The following changes since commit 44237e272f1eac3b026709e76333a07b2d3a3523:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2019-05-06 07:19:31 -0400)
git://git.denx.de/u-boot-sh.git master
for you to fetch changes up to ba932bc846e8f44b7b61fcaac41e0be907d1303e:
ARM: dts: renesas: Add RZ/A1 GR-Peach board (2019-05-07 05:41:32 +0200)
---------------------------------------------------------------- Chris Brandt (2): ARM: dts: renesas: Add RZ/A1 platform code ARM: dts: renesas: Add RZ/A1 GR-Peach board
Marek Vasut (12): sh: sh7757lcr: Fix copy-paste error in README sh: ecovec: Remove the board sh: 7724: Remove CPU support sh: sh7785lcr: Remove the board sh: 7785: Remove CPU support gpio: renesas: Add RZ/A1 R7S72100 GPIO driver pinctrl: renesas: Add RZ/A1 R7S72100 pin control driver timer: renesas: Add RZ/A1 R7S72100 OSTM timer driver serial: sh: Add RZ/A1 support net: sh_eth: Add RZ/A1 support net: sh_eth: Add support for operation without clock framework spi: rpc: Add support for operation without clock framework
arch/arm/Kconfig | 2 +- arch/arm/dts/Makefile | 3 + arch/arm/dts/r7s72100-gr-peach-u-boot.dts | 78 ++++++++++++++++ arch/arm/dts/r7s72100-gr-peach.dts | 134 +++++++++++++++++++++++++++ arch/arm/dts/r7s72100.dtsi | 705 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-rmobile/Kconfig | 5 + arch/arm/mach-rmobile/Kconfig.rza1 | 28 ++++++ arch/arm/mach-rmobile/cpu_info.c | 8 ++ arch/arm/mach-rmobile/include/mach/rmobile.h | 1 + arch/sh/Kconfig | 10 -- arch/sh/include/asm/cpu_sh4.h | 4 - arch/sh/include/asm/cpu_sh7724.h | 209 ------------------------------------------ arch/sh/include/asm/cpu_sh7785.h | 119 ------------------------ board/renesas/ecovec/MAINTAINERS | 7 -- board/renesas/ecovec/Makefile | 8 -- board/renesas/ecovec/ecovec.c | 98 -------------------- board/renesas/ecovec/lowlevel_init.S | 196 --------------------------------------- board/renesas/{ecovec => grpeach}/Kconfig | 6 +- board/renesas/grpeach/MAINTAINERS | 6 ++ board/renesas/grpeach/Makefile | 8 ++ board/renesas/grpeach/grpeach.c | 52 +++++++++++ board/renesas/grpeach/lowlevel_init.S | 107 ++++++++++++++++++++++ board/renesas/sh7757lcr/README.sh7757lcr | 2 +- board/renesas/sh7785lcr/Kconfig | 12 --- board/renesas/sh7785lcr/MAINTAINERS | 7 -- board/renesas/sh7785lcr/Makefile | 7 -- board/renesas/sh7785lcr/README.sh7785lcr | 123 ------------------------- board/renesas/sh7785lcr/lowlevel_init.S | 361 ------------------------------------------------------------------------ board/renesas/sh7785lcr/rtl8169.h | 43 --------- board/renesas/sh7785lcr/rtl8169_mac.c | 330 ------------------------------------------------------------------ board/renesas/sh7785lcr/selfcheck.c | 150 ------------------------------ board/renesas/sh7785lcr/sh7785lcr.c | 63 ------------- configs/ecovec_defconfig | 40 -------- configs/grpeach_defconfig | 53 +++++++++++ configs/sh7785lcr_32bit_defconfig | 40 -------- configs/sh7785lcr_defconfig | 39 -------- doc/README.sh | 1 - drivers/gpio/Kconfig | 6 ++ drivers/gpio/Makefile | 1 + drivers/gpio/gpio-rza1.c | 134 +++++++++++++++++++++++++++ drivers/net/sh_eth.c | 11 ++- drivers/net/sh_eth.h | 59 +++++++++++- drivers/pinctrl/renesas/Kconfig | 12 +++ drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r7s72100.c | 146 +++++++++++++++++++++++++++++ drivers/serial/serial_sh.c | 4 +- drivers/serial/serial_sh.h | 24 ++--- drivers/spi/Kconfig | 2 +- drivers/spi/renesas_rpc_spi.c | 12 ++- drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/ostm_timer.c | 92 +++++++++++++++++++ include/configs/ecovec.h | 133 --------------------------- include/configs/grpeach.h | 53 +++++++++++ include/configs/sh7785lcr.h | 128 -------------------------- include/dt-bindings/clock/r7s72100-clock.h | 112 +++++++++++++++++++++++ include/dt-bindings/pinctrl/r7s72100-pinctrl.h | 18 ++++ scripts/config_whitelist.txt | 3 - 58 files changed, 1860 insertions(+), 2164 deletions(-) create mode 100644 arch/arm/dts/r7s72100-gr-peach-u-boot.dts create mode 100644 arch/arm/dts/r7s72100-gr-peach.dts create mode 100644 arch/arm/dts/r7s72100.dtsi create mode 100644 arch/arm/mach-rmobile/Kconfig.rza1 delete mode 100644 arch/sh/include/asm/cpu_sh7724.h delete mode 100644 arch/sh/include/asm/cpu_sh7785.h delete mode 100644 board/renesas/ecovec/MAINTAINERS delete mode 100644 board/renesas/ecovec/Makefile delete mode 100644 board/renesas/ecovec/ecovec.c delete mode 100644 board/renesas/ecovec/lowlevel_init.S rename board/renesas/{ecovec => grpeach}/Kconfig (60%) create mode 100644 board/renesas/grpeach/MAINTAINERS create mode 100644 board/renesas/grpeach/Makefile create mode 100644 board/renesas/grpeach/grpeach.c create mode 100644 board/renesas/grpeach/lowlevel_init.S delete mode 100644 board/renesas/sh7785lcr/Kconfig delete mode 100644 board/renesas/sh7785lcr/MAINTAINERS delete mode 100644 board/renesas/sh7785lcr/Makefile delete mode 100644 board/renesas/sh7785lcr/README.sh7785lcr delete mode 100644 board/renesas/sh7785lcr/lowlevel_init.S delete mode 100644 board/renesas/sh7785lcr/rtl8169.h delete mode 100644 board/renesas/sh7785lcr/rtl8169_mac.c delete mode 100644 board/renesas/sh7785lcr/selfcheck.c delete mode 100644 board/renesas/sh7785lcr/sh7785lcr.c delete mode 100644 configs/ecovec_defconfig create mode 100644 configs/grpeach_defconfig delete mode 100644 configs/sh7785lcr_32bit_defconfig delete mode 100644 configs/sh7785lcr_defconfig create mode 100644 drivers/gpio/gpio-rza1.c create mode 100644 drivers/pinctrl/renesas/pfc-r7s72100.c create mode 100644 drivers/timer/ostm_timer.c delete mode 100644 include/configs/ecovec.h create mode 100644 include/configs/grpeach.h delete mode 100644 include/configs/sh7785lcr.h create mode 100644 include/dt-bindings/clock/r7s72100-clock.h create mode 100644 include/dt-bindings/pinctrl/r7s72100-pinctrl.h
