351400 4064c0 00 WA 0 0 16 [ 4] .debug_aranges PROGBITS 00000000 351400 000060 00 0 0 1 [ 5] .debug_pubnames PROGBITS 00000000 351460 00018b 00 0 0 1 [ 6] .debug_info PROGBITS 00000000 3515eb 003429 00 0 0 1 [ 7] .debug_abbrev PROGBITS 00000000 354a14 000454 00 0 0 1 [ 8] .debug_line PROGBITS 00000000 354e68 0016a4 00 0 0 1 [ 9] .shstrtab STRTAB 00000000 35650c 000071 00 0 0 1 [10] .symtab SYMTAB 00000000 356760 0440e0 10 11 8574 4 [11] .strtab STRTAB 00000000 39a840 03e66c 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific)
greets -- Christian Gmeiner, MSc
Great, thanks. Make sure to mention in the commit message that you've tested both versions.
Christian Gmeiner
