[U-Boot] [PATCH 2/3] test/fs: Check ext4 behaviour if dirent is first entry in directory block
This is a regression test for a crash happening if the first dirent in the block matches. Code tried to access a predecessor entry which does not exist. The crash happened for any block, but "." is always the first entry in the first directory block and thus easy to check for.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- test/fs/fs-test.sh | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/test/fs/fs-test.sh b/test/fs/fs-test.sh index 12450ed..cb2a765 100755 --- a/test/fs/fs-test.sh +++ b/test/fs/fs-test.sh @@ -291,6 +291,12 @@ ${PREFIX}load host${SUFFIX} $addr ${FPATH}$FILE_WRITE md5sum $addr $filesize setenv filesize # + +# Next test case checks writing a file whose dirent +# is the first in the block, which is always true for "." +# The write should fail, but the lookup should work +# Test Case 12 - Check directory traversal +${PREFIX}${WRITE} host${SUFFIX} $addr ${FPATH}. 0x10 reset
EOF @@ -471,6 +477,11 @@ function check_results() { pass_fail "TC11: 1MB write to $5 - write succeeded" check_md5 "Test Case 11b " "$1" "$2" 1 \ "TC11: 1MB write to $5 - content verified" + + # Check lookup of 'dot' directory + grep -A5 "Test Case 12 " "$1" | \ + egrep -q 'Unable to write file' + pass_fail "TC12: 1MB write to . - write denied" echo "** End $1" }
Doesn't that attempt to write a file named ".", which would end up over-writing the directory content? Unless I'm misunderstanding, that doesn't seem like a good idea.
Also, ${FPATH} might be "", "/", "something", or "something/". Appending "." to some of those won't work the same way as some others.
- # Check lookup of 'dot' directory
- grep -A5 "Test Case 12 " "$1" | \
- pass_fail "TC12: 1MB write to . - write denied"
Oh, I see; this expects the write to be denied since the destination is a directory. Perhaps that's OK. I'd rather see a read attempt though, to guarantee that even if the access does end up being allowed, the FS isn't trashed for any future tests that may be added afterwards.
"something" can not happen. The other three cases are exactly what is wanted here, as fat currently needs a relative path, with CWD being "/", and ext explicitly wants an absolute path.
U-Boot master/2016-09 crashes here without the pending ext4 fixes. IMHO after a failed test case, everything afterwards is invalid anyway, if the same fs image is used.
As soon as the image is modified, tests are no longer idempotent. Block allocation order may change, anything that allocates any resource changes the image.
Atempting a write here is done as it actually exercises a different code path. "ext4load host 0:0 0 /." reports "File not found", "ext4write host 0:0 0 /." crashes.
Kind regards,
Stefan
I don't see any code that prevents that. I think it's fairer to say that nothing currently happens to call the function with FPATH with a trailing /. Someone could easily edit the script later and add such a call without knowing about the undocumented restriction.
I note that in patch 1, the following logic:
+ if [ ! -z "$6" ]; then + FPATH=${6}/${FPATH} fi
... ends up with FPATH having a leading / for the second invocation of test_image by the main script body, since ${6} has the value `pwd`/$MOUNT_DIR. That seems to violate FAT's requirement for pathnames not to have a leading /.
That's fair.
Kind regards,
Stefan
- if [ ! -z "$6" ]; then
fiFPATH=${6}/${FPATH}
There are 6 different test runs: { sb, fs, nonfs } x { fat, ext4 }
fs and nonfs can be treated the same way, its just e.g. "ext4ls", "ls" or "fatls", "ls" resp. Thats what I called "native" in the other mail.
Now in the "sb" cases, it does not matter if the mounted image is fat or ext4 - it always uses the full absolute path to the mountpoint.
The specific requirements of ext4 (absolute path) and fat (relative path) only apply to the nonfs and fs test runs.
Kind regards,
Stefan
Brüns, Stefan
Stefan Bruens
Stefan Brüns
Stephen Warren
