[U-Boot-Users] Debug symbols for start.S
I have a problem which is causing me some headaches during my porting exercise, I am currently porting u-boot from the ep8260 to our own hardware. I am lucky enough to have not one but four Abatron probes however my problem seems to lie with gdb.
I have compiled the u-boot code straight out of the box so to speak, so I haven't changed anything strange, however when I load gdb with the elf file I find that gdb cannot find the start.S file, it prompts the following:
$ ppc_82xx-gdb u-boot GNU gdb 5.2.1 Copyright 2002 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "--host=i686-pc-linux-gnu --target=powerpc-hardhat-linux"... (gdb) target remote bdi:2001 Remote debugging using bdi:2001 0x00000100 in _start () (gdb) list 1 {standard input}: No such file or directory. in {standard input} (gdb) list strc strcat strchr strcmp strcpy (gdb) list strcmp 48 bne 1b 49 blr 50 51 .globl strcmp 52 strcmp: 53 addi r5,r3,-1 54 addi r4,r4,-1 55 1: lbzu r3,1(r5) 56 cmpwi 1,r3,0 57 lbzu r0,1(r4) (gdb)
The strange thing is that the ppcstring.S routines and others seem fine, I was hoping someone else has seen the same problem? Any help would be very much appreciated.
Thanks
Mark Doherty
Dear Mark,
This is probably a known problem. If you like, you can try out our latest patches; you can find a test version of our cross GDB at ftp://ftp.denx.de/pub/tmp/ppc-linux-gdb - don't forget to set the CROSS_COMPILE environment variable as needed (= ppc_82xx- in your case) as with all our ELDK tools.
Please let me know if it works for you...
Mark Doherty
