[U-Boot-Users] Updated libfdt branch
Please pull from 'libfdt' branch of
git.kernel.org:/pub/scm/boot/u-boot/galak/u-boot.git libfdt
This is just a resync with 1.3.0-rc4+ and the latest dtc commits
to receive the following updates:
board/cm5200/cm5200.c | 2 board/freescale/mpc832xemds/pci.c | 2 board/freescale/mpc8349emds/pci.c | 4 board/freescale/mpc8349itx/pci.c | 4 board/freescale/mpc8360emds/pci.c | 2 common/cmd_fdt.c | 28 - common/fdt_support.c | 82 +++- cpu/mpc5xxx/cpu.c | 40 -- cpu/mpc8260/cpu.c | 30 - cpu/mpc83xx/cpu.c | 4 cpu/mpc83xx/pci.c | 4 include/fdt.h | 51 -- include/fdt_support.h | 4 include/libfdt.h | 688 ++++++++++++++++++++++++++++++++--- libfdt/fdt.c | 97 ++++- libfdt/fdt_ro.c | 732 ++++++++++++++++++++------------------ libfdt/fdt_rw.c | 266 ++++++++++--- libfdt/fdt_strerror.c | 54 ++ libfdt/fdt_sw.c | 92 +++- libfdt/fdt_wip.c | 89 ++-- libfdt/libfdt_internal.h | 81 +++- 21 files changed, 1643 insertions(+), 713 deletions(-)
Kumar Gala (4): Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdt Make no options to fdt print default to '/' Move do_fixup* for libfdt into common code Update libfdt from device tree compiler (dtc)
Hi Kumar,
Thanks, will do.
Now that WD has done a "final call" for 1.3.0, I'm going to lose my excuse for procrastinating...
Best regards, gvb
On Nov 19, 2007, at 9:29 AM, Jerry Van Baren wrote:
Kumar Gala wrote:
Please pull from 'libfdt' branch of git.kernel.org:/pub/scm/boot/u-boot/galak/u-boot.git libfdt This is just a resync with 1.3.0-rc4+ and the latest dtc commits to receive the following updates: board/cm5200/cm5200.c | 2 board/freescale/mpc832xemds/pci.c | 2 board/freescale/mpc8349emds/pci.c | 4 board/freescale/mpc8349itx/pci.c | 4 board/freescale/mpc8360emds/pci.c | 2 common/cmd_fdt.c | 28 - common/fdt_support.c | 82 +++- cpu/mpc5xxx/cpu.c | 40 -- cpu/mpc8260/cpu.c | 30 - cpu/mpc83xx/cpu.c | 4 cpu/mpc83xx/pci.c | 4 include/fdt.h | 51 -- include/fdt_support.h | 4 include/libfdt.h | 688 +++++++++++++++++++++++++++ +++++--- libfdt/fdt.c | 97 ++++- libfdt/fdt_ro.c | 732 +++++++++++++++++++ +------------------ libfdt/fdt_rw.c | 266 ++++++++++--- libfdt/fdt_strerror.c | 54 ++ libfdt/fdt_sw.c | 92 +++- libfdt/fdt_wip.c | 89 ++-- libfdt/libfdt_internal.h | 81 +++- 21 files changed, 1643 insertions(+), 713 deletions(-) Kumar Gala (4): Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdt Make no options to fdt print default to '/' Move do_fixup* for libfdt into common code Update libfdt from device tree compiler (dtc)
Hi Kumar,
Thanks, will do.
I figured as much and guessing we also need the "add common memory fixup function" patch.
I'm going to try and start playing with the alias idea that I brought up before for handling some of the fix ups for ethernet and serial and see what we need beyond that.
- k
In message Pine.LNX.4.64.0711190913540.20824@blarg.am.freescale.net you wrote:
Just for the record:
I ignored this pull request, and I will continue to ignore similar requests. libfdt updates have to go through the FDT custodian (which you are not).
Posting such requests is confusing to me, so please don't do this.
Jerry Van Baren
Kumar Gala
