[U-Boot] [PATCH 1/7] libfdt: migrate fdt_rw.c to a wrapper of scripts/dtc/libfdt/fdt_rw.c
The only difference between scripts/dtc/libfdt/fdt_rw.c and lib/libfdt/fdt_rw.c is fdt_remove_unused_strings().
It is only used by fdtgrep, so we do not need to compile it for U-Boot image. Move it to tools/libfdt/fdw_rw.c so that lib/libfdt/fdt_rw.c can be a wrapper of scripts/dtc/libfdt/fdt_rw.c.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
lib/libfdt/Makefile | 5 +- lib/libfdt/fdt_rw.c | 498 +------------------------------------------------- lib/libfdt/libfdt.h | 17 -- tools/Makefile | 6 +- tools/fdt_host.h | 17 ++ tools/fdtgrep.c | 2 +- tools/libfdt/fdt_rw.c | 35 ++++ 7 files changed, 60 insertions(+), 520 deletions(-) create mode 100644 tools/libfdt/fdt_rw.c
diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index be42e94..4e3e12f 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -11,6 +11,7 @@ obj-y += \ fdt_wip.o \ fdt_strerror.o \ fdt_sw.o \ + fdt_rw.o \ fdt_empty_tree.o \ fdt_addresses.o
@@ -18,9 +19,7 @@ obj-$(CONFIG_OF_LIBFDT_OVERLAY) += fdt_overlay.o
# Locally modified for U-Boot. # TODO: split out the local modifiction. -obj-y += \ - fdt_ro.o \ - fdt_rw.o +obj-y += fdt_ro.o
# U-Boot own file obj-y += fdt_region.o diff --git a/lib/libfdt/fdt_rw.c b/lib/libfdt/fdt_rw.c index 3dc7752..aafded0 100644 --- a/lib/libfdt/fdt_rw.c +++ b/lib/libfdt/fdt_rw.c @@ -1,496 +1,2 @@ -/* - * libfdt - Flat Device Tree manipulation - * Copyright (C) 2006 David Gibson, IBM Corporation. - * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause - */ -#include <libfdt_env.h> - -#ifndef USE_HOSTCC -#include <fdt.h> -#include <libfdt.h> -#else -#include "fdt_host.h" -#endif - -#include "libfdt_internal.h" - -static int _fdt_blocks_misordered(const void *fdt, - int mem_rsv_size, int struct_size) -{ - return (fdt_off_mem_rsvmap(fdt) < FDT_ALIGN(sizeof(struct fdt_header), 8)) - || (fdt_off_dt_struct(fdt) < - (fdt_off_mem_rsvmap(fdt) + mem_rsv_size)) - || (fdt_off_dt_strings(fdt) < - (fdt_off_dt_struct(fdt) + struct_size)) - || (fdt_totalsize(fdt) < - (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt))); -} - -static int _fdt_rw_check_header(void *fdt) -{ - FDT_CHECK_HEADER(fdt); - - if (fdt_version(fdt) < 17) - return -FDT_ERR_BADVERSION; - if (_fdt_blocks_misordered(fdt, sizeof(struct fdt_reserve_entry), - fdt_size_dt_struct(fdt))) - return -FDT_ERR_BADLAYOUT; - if (fdt_version(fdt) > 17) - fdt_set_version(fdt, 17); - - return 0; -} - -#define FDT_RW_CHECK_HEADER(fdt) \ - { \ - int __err; \ - if ((__err = _fdt_rw_check_header(fdt)) != 0) \ - return __err; \ - } - -static inline int _fdt_data_size(void *fdt) -{ - return fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt); -} - -static int _fdt_splice(void *fdt, void *splicepoint, int oldlen, int newlen) -{ - char *p = splicepoint; - char *end = (char *)fdt + _fdt_data_size(fdt); - - if (((p + oldlen) < p) || ((p + oldlen) > end)) - return -FDT_ERR_BADOFFSET; - if ((p < (char *)fdt) || ((end - oldlen + newlen) < (char *)fdt)) - return -FDT_ERR_BADOFFSET; - if ((end - oldlen + newlen) > ((char *)fdt + fdt_totalsize(fdt))) - return -FDT_ERR_NOSPACE; - memmove(p + newlen, p + oldlen, end - p - oldlen); - return 0; -} - -static int _fdt_splice_mem_rsv(void *fdt, struct fdt_reserve_entry *p, - int oldn, int newn) -{ - int delta = (newn - oldn) * sizeof(*p); - int err; - err = _fdt_splice(fdt, p, oldn * sizeof(*p), newn * sizeof(*p)); - if (err) - return err; - fdt_set_off_dt_struct(fdt, fdt_off_dt_struct(fdt) + delta); - fdt_set_off_dt_strings(fdt, fdt_off_dt_strings(fdt) + delta); - return 0; -} - -static int _fdt_splice_struct(void *fdt, void *p, - int oldlen, int newlen) -{ - int delta = newlen - oldlen; - int err; - - if ((err = _fdt_splice(fdt, p, oldlen, newlen))) - return err; - - fdt_set_size_dt_struct(fdt, fdt_size_dt_struct(fdt) + delta); - fdt_set_off_dt_strings(fdt, fdt_off_dt_strings(fdt) + delta); - return 0; -} - -static int _fdt_splice_string(void *fdt, int newlen) -{ - void *p = (char *)fdt - + fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt); - int err; - - if ((err = _fdt_splice(fdt, p, 0, newlen))) - return err; - - fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) + newlen); - return 0; -} - -static int _fdt_find_add_string(void *fdt, const char *s) -{ - char *strtab = (char *)fdt + fdt_off_dt_strings(fdt); - const char *p; - char *new; - int len = strlen(s) + 1; - int err; - - p = _fdt_find_string(strtab, fdt_size_dt_strings(fdt), s); - if (p) - /* found it */ - return (p - strtab); - - new = strtab + fdt_size_dt_strings(fdt); - err = _fdt_splice_string(fdt, len); - if (err) - return err; - - memcpy(new, s, len); - return (new - strtab); -} - -int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size) -{ - struct fdt_reserve_entry *re; - int err; - - FDT_RW_CHECK_HEADER(fdt); - - re = _fdt_mem_rsv_w(fdt, fdt_num_mem_rsv(fdt)); - err = _fdt_splice_mem_rsv(fdt, re, 0, 1); - if (err) - return err; - - re->address = cpu_to_fdt64(address); - re->size = cpu_to_fdt64(size); - return 0; -} - -int fdt_del_mem_rsv(void *fdt, int n) -{ - struct fdt_reserve_entry *re = _fdt_mem_rsv_w(fdt, n); - - FDT_RW_CHECK_HEADER(fdt); - - if (n >= fdt_num_mem_rsv(fdt)) - return -FDT_ERR_NOTFOUND; - - return _fdt_splice_mem_rsv(fdt, re, 1, 0); -} - -static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name, - int len, struct fdt_property **prop) -{ - int oldlen; - int err; - - *prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); - if (!*prop) - return oldlen; - - if ((err = _fdt_splice_struct(fdt, (*prop)->data, FDT_TAGALIGN(oldlen), - FDT_TAGALIGN(len)))) - return err; - - (*prop)->len = cpu_to_fdt32(len); - return 0; -} - -static int _fdt_add_property(void *fdt, int nodeoffset, const char *name, - int len, struct fdt_property **prop) -{ - int proplen; - int nextoffset; - int namestroff; - int err; - - if ((nextoffset = _fdt_check_node_offset(fdt, nodeoffset)) < 0) - return nextoffset; - - namestroff = _fdt_find_add_string(fdt, name); - if (namestroff < 0) - return namestroff; - - *prop = _fdt_offset_ptr_w(fdt, nextoffset); - proplen = sizeof(**prop) + FDT_TAGALIGN(len); - - err = _fdt_splice_struct(fdt, *prop, 0, proplen); - if (err) - return err; - - (*prop)->tag = cpu_to_fdt32(FDT_PROP); - (*prop)->nameoff = cpu_to_fdt32(namestroff); - (*prop)->len = cpu_to_fdt32(len); - return 0; -} - -int fdt_set_name(void *fdt, int nodeoffset, const char *name) -{ - char *namep; - int oldlen, newlen; - int err; - - FDT_RW_CHECK_HEADER(fdt); - - namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen); - if (!namep) - return oldlen; - - newlen = strlen(name); - - err = _fdt_splice_struct(fdt, namep, FDT_TAGALIGN(oldlen+1), - FDT_TAGALIGN(newlen+1)); - if (err) - return err; - - memcpy(namep, name, newlen+1); - return 0; -} - -int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, - int len, void **prop_data) -{ - struct fdt_property *prop; - int err; - - FDT_RW_CHECK_HEADER(fdt); - - err = _fdt_resize_property(fdt, nodeoffset, name, len, &prop); - if (err == -FDT_ERR_NOTFOUND) - err = _fdt_add_property(fdt, nodeoffset, name, len, &prop); - if (err) - return err; - - *prop_data = prop->data; - return 0; -} - -int fdt_setprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len) -{ - void *prop_data; - int err; - - err = fdt_setprop_placeholder(fdt, nodeoffset, name, len, &prop_data); - if (err) - return err; - - if (len) - memcpy(prop_data, val, len); - return 0; -} - -int fdt_appendprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len) -{ - struct fdt_property *prop; - int err, oldlen, newlen; - - FDT_RW_CHECK_HEADER(fdt); - - prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); - if (prop) { - newlen = len + oldlen; - err = _fdt_splice_struct(fdt, prop->data, - FDT_TAGALIGN(oldlen), - FDT_TAGALIGN(newlen)); - if (err) - return err; - prop->len = cpu_to_fdt32(newlen); - memcpy(prop->data + oldlen, val, len); - } else { - err = _fdt_add_property(fdt, nodeoffset, name, len, &prop); - if (err) - return err; - memcpy(prop->data, val, len); - } - return 0; -} - -int fdt_delprop(void *fdt, int nodeoffset, const char *name) -{ - struct fdt_property *prop; - int len, proplen; - - FDT_RW_CHECK_HEADER(fdt); - - prop = fdt_get_property_w(fdt, nodeoffset, name, &len); - if (!prop) - return len; - - proplen = sizeof(*prop) + FDT_TAGALIGN(len); - return _fdt_splice_struct(fdt, prop, proplen, 0); -} - -int fdt_add_subnode_namelen(void *fdt, int parentoffset, - const char *name, int namelen) -{ - struct fdt_node_header *nh; - int offset, nextoffset; - int nodelen; - int err; - uint32_t tag; - fdt32_t *endtag; - - FDT_RW_CHECK_HEADER(fdt); - - offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen); - if (offset >= 0) - return -FDT_ERR_EXISTS; - else if (offset != -FDT_ERR_NOTFOUND) - return offset; - - /* Try to place the new node after the parent's properties */ - fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */ - do { - offset = nextoffset; - tag = fdt_next_tag(fdt, offset, &nextoffset); - } while ((tag == FDT_PROP) || (tag == FDT_NOP)); - - nh = _fdt_offset_ptr_w(fdt, offset); - nodelen = sizeof(*nh) + FDT_TAGALIGN(namelen+1) + FDT_TAGSIZE; - - err = _fdt_splice_struct(fdt, nh, 0, nodelen); - if (err) - return err; - - nh->tag = cpu_to_fdt32(FDT_BEGIN_NODE); - memset(nh->name, 0, FDT_TAGALIGN(namelen+1)); - memcpy(nh->name, name, namelen); - endtag = (fdt32_t *)((char *)nh + nodelen - FDT_TAGSIZE); - *endtag = cpu_to_fdt32(FDT_END_NODE); - - return offset; -} - -int fdt_add_subnode(void *fdt, int parentoffset, const char *name) -{ - return fdt_add_subnode_namelen(fdt, parentoffset, name, strlen(name)); -} - -int fdt_del_node(void *fdt, int nodeoffset) -{ - int endoffset; - - FDT_RW_CHECK_HEADER(fdt); - - endoffset = _fdt_node_end_offset(fdt, nodeoffset); - if (endoffset < 0) - return endoffset; - - return _fdt_splice_struct(fdt, _fdt_offset_ptr_w(fdt, nodeoffset), - endoffset - nodeoffset, 0); -} - -static void _fdt_packblocks(const char *old, char *new, - int mem_rsv_size, int struct_size) -{ - int mem_rsv_off, struct_off, strings_off; - - mem_rsv_off = FDT_ALIGN(sizeof(struct fdt_header), 8); - struct_off = mem_rsv_off + mem_rsv_size; - strings_off = struct_off + struct_size; - - memmove(new + mem_rsv_off, old + fdt_off_mem_rsvmap(old), mem_rsv_size); - fdt_set_off_mem_rsvmap(new, mem_rsv_off); - - memmove(new + struct_off, old + fdt_off_dt_struct(old), struct_size); - fdt_set_off_dt_struct(new, struct_off); - fdt_set_size_dt_struct(new, struct_size); - - memmove(new + strings_off, old + fdt_off_dt_strings(old), - fdt_size_dt_strings(old)); - fdt_set_off_dt_strings(new, strings_off); - fdt_set_size_dt_strings(new, fdt_size_dt_strings(old)); -} - -int fdt_open_into(const void *fdt, void *buf, int bufsize) -{ - int err; - int mem_rsv_size, struct_size; - int newsize; - const char *fdtstart = fdt; - const char *fdtend = fdtstart + fdt_totalsize(fdt); - char *tmp; - - FDT_CHECK_HEADER(fdt); - - mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) - * sizeof(struct fdt_reserve_entry); - - if (fdt_version(fdt) >= 17) { - struct_size = fdt_size_dt_struct(fdt); - } else { - struct_size = 0; - while (fdt_next_tag(fdt, struct_size, &struct_size) != FDT_END) - ; - if (struct_size < 0) - return struct_size; - } - - if (!_fdt_blocks_misordered(fdt, mem_rsv_size, struct_size)) { - /* no further work necessary */ - err = fdt_move(fdt, buf, bufsize); - if (err) - return err; - fdt_set_version(buf, 17); - fdt_set_size_dt_struct(buf, struct_size); - fdt_set_totalsize(buf, bufsize); - return 0; - } - - /* Need to reorder */ - newsize = FDT_ALIGN(sizeof(struct fdt_header), 8) + mem_rsv_size - + struct_size + fdt_size_dt_strings(fdt); - - if (bufsize < newsize) - return -FDT_ERR_NOSPACE; - - /* First attempt to build converted tree at beginning of buffer */ - tmp = buf; - /* But if that overlaps with the old tree... */ - if (((tmp + newsize) > fdtstart) && (tmp < fdtend)) { - /* Try right after the old tree instead */ - tmp = (char *)(uintptr_t)fdtend; - if ((tmp + newsize) > ((char *)buf + bufsize)) - return -FDT_ERR_NOSPACE; - } - - _fdt_packblocks(fdt, tmp, mem_rsv_size, struct_size); - memmove(buf, tmp, newsize); - - fdt_set_magic(buf, FDT_MAGIC); - fdt_set_totalsize(buf, bufsize); - fdt_set_version(buf, 17); - fdt_set_last_comp_version(buf, 16); - fdt_set_boot_cpuid_phys(buf, fdt_boot_cpuid_phys(fdt)); - - return 0; -} - -int fdt_pack(void *fdt) -{ - int mem_rsv_size; - - FDT_RW_CHECK_HEADER(fdt); - - mem_rsv_size = (fdt_num_mem_rsv(fdt)+1) - * sizeof(struct fdt_reserve_entry); - _fdt_packblocks(fdt, fdt, mem_rsv_size, fdt_size_dt_struct(fdt)); - fdt_set_totalsize(fdt, _fdt_data_size(fdt)); - - return 0; -} - -int fdt_remove_unused_strings(const void *old, void *new) -{ - const struct fdt_property *old_prop; - struct fdt_property *new_prop; - int size = fdt_totalsize(old); - int next_offset, offset; - const char *str; - int ret; - int tag = FDT_PROP; - - /* Make a copy and remove the strings */ - memcpy(new, old, size); - fdt_set_size_dt_strings(new, 0); - - /* Add every property name back into the new string table */ - for (offset = 0; tag != FDT_END; offset = next_offset) { - tag = fdt_next_tag(old, offset, &next_offset); - if (tag != FDT_PROP) - continue; - old_prop = fdt_get_property_by_offset(old, offset, NULL); - new_prop = (struct fdt_property *)(unsigned long) - fdt_get_property_by_offset(new, offset, NULL); - str = fdt_string(old, fdt32_to_cpu(old_prop->nameoff)); - ret = _fdt_find_add_string(new, str); - if (ret < 0) - return ret; - new_prop->nameoff = cpu_to_fdt32(ret); - } - - return 0; -} +#include <linux/libfdt_env.h> +#include "../../scripts/dtc/libfdt/fdt_rw.c" diff --git a/lib/libfdt/libfdt.h b/lib/libfdt/libfdt.h index 6af94cb..4e2c841 100644 --- a/lib/libfdt/libfdt.h +++ b/lib/libfdt/libfdt.h @@ -1853,23 +1853,6 @@ int fdt_overlay_apply(void *fdt, void *fdto); #ifndef SWIG /* Not available in Python */ const char *fdt_strerror(int errval);
-/** - * fdt_remove_unused_strings() - Remove any unused strings from an FDT - * - * This creates a new device tree in @new with unused strings removed. The - * called can then use fdt_pack() to minimise the space consumed. - * - * @old: Old device tree blog - * @new: Place to put new device tree blob, which must be as large as - * @old - * @return - * 0, on success - * -FDT_ERR_BADOFFSET, corrupt device tree - * -FDT_ERR_NOSPACE, out of space, which should not happen unless there - * is something very wrong with the device tree input - */ -int fdt_remove_unused_strings(const void *old, void *new); - struct fdt_region { int offset; int size; diff --git a/tools/Makefile b/tools/Makefile index 4d32fe5..3274487 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -61,11 +61,11 @@ FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o
# The following files are synced with upstream DTC. # Use synced versions from scripts/dtc/libfdt/. -LIBFDT_SRCS_SYNCED := fdt.c fdt_wip.c fdt_sw.c fdt_strerror.c fdt_empty_tree.c \ - fdt_addresses.c fdt_overlay.c +LIBFDT_SRCS_SYNCED := fdt.c fdt_wip.c fdt_sw.c fdt_rw.c \ + fdt_strerror.c fdt_empty_tree.c fdt_addresses.c fdt_overlay.c # The following files are locally modified for U-Boot (unfotunately). # Use U-Boot own versions from lib/libfdt/. -LIBFDT_SRCS_UNSYNCED := fdt_ro.c fdt_rw.c fdt_region.c +LIBFDT_SRCS_UNSYNCED := fdt_ro.c fdt_region.c
LIBFDT_OBJS := $(addprefix libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_SYNCED))) \ $(addprefix lib/libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_UNSYNCED))) diff --git a/tools/fdt_host.h b/tools/fdt_host.h index 134d965..8d4aa06 100644 --- a/tools/fdt_host.h +++ b/tools/fdt_host.h @@ -11,6 +11,23 @@ #include "../include/libfdt.h" #include "../include/fdt_support.h"
+/** + * fdt_remove_unused_strings() - Remove any unused strings from an FDT + * + * This creates a new device tree in @new with unused strings removed. The + * called can then use fdt_pack() to minimise the space consumed. + * + * @old: Old device tree blog + * @new: Place to put new device tree blob, which must be as large as + * @old + * @return + * 0, on success + * -FDT_ERR_BADOFFSET, corrupt device tree + * -FDT_ERR_NOSPACE, out of space, which should not happen unless there + * is something very wrong with the device tree input + */ +int fdt_remove_unused_strings(const void *old, void *new); + int fit_check_sign(const void *working_fdt, const void *key);
#endif /* __FDT_HOST_H__ */ diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 5897b6d..7af77b7 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -16,7 +16,7 @@ #include <string.h> #include <unistd.h>
-#include "../include/libfdt.h" +#include "fdt_host.h" #include "libfdt_internal.h"
/* Define DEBUG to get some debugging output on stderr */ diff --git a/tools/libfdt/fdt_rw.c b/tools/libfdt/fdt_rw.c new file mode 100644 index 0000000..e475084 --- /dev/null +++ b/tools/libfdt/fdt_rw.c @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ +#include "fdt_host.h" +#include "../../scripts/dtc/libfdt/fdt_rw.c" + +int fdt_remove_unused_strings(const void *old, void *new) +{ + const struct fdt_property *old_prop; + struct fdt_property *new_prop; + int size = fdt_totalsize(old); + int next_offset, offset; + const char *str; + int ret; + int tag = FDT_PROP; + + /* Make a copy and remove the strings */ + memcpy(new, old, size); + fdt_set_size_dt_strings(new, 0); + + /* Add every property name back into the new string table */ + for (offset = 0; tag != FDT_END; offset = next_offset) { + tag = fdt_next_tag(old, offset, &next_offset); + if (tag != FDT_PROP) + continue; + old_prop = fdt_get_property_by_offset(old, offset, NULL); + new_prop = (struct fdt_property *)(unsigned long) + fdt_get_property_by_offset(new, offset, NULL); + str = fdt_string(old, fdt32_to_cpu(old_prop->nameoff)); + ret = _fdt_find_add_string(new, str); + if (ret < 0) + return ret; + new_prop->nameoff = cpu_to_fdt32(ret); + } + + return 0; +}
I do not remember why, but this is apparently a file-copy mistake. The file name is libfdt.h, but its content is that of libfdt_env.h
Re-import it from upstream Linux.
include/linux/libfdt.h | 22 +++++++--------------- 1 file changed, 7 insertions(+), 15 deletions(-)
diff --git a/include/linux/libfdt.h b/include/linux/libfdt.h index 2a663c6..27ba06e 100644 --- a/include/linux/libfdt.h +++ b/include/linux/libfdt.h @@ -1,17 +1,9 @@ -#ifndef _LIBFDT_ENV_H -#define _LIBFDT_ENV_H +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef _INCLUDE_LIBFDT_H_ +#define _INCLUDE_LIBFDT_H_
-#include <linux/string.h> +#include <linux/libfdt_env.h> +#include "../../scripts/dtc/libfdt/fdt.h" +#include "../../scripts/dtc/libfdt/libfdt.h"
-#include <asm/byteorder.h> - -typedef __be16 fdt16_t; -typedef __be32 fdt32_t; -typedef __be64 fdt64_t; - -#define fdt32_to_cpu(x) be32_to_cpu(x) -#define cpu_to_fdt32(x) cpu_to_be32(x) -#define fdt64_to_cpu(x) be64_to_cpu(x) -#define cpu_to_fdt64(x) cpu_to_be64(x) - -#endif /* _LIBFDT_ENV_H */ +#endif /* _INCLUDE_LIBFDT_H_ */
On 9 January 2018 at 01:34, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Or we could just delete this file, since it doesn't seem to be used.
Several host-tools use "bool" type without including <stdbool.h>. This relies on the crappy header inclusion chain.
tools/Makefile has the following line:
HOST_EXTRACFLAGS += -include $(srctree)/include/libfdt_env.h \
All host-tools are forced to include libfdt_env.h even if they are totally unrelated to FDT. Then, <stdbool.h> is indirectly included as follows:
include/libfdt_env.h -> include/linux/types.h -> <stdbool.h>
I am fixing this horrible crap. In advance, I need to add necessary include directives explicitly. tools/fdtgrep.c needs more; <fctl.h> for open() and <errno.h> for errno.
tools/fdtgrep.c | 3 +++ tools/gen_ethaddr_crc.c | 1 + tools/ifdtool.c | 1 + tools/imagetool.h | 1 + tools/mips-relocs.c | 1 + 5 files changed, 7 insertions(+)
diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 7af77b7..8d33205 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -10,7 +10,10 @@
#include <assert.h> #include <ctype.h> +#include <errno.h> #include <getopt.h> +#include <fcntl.h> +#include <stdbool.h> #include <stdio.h> #include <stdlib.h> #include <string.h> diff --git a/tools/gen_ethaddr_crc.c b/tools/gen_ethaddr_crc.c index fe9896d..8cf86f4 100644 --- a/tools/gen_ethaddr_crc.c +++ b/tools/gen_ethaddr_crc.c @@ -6,6 +6,7 @@ */
#include <ctype.h> +#include <stdbool.h> #include <stdint.h> #include <stdio.h> #include <stdlib.h> diff --git a/tools/ifdtool.c b/tools/ifdtool.c index 195b153..729991e 100644 --- a/tools/ifdtool.c +++ b/tools/ifdtool.c @@ -12,6 +12,7 @@ #include <assert.h> #include <fcntl.h> #include <getopt.h> +#include <stdbool.h> #include <stdlib.h> #include <stdio.h> #include <string.h> diff --git a/tools/imagetool.h b/tools/imagetool.h index a8d5054..e67de9b 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -12,6 +12,7 @@ #include "os_support.h" #include <errno.h> #include <fcntl.h> +#include <stdbool.h> #include <stdio.h> #include <stdlib.h> #include <string.h> diff --git a/tools/mips-relocs.c b/tools/mips-relocs.c index 8be69d3..27d4730 100644 --- a/tools/mips-relocs.c +++ b/tools/mips-relocs.c @@ -11,6 +11,7 @@ #include <errno.h> #include <fcntl.h> #include <limits.h> +#include <stdbool.h> #include <stdio.h> #include <stdlib.h> #include <sys/mman.h>
On Tue, Jan 9, 2018 at 3:34 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
include/libfdt.h is a wrapper of lib/libfdt/libfdt.h, but lib/libfdt/ is no longer a central point of libfdt. (Now, scripts/dtc/libfdt is synced with upstream)
Move the content to include/libfdt.h, then delete lib/libfdt/libfdt.h.
include/libfdt.h | 2154 ++++++++++++++++++++++++++++++++++++++++++++++++++- lib/libfdt/libfdt.h | 2153 -------------------------------------------------- 2 files changed, 2153 insertions(+), 2154 deletions(-) delete mode 100644 lib/libfdt/libfdt.h
diff --git a/include/libfdt.h b/include/libfdt.h index 7ba13e6..4e2c841 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -1 +1,2153 @@ -#include "../lib/libfdt/libfdt.h" +#ifndef _LIBFDT_H +#define _LIBFDT_H +/* + * libfdt - Flat Device Tree manipulation + * Copyright (C) 2006 David Gibson, IBM Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause + */ + +#include <libfdt_env.h> +#include <fdt.h> + +#define FDT_FIRST_SUPPORTED_VERSION 0x10 +#define FDT_LAST_SUPPORTED_VERSION 0x11 + +/* Error codes: informative error codes */ +#define FDT_ERR_NOTFOUND 1 + /* FDT_ERR_NOTFOUND: The requested node or property does not exist */ +#define FDT_ERR_EXISTS 2 + /* FDT_ERR_EXISTS: Attempted to create a node or property which + * already exists */ +#define FDT_ERR_NOSPACE 3 + /* FDT_ERR_NOSPACE: Operation needed to expand the device + * tree, but its buffer did not have sufficient space to + * contain the expanded tree. Use fdt_open_into() to move the + * device tree to a buffer with more space. */ + +/* Error codes: codes for bad parameters */ +#define FDT_ERR_BADOFFSET 4 + /* FDT_ERR_BADOFFSET: Function was passed a structure block + * offset which is out-of-bounds, or which points to an + * unsuitable part of the structure for the operation. */ +#define FDT_ERR_BADPATH 5 + /* FDT_ERR_BADPATH: Function was passed a badly formatted path + * (e.g. missing a leading / for a function which requires an + * absolute path) */ +#define FDT_ERR_BADPHANDLE 6 + /* FDT_ERR_BADPHANDLE: Function was passed an invalid phandle. + * This can be caused either by an invalid phandle property + * length, or the phandle value was either 0 or -1, which are + * not permitted. */ +#define FDT_ERR_BADSTATE 7 + /* FDT_ERR_BADSTATE: Function was passed an incomplete device + * tree created by the sequential-write functions, which is + * not sufficiently complete for the requested operation. */ + +/* Error codes: codes for bad device tree blobs */ +#define FDT_ERR_TRUNCATED 8 + /* FDT_ERR_TRUNCATED: Structure block of the given device tree + * ends without an FDT_END tag. */ +#define FDT_ERR_BADMAGIC 9 + /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a + * device tree at all - it is missing the flattened device + * tree magic number. */ +#define FDT_ERR_BADVERSION 10 + /* FDT_ERR_BADVERSION: Given device tree has a version which + * can't be handled by the requested operation. For + * read-write functions, this may mean that fdt_open_into() is + * required to convert the tree to the expected version. */ +#define FDT_ERR_BADSTRUCTURE 11 + /* FDT_ERR_BADSTRUCTURE: Given device tree has a corrupt + * structure block or other serious error (e.g. misnested + * nodes, or subnodes preceding properties). */ +#define FDT_ERR_BADLAYOUT 12 + /* FDT_ERR_BADLAYOUT: For read-write functions, the given + * device tree has it's sub-blocks in an order that the + * function can't handle (memory reserve map, then structure, + * then strings). Use fdt_open_into() to reorganize the tree + * into a form suitable for the read-write operations. */ + +/* "Can't happen" error indicating a bug in libfdt */ +#define FDT_ERR_INTERNAL 13 + /* FDT_ERR_INTERNAL: libfdt has failed an internal assertion. + * Should never be returned, if it is, it indicates a bug in + * libfdt itself. */ + +/* Errors in device tree content */ +#define FDT_ERR_BADNCELLS 14 + /* FDT_ERR_BADNCELLS: Device tree has a #address-cells, #size-cells + * or similar property with a bad format or value */ + +#define FDT_ERR_BADVALUE 15 + /* FDT_ERR_BADVALUE: Device tree has a property with an unexpected + * value. For example: a property expected to contain a string list + * is not NUL-terminated within the length of its value. */ + +#define FDT_ERR_BADOVERLAY 16 + /* FDT_ERR_BADOVERLAY: The device tree overlay, while + * correctly structured, cannot be applied due to some + * unexpected or missing value, property or node. */ + +#define FDT_ERR_NOPHANDLES 17 + /* FDT_ERR_NOPHANDLES: The device tree doesn't have any + * phandle available anymore without causing an overflow */ + +#define FDT_ERR_MAX 17 + +/**********************************************************************/ +/* Low-level functions (you probably don't need these) */ +/**********************************************************************/ + +#ifndef SWIG /* This function is not useful in Python */ +const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int checklen); +#endif +static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen) +{ + return (void *)(uintptr_t)fdt_offset_ptr(fdt, offset, checklen); +} + +uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset); + +/**********************************************************************/ +/* Traversal functions */ +/**********************************************************************/ + +int fdt_next_node(const void *fdt, int offset, int *depth); + +/** + * fdt_first_subnode() - get offset of first direct subnode + * + * @fdt: FDT blob + * @offset: Offset of node to check + * @return offset of first subnode, or -FDT_ERR_NOTFOUND if there is none + */ +int fdt_first_subnode(const void *fdt, int offset); + +/** + * fdt_next_subnode() - get offset of next direct subnode + * + * After first calling fdt_first_subnode(), call this function repeatedly to + * get direct subnodes of a parent node. + * + * @fdt: FDT blob + * @offset: Offset of previous subnode + * @return offset of next subnode, or -FDT_ERR_NOTFOUND if there are no more + * subnodes + */ +int fdt_next_subnode(const void *fdt, int offset); + +/** + * fdt_for_each_subnode - iterate over all subnodes of a parent + * + * @node: child node (int, lvalue) + * @fdt: FDT blob (const void *) + * @parent: parent node (int) + * + * This is actually a wrapper around a for loop and would be used like so: + * + * fdt_for_each_subnode(node, fdt, parent) { + * Use node + * ... + * } + * + * if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) { + * Error handling + * } + * + * Note that this is implemented as a macro and @node is used as + * iterator in the loop. The parent variable be constant or even a + * literal. + * + */ +#define fdt_for_each_subnode(node, fdt, parent) \ + for (node = fdt_first_subnode(fdt, parent); \ + node >= 0; \ + node = fdt_next_subnode(fdt, node)) + +/**********************************************************************/ +/* General functions */ +/**********************************************************************/ +#define fdt_get_header(fdt, field) \ + (fdt32_to_cpu(((const struct fdt_header *)(fdt))->field)) +#define fdt_magic(fdt) (fdt_get_header(fdt, magic)) +#define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) +#define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) +#define fdt_off_dt_strings(fdt) (fdt_get_header(fdt, off_dt_strings)) +#define fdt_off_mem_rsvmap(fdt) (fdt_get_header(fdt, off_mem_rsvmap)) +#define fdt_version(fdt) (fdt_get_header(fdt, version)) +#define fdt_last_comp_version(fdt) (fdt_get_header(fdt, last_comp_version)) +#define fdt_boot_cpuid_phys(fdt) (fdt_get_header(fdt, boot_cpuid_phys)) +#define fdt_size_dt_strings(fdt) (fdt_get_header(fdt, size_dt_strings)) +#define fdt_size_dt_struct(fdt) (fdt_get_header(fdt, size_dt_struct)) + +#define __fdt_set_hdr(name) \ + static inline void fdt_set_##name(void *fdt, uint32_t val) \ + { \ + struct fdt_header *fdth = (struct fdt_header *)fdt; \ + fdth->name = cpu_to_fdt32(val); \ + } +__fdt_set_hdr(magic); +__fdt_set_hdr(totalsize); +__fdt_set_hdr(off_dt_struct); +__fdt_set_hdr(off_dt_strings); +__fdt_set_hdr(off_mem_rsvmap); +__fdt_set_hdr(version); +__fdt_set_hdr(last_comp_version); +__fdt_set_hdr(boot_cpuid_phys); +__fdt_set_hdr(size_dt_strings); +__fdt_set_hdr(size_dt_struct); +#undef __fdt_set_hdr + +/** + * fdt_check_header - sanity check a device tree or possible device tree + * @fdt: pointer to data which might be a flattened device tree + * + * fdt_check_header() checks that the given buffer contains what + * appears to be a flattened device tree with sane information in its + * header. + * + * returns: + * 0, if the buffer appears to contain a valid device tree + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, standard meanings, as above + */ +int fdt_check_header(const void *fdt); + +/** + * fdt_move - move a device tree around in memory + * @fdt: pointer to the device tree to move + * @buf: pointer to memory where the device is to be moved + * @bufsize: size of the memory space at buf + * + * fdt_move() relocates, if possible, the device tree blob located at + * fdt to the buffer at buf of size bufsize. The buffer may overlap + * with the existing device tree blob at fdt. Therefore, + * fdt_move(fdt, fdt, fdt_totalsize(fdt)) + * should always succeed. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, bufsize is insufficient to contain the device tree + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, standard meanings + */ +int fdt_move(const void *fdt, void *buf, int bufsize); + +/**********************************************************************/ +/* Read-only functions */ +/**********************************************************************/ + +/** + * fdt_string - retrieve a string from the strings block of a device tree + * @fdt: pointer to the device tree blob + * @stroffset: offset of the string within the strings block (native endian) + * + * fdt_string() retrieves a pointer to a single string from the + * strings block of the device tree blob at fdt. + * + * returns: + * a pointer to the string, on success + * NULL, if stroffset is out of bounds + */ +const char *fdt_string(const void *fdt, int stroffset); + +/** + * fdt_get_max_phandle - retrieves the highest phandle in a tree + * @fdt: pointer to the device tree blob + * + * fdt_get_max_phandle retrieves the highest phandle in the given + * device tree. This will ignore badly formatted phandles, or phandles + * with a value of 0 or -1. + * + * returns: + * the highest phandle on success + * 0, if no phandle was found in the device tree + * -1, if an error occurred + */ +uint32_t fdt_get_max_phandle(const void *fdt); + +/** + * fdt_num_mem_rsv - retrieve the number of memory reserve map entries + * @fdt: pointer to the device tree blob + * + * Returns the number of entries in the device tree blob's memory + * reservation map. This does not include the terminating 0,0 entry + * or any other (0,0) entries reserved for expansion. + * + * returns: + * the number of entries + */ +int fdt_num_mem_rsv(const void *fdt); + +/** + * fdt_get_mem_rsv - retrieve one memory reserve map entry + * @fdt: pointer to the device tree blob + * @address, @size: pointers to 64-bit variables + * + * On success, *address and *size will contain the address and size of + * the n-th reserve map entry from the device tree blob, in + * native-endian format. + * + * returns: + * 0, on success + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, standard meanings + */ +int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size); + +/** + * fdt_subnode_offset_namelen - find a subnode based on substring + * @fdt: pointer to the device tree blob + * @parentoffset: structure block offset of a node + * @name: name of the subnode to locate + * @namelen: number of characters of name to consider + * + * Identical to fdt_subnode_offset(), but only examine the first + * namelen characters of name for matching the subnode name. This is + * useful for finding subnodes based on a portion of a larger string, + * such as a full path. + */ +#ifndef SWIG /* Not available in Python */ +int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, + const char *name, int namelen); +#endif +/** + * fdt_subnode_offset - find a subnode of a given node + * @fdt: pointer to the device tree blob + * @parentoffset: structure block offset of a node + * @name: name of the subnode to locate + * + * fdt_subnode_offset() finds a subnode of the node at structure block + * offset parentoffset with the given name. name may include a unit + * address, in which case fdt_subnode_offset() will find the subnode + * with that unit address, or the unit address may be omitted, in + * which case fdt_subnode_offset() will find an arbitrary subnode + * whose name excluding unit address matches the given name. + * + * returns: + * structure block offset of the requested subnode (>=0), on success + * -FDT_ERR_NOTFOUND, if the requested subnode does not exist + * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE + * tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings. + */ +int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name); + +/** + * fdt_path_offset_namelen - find a tree node by its full path + * @fdt: pointer to the device tree blob + * @path: full path of the node to locate + * @namelen: number of characters of path to consider + * + * Identical to fdt_path_offset(), but only consider the first namelen + * characters of path as the path name. + */ +#ifndef SWIG /* Not available in Python */ +int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen); +#endif + +/** + * fdt_path_offset - find a tree node by its full path + * @fdt: pointer to the device tree blob + * @path: full path of the node to locate + * + * fdt_path_offset() finds a node of a given path in the device tree. + * Each path component may omit the unit address portion, but the + * results of this are undefined if any such path component is + * ambiguous (that is if there are multiple nodes at the relevant + * level matching the given component, differentiated only by unit + * address). + * + * returns: + * structure block offset of the node with the requested path (>=0), on + * success + * -FDT_ERR_BADPATH, given path does not begin with '/' or is invalid + * -FDT_ERR_NOTFOUND, if the requested node does not exist + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings. + */ +int fdt_path_offset(const void *fdt, const char *path); + +/** + * fdt_get_name - retrieve the name of a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: structure block offset of the starting node + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_get_name() retrieves the name (including unit address) of the + * device tree node at structure block offset nodeoffset. If lenp is + * non-NULL, the length of this name is also returned, in the integer + * pointed to by lenp. + * + * returns: + * pointer to the node's name, on success + * If lenp is non-NULL, *lenp contains the length of that name + * (>=0) + * NULL, on error + * if lenp is non-NULL *lenp contains an error code (<0): + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE + * tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, standard meanings + */ +const char *fdt_get_name(const void *fdt, int nodeoffset, int *lenp); + +/** + * fdt_first_property_offset - find the offset of a node's first property + * @fdt: pointer to the device tree blob + * @nodeoffset: structure block offset of a node + * + * fdt_first_property_offset() finds the first property of the node at + * the given structure block offset. + * + * returns: + * structure block offset of the property (>=0), on success + * -FDT_ERR_NOTFOUND, if the requested node has no properties + * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings. + */ +int fdt_first_property_offset(const void *fdt, int nodeoffset); + +/** + * fdt_next_property_offset - step through a node's properties + * @fdt: pointer to the device tree blob + * @offset: structure block offset of a property + * + * fdt_next_property_offset() finds the property immediately after the + * one at the given structure block offset. This will be a property + * of the same node as the given property. + * + * returns: + * structure block offset of the next property (>=0), on success + * -FDT_ERR_NOTFOUND, if the given property is the last in its node + * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_PROP tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings. + */ +int fdt_next_property_offset(const void *fdt, int offset); + +/** + * fdt_for_each_property_offset - iterate over all properties of a node + * + * @property_offset: property offset (int, lvalue) + * @fdt: FDT blob (const void *) + * @node: node offset (int) + * + * This is actually a wrapper around a for loop and would be used like so: + * + * fdt_for_each_property_offset(property, fdt, node) { + * Use property + * ... + * } + * + * if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) { + * Error handling + * } + * + * Note that this is implemented as a macro and property is used as + * iterator in the loop. The node variable can be constant or even a + * literal. + */ +#define fdt_for_each_property_offset(property, fdt, node) \ + for (property = fdt_first_property_offset(fdt, node); \ + property >= 0; \ + property = fdt_next_property_offset(fdt, property)) + +/** + * fdt_get_property_by_offset - retrieve the property at a given offset + * @fdt: pointer to the device tree blob + * @offset: offset of the property to retrieve + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_get_property_by_offset() retrieves a pointer to the + * fdt_property structure within the device tree blob at the given + * offset. If lenp is non-NULL, the length of the property value is + * also returned, in the integer pointed to by lenp. + * + * returns: + * pointer to the structure representing the property + * if lenp is non-NULL, *lenp contains the length of the property + * value (>=0) + * NULL, on error + * if lenp is non-NULL, *lenp contains an error code (<0): + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +const struct fdt_property *fdt_get_property_by_offset(const void *fdt, + int offset, + int *lenp); + +/** + * fdt_get_property_namelen - find a property based on substring + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to find + * @name: name of the property to find + * @namelen: number of characters of name to consider + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * Identical to fdt_get_property(), but only examine the first namelen + * characters of name for matching the property name. + */ +#ifndef SWIG /* Not available in Python */ +const struct fdt_property *fdt_get_property_namelen(const void *fdt, + int nodeoffset, + const char *name, + int namelen, int *lenp); +#endif + +/** + * fdt_get_property - find a given property in a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to find + * @name: name of the property to find + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_get_property() retrieves a pointer to the fdt_property + * structure within the device tree blob corresponding to the property + * named 'name' of the node at offset nodeoffset. If lenp is + * non-NULL, the length of the property value is also returned, in the + * integer pointed to by lenp. + * + * returns: + * pointer to the structure representing the property + * if lenp is non-NULL, *lenp contains the length of the property + * value (>=0) + * NULL, on error + * if lenp is non-NULL, *lenp contains an error code (<0): + * -FDT_ERR_NOTFOUND, node does not have named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE + * tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, + const char *name, int *lenp); +static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, + const char *name, + int *lenp) +{ + return (struct fdt_property *)(uintptr_t) + fdt_get_property(fdt, nodeoffset, name, lenp); +} + +/** + * fdt_getprop_by_offset - retrieve the value of a property at a given offset + * @fdt: pointer to the device tree blob + * @ffset: offset of the property to read + * @namep: pointer to a string variable (will be overwritten) or NULL + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_getprop_by_offset() retrieves a pointer to the value of the + * property at structure block offset 'offset' (this will be a pointer + * to within the device blob itself, not a copy of the value). If + * lenp is non-NULL, the length of the property value is also + * returned, in the integer pointed to by lenp. If namep is non-NULL, + * the property's namne will also be returned in the char * pointed to + * by namep (this will be a pointer to within the device tree's string + * block, not a new copy of the name). + * + * returns: + * pointer to the property's value + * if lenp is non-NULL, *lenp contains the length of the property + * value (>=0) + * if namep is non-NULL *namep contiains a pointer to the property + * name. + * NULL, on error + * if lenp is non-NULL, *lenp contains an error code (<0): + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#ifndef SWIG /* This function is not useful in Python */ +const void *fdt_getprop_by_offset(const void *fdt, int offset, + const char **namep, int *lenp); +#endif + +/** + * fdt_getprop_namelen - get property value based on substring + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to find + * @name: name of the property to find + * @namelen: number of characters of name to consider + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * Identical to fdt_getprop(), but only examine the first namelen + * characters of name for matching the property name. + */ +#ifndef SWIG /* Not available in Python */ +const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, + const char *name, int namelen, int *lenp); +static inline void *fdt_getprop_namelen_w(void *fdt, int nodeoffset, + const char *name, int namelen, + int *lenp) +{ + return (void *)(uintptr_t)fdt_getprop_namelen(fdt, nodeoffset, name, + namelen, lenp); +} +#endif + +/** + * fdt_getprop - retrieve the value of a given property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to find + * @name: name of the property to find + * @lenp: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_getprop() retrieves a pointer to the value of the property + * named 'name' of the node at offset nodeoffset (this will be a + * pointer to within the device blob itself, not a copy of the value). + * If lenp is non-NULL, the length of the property value is also + * returned, in the integer pointed to by lenp. + * + * returns: + * pointer to the property's value + * if lenp is non-NULL, *lenp contains the length of the property + * value (>=0) + * NULL, on error + * if lenp is non-NULL, *lenp contains an error code (<0): + * -FDT_ERR_NOTFOUND, node does not have named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE + * tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +const void *fdt_getprop(const void *fdt, int nodeoffset, + const char *name, int *lenp); +static inline void *fdt_getprop_w(void *fdt, int nodeoffset, + const char *name, int *lenp) +{ + return (void *)(uintptr_t)fdt_getprop(fdt, nodeoffset, name, lenp); +} + +/** + * fdt_get_phandle - retrieve the phandle of a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: structure block offset of the node + * + * fdt_get_phandle() retrieves the phandle of the device tree node at + * structure block offset nodeoffset. + * + * returns: + * the phandle of the node at nodeoffset, on success (!= 0, != -1) + * 0, if the node has no phandle, or another error occurs + */ +uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); + +/** + * fdt_get_alias_namelen - get alias based on substring + * @fdt: pointer to the device tree blob + * @name: name of the alias th look up + * @namelen: number of characters of name to consider + * + * Identical to fdt_get_alias(), but only examine the first namelen + * characters of name for matching the alias name. + */ +#ifndef SWIG /* Not available in Python */ +const char *fdt_get_alias_namelen(const void *fdt, + const char *name, int namelen); +#endif + +/** + * fdt_get_alias - retrieve the path referenced by a given alias + * @fdt: pointer to the device tree blob + * @name: name of the alias th look up + * + * fdt_get_alias() retrieves the value of a given alias. That is, the + * value of the property named 'name' in the node /aliases. + * + * returns: + * a pointer to the expansion of the alias named 'name', if it exists + * NULL, if the given alias or the /aliases node does not exist + */ +const char *fdt_get_alias(const void *fdt, const char *name); + +/** + * fdt_get_path - determine the full path of a node + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose path to find + * @buf: character buffer to contain the returned path (will be overwritten) + * @buflen: size of the character buffer at buf + * + * fdt_get_path() computes the full path of the node at offset + * nodeoffset, and records that path in the buffer at buf. + * + * NOTE: This function is expensive, as it must scan the device tree + * structure from the start to nodeoffset. + * + * returns: + * 0, on success + * buf contains the absolute path of the node at + * nodeoffset, as a NUL-terminated string. + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_NOSPACE, the path of the given node is longer than (bufsize-1) + * characters and will not fit in the given buffer. + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen); + +/** + * fdt_supernode_atdepth_offset - find a specific ancestor of a node + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose parent to find + * @supernodedepth: depth of the ancestor to find + * @nodedepth: pointer to an integer variable (will be overwritten) or NULL + * + * fdt_supernode_atdepth_offset() finds an ancestor of the given node + * at a specific depth from the root (where the root itself has depth + * 0, its immediate subnodes depth 1 and so forth). So + * fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, NULL); + * will always return 0, the offset of the root node. If the node at + * nodeoffset has depth D, then: + * fdt_supernode_atdepth_offset(fdt, nodeoffset, D, NULL); + * will return nodeoffset itself. + * + * NOTE: This function is expensive, as it must scan the device tree + * structure from the start to nodeoffset. + * + * returns: + * structure block offset of the node at node offset's ancestor + * of depth supernodedepth (>=0), on success + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of + * nodeoffset + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, + int supernodedepth, int *nodedepth); + +/** + * fdt_node_depth - find the depth of a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose parent to find + * + * fdt_node_depth() finds the depth of a given node. The root node + * has depth 0, its immediate subnodes depth 1 and so forth. + * + * NOTE: This function is expensive, as it must scan the device tree + * structure from the start to nodeoffset. + * + * returns: + * depth of the node at nodeoffset (>=0), on success + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_node_depth(const void *fdt, int nodeoffset); + +/** + * fdt_parent_offset - find the parent of a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose parent to find + * + * fdt_parent_offset() locates the parent node of a given node (that + * is, it finds the offset of the node which contains the node at + * nodeoffset as a subnode). + * + * NOTE: This function is expensive, as it must scan the device tree + * structure from the start to nodeoffset, *twice*. + * + * returns: + * structure block offset of the parent of the node at nodeoffset + * (>=0), on success + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_parent_offset(const void *fdt, int nodeoffset); + +/** + * fdt_node_offset_by_prop_value - find nodes with a given property value + * @fdt: pointer to the device tree blob + * @startoffset: only find nodes after this offset + * @propname: property name to check + * @propval: property value to search for + * @proplen: length of the value in propval + * + * fdt_node_offset_by_prop_value() returns the offset of the first + * node after startoffset, which has a property named propname whose + * value is of length proplen and has value equal to propval; or if + * startoffset is -1, the very first such node in the tree. + * + * To iterate through all nodes matching the criterion, the following + * idiom can be used: + * offset = fdt_node_offset_by_prop_value(fdt, -1, propname, + * propval, proplen); + * while (offset != -FDT_ERR_NOTFOUND) { + * // other code here + * offset = fdt_node_offset_by_prop_value(fdt, offset, propname, + * propval, proplen); + * } + * + * Note the -1 in the first call to the function, if 0 is used here + * instead, the function will never locate the root node, even if it + * matches the criterion. + * + * returns: + * structure block offset of the located node (>= 0, >startoffset), + * on success + * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the + * tree after startoffset + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, + const char *propname, + const void *propval, int proplen); + +/** + * fdt_node_offset_by_phandle - find the node with a given phandle + * @fdt: pointer to the device tree blob + * @phandle: phandle value + * + * fdt_node_offset_by_phandle() returns the offset of the node + * which has the given phandle value. If there is more than one node + * in the tree with the given phandle (an invalid tree), results are + * undefined. + * + * returns: + * structure block offset of the located node (>= 0), on success + * -FDT_ERR_NOTFOUND, no node with that phandle exists + * -FDT_ERR_BADPHANDLE, given phandle value was invalid (0 or -1) + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle); + +/** + * fdt_node_check_compatible: check a node's compatible property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of a tree node + * @compatible: string to match against + * + * + * fdt_node_check_compatible() returns 0 if the given node contains a + * 'compatible' property with the given string as one of its elements, + * it returns non-zero otherwise, or on error. + * + * returns: + * 0, if the node has a 'compatible' property listing the given string + * 1, if the node has a 'compatible' property, but it does not list + * the given string + * -FDT_ERR_NOTFOUND, if the given node has no 'compatible' property + * -FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_node_check_compatible(const void *fdt, int nodeoffset, + const char *compatible); + +/** + * fdt_node_offset_by_compatible - find nodes with a given 'compatible' value + * @fdt: pointer to the device tree blob + * @startoffset: only find nodes after this offset + * @compatible: 'compatible' string to match against + * + * fdt_node_offset_by_compatible() returns the offset of the first + * node after startoffset, which has a 'compatible' property which + * lists the given compatible string; or if startoffset is -1, the + * very first such node in the tree. + * + * To iterate through all nodes matching the criterion, the following + * idiom can be used: + * offset = fdt_node_offset_by_compatible(fdt, -1, compatible); + * while (offset != -FDT_ERR_NOTFOUND) { + * // other code here + * offset = fdt_node_offset_by_compatible(fdt, offset, compatible); + * } + * + * Note the -1 in the first call to the function, if 0 is used here + * instead, the function will never locate the root node, even if it + * matches the criterion. + * + * returns: + * structure block offset of the located node (>= 0, >startoffset), + * on success + * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the + * tree after startoffset + * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, standard meanings + */ +int fdt_node_offset_by_compatible(const void *fdt, int startoffset, + const char *compatible); + +/** + * fdt_stringlist_contains - check a string list property for a string + * @strlist: Property containing a list of strings to check + * @listlen: Length of property + * @str: String to search for + * + * This is a utility function provided for convenience. The list contains + * one or more strings, each terminated by \0, as is found in a device tree + * "compatible" property. + * + * @return: 1 if the string is found in the list, 0 not found, or invalid list + */ +int fdt_stringlist_contains(const char *strlist, int listlen, const char *str); + +/** + * fdt_stringlist_count - count the number of strings in a string list + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of a tree node + * @property: name of the property containing the string list + * @return: + * the number of strings in the given property + * -FDT_ERR_BADVALUE if the property value is not NUL-terminated + * -FDT_ERR_NOTFOUND if the property does not exist + */ +int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property); + +/** + * fdt_stringlist_search - find a string in a string list and return its index + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of a tree node + * @property: name of the property containing the string list + * @string: string to look up in the string list + * + * Note that it is possible for this function to succeed on property values + * that are not NUL-terminated. That's because the function will stop after + * finding the first occurrence of @string. This can for example happen with + * small-valued cell properties, such as #address-cells, when searching for + * the empty string. + * + * @return: + * the index of the string in the list of strings + * -FDT_ERR_BADVALUE if the property value is not NUL-terminated + * -FDT_ERR_NOTFOUND if the property does not exist or does not contain + * the given string + */ +int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property, + const char *string); + +/** + * fdt_stringlist_get() - obtain the string at a given index in a string list + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of a tree node + * @property: name of the property containing the string list + * @index: index of the string to return + * @lenp: return location for the string length or an error code on failure + * + * Note that this will successfully extract strings from properties with + * non-NUL-terminated values. For example on small-valued cell properties + * this function will return the empty string. + * + * If non-NULL, the length of the string (on success) or a negative error-code + * (on failure) will be stored in the integer pointer to by lenp. + * + * @return: + * A pointer to the string at the given index in the string list or NULL on + * failure. On success the length of the string will be stored in the memory + * location pointed to by the lenp parameter, if non-NULL. On failure one of + * the following negative error codes will be returned in the lenp parameter + * (if non-NULL): + * -FDT_ERR_BADVALUE if the property value is not NUL-terminated + * -FDT_ERR_NOTFOUND if the property does not exist + */ +const char *fdt_stringlist_get(const void *fdt, int nodeoffset, + const char *property, int index, + int *lenp); + +/**********************************************************************/ +/* Read-only functions (addressing related) */ +/**********************************************************************/ + +/** + * FDT_MAX_NCELLS - maximum value for #address-cells and #size-cells + * + * This is the maximum value for #address-cells, #size-cells and + * similar properties that will be processed by libfdt. IEE1275 + * requires that OF implementations handle values up to 4. + * Implementations may support larger values, but in practice higher + * values aren't used. + */ +#define FDT_MAX_NCELLS 4 + +/** + * fdt_address_cells - retrieve address size for a bus represented in the tree + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to find the address size for + * + * When the node has a valid #address-cells property, returns its value. + * + * returns: + * 0 <= n < FDT_MAX_NCELLS, on success + * 2, if the node has no #address-cells property + * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid + * #address-cells property + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_address_cells(const void *fdt, int nodeoffset); + +/** + * fdt_size_cells - retrieve address range size for a bus represented in the + * tree + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to find the address range size for + * + * When the node has a valid #size-cells property, returns its value. + * + * returns: + * 0 <= n < FDT_MAX_NCELLS, on success + * 2, if the node has no #address-cells property + * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid + * #size-cells property + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_size_cells(const void *fdt, int nodeoffset); + + +/**********************************************************************/ +/* Write-in-place functions */ +/**********************************************************************/ + +/** + * fdt_setprop_inplace_namelen_partial - change a property's value, + * but not its size + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @namelen: number of characters of name to consider + * @idx: index of the property to change in the array + * @val: pointer to data to replace the property value with + * @len: length of the property value + * + * Identical to fdt_setprop_inplace(), but modifies the given property + * starting from the given index, and using only the first characters + * of the name. It is useful when you want to manipulate only one value of + * an array and you have a string that doesn't end with \0. + */ +#ifndef SWIG /* Not available in Python */ +int fdt_setprop_inplace_namelen_partial(void *fdt, int nodeoffset, + const char *name, int namelen, + uint32_t idx, const void *val, + int len); +#endif + +/** + * fdt_setprop_inplace - change a property's value, but not its size + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: pointer to data to replace the property value with + * @len: length of the property value + * + * fdt_setprop_inplace() replaces the value of a given property with + * the data in val, of length len. This function cannot change the + * size of a property, and so will only work if len is equal to the + * current length of the property. + * + * This function will alter only the bytes in the blob which contain + * the given property value, and will not alter or move any other part + * of the tree. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, if len is not equal to the property's current length + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#ifndef SWIG /* Not available in Python */ +int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, + const void *val, int len); +#endif + +/** + * fdt_setprop_inplace_u32 - change the value of a 32-bit integer property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 32-bit integer value to replace the property with + * + * fdt_setprop_inplace_u32() replaces the value of a given property + * with the 32-bit integer value in val, converting val to big-endian + * if necessary. This function cannot change the size of a property, + * and so will only work if the property already exists and has length + * 4. + * + * This function will alter only the bytes in the blob which contain + * the given property value, and will not alter or move any other part + * of the tree. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, if the property's length is not equal to 4 + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + fdt32_t tmp = cpu_to_fdt32(val); + return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_setprop_inplace_u64 - change the value of a 64-bit integer property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value to replace the property with + * + * fdt_setprop_inplace_u64() replaces the value of a given property + * with the 64-bit integer value in val, converting val to big-endian + * if necessary. This function cannot change the size of a property, + * and so will only work if the property already exists and has length + * 8. + * + * This function will alter only the bytes in the blob which contain + * the given property value, and will not alter or move any other part + * of the tree. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, if the property's length is not equal to 8 + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset, + const char *name, uint64_t val) +{ + fdt64_t tmp = cpu_to_fdt64(val); + return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_setprop_inplace_cell - change the value of a single-cell property + * + * This is an alternative name for fdt_setprop_inplace_u32() + */ +static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + return fdt_setprop_inplace_u32(fdt, nodeoffset, name, val); +} + +/** + * fdt_nop_property - replace a property with nop tags + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to nop + * @name: name of the property to nop + * + * fdt_nop_property() will replace a given property's representation + * in the blob with FDT_NOP tags, effectively removing it from the + * tree. + * + * This function will alter only the bytes in the blob which contain + * the property, and will not alter or move any other part of the + * tree. + * + * returns: + * 0, on success + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_nop_property(void *fdt, int nodeoffset, const char *name); + +/** + * fdt_nop_node - replace a node (subtree) with nop tags + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to nop + * + * fdt_nop_node() will replace a given node's representation in the + * blob, including all its subnodes, if any, with FDT_NOP tags, + * effectively removing it from the tree. + * + * This function will alter only the bytes in the blob which contain + * the node and its properties and subnodes, and will not alter or + * move any other part of the tree. + * + * returns: + * 0, on success + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_nop_node(void *fdt, int nodeoffset); + +/**********************************************************************/ +/* Sequential write functions */ +/**********************************************************************/ + +int fdt_create(void *buf, int bufsize); +int fdt_resize(void *fdt, void *buf, int bufsize); +int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); +int fdt_finish_reservemap(void *fdt); +int fdt_begin_node(void *fdt, const char *name); +int fdt_property(void *fdt, const char *name, const void *val, int len); +static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val) +{ + fdt32_t tmp = cpu_to_fdt32(val); + return fdt_property(fdt, name, &tmp, sizeof(tmp)); +} +static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val) +{ + fdt64_t tmp = cpu_to_fdt64(val); + return fdt_property(fdt, name, &tmp, sizeof(tmp)); +} +static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val) +{ + return fdt_property_u32(fdt, name, val); +} + +/** + * fdt_property_placeholder - add a new property and return a ptr to its value + * + * @fdt: pointer to the device tree blob + * @name: name of property to add + * @len: length of property value in bytes + * @valp: returns a pointer to where where the value should be placed + * + * returns: + * 0, on success + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_NOSPACE, standard meanings + */ +int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp); + +#define fdt_property_string(fdt, name, str) \ + fdt_property(fdt, name, str, strlen(str)+1) +int fdt_end_node(void *fdt); +int fdt_finish(void *fdt); + +/**********************************************************************/ +/* Read-write functions */ +/**********************************************************************/ + +int fdt_create_empty_tree(void *buf, int bufsize); +int fdt_open_into(const void *fdt, void *buf, int bufsize); +int fdt_pack(void *fdt); + +/** + * fdt_add_mem_rsv - add one memory reserve map entry + * @fdt: pointer to the device tree blob + * @address, @size: 64-bit values (native endian) + * + * Adds a reserve map entry to the given blob reserving a region at + * address address of length size. + * + * This function will insert data into the reserve map and will + * therefore change the indexes of some entries in the table. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new reservation entry + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size); + +/** + * fdt_del_mem_rsv - remove a memory reserve map entry + * @fdt: pointer to the device tree blob + * @n: entry to remove + * + * fdt_del_mem_rsv() removes the n-th memory reserve map entry from + * the blob. + * + * This function will delete data from the reservation table and will + * therefore change the indexes of some entries in the table. + * + * returns: + * 0, on success + * -FDT_ERR_NOTFOUND, there is no entry of the given index (i.e. there + * are less than n+1 reserve map entries) + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_del_mem_rsv(void *fdt, int n); + +/** + * fdt_set_name - change the name of a given node + * @fdt: pointer to the device tree blob + * @nodeoffset: structure block offset of a node + * @name: name to give the node + * + * fdt_set_name() replaces the name (including unit address, if any) + * of the given node with the given string. NOTE: this function can't + * efficiently check if the new name is unique amongst the given + * node's siblings; results are undefined if this function is invoked + * with a name equal to one of the given node's siblings. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob + * to contain the new name + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, standard meanings + */ +int fdt_set_name(void *fdt, int nodeoffset, const char *name); + +/** + * fdt_setprop - create or change a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: pointer to data to set the property value to + * @len: length of the property value + * + * fdt_setprop() sets the value of the named property in the given + * node to the given value and length, creating the property if it + * does not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_setprop(void *fdt, int nodeoffset, const char *name, + const void *val, int len); + +/** + * fdt_setprop _placeholder - allocate space for a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @len: length of the property value + * @prop_data: return pointer to property data + * + * fdt_setprop_placeholer() allocates the named property in the given node. + * If the property exists it is resized. In either case a pointer to the + * property data is returned. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, + int len, void **prop_data); + +/** + * fdt_setprop_u32 - set a property to a 32-bit integer + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 32-bit integer value for the property (native endian) + * + * fdt_setprop_u32() sets the value of the named property in the given + * node to the given 32-bit integer value (converting to big-endian if + * necessary), or creates a new property with that value if it does + * not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name, + uint32_t val) +{ + fdt32_t tmp = cpu_to_fdt32(val); + return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_setprop_u64 - set a property to a 64-bit integer + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value for the property (native endian) + * + * fdt_setprop_u64() sets the value of the named property in the given + * node to the given 64-bit integer value (converting to big-endian if + * necessary), or creates a new property with that value if it does + * not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name, + uint64_t val) +{ + fdt64_t tmp = cpu_to_fdt64(val); + return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_setprop_cell - set a property to a single cell value + * + * This is an alternative name for fdt_setprop_u32() + */ +static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, + uint32_t val) +{ + return fdt_setprop_u32(fdt, nodeoffset, name, val); +} + +/** + * fdt_setprop_string - set a property to a string value + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @str: string value for the property + * + * fdt_setprop_string() sets the value of the named property in the + * given node to the given string value (using the length of the + * string to determine the new length of the property), or creates a + * new property with that value if it does not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#define fdt_setprop_string(fdt, nodeoffset, name, str) \ + fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) + + +/** + * fdt_setprop_empty - set a property to an empty value + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * + * fdt_setprop_empty() sets the value of the named property in the + * given node to an empty (zero length) value, or creates a new empty + * property if it does not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#define fdt_setprop_empty(fdt, nodeoffset, name) \ + fdt_setprop((fdt), (nodeoffset), (name), NULL, 0) + +/** + * fdt_appendprop - append to or create a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to append to + * @val: pointer to data to append to the property value + * @len: length of the data to append to the property value + * + * fdt_appendprop() appends the value to the named property in the + * given node, creating the property if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_appendprop(void *fdt, int nodeoffset, const char *name, + const void *val, int len); + +/** + * fdt_appendprop_u32 - append a 32-bit integer value to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 32-bit integer value to append to the property (native endian) + * + * fdt_appendprop_u32() appends the given 32-bit integer value + * (converting to big-endian if necessary) to the value of the named + * property in the given node, or creates a new property with that + * value if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_appendprop_u32(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + fdt32_t tmp = cpu_to_fdt32(val); + return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_appendprop_u64 - append a 64-bit integer value to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value to append to the property (native endian) + * + * fdt_appendprop_u64() appends the given 64-bit integer value + * (converting to big-endian if necessary) to the value of the named + * property in the given node, or creates a new property with that + * value if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_appendprop_u64(void *fdt, int nodeoffset, + const char *name, uint64_t val) +{ + fdt64_t tmp = cpu_to_fdt64(val); + return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} + +/** + * fdt_appendprop_cell - append a single cell value to a property + * + * This is an alternative name for fdt_appendprop_u32() + */ +static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + return fdt_appendprop_u32(fdt, nodeoffset, name, val); +} + +/** + * fdt_appendprop_string - append a string to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @str: string value to append to the property + * + * fdt_appendprop_string() appends the given string to the value of + * the named property in the given node, or creates a new property + * with that value if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#define fdt_appendprop_string(fdt, nodeoffset, name, str) \ + fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) + +/** + * fdt_delprop - delete a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to nop + * @name: name of the property to nop + * + * fdt_del_property() will delete the given property. + * + * This function will delete data from the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_delprop(void *fdt, int nodeoffset, const char *name); + +/** + * fdt_add_subnode_namelen - creates a new node based on substring + * @fdt: pointer to the device tree blob + * @parentoffset: structure block offset of a node + * @name: name of the subnode to locate + * @namelen: number of characters of name to consider + * + * Identical to fdt_add_subnode(), but use only the first namelen + * characters of name as the name of the new node. This is useful for + * creating subnodes based on a portion of a larger string, such as a + * full path. + */ +#ifndef SWIG /* Not available in Python */ +int fdt_add_subnode_namelen(void *fdt, int parentoffset, + const char *name, int namelen); +#endif + +/** + * fdt_add_subnode - creates a new node + * @fdt: pointer to the device tree blob + * @parentoffset: structure block offset of a node + * @name: name of the subnode to locate + * + * fdt_add_subnode() creates a new node as a subnode of the node at + * structure block offset parentoffset, with the given name (which + * should include the unit address, if any). + * + * This function will insert data into the blob, and will therefore + * change the offsets of some existing nodes. + + * returns: + * structure block offset of the created nodeequested subnode (>=0), on + * success + * -FDT_ERR_NOTFOUND, if the requested subnode does not exist + * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE + * tag + * -FDT_ERR_EXISTS, if the node at parentoffset already has a subnode of + * the given name + * -FDT_ERR_NOSPACE, if there is insufficient free space in the + * blob to contain the new node + * -FDT_ERR_NOSPACE + * -FDT_ERR_BADLAYOUT + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings. + */ +int fdt_add_subnode(void *fdt, int parentoffset, const char *name); + +/** + * fdt_del_node - delete a node (subtree) + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to nop + * + * fdt_del_node() will remove the given node, including all its + * subnodes if any, from the blob. + * + * This function will delete data from the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_del_node(void *fdt, int nodeoffset); + +/** + * fdt_overlay_apply - Applies a DT overlay on a base DT + * @fdt: pointer to the base device tree blob + * @fdto: pointer to the device tree overlay blob + * + * fdt_overlay_apply() will apply the given device tree overlay on the + * given base device tree. + * + * Expect the base device tree to be modified, even if the function + * returns an error. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there's not enough space in the base device tree + * -FDT_ERR_NOTFOUND, the overlay points to some inexistant nodes or + * properties in the base DT + * -FDT_ERR_BADPHANDLE, + * -FDT_ERR_BADOVERLAY, + * -FDT_ERR_NOPHANDLES, + * -FDT_ERR_INTERNAL, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADOFFSET, + * -FDT_ERR_BADPATH, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_overlay_apply(void *fdt, void *fdto); + +/**********************************************************************/ +/* Debugging / informational functions */ +/**********************************************************************/ + +#ifndef SWIG /* Not available in Python */ +const char *fdt_strerror(int errval); + +struct fdt_region { + int offset; + int size; +}; + +/* + * Flags for fdt_find_regions() + * + * Add a region for the string table (always the last region) + */ +#define FDT_REG_ADD_STRING_TAB (1 << 0) + +/* + * Add all supernodes of a matching node/property, useful for creating a + * valid subset tree + */ +#define FDT_REG_SUPERNODES (1 << 1) + +/* Add the FDT_BEGIN_NODE tags of subnodes, including their names */ +#define FDT_REG_DIRECT_SUBNODES (1 << 2) + +/* Add all subnodes of a matching node */ +#define FDT_REG_ALL_SUBNODES (1 << 3) + +/* Add a region for the mem_rsvmap table (always the first region) */ +#define FDT_REG_ADD_MEM_RSVMAP (1 << 4) + +/* Indicates what an fdt part is (node, property, value) */ +#define FDT_IS_NODE (1 << 0) +#define FDT_IS_PROP (1 << 1) +#define FDT_IS_VALUE (1 << 2) /* not supported */ +#define FDT_IS_COMPAT (1 << 3) /* used internally */ +#define FDT_NODE_HAS_PROP (1 << 4) /* node contains prop */ + +#define FDT_ANY_GLOBAL (FDT_IS_NODE | FDT_IS_PROP | FDT_IS_VALUE | \ + FDT_IS_COMPAT) +#define FDT_IS_ANY 0x1f /* all the above */ + +/* We set a reasonable limit on the number of nested nodes */ +#define FDT_MAX_DEPTH 32 + +/* Decribes what we want to include from the current tag */ +enum want_t { + WANT_NOTHING, + WANT_NODES_ONLY, /* No properties */ + WANT_NODES_AND_PROPS, /* Everything for one level */ + WANT_ALL_NODES_AND_PROPS /* Everything for all levels */ +}; + +/* Keeps track of the state at parent nodes */ +struct fdt_subnode_stack { + int offset; /* Offset of node */ + enum want_t want; /* The 'want' value here */ + int included; /* 1 if we included this node, 0 if not */ +}; + +struct fdt_region_ptrs { + int depth; /* Current tree depth */ + int done; /* What we have completed scanning */ + enum want_t want; /* What we are currently including */ + char *end; /* Pointer to end of full node path */ + int nextoffset; /* Next node offset to check */ +}; + +/* The state of our finding algortihm */ +struct fdt_region_state { + struct fdt_subnode_stack stack[FDT_MAX_DEPTH]; /* node stack */ + struct fdt_region *region; /* Contains list of regions found */ + int count; /* Numnber of regions found */ + const void *fdt; /* FDT blob */ + int max_regions; /* Maximum regions to find */ + int can_merge; /* 1 if we can merge with previous region */ + int start; /* Start position of current region */ + struct fdt_region_ptrs ptrs; /* Pointers for what we are up to */ +}; + +/** + * fdt_find_regions() - find regions in device tree + * + * Given a list of nodes to include and properties to exclude, find + * the regions of the device tree which describe those included parts. + * + * The intent is to get a list of regions which will be invariant provided + * those parts are invariant. For example, if you request a list of regions + * for all nodes but exclude the property "data", then you will get the + * same region contents regardless of any change to "data" properties. + * + * This function can be used to produce a byte-stream to send to a hashing + * function to verify that critical parts of the FDT have not changed. + * + * Nodes which are given in 'inc' are included in the region list, as + * are the names of the immediate subnodes nodes (but not the properties + * or subnodes of those subnodes). + * + * For eaxample "/" means to include the root node, all root properties + * and the FDT_BEGIN_NODE and FDT_END_NODE of all subnodes of /. The latter + * ensures that we capture the names of the subnodes. In a hashing situation + * it prevents the root node from changing at all Any change to non-excluded + * properties, names of subnodes or number of subnodes would be detected. + * + * When used with FITs this provides the ability to hash and sign parts of + * the FIT based on different configurations in the FIT. Then it is + * impossible to change anything about that configuration (include images + * attached to the configuration), but it may be possible to add new + * configurations, new images or new signatures within the existing + * framework. + * + * Adding new properties to a device tree may result in the string table + * being extended (if the new property names are different from those + * already added). This function can optionally include a region for + * the string table so that this can be part of the hash too. + * + * The device tree header is not included in the list. + * + * @fdt: Device tree to check + * @inc: List of node paths to included + * @inc_count: Number of node paths in list + * @exc_prop: List of properties names to exclude + * @exc_prop_count: Number of properties in exclude list + * @region: Returns list of regions + * @max_region: Maximum length of region list + * @path: Pointer to a temporary string for the function to use for + * building path names + * @path_len: Length of path, must be large enough to hold the longest + * path in the tree + * @add_string_tab: 1 to add a region for the string table + * @return number of regions in list. If this is >max_regions then the + * region array was exhausted. You should increase max_regions and try + * the call again. + */ +int fdt_find_regions(const void *fdt, char * const inc[], int inc_count, + char * const exc_prop[], int exc_prop_count, + struct fdt_region region[], int max_regions, + char *path, int path_len, int add_string_tab); + +/** + * fdt_first_region() - find regions in device tree + * + * Given a nodes and properties to include and properties to exclude, find + * the regions of the device tree which describe those included parts. + * + * The use for this function is twofold. Firstly it provides a convenient + * way of performing a structure-aware grep of the tree. For example it is + * possible to grep for a node and get all the properties associated with + * that node. Trees can be subsetted easily, by specifying the nodes that + * are required, and then writing out the regions returned by this function. + * This is useful for small resource-constrained systems, such as boot + * loaders, which want to use an FDT but do not need to know about all of + * it. + * + * Secondly it makes it easy to hash parts of the tree and detect changes. + * The intent is to get a list of regions which will be invariant provided + * those parts are invariant. For example, if you request a list of regions + * for all nodes but exclude the property "data", then you will get the + * same region contents regardless of any change to "data" properties. + * + * This function can be used to produce a byte-stream to send to a hashing + * function to verify that critical parts of the FDT have not changed. + * Note that semantically null changes in order could still cause false + * hash misses. Such reordering might happen if the tree is regenerated + * from source, and nodes are reordered (the bytes-stream will be emitted + * in a different order and mnay hash functions will detect this). However + * if an existing tree is modified using libfdt functions, such as + * fdt_add_subnode() and fdt_setprop(), then this problem is avoided. + * + * The nodes/properties to include/exclude are defined by a function + * provided by the caller. This function is called for each node and + * property, and must return: + * + * 0 - to exclude this part + * 1 - to include this part + * -1 - for FDT_IS_PROP only: no information is available, so include + * if its containing node is included + * + * The last case is only used to deal with properties. Often a property is + * included if its containing node is included - this is the case where + * -1 is returned.. However if the property is specifically required to be + * included/excluded, then 0 or 1 can be returned. Note that including a + * property when the FDT_REG_SUPERNODES flag is given will force its + * containing node to be included since it is not valid to have a property + * that is not in a node. + * + * Using the information provided, the inclusion of a node can be controlled + * either by a node name or its compatible string, or any other property + * that the function can determine. + * + * As an example, including node "/" means to include the root node and all + * root properties. A flag provides a way of also including supernodes (of + * which there is none for the root node), and another flag includes + * immediate subnodes, so in this case we would get the FDT_BEGIN_NODE and + * FDT_END_NODE of all subnodes of /. + * + * The subnode feature helps in a hashing situation since it prevents the + * root node from changing at all. Any change to non-excluded properties, + * names of subnodes or number of subnodes would be detected. + * + * When used with FITs this provides the ability to hash and sign parts of + * the FIT based on different configurations in the FIT. Then it is + * impossible to change anything about that configuration (include images + * attached to the configuration), but it may be possible to add new + * configurations, new images or new signatures within the existing + * framework. + * + * Adding new properties to a device tree may result in the string table + * being extended (if the new property names are different from those + * already added). This function can optionally include a region for + * the string table so that this can be part of the hash too. This is always + * the last region. + * + * The FDT also has a mem_rsvmap table which can also be included, and is + * always the first region if so. + * + * The device tree header is not included in the region list. Since the + * contents of the FDT are changing (shrinking, often), the caller will need + * to regenerate the header anyway. + * + * @fdt: Device tree to check + * @h_include: Function to call to determine whether to include a part or + * not: + * + * @priv: Private pointer as passed to fdt_find_regions() + * @fdt: Pointer to FDT blob + * @offset: Offset of this node / property + * @type: Type of this part, FDT_IS_... + * @data: Pointer to data (node name, property name, compatible + * string, value (not yet supported) + * @size: Size of data, or 0 if none + * @return 0 to exclude, 1 to include, -1 if no information is + * available + * @priv: Private pointer passed to h_include + * @region: Returns list of regions, sorted by offset + * @max_regions: Maximum length of region list + * @path: Pointer to a temporary string for the function to use for + * building path names + * @path_len: Length of path, must be large enough to hold the longest + * path in the tree + * @flags: Various flags that control the region algortihm, see + * FDT_REG_... + * @return number of regions in list. If this is >max_regions then the + * region array was exhausted. You should increase max_regions and try + * the call again. Only the first max_regions elements are available in the + * array. + * + * On error a -ve value is return, which can be: + * + * -FDT_ERR_BADSTRUCTURE (too deep or more END tags than BEGIN tags + * -FDT_ERR_BADLAYOUT + * -FDT_ERR_NOSPACE (path area is too small) + */ +int fdt_first_region(const void *fdt, + int (*h_include)(void *priv, const void *fdt, int offset, + int type, const char *data, int size), + void *priv, struct fdt_region *region, + char *path, int path_len, int flags, + struct fdt_region_state *info); + +/** fdt_next_region() - find next region + * + * See fdt_first_region() for full description. This function finds the + * next region according to the provided parameters, which must be the same + * as passed to fdt_first_region(). + * + * This function can additionally return -FDT_ERR_NOTFOUND when there are no + * more regions + */ +int fdt_next_region(const void *fdt, + int (*h_include)(void *priv, const void *fdt, int offset, + int type, const char *data, int size), + void *priv, struct fdt_region *region, + char *path, int path_len, int flags, + struct fdt_region_state *info); + +/** + * fdt_add_alias_regions() - find aliases that point to existing regions + * + * Once a device tree grep is complete some of the nodes will be present + * and some will have been dropped. This function checks all the alias nodes + * to figure out which points point to nodes which are still present. These + * aliases need to be kept, along with the nodes they reference. + * + * Given a list of regions function finds the aliases that still apply and + * adds more regions to the list for these. This function is called after + * fdt_next_region() has finished returning regions and requires the same + * state. + * + * @fdt: Device tree file to reference + * @region: List of regions that will be kept + * @count: Number of regions + * @max_regions: Number of entries that can fit in @region + * @info: Region state as returned from fdt_next_region() + * @return new number of regions in @region (i.e. count + the number added) + * or -FDT_ERR_NOSPACE if there was not enough space. + */ +int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, + int max_regions, struct fdt_region_state *info); +#endif /* SWIG */ + +#endif /* _LIBFDT_H */ diff --git a/lib/libfdt/libfdt.h b/lib/libfdt/libfdt.h deleted file mode 100644 index 4e2c841..0000000 --- a/lib/libfdt/libfdt.h +++ /dev/null @@ -1,2153 +0,0 @@ -#ifndef _LIBFDT_H -#define _LIBFDT_H -/* - * libfdt - Flat Device Tree manipulation - * Copyright (C) 2006 David Gibson, IBM Corporation. - * - * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause - */ - -#include <libfdt_env.h> -#include <fdt.h> - -#define FDT_FIRST_SUPPORTED_VERSION 0x10 -#define FDT_LAST_SUPPORTED_VERSION 0x11 - -/* Error codes: informative error codes */ -#define FDT_ERR_NOTFOUND 1 - /* FDT_ERR_NOTFOUND: The requested node or property does not exist */ -#define FDT_ERR_EXISTS 2 - /* FDT_ERR_EXISTS: Attempted to create a node or property which - * already exists */ -#define FDT_ERR_NOSPACE 3 - /* FDT_ERR_NOSPACE: Operation needed to expand the device - * tree, but its buffer did not have sufficient space to - * contain the expanded tree. Use fdt_open_into() to move the - * device tree to a buffer with more space. */ - -/* Error codes: codes for bad parameters */ -#define FDT_ERR_BADOFFSET 4 - /* FDT_ERR_BADOFFSET: Function was passed a structure block - * offset which is out-of-bounds, or which points to an - * unsuitable part of the structure for the operation. */ -#define FDT_ERR_BADPATH 5 - /* FDT_ERR_BADPATH: Function was passed a badly formatted path - * (e.g. missing a leading / for a function which requires an - * absolute path) */ -#define FDT_ERR_BADPHANDLE 6 - /* FDT_ERR_BADPHANDLE: Function was passed an invalid phandle. - * This can be caused either by an invalid phandle property - * length, or the phandle value was either 0 or -1, which are - * not permitted. */ -#define FDT_ERR_BADSTATE 7 - /* FDT_ERR_BADSTATE: Function was passed an incomplete device - * tree created by the sequential-write functions, which is - * not sufficiently complete for the requested operation. */ - -/* Error codes: codes for bad device tree blobs */ -#define FDT_ERR_TRUNCATED 8 - /* FDT_ERR_TRUNCATED: Structure block of the given device tree - * ends without an FDT_END tag. */ -#define FDT_ERR_BADMAGIC 9 - /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a - * device tree at all - it is missing the flattened device - * tree magic number. */ -#define FDT_ERR_BADVERSION 10 - /* FDT_ERR_BADVERSION: Given device tree has a version which - * can't be handled by the requested operation. For - * read-write functions, this may mean that fdt_open_into() is - * required to convert the tree to the expected version. */ -#define FDT_ERR_BADSTRUCTURE 11 - /* FDT_ERR_BADSTRUCTURE: Given device tree has a corrupt - * structure block or other serious error (e.g. misnested - * nodes, or subnodes preceding properties). */ -#define FDT_ERR_BADLAYOUT 12 - /* FDT_ERR_BADLAYOUT: For read-write functions, the given - * device tree has it's sub-blocks in an order that the - * function can't handle (memory reserve map, then structure, - * then strings). Use fdt_open_into() to reorganize the tree - * into a form suitable for the read-write operations. */ - -/* "Can't happen" error indicating a bug in libfdt */ -#define FDT_ERR_INTERNAL 13 - /* FDT_ERR_INTERNAL: libfdt has failed an internal assertion. - * Should never be returned, if it is, it indicates a bug in - * libfdt itself. */ - -/* Errors in device tree content */ -#define FDT_ERR_BADNCELLS 14 - /* FDT_ERR_BADNCELLS: Device tree has a #address-cells, #size-cells - * or similar property with a bad format or value */ - -#define FDT_ERR_BADVALUE 15 - /* FDT_ERR_BADVALUE: Device tree has a property with an unexpected - * value. For example: a property expected to contain a string list - * is not NUL-terminated within the length of its value. */ - -#define FDT_ERR_BADOVERLAY 16 - /* FDT_ERR_BADOVERLAY: The device tree overlay, while - * correctly structured, cannot be applied due to some - * unexpected or missing value, property or node. */ - -#define FDT_ERR_NOPHANDLES 17 - /* FDT_ERR_NOPHANDLES: The device tree doesn't have any - * phandle available anymore without causing an overflow */ - -#define FDT_ERR_MAX 17 - -/**********************************************************************/ -/* Low-level functions (you probably don't need these) */ -/**********************************************************************/ - -#ifndef SWIG /* This function is not useful in Python */ -const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int checklen); -#endif -static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen) -{ - return (void *)(uintptr_t)fdt_offset_ptr(fdt, offset, checklen); -} - -uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset); - -/**********************************************************************/ -/* Traversal functions */ -/**********************************************************************/ - -int fdt_next_node(const void *fdt, int offset, int *depth); - -/** - * fdt_first_subnode() - get offset of first direct subnode - * - * @fdt: FDT blob - * @offset: Offset of node to check - * @return offset of first subnode, or -FDT_ERR_NOTFOUND if there is none - */ -int fdt_first_subnode(const void *fdt, int offset); - -/** - * fdt_next_subnode() - get offset of next direct subnode - * - * After first calling fdt_first_subnode(), call this function repeatedly to - * get direct subnodes of a parent node. - * - * @fdt: FDT blob - * @offset: Offset of previous subnode - * @return offset of next subnode, or -FDT_ERR_NOTFOUND if there are no more - * subnodes - */ -int fdt_next_subnode(const void *fdt, int offset); - -/** - * fdt_for_each_subnode - iterate over all subnodes of a parent - * - * @node: child node (int, lvalue) - * @fdt: FDT blob (const void *) - * @parent: parent node (int) - * - * This is actually a wrapper around a for loop and would be used like so: - * - * fdt_for_each_subnode(node, fdt, parent) { - * Use node - * ... - * } - * - * if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) { - * Error handling - * } - * - * Note that this is implemented as a macro and @node is used as - * iterator in the loop. The parent variable be constant or even a - * literal. - * - */ -#define fdt_for_each_subnode(node, fdt, parent) \ - for (node = fdt_first_subnode(fdt, parent); \ - node >= 0; \ - node = fdt_next_subnode(fdt, node)) - -/**********************************************************************/ -/* General functions */ -/**********************************************************************/ -#define fdt_get_header(fdt, field) \ - (fdt32_to_cpu(((const struct fdt_header *)(fdt))->field)) -#define fdt_magic(fdt) (fdt_get_header(fdt, magic)) -#define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) -#define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) -#define fdt_off_dt_strings(fdt) (fdt_get_header(fdt, off_dt_strings)) -#define fdt_off_mem_rsvmap(fdt) (fdt_get_header(fdt, off_mem_rsvmap)) -#define fdt_version(fdt) (fdt_get_header(fdt, version)) -#define fdt_last_comp_version(fdt) (fdt_get_header(fdt, last_comp_version)) -#define fdt_boot_cpuid_phys(fdt) (fdt_get_header(fdt, boot_cpuid_phys)) -#define fdt_size_dt_strings(fdt) (fdt_get_header(fdt, size_dt_strings)) -#define fdt_size_dt_struct(fdt) (fdt_get_header(fdt, size_dt_struct)) - -#define __fdt_set_hdr(name) \ - static inline void fdt_set_##name(void *fdt, uint32_t val) \ - { \ - struct fdt_header *fdth = (struct fdt_header *)fdt; \ - fdth->name = cpu_to_fdt32(val); \ - } -__fdt_set_hdr(magic); -__fdt_set_hdr(totalsize); -__fdt_set_hdr(off_dt_struct); -__fdt_set_hdr(off_dt_strings); -__fdt_set_hdr(off_mem_rsvmap); -__fdt_set_hdr(version); -__fdt_set_hdr(last_comp_version); -__fdt_set_hdr(boot_cpuid_phys); -__fdt_set_hdr(size_dt_strings); -__fdt_set_hdr(size_dt_struct); -#undef __fdt_set_hdr - -/** - * fdt_check_header - sanity check a device tree or possible device tree - * @fdt: pointer to data which might be a flattened device tree - * - * fdt_check_header() checks that the given buffer contains what - * appears to be a flattened device tree with sane information in its - * header. - * - * returns: - * 0, if the buffer appears to contain a valid device tree - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings, as above - */ -int fdt_check_header(const void *fdt); - -/** - * fdt_move - move a device tree around in memory - * @fdt: pointer to the device tree to move - * @buf: pointer to memory where the device is to be moved - * @bufsize: size of the memory space at buf - * - * fdt_move() relocates, if possible, the device tree blob located at - * fdt to the buffer at buf of size bufsize. The buffer may overlap - * with the existing device tree blob at fdt. Therefore, - * fdt_move(fdt, fdt, fdt_totalsize(fdt)) - * should always succeed. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, bufsize is insufficient to contain the device tree - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_move(const void *fdt, void *buf, int bufsize); - -/**********************************************************************/ -/* Read-only functions */ -/**********************************************************************/ - -/** - * fdt_string - retrieve a string from the strings block of a device tree - * @fdt: pointer to the device tree blob - * @stroffset: offset of the string within the strings block (native endian) - * - * fdt_string() retrieves a pointer to a single string from the - * strings block of the device tree blob at fdt. - * - * returns: - * a pointer to the string, on success - * NULL, if stroffset is out of bounds - */ -const char *fdt_string(const void *fdt, int stroffset); - -/** - * fdt_get_max_phandle - retrieves the highest phandle in a tree - * @fdt: pointer to the device tree blob - * - * fdt_get_max_phandle retrieves the highest phandle in the given - * device tree. This will ignore badly formatted phandles, or phandles - * with a value of 0 or -1. - * - * returns: - * the highest phandle on success - * 0, if no phandle was found in the device tree - * -1, if an error occurred - */ -uint32_t fdt_get_max_phandle(const void *fdt); - -/** - * fdt_num_mem_rsv - retrieve the number of memory reserve map entries - * @fdt: pointer to the device tree blob - * - * Returns the number of entries in the device tree blob's memory - * reservation map. This does not include the terminating 0,0 entry - * or any other (0,0) entries reserved for expansion. - * - * returns: - * the number of entries - */ -int fdt_num_mem_rsv(const void *fdt); - -/** - * fdt_get_mem_rsv - retrieve one memory reserve map entry - * @fdt: pointer to the device tree blob - * @address, @size: pointers to 64-bit variables - * - * On success, *address and *size will contain the address and size of - * the n-th reserve map entry from the device tree blob, in - * native-endian format. - * - * returns: - * 0, on success - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size); - -/** - * fdt_subnode_offset_namelen - find a subnode based on substring - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * @namelen: number of characters of name to consider - * - * Identical to fdt_subnode_offset(), but only examine the first - * namelen characters of name for matching the subnode name. This is - * useful for finding subnodes based on a portion of a larger string, - * such as a full path. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, - const char *name, int namelen); -#endif -/** - * fdt_subnode_offset - find a subnode of a given node - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * - * fdt_subnode_offset() finds a subnode of the node at structure block - * offset parentoffset with the given name. name may include a unit - * address, in which case fdt_subnode_offset() will find the subnode - * with that unit address, or the unit address may be omitted, in - * which case fdt_subnode_offset() will find an arbitrary subnode - * whose name excluding unit address matches the given name. - * - * returns: - * structure block offset of the requested subnode (>=0), on success - * -FDT_ERR_NOTFOUND, if the requested subnode does not exist - * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name); - -/** - * fdt_path_offset_namelen - find a tree node by its full path - * @fdt: pointer to the device tree blob - * @path: full path of the node to locate - * @namelen: number of characters of path to consider - * - * Identical to fdt_path_offset(), but only consider the first namelen - * characters of path as the path name. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen); -#endif - -/** - * fdt_path_offset - find a tree node by its full path - * @fdt: pointer to the device tree blob - * @path: full path of the node to locate - * - * fdt_path_offset() finds a node of a given path in the device tree. - * Each path component may omit the unit address portion, but the - * results of this are undefined if any such path component is - * ambiguous (that is if there are multiple nodes at the relevant - * level matching the given component, differentiated only by unit - * address). - * - * returns: - * structure block offset of the node with the requested path (>=0), on - * success - * -FDT_ERR_BADPATH, given path does not begin with '/' or is invalid - * -FDT_ERR_NOTFOUND, if the requested node does not exist - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_path_offset(const void *fdt, const char *path); - -/** - * fdt_get_name - retrieve the name of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of the starting node - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_name() retrieves the name (including unit address) of the - * device tree node at structure block offset nodeoffset. If lenp is - * non-NULL, the length of this name is also returned, in the integer - * pointed to by lenp. - * - * returns: - * pointer to the node's name, on success - * If lenp is non-NULL, *lenp contains the length of that name - * (>=0) - * NULL, on error - * if lenp is non-NULL *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -const char *fdt_get_name(const void *fdt, int nodeoffset, int *lenp); - -/** - * fdt_first_property_offset - find the offset of a node's first property - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of a node - * - * fdt_first_property_offset() finds the first property of the node at - * the given structure block offset. - * - * returns: - * structure block offset of the property (>=0), on success - * -FDT_ERR_NOTFOUND, if the requested node has no properties - * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_first_property_offset(const void *fdt, int nodeoffset); - -/** - * fdt_next_property_offset - step through a node's properties - * @fdt: pointer to the device tree blob - * @offset: structure block offset of a property - * - * fdt_next_property_offset() finds the property immediately after the - * one at the given structure block offset. This will be a property - * of the same node as the given property. - * - * returns: - * structure block offset of the next property (>=0), on success - * -FDT_ERR_NOTFOUND, if the given property is the last in its node - * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_next_property_offset(const void *fdt, int offset); - -/** - * fdt_for_each_property_offset - iterate over all properties of a node - * - * @property_offset: property offset (int, lvalue) - * @fdt: FDT blob (const void *) - * @node: node offset (int) - * - * This is actually a wrapper around a for loop and would be used like so: - * - * fdt_for_each_property_offset(property, fdt, node) { - * Use property - * ... - * } - * - * if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) { - * Error handling - * } - * - * Note that this is implemented as a macro and property is used as - * iterator in the loop. The node variable can be constant or even a - * literal. - */ -#define fdt_for_each_property_offset(property, fdt, node) \ - for (property = fdt_first_property_offset(fdt, node); \ - property >= 0; \ - property = fdt_next_property_offset(fdt, property)) - -/** - * fdt_get_property_by_offset - retrieve the property at a given offset - * @fdt: pointer to the device tree blob - * @offset: offset of the property to retrieve - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_property_by_offset() retrieves a pointer to the - * fdt_property structure within the device tree blob at the given - * offset. If lenp is non-NULL, the length of the property value is - * also returned, in the integer pointed to by lenp. - * - * returns: - * pointer to the structure representing the property - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const struct fdt_property *fdt_get_property_by_offset(const void *fdt, - int offset, - int *lenp); - -/** - * fdt_get_property_namelen - find a property based on substring - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @namelen: number of characters of name to consider - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * Identical to fdt_get_property(), but only examine the first namelen - * characters of name for matching the property name. - */ -#ifndef SWIG /* Not available in Python */ -const struct fdt_property *fdt_get_property_namelen(const void *fdt, - int nodeoffset, - const char *name, - int namelen, int *lenp); -#endif - -/** - * fdt_get_property - find a given property in a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_property() retrieves a pointer to the fdt_property - * structure within the device tree blob corresponding to the property - * named 'name' of the node at offset nodeoffset. If lenp is - * non-NULL, the length of the property value is also returned, in the - * integer pointed to by lenp. - * - * returns: - * pointer to the structure representing the property - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_NOTFOUND, node does not have named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, - const char *name, int *lenp); -static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, - const char *name, - int *lenp) -{ - return (struct fdt_property *)(uintptr_t) - fdt_get_property(fdt, nodeoffset, name, lenp); -} - -/** - * fdt_getprop_by_offset - retrieve the value of a property at a given offset - * @fdt: pointer to the device tree blob - * @ffset: offset of the property to read - * @namep: pointer to a string variable (will be overwritten) or NULL - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_getprop_by_offset() retrieves a pointer to the value of the - * property at structure block offset 'offset' (this will be a pointer - * to within the device blob itself, not a copy of the value). If - * lenp is non-NULL, the length of the property value is also - * returned, in the integer pointed to by lenp. If namep is non-NULL, - * the property's namne will also be returned in the char * pointed to - * by namep (this will be a pointer to within the device tree's string - * block, not a new copy of the name). - * - * returns: - * pointer to the property's value - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * if namep is non-NULL *namep contiains a pointer to the property - * name. - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#ifndef SWIG /* This function is not useful in Python */ -const void *fdt_getprop_by_offset(const void *fdt, int offset, - const char **namep, int *lenp); -#endif - -/** - * fdt_getprop_namelen - get property value based on substring - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @namelen: number of characters of name to consider - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * Identical to fdt_getprop(), but only examine the first namelen - * characters of name for matching the property name. - */ -#ifndef SWIG /* Not available in Python */ -const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, - const char *name, int namelen, int *lenp); -static inline void *fdt_getprop_namelen_w(void *fdt, int nodeoffset, - const char *name, int namelen, - int *lenp) -{ - return (void *)(uintptr_t)fdt_getprop_namelen(fdt, nodeoffset, name, - namelen, lenp); -} -#endif - -/** - * fdt_getprop - retrieve the value of a given property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_getprop() retrieves a pointer to the value of the property - * named 'name' of the node at offset nodeoffset (this will be a - * pointer to within the device blob itself, not a copy of the value). - * If lenp is non-NULL, the length of the property value is also - * returned, in the integer pointed to by lenp. - * - * returns: - * pointer to the property's value - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_NOTFOUND, node does not have named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const void *fdt_getprop(const void *fdt, int nodeoffset, - const char *name, int *lenp); -static inline void *fdt_getprop_w(void *fdt, int nodeoffset, - const char *name, int *lenp) -{ - return (void *)(uintptr_t)fdt_getprop(fdt, nodeoffset, name, lenp); -} - -/** - * fdt_get_phandle - retrieve the phandle of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of the node - * - * fdt_get_phandle() retrieves the phandle of the device tree node at - * structure block offset nodeoffset. - * - * returns: - * the phandle of the node at nodeoffset, on success (!= 0, != -1) - * 0, if the node has no phandle, or another error occurs - */ -uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); - -/** - * fdt_get_alias_namelen - get alias based on substring - * @fdt: pointer to the device tree blob - * @name: name of the alias th look up - * @namelen: number of characters of name to consider - * - * Identical to fdt_get_alias(), but only examine the first namelen - * characters of name for matching the alias name. - */ -#ifndef SWIG /* Not available in Python */ -const char *fdt_get_alias_namelen(const void *fdt, - const char *name, int namelen); -#endif - -/** - * fdt_get_alias - retrieve the path referenced by a given alias - * @fdt: pointer to the device tree blob - * @name: name of the alias th look up - * - * fdt_get_alias() retrieves the value of a given alias. That is, the - * value of the property named 'name' in the node /aliases. - * - * returns: - * a pointer to the expansion of the alias named 'name', if it exists - * NULL, if the given alias or the /aliases node does not exist - */ -const char *fdt_get_alias(const void *fdt, const char *name); - -/** - * fdt_get_path - determine the full path of a node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose path to find - * @buf: character buffer to contain the returned path (will be overwritten) - * @buflen: size of the character buffer at buf - * - * fdt_get_path() computes the full path of the node at offset - * nodeoffset, and records that path in the buffer at buf. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * 0, on success - * buf contains the absolute path of the node at - * nodeoffset, as a NUL-terminated string. - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_NOSPACE, the path of the given node is longer than (bufsize-1) - * characters and will not fit in the given buffer. - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen); - -/** - * fdt_supernode_atdepth_offset - find a specific ancestor of a node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * @supernodedepth: depth of the ancestor to find - * @nodedepth: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_supernode_atdepth_offset() finds an ancestor of the given node - * at a specific depth from the root (where the root itself has depth - * 0, its immediate subnodes depth 1 and so forth). So - * fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, NULL); - * will always return 0, the offset of the root node. If the node at - * nodeoffset has depth D, then: - * fdt_supernode_atdepth_offset(fdt, nodeoffset, D, NULL); - * will return nodeoffset itself. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * structure block offset of the node at node offset's ancestor - * of depth supernodedepth (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of - * nodeoffset - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, - int supernodedepth, int *nodedepth); - -/** - * fdt_node_depth - find the depth of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * - * fdt_node_depth() finds the depth of a given node. The root node - * has depth 0, its immediate subnodes depth 1 and so forth. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * depth of the node at nodeoffset (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_depth(const void *fdt, int nodeoffset); - -/** - * fdt_parent_offset - find the parent of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * - * fdt_parent_offset() locates the parent node of a given node (that - * is, it finds the offset of the node which contains the node at - * nodeoffset as a subnode). - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset, *twice*. - * - * returns: - * structure block offset of the parent of the node at nodeoffset - * (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_parent_offset(const void *fdt, int nodeoffset); - -/** - * fdt_node_offset_by_prop_value - find nodes with a given property value - * @fdt: pointer to the device tree blob - * @startoffset: only find nodes after this offset - * @propname: property name to check - * @propval: property value to search for - * @proplen: length of the value in propval - * - * fdt_node_offset_by_prop_value() returns the offset of the first - * node after startoffset, which has a property named propname whose - * value is of length proplen and has value equal to propval; or if - * startoffset is -1, the very first such node in the tree. - * - * To iterate through all nodes matching the criterion, the following - * idiom can be used: - * offset = fdt_node_offset_by_prop_value(fdt, -1, propname, - * propval, proplen); - * while (offset != -FDT_ERR_NOTFOUND) { - * // other code here - * offset = fdt_node_offset_by_prop_value(fdt, offset, propname, - * propval, proplen); - * } - * - * Note the -1 in the first call to the function, if 0 is used here - * instead, the function will never locate the root node, even if it - * matches the criterion. - * - * returns: - * structure block offset of the located node (>= 0, >startoffset), - * on success - * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the - * tree after startoffset - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, - const char *propname, - const void *propval, int proplen); - -/** - * fdt_node_offset_by_phandle - find the node with a given phandle - * @fdt: pointer to the device tree blob - * @phandle: phandle value - * - * fdt_node_offset_by_phandle() returns the offset of the node - * which has the given phandle value. If there is more than one node - * in the tree with the given phandle (an invalid tree), results are - * undefined. - * - * returns: - * structure block offset of the located node (>= 0), on success - * -FDT_ERR_NOTFOUND, no node with that phandle exists - * -FDT_ERR_BADPHANDLE, given phandle value was invalid (0 or -1) - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle); - -/** - * fdt_node_check_compatible: check a node's compatible property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @compatible: string to match against - * - * - * fdt_node_check_compatible() returns 0 if the given node contains a - * 'compatible' property with the given string as one of its elements, - * it returns non-zero otherwise, or on error. - * - * returns: - * 0, if the node has a 'compatible' property listing the given string - * 1, if the node has a 'compatible' property, but it does not list - * the given string - * -FDT_ERR_NOTFOUND, if the given node has no 'compatible' property - * -FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_check_compatible(const void *fdt, int nodeoffset, - const char *compatible); - -/** - * fdt_node_offset_by_compatible - find nodes with a given 'compatible' value - * @fdt: pointer to the device tree blob - * @startoffset: only find nodes after this offset - * @compatible: 'compatible' string to match against - * - * fdt_node_offset_by_compatible() returns the offset of the first - * node after startoffset, which has a 'compatible' property which - * lists the given compatible string; or if startoffset is -1, the - * very first such node in the tree. - * - * To iterate through all nodes matching the criterion, the following - * idiom can be used: - * offset = fdt_node_offset_by_compatible(fdt, -1, compatible); - * while (offset != -FDT_ERR_NOTFOUND) { - * // other code here - * offset = fdt_node_offset_by_compatible(fdt, offset, compatible); - * } - * - * Note the -1 in the first call to the function, if 0 is used here - * instead, the function will never locate the root node, even if it - * matches the criterion. - * - * returns: - * structure block offset of the located node (>= 0, >startoffset), - * on success - * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the - * tree after startoffset - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_compatible(const void *fdt, int startoffset, - const char *compatible); - -/** - * fdt_stringlist_contains - check a string list property for a string - * @strlist: Property containing a list of strings to check - * @listlen: Length of property - * @str: String to search for - * - * This is a utility function provided for convenience. The list contains - * one or more strings, each terminated by \0, as is found in a device tree - * "compatible" property. - * - * @return: 1 if the string is found in the list, 0 not found, or invalid list - */ -int fdt_stringlist_contains(const char *strlist, int listlen, const char *str); - -/** - * fdt_stringlist_count - count the number of strings in a string list - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @return: - * the number of strings in the given property - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist - */ -int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property); - -/** - * fdt_stringlist_search - find a string in a string list and return its index - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @string: string to look up in the string list - * - * Note that it is possible for this function to succeed on property values - * that are not NUL-terminated. That's because the function will stop after - * finding the first occurrence of @string. This can for example happen with - * small-valued cell properties, such as #address-cells, when searching for - * the empty string. - * - * @return: - * the index of the string in the list of strings - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist or does not contain - * the given string - */ -int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property, - const char *string); - -/** - * fdt_stringlist_get() - obtain the string at a given index in a string list - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @index: index of the string to return - * @lenp: return location for the string length or an error code on failure - * - * Note that this will successfully extract strings from properties with - * non-NUL-terminated values. For example on small-valued cell properties - * this function will return the empty string. - * - * If non-NULL, the length of the string (on success) or a negative error-code - * (on failure) will be stored in the integer pointer to by lenp. - * - * @return: - * A pointer to the string at the given index in the string list or NULL on - * failure. On success the length of the string will be stored in the memory - * location pointed to by the lenp parameter, if non-NULL. On failure one of - * the following negative error codes will be returned in the lenp parameter - * (if non-NULL): - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist - */ -const char *fdt_stringlist_get(const void *fdt, int nodeoffset, - const char *property, int index, - int *lenp); - -/**********************************************************************/ -/* Read-only functions (addressing related) */ -/**********************************************************************/ - -/** - * FDT_MAX_NCELLS - maximum value for #address-cells and #size-cells - * - * This is the maximum value for #address-cells, #size-cells and - * similar properties that will be processed by libfdt. IEE1275 - * requires that OF implementations handle values up to 4. - * Implementations may support larger values, but in practice higher - * values aren't used. - */ -#define FDT_MAX_NCELLS 4 - -/** - * fdt_address_cells - retrieve address size for a bus represented in the tree - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to find the address size for - * - * When the node has a valid #address-cells property, returns its value. - * - * returns: - * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #address-cells property - * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid - * #address-cells property - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_address_cells(const void *fdt, int nodeoffset); - -/** - * fdt_size_cells - retrieve address range size for a bus represented in the - * tree - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to find the address range size for - * - * When the node has a valid #size-cells property, returns its value. - * - * returns: - * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #address-cells property - * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid - * #size-cells property - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_size_cells(const void *fdt, int nodeoffset); - - -/**********************************************************************/ -/* Write-in-place functions */ -/**********************************************************************/ - -/** - * fdt_setprop_inplace_namelen_partial - change a property's value, - * but not its size - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @namelen: number of characters of name to consider - * @idx: index of the property to change in the array - * @val: pointer to data to replace the property value with - * @len: length of the property value - * - * Identical to fdt_setprop_inplace(), but modifies the given property - * starting from the given index, and using only the first characters - * of the name. It is useful when you want to manipulate only one value of - * an array and you have a string that doesn't end with \0. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_setprop_inplace_namelen_partial(void *fdt, int nodeoffset, - const char *name, int namelen, - uint32_t idx, const void *val, - int len); -#endif - -/** - * fdt_setprop_inplace - change a property's value, but not its size - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: pointer to data to replace the property value with - * @len: length of the property value - * - * fdt_setprop_inplace() replaces the value of a given property with - * the data in val, of length len. This function cannot change the - * size of a property, and so will only work if len is equal to the - * current length of the property. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if len is not equal to the property's current length - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#ifndef SWIG /* Not available in Python */ -int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, - const void *val, int len); -#endif - -/** - * fdt_setprop_inplace_u32 - change the value of a 32-bit integer property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value to replace the property with - * - * fdt_setprop_inplace_u32() replaces the value of a given property - * with the 32-bit integer value in val, converting val to big-endian - * if necessary. This function cannot change the size of a property, - * and so will only work if the property already exists and has length - * 4. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if the property's length is not equal to 4 - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_inplace_u64 - change the value of a 64-bit integer property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value to replace the property with - * - * fdt_setprop_inplace_u64() replaces the value of a given property - * with the 64-bit integer value in val, converting val to big-endian - * if necessary. This function cannot change the size of a property, - * and so will only work if the property already exists and has length - * 8. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if the property's length is not equal to 8 - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset, - const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_inplace_cell - change the value of a single-cell property - * - * This is an alternative name for fdt_setprop_inplace_u32() - */ -static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - return fdt_setprop_inplace_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_nop_property - replace a property with nop tags - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to nop - * @name: name of the property to nop - * - * fdt_nop_property() will replace a given property's representation - * in the blob with FDT_NOP tags, effectively removing it from the - * tree. - * - * This function will alter only the bytes in the blob which contain - * the property, and will not alter or move any other part of the - * tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_nop_property(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_nop_node - replace a node (subtree) with nop tags - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to nop - * - * fdt_nop_node() will replace a given node's representation in the - * blob, including all its subnodes, if any, with FDT_NOP tags, - * effectively removing it from the tree. - * - * This function will alter only the bytes in the blob which contain - * the node and its properties and subnodes, and will not alter or - * move any other part of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_nop_node(void *fdt, int nodeoffset); - -/**********************************************************************/ -/* Sequential write functions */ -/**********************************************************************/ - -int fdt_create(void *buf, int bufsize); -int fdt_resize(void *fdt, void *buf, int bufsize); -int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); -int fdt_finish_reservemap(void *fdt); -int fdt_begin_node(void *fdt, const char *name); -int fdt_property(void *fdt, const char *name, const void *val, int len); -static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_property(fdt, name, &tmp, sizeof(tmp)); -} -static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_property(fdt, name, &tmp, sizeof(tmp)); -} -static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val) -{ - return fdt_property_u32(fdt, name, val); -} - -/** - * fdt_property_placeholder - add a new property and return a ptr to its value - * - * @fdt: pointer to the device tree blob - * @name: name of property to add - * @len: length of property value in bytes - * @valp: returns a pointer to where where the value should be placed - * - * returns: - * 0, on success - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_NOSPACE, standard meanings - */ -int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp); - -#define fdt_property_string(fdt, name, str) \ - fdt_property(fdt, name, str, strlen(str)+1) -int fdt_end_node(void *fdt); -int fdt_finish(void *fdt); - -/**********************************************************************/ -/* Read-write functions */ -/**********************************************************************/ - -int fdt_create_empty_tree(void *buf, int bufsize); -int fdt_open_into(const void *fdt, void *buf, int bufsize); -int fdt_pack(void *fdt); - -/** - * fdt_add_mem_rsv - add one memory reserve map entry - * @fdt: pointer to the device tree blob - * @address, @size: 64-bit values (native endian) - * - * Adds a reserve map entry to the given blob reserving a region at - * address address of length size. - * - * This function will insert data into the reserve map and will - * therefore change the indexes of some entries in the table. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new reservation entry - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size); - -/** - * fdt_del_mem_rsv - remove a memory reserve map entry - * @fdt: pointer to the device tree blob - * @n: entry to remove - * - * fdt_del_mem_rsv() removes the n-th memory reserve map entry from - * the blob. - * - * This function will delete data from the reservation table and will - * therefore change the indexes of some entries in the table. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, there is no entry of the given index (i.e. there - * are less than n+1 reserve map entries) - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_del_mem_rsv(void *fdt, int n); - -/** - * fdt_set_name - change the name of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of a node - * @name: name to give the node - * - * fdt_set_name() replaces the name (including unit address, if any) - * of the given node with the given string. NOTE: this function can't - * efficiently check if the new name is unique amongst the given - * node's siblings; results are undefined if this function is invoked - * with a name equal to one of the given node's siblings. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob - * to contain the new name - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_set_name(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_setprop - create or change a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: pointer to data to set the property value to - * @len: length of the property value - * - * fdt_setprop() sets the value of the named property in the given - * node to the given value and length, creating the property if it - * does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_setprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len); - -/** - * fdt_setprop _placeholder - allocate space for a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @len: length of the property value - * @prop_data: return pointer to property data - * - * fdt_setprop_placeholer() allocates the named property in the given node. - * If the property exists it is resized. In either case a pointer to the - * property data is returned. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, - int len, void **prop_data); - -/** - * fdt_setprop_u32 - set a property to a 32-bit integer - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value for the property (native endian) - * - * fdt_setprop_u32() sets the value of the named property in the given - * node to the given 32-bit integer value (converting to big-endian if - * necessary), or creates a new property with that value if it does - * not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name, - uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_u64 - set a property to a 64-bit integer - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value for the property (native endian) - * - * fdt_setprop_u64() sets the value of the named property in the given - * node to the given 64-bit integer value (converting to big-endian if - * necessary), or creates a new property with that value if it does - * not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name, - uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_cell - set a property to a single cell value - * - * This is an alternative name for fdt_setprop_u32() - */ -static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, - uint32_t val) -{ - return fdt_setprop_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_setprop_string - set a property to a string value - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @str: string value for the property - * - * fdt_setprop_string() sets the value of the named property in the - * given node to the given string value (using the length of the - * string to determine the new length of the property), or creates a - * new property with that value if it does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_setprop_string(fdt, nodeoffset, name, str) \ - fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) - - -/** - * fdt_setprop_empty - set a property to an empty value - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * - * fdt_setprop_empty() sets the value of the named property in the - * given node to an empty (zero length) value, or creates a new empty - * property if it does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_setprop_empty(fdt, nodeoffset, name) \ - fdt_setprop((fdt), (nodeoffset), (name), NULL, 0) - -/** - * fdt_appendprop - append to or create a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to append to - * @val: pointer to data to append to the property value - * @len: length of the data to append to the property value - * - * fdt_appendprop() appends the value to the named property in the - * given node, creating the property if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_appendprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len); - -/** - * fdt_appendprop_u32 - append a 32-bit integer value to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value to append to the property (native endian) - * - * fdt_appendprop_u32() appends the given 32-bit integer value - * (converting to big-endian if necessary) to the value of the named - * property in the given node, or creates a new property with that - * value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_appendprop_u32(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_appendprop_u64 - append a 64-bit integer value to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value to append to the property (native endian) - * - * fdt_appendprop_u64() appends the given 64-bit integer value - * (converting to big-endian if necessary) to the value of the named - * property in the given node, or creates a new property with that - * value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_appendprop_u64(void *fdt, int nodeoffset, - const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_appendprop_cell - append a single cell value to a property - * - * This is an alternative name for fdt_appendprop_u32() - */ -static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - return fdt_appendprop_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_appendprop_string - append a string to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @str: string value to append to the property - * - * fdt_appendprop_string() appends the given string to the value of - * the named property in the given node, or creates a new property - * with that value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_appendprop_string(fdt, nodeoffset, name, str) \ - fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) - -/** - * fdt_delprop - delete a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to nop - * @name: name of the property to nop - * - * fdt_del_property() will delete the given property. - * - * This function will delete data from the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_delprop(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_add_subnode_namelen - creates a new node based on substring - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * @namelen: number of characters of name to consider - * - * Identical to fdt_add_subnode(), but use only the first namelen - * characters of name as the name of the new node. This is useful for - * creating subnodes based on a portion of a larger string, such as a - * full path. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_add_subnode_namelen(void *fdt, int parentoffset, - const char *name, int namelen); -#endif - -/** - * fdt_add_subnode - creates a new node - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * - * fdt_add_subnode() creates a new node as a subnode of the node at - * structure block offset parentoffset, with the given name (which - * should include the unit address, if any). - * - * This function will insert data into the blob, and will therefore - * change the offsets of some existing nodes. - - * returns: - * structure block offset of the created nodeequested subnode (>=0), on - * success - * -FDT_ERR_NOTFOUND, if the requested subnode does not exist - * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE - * tag - * -FDT_ERR_EXISTS, if the node at parentoffset already has a subnode of - * the given name - * -FDT_ERR_NOSPACE, if there is insufficient free space in the - * blob to contain the new node - * -FDT_ERR_NOSPACE - * -FDT_ERR_BADLAYOUT - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_add_subnode(void *fdt, int parentoffset, const char *name); - -/** - * fdt_del_node - delete a node (subtree) - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to nop - * - * fdt_del_node() will remove the given node, including all its - * subnodes if any, from the blob. - * - * This function will delete data from the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_del_node(void *fdt, int nodeoffset); - -/** - * fdt_overlay_apply - Applies a DT overlay on a base DT - * @fdt: pointer to the base device tree blob - * @fdto: pointer to the device tree overlay blob - * - * fdt_overlay_apply() will apply the given device tree overlay on the - * given base device tree. - * - * Expect the base device tree to be modified, even if the function - * returns an error. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there's not enough space in the base device tree - * -FDT_ERR_NOTFOUND, the overlay points to some inexistant nodes or - * properties in the base DT - * -FDT_ERR_BADPHANDLE, - * -FDT_ERR_BADOVERLAY, - * -FDT_ERR_NOPHANDLES, - * -FDT_ERR_INTERNAL, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADOFFSET, - * -FDT_ERR_BADPATH, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_overlay_apply(void *fdt, void *fdto); - -/**********************************************************************/ -/* Debugging / informational functions */ -/**********************************************************************/ - -#ifndef SWIG /* Not available in Python */ -const char *fdt_strerror(int errval); - -struct fdt_region { - int offset; - int size; -}; - -/* - * Flags for fdt_find_regions() - * - * Add a region for the string table (always the last region) - */ -#define FDT_REG_ADD_STRING_TAB (1 << 0) - -/* - * Add all supernodes of a matching node/property, useful for creating a - * valid subset tree - */ -#define FDT_REG_SUPERNODES (1 << 1) - -/* Add the FDT_BEGIN_NODE tags of subnodes, including their names */ -#define FDT_REG_DIRECT_SUBNODES (1 << 2) - -/* Add all subnodes of a matching node */ -#define FDT_REG_ALL_SUBNODES (1 << 3) - -/* Add a region for the mem_rsvmap table (always the first region) */ -#define FDT_REG_ADD_MEM_RSVMAP (1 << 4) - -/* Indicates what an fdt part is (node, property, value) */ -#define FDT_IS_NODE (1 << 0) -#define FDT_IS_PROP (1 << 1) -#define FDT_IS_VALUE (1 << 2) /* not supported */ -#define FDT_IS_COMPAT (1 << 3) /* used internally */ -#define FDT_NODE_HAS_PROP (1 << 4) /* node contains prop */ - -#define FDT_ANY_GLOBAL (FDT_IS_NODE | FDT_IS_PROP | FDT_IS_VALUE | \ - FDT_IS_COMPAT) -#define FDT_IS_ANY 0x1f /* all the above */ - -/* We set a reasonable limit on the number of nested nodes */ -#define FDT_MAX_DEPTH 32 - -/* Decribes what we want to include from the current tag */ -enum want_t { - WANT_NOTHING, - WANT_NODES_ONLY, /* No properties */ - WANT_NODES_AND_PROPS, /* Everything for one level */ - WANT_ALL_NODES_AND_PROPS /* Everything for all levels */ -}; - -/* Keeps track of the state at parent nodes */ -struct fdt_subnode_stack { - int offset; /* Offset of node */ - enum want_t want; /* The 'want' value here */ - int included; /* 1 if we included this node, 0 if not */ -}; - -struct fdt_region_ptrs { - int depth; /* Current tree depth */ - int done; /* What we have completed scanning */ - enum want_t want; /* What we are currently including */ - char *end; /* Pointer to end of full node path */ - int nextoffset; /* Next node offset to check */ -}; - -/* The state of our finding algortihm */ -struct fdt_region_state { - struct fdt_subnode_stack stack[FDT_MAX_DEPTH]; /* node stack */ - struct fdt_region *region; /* Contains list of regions found */ - int count; /* Numnber of regions found */ - const void *fdt; /* FDT blob */ - int max_regions; /* Maximum regions to find */ - int can_merge; /* 1 if we can merge with previous region */ - int start; /* Start position of current region */ - struct fdt_region_ptrs ptrs; /* Pointers for what we are up to */ -}; - -/** - * fdt_find_regions() - find regions in device tree - * - * Given a list of nodes to include and properties to exclude, find - * the regions of the device tree which describe those included parts. - * - * The intent is to get a list of regions which will be invariant provided - * those parts are invariant. For example, if you request a list of regions - * for all nodes but exclude the property "data", then you will get the - * same region contents regardless of any change to "data" properties. - * - * This function can be used to produce a byte-stream to send to a hashing - * function to verify that critical parts of the FDT have not changed. - * - * Nodes which are given in 'inc' are included in the region list, as - * are the names of the immediate subnodes nodes (but not the properties - * or subnodes of those subnodes). - * - * For eaxample "/" means to include the root node, all root properties - * and the FDT_BEGIN_NODE and FDT_END_NODE of all subnodes of /. The latter - * ensures that we capture the names of the subnodes. In a hashing situation - * it prevents the root node from changing at all Any change to non-excluded - * properties, names of subnodes or number of subnodes would be detected. - * - * When used with FITs this provides the ability to hash and sign parts of - * the FIT based on different configurations in the FIT. Then it is - * impossible to change anything about that configuration (include images - * attached to the configuration), but it may be possible to add new - * configurations, new images or new signatures within the existing - * framework. - * - * Adding new properties to a device tree may result in the string table - * being extended (if the new property names are different from those - * already added). This function can optionally include a region for - * the string table so that this can be part of the hash too. - * - * The device tree header is not included in the list. - * - * @fdt: Device tree to check - * @inc: List of node paths to included - * @inc_count: Number of node paths in list - * @exc_prop: List of properties names to exclude - * @exc_prop_count: Number of properties in exclude list - * @region: Returns list of regions - * @max_region: Maximum length of region list - * @path: Pointer to a temporary string for the function to use for - * building path names - * @path_len: Length of path, must be large enough to hold the longest - * path in the tree - * @add_string_tab: 1 to add a region for the string table - * @return number of regions in list. If this is >max_regions then the - * region array was exhausted. You should increase max_regions and try - * the call again. - */ -int fdt_find_regions(const void *fdt, char * const inc[], int inc_count, - char * const exc_prop[], int exc_prop_count, - struct fdt_region region[], int max_regions, - char *path, int path_len, int add_string_tab); - -/** - * fdt_first_region() - find regions in device tree - * - * Given a nodes and properties to include and properties to exclude, find - * the regions of the device tree which describe those included parts. - * - * The use for this function is twofold. Firstly it provides a convenient - * way of performing a structure-aware grep of the tree. For example it is - * possible to grep for a node and get all the properties associated with - * that node. Trees can be subsetted easily, by specifying the nodes that - * are required, and then writing out the regions returned by this function. - * This is useful for small resource-constrained systems, such as boot - * loaders, which want to use an FDT but do not need to know about all of - * it. - * - * Secondly it makes it easy to hash parts of the tree and detect changes. - * The intent is to get a list of regions which will be invariant provided - * those parts are invariant. For example, if you request a list of regions - * for all nodes but exclude the property "data", then you will get the - * same region contents regardless of any change to "data" properties. - * - * This function can be used to produce a byte-stream to send to a hashing - * function to verify that critical parts of the FDT have not changed. - * Note that semantically null changes in order could still cause false - * hash misses. Such reordering might happen if the tree is regenerated - * from source, and nodes are reordered (the bytes-stream will be emitted - * in a different order and mnay hash functions will detect this). However - * if an existing tree is modified using libfdt functions, such as - * fdt_add_subnode() and fdt_setprop(), then this problem is avoided. - * - * The nodes/properties to include/exclude are defined by a function - * provided by the caller. This function is called for each node and - * property, and must return: - * - * 0 - to exclude this part - * 1 - to include this part - * -1 - for FDT_IS_PROP only: no information is available, so include - * if its containing node is included - * - * The last case is only used to deal with properties. Often a property is - * included if its containing node is included - this is the case where - * -1 is returned.. However if the property is specifically required to be - * included/excluded, then 0 or 1 can be returned. Note that including a - * property when the FDT_REG_SUPERNODES flag is given will force its - * containing node to be included since it is not valid to have a property - * that is not in a node. - * - * Using the information provided, the inclusion of a node can be controlled - * either by a node name or its compatible string, or any other property - * that the function can determine. - * - * As an example, including node "/" means to include the root node and all - * root properties. A flag provides a way of also including supernodes (of - * which there is none for the root node), and another flag includes - * immediate subnodes, so in this case we would get the FDT_BEGIN_NODE and - * FDT_END_NODE of all subnodes of /. - * - * The subnode feature helps in a hashing situation since it prevents the - * root node from changing at all. Any change to non-excluded properties, - * names of subnodes or number of subnodes would be detected. - * - * When used with FITs this provides the ability to hash and sign parts of - * the FIT based on different configurations in the FIT. Then it is - * impossible to change anything about that configuration (include images - * attached to the configuration), but it may be possible to add new - * configurations, new images or new signatures within the existing - * framework. - * - * Adding new properties to a device tree may result in the string table - * being extended (if the new property names are different from those - * already added). This function can optionally include a region for - * the string table so that this can be part of the hash too. This is always - * the last region. - * - * The FDT also has a mem_rsvmap table which can also be included, and is - * always the first region if so. - * - * The device tree header is not included in the region list. Since the - * contents of the FDT are changing (shrinking, often), the caller will need - * to regenerate the header anyway. - * - * @fdt: Device tree to check - * @h_include: Function to call to determine whether to include a part or - * not: - * - * @priv: Private pointer as passed to fdt_find_regions() - * @fdt: Pointer to FDT blob - * @offset: Offset of this node / property - * @type: Type of this part, FDT_IS_... - * @data: Pointer to data (node name, property name, compatible - * string, value (not yet supported) - * @size: Size of data, or 0 if none - * @return 0 to exclude, 1 to include, -1 if no information is - * available - * @priv: Private pointer passed to h_include - * @region: Returns list of regions, sorted by offset - * @max_regions: Maximum length of region list - * @path: Pointer to a temporary string for the function to use for - * building path names - * @path_len: Length of path, must be large enough to hold the longest - * path in the tree - * @flags: Various flags that control the region algortihm, see - * FDT_REG_... - * @return number of regions in list. If this is >max_regions then the - * region array was exhausted. You should increase max_regions and try - * the call again. Only the first max_regions elements are available in the - * array. - * - * On error a -ve value is return, which can be: - * - * -FDT_ERR_BADSTRUCTURE (too deep or more END tags than BEGIN tags - * -FDT_ERR_BADLAYOUT - * -FDT_ERR_NOSPACE (path area is too small) - */ -int fdt_first_region(const void *fdt, - int (*h_include)(void *priv, const void *fdt, int offset, - int type, const char *data, int size), - void *priv, struct fdt_region *region, - char *path, int path_len, int flags, - struct fdt_region_state *info); - -/** fdt_next_region() - find next region - * - * See fdt_first_region() for full description. This function finds the - * next region according to the provided parameters, which must be the same - * as passed to fdt_first_region(). - * - * This function can additionally return -FDT_ERR_NOTFOUND when there are no - * more regions - */ -int fdt_next_region(const void *fdt, - int (*h_include)(void *priv, const void *fdt, int offset, - int type, const char *data, int size), - void *priv, struct fdt_region *region, - char *path, int path_len, int flags, - struct fdt_region_state *info); - -/** - * fdt_add_alias_regions() - find aliases that point to existing regions - * - * Once a device tree grep is complete some of the nodes will be present - * and some will have been dropped. This function checks all the alias nodes - * to figure out which points point to nodes which are still present. These - * aliases need to be kept, along with the nodes they reference. - * - * Given a list of regions function finds the aliases that still apply and - * adds more regions to the list for these. This function is called after - * fdt_next_region() has finished returning regions and requires the same - * state. - * - * @fdt: Device tree file to reference - * @region: List of regions that will be kept - * @count: Number of regions - * @max_regions: Number of entries that can fit in @region - * @info: Region state as returned from fdt_next_region() - * @return new number of regions in @region (i.e. count + the number added) - * or -FDT_ERR_NOSPACE if there was not enough space. - */ -int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, - int max_regions, struct fdt_region_state *info); -#endif /* SWIG */ - -#endif /* _LIBFDT_H */
Hi Masahiro,
On 9 January 2018 at 01:34, Masahiro Yamada yamada.masahiro@socionext.com wrote:
include/libfdt.h is a wrapper of lib/libfdt/libfdt.h, but lib/libfdt/ is no longer a central point of libfdt. (Now, scripts/dtc/libfdt is synced with upstream)
Move the content to include/libfdt.h, then delete lib/libfdt/libfdt.h.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com
include/libfdt.h | 2154 ++++++++++++++++++++++++++++++++++++++++++++++++++- lib/libfdt/libfdt.h | 2153 -------------------------------------------------- 2 files changed, 2153 insertions(+), 2154 deletions(-) delete mode 100644 lib/libfdt/libfdt.h
How come this is such a huge delta, if it is just a rename?
Hi Simon,
2018-01-16 23:50 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Masahiro,
The original include/libfdt.h contained one-line include.
I guess that is why git did not consider this renaming.
libfdt_env.h exists to contain system-dependent defines:
- typedef of fdt*_t - fdt*_to_cpu(), cpu_to_fdt*
working_fdt and FDT_RAMDISK_OVERHEAD are unrelated to the environment, so they must get out of this header.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/libfdt.h | 5 +++++ include/libfdt_env.h | 5 ----- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/libfdt.h b/include/libfdt.h index 4e2c841..59da5bc 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -2150,4 +2150,9 @@ int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, int max_regions, struct fdt_region_state *info); #endif /* SWIG */
+extern struct fdt_header *working_fdt; /* Pointer to the working fdt */ + +/* adding a ramdisk needs 0x44 bytes in version 2008.10 */ +#define FDT_RAMDISK_OVERHEAD 0x80 + #endif /* _LIBFDT_H */ diff --git a/include/libfdt_env.h b/include/libfdt_env.h index 273b5d3..ea26979 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -12,8 +12,6 @@ #include "compiler.h" #include "linux/types.h"
-extern struct fdt_header *working_fdt; /* Pointer to the working fdt */ - typedef __be16 fdt16_t; typedef __be32 fdt32_t; typedef __be64 fdt64_t; @@ -23,7 +21,4 @@ typedef __be64 fdt64_t; #define fdt64_to_cpu(x) be64_to_cpu(x) #define cpu_to_fdt64(x) cpu_to_be64(x)
-/* adding a ramdisk needs 0x44 bytes in version 2008.10 */ -#define FDT_RAMDISK_OVERHEAD 0x80 - #endif /* _LIBFDT_ENV_H */
- typedef of fdt*_t
Remove the tons of code duplication between include/libfdt.h and sciprts/dtc/libfdt/libfdt.h. I am keeping U-Boot local code in include/libfdt.h.
include/libfdt.h | 1856 +----------------------------------------------------- 1 file changed, 8 insertions(+), 1848 deletions(-)
diff --git a/include/libfdt.h b/include/libfdt.h index 59da5bc..0979ad6 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -1,1858 +1,18 @@ -#ifndef _LIBFDT_H -#define _LIBFDT_H +#ifndef UBOOT_LIBFDT_H +#define UBOOT_LIBFDT_H /* - * libfdt - Flat Device Tree manipulation - * Copyright (C) 2006 David Gibson, IBM Corporation. - * * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */
-#include <libfdt_env.h> -#include <fdt.h> - -#define FDT_FIRST_SUPPORTED_VERSION 0x10 -#define FDT_LAST_SUPPORTED_VERSION 0x11 - -/* Error codes: informative error codes */ -#define FDT_ERR_NOTFOUND 1 - /* FDT_ERR_NOTFOUND: The requested node or property does not exist */ -#define FDT_ERR_EXISTS 2 - /* FDT_ERR_EXISTS: Attempted to create a node or property which - * already exists */ -#define FDT_ERR_NOSPACE 3 - /* FDT_ERR_NOSPACE: Operation needed to expand the device - * tree, but its buffer did not have sufficient space to - * contain the expanded tree. Use fdt_open_into() to move the - * device tree to a buffer with more space. */ - -/* Error codes: codes for bad parameters */ -#define FDT_ERR_BADOFFSET 4 - /* FDT_ERR_BADOFFSET: Function was passed a structure block - * offset which is out-of-bounds, or which points to an - * unsuitable part of the structure for the operation. */ -#define FDT_ERR_BADPATH 5 - /* FDT_ERR_BADPATH: Function was passed a badly formatted path - * (e.g. missing a leading / for a function which requires an - * absolute path) */ -#define FDT_ERR_BADPHANDLE 6 - /* FDT_ERR_BADPHANDLE: Function was passed an invalid phandle. - * This can be caused either by an invalid phandle property - * length, or the phandle value was either 0 or -1, which are - * not permitted. */ -#define FDT_ERR_BADSTATE 7 - /* FDT_ERR_BADSTATE: Function was passed an incomplete device - * tree created by the sequential-write functions, which is - * not sufficiently complete for the requested operation. */ - -/* Error codes: codes for bad device tree blobs */ -#define FDT_ERR_TRUNCATED 8 - /* FDT_ERR_TRUNCATED: Structure block of the given device tree - * ends without an FDT_END tag. */ -#define FDT_ERR_BADMAGIC 9 - /* FDT_ERR_BADMAGIC: Given "device tree" appears not to be a - * device tree at all - it is missing the flattened device - * tree magic number. */ -#define FDT_ERR_BADVERSION 10 - /* FDT_ERR_BADVERSION: Given device tree has a version which - * can't be handled by the requested operation. For - * read-write functions, this may mean that fdt_open_into() is - * required to convert the tree to the expected version. */ -#define FDT_ERR_BADSTRUCTURE 11 - /* FDT_ERR_BADSTRUCTURE: Given device tree has a corrupt - * structure block or other serious error (e.g. misnested - * nodes, or subnodes preceding properties). */ -#define FDT_ERR_BADLAYOUT 12 - /* FDT_ERR_BADLAYOUT: For read-write functions, the given - * device tree has it's sub-blocks in an order that the - * function can't handle (memory reserve map, then structure, - * then strings). Use fdt_open_into() to reorganize the tree - * into a form suitable for the read-write operations. */ - -/* "Can't happen" error indicating a bug in libfdt */ -#define FDT_ERR_INTERNAL 13 - /* FDT_ERR_INTERNAL: libfdt has failed an internal assertion. - * Should never be returned, if it is, it indicates a bug in - * libfdt itself. */ - -/* Errors in device tree content */ -#define FDT_ERR_BADNCELLS 14 - /* FDT_ERR_BADNCELLS: Device tree has a #address-cells, #size-cells - * or similar property with a bad format or value */ - -#define FDT_ERR_BADVALUE 15 - /* FDT_ERR_BADVALUE: Device tree has a property with an unexpected - * value. For example: a property expected to contain a string list - * is not NUL-terminated within the length of its value. */ - -#define FDT_ERR_BADOVERLAY 16 - /* FDT_ERR_BADOVERLAY: The device tree overlay, while - * correctly structured, cannot be applied due to some - * unexpected or missing value, property or node. */ - -#define FDT_ERR_NOPHANDLES 17 - /* FDT_ERR_NOPHANDLES: The device tree doesn't have any - * phandle available anymore without causing an overflow */ - -#define FDT_ERR_MAX 17 - -/**********************************************************************/ -/* Low-level functions (you probably don't need these) */ -/**********************************************************************/ - -#ifndef SWIG /* This function is not useful in Python */ -const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int checklen); -#endif -static inline void *fdt_offset_ptr_w(void *fdt, int offset, int checklen) -{ - return (void *)(uintptr_t)fdt_offset_ptr(fdt, offset, checklen); -} - -uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset); - -/**********************************************************************/ -/* Traversal functions */ -/**********************************************************************/ - -int fdt_next_node(const void *fdt, int offset, int *depth); - -/** - * fdt_first_subnode() - get offset of first direct subnode - * - * @fdt: FDT blob - * @offset: Offset of node to check - * @return offset of first subnode, or -FDT_ERR_NOTFOUND if there is none - */ -int fdt_first_subnode(const void *fdt, int offset); - -/** - * fdt_next_subnode() - get offset of next direct subnode - * - * After first calling fdt_first_subnode(), call this function repeatedly to - * get direct subnodes of a parent node. - * - * @fdt: FDT blob - * @offset: Offset of previous subnode - * @return offset of next subnode, or -FDT_ERR_NOTFOUND if there are no more - * subnodes - */ -int fdt_next_subnode(const void *fdt, int offset); - -/** - * fdt_for_each_subnode - iterate over all subnodes of a parent - * - * @node: child node (int, lvalue) - * @fdt: FDT blob (const void *) - * @parent: parent node (int) - * - * This is actually a wrapper around a for loop and would be used like so: - * - * fdt_for_each_subnode(node, fdt, parent) { - * Use node - * ... - * } - * - * if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) { - * Error handling - * } - * - * Note that this is implemented as a macro and @node is used as - * iterator in the loop. The parent variable be constant or even a - * literal. - * - */ -#define fdt_for_each_subnode(node, fdt, parent) \ - for (node = fdt_first_subnode(fdt, parent); \ - node >= 0; \ - node = fdt_next_subnode(fdt, node)) - -/**********************************************************************/ -/* General functions */ -/**********************************************************************/ -#define fdt_get_header(fdt, field) \ - (fdt32_to_cpu(((const struct fdt_header *)(fdt))->field)) -#define fdt_magic(fdt) (fdt_get_header(fdt, magic)) -#define fdt_totalsize(fdt) (fdt_get_header(fdt, totalsize)) -#define fdt_off_dt_struct(fdt) (fdt_get_header(fdt, off_dt_struct)) -#define fdt_off_dt_strings(fdt) (fdt_get_header(fdt, off_dt_strings)) -#define fdt_off_mem_rsvmap(fdt) (fdt_get_header(fdt, off_mem_rsvmap)) -#define fdt_version(fdt) (fdt_get_header(fdt, version)) -#define fdt_last_comp_version(fdt) (fdt_get_header(fdt, last_comp_version)) -#define fdt_boot_cpuid_phys(fdt) (fdt_get_header(fdt, boot_cpuid_phys)) -#define fdt_size_dt_strings(fdt) (fdt_get_header(fdt, size_dt_strings)) -#define fdt_size_dt_struct(fdt) (fdt_get_header(fdt, size_dt_struct)) - -#define __fdt_set_hdr(name) \ - static inline void fdt_set_##name(void *fdt, uint32_t val) \ - { \ - struct fdt_header *fdth = (struct fdt_header *)fdt; \ - fdth->name = cpu_to_fdt32(val); \ - } -__fdt_set_hdr(magic); -__fdt_set_hdr(totalsize); -__fdt_set_hdr(off_dt_struct); -__fdt_set_hdr(off_dt_strings); -__fdt_set_hdr(off_mem_rsvmap); -__fdt_set_hdr(version); -__fdt_set_hdr(last_comp_version); -__fdt_set_hdr(boot_cpuid_phys); -__fdt_set_hdr(size_dt_strings); -__fdt_set_hdr(size_dt_struct); -#undef __fdt_set_hdr - -/** - * fdt_check_header - sanity check a device tree or possible device tree - * @fdt: pointer to data which might be a flattened device tree - * - * fdt_check_header() checks that the given buffer contains what - * appears to be a flattened device tree with sane information in its - * header. - * - * returns: - * 0, if the buffer appears to contain a valid device tree - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings, as above - */ -int fdt_check_header(const void *fdt); - -/** - * fdt_move - move a device tree around in memory - * @fdt: pointer to the device tree to move - * @buf: pointer to memory where the device is to be moved - * @bufsize: size of the memory space at buf - * - * fdt_move() relocates, if possible, the device tree blob located at - * fdt to the buffer at buf of size bufsize. The buffer may overlap - * with the existing device tree blob at fdt. Therefore, - * fdt_move(fdt, fdt, fdt_totalsize(fdt)) - * should always succeed. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, bufsize is insufficient to contain the device tree - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_move(const void *fdt, void *buf, int bufsize); - -/**********************************************************************/ -/* Read-only functions */ -/**********************************************************************/ - -/** - * fdt_string - retrieve a string from the strings block of a device tree - * @fdt: pointer to the device tree blob - * @stroffset: offset of the string within the strings block (native endian) - * - * fdt_string() retrieves a pointer to a single string from the - * strings block of the device tree blob at fdt. - * - * returns: - * a pointer to the string, on success - * NULL, if stroffset is out of bounds - */ -const char *fdt_string(const void *fdt, int stroffset); - -/** - * fdt_get_max_phandle - retrieves the highest phandle in a tree - * @fdt: pointer to the device tree blob - * - * fdt_get_max_phandle retrieves the highest phandle in the given - * device tree. This will ignore badly formatted phandles, or phandles - * with a value of 0 or -1. - * - * returns: - * the highest phandle on success - * 0, if no phandle was found in the device tree - * -1, if an error occurred - */ -uint32_t fdt_get_max_phandle(const void *fdt); - -/** - * fdt_num_mem_rsv - retrieve the number of memory reserve map entries - * @fdt: pointer to the device tree blob - * - * Returns the number of entries in the device tree blob's memory - * reservation map. This does not include the terminating 0,0 entry - * or any other (0,0) entries reserved for expansion. - * - * returns: - * the number of entries - */ -int fdt_num_mem_rsv(const void *fdt); - -/** - * fdt_get_mem_rsv - retrieve one memory reserve map entry - * @fdt: pointer to the device tree blob - * @address, @size: pointers to 64-bit variables - * - * On success, *address and *size will contain the address and size of - * the n-th reserve map entry from the device tree blob, in - * native-endian format. - * - * returns: - * 0, on success - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size); - -/** - * fdt_subnode_offset_namelen - find a subnode based on substring - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * @namelen: number of characters of name to consider - * - * Identical to fdt_subnode_offset(), but only examine the first - * namelen characters of name for matching the subnode name. This is - * useful for finding subnodes based on a portion of a larger string, - * such as a full path. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, - const char *name, int namelen); -#endif -/** - * fdt_subnode_offset - find a subnode of a given node - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * - * fdt_subnode_offset() finds a subnode of the node at structure block - * offset parentoffset with the given name. name may include a unit - * address, in which case fdt_subnode_offset() will find the subnode - * with that unit address, or the unit address may be omitted, in - * which case fdt_subnode_offset() will find an arbitrary subnode - * whose name excluding unit address matches the given name. - * - * returns: - * structure block offset of the requested subnode (>=0), on success - * -FDT_ERR_NOTFOUND, if the requested subnode does not exist - * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name); - -/** - * fdt_path_offset_namelen - find a tree node by its full path - * @fdt: pointer to the device tree blob - * @path: full path of the node to locate - * @namelen: number of characters of path to consider - * - * Identical to fdt_path_offset(), but only consider the first namelen - * characters of path as the path name. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen); -#endif - -/** - * fdt_path_offset - find a tree node by its full path - * @fdt: pointer to the device tree blob - * @path: full path of the node to locate - * - * fdt_path_offset() finds a node of a given path in the device tree. - * Each path component may omit the unit address portion, but the - * results of this are undefined if any such path component is - * ambiguous (that is if there are multiple nodes at the relevant - * level matching the given component, differentiated only by unit - * address). - * - * returns: - * structure block offset of the node with the requested path (>=0), on - * success - * -FDT_ERR_BADPATH, given path does not begin with '/' or is invalid - * -FDT_ERR_NOTFOUND, if the requested node does not exist - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_path_offset(const void *fdt, const char *path); - -/** - * fdt_get_name - retrieve the name of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of the starting node - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_name() retrieves the name (including unit address) of the - * device tree node at structure block offset nodeoffset. If lenp is - * non-NULL, the length of this name is also returned, in the integer - * pointed to by lenp. - * - * returns: - * pointer to the node's name, on success - * If lenp is non-NULL, *lenp contains the length of that name - * (>=0) - * NULL, on error - * if lenp is non-NULL *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -const char *fdt_get_name(const void *fdt, int nodeoffset, int *lenp); - -/** - * fdt_first_property_offset - find the offset of a node's first property - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of a node - * - * fdt_first_property_offset() finds the first property of the node at - * the given structure block offset. - * - * returns: - * structure block offset of the property (>=0), on success - * -FDT_ERR_NOTFOUND, if the requested node has no properties - * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_first_property_offset(const void *fdt, int nodeoffset); - -/** - * fdt_next_property_offset - step through a node's properties - * @fdt: pointer to the device tree blob - * @offset: structure block offset of a property - * - * fdt_next_property_offset() finds the property immediately after the - * one at the given structure block offset. This will be a property - * of the same node as the given property. - * - * returns: - * structure block offset of the next property (>=0), on success - * -FDT_ERR_NOTFOUND, if the given property is the last in its node - * -FDT_ERR_BADOFFSET, if nodeoffset did not point to an FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_next_property_offset(const void *fdt, int offset); - -/** - * fdt_for_each_property_offset - iterate over all properties of a node - * - * @property_offset: property offset (int, lvalue) - * @fdt: FDT blob (const void *) - * @node: node offset (int) - * - * This is actually a wrapper around a for loop and would be used like so: - * - * fdt_for_each_property_offset(property, fdt, node) { - * Use property - * ... - * } - * - * if ((property < 0) && (property != -FDT_ERR_NOT_FOUND)) { - * Error handling - * } - * - * Note that this is implemented as a macro and property is used as - * iterator in the loop. The node variable can be constant or even a - * literal. - */ -#define fdt_for_each_property_offset(property, fdt, node) \ - for (property = fdt_first_property_offset(fdt, node); \ - property >= 0; \ - property = fdt_next_property_offset(fdt, property)) - -/** - * fdt_get_property_by_offset - retrieve the property at a given offset - * @fdt: pointer to the device tree blob - * @offset: offset of the property to retrieve - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_property_by_offset() retrieves a pointer to the - * fdt_property structure within the device tree blob at the given - * offset. If lenp is non-NULL, the length of the property value is - * also returned, in the integer pointed to by lenp. - * - * returns: - * pointer to the structure representing the property - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const struct fdt_property *fdt_get_property_by_offset(const void *fdt, - int offset, - int *lenp); - -/** - * fdt_get_property_namelen - find a property based on substring - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @namelen: number of characters of name to consider - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * Identical to fdt_get_property(), but only examine the first namelen - * characters of name for matching the property name. - */ -#ifndef SWIG /* Not available in Python */ -const struct fdt_property *fdt_get_property_namelen(const void *fdt, - int nodeoffset, - const char *name, - int namelen, int *lenp); -#endif - -/** - * fdt_get_property - find a given property in a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_get_property() retrieves a pointer to the fdt_property - * structure within the device tree blob corresponding to the property - * named 'name' of the node at offset nodeoffset. If lenp is - * non-NULL, the length of the property value is also returned, in the - * integer pointed to by lenp. - * - * returns: - * pointer to the structure representing the property - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_NOTFOUND, node does not have named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, - const char *name, int *lenp); -static inline struct fdt_property *fdt_get_property_w(void *fdt, int nodeoffset, - const char *name, - int *lenp) -{ - return (struct fdt_property *)(uintptr_t) - fdt_get_property(fdt, nodeoffset, name, lenp); -} - -/** - * fdt_getprop_by_offset - retrieve the value of a property at a given offset - * @fdt: pointer to the device tree blob - * @ffset: offset of the property to read - * @namep: pointer to a string variable (will be overwritten) or NULL - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_getprop_by_offset() retrieves a pointer to the value of the - * property at structure block offset 'offset' (this will be a pointer - * to within the device blob itself, not a copy of the value). If - * lenp is non-NULL, the length of the property value is also - * returned, in the integer pointed to by lenp. If namep is non-NULL, - * the property's namne will also be returned in the char * pointed to - * by namep (this will be a pointer to within the device tree's string - * block, not a new copy of the name). - * - * returns: - * pointer to the property's value - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * if namep is non-NULL *namep contiains a pointer to the property - * name. - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_PROP tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#ifndef SWIG /* This function is not useful in Python */ -const void *fdt_getprop_by_offset(const void *fdt, int offset, - const char **namep, int *lenp); -#endif - -/** - * fdt_getprop_namelen - get property value based on substring - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @namelen: number of characters of name to consider - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * Identical to fdt_getprop(), but only examine the first namelen - * characters of name for matching the property name. - */ -#ifndef SWIG /* Not available in Python */ -const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, - const char *name, int namelen, int *lenp); -static inline void *fdt_getprop_namelen_w(void *fdt, int nodeoffset, - const char *name, int namelen, - int *lenp) -{ - return (void *)(uintptr_t)fdt_getprop_namelen(fdt, nodeoffset, name, - namelen, lenp); -} -#endif - -/** - * fdt_getprop - retrieve the value of a given property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to find - * @name: name of the property to find - * @lenp: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_getprop() retrieves a pointer to the value of the property - * named 'name' of the node at offset nodeoffset (this will be a - * pointer to within the device blob itself, not a copy of the value). - * If lenp is non-NULL, the length of the property value is also - * returned, in the integer pointed to by lenp. - * - * returns: - * pointer to the property's value - * if lenp is non-NULL, *lenp contains the length of the property - * value (>=0) - * NULL, on error - * if lenp is non-NULL, *lenp contains an error code (<0): - * -FDT_ERR_NOTFOUND, node does not have named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE - * tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -const void *fdt_getprop(const void *fdt, int nodeoffset, - const char *name, int *lenp); -static inline void *fdt_getprop_w(void *fdt, int nodeoffset, - const char *name, int *lenp) -{ - return (void *)(uintptr_t)fdt_getprop(fdt, nodeoffset, name, lenp); -} - -/** - * fdt_get_phandle - retrieve the phandle of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of the node - * - * fdt_get_phandle() retrieves the phandle of the device tree node at - * structure block offset nodeoffset. - * - * returns: - * the phandle of the node at nodeoffset, on success (!= 0, != -1) - * 0, if the node has no phandle, or another error occurs - */ -uint32_t fdt_get_phandle(const void *fdt, int nodeoffset); - -/** - * fdt_get_alias_namelen - get alias based on substring - * @fdt: pointer to the device tree blob - * @name: name of the alias th look up - * @namelen: number of characters of name to consider - * - * Identical to fdt_get_alias(), but only examine the first namelen - * characters of name for matching the alias name. - */ -#ifndef SWIG /* Not available in Python */ -const char *fdt_get_alias_namelen(const void *fdt, - const char *name, int namelen); -#endif - -/** - * fdt_get_alias - retrieve the path referenced by a given alias - * @fdt: pointer to the device tree blob - * @name: name of the alias th look up - * - * fdt_get_alias() retrieves the value of a given alias. That is, the - * value of the property named 'name' in the node /aliases. - * - * returns: - * a pointer to the expansion of the alias named 'name', if it exists - * NULL, if the given alias or the /aliases node does not exist - */ -const char *fdt_get_alias(const void *fdt, const char *name); - -/** - * fdt_get_path - determine the full path of a node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose path to find - * @buf: character buffer to contain the returned path (will be overwritten) - * @buflen: size of the character buffer at buf - * - * fdt_get_path() computes the full path of the node at offset - * nodeoffset, and records that path in the buffer at buf. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * 0, on success - * buf contains the absolute path of the node at - * nodeoffset, as a NUL-terminated string. - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_NOSPACE, the path of the given node is longer than (bufsize-1) - * characters and will not fit in the given buffer. - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen); - -/** - * fdt_supernode_atdepth_offset - find a specific ancestor of a node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * @supernodedepth: depth of the ancestor to find - * @nodedepth: pointer to an integer variable (will be overwritten) or NULL - * - * fdt_supernode_atdepth_offset() finds an ancestor of the given node - * at a specific depth from the root (where the root itself has depth - * 0, its immediate subnodes depth 1 and so forth). So - * fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, NULL); - * will always return 0, the offset of the root node. If the node at - * nodeoffset has depth D, then: - * fdt_supernode_atdepth_offset(fdt, nodeoffset, D, NULL); - * will return nodeoffset itself. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * structure block offset of the node at node offset's ancestor - * of depth supernodedepth (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of - * nodeoffset - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, - int supernodedepth, int *nodedepth); - -/** - * fdt_node_depth - find the depth of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * - * fdt_node_depth() finds the depth of a given node. The root node - * has depth 0, its immediate subnodes depth 1 and so forth. - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset. - * - * returns: - * depth of the node at nodeoffset (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_depth(const void *fdt, int nodeoffset); - -/** - * fdt_parent_offset - find the parent of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose parent to find - * - * fdt_parent_offset() locates the parent node of a given node (that - * is, it finds the offset of the node which contains the node at - * nodeoffset as a subnode). - * - * NOTE: This function is expensive, as it must scan the device tree - * structure from the start to nodeoffset, *twice*. - * - * returns: - * structure block offset of the parent of the node at nodeoffset - * (>=0), on success - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_parent_offset(const void *fdt, int nodeoffset); - -/** - * fdt_node_offset_by_prop_value - find nodes with a given property value - * @fdt: pointer to the device tree blob - * @startoffset: only find nodes after this offset - * @propname: property name to check - * @propval: property value to search for - * @proplen: length of the value in propval - * - * fdt_node_offset_by_prop_value() returns the offset of the first - * node after startoffset, which has a property named propname whose - * value is of length proplen and has value equal to propval; or if - * startoffset is -1, the very first such node in the tree. - * - * To iterate through all nodes matching the criterion, the following - * idiom can be used: - * offset = fdt_node_offset_by_prop_value(fdt, -1, propname, - * propval, proplen); - * while (offset != -FDT_ERR_NOTFOUND) { - * // other code here - * offset = fdt_node_offset_by_prop_value(fdt, offset, propname, - * propval, proplen); - * } - * - * Note the -1 in the first call to the function, if 0 is used here - * instead, the function will never locate the root node, even if it - * matches the criterion. - * - * returns: - * structure block offset of the located node (>= 0, >startoffset), - * on success - * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the - * tree after startoffset - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, - const char *propname, - const void *propval, int proplen); - -/** - * fdt_node_offset_by_phandle - find the node with a given phandle - * @fdt: pointer to the device tree blob - * @phandle: phandle value - * - * fdt_node_offset_by_phandle() returns the offset of the node - * which has the given phandle value. If there is more than one node - * in the tree with the given phandle (an invalid tree), results are - * undefined. - * - * returns: - * structure block offset of the located node (>= 0), on success - * -FDT_ERR_NOTFOUND, no node with that phandle exists - * -FDT_ERR_BADPHANDLE, given phandle value was invalid (0 or -1) - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle); - -/** - * fdt_node_check_compatible: check a node's compatible property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @compatible: string to match against - * - * - * fdt_node_check_compatible() returns 0 if the given node contains a - * 'compatible' property with the given string as one of its elements, - * it returns non-zero otherwise, or on error. - * - * returns: - * 0, if the node has a 'compatible' property listing the given string - * 1, if the node has a 'compatible' property, but it does not list - * the given string - * -FDT_ERR_NOTFOUND, if the given node has no 'compatible' property - * -FDT_ERR_BADOFFSET, if nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_check_compatible(const void *fdt, int nodeoffset, - const char *compatible); - -/** - * fdt_node_offset_by_compatible - find nodes with a given 'compatible' value - * @fdt: pointer to the device tree blob - * @startoffset: only find nodes after this offset - * @compatible: 'compatible' string to match against - * - * fdt_node_offset_by_compatible() returns the offset of the first - * node after startoffset, which has a 'compatible' property which - * lists the given compatible string; or if startoffset is -1, the - * very first such node in the tree. - * - * To iterate through all nodes matching the criterion, the following - * idiom can be used: - * offset = fdt_node_offset_by_compatible(fdt, -1, compatible); - * while (offset != -FDT_ERR_NOTFOUND) { - * // other code here - * offset = fdt_node_offset_by_compatible(fdt, offset, compatible); - * } - * - * Note the -1 in the first call to the function, if 0 is used here - * instead, the function will never locate the root node, even if it - * matches the criterion. - * - * returns: - * structure block offset of the located node (>= 0, >startoffset), - * on success - * -FDT_ERR_NOTFOUND, no node matching the criterion exists in the - * tree after startoffset - * -FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, standard meanings - */ -int fdt_node_offset_by_compatible(const void *fdt, int startoffset, - const char *compatible); - -/** - * fdt_stringlist_contains - check a string list property for a string - * @strlist: Property containing a list of strings to check - * @listlen: Length of property - * @str: String to search for - * - * This is a utility function provided for convenience. The list contains - * one or more strings, each terminated by \0, as is found in a device tree - * "compatible" property. - * - * @return: 1 if the string is found in the list, 0 not found, or invalid list - */ -int fdt_stringlist_contains(const char *strlist, int listlen, const char *str); - -/** - * fdt_stringlist_count - count the number of strings in a string list - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @return: - * the number of strings in the given property - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist - */ -int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property); - -/** - * fdt_stringlist_search - find a string in a string list and return its index - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @string: string to look up in the string list - * - * Note that it is possible for this function to succeed on property values - * that are not NUL-terminated. That's because the function will stop after - * finding the first occurrence of @string. This can for example happen with - * small-valued cell properties, such as #address-cells, when searching for - * the empty string. - * - * @return: - * the index of the string in the list of strings - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist or does not contain - * the given string - */ -int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property, - const char *string); - -/** - * fdt_stringlist_get() - obtain the string at a given index in a string list - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of a tree node - * @property: name of the property containing the string list - * @index: index of the string to return - * @lenp: return location for the string length or an error code on failure - * - * Note that this will successfully extract strings from properties with - * non-NUL-terminated values. For example on small-valued cell properties - * this function will return the empty string. - * - * If non-NULL, the length of the string (on success) or a negative error-code - * (on failure) will be stored in the integer pointer to by lenp. - * - * @return: - * A pointer to the string at the given index in the string list or NULL on - * failure. On success the length of the string will be stored in the memory - * location pointed to by the lenp parameter, if non-NULL. On failure one of - * the following negative error codes will be returned in the lenp parameter - * (if non-NULL): - * -FDT_ERR_BADVALUE if the property value is not NUL-terminated - * -FDT_ERR_NOTFOUND if the property does not exist - */ -const char *fdt_stringlist_get(const void *fdt, int nodeoffset, - const char *property, int index, - int *lenp); - -/**********************************************************************/ -/* Read-only functions (addressing related) */ -/**********************************************************************/ - -/** - * FDT_MAX_NCELLS - maximum value for #address-cells and #size-cells - * - * This is the maximum value for #address-cells, #size-cells and - * similar properties that will be processed by libfdt. IEE1275 - * requires that OF implementations handle values up to 4. - * Implementations may support larger values, but in practice higher - * values aren't used. - */ -#define FDT_MAX_NCELLS 4 - -/** - * fdt_address_cells - retrieve address size for a bus represented in the tree - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to find the address size for - * - * When the node has a valid #address-cells property, returns its value. - * - * returns: - * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #address-cells property - * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid - * #address-cells property - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_address_cells(const void *fdt, int nodeoffset); - -/** - * fdt_size_cells - retrieve address range size for a bus represented in the - * tree - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to find the address range size for - * - * When the node has a valid #size-cells property, returns its value. - * - * returns: - * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #address-cells property - * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid - * #size-cells property - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_size_cells(const void *fdt, int nodeoffset); - - -/**********************************************************************/ -/* Write-in-place functions */ -/**********************************************************************/ - -/** - * fdt_setprop_inplace_namelen_partial - change a property's value, - * but not its size - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @namelen: number of characters of name to consider - * @idx: index of the property to change in the array - * @val: pointer to data to replace the property value with - * @len: length of the property value - * - * Identical to fdt_setprop_inplace(), but modifies the given property - * starting from the given index, and using only the first characters - * of the name. It is useful when you want to manipulate only one value of - * an array and you have a string that doesn't end with \0. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_setprop_inplace_namelen_partial(void *fdt, int nodeoffset, - const char *name, int namelen, - uint32_t idx, const void *val, - int len); -#endif - -/** - * fdt_setprop_inplace - change a property's value, but not its size - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: pointer to data to replace the property value with - * @len: length of the property value - * - * fdt_setprop_inplace() replaces the value of a given property with - * the data in val, of length len. This function cannot change the - * size of a property, and so will only work if len is equal to the - * current length of the property. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if len is not equal to the property's current length - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#ifndef SWIG /* Not available in Python */ -int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, - const void *val, int len); -#endif - -/** - * fdt_setprop_inplace_u32 - change the value of a 32-bit integer property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value to replace the property with - * - * fdt_setprop_inplace_u32() replaces the value of a given property - * with the 32-bit integer value in val, converting val to big-endian - * if necessary. This function cannot change the size of a property, - * and so will only work if the property already exists and has length - * 4. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if the property's length is not equal to 4 - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_inplace_u64 - change the value of a 64-bit integer property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value to replace the property with - * - * fdt_setprop_inplace_u64() replaces the value of a given property - * with the 64-bit integer value in val, converting val to big-endian - * if necessary. This function cannot change the size of a property, - * and so will only work if the property already exists and has length - * 8. - * - * This function will alter only the bytes in the blob which contain - * the given property value, and will not alter or move any other part - * of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, if the property's length is not equal to 8 - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset, - const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_setprop_inplace(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_inplace_cell - change the value of a single-cell property - * - * This is an alternative name for fdt_setprop_inplace_u32() - */ -static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - return fdt_setprop_inplace_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_nop_property - replace a property with nop tags - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to nop - * @name: name of the property to nop - * - * fdt_nop_property() will replace a given property's representation - * in the blob with FDT_NOP tags, effectively removing it from the - * tree. - * - * This function will alter only the bytes in the blob which contain - * the property, and will not alter or move any other part of the - * tree. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_nop_property(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_nop_node - replace a node (subtree) with nop tags - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to nop - * - * fdt_nop_node() will replace a given node's representation in the - * blob, including all its subnodes, if any, with FDT_NOP tags, - * effectively removing it from the tree. - * - * This function will alter only the bytes in the blob which contain - * the node and its properties and subnodes, and will not alter or - * move any other part of the tree. - * - * returns: - * 0, on success - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_nop_node(void *fdt, int nodeoffset); - -/**********************************************************************/ -/* Sequential write functions */ -/**********************************************************************/ - -int fdt_create(void *buf, int bufsize); -int fdt_resize(void *fdt, void *buf, int bufsize); -int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); -int fdt_finish_reservemap(void *fdt); -int fdt_begin_node(void *fdt, const char *name); -int fdt_property(void *fdt, const char *name, const void *val, int len); -static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_property(fdt, name, &tmp, sizeof(tmp)); -} -static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_property(fdt, name, &tmp, sizeof(tmp)); -} -static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val) -{ - return fdt_property_u32(fdt, name, val); -} - -/** - * fdt_property_placeholder - add a new property and return a ptr to its value - * - * @fdt: pointer to the device tree blob - * @name: name of property to add - * @len: length of property value in bytes - * @valp: returns a pointer to where where the value should be placed - * - * returns: - * 0, on success - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_NOSPACE, standard meanings - */ -int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp); - -#define fdt_property_string(fdt, name, str) \ - fdt_property(fdt, name, str, strlen(str)+1) -int fdt_end_node(void *fdt); -int fdt_finish(void *fdt); - -/**********************************************************************/ -/* Read-write functions */ -/**********************************************************************/ - -int fdt_create_empty_tree(void *buf, int bufsize); -int fdt_open_into(const void *fdt, void *buf, int bufsize); -int fdt_pack(void *fdt); - -/** - * fdt_add_mem_rsv - add one memory reserve map entry - * @fdt: pointer to the device tree blob - * @address, @size: 64-bit values (native endian) - * - * Adds a reserve map entry to the given blob reserving a region at - * address address of length size. - * - * This function will insert data into the reserve map and will - * therefore change the indexes of some entries in the table. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new reservation entry - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size); - -/** - * fdt_del_mem_rsv - remove a memory reserve map entry - * @fdt: pointer to the device tree blob - * @n: entry to remove - * - * fdt_del_mem_rsv() removes the n-th memory reserve map entry from - * the blob. - * - * This function will delete data from the reservation table and will - * therefore change the indexes of some entries in the table. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, there is no entry of the given index (i.e. there - * are less than n+1 reserve map entries) - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_del_mem_rsv(void *fdt, int n); - -/** - * fdt_set_name - change the name of a given node - * @fdt: pointer to the device tree blob - * @nodeoffset: structure block offset of a node - * @name: name to give the node - * - * fdt_set_name() replaces the name (including unit address, if any) - * of the given node with the given string. NOTE: this function can't - * efficiently check if the new name is unique amongst the given - * node's siblings; results are undefined if this function is invoked - * with a name equal to one of the given node's siblings. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob - * to contain the new name - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, standard meanings - */ -int fdt_set_name(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_setprop - create or change a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: pointer to data to set the property value to - * @len: length of the property value - * - * fdt_setprop() sets the value of the named property in the given - * node to the given value and length, creating the property if it - * does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_setprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len); - -/** - * fdt_setprop _placeholder - allocate space for a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @len: length of the property value - * @prop_data: return pointer to property data - * - * fdt_setprop_placeholer() allocates the named property in the given node. - * If the property exists it is resized. In either case a pointer to the - * property data is returned. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name, - int len, void **prop_data); - -/** - * fdt_setprop_u32 - set a property to a 32-bit integer - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value for the property (native endian) - * - * fdt_setprop_u32() sets the value of the named property in the given - * node to the given 32-bit integer value (converting to big-endian if - * necessary), or creates a new property with that value if it does - * not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name, - uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_u64 - set a property to a 64-bit integer - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value for the property (native endian) - * - * fdt_setprop_u64() sets the value of the named property in the given - * node to the given 64-bit integer value (converting to big-endian if - * necessary), or creates a new property with that value if it does - * not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name, - uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_setprop_cell - set a property to a single cell value - * - * This is an alternative name for fdt_setprop_u32() - */ -static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, - uint32_t val) -{ - return fdt_setprop_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_setprop_string - set a property to a string value - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @str: string value for the property - * - * fdt_setprop_string() sets the value of the named property in the - * given node to the given string value (using the length of the - * string to determine the new length of the property), or creates a - * new property with that value if it does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_setprop_string(fdt, nodeoffset, name, str) \ - fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) - - -/** - * fdt_setprop_empty - set a property to an empty value - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * - * fdt_setprop_empty() sets the value of the named property in the - * given node to an empty (zero length) value, or creates a new empty - * property if it does not already exist. - * - * This function may insert or delete data from the blob, and will - * therefore change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_setprop_empty(fdt, nodeoffset, name) \ - fdt_setprop((fdt), (nodeoffset), (name), NULL, 0) - -/** - * fdt_appendprop - append to or create a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to append to - * @val: pointer to data to append to the property value - * @len: length of the data to append to the property value - * - * fdt_appendprop() appends the value to the named property in the - * given node, creating the property if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_appendprop(void *fdt, int nodeoffset, const char *name, - const void *val, int len); - -/** - * fdt_appendprop_u32 - append a 32-bit integer value to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 32-bit integer value to append to the property (native endian) - * - * fdt_appendprop_u32() appends the given 32-bit integer value - * (converting to big-endian if necessary) to the value of the named - * property in the given node, or creates a new property with that - * value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_appendprop_u32(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - fdt32_t tmp = cpu_to_fdt32(val); - return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_appendprop_u64 - append a 64-bit integer value to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @val: 64-bit integer value to append to the property (native endian) - * - * fdt_appendprop_u64() appends the given 64-bit integer value - * (converting to big-endian if necessary) to the value of the named - * property in the given node, or creates a new property with that - * value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -static inline int fdt_appendprop_u64(void *fdt, int nodeoffset, - const char *name, uint64_t val) -{ - fdt64_t tmp = cpu_to_fdt64(val); - return fdt_appendprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); -} - -/** - * fdt_appendprop_cell - append a single cell value to a property - * - * This is an alternative name for fdt_appendprop_u32() - */ -static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) -{ - return fdt_appendprop_u32(fdt, nodeoffset, name, val); -} - -/** - * fdt_appendprop_string - append a string to a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to change - * @name: name of the property to change - * @str: string value to append to the property - * - * fdt_appendprop_string() appends the given string to the value of - * the named property in the given node, or creates a new property - * with that value if it does not already exist. - * - * This function may insert data into the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to - * contain the new property value - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_TRUNCATED, standard meanings - */ -#define fdt_appendprop_string(fdt, nodeoffset, name, str) \ - fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) - -/** - * fdt_delprop - delete a property - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node whose property to nop - * @name: name of the property to nop - * - * fdt_del_property() will delete the given property. - * - * This function will delete data from the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_NOTFOUND, node does not have the named property - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_delprop(void *fdt, int nodeoffset, const char *name); - -/** - * fdt_add_subnode_namelen - creates a new node based on substring - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * @namelen: number of characters of name to consider - * - * Identical to fdt_add_subnode(), but use only the first namelen - * characters of name as the name of the new node. This is useful for - * creating subnodes based on a portion of a larger string, such as a - * full path. - */ -#ifndef SWIG /* Not available in Python */ -int fdt_add_subnode_namelen(void *fdt, int parentoffset, - const char *name, int namelen); +#ifdef USE_HOSTCC +#include "../scripts/dtc/libfdt/libfdt.h" +#else +#include <linux/libfdt.h> #endif
-/** - * fdt_add_subnode - creates a new node - * @fdt: pointer to the device tree blob - * @parentoffset: structure block offset of a node - * @name: name of the subnode to locate - * - * fdt_add_subnode() creates a new node as a subnode of the node at - * structure block offset parentoffset, with the given name (which - * should include the unit address, if any). - * - * This function will insert data into the blob, and will therefore - * change the offsets of some existing nodes. - - * returns: - * structure block offset of the created nodeequested subnode (>=0), on - * success - * -FDT_ERR_NOTFOUND, if the requested subnode does not exist - * -FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE - * tag - * -FDT_ERR_EXISTS, if the node at parentoffset already has a subnode of - * the given name - * -FDT_ERR_NOSPACE, if there is insufficient free space in the - * blob to contain the new node - * -FDT_ERR_NOSPACE - * -FDT_ERR_BADLAYOUT - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings. - */ -int fdt_add_subnode(void *fdt, int parentoffset, const char *name); - -/** - * fdt_del_node - delete a node (subtree) - * @fdt: pointer to the device tree blob - * @nodeoffset: offset of the node to nop - * - * fdt_del_node() will remove the given node, including all its - * subnodes if any, from the blob. - * - * This function will delete data from the blob, and will therefore - * change the offsets of some existing nodes. - * - * returns: - * 0, on success - * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_del_node(void *fdt, int nodeoffset); - -/** - * fdt_overlay_apply - Applies a DT overlay on a base DT - * @fdt: pointer to the base device tree blob - * @fdto: pointer to the device tree overlay blob - * - * fdt_overlay_apply() will apply the given device tree overlay on the - * given base device tree. - * - * Expect the base device tree to be modified, even if the function - * returns an error. - * - * returns: - * 0, on success - * -FDT_ERR_NOSPACE, there's not enough space in the base device tree - * -FDT_ERR_NOTFOUND, the overlay points to some inexistant nodes or - * properties in the base DT - * -FDT_ERR_BADPHANDLE, - * -FDT_ERR_BADOVERLAY, - * -FDT_ERR_NOPHANDLES, - * -FDT_ERR_INTERNAL, - * -FDT_ERR_BADLAYOUT, - * -FDT_ERR_BADMAGIC, - * -FDT_ERR_BADOFFSET, - * -FDT_ERR_BADPATH, - * -FDT_ERR_BADVERSION, - * -FDT_ERR_BADSTRUCTURE, - * -FDT_ERR_BADSTATE, - * -FDT_ERR_TRUNCATED, standard meanings - */ -int fdt_overlay_apply(void *fdt, void *fdto); - -/**********************************************************************/ -/* Debugging / informational functions */ -/**********************************************************************/ +/* U-Boot local hacks */
#ifndef SWIG /* Not available in Python */ -const char *fdt_strerror(int errval); - struct fdt_region { int offset; int size; @@ -2155,4 +315,4 @@ extern struct fdt_header *working_fdt; /* Pointer to the working fdt */ /* adding a ramdisk needs 0x44 bytes in version 2008.10 */ #define FDT_RAMDISK_OVERHEAD 0x80
-#endif /* _LIBFDT_H */ +#endif /* UBOOT_LIBFDT_H */
On 9 January 2018 at 01:34, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Remove the tons of code duplication between include/libfdt.h and sciprts/dtc/libfdt/libfdt.h. I am keeping U-Boot local code in include/libfdt.h.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com
include/libfdt.h | 1856 +----------------------------------------------------- 1 file changed, 8 insertions(+), 1848 deletions(-)
Didn't you just add this file two patches ago? Why not just not add it?
2018-01-16 23:56 GMT+09:00 Simon Glass sjg@chromium.org:
Well, a good question.
I tried to do one thing in each commit.
Two patches ago, I moved 2100 lines to this file. Then, I deleted 1800 lines in this patch.
If I had merged them into one patch, I would have just needed to move 300 lines.
I will take a look if you do not want to see the huge diffs twice.
libfdt_env.h is supposed to provide system-dependent defines.
scripts/dtc/libfdt/libfdt_env.h from upstream DTC is suitable for user-space, so we should use this for USE_HOSTCC case.
For compiling U-Boot, we need to override such system-dependent defines, so use <linux/libfdt_env.h> imported from Linux.
I can rip off the include/libfdt_env.h from HOST_EXTRACFLAGS. Adding all sort of stuff to the include path just for suppressing errors is a crazy idea.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/libfdt_env.h | 29 +++++------------------------ tools/Makefile | 2 +- 2 files changed, 6 insertions(+), 25 deletions(-)
diff --git a/include/libfdt_env.h b/include/libfdt_env.h index ea26979..d7e9d32 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -1,24 +1,5 @@ -/* - * libfdt - Flat Device Tree manipulation (build/run environment adaptation) - * Copyright (C) 2007 Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com - * Original version written by David Gibson, IBM Corporation. - * - * SPDX-License-Identifier: LGPL-2.1+ - */ - -#ifndef _LIBFDT_ENV_H -#define _LIBFDT_ENV_H - -#include "compiler.h" -#include "linux/types.h" - -typedef __be16 fdt16_t; -typedef __be32 fdt32_t; -typedef __be64 fdt64_t; - -#define fdt32_to_cpu(x) be32_to_cpu(x) -#define cpu_to_fdt32(x) cpu_to_be32(x) -#define fdt64_to_cpu(x) be64_to_cpu(x) -#define cpu_to_fdt64(x) cpu_to_be64(x) - -#endif /* _LIBFDT_ENV_H */ +#ifdef USE_HOSTCC +#include "../scripts/dtc/libfdt/libfdt_env.h" +#else +#include <linux/libfdt_env.h> +#endif diff --git a/tools/Makefile b/tools/Makefile index 3274487..2333646 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -238,7 +238,7 @@ endif # !LOGO_BMP # Define __KERNEL_STRICT_NAMES to prevent typedef overlaps # Define _GNU_SOURCE to obtain the getline prototype from stdio.h # -HOST_EXTRACFLAGS += -include $(srctree)/include/libfdt_env.h \ +HOST_EXTRACFLAGS += -include $(srctree)/include/compiler.h \ $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \ -I$(srctree)/lib/libfdt \ -I$(srctree)/tools \
I'm not really sure why we want to use linux/libfdt.h though... Can you add some details in the patch?
- Simon
I just borrowed as much code from Linux as possible.
This is successful in most cases. I trust kernel developers.
<linux/libfdt_env.h> contains environments for the target board.
<libfdt_env.h> selects either of them depending on USE_HOSTCC.
Maybe we can move USB_HOSTCC case to tools/ in the future, but this series makes the code much cleaner than the current one.
The only difference between scripts/dtc/libfdt/fdt_rw.c and lib/libfdt/fdt_rw.c is fdt_remove_unused_strings().
It is only used by fdtgrep, so we do not need to compile it for U-Boot image. Move it to tools/libfdt/fdw_rw.c so that lib/libfdt/fdt_rw.c can be a wrapper of scripts/dtc/libfdt/fdt_rw.c.
lib/libfdt/Makefile | 5 +- lib/libfdt/fdt_rw.c | 498 +------------------------------------------------- lib/libfdt/libfdt.h | 17 -- tools/Makefile | 6 +- tools/fdt_host.h | 17 ++ tools/fdtgrep.c | 2 +- tools/libfdt/fdt_rw.c | 35 ++++ 7 files changed, 60 insertions(+), 520 deletions(-) create mode 100644 tools/libfdt/fdt_rw.c
Joe Hershberger
Masahiro Yamada
