[U-Boot-Users] [PATCH: cmdcfg: 10/19] lib_ppc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely.
All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jon Loeliger jdl@freescale.com --- lib_ppc/board.c | 33 +++++++++++++++++---------------- lib_ppc/kgdb.c | 2 +- 2 files changed, 18 insertions(+), 17 deletions(-)
diff --git a/lib_ppc/board.c b/lib_ppc/board.c index c4fc580..310c1de 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -35,13 +35,13 @@ #ifdef CONFIG_MPC5xxx #include <mpc5xxx.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_IDE) +#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) #include <ide.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_SCSI) +#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) #include <scsi.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) #include <kgdb.h> #endif #ifdef CONFIG_STATUS_LED @@ -80,14 +80,14 @@ extern int update_flash_size (int flash_size); extern void sc3_read_eeprom(void); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) +#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) void doc_init (void); #endif #if defined(CONFIG_HARD_I2C) || \ defined(CONFIG_SOFT_I2C) #include <i2c.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) void nand_init (void); #endif
@@ -118,7 +118,7 @@ extern ulong __init_end; extern ulong _end; ulong monitor_flash_len;
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) #include <bedbug/type.h> #endif
@@ -779,7 +779,7 @@ void board_init_r (gd_t *id, ulong dest_addr) spi_init_r (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) WATCHDOG_RESET (); puts ("NAND: "); nand_init(); /* go init the NAND */ @@ -941,7 +941,7 @@ void board_init_r (gd_t *id, ulong dest_addr) hermes_start_lxt980 ((int) bd->bi_ethspeed); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) WATCHDOG_RESET (); puts ("KGDB: "); kgdb_init (); @@ -973,7 +973,7 @@ void board_init_r (gd_t *id, ulong dest_addr) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -981,19 +981,19 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET ();
-#if (CONFIG_COMMANDS & CFG_CMD_SCSI) +#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) WATCHDOG_RESET (); puts ("SCSI: "); scsi_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) +#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) WATCHDOG_RESET (); puts ("DOC: "); doc_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) WATCHDOG_RESET (); puts ("Net: "); @@ -1001,7 +1001,7 @@ void board_init_r (gd_t *id, ulong dest_addr) eth_initialize (bd); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) && ( \ +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && ( \ defined(CONFIG_CCM) || \ defined(CONFIG_ELPT860) || \ defined(CONFIG_EP8260) || \ @@ -1026,13 +1026,14 @@ void board_init_r (gd_t *id, ulong dest_addr) post_run (NULL, POST_RAM | post_bootmode_get(0)); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_PCMCIA) && !(CONFIG_COMMANDS & CFG_CMD_IDE) +#if ((CONFIG_COMMANDS & CFG_CMD_PCMCIA) || defined(CONFIG_CMD_PCMCIA)) \ + && !((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE)) WATCHDOG_RESET (); puts ("PCMCIA:"); pcmcia_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IDE) +#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) WATCHDOG_RESET (); # ifdef CONFIG_IDE_8xx_PCCARD puts ("PCMCIA:"); @@ -1057,7 +1058,7 @@ void board_init_r (gd_t *id, ulong dest_addr) last_stage_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) WATCHDOG_RESET (); bedbug_init (); #endif diff --git a/lib_ppc/kgdb.c b/lib_ppc/kgdb.c index 4c5d79a..243d311 100644 --- a/lib_ppc/kgdb.c +++ b/lib_ppc/kgdb.c @@ -1,7 +1,7 @@ #include <common.h> #include <command.h>
#include <kgdb.h> #include <asm/signal.h>
Jon Loeliger
