[U-Boot] [PATCH v3] Add a simple script to remove boards
This script attempts to create a git commit which removes a single board. It is quite fallible and everything it does needs checking. But it can help speed up the process.
Changes in v3: - Move this into its own separate patch - Fix typos
tools/rmboard.py | 150 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 150 insertions(+) create mode 100755 tools/rmboard.py
diff --git a/tools/rmboard.py b/tools/rmboard.py new file mode 100755 index 00000000000..df4f04b01c5 --- /dev/null +++ b/tools/rmboard.py @@ -0,0 +1,150 @@ +#! /usr/bin/python +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2019 Google LLC +# + +""" +Script to remove boards + +Usage: + rmboard.py <board_name>... + +A single commit is created for each board removed. + +Some boards may depend on files provided by another and this will cause +problems, generally the removal of files which should not be removed. + +This script works by: + - Looking through the MAINTAINERS files which mention a board to find out + what files the board uses + - Looking through the Kconfig files which mention a board to find one that + needs to have material removed + +Search for ## to update the commit message manually. +""" + +from __future__ import print_function + +import glob +import os +import re +import sys + +# Bring in the patman libraries +our_path = os.path.dirname(os.path.realpath(__file__)) +sys.path.append(os.path.join(our_path, '../tools/patman')) + +import command + +def rm_kconfig_include(path): + """Remove a path from Kconfig files + + This function finds the given path in a 'source' statement in a Kconfig + file and removes that line from the file. This is needed because the path + is going to be removed, so any reference to it will cause a problem with + Kconfig parsing. + + The changes are made locally and then added to the git staging area. + + Args: + path: Path to search for and remove + """ + cmd = ['git', 'grep', path] + stdout = command.RunPipe([cmd], capture=True, raise_on_error=False).stdout + if not stdout: + return + fname = stdout.split(':')[0] + + print("Fixing up '%s' to remove reference to '%s'" % (fname, path)) + cmd = ['sed', '-i', '|%s|d' % path, fname] + stdout = command.RunPipe([cmd], capture=True).stdout + + cmd = ['git', 'add', fname] + stdout = command.RunPipe([cmd], capture=True).stdout + +def rm_board(board): + """Create a commit which removes a single board + + This looks up the MAINTAINERS file to file files that need to be removed, + then removes pieces from the Kconfig files that mention the board. + + + Args: + board: Board name to remove + """ + + # Find all MAINTAINERS and Kconfig files which mention the board + cmd = ['git', 'grep', '-l', board] + stdout = command.RunPipe([cmd], capture=True).stdout + maintain = [] + kconfig = [] + for line in stdout.splitlines(): + line = line.strip() + if 'MAINTAINERS' in line: + if line not in maintain: + maintain.append(line) + elif 'Kconfig' in line: + kconfig.append(line) + paths = [] + cc = [] + + # Look through the MAINTAINERS file to find things to remove + for fname in maintain: + with open(fname) as fd: + for line in fd: + line = line.strip() + fields = re.split('[ \t]', line, 1) + if len(fields) == 2: + if fields[0] == 'M:': + cc.append(fields[1]) + elif fields[0] == 'F:': + paths.append(fields[1].strip()) + + # Expand any wildcards in the MAINTAINERS file + real = [] + for path in paths: + if path[-1] == '/': + path = path[:-1] + if '*' in path: + globbed = glob.glob(path) + print("Expanded '%s' to '%s'" % (path, globbed)) + real += globbed + else: + real.append(path) + + # Search for Kconfig files in the resulting list. Remove any 'source' lines + # which reference Kconfig files we want to remove + for path in real: + cmd = ['find', path] + stdout = (command.RunPipe([cmd], capture=True, raise_on_error=False). + stdout) + for fname in stdout.splitlines(): + if fname.endswith('Kconfig'): + rm_kconfig_include(fname) + + # Remove unwanted files + cmd = ['git', 'rm', '-r'] + real + stdout = command.RunPipe([cmd], capture=True).stdout + + ## Change the messages as needed + msg = '''arm: Remove %s board + +This board has not been converted to CONFIG_DM_MMC by the deadline. +Remove it. + +''' % board + for name in cc: + msg += 'Patch-cc: %s\n' % name + + # Create the commit + cmd = ['git', 'commit', '-s', '-m', msg] + stdout = command.RunPipe([cmd], capture=True).stdout + + # Check if the board is mentioned anywhere else. The user will need to deal + # with this + cmd = ['git', 'grep', '-il', board] + print(command.RunPipe([cmd], capture=True, raise_on_error=False).stdout) + print(' '.join(cmd)) + +for board in sys.argv[1:]: + rm_board(board)
Reviewed-by: Chris Packham judge.packham@gmail.com
Changes in v3:
- Fix typos
+Usage:
- rmboard.py <board_name>...
out
that
+import command
- """Remove a path from Kconfig files
- This function finds the given path in a 'source' statement in a
Kconfig
- file and removes that line from the file. This is needed because the
path
- is going to be removed, so any reference to it will cause a problem
with
- Kconfig parsing.
- The changes are made locally and then added to the git staging area.
- Args:
- cmd = ['git', 'grep', path]
- stdout = command.RunPipe([cmd], capture=True,
- if not stdout:
return
- fname = stdout.split(':')[0]
- print("Fixing up '%s' to remove reference to '%s'" % (fname, path))
- cmd = ['sed', '-i', '|%s|d' % path, fname]
- stdout = command.RunPipe([cmd], capture=True).stdout
- cmd = ['git', 'add', fname]
- """Create a commit which removes a single board
- This looks up the MAINTAINERS file to file files that need to be
removed,
- then removes pieces from the Kconfig files that mention the board.
- Args:
- # Find all MAINTAINERS and Kconfig files which mention the board
- cmd = ['git', 'grep', '-l', board]
- maintain = []
- kconfig = []
- for line in stdout.splitlines():
line = line.strip()
- paths = []
- cc = []
- # Look through the MAINTAINERS file to find things to remove
- for fname in maintain:
for line in fd:
line = line.strip()
- # Expand any wildcards in the MAINTAINERS file
- real = []
- for path in paths:
if path[-1] == '/':
path = path[:-1]
if '*' in path:
real += globbed
else:
real.append(path)
- # Search for Kconfig files in the resulting list. Remove any 'source'
lines
- # which reference Kconfig files we want to remove
- for path in real:
stdout)
- # Remove unwanted files
- cmd = ['git', 'rm', '-r'] + real
- ## Change the messages as needed
- msg = '''arm: Remove %s board
+''' % board
- for name in cc:
- # Create the commit
- cmd = ['git', 'commit', '-s', '-m', msg]
- # Check if the board is mentioned anywhere else. The user will need
to deal
- # with this
- cmd = ['git', 'grep', '-il', board]
- print(command.RunPipe([cmd], capture=True,
- print(' '.join(cmd))
- rm_board(board)
-- 2.21.0.1020.gf2820cf01a-goog
Applied to u-boot-dm/next
Chris Packham
