[PATCH v2] misc: Fix always compiling MISC even for SPL/TPL
We should only build support for misc if the appropriate SPL/TPL symbol is defined. To ease the transition, make SPL/TPL_MISC default to MISC. This is necessary because many drivers don't specify their dependencies properly. These defaults can be removed once all drivers depend on the appropriate config.
Fixes: aaba703fd0 ("spl: misc: Allow misc drivers in SPL and TPL") Signed-off-by: Sean Anderson sean.anderson@seco.com ---
Changes in v2: - Make SPL/TPL_MISC default to MISC
drivers/misc/Kconfig | 2 ++ drivers/misc/Makefile | 2 +- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 10fd601278..21b334d43d 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -16,6 +16,7 @@ config MISC config SPL_MISC bool "Enable Driver Model for Misc drivers in SPL" depends on SPL_DM + default MISC help Enable driver model for miscellaneous devices. This class is used only for those do not fit other more general classes. A @@ -25,6 +26,7 @@ config SPL_MISC config TPL_MISC bool "Enable Driver Model for Misc drivers in TPL" depends on TPL_DM + default MISC help Enable driver model for miscellaneous devices. This class is used only for those do not fit other more general classes. A diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 6150d01e88..7a6047f64f 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -3,7 +3,7 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_MISC) += misc-uclass.o +obj-$(CONFIG_$(SPL_TPL_)MISC) += misc-uclass.o
obj-$(CONFIG_$(SPL_TPL_)CROS_EC) += cros_ec.o obj-$(CONFIG_$(SPL_TPL_)CROS_EC_SANDBOX) += cros_ec_sandbox.o
Sean Anderson
