[U-Boot-Users] Problem about porting u-boot 1.1.4 to MPC8560
Hi, After prog u-boot image to 8560. We get output as follows:
U-Boot 1.1.4 (Sep 4 2006 - 17:15:31)
CPU: 8560, Version: 1.0, (0x80700010) Core: E500, Version: Clock Configuration:- 19:56:59) CPU: 825 MHz, CCB: 330 MHz,, Version: 1.0, (0x80700010) DDR: 165 MHz, LBC: 82 MHzCore: E500, Version: 1.0, (0x802 L1: D-cache 32 kB enabled Clock Confi I-cache 32 kB enabled CPU: 792 MHz, CCB: 2 Board: ADS PCI1: 32 bit, 33 MHz (compiled) MHz, LBC: 66 MHz I2C: ready L1: D DRAM: Initializing 32 kB enabled DDR: number of ranks = 1: ADS PCI1 DDR: DDR I rank density = 0x10000000 I2C: rea
DDR: cs0_bnds = 0x0000000fzing DDR: DDR: cs0_config = 0x80000102 DDR: DDR I r DDR: caslat SPD bit is 4 DDR: tCKmin = 5000 psbnds = 0x00000007 DDR: sdram_mode_2 = 0x00000000 DDR: sdram_interval = 0x05080100 DDR: sdram_cfg_2 = 0x00000000 DDR: sdram_cfg = 0xc2000000 DDR: MAS0=0x10080000 DDR: MAS1=0xc0000900 DDR: MAS2=0x00000000 DDR: MAS3=0x00000015 DDR: LAWBAR1=0x00000000 DDR: LARAR1=0x80f0001b SDRAM: 64 MB DDR: 256 MB Top of RAM usable for U-Boot at: 10000000 Reserving 173k for U-Boot at: 0ffd0000 Reserving 136k for malloc() at: 0ffae000 Reserving 88 Bytes for Board Info at: 0ffadfa8 Reserving 72 Bytes for Global Data at: 0ffadf60 Stack Pointer at: 0ffadf48
then it can't go on running. we checked ,found it falled in "relocate_code" ,then we write a progam to test memory, we found test failed(say write some thing to 0-0x8000000 then read)
How can we do to fix this problem?
So you obviously have either some hardware problem with your RAM, and/or bugs in your RAM init code.
Review the hardware and your chnages to the code.
we can see from the out put, u-boot can recognize the frequence of the momery, and more info. through spd.
we use MT9VDDT1672AG first, then, KVR400X64C3A, both can't work.
----- Original Message ----- From: "Wolfgang Denk" wd@denx.de To: "enorm" enorm@126.com Cc: u-boot-users@lists.sourceforge.net Sent: Monday, September 04, 2006 8:31 PM Subject: Re: [U-Boot-Users] Problem about porting u-boot 1.1.4 to MPC8560
Did you verify that the information is correct for your hardware? Did you verify that the remaining parts of the init sequence are ok for your hardware? Did you verify that your hardware is OK?
Yes, that's what I meant when I wrote "review the hardware and your changes to the code."
And please stop top posting/full quoting; please see http://www.netmeister.org/news/learn2quote.html
With my recent port for the 8560 for our custom board we found that the 8560 does not work properly with some makes of DDR modules. Have you tried some different RAM with your board?
Tell us a bit more about your RAM
Looks like the RAM is not set-up correctly at all - you will need to go through the settings using the RAM data sheet and the 8560RM book. Make sure the settings being derived by "spd_eeprom" are what you expect.
Also when you get it working with your RAM test you may still get problems with your OS. We ended up having to hand pick RAM for this processor with our board. I would be interested in seeing how you get on.
We have moved on to the the 8548 for our B-Model and I have had to make changes to "spd_eeprom.c" to accommodate our RAM. I am hoping to provide this back as a patch when I am sure it works OK with our OS (QNX).
Steve Williams
enorm
Steve Williams
