[PATCH 1/8] ARM: meson: Sync Amlogic DT from Linux 5.12-rc2
Import Amlogic DT changes from Linux commit a38fd8748464 ("Linux 5.12-rc2"), dt-bindings clock changes and new meson-g12b-gsking-x.dts & odroid-hc4 boards.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-axg-s400.dts | 16 + arch/arm/dts/meson-axg.dtsi | 181 +++++++ arch/arm/dts/meson-g12-common.dtsi | 12 +- arch/arm/dts/meson-g12a-sei510.dts | 2 +- arch/arm/dts/meson-g12b-gsking-x.dts | 133 ++++++ arch/arm/dts/meson-g12b-gtking-pro.dts | 19 +- arch/arm/dts/meson-g12b-gtking.dts | 20 +- arch/arm/dts/meson-g12b-odroid-n2-plus.dts | 2 +- arch/arm/dts/meson-g12b-odroid-n2.dtsi | 18 +- arch/arm/dts/meson-g12b-w400.dtsi | 2 +- arch/arm/dts/meson-g12b.dtsi | 4 + arch/arm/dts/meson-gx-libretech-pc.dtsi | 2 +- arch/arm/dts/meson-gx-p23x-q20x.dtsi | 2 +- arch/arm/dts/meson-gxbb-nanopi-k2.dts | 42 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 42 +- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 50 +- .../dts/meson-gxl-s905x-libretech-cc-v2.dts | 6 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 2 +- arch/arm/dts/meson-gxm-khadas-vim2.dts | 55 ++- arch/arm/dts/meson-gxm.dtsi | 20 + arch/arm/dts/meson-khadas-vim3.dtsi | 36 +- arch/arm/dts/meson-sm1-khadas-vim3l.dts | 7 +- arch/arm/dts/meson-sm1-odroid-c4.dts | 429 +---------------- arch/arm/dts/meson-sm1-odroid-hc4.dts | 96 ++++ arch/arm/dts/meson-sm1-odroid.dtsi | 442 ++++++++++++++++++ arch/arm/dts/meson-sm1-sei610.dts | 10 +- arch/arm/dts/meson-sm1.dtsi | 2 +- include/dt-bindings/clock/axg-clkc.h | 26 +- include/dt-bindings/clock/g12a-clkc.h | 2 + 31 files changed, 1195 insertions(+), 489 deletions(-) create mode 100644 arch/arm/dts/meson-g12b-gsking-x.dts create mode 100644 arch/arm/dts/meson-sm1-odroid-hc4.dts create mode 100644 arch/arm/dts/meson-sm1-odroid.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1dd6c4b2e8..cb2b2ae6fb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -173,11 +173,13 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-g12a-sei510.dtb \ meson-g12b-gtking.dtb \ meson-g12b-gtking-pro.dtb \ + meson-g12b-gsking-x.dtb \ meson-g12b-odroid-n2.dtb \ meson-g12b-odroid-n2-plus.dtb \ meson-g12b-a311d-khadas-vim3.dtb \ meson-sm1-khadas-vim3l.dtb \ meson-sm1-odroid-c4.dtb \ + meson-sm1-odroid-hc4.dtb \ meson-sm1-sei610.dtb dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ diff --git a/arch/arm/dts/meson-axg-s400.dts b/arch/arm/dts/meson-axg-s400.dts index cb1360ae12..359589d1df 100644 --- a/arch/arm/dts/meson-axg-s400.dts +++ b/arch/arm/dts/meson-axg-s400.dts @@ -441,6 +441,16 @@ status = "okay"; };
+&pcieA { + reset-gpios = <&gpio GPIOX_19 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&pcieB { + reset-gpios = <&gpio GPIOZ_10 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + &pwm_ab { status = "okay"; pinctrl-0 = <&pwm_a_x20_pins>; @@ -584,3 +594,9 @@ pinctrl-0 = <&uart_ao_a_pins>; pinctrl-names = "default"; }; + +&usb { + status = "okay"; + dr_mode = "otg"; + vbus-supply = <&usb_pwr>; +}; diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index b9efc84692..d945c84ab6 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -12,6 +12,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> #include <dt-bindings/reset/amlogic,meson-axg-reset.h> +#include <dt-bindings/power/meson-axg-power.h>
/ { compatible = "amlogic,meson-axg"; @@ -171,6 +172,98 @@ #size-cells = <2>; ranges;
+ pcieA: pcie@f9800000 { + compatible = "amlogic,axg-pcie", "snps,dw-pcie"; + reg = <0x0 0xf9800000 0x0 0x400000>, + <0x0 0xff646000 0x0 0x2000>, + <0x0 0xf9f00000 0x0 0x100000>; + reg-names = "elbi", "cfg", "config"; + interrupts = <GIC_SPI 177 IRQ_TYPE_EDGE_RISING>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 179 IRQ_TYPE_EDGE_RISING>; + bus-range = <0x0 0xff>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x82000000 0 0xf9c00000 0x0 0xf9c00000 0 0x00300000>; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_A>, <&clkc CLKID_PCIE_CML_EN0>; + clock-names = "general", "pclk", "port"; + resets = <&reset RESET_PCIE_A>, <&reset RESET_PCIE_APB>; + reset-names = "port", "apb"; + num-lanes = <1>; + phys = <&pcie_phy>; + phy-names = "pcie"; + status = "disabled"; + }; + + pcieB: pcie@fa000000 { + compatible = "amlogic,axg-pcie", "snps,dw-pcie"; + reg = <0x0 0xfa000000 0x0 0x400000>, + <0x0 0xff648000 0x0 0x2000>, + <0x0 0xfa400000 0x0 0x100000>; + reg-names = "elbi", "cfg", "config"; + interrupts = <GIC_SPI 167 IRQ_TYPE_EDGE_RISING>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 169 IRQ_TYPE_EDGE_RISING>; + bus-range = <0x0 0xff>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x82000000 0 0xfa500000 0x0 0xfa500000 0 0x00300000>; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_B>, <&clkc CLKID_PCIE_CML_EN1>; + clock-names = "general", "pclk", "port"; + resets = <&reset RESET_PCIE_B>, <&reset RESET_PCIE_APB>; + reset-names = "port", "apb"; + num-lanes = <1>; + phys = <&pcie_phy>; + phy-names = "pcie"; + status = "disabled"; + }; + + usb: usb@ffe09080 { + compatible = "amlogic,meson-axg-usb-ctrl"; + reg = <0x0 0xffe09080 0x0 0x20>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "usb_ctrl", "ddr"; + resets = <&reset RESET_USB_OTG>; + + dr_mode = "otg"; + + phys = <&usb2_phy1>; + phy-names = "usb2-phy1"; + + dwc2: usb@ff400000 { + compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; + reg = <0x0 0xff400000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1>; + clock-names = "otg"; + phys = <&usb2_phy1>; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + }; + + dwc3: usb@ff500000 { + compatible = "snps,dwc3"; + reg = <0x0 0xff500000 0x0 0x100000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + maximum-speed = "high-speed"; + snps,dis_u2_susphy_quirk; + }; + }; + ethmac: ethernet@ff3f0000 { compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.70a", @@ -187,9 +280,19 @@ "timing-adjustment"; rx-fifo-depth = <4096>; tx-fifo-depth = <2048>; + power-domains = <&pwrc PWRC_AXG_ETHERNET_MEM_ID>; status = "disabled"; };
+ pcie_phy: phy@ff644000 { + compatible = "amlogic,axg-pcie-phy"; + reg = <0x0 0xff644000 0x0 0x1c>; + resets = <&reset RESET_PCIE_PHY>; + phys = <&mipi_pcie_analog_dphy>; + phy-names = "analog"; + #phy-cells = <0>; + }; + pdm: audio-controller@ff632000 { compatible = "amlogic,axg-pdm"; reg = <0x0 0xff632000 0x0 0x34>; @@ -1117,6 +1220,52 @@ clocks = <&xtal>; clock-names = "xtal"; }; + + pwrc: power-controller { + compatible = "amlogic,meson-axg-pwrc"; + #power-domain-cells = <1>; + amlogic,ao-sysctrl = <&sysctrl_AO>; + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + reset-names = "viu", "venc", "vcbus", + "vencl", "vid_lock"; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <250000000>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ + }; + + mipi_pcie_analog_dphy: phy { + compatible = "amlogic,axg-mipi-pcie-analog-phy"; + #phy-cells = <0>; + status = "disabled"; + }; }; };
@@ -1129,6 +1278,19 @@ #mbox-cells = <1>; };
+ mipi_dphy: phy@ff640000 { + compatible = "amlogic,axg-mipi-dphy"; + reg = <0x0 0xff640000 0x0 0x100>; + clocks = <&clkc CLKID_MIPI_DSI_PHY>; + clock-names = "pclk"; + resets = <&reset RESET_MIPI_PHY>; + reset-names = "phy"; + phys = <&mipi_pcie_analog_dphy>; + phy-names = "analog"; + #phy-cells = <0>; + status = "disabled"; + }; + audio: bus@ff642000 { compatible = "simple-bus"; reg = <0x0 0xff642000 0x0 0x2000>; @@ -1563,6 +1725,15 @@ }; };
+ ge2d: ge2d@ff940000 { + compatible = "amlogic,axg-ge2d"; + reg = <0x0 0xff940000 0x0 0x10000>; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_VAPB>; + resets = <&reset RESET_GE2D>; + reset-names = "core"; + }; + gic: interrupt-controller@ffc01000 { compatible = "arm,gic-400"; reg = <0x0 0xffc01000 0 0x1000>, @@ -1734,6 +1905,16 @@ clock-names = "core", "clkin0", "clkin1"; resets = <&reset RESET_SD_EMMC_C>; }; + + usb2_phy1: phy@9020 { + compatible = "amlogic,meson-gxl-usb2-phy"; + #phy-cells = <0>; + reg = <0x0 0x9020 0x0 0x20>; + clocks = <&clkc CLKID_USB>; + clock-names = "phy"; + resets = <&reset RESET_USB_OTG>; + reset-names = "phy"; + }; };
sram: sram@fffc0000 { diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi index 1e83ec5b8c..b858c5e43c 100644 --- a/arch/arm/dts/meson-g12-common.dtsi +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -209,7 +209,7 @@ };
ethmac: ethernet@ff3f0000 { - compatible = "amlogic,meson-axg-dwmac", + compatible = "amlogic,meson-g12a-dwmac", "snps,dwmac-3.70a", "snps,dwmac"; reg = <0x0 0xff3f0000 0x0 0x10000>, @@ -282,6 +282,8 @@ hwrng: rng@218 { compatible = "amlogic,meson-rng"; reg = <0x0 0x218 0x0 0x4>; + clocks = <&clkc CLKID_RNG0>; + clock-names = "core"; }; };
@@ -2179,6 +2181,12 @@ amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; };
+ watchdog: wdt@f0d0 { + compatible = "amlogic,meson-gxbb-wdt"; + reg = <0x0 0xf0d0 0x0 0x10>; + clocks = <&xtal>; + }; + spicc0: spi@13000 { compatible = "amlogic,meson-g12a-spicc"; reg = <0x0 0x13000 0x0 0x44>; @@ -2380,7 +2388,7 @@ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; dr_mode = "host"; snps,dis_u2_susphy_quirk; - snps,quirk-frame-length-adjustment; + snps,quirk-frame-length-adjustment = <0x20>; snps,parkmode-disable-ss-quirk; }; }; diff --git a/arch/arm/dts/meson-g12a-sei510.dts b/arch/arm/dts/meson-g12a-sei510.dts index b00d0468c7..81269ccc24 100644 --- a/arch/arm/dts/meson-g12a-sei510.dts +++ b/arch/arm/dts/meson-g12a-sei510.dts @@ -181,7 +181,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12A-SEI510"; + model = "SEI510"; audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", diff --git a/arch/arm/dts/meson-g12b-gsking-x.dts b/arch/arm/dts/meson-g12b-gsking-x.dts new file mode 100644 index 0000000000..211191f663 --- /dev/null +++ b/arch/arm/dts/meson-g12b-gsking-x.dts @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +/dts-v1/; + +#include "meson-g12b-w400.dtsi" +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + compatible = "azw,gsking-x", "amlogic,g12b"; + model = "Beelink GS-King X"; + + aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + #address-cells = <1>; + #size-cells = <0>; + poll-interval = <100>; + + power-button { + label = "power"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "GSKING-X"; + audio-aux-devs = <&tdmout_a>; + audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 1", + "TDMOUT_A IN 1", "FRDDR_B OUT 1", + "TDMOUT_A IN 2", "FRDDR_C OUT 1", + "TDM_A Playback", "TDMOUT_A OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_a>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_A>; + }; + }; + + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + +&tdmif_a { + status = "okay"; +}; + +&tdmout_a { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; diff --git a/arch/arm/dts/meson-g12b-gtking-pro.dts b/arch/arm/dts/meson-g12b-gtking-pro.dts index f0c56a16af..0e331aa5a2 100644 --- a/arch/arm/dts/meson-g12b-gtking-pro.dts +++ b/arch/arm/dts/meson-g12b-gtking-pro.dts @@ -14,6 +14,11 @@ compatible = "azw,gtking", "amlogic,g12b"; model = "Beelink GT-King Pro";
+ aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + gpio-keys-polled { compatible = "gpio-keys-polled"; #address-cells = <1>; @@ -39,7 +44,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-GTKING-PRO"; + model = "GTKING-PRO"; audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1", @@ -112,6 +117,18 @@ status = "okay"; };
+&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &tdmif_b { status = "okay"; }; diff --git a/arch/arm/dts/meson-g12b-gtking.dts b/arch/arm/dts/meson-g12b-gtking.dts index eeb7bc5539..a7db84a500 100644 --- a/arch/arm/dts/meson-g12b-gtking.dts +++ b/arch/arm/dts/meson-g12b-gtking.dts @@ -14,6 +14,11 @@ compatible = "azw,gtking", "amlogic,g12b"; model = "Beelink GT-King";
+ aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + spdif_dit: audio-codec-1 { #sound-dai-cells = <0>; compatible = "linux,spdif-dit"; @@ -23,7 +28,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-GTKING"; + model = "GTKING"; audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1", @@ -122,6 +127,19 @@ status = "okay"; };
+ +&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &spdifout { pinctrl-0 = <&spdif_out_h_pins>; pinctrl-names = "default"; diff --git a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts index 5de2815ba9..ce1198ad34 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts +++ b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts @@ -19,7 +19,7 @@ regulator-min-microvolt = <680000>; regulator-max-microvolt = <1040000>;
- pwms = <&pwm_AO_cd 1 1500 0>; + pwms = <&pwm_ab 0 1500 0>; };
&vddcpu_b { diff --git a/arch/arm/dts/meson-g12b-odroid-n2.dtsi b/arch/arm/dts/meson-g12b-odroid-n2.dtsi index 6982632ae6..58ce569b2a 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2.dtsi +++ b/arch/arm/dts/meson-g12b-odroid-n2.dtsi @@ -13,6 +13,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac; + rtc0 = &rtc; + rtc1 = &vrtc; };
dioo2133: audio-amplifier-0 { @@ -211,7 +213,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-ODROID-N2"; + model = "ODROID-N2"; audio-widgets = "Line", "Lineout"; audio-aux-devs = <&tdmout_b>, <&tdmout_c>, <&tdmin_a>, <&tdmin_b>, <&tdmin_c>, <&tdmin_lb>, @@ -413,7 +415,7 @@ max-speed = <1000>;
reset-assert-us = <10000>; - reset-deassert-us = <30000>; + reset-deassert-us = <80000>; reset-gpios = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>;
interrupt-parent = <&gpio_intc>; @@ -478,6 +480,18 @@ linux,rc-map-name = "rc-odroid"; };
+&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &pwm_ab { pinctrl-0 = <&pwm_a_e_pins>; pinctrl-names = "default"; diff --git a/arch/arm/dts/meson-g12b-w400.dtsi b/arch/arm/dts/meson-g12b-w400.dtsi index 2802ddbb83..feb0885047 100644 --- a/arch/arm/dts/meson-g12b-w400.dtsi +++ b/arch/arm/dts/meson-g12b-w400.dtsi @@ -264,7 +264,7 @@ max-speed = <1000>;
interrupt-parent = <&gpio_intc>; diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 9b8548e5f6..ee8fcae9f9 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -135,3 +135,7 @@ }; }; }; + +&mali { + dma-coherent; +}; diff --git a/arch/arm/dts/meson-gx-libretech-pc.dtsi b/arch/arm/dts/meson-gx-libretech-pc.dtsi index c2480bab8d..2d7032f41e 100644 --- a/arch/arm/dts/meson-gx-libretech-pc.dtsi +++ b/arch/arm/dts/meson-gx-libretech-pc.dtsi @@ -186,7 +186,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S9XX-PC"; + model = "LIBRETECH-PC"; audio-aux-devs = <&dio2133>; audio-widgets = "Speaker", "7J4-14 LEFT", "Speaker", "7J4-11 RIGHT"; diff --git a/arch/arm/dts/meson-gx-p23x-q20x.dtsi b/arch/arm/dts/meson-gx-p23x-q20x.dtsi index 6b57e15aad..dafc841f7c 100644 --- a/arch/arm/dts/meson-gx-p23x-q20x.dtsi +++ b/arch/arm/dts/meson-gx-p23x-q20x.dtsi @@ -121,7 +121,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GX-P230-Q200"; + model = "P230-Q200"; audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLP", diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts index 7be3e35409..7273eed529 100644 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ b/arch/arm/dts/meson-gxbb-nanopi-k2.dts @@ -7,6 +7,7 @@
#include "meson-gxbb.dtsi" #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; @@ -130,6 +131,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "NANOPI-K2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -165,7 +205,7 @@ reg = <0>;
reset-assert-us = <10000>; - reset-deassert-us = <30000>; + reset-deassert-us = <80000>; reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>;
interrupt-parent = <&gpio_intc>; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index 70fcfb7b06..bfaf7f41a2 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -9,6 +9,7 @@
/ { compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; @@ -172,6 +173,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "ODROID-C2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -200,7 +240,7 @@ reg = <0>;
interrupt-parent = <&gpio_intc>; diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts index 9e43f4dca9..2d769203f6 100644 --- a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts +++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts @@ -118,7 +118,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S805X-AC"; + model = "LIBRETECH-AC"; audio-widgets = "Speaker", "9J5-3 LEFT", "Speaker", "9J5-2 RIGHT"; audio-routing = "9J5-3 LEFT", "ACODEC LOLN", diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts index 8bcdffdf55..60feac0179 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts @@ -5,9 +5,9 @@
/dts-v1/;
-#include <dt-bindings/input/input.h> - #include "meson-gxl-s905x-p212.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim", "amlogic,s905x", "amlogic,meson-gxl"; @@ -42,10 +42,10 @@ }; };
- pwmleds { + led-controller { compatible = "pwm-leds";
- power { + led-1 { label = "vim:red:power"; pwms = <&pwm_AO_ab 1 7812500 0>; max-brightness = <255>; @@ -63,6 +63,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "KHADAS-VIM"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -97,8 +136,7 @@ pinctrl-names = "default";
rtc: rtc@51 { - /* has to be enabled manually when a battery is connected: */ - status = "disabled"; + status = "okay"; compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts index 675eaa8796..93d8f8aff7 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts @@ -84,7 +84,6 @@ regulator-always-on; };
- vcck: regulator-vcck { compatible = "regulator-fixed"; regulator-name = "VCCK"; @@ -124,7 +123,6 @@ regulator-always-on; };
- vddio_card: regulator-vddio-card { compatible = "regulator-gpio"; regulator-name = "VDDIO_CARD"; @@ -161,7 +159,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S905X-CC-V2"; + model = "LIBRETECH-CC-V2"; assigned-clocks = <&clkc CLKID_MPLL0>, <&clkc CLKID_MPLL1>, <&clkc CLKID_MPLL2>; @@ -195,7 +193,6 @@ }; };
- &aiu { status = "okay"; }; @@ -207,7 +204,6 @@ hdmi-phandle = <&hdmi_tx>; };
- ðmac { status = "okay"; }; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts index 5ae7bb6209..82bfabfbd3 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts @@ -135,7 +135,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S905X-CC"; + model = "LIBRETECH-CC"; audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLN", diff --git a/arch/arm/dts/meson-gxm-khadas-vim2.dts b/arch/arm/dts/meson-gxm-khadas-vim2.dts index bff8ec2c1c..18a4b7a6c5 100644 --- a/arch/arm/dts/meson-gxm-khadas-vim2.dts +++ b/arch/arm/dts/meson-gxm-khadas-vim2.dts @@ -7,9 +7,9 @@
/dts-v1/;
-#include <dt-bindings/input/input.h> - #include "meson-gxm.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim2", "amlogic,s912", "amlogic,meson-gxm"; @@ -81,10 +81,10 @@ }; };
- power { + led-1 { label = "vim:red:power"; pwms = <&pwm_AO_ab 1 7812500 0>; max-brightness = <255>; @@ -145,6 +145,45 @@ clock-frequency = <32768>; pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "KHADAS-VIM2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -154,7 +193,6 @@ hdmi-phandle = <&hdmi_tx>; };
- &cpu_cooling_maps { map0 { cooling-device = <&gpio_fan THERMAL_NO_LIMIT 1>; @@ -194,7 +232,7 @@ reg = <0>;
interrupt-parent = <&gpio_intc>; @@ -228,8 +266,7 @@ pinctrl-names = "default";
rtc: rtc@51 { - /* has to be enabled manually when a battery is connected: */ - status = "disabled"; + status = "okay"; compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; @@ -341,7 +378,7 @@ #size-cells = <1>; compatible = "winbond,w25q16", "jedec,spi-nor"; reg = <0>; - spi-max-frequency = <3000000>; + spi-max-frequency = <104000000>; }; };
diff --git a/arch/arm/dts/meson-gxm.dtsi b/arch/arm/dts/meson-gxm.dtsi index fe41451122..411cc312fc 100644 --- a/arch/arm/dts/meson-gxm.dtsi +++ b/arch/arm/dts/meson-gxm.dtsi @@ -42,11 +42,28 @@ }; };
+ cpu0: cpu@0 { + capacity-dmips-mhz = <1024>; + }; + + cpu1: cpu@1 { + capacity-dmips-mhz = <1024>; + }; + + cpu2: cpu@2 { + capacity-dmips-mhz = <1024>; + }; + + cpu3: cpu@3 { + capacity-dmips-mhz = <1024>; + }; + cpu4: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a53"; reg = <0x0 0x100>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -57,6 +74,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x101>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -67,6 +85,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x102>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -77,6 +96,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x103>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; diff --git a/arch/arm/dts/meson-khadas-vim3.dtsi b/arch/arm/dts/meson-khadas-vim3.dtsi index 7b46555ac5..877e3b9892 100644 --- a/arch/arm/dts/meson-khadas-vim3.dtsi +++ b/arch/arm/dts/meson-khadas-vim3.dtsi @@ -6,6 +6,7 @@ */
#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/meson-g12a-gpio.h> #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
@@ -13,6 +14,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac; + rtc0 = &rtc; + rtc1 = &vrtc; };
chosen { @@ -40,14 +43,16 @@ leds { compatible = "gpio-leds";
- led-white { - label = "vim3:white:sys"; + white { + color = <LED_COLOR_ID_WHITE>; + function = LED_FUNCTION_STATUS; gpios = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; };
- led-red { - label = "vim3:red"; + red { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_STATUS; gpios = <&gpio_expander 5 GPIO_ACTIVE_HIGH>; }; }; @@ -165,7 +170,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-KHADAS-VIM3"; + model = "KHADAS-VIM3"; audio-aux-devs = <&tdmout_a>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", "TDMOUT_A IN 1", "FRDDR_B OUT 0", @@ -278,12 +283,12 @@ };
ðmac { - pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; - pinctrl-names = "default"; - status = "okay"; - phy-mode = "rgmii"; - phy-handle = <&external_phy>; - amlogic,tx-delay-ns = <2>; + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; };
&frddr_a { @@ -330,7 +335,7 @@ #gpio-cells = <2>; };
- rtc@51 { + rtc: rtc@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; @@ -349,9 +354,9 @@ };
&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; + status = "okay"; + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; };
&saradc { @@ -445,7 +450,6 @@ }; };
- &tdmif_a { status = "okay"; }; diff --git a/arch/arm/dts/meson-sm1-khadas-vim3l.dts b/arch/arm/dts/meson-sm1-khadas-vim3l.dts index 4b517ca720..06de0b1ce7 100644 --- a/arch/arm/dts/meson-sm1-khadas-vim3l.dts +++ b/arch/arm/dts/meson-sm1-khadas-vim3l.dts @@ -89,13 +89,12 @@ status = "okay"; };
-&sd_emmc_a { - sd-uhs-sdr50; -}; - &usb { phys = <&usb2_phy0>, <&usb2_phy1>; phy-names = "usb2-phy0", "usb2-phy1"; }; */
+&sd_emmc_a { + sd-uhs-sdr50; +}; diff --git a/arch/arm/dts/meson-sm1-odroid-c4.dts b/arch/arm/dts/meson-sm1-odroid-c4.dts index cf5a98f0e4..b2a4e823c1 100644 --- a/arch/arm/dts/meson-sm1-odroid-c4.dts +++ b/arch/arm/dts/meson-sm1-odroid-c4.dts @@ -5,34 +5,12 @@
/dts-v1/;
-#include "meson-sm1.dtsi" -#include <dt-bindings/gpio/meson-g12a-gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/sound/meson-g12a-tohdmitx.h> +#include "meson-sm1-odroid.dtsi"
/ { compatible = "hardkernel,odroid-c4", "amlogic,sm1"; model = "Hardkernel ODROID-C4";
- aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; - }; - leds { compatible = "gpio-leds";
@@ -45,96 +23,6 @@ }; };
- tflash_vdd: regulator-tflash_vdd { - compatible = "regulator-fixed"; - - regulator-name = "TFLASH_VDD"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - enable-active-high; - regulator-always-on; - }; - - tf_io: gpio-regulator-tf_io { - compatible = "regulator-gpio"; - - regulator-name = "TF_IO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_6 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - }; - - flash_1v8: regulator-flash_1v8 { - compatible = "regulator-fixed"; - regulator-name = "FLASH_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - regulator-always-on; - }; - - main_12v: regulator-main_12v { - compatible = "regulator-fixed"; - regulator-name = "12V"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - }; - - vcc_5v: regulator-vcc_5v { - compatible = "regulator-fixed"; - regulator-name = "5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&main_12v>; - }; - - vcc_1v8: regulator-vcc_1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - regulator-always-on; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vddao_3v3>; - regulator-always-on; - /* FIXME: actually controlled by VDDCPU_B_EN */ - }; - - vddcpu: regulator-vddcpu { - /* - * MP8756GD Regulator. - */ - compatible = "pwm-regulator"; - - regulator-name = "VDDCPU"; - regulator-min-microvolt = <721000>; - regulator-max-microvolt = <1022000>; - - vin-supply = <&main_12v>; - - pwms = <&pwm_AO_cd 1 1250 0>; - pwm-dutycycle-range = <100 0>; - - regulator-boot-on; - regulator-always-on; - }; - hub_5v: regulator-hub_5v { compatible = "regulator-fixed"; regulator-name = "HUB_5V"; @@ -147,215 +35,12 @@ enable-active-high; };
- usb_pwr_en: regulator-usb_pwr_en { - compatible = "regulator-fixed"; - regulator-name = "USB_PWR_EN"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_5v>; - - /* Connected to the microUSB port power enable */ - gpio = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddao_1v8: regulator-vddao_1v8 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vddao_3v3>; - regulator-always-on; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&main_12v>; - regulator-always-on; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - sound { - compatible = "amlogic,axg-sound-card"; - model = "SM1-ODROID-C4"; - audio-aux-devs = <&tdmout_b>; - audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", - "TDMOUT_B IN 1", "FRDDR_B OUT 1", - "TDMOUT_B IN 2", "FRDDR_C OUT 1", - "TDM_B Playback", "TDMOUT_B OUT"; - - assigned-clocks = <&clkc CLKID_MPLL2>, - <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&frddr_a>; - }; - - dai-link-1 { - sound-dai = <&frddr_b>; - }; - - dai-link-2 { - sound-dai = <&frddr_c>; - }; - - /* 8ch hdmi interface */ - dai-link-3 { - sound-dai = <&tdmif_b>; - dai-format = "i2s"; - dai-tdm-slot-tx-mask-0 = <1 1>; - dai-tdm-slot-tx-mask-1 = <1 1>; - dai-tdm-slot-tx-mask-2 = <1 1>; - dai-tdm-slot-tx-mask-3 = <1 1>; - mclk-fs = <256>; - - codec { - sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; - }; - }; - - /* hdmi glue */ - dai-link-4 { - sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; - - codec { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&arb { - status = "okay"; -}; - -&clkc_audio { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU_CLK>; - clock-latency = <50000>; -}; - -&cpu1 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU1_CLK>; - clock-latency = <50000>; -}; - -&cpu2 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU2_CLK>; - clock-latency = <50000>; -}; - -&cpu3 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU3_CLK>; - clock-latency = <50000>; -}; - -&ext_mdio { - external_phy: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - max-speed = <1000>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_14 */ - interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + model = "ODROID-C4"; }; };
-ðmac { - pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; - pinctrl-names = "default"; - status = "okay"; - phy-mode = "rgmii"; - phy-handle = <&external_phy>; - amlogic,tx-delay-ns = <2>; -}; - -&frddr_a { - status = "okay"; -}; - -&frddr_b { - status = "okay"; -}; - -&frddr_c { - status = "okay"; -}; - &gpio { - gpio-line-names = - /* GPIOZ */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - /* GPIOH */ - "", "", "", "", "", - "PIN_36", /* GPIOH_5 */ - "PIN_26", /* GPIOH_6 */ - "PIN_32", /* GPIOH_7 */ - "", - /* BOOT */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - /* GPIOC */ - "", "", "", "", "", "", "", "", - /* GPIOA */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", - "PIN_27", /* GPIOA_14 */ - "PIN_28", /* GPIOA_15 */ - /* GPIOX */ - "PIN_16", /* GPIOX_0 */ - "PIN_18", /* GPIOX_1 */ - "PIN_22", /* GPIOX_2 */ - "PIN_11", /* GPIOX_3 */ - "PIN_13", /* GPIOX_4 */ - "PIN_7", /* GPIOX_5 */ - "PIN_33", /* GPIOX_6 */ - "PIN_15", /* GPIOX_7 */ - "PIN_19", /* GPIOX_8 */ - "PIN_21", /* GPIOX_9 */ - "PIN_24", /* GPIOX_10 */ - "PIN_23", /* GPIOX_11 */ - "PIN_8", /* GPIOX_12 */ - "PIN_10", /* GPIOX_13 */ - "PIN_29", /* GPIOX_14 */ - "PIN_31", /* GPIOX_15 */ - "PIN_12", /* GPIOX_16 */ - "PIN_3", /* GPIOX_17 */ - "PIN_5", /* GPIOX_18 */ - "PIN_35"; /* GPIOX_19 */ - /* * WARNING: The USB Hub on the Odroid-C4 needs a reset signal * to be turned high in order to be detected by the USB Controller @@ -370,120 +55,10 @@ }; };
-&gpio_ao { - gpio-line-names = - /* GPIOAO */ - "", "", "", "", - "PIN_47", /* GPIOAO_4 */ - "", "", - "PIN_45", /* GPIOAO_7 */ - "PIN_46", /* GPIOAO_8 */ - "PIN_44", /* GPIOAO_9 */ - "PIN_42", /* GPIOAO_10 */ - "", - /* GPIOE */ - "", "", ""; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; - pinctrl-names = "default"; - hdmi-supply = <&vcc_5v>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - &ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; linux,rc-map-name = "rc-odroid"; };
-&pwm_AO_cd { - pinctrl-0 = <&pwm_ao_d_e_pins>; - pinctrl-names = "default"; - clocks = <&xtal>; - clock-names = "clkin1"; - status = "okay"; -}; - -&saradc { - status = "okay"; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_c_pins>; - pinctrl-1 = <&sdcard_clk_gate_c_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <200000000>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - disable-wp; - - cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; - vmmc-supply = <&tflash_vdd>; - vqmmc-supply = <&tf_io>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - max-frequency = <200000000>; - disable-wp; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&flash_1v8>; -}; - -&tdmif_b { - status = "okay"; -}; - -&tdmout_b { - status = "okay"; -}; - -&tohdmitx { - status = "okay"; -}; - -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb { - status = "okay"; - vbus-supply = <&usb_pwr_en>; -}; - -&usb2_phy0 { - phy-supply = <&vcc_5v>; -}; - &usb2_phy1 { /* Enable the hub which is connected to this port */ phy-supply = <&hub_5v>; diff --git a/arch/arm/dts/meson-sm1-odroid-hc4.dts b/arch/arm/dts/meson-sm1-odroid-hc4.dts new file mode 100644 index 0000000000..bf15700c4b --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid-hc4.dts @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Dongjin Kim tobetter@gmail.com + */ + +/dts-v1/; + +#include "meson-sm1-odroid.dtsi" + +/ { + compatible = "hardkernel,odroid-hc4", "amlogic,sm1"; + model = "Hardkernel ODROID-HC4"; + + aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + + fan0: pwm-fan { + compatible = "pwm-fan"; + #cooling-cells = <2>; + cooling-min-state = <0>; + cooling-max-state = <3>; + cooling-levels = <0 120 170 220>; + pwms = <&pwm_cd 1 40000 0>; + }; + + leds { + compatible = "gpio-leds"; + + led-blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + panic-indicator; + }; + + led-red { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_POWER; + gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + sound { + model = "ODROID-HC4"; + }; +}; + +&cpu_thermal { + cooling-maps { + map { + trip = <&cpu_passive>; + cooling-device = <&fan0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; +}; + +&ir { + linux,rc-map-name = "rc-odroid"; +}; + +&i2c2 { + status = "okay"; + pinctrl-0 = <&i2c2_sda_x_pins>, <&i2c2_sck_x_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + status = "okay"; + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + +&pcie { + status = "okay"; + reset-gpios = <&gpio GPIOH_4 GPIO_ACTIVE_LOW>; +}; + +&pwm_cd { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_d_x6_pins>; +}; + +&sd_emmc_c { + status = "disabled"; +}; + +&usb { + phys = <&usb2_phy0>, <&usb2_phy1>; + phy-names = "usb2-phy0", "usb2-phy1"; +}; diff --git a/arch/arm/dts/meson-sm1-odroid.dtsi b/arch/arm/dts/meson-sm1-odroid.dtsi new file mode 100644 index 0000000000..d14716b3d0 --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid.dtsi @@ -0,0 +1,442 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Dongjin Kim tobetter@gmail.com + */ + +#include "meson-sm1.dtsi" +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + tflash_vdd: regulator-tflash_vdd { + compatible = "regulator-fixed"; + + regulator-name = "TFLASH_VDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + }; + + tf_io: gpio-regulator-tf_io { + compatible = "regulator-gpio"; + + regulator-name = "TF_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio_ao GPIOAO_6 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + + states = <3300000 0>, + <1800000 1>; + }; + + flash_1v8: regulator-flash_1v8 { + compatible = "regulator-fixed"; + regulator-name = "FLASH_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + main_12v: regulator-main_12v { + compatible = "regulator-fixed"; + regulator-name = "12V"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + }; + + vcc_5v: regulator-vcc_5v { + compatible = "regulator-fixed"; + regulator-name = "5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&main_12v>; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + /* FIXME: actually controlled by VDDCPU_B_EN */ + }; + + vddcpu: regulator-vddcpu { + /* + * MP8756GD Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU"; + regulator-min-microvolt = <721000>; + regulator-max-microvolt = <1022000>; + + vin-supply = <&main_12v>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + usb_pwr_en: regulator-usb_pwr_en { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR_EN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + /* Connected to the microUSB port power enable */ + gpio = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + vddao_3v3: regulator-vddao_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&main_12v>; + regulator-always-on; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + audio-aux-devs = <&tdmout_b>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* hdmi glue */ + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU1_CLK>; + clock-latency = <50000>; +}; + +&cpu2 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU2_CLK>; + clock-latency = <50000>; +}; + +&cpu3 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU3_CLK>; + clock-latency = <50000>; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&gpio { + gpio-line-names = + /* GPIOZ */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOH */ + "", "", "", "", "", + "PIN_36", /* GPIOH_5 */ + "PIN_26", /* GPIOH_6 */ + "PIN_32", /* GPIOH_7 */ + "", + /* BOOT */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOC */ + "", "", "", "", "", "", "", "", + /* GPIOA */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", + "PIN_27", /* GPIOA_14 */ + "PIN_28", /* GPIOA_15 */ + /* GPIOX */ + "PIN_16", /* GPIOX_0 */ + "PIN_18", /* GPIOX_1 */ + "PIN_22", /* GPIOX_2 */ + "PIN_11", /* GPIOX_3 */ + "PIN_13", /* GPIOX_4 */ + "PIN_7", /* GPIOX_5 */ + "PIN_33", /* GPIOX_6 */ + "PIN_15", /* GPIOX_7 */ + "PIN_19", /* GPIOX_8 */ + "PIN_21", /* GPIOX_9 */ + "PIN_24", /* GPIOX_10 */ + "PIN_23", /* GPIOX_11 */ + "PIN_8", /* GPIOX_12 */ + "PIN_10", /* GPIOX_13 */ + "PIN_29", /* GPIOX_14 */ + "PIN_31", /* GPIOX_15 */ + "PIN_12", /* GPIOX_16 */ + "PIN_3", /* GPIOX_17 */ + "PIN_5", /* GPIOX_18 */ + "PIN_35"; /* GPIOX_19 */ +}; + +&gpio_ao { + gpio-line-names = + /* GPIOAO */ + "", "", "", "", + "PIN_47", /* GPIOAO_4 */ + "", "", + "PIN_45", /* GPIOAO_7 */ + "PIN_46", /* GPIOAO_8 */ + "PIN_44", /* GPIOAO_9 */ + "PIN_42", /* GPIOAO_10 */ + "", + /* GPIOE */ + "", "", ""; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc_5v>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + +&saradc { + status = "okay"; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <200000000>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&tflash_vdd>; + vqmmc-supply = <&tf_io>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&flash_1v8>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb { + status = "okay"; + vbus-supply = <&usb_pwr_en>; +}; + +&usb2_phy0 { + phy-supply = <&vcc_5v>; +}; + diff --git a/arch/arm/dts/meson-sm1-sei610.dts b/arch/arm/dts/meson-sm1-sei610.dts index 5ab139a34c..2194a77897 100644 --- a/arch/arm/dts/meson-sm1-sei610.dts +++ b/arch/arm/dts/meson-sm1-sei610.dts @@ -101,20 +101,20 @@ }; };
- leds { + led-controller-1 { compatible = "gpio-leds";
- led-bluetooth { + led-1 { label = "sei610:blue:bt"; gpios = <&gpio GPIOC_7 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; default-state = "off"; }; };
- pwmleds { + led-controller-2 { compatible = "pwm-leds";
- power { + led-2 { label = "sei610:red:power"; pwms = <&pwm_AO_ab 0 30518 0>; max-brightness = <255>; @@ -220,7 +220,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "SM1-SEI610"; + model = "SEI610"; audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", diff --git a/arch/arm/dts/meson-sm1.dtsi b/arch/arm/dts/meson-sm1.dtsi index 71317f5aad..c309517aba 100644 --- a/arch/arm/dts/meson-sm1.dtsi +++ b/arch/arm/dts/meson-sm1.dtsi @@ -130,7 +130,7 @@ opp-microvolt = <790000>; };
- opp-1512000000 { + opp-1500000000 { opp-hz = /bits/ 64 <1500000000>; opp-microvolt = <800000>; }; diff --git a/include/dt-bindings/clock/axg-clkc.h b/include/dt-bindings/clock/axg-clkc.h index fd1f938c38..93752ea107 100644 --- a/include/dt-bindings/clock/axg-clkc.h +++ b/include/dt-bindings/clock/axg-clkc.h @@ -70,7 +70,31 @@ #define CLKID_HIFI_PLL 69 #define CLKID_PCIE_CML_EN0 79 #define CLKID_PCIE_CML_EN1 80 -#define CLKID_MIPI_ENABLE 81 #define CLKID_GEN_CLK 84 +#define CLKID_VPU_0_SEL 92 +#define CLKID_VPU_0 93 +#define CLKID_VPU_1_SEL 95 +#define CLKID_VPU_1 96 +#define CLKID_VPU 97 +#define CLKID_VAPB_0_SEL 99 +#define CLKID_VAPB_0 100 +#define CLKID_VAPB_1_SEL 102 +#define CLKID_VAPB_1 103 +#define CLKID_VAPB_SEL 104 +#define CLKID_VAPB 105 +#define CLKID_VCLK 106 +#define CLKID_VCLK2 107 +#define CLKID_VCLK_DIV1 122 +#define CLKID_VCLK_DIV2 123 +#define CLKID_VCLK_DIV4 124 +#define CLKID_VCLK_DIV6 125 +#define CLKID_VCLK_DIV12 126 +#define CLKID_VCLK2_DIV1 127 +#define CLKID_VCLK2_DIV2 128 +#define CLKID_VCLK2_DIV4 129 +#define CLKID_VCLK2_DIV6 130 +#define CLKID_VCLK2_DIV12 131 +#define CLKID_CTS_ENCL 133 +#define CLKID_VDIN_MEAS 136
#endif /* __AXG_CLKC_H */ diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index 40d49940d8..a93b58c5e1 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -147,5 +147,7 @@ #define CLKID_SPICC1_SCLK 261 #define CLKID_NNA_AXI_CLK 264 #define CLKID_NNA_CORE_CLK 267 +#define CLKID_MIPI_DSI_PXCLK_SEL 269 +#define CLKID_MIPI_DSI_PXCLK 270
#endif /* __G12A_CLKC_H */
Add support for the Meson G12A dwmac glue compatible needed after Linux 5.12 sync.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/net/dwmac_meson8b.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/dwmac_meson8b.c b/drivers/net/dwmac_meson8b.c index c0b6ef4994..069bf1724d 100644 --- a/drivers/net/dwmac_meson8b.c +++ b/drivers/net/dwmac_meson8b.c @@ -133,6 +133,7 @@ static int dwmac_meson8b_probe(struct udevice *dev)
static const struct udevice_id dwmac_meson8b_ids[] = { { .compatible = "amlogic,meson-gxbb-dwmac", .data = (ulong)dwmac_setup_gx }, + { .compatible = "amlogic,meson-g12a-dwmac", .data = (ulong)dwmac_setup_axg }, { .compatible = "amlogic,meson-axg-dwmac", .data = (ulong)dwmac_setup_axg }, { } };
On Wed, Apr 21, 2021 at 12:18 PM Neil Armstrong narmstrong@baylibre.com wrote:
2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
- { .compatible = "amlogic,meson-g12a-dwmac", .data = (ulong)dwmac_setup_axg }, { .compatible = "amlogic,meson-axg-dwmac", .data = (ulong)dwmac_setup_axg }, { }
Thanks,
Applied to u-boot-amlogic
Neil
Drop the local USB nodes after Linux 5.12 sync.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-axg-s400-u-boot.dtsi | 8 ---- arch/arm/dts/meson-axg-u-boot.dtsi | 62 ------------------------- 2 files changed, 70 deletions(-) delete mode 100644 arch/arm/dts/meson-axg-u-boot.dtsi
diff --git a/arch/arm/dts/meson-axg-s400-u-boot.dtsi b/arch/arm/dts/meson-axg-s400-u-boot.dtsi index 2c4b06f140..334650d610 100644 --- a/arch/arm/dts/meson-axg-s400-u-boot.dtsi +++ b/arch/arm/dts/meson-axg-s400-u-boot.dtsi @@ -3,8 +3,6 @@ * Copyright (c) 2017 Amlogic, Inc. All rights reserved. */
-#include "meson-axg-u-boot.dtsi" - /* wifi module */ &sd_emmc_b { status = "disabled"; @@ -15,12 +13,6 @@ status = "okay"; };
-&usb { - status = "okay"; - dr_mode = "otg"; - vbus-supply = <&usb_pwr>; -}; - &usb2_phy1 { phy-supply = <&vcc_5v>; }; diff --git a/arch/arm/dts/meson-axg-u-boot.dtsi b/arch/arm/dts/meson-axg-u-boot.dtsi deleted file mode 100644 index cb1c71e78c..0000000000 --- a/arch/arm/dts/meson-axg-u-boot.dtsi +++ /dev/null @@ -1,62 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/ { - soc { - usb: usb@ffe09080 { - compatible = "amlogic,meson-gxl-usb-ctrl"; - reg = <0x0 0xffe09080 0x0 0x20>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1_DDR_BRIDGE>; - clock-names = "usb_ctrl", "ddr"; - resets = <&reset RESET_USB_OTG>; - - dr_mode = "otg"; - - phys = <&usb2_phy1>; - phy-names = "usb2-phy1"; - - dwc2: usb@ff400000 { - compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; - reg = <0x0 0xff400000 0x0 0x40000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB1>; - clock-names = "otg"; - phys = <&usb2_phy1>; - dr_mode = "peripheral"; - g-rx-fifo-size = <192>; - g-np-tx-fifo-size = <128>; - g-tx-fifo-size = <128 128 16 16 16>; - }; - - dwc3: usb@ff500000 { - compatible = "snps,dwc3"; - reg = <0x0 0xff500000 0x0 0x100000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - dr_mode = "host"; - maximum-speed = "high-speed"; - snps,dis_u2_susphy_quirk; - }; - }; - }; -}; - -&apb { - usb2_phy1: phy@9020 { - compatible = "amlogic,meson-gxl-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0x9020 0x0 0x20>; - clocks = <&clkc CLKID_USB>; - clock-names = "phy"; - resets = <&reset RESET_USB_OTG>; - reset-names = "phy"; - status = "okay"; - }; -};
Add SCSI target to be able to boot from the SATA disks on the Odroid HC4 using an on-board AHCI PCIe controller.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Mark Kettenis kettenis@openbsd.org --- include/configs/meson64.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/meson64.h b/include/configs/meson64.h index 17ebccd2c4..d1539477a0 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -64,6 +64,12 @@ #define BOOT_TARGET_NVME(func) #endif
+#ifdef CONFIG_CMD_SCSI + #define BOOT_TARGET_SCSI(func) func(SCSI, scsi, 0) +#else + #define BOOT_TARGET_SCSI(func) +#endif + #ifndef BOOT_TARGET_DEVICES #define BOOT_TARGET_DEVICES(func) \ func(ROMUSB, romusb, na) \ @@ -72,6 +78,7 @@ func(MMC, mmc, 2) \ BOOT_TARGET_DEVICES_USB(func) \ BOOT_TARGET_NVME(func) \ + BOOT_TARGET_SCSI(func) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na) #endif
The SCSI device can be a PCIe adapter, so run pcie enum if enabled.
Signed-off-by: Mark Kettenis kettenis@openbsd.org Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- include/config_distro_bootcmd.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 2627c2a6a5..f4f6fa8f8a 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -226,6 +226,7 @@ "fi\0" \ \ "scsi_boot=" \ + BOOTENV_RUN_PCI_ENUM \ BOOTENV_RUN_SCSI_INIT \ BOOTENV_SHARED_BLKDEV_BODY(scsi) #define BOOTENV_DEV_SCSI BOOTENV_DEV_BLKDEV
The Odroid-HC4 is a variant of the Odroid-C4 board but with an PCIe-SATA bridge instead of the USB3 ports.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi | 23 +++++ configs/odroid-hc4_defconfig | 86 +++++++++++++++++++ 2 files changed, 109 insertions(+) create mode 100644 arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi create mode 100644 configs/odroid-hc4_defconfig
diff --git a/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi b/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi new file mode 100644 index 0000000000..963bf96b25 --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-sm1-u-boot.dtsi" + +ðmac { + snps,reset-gpio = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +}; + +/* SARADC is needed for proper board variant detection */ +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + +&tflash_vdd { + gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; +}; diff --git a/configs/odroid-hc4_defconfig b/configs/odroid-hc4_defconfig new file mode 100644 index 0000000000..12a1db0150 --- /dev/null +++ b/configs/odroid-hc4_defconfig @@ -0,0 +1,86 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="odroid-n2" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" odroid-hc4" +CONFIG_DEFAULT_DEVICE_TREE="meson-sm1-odroid-hc4" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_PCI=y +CONFIG_CMD_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MESON=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_AHCI=y +CONFIG_SATA=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y
Add documentation bits for the Odroid-HC4.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- doc/board/amlogic/index.rst | 2 +- doc/board/amlogic/odroid-c4.rst | 3 +++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/doc/board/amlogic/index.rst b/doc/board/amlogic/index.rst index 8da7afddb4..af12f94fde 100644 --- a/doc/board/amlogic/index.rst +++ b/doc/board/amlogic/index.rst @@ -18,7 +18,7 @@ This matrix concerns the actual source code version. | Boards | Odroid-C2 | P212 | Khadas VIM2 | S400 | U200 | Odroid-N2 | SEI610 | | | Nanopi-K2 | Khadas-VIM | Libretech-PC | | SEI510 | Khadas-VIM3 | Khadas-VIM3L | | | P200 | LibreTech-CC v1 | WeTek Core2 | | | GT-King/Pro | Odroid-C4 | -| | P201 | LibreTech-AC v2 | | | | | | +| | P201 | LibreTech-AC v2 | | | | | Odroid-HC4 | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ | UART | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ diff --git a/doc/board/amlogic/odroid-c4.rst b/doc/board/amlogic/odroid-c4.rst index 5a5a8688b8..f66d60a54d 100644 --- a/doc/board/amlogic/odroid-c4.rst +++ b/doc/board/amlogic/odroid-c4.rst @@ -17,6 +17,9 @@ Co. Ltd with the following specifications: - UART serial - Infrared receiver
+The ODROID-HC4 is a variant with a PCIe-SATA controller, the same commands +applies for HC4. + Schematics are available on the manufacturer website.
U-Boot compilation
The Beelink GS-King X is a variant of the GS King boards but with an internal USB to SATA bridge and advanced audio features.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi | 7 ++ configs/beelink-gsking-x_defconfig | 72 ++++++++++++++++++++ 2 files changed, 79 insertions(+) create mode 100644 arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi create mode 100644 configs/beelink-gsking-x_defconfig
diff --git a/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi b/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi new file mode 100644 index 0000000000..236f2468dc --- /dev/null +++ b/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-g12-common-u-boot.dtsi" diff --git a/configs/beelink-gsking-x_defconfig b/configs/beelink-gsking-x_defconfig new file mode 100644 index 0000000000..ec9079d960 --- /dev/null +++ b/configs/beelink-gsking-x_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="beelink-s922x" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" beelink" +CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-gsking-x" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_OF_LIBFDT_OVERLAY=y
Neil Armstrong
Ramon Fried
