Re: [U-Boot] [PATCH 1/2] ARM: dts: meson: add p200 and p201 boards
Hi Mohammad,
Thanks for patches,
Can you specify from which kernel release you sync'ed the DT ?
On 14/03/2019 14:52, Mohammad Rasim wrote:
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com
arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-p200.dts | 99 ++++++++++++ arch/arm/dts/meson-gxbb-p201.dts | 26 ++++ arch/arm/dts/meson-gxbb-p20x.dtsi | 247 ++++++++++++++++++++++++++++++ 4 files changed, 374 insertions(+) create mode 100644 arch/arm/dts/meson-gxbb-p200.dts create mode 100644 arch/arm/dts/meson-gxbb-p201.dts create mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2a040b20a5..adf5f26fac 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -60,6 +60,8 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ meson-gxbb-odroidc2.dtb \ meson-gxbb-nanopi-k2.dtb \
- meson-gxbb-p200.dtb \
- meson-gxbb-p201.dtb \ meson-gxl-s905x-p212.dtb \ meson-gxl-s905x-libretech-cc.dtb \ meson-gxl-s905x-khadas-vim.dtb \
diff --git a/arch/arm/dts/meson-gxbb-p200.dts b/arch/arm/dts/meson-gxbb-p200.dts new file mode 100644 index 0000000000..9d2406a7c4 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p200.dts @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (c) 2016 Andreas Färber
You should use format-patch and git send-email to send this patch, it will keep the UTF-8 encoding.
- Copyright (c) 2016 BayLibre, Inc.
- Author: Kevin Hilman khilman@kernel.org
+/dts-v1/;
+#include "meson-gxbb-p20x.dtsi" +#include <dt-bindings/input/input.h>
- compatible = "amlogic,p200", "amlogic,meson-gxbb";
- model = "Amlogic Meson GXBB P200 Development Board";
- avdd18_usb_adc: regulator-avdd18_usb_adc {
compatible = "regulator-fixed";
regulator-name = "AVDD18_USB_ADC";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
- adc_keys {
compatible = "adc-keys";
io-channels = <&saradc 0>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1800000>;
button-home {
label = "Home";
linux,code = <KEY_HOME>;
press-threshold-microvolt = <900000>; /* 50% */
button-esc {
label = "Esc";
linux,code = <KEY_ESC>;
press-threshold-microvolt = <684000>; /* 38% */
button-up {
label = "Volume Up";
linux,code = <KEY_VOLUMEUP>;
press-threshold-microvolt = <468000>; /* 26% */
button-down {
label = "Volume Down";
linux,code = <KEY_VOLUMEDOWN>;
press-threshold-microvolt = <252000>; /* 14% */
button-menu {
label = "Menu";
linux,code = <KEY_MENU>;
press-threshold-microvolt = <0>; /* 0% */
+ðmac {
- status = "okay";
- pinctrl-0 = <ð_rgmii_pins>;
- pinctrl-names = "default";
- phy-handle = <ð_phy0>;
- phy-mode = "rgmii";
- amlogic,tx-delay-ns = <2>;
- snps,reset-gpio = <&gpio GPIOZ_14 0>;
- snps,reset-delays-us = <0 10000 1000000>;
- snps,reset-active-low;
- mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
eth_phy0: ethernet-phy@3 {
/* Micrel KSZ9031 (0x00221620) */
reg = <3>;
interrupt-parent = <&gpio_intc>;
/* MAC_INTR on GPIOZ_15 */
interrupts = <29 IRQ_TYPE_LEVEL_LOW>;
+&i2c_B {
- status = "okay";
- pinctrl-0 = <&i2c_b_pins>;
+&saradc {
- status = "okay";
- vref-supply = <&avdd18_usb_adc>;
+}; diff --git a/arch/arm/dts/meson-gxbb-p201.dts b/arch/arm/dts/meson-gxbb-p201.dts new file mode 100644 index 0000000000..56e0dd1ff5 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p201.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+/dts-v1/;
- compatible = "amlogic,p201", "amlogic,meson-gxbb";
- model = "Amlogic Meson GXBB P201 Development Board";
+ðmac {
- status = "okay";
- pinctrl-0 = <ð_rmii_pins>;
- phy-mode = "rmii";
+}; diff --git a/arch/arm/dts/meson-gxbb-p20x.dtsi b/arch/arm/dts/meson-gxbb-p20x.dtsi new file mode 100644 index 0000000000..0be0f2a5d2 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p20x.dtsi @@ -0,0 +1,247 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+#include "meson-gxbb.dtsi"
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
stdout-path = "serial0:115200n8";
- memory@0 {
device_type = "memory";
reg = <0x0 0x0 0x0 0x40000000>;
- usb_pwr: regulator-usb-pwrs {
regulator-name = "USB_PWR";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
/* signal name in schematic: USB_PWR_EN */
gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>;
enable-active-high;
- vddio_card: gpio-regulator {
compatible = "regulator-gpio";
regulator-name = "VDDIO_CARD";
regulator-max-microvolt = <3300000>;
gpios = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
/* Based on P200 schematics, signal CARD_1.8V/3.3V_CTR */
states = <1800000 0
3300000 1>;
regulator-settling-time-up-us = <10000>;
regulator-settling-time-down-us = <150000>;
- vddio_boot: regulator-vddio_boot {
regulator-name = "VDDIO_BOOT";
- vddao_3v3: regulator-vddao_3v3 {
regulator-name = "VDDAO_3V3";
regulator-min-microvolt = <3300000>;
- vcc_3v3: regulator-vcc_3v3 {
regulator-name = "VCC_3V3";
- emmc_pwrseq: emmc-pwrseq {
compatible = "mmc-pwrseq-emmc";
reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>;
- wifi32k: wifi32k {
compatible = "pwm-clock";
#clock-cells = <0>;
clock-frequency = <32768>;
pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>;
clocks = <&wifi32k>;
clock-names = "ext_clock";
- cvbs_connector: cvbs-connector {
compatible = "composite-video-connector";
port {
cvbs_connector_in: endpoint {
remote-endpoint = <&cvbs_vdac_out>;
- hdmi-connector {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&hdmi_tx_tmds_out>;
+&cec_AO {
- status = "okay";
- pinctrl-0 = <&ao_cec_pins>;
- hdmi-phandle = <&hdmi_tx>;
+&cvbs_vdac_port {
- cvbs_vdac_out: endpoint {
remote-endpoint = <&cvbs_connector_in>;
+&hdmi_tx {
- status = "okay";
- pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>;
+&hdmi_tx_tmds_port {
- hdmi_tx_tmds_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>;
+&pwm_ef {
- status = "okay";
- pinctrl-0 = <&pwm_e_pins>;
- clocks = <&clkc CLKID_FCLK_DIV4>;
- clock-names = "clkin0";
+/* Wireless SDIO Module */ +&sd_emmc_a {
- status = "okay";
- pinctrl-0 = <&sdio_pins>;
- pinctrl-1 = <&sdio_clk_gate_pins>;
- pinctrl-names = "default", "clk-gate";
- #address-cells = <1>;
- #size-cells = <0>;
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <100000000>;
- non-removable;
- disable-wp;
- mmc-pwrseq = <&sdio_pwrseq>;
- vmmc-supply = <&vddao_3v3>;
- vqmmc-supply = <&vddio_boot>;
- brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
+/* SD card */ +&sd_emmc_b {
- status = "okay";
- pinctrl-0 = <&sdcard_pins>;
- pinctrl-1 = <&sdcard_clk_gate_pins>;
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- disable-wp;
- cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>;
- vqmmc-supply = <&vddio_card>;
+/* eMMC */ +&sd_emmc_c {
- status = "okay";
- pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>;
- pinctrl-1 = <&emmc_clk_gate_pins>;
- bus-width = <8>;
- cap-mmc-highspeed;
- max-frequency = <200000000>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vcc_3v3>;
+/* This UART is brought out to the DB9 connector */ +&uart_AO {
- status = "okay";
- pinctrl-0 = <&uart_ao_a_pins>;
+&usb0_phy {
- status = "okay";
- phy-supply = <&usb_pwr>;
+&usb1_phy {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb1 {
- status = "okay";
2.21.0
On 19/03/14 04:05, Neil Armstrong wrote:
Hi Mohammad,
Thanks for patches,
kernel version: 5.0.0 revision: a667cb7a94d48a483fb5d6006fe04a440f1a42ce
Should I include this information in V2?
I used format-patch but with my own smtp client (msmtp) which apparently corrupted the message
+/dts-v1/;
- adc_keys {
button-home {
label = "Home";
button-esc {
label = "Esc";
button-up {
button-down {
button-menu {
label = "Menu";
+ðmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <3>;
+&i2c_B {
- status = "okay";
+&saradc {
- status = "okay";
+/dts-v1/;
+ðmac {
- status = "okay";
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
enable-active-high;
gpios-states = <1>;
states = <1800000 0
3300000 1>;
#clock-cells = <0>;
port {
- hdmi-connector {
type = "a";
port {
+&cec_AO {
- status = "okay";
+&cvbs_vdac_port {
+&hdmi_tx {
- status = "okay";
+&ir {
- status = "okay";
+&pwm_ef {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- non-removable;
- disable-wp;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- status = "okay";
+&usb0_phy {
- status = "okay";
+&usb1_phy {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb1 {
- status = "okay";
2.21.0
Mohammad Rasim
Neil Armstrong
