[U-Boot-Users] Clarification regarding the Internal Flash Identification Code.
Hi All In the file "include/flash.h" some # defines are there e.g for Intel StrataFlash 28F320J5 three Macros (hash define values) are there:
#define INTEL_MANUFACT 0x00890089 /*INTEL manuf. ID in D23..D16, D7..D0 */ #define INTEL_ID_28F320J5 0x00140014 /* 32M = 128K x 32 */ #define FLASH_28F320J5 0x0085 /* Intel 28F320J5 ( 4M = 128K x 32 ) */
Since I am using Intel StrataFlash 28F256J3, I have to define the three required macros accordingly:
#define INTEL_MANUFACT 0x00890089 /*INTEL Manufacturer. ID */ #define INTEL_ID_28F256J3 0x001D001D /*Device ID*/
#define FLASH_28F256J3 /*Internal Flash Identification Code*/
I got the Device Id value from the Intel Site but I didn't found any thing like Internal Flash Identification Code. Is this value is to be supplied by the vendor if not then what value should I have to assign to the Macro FLASH_28F256J3.
Best Regards, Vikrant Basotra
************************************************************************** This email (including any attachments) is intended for the sole use of the intended recipient/s and may contain material that is CONFIDENTIAL AND PRIVATE COMPANY INFORMATION. Any review or reliance by others or copying or distribution or forwarding of any or all of the contents in this message is STRICTLY PROHIBITED. If you are not the intended recipient, please contact the sender by email and delete all copies; your cooperation in this regard is appreciated. **************************************************************************
In message 3D9FDCA910DD4445896A0BE5ECF009D401CCAA1F@bla.satyam.com you wrote:
As the name "Internal FLASH identification codes" suggests this is a code that is _internal_ to U-Boot so you will not find it mentioned in any vendor documentation (at least not before they are sterting to manufacture "U-Boot flash chips" :-)
Just chose the next unused entry, but keep in mind that odd numbers are used only for "bottom boot sector" types!
Vikrant_Basotra
