[PATCH] board: amlogic: vim3: fix setup ethernet mac from efuse
Fix reading built-in ethernet MAC address from efuse
NOTE: MAC is stored in ASCII format, 1bytes = 2characters by 0 offset
if mac from efuse not valid we use meson_generate_serial_ethaddr
NOTE: remake odroid-n2.c variant from Neil Armstrong narmstrong@baylibre.com
Signed-off-by: Artem Lapkin art@khadas.com --- board/amlogic/vim3/vim3.c | 22 +++++++++++++++++++--- 1 file changed, 19 insertions(+), 3 deletions(-)
diff --git a/board/amlogic/vim3/vim3.c b/board/amlogic/vim3/vim3.c index 824fff8262..87d9fe1f02 100644 --- a/board/amlogic/vim3/vim3.c +++ b/board/amlogic/vim3/vim3.c @@ -139,26 +139,42 @@ int meson_ft_board_setup(void *blob, struct bd_info *bd) }
#define EFUSE_MAC_OFFSET 0 -#define EFUSE_MAC_SIZE 6 +#define EFUSE_MAC_SIZE 12 +#define MAC_ADDR_LEN 6
int misc_init_r(void) { - uint8_t mac_addr[EFUSE_MAC_SIZE]; + uint8_t mac_addr[MAC_ADDR_LEN]; + char efuse_mac_addr[EFUSE_MAC_SIZE], tmp[3]; ssize_t len;
meson_eth_init(PHY_INTERFACE_MODE_RGMII, 0);
if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, - mac_addr, EFUSE_MAC_SIZE); + efuse_mac_addr, EFUSE_MAC_SIZE); if (len != EFUSE_MAC_SIZE) return 0;
+ /* MAC is stored in ASCII format, 1bytes = 2characters */ + for (int i = 0; i < 6; i++) { + tmp[0] = efuse_mac_addr[i * 2]; + tmp[1] = efuse_mac_addr[i * 2 + 1]; + tmp[2] = '\0'; + mac_addr[i] = simple_strtoul(tmp, NULL, 16); + } + if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("ethaddr", mac_addr); else meson_generate_serial_ethaddr(); + + eth_env_get_enetaddr("ethaddr", mac_addr); + printf("[i] setup onboard mac %02X:%02X:%02X:%02X:%02X:%02X\n", + mac_addr[0],mac_addr[1],mac_addr[2], + mac_addr[3],mac_addr[4],mac_addr[5]); }
return 0; } +
tmp[2] = '\0';
Doesn't need to print mac. If you have to print mac address, then fix the checkpatch error, plz.
ERROR: space required after that ',' (ctx:VxV) #62: FILE: board/amlogic/vim3/vim3.c:174: + mac_addr[0],mac_addr[1],mac_addr[2], ^ ..
return 0; }
Not need whitespace.
Best Regards, Jaehoon Chung
Hi Artem,
First of all, thanks pointing again at this issue.
I've implemented reading of MAC address from EFUSE for VIM boards and I was convinced that it is stored in binary format. I've based my assumptions on the vendor code, especially the message from the vendor kernel:
[ 4.028236] efusekeynum: 1 [ 4.031072] efusekeyname: mac offset: 0 size: 6 [ 4.037542] efuse efuse: probe OK!
and the vendors dts:
https://github.com/khadas/linux/blob/khadas-vims-4.9.y/arch/arm64/boot/dts/a...
which both points that the EFUSE key has only 6 bytes, what means binary format. I didn't check it further what is really stored there.
Now I checked again and it looks that the DTS (and thus vendor's kernel message) is incorrect, as the MAC is stored in ASCII and occupies 12 bytes in efuse. One can check that with vendor's kernel:
# cat /sys/class/efuse/userdata 0x00: 43 38 36 33 31 34 37 30 41 38 44 37 00 00 00 00 0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
This means that your patch is correct, although I would change it a bit.
BTW, the Odroid N2/C4 boards don't have MAC stored explicitly in the EFUSE, but the boards UUID. The original code use the last bytes of the UUID as the MAC address.
tmp[2] = '\0';
Now the above code is the same as for Odroid N2/C4, so it can be moved to arch/arm/mach-meson/board-common.c, maybe as meson_read_efuse_mac_addr() with the offset as parameter, so it can be directly used by Odroids and VIMs.
I'm not really convinced that this message has to be displayed. If so, then use "%pM" for printing MAC address.
return 0; }
Best regards
Artem Lapkin
Jaehoon Chung
Marek Szyprowski
