[PATCH v11 0/8] tpm: Support boot measurements
This series adds support for measuring the boot images more generically than the existing EFI support. Several EFI functions have been moved to the TPM layer. The series includes optional measurement from the bootm command. A new test case has been added for the bootm measurement to test the new path, and the sandbox TPM2 driver has been updated to support this use case.
Changes since v10: - Fix commit message on efi_loader change - Drop python test change - Squash armv7 fix from Ilias
Changes since v9: - Rebase and add Ilias' fixes (thanks!)
Changes since v8: - Fix a sandbox driver off-by-one error in checking the property type. - Fix log parsing again - any data corruption seen while replaying the event log was failing the entire measurement. - Added an option to ignore the existing log and a configuration option for systems to select that for the bootm measurement. This would only be selected for systems that know that U-Boot is the first stage bootloader. This is necessary because the reserved memory region may persist through resets and so U-Boot attempts to append to the previous boot's log.
Changes since v7: - Change name of tcg2_init_log and add more documentation - Add a check, when parsing the event log header, to ensure that the previous stage bootloader used all the active PCRs. - Change name of tcg2_log_find_end - Fix the greater than or equal to check to exit the log parsing - Make sure log_position is 0 if there is any error discovering the log - Return errors parsing the log if the data is corrupt so that we don't end up with half a log
Changes since v6: - Added comment for bootm_measure - Fixed line length in bootm_measure - Added Linaro copyright for all the EFI moved code - Changed tcg2_init_log (and by extension, tcg2_measurement_init) to copy any discovered event log to the user's log if passed in.
Changes since v5: - Re-ordered the patches to put the sandbox TPM driver patch second - Remove unused platform_get_eventlog in efi_tcg2.c - First look for tpm_event_log_* properties instead of linux,sml-* - Fix efi_tcg2.c compilation - Select SHA* configs - Remove the !SANDBOX dependency for EFI TCG2 - Only compile in the measurement u-boot command when CONFIG_MEASURED_BOOT is enabled
Changes since v4: - Remove tcg2_measure_event function and check for NULL data in tcg2_measure_data - Use tpm_auto_startup - Fix efi_tcg2.c compilation for removing tcg2_pcr_read function - Change PCR indexes for initrd and dtb - Drop u8 casting in measurement test - Use bullets in documentation
Changes since v3: - Reordered headers - Refactored more of EFI code into common code Removed digest_info structure and instead used the common alg_to_mask and alg_to_len Improved event log parsing in common code to get it equivalent to EFI Common code now extends PCR if previous bootloader stage couldn't No need to allocate memory in the common code, so EFI copies the discovered buffer like it did before Rename efi measure_event function
Changes since v2: - Add documentation. - Changed reserved memory address to the top of the RAM for sandbox dts. - Add measure state to booti and bootz. - Skip measurement for EFI images that should be measured
Changes since v1: - Refactor TPM layer functions to allow EFI system to use them, and remove duplicate EFI functions. - Add test case - Drop #ifdefs for bootm - Add devicetree measurement config option - Update sandbox TPM driver
Eddie James (6): tpm: Fix spelling for tpmu_ha union tpm: sandbox: Update for needed TPM2 capabilities tpm: Support boot measurements bootm: Support boot measurement test: Add sandbox TPM boot measurement doc: Add measured boot documentation
Ilias Apalodimas (2): efi_loader: fix EFI_ENTRY point on get_active_pcr_banks test: use a non system PCR for testing PCR extend
arch/sandbox/dts/sandbox.dtsi | 13 + arch/sandbox/dts/test.dts | 13 + boot/Kconfig | 32 + boot/bootm.c | 74 +++ cmd/booti.c | 1 + cmd/bootm.c | 2 + cmd/bootz.c | 1 + configs/sandbox_defconfig | 1 + doc/usage/index.rst | 1 + doc/usage/measured_boot.rst | 23 + drivers/tpm/tpm2_tis_sandbox.c | 100 ++- include/bootm.h | 11 + include/efi_tcg2.h | 44 -- include/image.h | 1 + include/test/suites.h | 1 + include/tpm-v2.h | 263 +++++++- lib/Kconfig | 4 + lib/efi_loader/Kconfig | 2 - lib/efi_loader/efi_tcg2.c | 1056 +++----------------------------- lib/tpm-v2.c | 814 ++++++++++++++++++++++++ test/boot/Makefile | 1 + test/boot/measurement.c | 66 ++ test/cmd_ut.c | 4 + test/py/tests/test_tpm2.py | 16 +- 24 files changed, 1482 insertions(+), 1062 deletions(-) create mode 100644 doc/usage/measured_boot.rst create mode 100644 test/boot/measurement.c
tmpu -> tpmu
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/tpm-v2.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 2b6980e441..6684033deb 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -169,7 +169,7 @@ struct tcg_pcr_event { /** * Definition of TPMU_HA Union */ -union tmpu_ha { +union tpmu_ha { u8 sha1[TPM2_SHA1_DIGEST_SIZE]; u8 sha256[TPM2_SHA256_DIGEST_SIZE]; u8 sm3_256[TPM2_SM3_256_DIGEST_SIZE]; @@ -185,7 +185,7 @@ union tmpu_ha { */ struct tpmt_ha { u16 hash_alg; - union tmpu_ha digest; + union tpmu_ha digest; } __packed;
The driver needs to support getting the PCRs in the capabilities command. Fix various other things and support the max number of PCRs for TPM2. Remove the !SANDBOX dependency for EFI TCG2 as well.
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v8: - Use >= for checking the property against TPM2_PROPERTIES_OFFSET
Changes since v5: - Remove the !SANDBOX dependency for EFI TCG2
drivers/tpm/tpm2_tis_sandbox.c | 100 ++++++++++++++++++++++++--------- lib/efi_loader/Kconfig | 2 - 2 files changed, 72 insertions(+), 30 deletions(-)
diff --git a/drivers/tpm/tpm2_tis_sandbox.c b/drivers/tpm/tpm2_tis_sandbox.c index e4004cfcca..d15a28d9fc 100644 --- a/drivers/tpm/tpm2_tis_sandbox.c +++ b/drivers/tpm/tpm2_tis_sandbox.c @@ -22,11 +22,6 @@ enum tpm2_hierarchy { TPM2_HIERARCHY_NB, };
-/* Subset of supported capabilities */ -enum tpm2_capability { - TPM_CAP_TPM_PROPERTIES = 0x6, -}; - /* Subset of supported properties */ #define TPM2_PROPERTIES_OFFSET 0x0000020E
@@ -38,7 +33,8 @@ enum tpm2_cap_tpm_property { TPM2_PROPERTY_NB, };
-#define SANDBOX_TPM_PCR_NB 1 +#define SANDBOX_TPM_PCR_NB TPM2_MAX_PCRS +#define SANDBOX_TPM_PCR_SELECT_MAX ((SANDBOX_TPM_PCR_NB + 7) / 8)
/* * Information about our TPM emulation. This is preserved in the sandbox @@ -433,7 +429,7 @@ static int sandbox_tpm2_xfer(struct udevice *dev, const u8 *sendbuf, int i, j;
/* TPM2_GetProperty */ - u32 capability, property, property_count; + u32 capability, property, property_count, val;
/* TPM2_PCR_Read/Extend variables */ int pcr_index = 0; @@ -542,19 +538,32 @@ static int sandbox_tpm2_xfer(struct udevice *dev, const u8 *sendbuf, case TPM2_CC_GET_CAPABILITY: capability = get_unaligned_be32(sent); sent += sizeof(capability); - if (capability != TPM_CAP_TPM_PROPERTIES) { - printf("Sandbox TPM only support TPM_CAPABILITIES\n"); - return TPM2_RC_HANDLE; - } - property = get_unaligned_be32(sent); sent += sizeof(property); - property -= TPM2_PROPERTIES_OFFSET; - property_count = get_unaligned_be32(sent); sent += sizeof(property_count); - if (!property_count || - property + property_count > TPM2_PROPERTY_NB) { + + switch (capability) { + case TPM2_CAP_PCRS: + break; + case TPM2_CAP_TPM_PROPERTIES: + if (!property_count) { + rc = TPM2_RC_HANDLE; + return sandbox_tpm2_fill_buf(recv, recv_len, + tag, rc); + } + + if (property >= TPM2_PROPERTIES_OFFSET && + ((property - TPM2_PROPERTIES_OFFSET) + + property_count > TPM2_PROPERTY_NB)) { + rc = TPM2_RC_HANDLE; + return sandbox_tpm2_fill_buf(recv, recv_len, + tag, rc); + } + break; + default: + printf("Sandbox TPM2 only supports TPM2_CAP_PCRS or " + "TPM2_CAP_TPM_PROPERTIES\n"); rc = TPM2_RC_HANDLE; return sandbox_tpm2_fill_buf(recv, recv_len, tag, rc); } @@ -578,18 +587,53 @@ static int sandbox_tpm2_xfer(struct udevice *dev, const u8 *sendbuf, put_unaligned_be32(capability, recv); recv += sizeof(capability);
- /* Give the number of properties that follow */ - put_unaligned_be32(property_count, recv); - recv += sizeof(property_count); - - /* Fill with the properties */ - for (i = 0; i < property_count; i++) { - put_unaligned_be32(TPM2_PROPERTIES_OFFSET + property + - i, recv); - recv += sizeof(property); - put_unaligned_be32(tpm->properties[property + i], - recv); - recv += sizeof(property); + switch (capability) { + case TPM2_CAP_PCRS: + /* Give the number of algorithms supported - just SHA256 */ + put_unaligned_be32(1, recv); + recv += sizeof(u32); + + /* Give SHA256 algorithm */ + put_unaligned_be16(TPM2_ALG_SHA256, recv); + recv += sizeof(u16); + + /* Select the PCRs supported */ + *recv = SANDBOX_TPM_PCR_SELECT_MAX; + recv++; + + /* Activate all the PCR bits */ + for (i = 0; i < SANDBOX_TPM_PCR_SELECT_MAX; ++i) { + *recv = 0xff; + recv++; + } + break; + case TPM2_CAP_TPM_PROPERTIES: + /* Give the number of properties that follow */ + put_unaligned_be32(property_count, recv); + recv += sizeof(property_count); + + /* Fill with the properties */ + for (i = 0; i < property_count; i++) { + put_unaligned_be32(property + i, recv); + recv += sizeof(property); + if (property >= TPM2_PROPERTIES_OFFSET) { + val = tpm->properties[(property - + TPM2_PROPERTIES_OFFSET) + i]; + } else { + switch (property) { + case TPM2_PT_PCR_COUNT: + val = SANDBOX_TPM_PCR_NB; + break; + default: + val = 0xffffffff; + break; + } + } + + put_unaligned_be32(val, recv); + recv += sizeof(property); + } + break; }
/* Add trailing \0 */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index c5835e6ef6..605719d2b6 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -333,8 +333,6 @@ config EFI_TCG2_PROTOCOL bool "EFI_TCG2_PROTOCOL support" default y depends on TPM_V2 - # Sandbox TPM currently fails on GetCapabilities needed for TCG2 - depends on !SANDBOX select SHA1 select SHA256 select SHA384
Add TPM2 functions to support boot measurement. This includes starting up the TPM, initializing/appending the event log, and measuring the U-Boot version. Much of the code was used in the EFI subsystem, so remove it there and use the common functions.
Signed-off-by: Eddie James eajames@linux.ibm.com --- Changes since v10: - Fix compile warning for armv7 (thanks Ilias)
Changes since v8: - Fix log parsing again - any data corruption seen while replaying the event log was failing the entire measurement. - Added an option to ignore the existing log. This should only be used for systems that know that U-Boot is the first stage bootloader. This is necessary because the reserved memory region may persist through resets and so U-Boot attempts to append to the previous boot's log.
Changes since v6: - Added Linaro copyright for all the EFI moved code - Changed tcg2_init_log (and by extension, tcg2_measurement_init) to copy any discovered event log to the user's log if passed in.
Changes since v5: - Remove unused platform_get_eventlog in efi_tcg2.c - First look for tpm_event_log_* properties instead of linux,sml-* - Fix efi_tcg2.c compilation - Select SHA* configs
include/efi_tcg2.h | 44 -- include/tpm-v2.h | 259 +++++++++ lib/Kconfig | 4 + lib/efi_loader/efi_tcg2.c | 1054 +++---------------------------------- lib/tpm-v2.c | 814 ++++++++++++++++++++++++++++ 5 files changed, 1154 insertions(+), 1021 deletions(-)
diff --git a/include/efi_tcg2.h b/include/efi_tcg2.h index b1c3abd097..b21c5cb3dd 100644 --- a/include/efi_tcg2.h +++ b/include/efi_tcg2.h @@ -129,50 +129,6 @@ struct efi_tcg2_boot_service_capability { #define BOOT_SERVICE_CAPABILITY_MIN \ offsetof(struct efi_tcg2_boot_service_capability, number_of_pcr_banks)
-#define TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03 "Spec ID Event03" -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2 2 -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 0 -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2 2 - -/** - * struct TCG_EfiSpecIdEventAlgorithmSize - hashing algorithm information - * - * @algorithm_id: algorithm defined in enum tpm2_algorithms - * @digest_size: size of the algorithm - */ -struct tcg_efi_spec_id_event_algorithm_size { - u16 algorithm_id; - u16 digest_size; -} __packed; - -/** - * struct TCG_EfiSpecIDEventStruct - content of the event log header - * - * @signature: signature, set to Spec ID Event03 - * @platform_class: class defined in TCG ACPI Specification - * Client Common Header. - * @spec_version_minor: minor version - * @spec_version_major: major version - * @spec_version_errata: major version - * @uintn_size: size of the efi_uintn_t fields used in various - * data structures used in this specification. - * 0x01 indicates u32 and 0x02 indicates u64 - * @number_of_algorithms: hashing algorithms used in this event log - * @digest_sizes: array of number_of_algorithms pairs - * 1st member defines the algorithm id - * 2nd member defines the algorithm size - */ -struct tcg_efi_spec_id_event { - u8 signature[16]; - u32 platform_class; - u8 spec_version_minor; - u8 spec_version_major; - u8 spec_errata; - u8 uintn_size; - u32 number_of_algorithms; - struct tcg_efi_spec_id_event_algorithm_size digest_sizes[]; -} __packed; - /** * struct tdEFI_TCG2_FINAL_EVENTS_TABLE - log entries after Get Event Log * @version: version number for this structure diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 6684033deb..33dd103767 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -216,6 +216,50 @@ struct tcg_pcr_event2 { u8 event[]; } __packed;
+/** + * struct TCG_EfiSpecIdEventAlgorithmSize - hashing algorithm information + * + * @algorithm_id: algorithm defined in enum tpm2_algorithms + * @digest_size: size of the algorithm + */ +struct tcg_efi_spec_id_event_algorithm_size { + u16 algorithm_id; + u16 digest_size; +} __packed; + +#define TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03 "Spec ID Event03" +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2 2 +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 0 +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2 2 + +/** + * struct TCG_EfiSpecIDEventStruct - content of the event log header + * + * @signature: signature, set to Spec ID Event03 + * @platform_class: class defined in TCG ACPI Specification + * Client Common Header. + * @spec_version_minor: minor version + * @spec_version_major: major version + * @spec_version_errata: major version + * @uintn_size: size of the efi_uintn_t fields used in various + * data structures used in this specification. + * 0x01 indicates u32 and 0x02 indicates u64 + * @number_of_algorithms: hashing algorithms used in this event log + * @digest_sizes: array of number_of_algorithms pairs + * 1st member defines the algorithm id + * 2nd member defines the algorithm size + */ +struct tcg_efi_spec_id_event { + u8 signature[16]; + u32 platform_class; + u8 spec_version_minor; + u8 spec_version_major; + u8 spec_errata; + u8 uintn_size; + u32 number_of_algorithms; + struct tcg_efi_spec_id_event_algorithm_size digest_sizes[]; +} __packed; + /** * TPM2 Structure Tags for command/response buffers. * @@ -342,6 +386,26 @@ enum tpm2_algorithms { TPM2_ALG_SM3_256 = 0x12, };
+extern const enum tpm2_algorithms tpm2_supported_algorithms[4]; + +static inline u16 tpm2_algorithm_to_len(enum tpm2_algorithms a) +{ + switch (a) { + case TPM2_ALG_SHA1: + return TPM2_SHA1_DIGEST_SIZE; + case TPM2_ALG_SHA256: + return TPM2_SHA256_DIGEST_SIZE; + case TPM2_ALG_SHA384: + return TPM2_SHA384_DIGEST_SIZE; + case TPM2_ALG_SHA512: + return TPM2_SHA512_DIGEST_SIZE; + default: + return 0; + } +} + +#define tpm2_algorithm_to_mask(a) (1 << (a)) + /* NV index attributes */ enum tpm_index_attrs { TPMA_NV_PPWRITE = 1UL << 0, @@ -421,6 +485,188 @@ enum { HR_NV_INDEX = TPM_HT_NV_INDEX << HR_SHIFT, };
+/** + * struct tcg2_event_log - Container for managing the platform event log + * + * @log: Address of the log + * @log_position: Current entry position + * @log_size: Log space available + * @found: Boolean indicating if an existing log was discovered + */ +struct tcg2_event_log { + u8 *log; + u32 log_position; + u32 log_size; + bool found; +}; + +/** + * Create a list of digests of the supported PCR banks for a given input data + * + * @dev TPM device + * @input Data + * @length Length of the data to calculate the digest + * @digest_list List of digests to fill in + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_create_digest(struct udevice *dev, const u8 *input, u32 length, + struct tpml_digest_values *digest_list); + +/** + * Get the event size of the specified digests + * + * @digest_list List of digests for the event + * + * Return: Size in bytes of the event + */ +u32 tcg2_event_get_size(struct tpml_digest_values *digest_list); + +/** + * tcg2_get_active_pcr_banks + * + * @dev TPM device + * @active_pcr_banks Bitmask of PCR algorithms supported + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_get_active_pcr_banks(struct udevice *dev, u32 *active_pcr_banks); + +/** + * tcg2_log_append - Append an event to an event log + * + * @pcr_index Index of the PCR + * @event_type Type of event + * @digest_list List of digests to add + * @size Size of event + * @event Event data + * @log Log buffer to append the event to + */ +void tcg2_log_append(u32 pcr_index, u32 event_type, + struct tpml_digest_values *digest_list, u32 size, + const u8 *event, u8 *log); + +/** + * Extend the PCR with specified digests + * + * @dev TPM device + * @pcr_index Index of the PCR + * @digest_list List of digests to extend + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_pcr_extend(struct udevice *dev, u32 pcr_index, + struct tpml_digest_values *digest_list); + +/** + * Read the PCR into a list of digests + * + * @dev TPM device + * @pcr_index Index of the PCR + * @digest_list List of digests to extend + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_pcr_read(struct udevice *dev, u32 pcr_index, + struct tpml_digest_values *digest_list); + +/** + * Measure data into the TPM PCRs and the platform event log. + * + * @dev TPM device + * @log Platform event log + * @pcr_index Index of the PCR + * @size Size of the data or 0 for event only + * @data Pointer to the data or NULL for event only + * @event_type Event log type + * @event_size Size of the event + * @event Pointer to the event + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_measure_data(struct udevice *dev, struct tcg2_event_log *elog, + u32 pcr_index, u32 size, const u8 *data, u32 event_type, + u32 event_size, const u8 *event); + +#define tcg2_measure_event(dev, elog, pcr_index, event_type, size, event) \ + tcg2_measure_data(dev, elog, pcr_index, 0, NULL, event_type, size, \ + event) + +/** + * Prepare the event log buffer. This function tries to discover an existing + * event log in memory from a previous bootloader stage. If such a log exists + * and the PCRs are not extended, the log is "replayed" to extend the PCRs. + * If no log is discovered, create the log header. + * + * @dev TPM device + * @elog Platform event log. The log pointer and log_size + * members must be initialized to either 0 or to a valid + * memory region, in which case any existing log + * discovered will be copied to the specified memory + * region. + * @ignore_existing_log Boolean to indicate whether or not to ignore an + * existing platform log in memory + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_log_prepare_buffer(struct udevice *dev, struct tcg2_event_log *elog, + bool ignore_existing_log); + +/** + * Begin measurements. + * + * @dev TPM device + * @elog Platform event log. The log pointer and log_size + * members must be initialized to either 0 or to a valid + * memory region, in which case any existing log + * discovered will be copied to the specified memory + * region. + * @ignore_existing_log Boolean to indicate whether or not to ignore an + * existing platform log in memory + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_measurement_init(struct udevice **dev, struct tcg2_event_log *elog, + bool ignore_existing_log); + +/** + * Stop measurements and record separator events. + * + * @dev TPM device + * @elog Platform event log + * @error Boolean to indicate whether an error ocurred or not + */ +void tcg2_measurement_term(struct udevice *dev, struct tcg2_event_log *elog, + bool error); + +/** + * Get the platform event log address and size. + * + * @dev TPM device + * @addr Address of the log + * @size Size of the log + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_platform_get_log(struct udevice *dev, void **addr, u32 *size); + +/** + * Get the first TPM2 device found. + * + * @dev TPM device + * + * Return: zero on success, negative errno otherwise + */ +int tcg2_platform_get_tpm2(struct udevice **dev); + +/** + * Platform-specific function for handling TPM startup errors + * + * @dev TPM device + * @rc The TPM response code + */ +void tcg2_platform_startup_error(struct udevice *dev, int rc); + /** * Issue a TPM2_Startup command. * @@ -540,6 +786,19 @@ u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz, u32 tpm2_get_capability(struct udevice *dev, u32 capability, u32 property, void *buf, size_t prop_count);
+/** + * tpm2_get_pcr_info() - get the supported, active PCRs and number of banks + * + * @dev: TPM device + * @supported_pcr: bitmask with the algorithms supported + * @active_pcr: bitmask with the active algorithms + * @pcr_banks: number of PCR banks + * + * @return 0 on success, code of operation or negative errno on failure + */ +int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, u32 *active_pcr, + u32 *pcr_banks); + /** * Issue a TPM2_DictionaryAttackLockReset command. * diff --git a/lib/Kconfig b/lib/Kconfig index c8b3ec1ec9..cd37cba511 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -423,6 +423,10 @@ config TPM bool "Trusted Platform Module (TPM) Support" depends on DM imply DM_RNG + select SHA1 + select SHA256 + select SHA384 + select SHA512 help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index a83ae7a46c..5f0f4b5dd2 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -66,35 +66,6 @@ static bool tcg2_efi_app_invoked; static const efi_guid_t efi_guid_tcg2_protocol = EFI_TCG2_PROTOCOL_GUID; static const efi_guid_t efi_guid_final_events = EFI_TCG2_FINAL_EVENTS_TABLE_GUID;
-struct digest_info { - u16 hash_alg; - u32 hash_mask; - u16 hash_len; -}; - -static const struct digest_info hash_algo_list[] = { - { - TPM2_ALG_SHA1, - EFI_TCG2_BOOT_HASH_ALG_SHA1, - TPM2_SHA1_DIGEST_SIZE, - }, - { - TPM2_ALG_SHA256, - EFI_TCG2_BOOT_HASH_ALG_SHA256, - TPM2_SHA256_DIGEST_SIZE, - }, - { - TPM2_ALG_SHA384, - EFI_TCG2_BOOT_HASH_ALG_SHA384, - TPM2_SHA384_DIGEST_SIZE, - }, - { - TPM2_ALG_SHA512, - EFI_TCG2_BOOT_HASH_ALG_SHA512, - TPM2_SHA512_DIGEST_SIZE, - }, -}; - struct variable_info { const u16 *name; bool accept_empty; @@ -113,46 +84,6 @@ static struct variable_info secure_variables[] = { {u"AuditMode", false, 1}, };
-#define MAX_HASH_COUNT ARRAY_SIZE(hash_algo_list) - -/** - * alg_to_mask - Get a TCG hash mask for algorithms - * - * @hash_alg: TCG defined algorithm - * - * @Return: TCG hashing algorithm bitmaps, 0 if the algorithm is not supported - */ -static u32 alg_to_mask(u16 hash_alg) -{ - size_t i; - - for (i = 0; i < MAX_HASH_COUNT; i++) { - if (hash_algo_list[i].hash_alg == hash_alg) - return hash_algo_list[i].hash_mask; - } - - return 0; -} - -/** - * alg_to_len - Get a TCG hash len for algorithms - * - * @hash_alg: TCG defined algorithm - * - * @Return: len of chosen algorithm, 0 if the algorithm is not supported - */ -static u16 alg_to_len(u16 hash_alg) -{ - size_t i; - - for (i = 0; i < MAX_HASH_COUNT; i++) { - if (hash_algo_list[i].hash_alg == hash_alg) - return hash_algo_list[i].hash_len; - } - - return 0; -} - static bool is_tcg2_protocol_installed(void) { struct efi_handler *handler; @@ -162,145 +93,6 @@ static bool is_tcg2_protocol_installed(void) return ret == EFI_SUCCESS; }
-static u32 tcg_event_final_size(struct tpml_digest_values *digest_list) -{ - u32 len; - size_t i; - - len = offsetof(struct tcg_pcr_event2, digests); - len += offsetof(struct tpml_digest_values, digests); - for (i = 0; i < digest_list->count; i++) { - u16 hash_alg = digest_list->digests[i].hash_alg; - - len += offsetof(struct tpmt_ha, digest); - len += alg_to_len(hash_alg); - } - len += sizeof(u32); /* tcg_pcr_event2 event_size*/ - - return len; -} - -/* tcg2_pcr_extend - Extend PCRs for a TPM2 device for a given tpml_digest_values - * - * @dev: device - * @digest_list: list of digest algorithms to extend - * - * @Return: status code - */ -static efi_status_t tcg2_pcr_extend(struct udevice *dev, u32 pcr_index, - struct tpml_digest_values *digest_list) -{ - u32 rc; - size_t i; - - for (i = 0; i < digest_list->count; i++) { - u32 alg = digest_list->digests[i].hash_alg; - - rc = tpm2_pcr_extend(dev, pcr_index, alg, - (u8 *)&digest_list->digests[i].digest, - alg_to_len(alg)); - if (rc) { - EFI_PRINT("Failed to extend PCR\n"); - return EFI_DEVICE_ERROR; - } - } - - return EFI_SUCCESS; -} - -/* tcg2_pcr_read - Read PCRs for a TPM2 device for a given tpml_digest_values - * - * @dev: device - * @pcr_index: PCR index - * @digest_list: list of digest algorithms to extend - * - * @Return: status code - */ -static efi_status_t tcg2_pcr_read(struct udevice *dev, u32 pcr_index, - struct tpml_digest_values *digest_list) -{ - struct tpm_chip_priv *priv; - unsigned int updates, pcr_select_min; - u32 rc; - size_t i; - - priv = dev_get_uclass_priv(dev); - if (!priv) - return EFI_DEVICE_ERROR; - - pcr_select_min = priv->pcr_select_min; - - for (i = 0; i < digest_list->count; i++) { - u16 hash_alg = digest_list->digests[i].hash_alg; - u8 *digest = (u8 *)&digest_list->digests[i].digest; - - rc = tpm2_pcr_read(dev, pcr_index, pcr_select_min, - hash_alg, digest, alg_to_len(hash_alg), - &updates); - if (rc) { - EFI_PRINT("Failed to read PCR\n"); - return EFI_DEVICE_ERROR; - } - } - - return EFI_SUCCESS; -} - -/* put_event - Append an agile event to an eventlog - * - * @pcr_index: PCR index - * @event_type: type of event added - * @digest_list: list of digest algorithms to add - * @size: size of event - * @event: event to add - * @log: log buffer to append the event - * - */ -static void put_event(u32 pcr_index, u32 event_type, - struct tpml_digest_values *digest_list, u32 size, - u8 event[], void *log) -{ - size_t pos; - size_t i; - u32 event_size; - - /* - * size refers to the length of event[] only, we need to check against - * the final tcg_pcr_event2 size - */ - event_size = size + tcg_event_final_size(digest_list); - - put_unaligned_le32(pcr_index, log); - pos = offsetof(struct tcg_pcr_event2, event_type); - put_unaligned_le32(event_type, (void *)((uintptr_t)log + pos)); - pos = offsetof(struct tcg_pcr_event2, digests); /* count */ - put_unaligned_le32(digest_list->count, (void *)((uintptr_t)log + pos)); - - pos += offsetof(struct tpml_digest_values, digests); - for (i = 0; i < digest_list->count; i++) { - u16 hash_alg = digest_list->digests[i].hash_alg; - u8 *digest = (u8 *)&digest_list->digests[i].digest; - - put_unaligned_le16(hash_alg, (void *)((uintptr_t)log + pos)); - pos += offsetof(struct tpmt_ha, digest); - memcpy((void *)((uintptr_t)log + pos), digest, alg_to_len(hash_alg)); - pos += alg_to_len(hash_alg); - } - - put_unaligned_le32(size, (void *)((uintptr_t)log + pos)); - pos += sizeof(u32); /* tcg_pcr_event2 event_size*/ - memcpy((void *)((uintptr_t)log + pos), event, size); - pos += size; - - /* - * make sure the calculated buffer is what we checked against - * This check should never fail. It checks the code above is - * calculating the right length for the event we are adding - */ - if (pos != event_size) - log_err("Appending to the EventLog failed\n"); -} - /* tcg2_agile_log_append - Append an agile event to an eventlog * * @pcr_index: PCR index @@ -317,7 +109,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, u32 size, u8 event[]) { void *log = (void *)((uintptr_t)event_log.buffer + event_log.pos); - u32 event_size = size + tcg_event_final_size(digest_list); + u32 event_size = size + tcg2_event_get_size(digest_list); struct efi_tcg2_final_events_table *final_event; efi_status_t ret = EFI_SUCCESS;
@@ -328,7 +120,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, event_log.truncated = true; return EFI_VOLUME_FULL; } - put_event(pcr_index, event_type, digest_list, size, event, log); + tcg2_log_append(pcr_index, event_type, digest_list, size, event, log); event_log.pos += event_size; event_log.last_event_size = event_size; } @@ -341,7 +133,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, return EFI_VOLUME_FULL;
log = (void *)((uintptr_t)event_log.final_buffer + event_log.final_pos); - put_event(pcr_index, event_type, digest_list, size, event, log); + tcg2_log_append(pcr_index, event_type, digest_list, size, event, log);
final_event = event_log.final_buffer; final_event->number_of_events++; @@ -350,66 +142,6 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, return ret; }
-/** - * platform_get_tpm_device() - retrieve TPM device - * - * This function retrieves the udevice implementing a TPM - * - * This function may be overridden if special initialization is needed. - * - * @dev: udevice - * Return: status code - */ -__weak efi_status_t platform_get_tpm2_device(struct udevice **dev) -{ - for_each_tpm_device(*dev) { - /* Only support TPMv2 devices */ - if (tpm_get_version(*dev) == TPM_V2) - return EFI_SUCCESS; - } - - return EFI_NOT_FOUND; -} - -/** - * platform_get_eventlog() - retrieve the eventlog address and size - * - * This function retrieves the eventlog address and size if the underlying - * firmware has done some measurements and passed them. - * - * This function may be overridden based on platform specific method of - * passing the eventlog address and size. - * - * @dev: udevice - * @addr: eventlog address - * @sz: eventlog size - * Return: status code - */ -__weak efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, - u32 *sz) -{ - const u64 *basep; - const u32 *sizep; - - basep = dev_read_prop(dev, "tpm_event_log_addr", NULL); - if (!basep) - return EFI_NOT_FOUND; - - *addr = be64_to_cpup((__force __be64 *)basep); - - sizep = dev_read_prop(dev, "tpm_event_log_size", NULL); - if (!sizep) - return EFI_NOT_FOUND; - - *sz = be32_to_cpup((__force __be32 *)sizep); - if (*sz == 0) { - log_debug("event log empty\n"); - return EFI_NOT_FOUND; - } - - return EFI_SUCCESS; -} - /** * tpm2_get_max_command_size() - get the supported max command size * @@ -485,239 +217,6 @@ static int tpm2_get_manufacturer_id(struct udevice *dev, u32 *manufacturer_id) return 0; }
-/** - * tpm2_get_num_pcr() - get the number of PCRs - * - * @dev: TPM device - * @manufacturer_id: output buffer for the number - * - * Return: 0 on success, -1 on error - */ -static int tpm2_get_num_pcr(struct udevice *dev, u32 *num_pcr) -{ - u8 response[TPM2_RESPONSE_BUFFER_SIZE]; - u32 ret; - - memset(response, 0, sizeof(response)); - ret = tpm2_get_capability(dev, TPM2_CAP_TPM_PROPERTIES, - TPM2_PT_PCR_COUNT, response, 1); - if (ret) - return -1; - - *num_pcr = get_unaligned_be32(response + properties_offset); - if (*num_pcr > TPM2_MAX_PCRS) - return -1; - - return 0; -} - -/** - * is_active_pcr() - Check if a supported algorithm is active - * - * @dev: TPM device - * @selection: struct of PCR information - * - * Return: true if PCR is active - */ -static bool is_active_pcr(struct tpms_pcr_selection *selection) -{ - int i; - /* - * check the pcr_select. If at least one of the PCRs supports the - * algorithm add it on the active ones - */ - for (i = 0; i < selection->size_of_select; i++) { - if (selection->pcr_select[i]) - return true; - } - - return false; -} - -/** - * tpm2_get_pcr_info() - get the supported, active PCRs and number of banks - * - * @dev: TPM device - * @supported_pcr: bitmask with the algorithms supported - * @active_pcr: bitmask with the active algorithms - * @pcr_banks: number of PCR banks - * - * Return: 0 on success, -1 on error - */ -static int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, - u32 *active_pcr, u32 *pcr_banks) -{ - u8 response[TPM2_RESPONSE_BUFFER_SIZE]; - struct tpml_pcr_selection pcrs; - u32 ret, num_pcr; - size_t i; - int tpm_ret; - - *supported_pcr = 0; - *active_pcr = 0; - *pcr_banks = 0; - memset(response, 0, sizeof(response)); - ret = tpm2_get_capability(dev, TPM2_CAP_PCRS, 0, response, 1); - if (ret) - goto out; - - pcrs.count = get_unaligned_be32(response); - /* - * We only support 5 algorithms for now so check against that - * instead of TPM2_NUM_PCR_BANKS - */ - if (pcrs.count > MAX_HASH_COUNT || pcrs.count < 1) - goto out; - - tpm_ret = tpm2_get_num_pcr(dev, &num_pcr); - if (tpm_ret) - goto out; - - for (i = 0; i < pcrs.count; i++) { - /* - * Definition of TPMS_PCR_SELECTION Structure - * hash: u16 - * size_of_select: u8 - * pcr_select: u8 array - * - * The offsets depend on the number of the device PCRs - * so we have to calculate them based on that - */ - u32 hash_offset = offsetof(struct tpml_pcr_selection, selection) + - i * offsetof(struct tpms_pcr_selection, pcr_select) + - i * ((num_pcr + 7) / 8); - u32 size_select_offset = - hash_offset + offsetof(struct tpms_pcr_selection, - size_of_select); - u32 pcr_select_offset = - hash_offset + offsetof(struct tpms_pcr_selection, - pcr_select); - - pcrs.selection[i].hash = - get_unaligned_be16(response + hash_offset); - pcrs.selection[i].size_of_select = - __get_unaligned_be(response + size_select_offset); - if (pcrs.selection[i].size_of_select > TPM2_PCR_SELECT_MAX) - goto out; - /* copy the array of pcr_select */ - memcpy(pcrs.selection[i].pcr_select, response + pcr_select_offset, - pcrs.selection[i].size_of_select); - } - - for (i = 0; i < pcrs.count; i++) { - u32 hash_mask = alg_to_mask(pcrs.selection[i].hash); - - if (hash_mask) { - *supported_pcr |= hash_mask; - if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= hash_mask; - } else { - EFI_PRINT("Unknown algorithm %x\n", pcrs.selection[i].hash); - } - } - - *pcr_banks = pcrs.count; - - return 0; -out: - return -1; -} - -/** - * __get_active_pcr_banks() - returns the currently active PCR banks - * - * @active_pcr_banks: pointer for receiving the bitmap of currently - * active PCR banks - * - * Return: status code - */ -static efi_status_t __get_active_pcr_banks(u32 *active_pcr_banks) -{ - struct udevice *dev; - u32 active = 0, supported = 0, pcr_banks = 0; - efi_status_t ret; - int err; - - ret = platform_get_tpm2_device(&dev); - if (ret != EFI_SUCCESS) - goto out; - - err = tpm2_get_pcr_info(dev, &supported, &active, &pcr_banks); - if (err) { - ret = EFI_DEVICE_ERROR; - goto out; - } - - *active_pcr_banks = active; - -out: - return ret; -} - -/* tcg2_create_digest - create a list of digests of the supported PCR banks - * for a given memory range - * - * @input: input memory - * @length: length of buffer to calculate the digest - * @digest_list: list of digests to fill in - * - * Return: status code - */ -static efi_status_t tcg2_create_digest(const u8 *input, u32 length, - struct tpml_digest_values *digest_list) -{ - sha1_context ctx; - sha256_context ctx_256; - sha512_context ctx_512; - u8 final[TPM2_SHA512_DIGEST_SIZE]; - efi_status_t ret; - u32 active; - size_t i; - - ret = __get_active_pcr_banks(&active); - if (ret != EFI_SUCCESS) - return ret; - - digest_list->count = 0; - for (i = 0; i < MAX_HASH_COUNT; i++) { - u16 hash_alg = hash_algo_list[i].hash_alg; - - if (!(active & alg_to_mask(hash_alg))) - continue; - switch (hash_alg) { - case TPM2_ALG_SHA1: - sha1_starts(&ctx); - sha1_update(&ctx, input, length); - sha1_finish(&ctx, final); - break; - case TPM2_ALG_SHA256: - sha256_starts(&ctx_256); - sha256_update(&ctx_256, input, length); - sha256_finish(&ctx_256, final); - break; - case TPM2_ALG_SHA384: - sha384_starts(&ctx_512); - sha384_update(&ctx_512, input, length); - sha384_finish(&ctx_512, final); - break; - case TPM2_ALG_SHA512: - sha512_starts(&ctx_512); - sha512_update(&ctx_512, input, length); - sha512_finish(&ctx_512, final); - break; - default: - EFI_PRINT("Unsupported algorithm %x\n", hash_alg); - return EFI_INVALID_PARAMETER; - } - digest_list->digests[digest_list->count].hash_alg = hash_alg; - memcpy(&digest_list->digests[digest_list->count].digest, final, - (u32)alg_to_len(hash_alg)); - digest_list->count++; - } - - return EFI_SUCCESS; -} - /** * efi_tcg2_get_capability() - protocol capability information and state information * @@ -759,7 +258,7 @@ efi_tcg2_get_capability(struct efi_tcg2_protocol *this, capability->protocol_version.major = 1; capability->protocol_version.minor = 1;
- efi_ret = platform_get_tpm2_device(&dev); + efi_ret = tcg2_platform_get_tpm2(&dev); if (efi_ret != EFI_SUCCESS) { capability->supported_event_logs = 0; capability->hash_algorithm_bitmap = 0; @@ -855,7 +354,7 @@ efi_tcg2_get_eventlog(struct efi_tcg2_protocol *this, goto out; }
- ret = platform_get_tpm2_device(&dev); + ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) { event_log_location = NULL; event_log_last_entry = NULL; @@ -890,6 +389,7 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, struct efi_image_regions *regs = NULL; void *new_efi = NULL; u8 hash[TPM2_SHA512_DIGEST_SIZE]; + struct udevice *dev; efi_status_t ret; u32 active; int i; @@ -905,16 +405,20 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, goto out; }
- ret = __get_active_pcr_banks(&active); + ret = tcg2_platform_get_tpm2(&dev); + if (ret != EFI_SUCCESS) + goto out; + + ret = tcg2_get_active_pcr_banks(dev, &active); if (ret != EFI_SUCCESS) { goto out; }
digest_list->count = 0; - for (i = 0; i < MAX_HASH_COUNT; i++) { - u16 hash_alg = hash_algo_list[i].hash_alg; + for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); i++) { + u16 hash_alg = tpm2_supported_algorithms[i];
- if (!(active & alg_to_mask(hash_alg))) + if (!(active & tpm2_algorithm_to_mask(hash_alg))) continue; switch (hash_alg) { case TPM2_ALG_SHA1: @@ -935,7 +439,7 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, } digest_list->digests[digest_list->count].hash_alg = hash_alg; memcpy(&digest_list->digests[digest_list->count].digest, hash, - (u32)alg_to_len(hash_alg)); + (u32)tpm2_algorithm_to_len(hash_alg)); digest_list->count++; }
@@ -975,7 +479,7 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
- ret = platform_get_tpm2_device(&dev); + ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) return EFI_SECURITY_VIOLATION;
@@ -1084,7 +588,7 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, goto out; }
- ret = platform_get_tpm2_device(&dev); + ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) goto out;
@@ -1119,7 +623,7 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, ret = tcg2_hash_pe_image((void *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list); } else { - ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, + ret = tcg2_create_digest(dev, (u8 *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list); }
@@ -1182,7 +686,7 @@ efi_tcg2_submit_command(struct efi_tcg2_protocol *this, goto out; }
@@ -1211,6 +715,7 @@ static efi_status_t EFIAPI efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, u32 *active_pcr_banks) { + struct udevice *dev; efi_status_t ret;
if (!this || !active_pcr_banks) { @@ -1218,8 +723,12 @@ efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, goto out; }
+ ret = tcg2_platform_get_tpm2(&dev); + if (ret != EFI_SUCCESS) + goto out; + EFI_ENTRY("%p, %p", this, active_pcr_banks); - ret = __get_active_pcr_banks(active_pcr_banks); + ret = tcg2_get_active_pcr_banks(dev, active_pcr_banks);
out: return EFI_EXIT(ret); @@ -1270,397 +779,6 @@ static const struct efi_tcg2_protocol efi_tcg2_protocol = { .get_result_of_set_active_pcr_banks = efi_tcg2_get_result_of_set_active_pcr_banks, };
-/** - * parse_event_log_header() - Parse and verify the event log header fields - * - * @buffer: Pointer to the start of the eventlog - * @size: Size of the eventlog - * @pos: Return offset of the next event in buffer right - * after the event header i.e specID - * - * Return: status code - */ -static efi_status_t parse_event_log_header(void *buffer, u32 size, u32 *pos) -{ - struct tcg_pcr_event *event_header = (struct tcg_pcr_event *)buffer; - int i = 0; - - if (size < sizeof(*event_header)) - return EFI_COMPROMISED_DATA; - - if (get_unaligned_le32(&event_header->pcr_index) != 0 || - get_unaligned_le32(&event_header->event_type) != EV_NO_ACTION) - return EFI_COMPROMISED_DATA; - - for (i = 0; i < sizeof(event_header->digest); i++) { - if (event_header->digest[i]) - return EFI_COMPROMISED_DATA; - } - - *pos += sizeof(*event_header); - - return EFI_SUCCESS; -} - -/** - * parse_specid_event() - Parse and verify the specID Event in the eventlog - * - * @dev: udevice - * @buffer: Pointer to the start of the eventlog - * @log_size: Size of the eventlog - * @pos: [in] Offset of specID event in the eventlog buffer - * [out] Return offset of the next event in the buffer - * after the specID - * @digest_list: list of digests in the event - * - * Return: status code - * @pos Offset in the eventlog where the specID event ends - * @digest_list: list of digests in the event - */ -static efi_status_t parse_specid_event(struct udevice *dev, void *buffer, - u32 log_size, u32 *pos, - struct tpml_digest_values *digest_list) -{ - struct tcg_efi_spec_id_event *spec_event; - struct tcg_pcr_event *event_header = (struct tcg_pcr_event *)buffer; - size_t spec_event_size; - u32 active = 0, supported = 0, pcr_count = 0, alg_count = 0; - u32 spec_active = 0; - u16 hash_alg; - u8 vendor_sz; - int err, i; - - if (*pos >= log_size || (*pos + sizeof(*spec_event)) > log_size) - return EFI_COMPROMISED_DATA; - - /* Check specID event data */ - spec_event = (struct tcg_efi_spec_id_event *)((uintptr_t)buffer + *pos); - /* Check for signature */ - if (memcmp(spec_event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03, - sizeof(TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03))) { - log_err("specID Event: Signature mismatch\n"); - return EFI_COMPROMISED_DATA; - } - - if (spec_event->spec_version_minor != - TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 || - spec_event->spec_version_major != - TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2) - return EFI_COMPROMISED_DATA; - - if (spec_event->number_of_algorithms > MAX_HASH_COUNT || - spec_event->number_of_algorithms < 1) { - log_err("specID Event: Number of algorithms incorrect\n"); - return EFI_COMPROMISED_DATA; - } - - alg_count = spec_event->number_of_algorithms; - - err = tpm2_get_pcr_info(dev, &supported, &active, &pcr_count); - if (err) - return EFI_DEVICE_ERROR; - - digest_list->count = 0; - /* - * We have to take care that the sequence of algorithms that we record - * in digest_list matches the sequence in eventlog. - */ - for (i = 0; i < alg_count; i++) { - hash_alg = - get_unaligned_le16(&spec_event->digest_sizes[i].algorithm_id); - - if (!(supported & alg_to_mask(hash_alg))) { - log_err("specID Event: Unsupported algorithm\n"); - return EFI_COMPROMISED_DATA; - } - digest_list->digests[digest_list->count++].hash_alg = hash_alg; - - spec_active |= alg_to_mask(hash_alg); - } - - /* - * TCG specification expects the event log to have hashes for all - * active PCR's - */ - if (spec_active != active) { - /* - * Previous stage bootloader should know all the active PCR's - * and use them in the Eventlog. - */ - log_err("specID Event: All active hash alg not present\n"); - return EFI_COMPROMISED_DATA; - } - - /* - * the size of the spec event and placement of vendor_info_size - * depends on supported algoriths - */ - spec_event_size = - offsetof(struct tcg_efi_spec_id_event, digest_sizes) + - alg_count * sizeof(spec_event->digest_sizes[0]); - - if (*pos + spec_event_size >= log_size) - return EFI_COMPROMISED_DATA; - - vendor_sz = *(uint8_t *)((uintptr_t)buffer + *pos + spec_event_size); - - spec_event_size += sizeof(vendor_sz) + vendor_sz; - *pos += spec_event_size; - - if (get_unaligned_le32(&event_header->event_size) != spec_event_size) { - log_err("specID event: header event size mismatch\n"); - /* Right way to handle this can be to call SetActive PCR's */ - return EFI_COMPROMISED_DATA; - } - - return EFI_SUCCESS; -} - -/** - * tcg2_parse_event() - Parse the event in the eventlog - * - * @dev: udevice - * @buffer: Pointer to the start of the eventlog - * @log_size: Size of the eventlog - * @offset: [in] Offset of the event in the eventlog buffer - * [out] Return offset of the next event in the buffer - * @digest_list: list of digests in the event - * @pcr Index of the PCR in the event - * - * Return: status code - */ -static efi_status_t tcg2_parse_event(struct udevice *dev, void *buffer, - u32 log_size, u32 *offset, - struct tpml_digest_values *digest_list, - u32 *pcr) -{ - struct tcg_pcr_event2 *event = NULL; - u32 count, size, event_size; - size_t pos; - - event_size = tcg_event_final_size(digest_list); - if (*offset >= log_size || *offset + event_size > log_size) { - log_err("Event exceeds log size\n"); - return EFI_COMPROMISED_DATA; - } - - event = (struct tcg_pcr_event2 *)((uintptr_t)buffer + *offset); - *pcr = get_unaligned_le32(&event->pcr_index); - - /* get the count */ - count = get_unaligned_le32(&event->digests.count); - if (count != digest_list->count) - return EFI_COMPROMISED_DATA; - - pos = offsetof(struct tcg_pcr_event2, digests); - pos += offsetof(struct tpml_digest_values, digests); - - for (int i = 0; i < digest_list->count; i++) { - u16 alg; - u16 hash_alg = digest_list->digests[i].hash_alg; - u8 *digest = (u8 *)&digest_list->digests[i].digest; - - alg = get_unaligned_le16((void *)((uintptr_t)event + pos)); - - if (alg != hash_alg) - return EFI_COMPROMISED_DATA; - - pos += offsetof(struct tpmt_ha, digest); - memcpy(digest, (void *)((uintptr_t)event + pos), alg_to_len(hash_alg)); - pos += alg_to_len(hash_alg); - } - - size = get_unaligned_le32((void *)((uintptr_t)event + pos)); - event_size += size; - pos += sizeof(u32); /* tcg_pcr_event2 event_size*/ - pos += size; - - /* make sure the calculated buffer is what we checked against */ - if (pos != event_size) - return EFI_COMPROMISED_DATA; - - if (pos > log_size) - return EFI_COMPROMISED_DATA; - - *offset += pos; - - return EFI_SUCCESS; -} - -/** - * tcg2_get_fw_eventlog() - Get the eventlog address and size - * - * If the previous firmware has passed some eventlog, this function get it's - * location and check for it's validity. - * - * @dev: udevice - * @log_buffer: eventlog address - * @log_sz: eventlog size - * - * Return: status code - */ -static efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer, - size_t *log_sz) -{ - struct tpml_digest_values digest_list; - void *buffer; - efi_status_t ret; - u32 pcr, pos; - u64 base; - u32 sz; - bool extend_pcr = false; - int i; - - ret = platform_get_eventlog(dev, &base, &sz); - if (ret != EFI_SUCCESS) - return ret; - - if (sz > TPM2_EVENT_LOG_SIZE) - return EFI_VOLUME_FULL; - - buffer = (void *)(uintptr_t)base; - pos = 0; - /* Parse the eventlog to check for its validity */ - ret = parse_event_log_header(buffer, sz, &pos); - if (ret) - return ret; - - ret = parse_specid_event(dev, buffer, sz, &pos, &digest_list); - if (ret) { - log_err("Error parsing SPEC ID Event\n"); - return ret; - } - - ret = tcg2_pcr_read(dev, 0, &digest_list); - if (ret) { - log_err("Error reading PCR 0\n"); - return ret; - } - - /* - * If PCR0 is 0, previous firmware didn't have the capability - * to extend the PCR. In this scenario, extend the PCR as - * the eventlog is parsed. - */ - for (i = 0; i < digest_list.count; i++) { - u8 hash_buf[TPM2_SHA512_DIGEST_SIZE] = { 0 }; - u16 hash_alg = digest_list.digests[i].hash_alg; - - if (!memcmp((u8 *)&digest_list.digests[i].digest, hash_buf, - alg_to_len(hash_alg))) - extend_pcr = true; - } - - while (pos < sz) { - ret = tcg2_parse_event(dev, buffer, sz, &pos, &digest_list, - &pcr); - if (ret) { - log_err("Error parsing event\n"); - return ret; - } - if (extend_pcr) { - ret = tcg2_pcr_extend(dev, pcr, &digest_list); - if (ret != EFI_SUCCESS) { - log_err("Error in extending PCR\n"); - return ret; - } - - /* Clear the digest for next event */ - for (i = 0; i < digest_list.count; i++) { - u16 hash_alg = digest_list.digests[i].hash_alg; - u8 *digest = - (u8 *)&digest_list.digests[i].digest; - - memset(digest, 0, alg_to_len(hash_alg)); - } - } - } - - memcpy(log_buffer, buffer, sz); - *log_sz = sz; - - return ret; -} - -/** - * create_specid_event() - Create the first event in the eventlog - * - * @dev: tpm device - * @event_header: Pointer to the final event header - * @event_size: final spec event size - * - * Return: status code - */ -static efi_status_t create_specid_event(struct udevice *dev, void *buffer, - size_t *event_size) -{ - struct tcg_efi_spec_id_event *spec_event; - size_t spec_event_size; - efi_status_t ret = EFI_DEVICE_ERROR; - u32 active = 0, supported = 0, pcr_count = 0, alg_count = 0; - int err; - size_t i; - - /* - * Create Spec event. This needs to be the first event in the log - * according to the TCG EFI protocol spec - */ - - /* Setup specID event data */ - spec_event = (struct tcg_efi_spec_id_event *)buffer; - memcpy(spec_event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03, - sizeof(spec_event->signature)); - put_unaligned_le32(0, &spec_event->platform_class); /* type client */ - spec_event->spec_version_minor = - TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2; - spec_event->spec_version_major = - TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2; - spec_event->spec_errata = - TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2; - spec_event->uintn_size = sizeof(efi_uintn_t) / sizeof(u32); - - err = tpm2_get_pcr_info(dev, &supported, &active, &pcr_count); - - if (err) - goto out; - - for (i = 0; i < pcr_count; i++) { - u16 hash_alg = hash_algo_list[i].hash_alg; - u16 hash_len = hash_algo_list[i].hash_len; - - if (active & alg_to_mask(hash_alg)) { - put_unaligned_le16(hash_alg, - &spec_event->digest_sizes[alg_count].algorithm_id); - put_unaligned_le16(hash_len, - &spec_event->digest_sizes[alg_count].digest_size); - alg_count++; - } - } - - spec_event->number_of_algorithms = alg_count; - if (spec_event->number_of_algorithms > MAX_HASH_COUNT || - spec_event->number_of_algorithms < 1) - goto out; - - /* - * the size of the spec event and placement of vendor_info_size - * depends on supported algoriths - */ - spec_event_size = - offsetof(struct tcg_efi_spec_id_event, digest_sizes) + - spec_event->number_of_algorithms * sizeof(spec_event->digest_sizes[0]); - /* no vendor info for us */ - memset(buffer + spec_event_size, 0, 1); - /* add a byte for vendor_info_size in the spec event */ - spec_event_size += 1; - *event_size = spec_event_size; - - return EFI_SUCCESS; - -out: - return ret; -} - /** * tcg2_uninit - remove the final event table and free efi memory on failures */ @@ -1722,7 +840,7 @@ out: }
/** - * tcg2_measure_event() - common function to add event log and extend PCR + * measure_event() - common function to add event log and extend PCR * * @dev: TPM device * @pcr_index: PCR index @@ -1732,14 +850,13 @@ out: * * Return: status code */ -static efi_status_t -tcg2_measure_event(struct udevice *dev, u32 pcr_index, u32 event_type, - u32 size, u8 event[]) +static efi_status_t measure_event(struct udevice *dev, u32 pcr_index, + u32 event_type, u32 size, u8 event[]) { struct tpml_digest_values digest_list; efi_status_t ret;
- ret = tcg2_create_digest(event, size, &digest_list); + ret = tcg2_create_digest(dev, event, size, &digest_list); if (ret != EFI_SUCCESS) goto out;
@@ -1766,9 +883,8 @@ static efi_status_t efi_append_scrtm_version(struct udevice *dev) { efi_status_t ret;
- ret = tcg2_measure_event(dev, 0, EV_S_CRTM_VERSION, - strlen(version_string) + 1, - (u8 *)version_string); + ret = measure_event(dev, 0, EV_S_CRTM_VERSION, + strlen(version_string) + 1, (u8 *)version_string);
return ret; } @@ -1784,12 +900,11 @@ static efi_status_t efi_init_event_log(void) * vendor_info_size is currently set to 0, we need to change the length * and allocate the flexible array member if this changes */ - struct tcg_pcr_event *event_header = NULL; + struct tcg2_event_log elog; struct udevice *dev; - size_t spec_event_size; efi_status_t ret;
- ret = platform_get_tpm2_device(&dev); + ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) return ret;
@@ -1808,7 +923,6 @@ static efi_status_t efi_init_event_log(void) * The log header is defined to be in SHA1 event log entry format. * Setup event header */ - event_header = (struct tcg_pcr_event *)event_log.buffer; event_log.pos = 0; event_log.last_event_size = 0; event_log.get_event_called = false; @@ -1819,34 +933,20 @@ static efi_status_t efi_init_event_log(void) * Check if earlier firmware have passed any eventlog. Different * platforms can use different ways to do so. */ - ret = tcg2_get_fw_eventlog(dev, event_log.buffer, &event_log.pos); + elog.log = event_log.buffer; + elog.log_size = TPM2_EVENT_LOG_SIZE; + ret = tcg2_log_prepare_buffer(dev, &elog, false); + if (ret != EFI_SUCCESS) + goto free_pool; + + event_log.pos = elog.log_position; + /* - * If earlier firmware hasn't passed any eventlog, go ahead and - * create the eventlog header. + * Add SCRTM version to the log if previous firmmware + * doesn't pass an eventlog. */ - if (ret == EFI_NOT_FOUND) { - put_unaligned_le32(0, &event_header->pcr_index); - put_unaligned_le32(EV_NO_ACTION, &event_header->event_type); - memset(&event_header->digest, 0, sizeof(event_header->digest)); - ret = create_specid_event(dev, - (void *)((uintptr_t)event_log.buffer + - sizeof(*event_header)), - &spec_event_size); - if (ret != EFI_SUCCESS) - goto free_pool; - put_unaligned_le32(spec_event_size, &event_header->event_size); - event_log.pos = spec_event_size + sizeof(*event_header); - event_log.last_event_size = event_log.pos; - - /* - * Add SCRTM version to the log if previous firmmware - * doesn't pass an eventlog. - */ + if (!elog.found) ret = efi_append_scrtm_version(dev); - } - - if (ret != EFI_SUCCESS) - goto free_pool;
ret = create_final_event(); if (ret != EFI_SUCCESS) @@ -1899,8 +999,8 @@ static efi_status_t tcg2_measure_variable(struct udevice *dev, u32 pcr_index, memcpy((u16 *)event->unicode_name + event->unicode_name_length, data, data_size); } - ret = tcg2_measure_event(dev, pcr_index, event_type, event_size, - (u8 *)event); + ret = measure_event(dev, pcr_index, event_type, event_size, + (u8 *)event); free(event); return ret; } @@ -2011,8 +1111,8 @@ tcg2_measure_smbios(struct udevice *dev,
smbios_prepare_measurement(entry, smbios_copy);
- ret = tcg2_measure_event(dev, 1, EV_EFI_HANDOFF_TABLES2, event_size, - (u8 *)event); + ret = measure_event(dev, 1, EV_EFI_HANDOFF_TABLES2, event_size, + (u8 *)event); if (ret != EFI_SUCCESS) goto out;
@@ -2163,7 +1263,7 @@ tcg2_measure_gpt_data(struct udevice *dev, gpt_e = (gpt_entry *)((u8 *)gpt_e + gpt_h->sizeof_partition_entry); }
- ret = tcg2_measure_event(dev, 5, EV_EFI_GPT_EVENT, event_size, (u8 *)event); + ret = measure_event(dev, 5, EV_EFI_GPT_EVENT, event_size, (u8 *)event);
out2: free(gpt_h); @@ -2217,7 +1317,7 @@ efi_status_t efi_tcg2_measure_dtb(void *dtb) if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
@@ -2242,7 +1342,7 @@ efi_status_t efi_tcg2_measure_dtb(void *dtb) sha256_update(&hash_ctx, (u8 *)dtb + fdt_off_mem_rsvmap(dtb), rsvmap_size); sha256_finish(&hash_ctx, blob->data + blob->blob_description_size);
- ret = tcg2_measure_event(dev, 0, EV_POST_CODE, event_size, (u8 *)blob); + ret = measure_event(dev, 0, EV_POST_CODE, event_size, (u8 *)blob);
free(blob); return ret; @@ -2267,7 +1367,7 @@ efi_status_t efi_tcg2_measure_efi_app_invocation(struct efi_loaded_image_obj *ha if (tcg2_efi_app_invoked) return EFI_SUCCESS;
@@ -2275,9 +1375,9 @@ efi_status_t efi_tcg2_measure_efi_app_invocation(struct efi_loaded_image_obj *ha if (ret != EFI_SUCCESS) goto out;
- ret = tcg2_measure_event(dev, 4, EV_EFI_ACTION, - strlen(EFI_CALLING_EFI_APPLICATION), - (u8 *)EFI_CALLING_EFI_APPLICATION); + ret = measure_event(dev, 4, EV_EFI_ACTION, + strlen(EFI_CALLING_EFI_APPLICATION), + (u8 *)EFI_CALLING_EFI_APPLICATION); if (ret != EFI_SUCCESS) goto out;
@@ -2293,8 +1393,8 @@ efi_status_t efi_tcg2_measure_efi_app_invocation(struct efi_loaded_image_obj *ha goto out;
for (pcr_index = 0; pcr_index <= 7; pcr_index++) { - ret = tcg2_measure_event(dev, pcr_index, EV_SEPARATOR, - sizeof(event), (u8 *)&event); + ret = measure_event(dev, pcr_index, EV_SEPARATOR, + sizeof(event), (u8 *)&event); if (ret != EFI_SUCCESS) goto out; } @@ -2317,13 +1417,13 @@ efi_status_t efi_tcg2_measure_efi_app_exit(void) if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
- ret = tcg2_measure_event(dev, 4, EV_EFI_ACTION, - strlen(EFI_RETURNING_FROM_EFI_APPLICATION), - (u8 *)EFI_RETURNING_FROM_EFI_APPLICATION); + ret = measure_event(dev, 4, EV_EFI_ACTION, + strlen(EFI_RETURNING_FROM_EFI_APPLICATION), + (u8 *)EFI_RETURNING_FROM_EFI_APPLICATION); return ret; }
@@ -2348,19 +1448,19 @@ efi_tcg2_notify_exit_boot_services(struct efi_event *event, void *context) goto out; }
- ret = tcg2_measure_event(dev, 5, EV_EFI_ACTION, - strlen(EFI_EXIT_BOOT_SERVICES_INVOCATION), - (u8 *)EFI_EXIT_BOOT_SERVICES_INVOCATION); + ret = measure_event(dev, 5, EV_EFI_ACTION, + strlen(EFI_EXIT_BOOT_SERVICES_INVOCATION), + (u8 *)EFI_EXIT_BOOT_SERVICES_INVOCATION); if (ret != EFI_SUCCESS) goto out;
- ret = tcg2_measure_event(dev, 5, EV_EFI_ACTION, - strlen(EFI_EXIT_BOOT_SERVICES_SUCCEEDED), - (u8 *)EFI_EXIT_BOOT_SERVICES_SUCCEEDED); + ret = measure_event(dev, 5, EV_EFI_ACTION, + strlen(EFI_EXIT_BOOT_SERVICES_SUCCEEDED), + (u8 *)EFI_EXIT_BOOT_SERVICES_SUCCEEDED);
out: EFI_EXIT(ret); @@ -2380,19 +1480,19 @@ efi_status_t efi_tcg2_notify_exit_boot_services_failed(void) if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
- ret = tcg2_measure_event(dev, 5, EV_EFI_ACTION, - strlen(EFI_EXIT_BOOT_SERVICES_FAILED), - (u8 *)EFI_EXIT_BOOT_SERVICES_FAILED); + ret = measure_event(dev, 5, EV_EFI_ACTION, + strlen(EFI_EXIT_BOOT_SERVICES_FAILED), + (u8 *)EFI_EXIT_BOOT_SERVICES_FAILED);
out: return ret; @@ -2462,7 +1562,7 @@ efi_status_t efi_tcg2_do_initial_measurement(void) if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
@@ -2488,7 +1588,7 @@ efi_status_t efi_tcg2_register(void) struct efi_event *event; u32 err;
- ret = platform_get_tpm2_device(&dev); + ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) { log_warning("Missing TPMv2 device for EFI_TCG_PROTOCOL\n"); return EFI_SUCCESS; diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 9ab5b46df1..bd0fb078dc 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -1,16 +1,705 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * Copyright (c) 2023 Linaro Limited * Copyright (c) 2018 Bootlin * Author: Miquel Raynal miquel.raynal@bootlin.com */
#include <common.h> #include <dm.h> +#include <dm/of_access.h> +#include <tpm_api.h> #include <tpm-common.h> #include <tpm-v2.h> +#include <u-boot/sha1.h> +#include <u-boot/sha256.h> +#include <u-boot/sha512.h> +#include <version_string.h> +#include <asm/io.h> #include <linux/bitops.h> +#include <linux/unaligned/be_byteshift.h> +#include <linux/unaligned/generic.h> +#include <linux/unaligned/le_byteshift.h> + #include "tpm-utils.h"
+const enum tpm2_algorithms tpm2_supported_algorithms[4] = { + TPM2_ALG_SHA1, + TPM2_ALG_SHA256, + TPM2_ALG_SHA384, + TPM2_ALG_SHA512, +}; + +int tcg2_get_active_pcr_banks(struct udevice *dev, u32 *active_pcr_banks) +{ + u32 supported = 0; + u32 pcr_banks = 0; + u32 active = 0; + int rc; + + rc = tpm2_get_pcr_info(dev, &supported, &active, &pcr_banks); + if (rc) + return rc; + + *active_pcr_banks = active; + + return 0; +} + +u32 tcg2_event_get_size(struct tpml_digest_values *digest_list) +{ + u32 len; + size_t i; + + len = offsetof(struct tcg_pcr_event2, digests); + len += offsetof(struct tpml_digest_values, digests); + for (i = 0; i < digest_list->count; ++i) { + u16 l = tpm2_algorithm_to_len(digest_list->digests[i].hash_alg); + + if (!l) + continue; + + len += l + offsetof(struct tpmt_ha, digest); + } + len += sizeof(u32); + + return len; +} + +int tcg2_create_digest(struct udevice *dev, const u8 *input, u32 length, + struct tpml_digest_values *digest_list) +{ + u8 final[sizeof(union tpmu_ha)]; + sha256_context ctx_256; + sha512_context ctx_512; + sha1_context ctx; + u32 active; + size_t i; + u32 len; + int rc; + + rc = tcg2_get_active_pcr_banks(dev, &active); + if (rc) + return rc; + + digest_list->count = 0; + for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { + u32 mask = + tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + + if (!(active & mask)) + continue; + + switch (tpm2_supported_algorithms[i]) { + case TPM2_ALG_SHA1: + sha1_starts(&ctx); + sha1_update(&ctx, input, length); + sha1_finish(&ctx, final); + len = TPM2_SHA1_DIGEST_SIZE; + break; + case TPM2_ALG_SHA256: + sha256_starts(&ctx_256); + sha256_update(&ctx_256, input, length); + sha256_finish(&ctx_256, final); + len = TPM2_SHA256_DIGEST_SIZE; + break; + case TPM2_ALG_SHA384: + sha384_starts(&ctx_512); + sha384_update(&ctx_512, input, length); + sha384_finish(&ctx_512, final); + len = TPM2_SHA384_DIGEST_SIZE; + break; + case TPM2_ALG_SHA512: + sha512_starts(&ctx_512); + sha512_update(&ctx_512, input, length); + sha512_finish(&ctx_512, final); + len = TPM2_SHA512_DIGEST_SIZE; + break; + default: + printf("%s: unsupported algorithm %x\n", __func__, + tpm2_supported_algorithms[i]); + continue; + } + + digest_list->digests[digest_list->count].hash_alg = + tpm2_supported_algorithms[i]; + memcpy(&digest_list->digests[digest_list->count].digest, final, + len); + digest_list->count++; + } + + return 0; +} + +void tcg2_log_append(u32 pcr_index, u32 event_type, + struct tpml_digest_values *digest_list, u32 size, + const u8 *event, u8 *log) +{ + size_t len; + size_t pos; + u32 i; + + pos = offsetof(struct tcg_pcr_event2, pcr_index); + put_unaligned_le32(pcr_index, log); + pos = offsetof(struct tcg_pcr_event2, event_type); + put_unaligned_le32(event_type, log + pos); + pos = offsetof(struct tcg_pcr_event2, digests) + + offsetof(struct tpml_digest_values, count); + put_unaligned_le32(digest_list->count, log + pos); + + pos = offsetof(struct tcg_pcr_event2, digests) + + offsetof(struct tpml_digest_values, digests); + for (i = 0; i < digest_list->count; ++i) { + u16 hash_alg = digest_list->digests[i].hash_alg; + + len = tpm2_algorithm_to_len(hash_alg); + if (!len) + continue; + + pos += offsetof(struct tpmt_ha, hash_alg); + put_unaligned_le16(hash_alg, log + pos); + pos += offsetof(struct tpmt_ha, digest); + memcpy(log + pos, (u8 *)&digest_list->digests[i].digest, len); + pos += len; + } + + put_unaligned_le32(size, log + pos); + pos += sizeof(u32); + memcpy(log + pos, event, size); +} + +static int tcg2_log_append_check(struct tcg2_event_log *elog, u32 pcr_index, + u32 event_type, + struct tpml_digest_values *digest_list, + u32 size, const u8 *event) +{ + u32 event_size; + u8 *log; + + event_size = size + tcg2_event_get_size(digest_list); + if (elog->log_position + event_size > elog->log_size) { + printf("%s: log too large: %u + %u > %u\n", __func__, + elog->log_position, event_size, elog->log_size); + return -ENOBUFS; + } + + log = elog->log + elog->log_position; + elog->log_position += event_size; + + tcg2_log_append(pcr_index, event_type, digest_list, size, event, log); + + return 0; +} + +static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog) +{ + struct tcg_efi_spec_id_event *ev; + struct tcg_pcr_event *log; + u32 event_size; + u32 count = 0; + u32 log_size; + u32 active; + u32 mask; + size_t i; + u16 len; + int rc; + + rc = tcg2_get_active_pcr_banks(dev, &active); + if (rc) + return rc; + + event_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes); + for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { + mask = tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + + if (!(active & mask)) + continue; + + switch (tpm2_supported_algorithms[i]) { + case TPM2_ALG_SHA1: + case TPM2_ALG_SHA256: + case TPM2_ALG_SHA384: + case TPM2_ALG_SHA512: + count++; + break; + default: + continue; + } + } + + event_size += 1 + + (sizeof(struct tcg_efi_spec_id_event_algorithm_size) * count); + log_size = offsetof(struct tcg_pcr_event, event) + event_size; + + if (log_size > elog->log_size) { + printf("%s: log too large: %u > %u\n", __func__, log_size, + elog->log_size); + return -ENOBUFS; + } + + log = (struct tcg_pcr_event *)elog->log; + put_unaligned_le32(0, &log->pcr_index); + put_unaligned_le32(EV_NO_ACTION, &log->event_type); + memset(&log->digest, 0, sizeof(log->digest)); + put_unaligned_le32(event_size, &log->event_size); + + ev = (struct tcg_efi_spec_id_event *)log->event; + strlcpy((char *)ev->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03, + sizeof(ev->signature)); + put_unaligned_le32(0, &ev->platform_class); + ev->spec_version_minor = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2; + ev->spec_version_major = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2; + ev->spec_errata = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2; + ev->uintn_size = sizeof(size_t) / sizeof(u32); + put_unaligned_le32(count, &ev->number_of_algorithms); + + count = 0; + for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { + mask = tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + + if (!(active & mask)) + continue; + + len = tpm2_algorithm_to_len(tpm2_supported_algorithms[i]); + if (!len) + continue; + + put_unaligned_le16(tpm2_supported_algorithms[i], + &ev->digest_sizes[count].algorithm_id); + put_unaligned_le16(len, &ev->digest_sizes[count].digest_size); + count++; + } + + *((u8 *)ev + (event_size - 1)) = 0; + elog->log_position = log_size; + + return 0; +} + +static int tcg2_replay_eventlog(struct tcg2_event_log *elog, + struct udevice *dev, + struct tpml_digest_values *digest_list, + u32 log_position) +{ + const u32 offset = offsetof(struct tcg_pcr_event2, digests) + + offsetof(struct tpml_digest_values, digests); + u32 event_size; + u32 count; + u16 algo; + u32 pcr; + u32 pos; + u16 len; + u8 *log; + int rc; + u32 i; + + while (log_position + offset < elog->log_size) { + log = elog->log + log_position; + + pos = offsetof(struct tcg_pcr_event2, pcr_index); + pcr = get_unaligned_le32(log + pos); + pos = offsetof(struct tcg_pcr_event2, event_type); + if (!get_unaligned_le32(log + pos)) + return 0; + + pos = offsetof(struct tcg_pcr_event2, digests) + + offsetof(struct tpml_digest_values, count); + count = get_unaligned_le32(log + pos); + if (count > ARRAY_SIZE(tpm2_supported_algorithms) || + (digest_list->count && digest_list->count != count)) + return 0; + + pos = offsetof(struct tcg_pcr_event2, digests) + + offsetof(struct tpml_digest_values, digests); + for (i = 0; i < count; ++i) { + pos += offsetof(struct tpmt_ha, hash_alg); + if (log_position + pos + sizeof(u16) >= elog->log_size) + return 0; + + algo = get_unaligned_le16(log + pos); + pos += offsetof(struct tpmt_ha, digest); + switch (algo) { + case TPM2_ALG_SHA1: + case TPM2_ALG_SHA256: + case TPM2_ALG_SHA384: + case TPM2_ALG_SHA512: + len = tpm2_algorithm_to_len(algo); + break; + default: + return 0; + } + + if (digest_list->count) { + if (algo != digest_list->digests[i].hash_alg || + log_position + pos + len >= elog->log_size) + return 0; + + memcpy(digest_list->digests[i].digest.sha512, + log + pos, len); + } + + pos += len; + } + + if (log_position + pos + sizeof(u32) >= elog->log_size) + return 0; + + event_size = get_unaligned_le32(log + pos); + pos += event_size + sizeof(u32); + if (log_position + pos > elog->log_size) + return 0; + + if (digest_list->count) { + rc = tcg2_pcr_extend(dev, pcr, digest_list); + if (rc) + return rc; + } + + log_position += pos; + } + + elog->log_position = log_position; + elog->found = true; + return 0; +} + +static int tcg2_log_parse(struct udevice *dev, struct tcg2_event_log *elog) +{ + struct tpml_digest_values digest_list; + struct tcg_efi_spec_id_event *event; + struct tcg_pcr_event *log; + u32 log_active; + u32 calc_size; + u32 active; + u32 count; + u32 evsz; + u32 mask; + u16 algo; + u16 len; + int rc; + u32 i; + u16 j; + + if (elog->log_size <= offsetof(struct tcg_pcr_event, event)) + return 0; + + log = (struct tcg_pcr_event *)elog->log; + if (get_unaligned_le32(&log->pcr_index) != 0 || + get_unaligned_le32(&log->event_type) != EV_NO_ACTION) + return 0; + + for (i = 0; i < sizeof(log->digest); i++) { + if (log->digest[i]) + return 0; + } + + evsz = get_unaligned_le32(&log->event_size); + if (evsz < offsetof(struct tcg_efi_spec_id_event, digest_sizes) || + evsz + offsetof(struct tcg_pcr_event, event) > elog->log_size) + return 0; + + event = (struct tcg_efi_spec_id_event *)log->event; + if (memcmp(event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03, + sizeof(TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03))) + return 0; + + if (event->spec_version_minor != TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 || + event->spec_version_major != TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2) + return 0; + + count = get_unaligned_le32(&event->number_of_algorithms); + if (count > ARRAY_SIZE(tpm2_supported_algorithms)) + return 0; + + calc_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes) + + (sizeof(struct tcg_efi_spec_id_event_algorithm_size) * count) + + 1; + if (evsz != calc_size) + return 0; + + rc = tcg2_get_active_pcr_banks(dev, &active); + if (rc) + return rc; + + digest_list.count = 0; + log_active = 0; + + for (i = 0; i < count; ++i) { + algo = get_unaligned_le16(&event->digest_sizes[i].algorithm_id); + mask = tpm2_algorithm_to_mask(algo); + + if (!(active & mask)) + return 0; + + switch (algo) { + case TPM2_ALG_SHA1: + case TPM2_ALG_SHA256: + case TPM2_ALG_SHA384: + case TPM2_ALG_SHA512: + len = get_unaligned_le16(&event->digest_sizes[i].digest_size); + if (tpm2_algorithm_to_len(algo) != len) + return 0; + digest_list.digests[digest_list.count++].hash_alg = algo; + break; + default: + return 0; + } + + log_active |= mask; + } + + /* Ensure the previous firmware extended all the PCRs. */ + if (log_active != active) + return 0; + + /* Read PCR0 to check if previous firmware extended the PCRs or not. */ + rc = tcg2_pcr_read(dev, 0, &digest_list); + if (rc) + return rc; + + for (i = 0; i < digest_list.count; ++i) { + len = tpm2_algorithm_to_len(digest_list.digests[i].hash_alg); + for (j = 0; j < len; ++j) { + if (digest_list.digests[i].digest.sha512[j]) + break; + } + + /* PCR is non-zero; it has been extended, so skip extending. */ + if (j != len) { + digest_list.count = 0; + break; + } + } + + return tcg2_replay_eventlog(elog, dev, &digest_list, + offsetof(struct tcg_pcr_event, event) + + evsz); +} + +int tcg2_pcr_extend(struct udevice *dev, u32 pcr_index, + struct tpml_digest_values *digest_list) +{ + u32 rc; + u32 i; + + for (i = 0; i < digest_list->count; i++) { + u32 alg = digest_list->digests[i].hash_alg; + + rc = tpm2_pcr_extend(dev, pcr_index, alg, + (u8 *)&digest_list->digests[i].digest, + tpm2_algorithm_to_len(alg)); + if (rc) { + printf("%s: error pcr:%u alg:%08x\n", __func__, + pcr_index, alg); + return rc; + } + } + + return 0; +} + +int tcg2_pcr_read(struct udevice *dev, u32 pcr_index, + struct tpml_digest_values *digest_list) +{ + struct tpm_chip_priv *priv; + u32 rc; + u32 i; + + priv = dev_get_uclass_priv(dev); + if (!priv) + return -ENODEV; + + for (i = 0; i < digest_list->count; i++) { + u32 alg = digest_list->digests[i].hash_alg; + u8 *digest = (u8 *)&digest_list->digests[i].digest; + + rc = tpm2_pcr_read(dev, pcr_index, priv->pcr_select_min, alg, + digest, tpm2_algorithm_to_len(alg), NULL); + if (rc) { + printf("%s: error pcr:%u alg:%08x\n", __func__, + pcr_index, alg); + return rc; + } + } + + return 0; +} + +int tcg2_measure_data(struct udevice *dev, struct tcg2_event_log *elog, + u32 pcr_index, u32 size, const u8 *data, u32 event_type, + u32 event_size, const u8 *event) +{ + struct tpml_digest_values digest_list; + int rc; + + if (data) + rc = tcg2_create_digest(dev, data, size, &digest_list); + else + rc = tcg2_create_digest(dev, event, event_size, &digest_list); + if (rc) + return rc; + + rc = tcg2_pcr_extend(dev, pcr_index, &digest_list); + if (rc) + return rc; + + return tcg2_log_append_check(elog, pcr_index, event_type, &digest_list, + event_size, event); +} + +int tcg2_log_prepare_buffer(struct udevice *dev, struct tcg2_event_log *elog, + bool ignore_existing_log) +{ + struct tcg2_event_log log; + int rc; + + elog->log_position = 0; + elog->found = false; + + rc = tcg2_platform_get_log(dev, (void **)&log.log, &log.log_size); + if (!rc) { + log.log_position = 0; + log.found = false; + + if (!ignore_existing_log) { + rc = tcg2_log_parse(dev, &log); + if (rc) + return rc; + } + + if (elog->log_size) { + if (log.found) { + if (elog->log_size < log.log_position) + return -ENOSPC; + + /* + * Copy the discovered log into the user buffer + * if there's enough space. + */ + memcpy(elog->log, log.log, log.log_position); + } + + unmap_physmem(log.log, MAP_NOCACHE); + } else { + elog->log = log.log; + elog->log_size = log.log_size; + } + + elog->log_position = log.log_position; + elog->found = log.found; + } + + /* + * Initialize the log buffer if no log was discovered and the buffer is + * valid. User's can pass in their own buffer as a fallback if no + * memory region is found. + */ + if (!elog->found && elog->log_size) + rc = tcg2_log_init(dev, elog); + + return rc; +} + +int tcg2_measurement_init(struct udevice **dev, struct tcg2_event_log *elog, + bool ignore_existing_log) +{ + int rc; + + rc = tcg2_platform_get_tpm2(dev); + if (rc) + return rc; + + rc = tpm_auto_start(*dev); + if (rc) + return rc; + + rc = tcg2_log_prepare_buffer(*dev, elog, ignore_existing_log); + if (rc) { + tcg2_measurement_term(*dev, elog, true); + return rc; + } + + rc = tcg2_measure_event(*dev, elog, 0, EV_S_CRTM_VERSION, + strlen(version_string) + 1, + (u8 *)version_string); + if (rc) { + tcg2_measurement_term(*dev, elog, true); + return rc; + } + + return 0; +} + +void tcg2_measurement_term(struct udevice *dev, struct tcg2_event_log *elog, + bool error) +{ + u32 event = error ? 0x1 : 0xffffffff; + int i; + + for (i = 0; i < 8; ++i) + tcg2_measure_event(dev, elog, i, EV_SEPARATOR, sizeof(event), + (const u8 *)&event); + + if (elog->log) + unmap_physmem(elog->log, MAP_NOCACHE); +} + +__weak int tcg2_platform_get_log(struct udevice *dev, void **addr, u32 *size) +{ + const __be32 *addr_prop; + const __be32 *size_prop; + int asize; + int ssize; + + *addr = NULL; + *size = 0; + + addr_prop = dev_read_prop(dev, "tpm_event_log_addr", &asize); + if (!addr_prop) + addr_prop = dev_read_prop(dev, "linux,sml-base", &asize); + + size_prop = dev_read_prop(dev, "tpm_event_log_size", &ssize); + if (!size_prop) + size_prop = dev_read_prop(dev, "linux,sml-size", &ssize); + + if (addr_prop && size_prop) { + u64 a = of_read_number(addr_prop, asize / sizeof(__be32)); + u64 s = of_read_number(size_prop, ssize / sizeof(__be32)); + + *addr = map_physmem(a, s, MAP_NOCACHE); + *size = (u32)s; + } else { + struct ofnode_phandle_args args; + phys_addr_t a; + fdt_size_t s; + + if (dev_read_phandle_with_args(dev, "memory-region", NULL, 0, + 0, &args)) + return -ENODEV; + + a = ofnode_get_addr_size(args.node, "reg", &s); + if (a == FDT_ADDR_T_NONE) + return -ENOMEM; + + *addr = map_physmem(a, s, MAP_NOCACHE); + *size = (u32)s; + } + + return 0; +} + +__weak int tcg2_platform_get_tpm2(struct udevice **dev) +{ + for_each_tpm_device(*dev) { + if (tpm_get_version(*dev) == TPM_V2) + return 0; + } + + return -ENODEV; +} + +__weak void tcg2_platform_startup_error(struct udevice *dev, int rc) {} + u32 tpm2_startup(struct udevice *dev, enum tpm2_startup_types mode) { const u8 command_v2[12] = { @@ -359,6 +1048,131 @@ u32 tpm2_get_capability(struct udevice *dev, u32 capability, u32 property, return 0; }
+static int tpm2_get_num_pcr(struct udevice *dev, u32 *num_pcr) +{ + u8 response[(sizeof(struct tpms_capability_data) - + offsetof(struct tpms_capability_data, data))]; + u32 properties_offset = + offsetof(struct tpml_tagged_tpm_property, tpm_property) + + offsetof(struct tpms_tagged_property, value); + u32 ret; + + memset(response, 0, sizeof(response)); + ret = tpm2_get_capability(dev, TPM2_CAP_TPM_PROPERTIES, + TPM2_PT_PCR_COUNT, response, 1); + if (ret) + return ret; + + *num_pcr = get_unaligned_be32(response + properties_offset); + if (*num_pcr > TPM2_MAX_PCRS) { + printf("%s: too many pcrs: %u\n", __func__, *num_pcr); + return -E2BIG; + } + + return 0; +} + +static bool tpm2_is_active_pcr(struct tpms_pcr_selection *selection) +{ + int i; + + /* + * check the pcr_select. If at least one of the PCRs supports the + * algorithm add it on the active ones + */ + for (i = 0; i < selection->size_of_select; i++) { + if (selection->pcr_select[i]) + return true; + } + + return false; +} + +int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, u32 *active_pcr, + u32 *pcr_banks) +{ + u8 response[(sizeof(struct tpms_capability_data) - + offsetof(struct tpms_capability_data, data))]; + struct tpml_pcr_selection pcrs; + u32 num_pcr; + size_t i; + u32 ret; + + *supported_pcr = 0; + *active_pcr = 0; + *pcr_banks = 0; + memset(response, 0, sizeof(response)); + ret = tpm2_get_capability(dev, TPM2_CAP_PCRS, 0, response, 1); + if (ret) + return ret; + + pcrs.count = get_unaligned_be32(response); + /* + * We only support 5 algorithms for now so check against that + * instead of TPM2_NUM_PCR_BANKS + */ + if (pcrs.count > ARRAY_SIZE(tpm2_supported_algorithms) || + pcrs.count < 1) { + printf("%s: too many pcrs: %u\n", __func__, pcrs.count); + return -EMSGSIZE; + } + + ret = tpm2_get_num_pcr(dev, &num_pcr); + if (ret) + return ret; + + for (i = 0; i < pcrs.count; i++) { + /* + * Definition of TPMS_PCR_SELECTION Structure + * hash: u16 + * size_of_select: u8 + * pcr_select: u8 array + * + * The offsets depend on the number of the device PCRs + * so we have to calculate them based on that + */ + u32 hash_offset = offsetof(struct tpml_pcr_selection, selection) + + i * offsetof(struct tpms_pcr_selection, pcr_select) + + i * ((num_pcr + 7) / 8); + u32 size_select_offset = + hash_offset + offsetof(struct tpms_pcr_selection, + size_of_select); + u32 pcr_select_offset = + hash_offset + offsetof(struct tpms_pcr_selection, + pcr_select); + + pcrs.selection[i].hash = + get_unaligned_be16(response + hash_offset); + pcrs.selection[i].size_of_select = + __get_unaligned_be(response + size_select_offset); + if (pcrs.selection[i].size_of_select > TPM2_PCR_SELECT_MAX) { + printf("%s: pcrs selection too large: %u\n", __func__, + pcrs.selection[i].size_of_select); + return -ENOBUFS; + } + /* copy the array of pcr_select */ + memcpy(pcrs.selection[i].pcr_select, response + pcr_select_offset, + pcrs.selection[i].size_of_select); + } + + for (i = 0; i < pcrs.count; i++) { + u32 hash_mask = tpm2_algorithm_to_mask(pcrs.selection[i].hash); + + if (hash_mask) { + *supported_pcr |= hash_mask; + if (tpm2_is_active_pcr(&pcrs.selection[i])) + *active_pcr |= hash_mask; + } else { + printf("%s: unknown algorithm %x\n", __func__, + pcrs.selection[i].hash); + } + } + + *pcr_banks = pcrs.count; + + return 0; +} + u32 tpm2_dam_reset(struct udevice *dev, const char *pw, const ssize_t pw_sz) { u8 command_v2[COMMAND_BUFFER_SIZE] = {
Hi Eddie
On Mon, Aug 07, 2023 at 02:25:37PM -0500, Eddie James wrote:
Add TPM2 functions to support boot measurement. This includes starting up the TPM, initializing/appending the event log, and measuring the U-Boot version. Much of the code was used in the EFI subsystem, so remove it there and use the common functions.
Signed-off-by: Eddie James eajames@linux.ibm.com
Changes since v10:
- Fix compile warning for armv7 (thanks Ilias)
This doesn't apply cleanly and I think it's because of commit d12c3efe53107. This was merged after my rebase. Can you rebase on top of -master and resend?
Thanks /Ilias
Changes since v8:
- Fix log parsing again - any data corruption seen while replaying the event log was failing the entire measurement.
- Added an option to ignore the existing log. This should only be used for systems that know that U-Boot is the first stage bootloader. This is necessary because the reserved memory region may persist through resets and so U-Boot attempts to append to the previous boot's log.
Changes since v7:
- Change name of tcg2_init_log and add more documentation
- Add a check, when parsing the event log header, to ensure that the previous stage bootloader used all the active PCRs.
- Change name of tcg2_log_find_end
- Fix the greater than or equal to check to exit the log parsing
- Make sure log_position is 0 if there is any error discovering the log
- Return errors parsing the log if the data is corrupt so that we don't end up with half a log
Changes since v6:
- Added Linaro copyright for all the EFI moved code
- Changed tcg2_init_log (and by extension, tcg2_measurement_init) to copy any discovered event log to the user's log if passed in.
Changes since v5:
- Remove unused platform_get_eventlog in efi_tcg2.c
- First look for tpm_event_log_* properties instead of linux,sml-*
- Fix efi_tcg2.c compilation
- Select SHA* configs
Changes since v4:
- Remove tcg2_measure_event function and check for NULL data in tcg2_measure_data
- Use tpm_auto_startup
- Fix efi_tcg2.c compilation for removing tcg2_pcr_read function
Changes since v3:
- Reordered headers
- Refactored more of EFI code into common code Removed digest_info structure and instead used the common alg_to_mask and alg_to_len Improved event log parsing in common code to get it equivalent to EFI Common code now extends PCR if previous bootloader stage couldn't No need to allocate memory in the common code, so EFI copies the discovered buffer like it did before Rename efi measure_event function
Changes since v1:
- Refactor TPM layer functions to allow EFI system to use them, and remove duplicate EFI functions
include/efi_tcg2.h | 44 -- include/tpm-v2.h | 259 +++++++++ lib/Kconfig | 4 + lib/efi_loader/efi_tcg2.c | 1054 +++---------------------------------- lib/tpm-v2.c | 814 ++++++++++++++++++++++++++++ 5 files changed, 1154 insertions(+), 1021 deletions(-)
diff --git a/include/efi_tcg2.h b/include/efi_tcg2.h index b1c3abd097..b21c5cb3dd 100644 --- a/include/efi_tcg2.h +++ b/include/efi_tcg2.h @@ -129,50 +129,6 @@ struct efi_tcg2_boot_service_capability { #define BOOT_SERVICE_CAPABILITY_MIN \ offsetof(struct efi_tcg2_boot_service_capability, number_of_pcr_banks)
-#define TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03 "Spec ID Event03" -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2 2 -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 0 -#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2 2
- struct TCG_EfiSpecIdEventAlgorithmSize - hashing algorithm information
- @algorithm_id: algorithm defined in enum tpm2_algorithms
- @digest_size: size of the algorithm
-struct tcg_efi_spec_id_event_algorithm_size {
- u16 algorithm_id;
- u16 digest_size;
-} __packed;
- struct TCG_EfiSpecIDEventStruct - content of the event log header
- @signature: signature, set to Spec ID Event03
- @platform_class: class defined in TCG ACPI Specification
Client Common Header.
- @spec_version_minor: minor version
- @spec_version_major: major version
- @spec_version_errata: major version
- @uintn_size: size of the efi_uintn_t fields used in various
data structures used in this specification.
0x01 indicates u32 and 0x02 indicates u64
- @number_of_algorithms: hashing algorithms used in this event log
- @digest_sizes: array of number_of_algorithms pairs
1st member defines the algorithm id
2nd member defines the algorithm size
-struct tcg_efi_spec_id_event {
- u8 signature[16];
- u32 platform_class;
- u8 spec_version_minor;
- u8 spec_version_major;
- u8 spec_errata;
- u8 uintn_size;
- u32 number_of_algorithms;
- struct tcg_efi_spec_id_event_algorithm_size digest_sizes[];
-} __packed;
- struct tdEFI_TCG2_FINAL_EVENTS_TABLE - log entries after Get Event Log
- @version: version number for this structure
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 6684033deb..33dd103767 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -216,6 +216,50 @@ struct tcg_pcr_event2 { u8 event[]; } __packed;
+struct tcg_efi_spec_id_event_algorithm_size {
- u16 algorithm_id;
- u16 digest_size;
+} __packed;
+#define TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03 "Spec ID Event03" +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2 2 +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 0 +#define TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2 2
+struct tcg_efi_spec_id_event {
- u8 signature[16];
- u8 spec_errata;
- u8 uintn_size;
+} __packed;
- TPM2 Structure Tags for command/response buffers.
@@ -342,6 +386,26 @@ enum tpm2_algorithms { TPM2_ALG_SM3_256 = 0x12, };
+extern const enum tpm2_algorithms tpm2_supported_algorithms[4];
+static inline u16 tpm2_algorithm_to_len(enum tpm2_algorithms a) +{
- switch (a) {
return TPM2_SHA1_DIGEST_SIZE;
return TPM2_SHA256_DIGEST_SIZE;
return TPM2_SHA384_DIGEST_SIZE;
return TPM2_SHA512_DIGEST_SIZE;
- default:
+#define tpm2_algorithm_to_mask(a) (1 << (a))
/* NV index attributes */ enum tpm_index_attrs { TPMA_NV_PPWRITE = 1UL << 0, @@ -421,6 +485,188 @@ enum { HR_NV_INDEX = TPM_HT_NV_INDEX << HR_SHIFT, };
- struct tcg2_event_log - Container for managing the platform event log
- @log: Address of the log
- @log_position: Current entry position
- @log_size: Log space available
- @found: Boolean indicating if an existing log was discovered
+struct tcg2_event_log {
- u8 *log;
- u32 log_position;
- u32 log_size;
- bool found;
- Create a list of digests of the supported PCR banks for a given input data
- @dev TPM device
- @input Data
- @length Length of the data to calculate the digest
- @digest_list List of digests to fill in
- Return: zero on success, negative errno otherwise
struct tpml_digest_values *digest_list);
- Get the event size of the specified digests
- @digest_list List of digests for the event
- Return: Size in bytes of the event
+u32 tcg2_event_get_size(struct tpml_digest_values *digest_list);
- tcg2_get_active_pcr_banks
- @dev TPM device
- @active_pcr_banks Bitmask of PCR algorithms supported
+int tcg2_get_active_pcr_banks(struct udevice *dev, u32 *active_pcr_banks);
- tcg2_log_append - Append an event to an event log
- @pcr_index Index of the PCR
- @event_type Type of event
- @digest_list List of digests to add
- @size Size of event
- @event Event data
- @log Log buffer to append the event to
const u8 *event, u8 *log);
- Extend the PCR with specified digests
- @dev TPM device
- @digest_list List of digests to extend
- Read the PCR into a list of digests
- @dev TPM device
- Measure data into the TPM PCRs and the platform event log.
- @dev TPM device
- @log Platform event log
- @size Size of the data or 0 for event only
- @data Pointer to the data or NULL for event only
- @event_type Event log type
- @event_size Size of the event
- @event Pointer to the event
u32 event_size, const u8 *event);
+#define tcg2_measure_event(dev, elog, pcr_index, event_type, size, event) \
- tcg2_measure_data(dev, elog, pcr_index, 0, NULL, event_type, size, \
event)
- Prepare the event log buffer. This function tries to discover an existing
- event log in memory from a previous bootloader stage. If such a log exists
- and the PCRs are not extended, the log is "replayed" to extend the PCRs.
- If no log is discovered, create the log header.
- @dev TPM device
- @elog Platform event log. The log pointer and log_size
members must be initialized to either 0 or to a valid
memory region, in which case any existing log
discovered will be copied to the specified memory
region.
- @ignore_existing_log Boolean to indicate whether or not to ignore an
existing platform log in memory
bool ignore_existing_log);
- Begin measurements.
- @dev TPM device
region.
- Stop measurements and record separator events.
- @dev TPM device
- @error Boolean to indicate whether an error ocurred or not
bool error);
- Get the platform event log address and size.
- @dev TPM device
- @addr Address of the log
- @size Size of the log
+int tcg2_platform_get_log(struct udevice *dev, void **addr, u32 *size);
- Get the first TPM2 device found.
- @dev TPM device
+int tcg2_platform_get_tpm2(struct udevice **dev);
- Platform-specific function for handling TPM startup errors
- @dev TPM device
- @rc The TPM response code
+void tcg2_platform_startup_error(struct udevice *dev, int rc);
- Issue a TPM2_Startup command.
@@ -540,6 +786,19 @@ u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz, u32 tpm2_get_capability(struct udevice *dev, u32 capability, u32 property, void *buf, size_t prop_count);
- tpm2_get_pcr_info() - get the supported, active PCRs and number of banks
- @dev: TPM device
- @supported_pcr: bitmask with the algorithms supported
- @active_pcr: bitmask with the active algorithms
- @pcr_banks: number of PCR banks
- @return 0 on success, code of operation or negative errno on failure
u32 *pcr_banks);
- Issue a TPM2_DictionaryAttackLockReset command.
diff --git a/lib/Kconfig b/lib/Kconfig index c8b3ec1ec9..cd37cba511 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -423,6 +423,10 @@ config TPM bool "Trusted Platform Module (TPM) Support" depends on DM imply DM_RNG
- select SHA1
- select SHA256
- select SHA384
- select SHA512 help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index a83ae7a46c..5f0f4b5dd2 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -66,35 +66,6 @@ static bool tcg2_efi_app_invoked; static const efi_guid_t efi_guid_tcg2_protocol = EFI_TCG2_PROTOCOL_GUID; static const efi_guid_t efi_guid_final_events = EFI_TCG2_FINAL_EVENTS_TABLE_GUID;
-struct digest_info {
- u16 hash_alg;
- u32 hash_mask;
- u16 hash_len;
-static const struct digest_info hash_algo_list[] = {
TPM2_ALG_SHA1,
EFI_TCG2_BOOT_HASH_ALG_SHA1,
TPM2_SHA1_DIGEST_SIZE,
TPM2_ALG_SHA256,
EFI_TCG2_BOOT_HASH_ALG_SHA256,
TPM2_SHA256_DIGEST_SIZE,
TPM2_ALG_SHA384,
EFI_TCG2_BOOT_HASH_ALG_SHA384,
TPM2_SHA384_DIGEST_SIZE,
TPM2_ALG_SHA512,
EFI_TCG2_BOOT_HASH_ALG_SHA512,
TPM2_SHA512_DIGEST_SIZE,
struct variable_info { const u16 *name; bool accept_empty; @@ -113,46 +84,6 @@ static struct variable_info secure_variables[] = { {u"AuditMode", false, 1}, };
-#define MAX_HASH_COUNT ARRAY_SIZE(hash_algo_list)
- alg_to_mask - Get a TCG hash mask for algorithms
- @hash_alg: TCG defined algorithm
- @Return: TCG hashing algorithm bitmaps, 0 if the algorithm is not supported
-static u32 alg_to_mask(u16 hash_alg) -{
- size_t i;
if (hash_algo_list[i].hash_alg == hash_alg)
return hash_algo_list[i].hash_mask;
- alg_to_len - Get a TCG hash len for algorithms
- @Return: len of chosen algorithm, 0 if the algorithm is not supported
-static u16 alg_to_len(u16 hash_alg) -{
- size_t i;
return hash_algo_list[i].hash_len;
static bool is_tcg2_protocol_installed(void) { struct efi_handler *handler; @@ -162,145 +93,6 @@ static bool is_tcg2_protocol_installed(void) return ret == EFI_SUCCESS; }
-static u32 tcg_event_final_size(struct tpml_digest_values *digest_list) -{
- u32 len;
- size_t i;
- len = offsetof(struct tcg_pcr_event2, digests);
- len += offsetof(struct tpml_digest_values, digests);
- for (i = 0; i < digest_list->count; i++) {
len += offsetof(struct tpmt_ha, digest);
len += alg_to_len(hash_alg);
- len += sizeof(u32); /* tcg_pcr_event2 event_size*/
- return len;
-/* tcg2_pcr_extend - Extend PCRs for a TPM2 device for a given tpml_digest_values
- @dev: device
- @digest_list: list of digest algorithms to extend
- @Return: status code
-static efi_status_t tcg2_pcr_extend(struct udevice *dev, u32 pcr_index,
- u32 rc;
- size_t i;
alg_to_len(alg));
if (rc) {
EFI_PRINT("Failed to extend PCR\n");
-/* tcg2_pcr_read - Read PCRs for a TPM2 device for a given tpml_digest_values
- @dev: device
- @pcr_index: PCR index
-static efi_status_t tcg2_pcr_read(struct udevice *dev, u32 pcr_index,
- struct tpm_chip_priv *priv;
- unsigned int updates, pcr_select_min;
- u32 rc;
- size_t i;
- priv = dev_get_uclass_priv(dev);
- if (!priv)
- pcr_select_min = priv->pcr_select_min;
rc = tpm2_pcr_read(dev, pcr_index, pcr_select_min,
hash_alg, digest, alg_to_len(hash_alg),
&updates);
if (rc) {
EFI_PRINT("Failed to read PCR\n");
-/* put_event - Append an agile event to an eventlog
- @event_type: type of event added
- @digest_list: list of digest algorithms to add
- @size: size of event
- @event: event to add
- @log: log buffer to append the event
-static void put_event(u32 pcr_index, u32 event_type,
u8 event[], void *log)
- size_t pos;
- size_t i;
- u32 event_size;
* size refers to the length of event[] only, we need to check against
* the final tcg_pcr_event2 size
- event_size = size + tcg_event_final_size(digest_list);
- put_unaligned_le32(pcr_index, log);
- pos = offsetof(struct tcg_pcr_event2, event_type);
- put_unaligned_le32(event_type, (void *)((uintptr_t)log + pos));
- pos = offsetof(struct tcg_pcr_event2, digests); /* count */
- put_unaligned_le32(digest_list->count, (void *)((uintptr_t)log + pos));
put_unaligned_le16(hash_alg, (void *)((uintptr_t)log + pos));
memcpy((void *)((uintptr_t)log + pos), digest, alg_to_len(hash_alg));
- put_unaligned_le32(size, (void *)((uintptr_t)log + pos));
- memcpy((void *)((uintptr_t)log + pos), event, size);
- pos += size;
* This check should never fail. It checks the code above is
* calculating the right length for the event we are adding
log_err("Appending to the EventLog failed\n");
/* tcg2_agile_log_append - Append an agile event to an eventlog
@@ -317,7 +109,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, u32 size, u8 event[]) { void *log = (void *)((uintptr_t)event_log.buffer + event_log.pos);
- u32 event_size = size + tcg_event_final_size(digest_list);
- u32 event_size = size + tcg2_event_get_size(digest_list); struct efi_tcg2_final_events_table *final_event; efi_status_t ret = EFI_SUCCESS;
@@ -328,7 +120,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, event_log.truncated = true; return EFI_VOLUME_FULL; }
put_event(pcr_index, event_type, digest_list, size, event, log);
event_log.pos += event_size; event_log.last_event_size = event_size; }tcg2_log_append(pcr_index, event_type, digest_list, size, event, log);
@@ -341,7 +133,7 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, return EFI_VOLUME_FULL;
log = (void *)((uintptr_t)event_log.final_buffer + event_log.final_pos);
- put_event(pcr_index, event_type, digest_list, size, event, log);
final_event = event_log.final_buffer; final_event->number_of_events++;
@@ -350,66 +142,6 @@ static efi_status_t tcg2_agile_log_append(u32 pcr_index, u32 event_type, return ret; }
- platform_get_tpm_device() - retrieve TPM device
- This function retrieves the udevice implementing a TPM
- This function may be overridden if special initialization is needed.
- @dev: udevice
- Return: status code
-__weak efi_status_t platform_get_tpm2_device(struct udevice **dev) -{
- for_each_tpm_device(*dev) {
/* Only support TPMv2 devices */
return EFI_SUCCESS;
- return EFI_NOT_FOUND;
- platform_get_eventlog() - retrieve the eventlog address and size
- This function retrieves the eventlog address and size if the underlying
- firmware has done some measurements and passed them.
- This function may be overridden based on platform specific method of
- passing the eventlog address and size.
- @dev: udevice
- @addr: eventlog address
- @sz: eventlog size
-__weak efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr,
u32 *sz)
- const u64 *basep;
- const u32 *sizep;
- basep = dev_read_prop(dev, "tpm_event_log_addr", NULL);
- if (!basep)
- *addr = be64_to_cpup((__force __be64 *)basep);
- sizep = dev_read_prop(dev, "tpm_event_log_size", NULL);
- if (!sizep)
- *sz = be32_to_cpup((__force __be32 *)sizep);
- if (*sz == 0) {
log_debug("event log empty\n");
- tpm2_get_max_command_size() - get the supported max command size
@@ -485,239 +217,6 @@ static int tpm2_get_manufacturer_id(struct udevice *dev, u32 *manufacturer_id) return 0; }
- tpm2_get_num_pcr() - get the number of PCRs
- @dev: TPM device
- @manufacturer_id: output buffer for the number
- Return: 0 on success, -1 on error
-static int tpm2_get_num_pcr(struct udevice *dev, u32 *num_pcr) -{
- u8 response[TPM2_RESPONSE_BUFFER_SIZE];
- u32 ret;
- memset(response, 0, sizeof(response));
- ret = tpm2_get_capability(dev, TPM2_CAP_TPM_PROPERTIES,
- if (ret)
return -1;
- *num_pcr = get_unaligned_be32(response + properties_offset);
- if (*num_pcr > TPM2_MAX_PCRS)
return -1;
- is_active_pcr() - Check if a supported algorithm is active
- @dev: TPM device
- @selection: struct of PCR information
- Return: true if PCR is active
-static bool is_active_pcr(struct tpms_pcr_selection *selection) -{
- int i;
- for (i = 0; i < selection->size_of_select; i++) {
return true;
- return false;
- @dev: TPM device
-static int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr,
u32 *active_pcr, u32 *pcr_banks)
- struct tpml_pcr_selection pcrs;
- u32 ret, num_pcr;
- size_t i;
- int tpm_ret;
- *supported_pcr = 0;
- *active_pcr = 0;
- *pcr_banks = 0;
- ret = tpm2_get_capability(dev, TPM2_CAP_PCRS, 0, response, 1);
- if (ret)
goto out;
- pcrs.count = get_unaligned_be32(response);
- if (pcrs.count > MAX_HASH_COUNT || pcrs.count < 1)
goto out;
- tpm_ret = tpm2_get_num_pcr(dev, &num_pcr);
- if (tpm_ret)
goto out;
- for (i = 0; i < pcrs.count; i++) {
* hash: u16
size_of_select);
pcr_select);
goto out;
u32 hash_mask = alg_to_mask(pcrs.selection[i].hash);
if (hash_mask) {
if (is_active_pcr(&pcrs.selection[i]))
} else {
EFI_PRINT("Unknown algorithm %x\n", pcrs.selection[i].hash);
- *pcr_banks = pcrs.count;
-out:
- return -1;
- __get_active_pcr_banks() - returns the currently active PCR banks
- @active_pcr_banks: pointer for receiving the bitmap of currently
active PCR banks
-static efi_status_t __get_active_pcr_banks(u32 *active_pcr_banks) -{
- struct udevice *dev;
- u32 active = 0, supported = 0, pcr_banks = 0;
- efi_status_t ret;
- int err;
goto out;
- err = tpm2_get_pcr_info(dev, &supported, &active, &pcr_banks);
- if (err) {
goto out;
- *active_pcr_banks = active;
-out:
- return ret;
-/* tcg2_create_digest - create a list of digests of the supported PCR banks
for a given memory range
- @input: input memory
- @length: length of buffer to calculate the digest
- @digest_list: list of digests to fill in
-static efi_status_t tcg2_create_digest(const u8 *input, u32 length,
- sha1_context ctx;
- sha256_context ctx_256;
- sha512_context ctx_512;
- u8 final[TPM2_SHA512_DIGEST_SIZE];
- efi_status_t ret;
- u32 active;
- size_t i;
- ret = __get_active_pcr_banks(&active);
return ret;
- for (i = 0; i < MAX_HASH_COUNT; i++) {
if (!(active & alg_to_mask(hash_alg)))
continue;
switch (hash_alg) {
case TPM2_ALG_SHA1:
sha1_starts(&ctx);
break;
break;
break;
break;
default:
EFI_PRINT("Unsupported algorithm %x\n", hash_alg);
return EFI_INVALID_PARAMETER;
digest_list->digests[digest_list->count].hash_alg = hash_alg;
(u32)alg_to_len(hash_alg));
- efi_tcg2_get_capability() - protocol capability information and state information
@@ -759,7 +258,7 @@ efi_tcg2_get_capability(struct efi_tcg2_protocol *this, capability->protocol_version.major = 1; capability->protocol_version.minor = 1;
- efi_ret = platform_get_tpm2_device(&dev);
- efi_ret = tcg2_platform_get_tpm2(&dev); if (efi_ret != EFI_SUCCESS) { capability->supported_event_logs = 0; capability->hash_algorithm_bitmap = 0;
@@ -855,7 +354,7 @@ efi_tcg2_get_eventlog(struct efi_tcg2_protocol *this, goto out; }
- ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) { event_log_location = NULL; event_log_last_entry = NULL;
@@ -890,6 +389,7 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, struct efi_image_regions *regs = NULL; void *new_efi = NULL; u8 hash[TPM2_SHA512_DIGEST_SIZE];
- struct udevice *dev; efi_status_t ret; u32 active; int i;
@@ -905,16 +405,20 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, goto out; }
goto out;
ret = tcg2_get_active_pcr_banks(dev, &active); if (ret != EFI_SUCCESS) { goto out; }
- for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); i++) {
u16 hash_alg = tpm2_supported_algorithms[i];
switch (hash_alg) { case TPM2_ALG_SHA1:if (!(active & tpm2_algorithm_to_mask(hash_alg))) continue;
@@ -935,7 +439,7 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, } digest_list->digests[digest_list->count].hash_alg = hash_alg; memcpy(&digest_list->digests[digest_list->count].digest, hash,
digest_list->count++; }(u32)tpm2_algorithm_to_len(hash_alg));
@@ -975,7 +479,7 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, if (!is_tcg2_protocol_installed()) return EFI_SUCCESS;
- ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) return EFI_SECURITY_VIOLATION;
@@ -1084,7 +588,7 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, goto out; }
- ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) goto out;
@@ -1119,7 +623,7 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, ret = tcg2_hash_pe_image((void *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list); } else {
ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash,
}ret = tcg2_create_digest(dev, (u8 *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list);
@@ -1182,7 +686,7 @@ efi_tcg2_submit_command(struct efi_tcg2_protocol *this, goto out; }
@@ -1211,6 +715,7 @@ static efi_status_t EFIAPI efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, u32 *active_pcr_banks) {
if (!this || !active_pcr_banks) {
@@ -1218,8 +723,12 @@ efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, goto out; }
goto out;
- EFI_ENTRY("%p, %p", this, active_pcr_banks);
- ret = __get_active_pcr_banks(active_pcr_banks);
- ret = tcg2_get_active_pcr_banks(dev, active_pcr_banks);
out: return EFI_EXIT(ret); @@ -1270,397 +779,6 @@ static const struct efi_tcg2_protocol efi_tcg2_protocol = { .get_result_of_set_active_pcr_banks = efi_tcg2_get_result_of_set_active_pcr_banks, };
- parse_event_log_header() - Parse and verify the event log header fields
- @buffer: Pointer to the start of the eventlog
- @size: Size of the eventlog
- @pos: Return offset of the next event in buffer right
after the event header i.e specID
-static efi_status_t parse_event_log_header(void *buffer, u32 size, u32 *pos) -{
- struct tcg_pcr_event *event_header = (struct tcg_pcr_event *)buffer;
- int i = 0;
- if (size < sizeof(*event_header))
- if (get_unaligned_le32(&event_header->pcr_index) != 0 ||
get_unaligned_le32(&event_header->event_type) != EV_NO_ACTION)
- for (i = 0; i < sizeof(event_header->digest); i++) {
if (event_header->digest[i])
- *pos += sizeof(*event_header);
- parse_specid_event() - Parse and verify the specID Event in the eventlog
- @dev: udevice
- @log_size: Size of the eventlog
- @pos: [in] Offset of specID event in the eventlog buffer
after the specID
- @digest_list: list of digests in the event
- @pos Offset in the eventlog where the specID event ends
-static efi_status_t parse_specid_event(struct udevice *dev, void *buffer,
u32 log_size, u32 *pos,
- u32 spec_active = 0;
- u16 hash_alg;
- u8 vendor_sz;
- int err, i;
- if (*pos >= log_size || (*pos + sizeof(*spec_event)) > log_size)
- /* Check specID event data */
- spec_event = (struct tcg_efi_spec_id_event *)((uintptr_t)buffer + *pos);
- /* Check for signature */
- if (memcmp(spec_event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03,
sizeof(TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03))) {
log_err("specID Event: Signature mismatch\n");
- if (spec_event->spec_version_minor !=
spec_event->spec_version_major !=
spec_event->number_of_algorithms < 1) {
log_err("specID Event: Number of algorithms incorrect\n");
- alg_count = spec_event->number_of_algorithms;
- if (err)
return EFI_DEVICE_ERROR;
- digest_list->count = 0;
* We have to take care that the sequence of algorithms that we record
* in digest_list matches the sequence in eventlog.
- for (i = 0; i < alg_count; i++) {
hash_alg =
get_unaligned_le16(&spec_event->digest_sizes[i].algorithm_id);
if (!(supported & alg_to_mask(hash_alg))) {
log_err("specID Event: Unsupported algorithm\n");
digest_list->digests[digest_list->count++].hash_alg = hash_alg;
spec_active |= alg_to_mask(hash_alg);
* TCG specification expects the event log to have hashes for all
* active PCR's
- if (spec_active != active) {
* Previous stage bootloader should know all the active PCR's
* and use them in the Eventlog.
log_err("specID Event: All active hash alg not present\n");
- spec_event_size =
alg_count * sizeof(spec_event->digest_sizes[0]);
- if (*pos + spec_event_size >= log_size)
- vendor_sz = *(uint8_t *)((uintptr_t)buffer + *pos + spec_event_size);
- spec_event_size += sizeof(vendor_sz) + vendor_sz;
- *pos += spec_event_size;
- if (get_unaligned_le32(&event_header->event_size) != spec_event_size) {
log_err("specID event: header event size mismatch\n");
/* Right way to handle this can be to call SetActive PCR's */
- tcg2_parse_event() - Parse the event in the eventlog
- @dev: udevice
- @offset: [in] Offset of the event in the eventlog buffer
[out] Return offset of the next event in the buffer
- @pcr Index of the PCR in the event
-static efi_status_t tcg2_parse_event(struct udevice *dev, void *buffer,
u32 log_size, u32 *offset,
u32 *pcr)
- struct tcg_pcr_event2 *event = NULL;
- u32 count, size, event_size;
- size_t pos;
- event_size = tcg_event_final_size(digest_list);
- if (*offset >= log_size || *offset + event_size > log_size) {
log_err("Event exceeds log size\n");
- event = (struct tcg_pcr_event2 *)((uintptr_t)buffer + *offset);
- *pcr = get_unaligned_le32(&event->pcr_index);
- /* get the count */
- count = get_unaligned_le32(&event->digests.count);
- if (count != digest_list->count)
- pos += offsetof(struct tpml_digest_values, digests);
- for (int i = 0; i < digest_list->count; i++) {
u16 alg;
alg = get_unaligned_le16((void *)((uintptr_t)event + pos));
if (alg != hash_alg)
memcpy(digest, (void *)((uintptr_t)event + pos), alg_to_len(hash_alg));
pos += alg_to_len(hash_alg);
- size = get_unaligned_le32((void *)((uintptr_t)event + pos));
- event_size += size;
- pos += sizeof(u32); /* tcg_pcr_event2 event_size*/
- pos += size;
- /* make sure the calculated buffer is what we checked against */
- if (pos != event_size)
return EFI_COMPROMISED_DATA;
- if (pos > log_size)
- *offset += pos;
- tcg2_get_fw_eventlog() - Get the eventlog address and size
- If the previous firmware has passed some eventlog, this function get it's
- location and check for it's validity.
- @dev: udevice
- @log_buffer: eventlog address
- @log_sz: eventlog size
-static efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer,
size_t *log_sz)
- struct tpml_digest_values digest_list;
- void *buffer;
- efi_status_t ret;
- u32 pcr, pos;
- u64 base;
- u32 sz;
- bool extend_pcr = false;
- int i;
- ret = platform_get_eventlog(dev, &base, &sz);
return ret;
- if (sz > TPM2_EVENT_LOG_SIZE)
- buffer = (void *)(uintptr_t)base;
- pos = 0;
- /* Parse the eventlog to check for its validity */
- ret = parse_event_log_header(buffer, sz, &pos);
- if (ret)
return ret;
- ret = parse_specid_event(dev, buffer, sz, &pos, &digest_list);
- if (ret) {
log_err("Error parsing SPEC ID Event\n");
return ret;
- ret = tcg2_pcr_read(dev, 0, &digest_list);
- if (ret) {
log_err("Error reading PCR 0\n");
return ret;
* If PCR0 is 0, previous firmware didn't have the capability
* to extend the PCR. In this scenario, extend the PCR as
* the eventlog is parsed.
u8 hash_buf[TPM2_SHA512_DIGEST_SIZE] = { 0 };
extend_pcr = true;
&pcr);
if (ret) {
return ret;
if (extend_pcr) {
return ret;
u8 *digest =
- *log_sz = sz;
- return ret;
- create_specid_event() - Create the first event in the eventlog
- @dev: tpm device
- @event_header: Pointer to the final event header
- @event_size: final spec event size
size_t *event_size)
- int err;
- size_t i;
- if (err)
goto out;
alg_count++;
goto out;
- spec_event_size =
-out:
- return ret;
- tcg2_uninit - remove the final event table and free efi memory on failures
- tcg2_measure_event() - common function to add event log and extend PCR
- measure_event() - common function to add event log and extend PCR
- @dev: TPM device
- ret = tcg2_create_digest(dev, event, size, &digest_list); if (ret != EFI_SUCCESS) goto out;
return ret;
- struct tcg2_event_log elog; struct udevice *dev;
- ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) return ret;
- elog.log = event_log.buffer;
- elog.log_size = TPM2_EVENT_LOG_SIZE;
- ret = tcg2_log_prepare_buffer(dev, &elog, false);
goto free_pool;
- event_log.pos = elog.log_position;
*/* doesn't pass an eventlog.
&spec_event_size);
goto free_pool;
- if (!elog.found) ret = efi_append_scrtm_version(dev);
goto free_pool;
(u8 *)event);
- ret = measure_event(dev, pcr_index, event_type, event_size,
free(event); return ret;(u8 *)event);
(u8 *)event);
- ret = measure_event(dev, 1, EV_EFI_HANDOFF_TABLES2, event_size,
if (ret != EFI_SUCCESS) goto out;(u8 *)event);
- ret = measure_event(dev, 5, EV_EFI_GPT_EVENT, event_size, (u8 *)event);
- ret = measure_event(dev, 4, EV_EFI_ACTION,
if (ret != EFI_SUCCESS) goto out;(u8 *)EFI_CALLING_EFI_APPLICATION);
if (ret != EFI_SUCCESS) goto out; }sizeof(event), (u8 *)&event);
return ret;(u8 *)EFI_RETURNING_FROM_EFI_APPLICATION);
- ret = measure_event(dev, 5, EV_EFI_ACTION,
if (ret != EFI_SUCCESS) goto out;(u8 *)EFI_EXIT_BOOT_SERVICES_INVOCATION);
- ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) { log_warning("Missing TPMv2 device for EFI_TCG_PROTOCOL\n"); return EFI_SUCCESS;
- Copyright (c) 2023 Linaro Limited
- Copyright (c) 2018 Bootlin
- Author: Miquel Raynal miquel.raynal@bootlin.com
- TPM2_ALG_SHA1,
- TPM2_ALG_SHA256,
- TPM2_ALG_SHA384,
- TPM2_ALG_SHA512,
- u32 supported = 0;
- u32 pcr_banks = 0;
- u32 active = 0;
- int rc;
- rc = tpm2_get_pcr_info(dev, &supported, &active, &pcr_banks);
- if (rc)
return rc;
- u32 len;
- size_t i;
- for (i = 0; i < digest_list->count; ++i) {
if (!l)
continue;
- return len;
- u8 final[sizeof(union tpmu_ha)];
- sha1_context ctx;
- u32 active;
- size_t i;
- u32 len;
- int rc;
- rc = tcg2_get_active_pcr_banks(dev, &active);
- if (rc)
return rc;
- for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) {
u32 mask =
continue;
case TPM2_ALG_SHA1:
sha1_starts(&ctx);
break;
break;
break;
break;
default:
continue;
len);
- size_t len;
- size_t pos;
- u32 i;
- pos = offsetof(struct tcg_pcr_event2, pcr_index);
- put_unaligned_le32(event_type, log + pos);
- pos = offsetof(struct tcg_pcr_event2, digests) +
- put_unaligned_le32(digest_list->count, log + pos);
if (!len)
continue;
pos += len;
- put_unaligned_le32(size, log + pos);
- memcpy(log + pos, event, size);
u32 event_type,
- u32 event_size;
- u8 *log;
- event_size = size + tcg2_event_get_size(digest_list);
- if (elog->log_position + event_size > elog->log_size) {
return -ENOBUFS;
- log = elog->log + elog->log_position;
- elog->log_position += event_size;
- tcg2_log_append(pcr_index, event_type, digest_list, size, event, log);
- struct tcg_efi_spec_id_event *ev;
- struct tcg_pcr_event *log;
- u32 event_size;
- u32 count = 0;
- u32 log_size;
- u32 active;
- u32 mask;
- size_t i;
- u16 len;
- int rc;
- if (rc)
return rc;
- event_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes);
continue;
case TPM2_ALG_SHA1:
count++;
break;
default:
continue;
- event_size += 1 +
- log_size = offsetof(struct tcg_pcr_event, event) + event_size;
- if (log_size > elog->log_size) {
elog->log_size);
return -ENOBUFS;
- log = (struct tcg_pcr_event *)elog->log;
- put_unaligned_le32(0, &log->pcr_index);
- put_unaligned_le32(EV_NO_ACTION, &log->event_type);
- memset(&log->digest, 0, sizeof(log->digest));
- put_unaligned_le32(event_size, &log->event_size);
- ev = (struct tcg_efi_spec_id_event *)log->event;
- strlcpy((char *)ev->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03,
- put_unaligned_le32(0, &ev->platform_class);
- ev->spec_version_minor = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2;
- ev->spec_version_major = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2;
- ev->spec_errata = TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_ERRATA_TPM2;
- ev->uintn_size = sizeof(size_t) / sizeof(u32);
- put_unaligned_le32(count, &ev->number_of_algorithms);
- count = 0;
continue;
if (!len)
continue;
count++;
- *((u8 *)ev + (event_size - 1)) = 0;
- elog->log_position = log_size;
u32 log_position)
- const u32 offset = offsetof(struct tcg_pcr_event2, digests) +
- u32 event_size;
- u32 count;
- u16 algo;
- u32 pcr;
- u32 pos;
- u16 len;
- u8 *log;
- int rc;
- u32 i;
- while (log_position + offset < elog->log_size) {
switch (algo) {
case TPM2_ALG_SHA1:
break;
default:
log + pos, len);
pos += len;
if (rc)
return rc;
- elog->log_position = log_position;
- elog->found = true;
- struct tcg_efi_spec_id_event *event;
- u32 log_active;
- u32 calc_size;
- u32 active;
- u32 count;
- u32 evsz;
- u32 mask;
- u16 algo;
- u16 len;
- int rc;
- u32 i;
- u16 j;
- if (elog->log_size <= offsetof(struct tcg_pcr_event, event))
- if (get_unaligned_le32(&log->pcr_index) != 0 ||
- for (i = 0; i < sizeof(log->digest); i++) {
if (log->digest[i])
- evsz = get_unaligned_le32(&log->event_size);
- if (evsz < offsetof(struct tcg_efi_spec_id_event, digest_sizes) ||
- event = (struct tcg_efi_spec_id_event *)log->event;
- if (memcmp(event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03,
- if (event->spec_version_minor != TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 ||
- count = get_unaligned_le32(&event->number_of_algorithms);
- if (count > ARRAY_SIZE(tpm2_supported_algorithms))
- calc_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes) +
1;
- if (evsz != calc_size)
- if (rc)
return rc;
- digest_list.count = 0;
- log_active = 0;
- for (i = 0; i < count; ++i) {
switch (algo) {
case TPM2_ALG_SHA1:
break;
default:
log_active |= mask;
- /* Ensure the previous firmware extended all the PCRs. */
- if (log_active != active)
- /* Read PCR0 to check if previous firmware extended the PCRs or not. */
- rc = tcg2_pcr_read(dev, 0, &digest_list);
- if (rc)
return rc;
- for (i = 0; i < digest_list.count; ++i) {
break;
if (j != len) {
break;
- return tcg2_replay_eventlog(elog, dev, &digest_list,
evsz);
- u32 rc;
- u32 i;
if (rc) {
pcr_index, alg);
return rc;
- u32 rc;
- u32 i;
- if (!priv)
return -ENODEV;
if (rc) {
pcr_index, alg);
return rc;
- int rc;
- if (data)
- else
- if (rc)
return rc;
- rc = tcg2_pcr_extend(dev, pcr_index, &digest_list);
- if (rc)
return rc;
- return tcg2_log_append_check(elog, pcr_index, event_type, &digest_list,
event_size, event);
- struct tcg2_event_log log;
- int rc;
- elog->log_position = 0;
- elog->found = false;
- rc = tcg2_platform_get_log(dev, (void **)&log.log, &log.log_size);
- if (!rc) {
log.found = false;
if (rc)
return rc;
if (log.found) {
return -ENOSPC;
} else {
- if (!elog->found && elog->log_size)
- return rc;
- int rc;
- rc = tcg2_platform_get_tpm2(dev);
- if (rc)
return rc;
- rc = tpm_auto_start(*dev);
- if (rc)
return rc;
- rc = tcg2_log_prepare_buffer(*dev, elog, ignore_existing_log);
- if (rc) {
return rc;
- rc = tcg2_measure_event(*dev, elog, 0, EV_S_CRTM_VERSION,
- if (rc) {
return rc;
bool error)
- u32 event = error ? 0x1 : 0xffffffff;
- int i;
- for (i = 0; i < 8; ++i)
- if (elog->log)
- const __be32 *addr_prop;
- const __be32 *size_prop;
- int asize;
- int ssize;
- *addr = NULL;
- *size = 0;
- addr_prop = dev_read_prop(dev, "tpm_event_log_addr", &asize);
- if (!addr_prop)
- size_prop = dev_read_prop(dev, "tpm_event_log_size", &ssize);
- if (!size_prop)
- if (addr_prop && size_prop) {
*size = (u32)s;
- } else {
phys_addr_t a;
fdt_size_t s;
0, &args))
return -ENODEV;
return -ENOMEM;
*size = (u32)s;
- return -ENODEV;
- u8 response[(sizeof(struct tpms_capability_data) -
- u32 properties_offset =
- u32 ret;
- if (ret)
return ret;
- if (*num_pcr > TPM2_MAX_PCRS) {
return -E2BIG;
- int i;
return true;
- return false;
u32 *pcr_banks)
- u32 num_pcr;
- size_t i;
- u32 ret;
- *active_pcr = 0;
- *pcr_banks = 0;
- if (ret)
return ret;
- if (pcrs.count > ARRAY_SIZE(tpm2_supported_algorithms) ||
pcrs.count < 1) {
return -EMSGSIZE;
- ret = tpm2_get_num_pcr(dev, &num_pcr);
- if (ret)
return ret;
* hash: u16
size_of_select);
pcr_select);
return -ENOBUFS;
if (hash_mask) {
} else {
u32 tpm2_dam_reset(struct udevice *dev, const char *pw, const ssize_t pw_sz) { u8 command_v2[COMMAND_BUFFER_SIZE] = { -- 2.39.3
On 8/9/23 10:34, Ilias Apalodimas wrote:
Hi Eddie
Changes since v10:
Tom has started moving new stuff into next as the merge window is closed.
Best regards
Heinrich
Hi Eddie
Changes since v10:
Ah good point, I was going to let this soak on -next anyway. So please rebase against -next
Thanks /Ilias
Best regards
Heinrich
Hi Eddie
Changes since v10:
I did base this series on next actually, so it should apply there already (unless there are conflicting changes since Monday). Please let me know if I do need to rebase it.
Thanks,
Eddie
Thanks /Ilias
Best regards
Heinrich
Hi Eddie
Changes since v10:
I tried using 321d7b4d875a from next and still get an error. Patch failed at 0003 tpm: Support boot measurements hint: Use 'git am --show-current-patch=diff' to see the failed patch
Thanks /Ilias
Thanks,
Eddie
Thanks /Ilias
Best regards
Heinrich
Hi Eddie
Changes since v10: - Fix compile warning for armv7 (thanks Ilias)
OK, I'll rebase.
Thanks /Ilias
Thanks,
Eddie
Thanks /Ilias
Best regards
Heinrich
Add a configuration option to measure the boot through the bootm function. Add the measurement state to the booti and bootz paths as well.
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes since v8: - Added a configuration option to select to ignore any existing event log. This would only be selected for systems that know that U-Boot is the first stage bootloader. This is necessary because the reserved memory region may persist through resets and so U-Boot attempts to append to the previous boot's log.
Changes since v6: - Added comment for bootm_measure - Fixed line length in bootm_measure
boot/Kconfig | 32 +++++++++++++++++++++ boot/bootm.c | 74 +++++++++++++++++++++++++++++++++++++++++++++++++ cmd/booti.c | 1 + cmd/bootm.c | 2 ++ cmd/bootz.c | 1 + include/bootm.h | 11 ++++++++ include/image.h | 1 + 7 files changed, 122 insertions(+)
diff --git a/boot/Kconfig b/boot/Kconfig index a643a3d128..b160b20599 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -675,6 +675,38 @@ config LEGACY_IMAGE_FORMAT loaded. If a board needs the legacy image format support in this case, enable it here.
+config MEASURED_BOOT + bool "Measure boot images and configuration to TPM and event log" + depends on HASH && TPM_V2 + help + This option enables measurement of the boot process. Measurement + involves creating cryptographic hashes of the binary images that + are booting and storing them in the TPM. In addition, a log of + these hashes is stored in memory for the OS to verify the booted + images and configuration. Enable this if the OS has configured + some memory area for the event log and you intend to use some + attestation tools on your system. + +if MEASURED_BOOT + config MEASURE_DEVICETREE + bool "Measure the devicetree image" + default y if MEASURED_BOOT + help + On some platforms, the devicetree is not static as it may contain + random MAC addresses or other such data that changes each boot. + Therefore, it should not be measured into the TPM. In that case, + disable the measurement here. + + config MEASURE_IGNORE_LOG + bool "Ignore the existing event log" + default n + help + On platforms that use an event log memory region that persists + through system resets and are the first stage bootloader, then + this option should be enabled to ignore any existing data in the + event log memory region. +endif # MEASURED_BOOT + config SUPPORT_RAW_INITRD bool "Enable raw initrd images" help diff --git a/boot/bootm.c b/boot/bootm.c index 75f0b4a9af..c20a688749 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -22,6 +22,7 @@ #include <asm/global_data.h> #include <asm/io.h> #include <linux/sizes.h> +#include <tpm-v2.h> #if defined(CONFIG_CMD_USB) #include <usb.h> #endif @@ -673,6 +674,75 @@ int bootm_process_cmdline_env(int flags) return 0; }
+int bootm_measure(struct bootm_headers *images) +{ + int ret = 0; + + /* Skip measurement if EFI is going to do it */ + if (images->os.os == IH_OS_EFI && + IS_ENABLED(CONFIG_EFI_TCG2_PROTOCOL) && + IS_ENABLED(CONFIG_BOOTM_EFI)) + return ret; + + if (IS_ENABLED(CONFIG_MEASURED_BOOT)) { + struct tcg2_event_log elog; + struct udevice *dev; + void *initrd_buf; + void *image_buf; + const char *s; + u32 rd_len; + bool ign; + + elog.log_size = 0; + ign = IS_ENABLED(CONFIG_MEASURE_IGNORE_LOG); + ret = tcg2_measurement_init(&dev, &elog, ign); + if (ret) + return ret; + + image_buf = map_sysmem(images->os.image_start, + images->os.image_len); + ret = tcg2_measure_data(dev, &elog, 8, images->os.image_len, + image_buf, EV_COMPACT_HASH, + strlen("linux") + 1, (u8 *)"linux"); + if (ret) + goto unmap_image; + + rd_len = images->rd_end - images->rd_start; + initrd_buf = map_sysmem(images->rd_start, rd_len); + ret = tcg2_measure_data(dev, &elog, 9, rd_len, initrd_buf, + EV_COMPACT_HASH, strlen("initrd") + 1, + (u8 *)"initrd"); + if (ret) + goto unmap_initrd; + + if (IS_ENABLED(CONFIG_MEASURE_DEVICETREE)) { + ret = tcg2_measure_data(dev, &elog, 0, images->ft_len, + (u8 *)images->ft_addr, + EV_TABLE_OF_DEVICES, + strlen("dts") + 1, + (u8 *)"dts"); + if (ret) + goto unmap_initrd; + } + + s = env_get("bootargs"); + if (!s) + s = ""; + ret = tcg2_measure_data(dev, &elog, 1, strlen(s) + 1, (u8 *)s, + EV_PLATFORM_CONFIG_FLAGS, + strlen(s) + 1, (u8 *)s); + +unmap_initrd: + unmap_sysmem(initrd_buf); + +unmap_image: + unmap_sysmem(image_buf); + tcg2_measurement_term(dev, &elog, ret != 0); + } + + return ret; +} + /** * Execute selected states of the bootm command. * @@ -724,6 +794,10 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, if (!ret && (states & BOOTM_STATE_FINDOTHER)) ret = bootm_find_other(cmdtp, flag, argc, argv);
+ if (IS_ENABLED(CONFIG_MEASURED_BOOT) && !ret && + (states & BOOTM_STATE_MEASURE)) + bootm_measure(images); + /* Load the OS */ if (!ret && (states & BOOTM_STATE_LOADOS)) { iflag = bootm_disable_interrupts(); diff --git a/cmd/booti.c b/cmd/booti.c index 6ac39193db..659bb10549 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -127,6 +127,7 @@ int do_booti(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH BOOTM_STATE_RAMDISK | #endif + BOOTM_STATE_MEASURE | BOOTM_STATE_OS_PREP | BOOTM_STATE_OS_FAKE_GO | BOOTM_STATE_OS_GO, &images, 1); diff --git a/cmd/bootm.c b/cmd/bootm.c index 37c2af96e0..0c4a713e02 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -161,6 +161,8 @@ int do_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) BOOTM_STATE_OS_GO; if (IS_ENABLED(CONFIG_SYS_BOOT_RAMDISK_HIGH)) states |= BOOTM_STATE_RAMDISK; + if (IS_ENABLED(CONFIG_MEASURED_BOOT)) + states |= BOOTM_STATE_MEASURE; if (IS_ENABLED(CONFIG_PPC) || IS_ENABLED(CONFIG_MIPS)) states |= BOOTM_STATE_OS_CMDLINE; ret = do_bootm_states(cmdtp, flag, argc, argv, states, &images, 1); diff --git a/cmd/bootz.c b/cmd/bootz.c index f1423573d2..87922bfc3c 100644 --- a/cmd/bootz.c +++ b/cmd/bootz.c @@ -81,6 +81,7 @@ int do_bootz(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH BOOTM_STATE_RAMDISK | #endif + BOOTM_STATE_MEASURE | BOOTM_STATE_OS_PREP | BOOTM_STATE_OS_FAKE_GO | BOOTM_STATE_OS_GO, &images, 1); diff --git a/include/bootm.h b/include/bootm.h index 044a4797ed..76e8e38c82 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -55,6 +55,17 @@ ulong bootm_disable_interrupts(void); int bootm_find_images(int flag, int argc, char *const argv[], ulong start, ulong size);
+/* + * Measure the boot images. Measurement is the process of hashing some binary + * data and storing it into secure memory, i.e. TPM PCRs. In addition, each + * measurement is logged into the platform event log such that the operating + * system can access it and perform attestation of the boot. + * + * @images: The structure containing the various images to boot (linux, + * initrd, dts, etc.) + */ +int bootm_measure(struct bootm_headers *images); + int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[], int states, struct bootm_headers *images, int boot_progress); diff --git a/include/image.h b/include/image.h index 01a6787d21..ea492cc2b2 100644 --- a/include/image.h +++ b/include/image.h @@ -408,6 +408,7 @@ struct bootm_headers { #define BOOTM_STATE_OS_FAKE_GO 0x00000200 /* 'Almost' run the OS */ #define BOOTM_STATE_OS_GO 0x00000400 #define BOOTM_STATE_PRE_LOAD 0x00000800 +#define BOOTM_STATE_MEASURE 0x00001000 int state;
#if defined(CONFIG_LMB) && !defined(USE_HOSTCC)
Use the sandbox TPM driver to measure some boot images in a unit test case.
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v5: - Only compile in the measurement u-boot command when CONFIG_MEASURED_BOOT is enabled.
arch/sandbox/dts/sandbox.dtsi | 13 +++++++ arch/sandbox/dts/test.dts | 13 +++++++ configs/sandbox_defconfig | 1 + include/test/suites.h | 1 + test/boot/Makefile | 1 + test/boot/measurement.c | 66 +++++++++++++++++++++++++++++++++++ test/cmd_ut.c | 4 +++ 7 files changed, 99 insertions(+) create mode 100644 test/boot/measurement.c
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 30a305c4d2..ed39d20c6a 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -4,11 +4,23 @@ * and sandbox64 builds. */
+#include <config.h> #include <dt-bindings/input/input.h>
#define USB_CLASS_HUB 9
/ { + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + event_log: tcg_event_log { + no-map; + reg = <(CFG_SYS_SDRAM_SIZE - 0x2000) 0x2000>; + }; + }; + binman { };
@@ -336,6 +348,7 @@
tpm2 { compatible = "sandbox,tpm2"; + memory-region = <&event_log>; };
triangle { diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index ff9f9222e6..0bac073178 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -9,6 +9,7 @@
/dts-v1/;
+#include <config.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/sandbox-gpio.h> #include <dt-bindings/input/input.h> @@ -66,6 +67,17 @@ osd0 = "/osd"; };
+ reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + event_log: tcg_event_log { + no-map; + reg = <(CFG_SYS_SDRAM_SIZE - 0x2000) 0x2000>; + }; + }; + binman: binman { };
@@ -1365,6 +1377,7 @@
tpm { diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 1ec44d5b33..85ef821296 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -344,3 +344,4 @@ CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_MEASURED_BOOT=y diff --git a/include/test/suites.h b/include/test/suites.h index 1c7dc65966..48ed549c13 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -45,6 +45,7 @@ int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_log(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); +int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, diff --git a/test/boot/Makefile b/test/boot/Makefile index 22ed61c8fa..2dbb032a7e 100644 --- a/test/boot/Makefile +++ b/test/boot/Makefile @@ -4,6 +4,7 @@
obj-$(CONFIG_BOOTSTD) += bootdev.o bootstd_common.o bootflow.o bootmeth.o obj-$(CONFIG_FIT) += image.o +obj-$(CONFIG_MEASURED_BOOT) += measurement.o
obj-$(CONFIG_EXPO) += expo.o
diff --git a/test/boot/measurement.c b/test/boot/measurement.c new file mode 100644 index 0000000000..9db2ed324c --- /dev/null +++ b/test/boot/measurement.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Test for measured boot functions + * + * Copyright 2023 IBM Corp. + * Written by Eddie James eajames@linux.ibm.com + */ + +#include <common.h> +#include <bootm.h> +#include <malloc.h> +#include <test/suites.h> +#include <test/test.h> +#include <test/ut.h> +#include <asm/io.h> + +#define MEASUREMENT_TEST(_name, _flags) \ + UNIT_TEST(_name, _flags, measurement_test) + +static int measure(struct unit_test_state *uts) +{ + struct bootm_headers images; + const size_t size = 1024; + u8 *kernel; + u8 *initrd; + size_t i; + + kernel = malloc(size); + initrd = malloc(size); + + images.os.image_start = map_to_sysmem(kernel); + images.os.image_len = size; + + images.rd_start = map_to_sysmem(initrd); + images.rd_end = images.rd_start + size; + + images.ft_addr = malloc(size); + images.ft_len = size; + + env_set("bootargs", "measurement testing"); + + for (i = 0; i < size; ++i) { + kernel[i] = 0xf0 | (i & 0xf); + initrd[i] = (i & 0xf0) | 0xf; + images.ft_addr[i] = i & 0xff; + } + + ut_assertok(bootm_measure(&images)); + + free(images.ft_addr); + free(initrd); + free(kernel); + + return 0; +} +MEASUREMENT_TEST(measure, 0); + +int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct unit_test *tests = UNIT_TEST_SUITE_START(measurement_test); + const int n_ents = UNIT_TEST_SUITE_COUNT(measurement_test); + + return cmd_ut_category("measurement", "measurement_test_", tests, + n_ents, argc, argv); +} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 0cb514490b..23198a5064 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -99,6 +99,10 @@ static struct cmd_tbl cmd_ut_sub[] = { #if CONFIG_IS_ENABLED(UT_UNICODE) && !defined(API_BUILD) U_BOOT_CMD_MKENT(unicode, CONFIG_SYS_MAXARGS, 1, do_ut_unicode, "", ""), #endif +#ifdef CONFIG_MEASURED_BOOT + U_BOOT_CMD_MKENT(measurement, CONFIG_SYS_MAXARGS, 1, do_ut_measurement, + "", ""), +#endif #ifdef CONFIG_SANDBOX U_BOOT_CMD_MKENT(compression, CONFIG_SYS_MAXARGS, 1, do_ut_compression, "", ""),
Briefly describe the feature and specify the requirements.
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Simon Glass sjg@chromium.org --- doc/usage/index.rst | 1 + doc/usage/measured_boot.rst | 23 +++++++++++++++++++++++ 2 files changed, 24 insertions(+) create mode 100644 doc/usage/measured_boot.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 388e59f173..64eb362aef 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -13,6 +13,7 @@ Use U-Boot partitions cmdline semihosting + measured_boot
Shell commands -------------- diff --git a/doc/usage/measured_boot.rst b/doc/usage/measured_boot.rst new file mode 100644 index 0000000000..8357b1f480 --- /dev/null +++ b/doc/usage/measured_boot.rst @@ -0,0 +1,23 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Measured Boot +===================== + +U-Boot can perform a measured boot, the process of hashing various components +of the boot process, extending the results in the TPM and logging the +component's measurement in memory for the operating system to consume. + +Requirements +--------------------- + +* A hardware TPM 2.0 supported by the U-Boot drivers +* CONFIG_TPM=y +* CONFIG_MEASURED_BOOT=y +* Device-tree configuration of the TPM device to specify the memory area + for event logging. The TPM device node must either contain a phandle to + a reserved memory region or "linux,sml-base" and "linux,sml-size" + indicating the address and size of the memory region. An example can be + found in arch/sandbox/dts/test.dts +* The operating system must also be configured to use the memory regions + specified in the U-Boot device-tree in order to make use of the event + log.
efi_tcg2_get_active_pcr_banks doesn't immediately call the EFI_ENTRY() wrapper once it enters the function. Move the call a few lines above to cover the error cases properly as well.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_tcg2.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 5f0f4b5dd2..829bae7436 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -718,16 +718,16 @@ efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, struct udevice *dev; efi_status_t ret;
+ EFI_ENTRY("%p, %p", this, active_pcr_banks); + if (!this || !active_pcr_banks) { ret = EFI_INVALID_PARAMETER; goto out; } - ret = tcg2_platform_get_tpm2(&dev); if (ret != EFI_SUCCESS) goto out;
- EFI_ENTRY("%p, %p", this, active_pcr_banks); ret = tcg2_get_active_pcr_banks(dev, active_pcr_banks);
out:
We currently use PCR 0 for testing the PCR read/extend functionality in our selftests. How ever those PCRs are defined by the TCG spec for platform use. For example if the tests run *after* the efi subsystem initialization, which extends PCRs 0 & 7 it will give a false positive.
So let's switch over to a PCR which is more suitable and is defined for OS use. It's worth noting that we are using PCR10 here, since PCR9 is used internally by U-Boot if we choose to measure the loaded DTB
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- test/py/tests/test_tpm2.py | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/test/py/tests/test_tpm2.py b/test/py/tests/test_tpm2.py index fce689cd99..8cd3046285 100644 --- a/test/py/tests/test_tpm2.py +++ b/test/py/tests/test_tpm2.py @@ -236,7 +236,7 @@ def test_tpm2_dam_parameters(u_boot_console): def test_tpm2_pcr_read(u_boot_console): """Execute a TPM2_PCR_Read command.
- Perform a PCR read of the 0th PCR. Must be zero. + Perform a PCR read of the 10th PCR. Must be zero. """ if is_sandbox(u_boot_console): tpm2_sandbox_init(u_boot_console) @@ -244,7 +244,7 @@ def test_tpm2_pcr_read(u_boot_console): force_init(u_boot_console) ram = u_boot_utils.find_ram_base(u_boot_console)
- read_pcr = u_boot_console.run_command('tpm2 pcr_read 0 0x%x' % ram) + read_pcr = u_boot_console.run_command('tpm2 pcr_read 10 0x%x' % ram) output = u_boot_console.run_command('echo $?') assert output.endswith('0')
@@ -254,7 +254,7 @@ def test_tpm2_pcr_read(u_boot_console): updates = int(re.findall(r'\d+', str)[0])
# Check the output value - assert 'PCR #0 content' in read_pcr + assert 'PCR #10 content' in read_pcr assert '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' in read_pcr
@pytest.mark.buildconfigspec('cmd_tpm_v2') @@ -272,19 +272,19 @@ def test_tpm2_pcr_extend(u_boot_console): force_init(u_boot_console) ram = u_boot_utils.find_ram_base(u_boot_console)
- read_pcr = u_boot_console.run_command('tpm2 pcr_read 0 0x%x' % (ram + 0x20)) + read_pcr = u_boot_console.run_command('tpm2 pcr_read 10 0x%x' % (ram + 0x20)) output = u_boot_console.run_command('echo $?') assert output.endswith('0') str = re.findall(r'\d+ known updates', read_pcr)[0] updates = int(re.findall(r'\d+', str)[0])
- u_boot_console.run_command('tpm2 pcr_extend 0 0x%x' % ram) + u_boot_console.run_command('tpm2 pcr_extend 10 0x%x' % ram) output = u_boot_console.run_command('echo $?') assert output.endswith('0')
# Read the value back into a different place so we can still use 'ram' as # our zero bytes - read_pcr = u_boot_console.run_command('tpm2 pcr_read 0 0x%x' % (ram + 0x20)) + read_pcr = u_boot_console.run_command('tpm2 pcr_read 10 0x%x' % (ram + 0x20)) output = u_boot_console.run_command('echo $?') assert output.endswith('0') assert 'f5 a5 fd 42 d1 6a 20 30 27 98 ef 6e d3 09 97 9b' in read_pcr @@ -294,11 +294,11 @@ def test_tpm2_pcr_extend(u_boot_console): new_updates = int(re.findall(r'\d+', str)[0]) assert (updates + 1) == new_updates
- read_pcr = u_boot_console.run_command('tpm2 pcr_read 0 0x%x' % (ram + 0x20)) + read_pcr = u_boot_console.run_command('tpm2 pcr_read 10 0x%x' % (ram + 0x20)) output = u_boot_console.run_command('echo $?') assert output.endswith('0') assert '7a 05 01 f5 95 7b df 9c b3 a8 ff 49 66 f0 22 65' in read_pcr
Eddie James
Ilias Apalodimas
