[U-Boot] [PATCH] mx6sabresd: Reduce overall SPL size
Currently the SPL binary is 67 kB, which leaves only 1 kB of free internal RAM space.
The following options can be safely removed to save some precious SPL space:
- CONFIG_SPL_FS_EXT4: u-boot-dtb.img is stored in raw sector via dd command (at offset 69 kB) - CONFIG_SPL_I2C_SUPPORT: I2C is not used during SPL - CONFIG_SPL_OS_BOOT: no need to make Falcon mode supported by default
After this change the SPL binary size gets down to 51 kB.
Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/mx6sabresd_defconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 9400805831..84862feb8b 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -23,9 +23,6 @@ CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FIT_IMAGE_TINY=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C_SUPPORT=y -CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y
Subject: [PATCH] mx6sabresd: Reduce overall SPL size
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Currently the SPL binary is 67 kB, which leaves only 1 kB of free internal RAM space. The following options can be safely removed to save some precious SPL space:
by default After this change the SPL binary size gets down to 51 kB. Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
sbabic@denx.de
