[U-Boot] [PATCH 1/1] usb: musb-new: sunxi: Fix null pointer access
When the device is in peripheral mode there is no struct usb_bus_priv allocated pointer, as the uclass driver ("usb_dev_generic") doesn't call per_device_auto_alloc_size.
This results in writing to the internal SDRAM at priv->desc_before_addr = true;
Signed-off-by: Stefan Mavrodiev stefan@olimex.com --- drivers/usb/musb-new/sunxi.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 6cf9826cda..f3deb9bc66 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -435,11 +435,14 @@ static int musb_usb_probe(struct udevice *dev) { struct sunxi_glue *glue = dev_get_priv(dev); struct musb_host_data *host = &glue->mdata; - struct usb_bus_priv *priv = dev_get_uclass_priv(dev); struct musb_hdrc_platform_data pdata; void *base = dev_read_addr_ptr(dev); int ret;
+#ifdef CONFIG_USB_MUSB_HOST + struct usb_bus_priv *priv = dev_get_uclass_priv(dev); +#endif + if (!base) return -EINVAL;
@@ -459,7 +462,6 @@ static int musb_usb_probe(struct udevice *dev) return ret; }
- priv->desc_before_addr = true;
memset(&pdata, 0, sizeof(pdata)); pdata.power = 250; @@ -467,6 +469,8 @@ static int musb_usb_probe(struct udevice *dev) pdata.config = glue->cfg->config;
#ifdef CONFIG_USB_MUSB_HOST + priv->desc_before_addr = true; + pdata.mode = MUSB_HOST; host->host = musb_init_controller(&pdata, &glue->dev, base); if (!host->host)
Can you have two devices, one in peripheral mode and one in host mode, on the same system ?
- if (!base) return -EINVAL;
See my question at the beginning, and if that can be the case, the fix is to check if priv is not null here, eg. if (priv) priv->...
Still, why is the priv data not allocated for device ?
- pdata.mode = MUSB_HOST; host->host = musb_init_controller(&pdata, &glue->dev, base); if (!host->host)
Not 100% sure, but I'm thinking there is only one OTG port for all sunxi boards. The operation is decided in the Kconfig.
Depending on configuration, the device is registered ether as UCLASS_USB_DEV_GENERIC or UCLASS_USB. There is no
.per_device_auto_alloc_size = sizeof(struct usb_bus_priv),
for the second. (As seen in drivers/usb/host/usb-uclass.c)
I'm rather sure I saw sunxi boards with more than one USB port.
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 6cf9826cda..f3deb9bc66 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -435,11 +435,14 @@ static int musb_usb_probe(struct udevice *dev) { struct sunxi_glue *glue = dev_get_priv(dev); struct musb_host_data *host = &glue->mdata; - struct usb_bus_priv *priv = dev_get_uclass_priv(dev); struct musb_hdrc_platform_data pdata; void *base = dev_read_addr_ptr(dev); int ret; +#ifdef CONFIG_USB_MUSB_HOST + struct usb_bus_priv *priv = dev_get_uclass_priv(dev); +#endif
if (!base) return -EINVAL; @@ -459,7 +462,6 @@ static int musb_usb_probe(struct udevice *dev) return ret; } - priv->desc_before_addr = true;
I see the code is rather horrible. I'd expect all that configuration to come from DT otg-mode property instead of being hard-wired into the code. Sigh.
Jagan, A-B ? I'd like to pick this .
memset(&pdata, 0, sizeof(pdata)); pdata.power = 250; @@ -467,6 +469,8 @@ static int musb_usb_probe(struct udevice *dev) pdata.config = glue->cfg->config; #ifdef CONFIG_USB_MUSB_HOST + priv->desc_before_addr = true;
Any further comments?
As Jagan is inactive, applied.
@@ -459,7 +462,6 @@ static int musb_usb_probe(struct udevice *dev) return ret; }if (!base) return -EINVAL;
Sorry, I was in travel in multiple locations couldn't find this patch. Thanks for applying on your side.
No, or at least, on all of the SoCs that Allwinner ever produced, there's only a single musb controller.
Maxime
It is possible with the musb-new. Using DM_USB and DM_USB_GADGET, I did it with on a beaglebone black.
JJ
Does this patch break it ? And if so, can you send a proper fix ?
JJ
This file is not compiled when building for beaglebone, so it won't break anything.
BTW this driver could be adapted, with little work, to support a dynamic selection of the role based on "dr-mode" in the DT.
Not knowing the boards, I don't know if this work has any added value though.
JJ
JJ
Ah, sunxi, right.
It would, as it would remove ifdeffery.
participants (5)
Jagan Teki
Jean-Jacques Hiblot
Maxime Ripard
Stefan Mavrodiev
