[U-Boot] [PATCH v3] imx: Add support for i.MX28 based XEA board
This patch introduces support for i.MX28 based XEA board.
This board supports DM/DTS in U-Boot proper as well as DM aware drivers in SPL (u-boot.sb). More detailed information regarding usage of it can be found in ./board/liebherr/xea/README file.
U-Boot SPL 2019.10-rc1-00233-g6aa549f05c (Aug 12 2019 - 09:23:36 +0200) Trying to boot from MMC1 MMC0: Command 8 timeout (status 0xf0344020) mmc_load_image_raw_sector: mmc block read error
U-Boot 2019.10-rc1-00233-g6aa549f05c (Aug 12 2019 - 09:23:36 +0200)
CPU: Freescale i.MX28 rev1.2 at 454 MHz BOOT: SSP SPI #3, master, 3V3 NOR Model: Liebherr (LWE) XEA i.MX28 Board DRAM: 128 MiB MMC: MXS MMC: 0 Loading Environment from SPI Flash... SF: Detected n25q128a13 with page size 256 Bytes, erase size 64 KiB, total 16 MiB OK In: serial Out: serial Err: serial Net: Warning: ethernet@800f0000 (eth0) using random MAC address - ce:e1:9e:46:f3:a2 eth0: ethernet@800f0000 Hit any key to stop autoboot: 0
Signed-off-by: Mans Rullgard mans@mansr.com Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v3: - Use Kconfig defined option (CONFIG_FS_EXT4) instead of the one defined in xea.h - Use Kconfig defined option (CONFIG_SYS_SPI_U_BOOT_OFFS) instead of the one defined in xea.h - Provide correct SDPX header for xea.h
Changes in v2: - Adjust config to match dependent patches - Increase malloc size to allow booting the board with GPIO DM/DTS support - Add support for GPIO driver in SPL (with DM + OF_PLATDATA) - Adjust spl_xea.c to support bootmode pins - Add patches to set in Kconfig default boot HW partition for eMMC
Dependencies: - The whole patch series (v3) (1-3) starting at: https://patchwork.ozlabs.org/cover/1158144/ (Conversion of DM_SPI to (SPL_TPL_)_DM_SPI)
- Fixes/conversion for i.MX28 spi, emmc and gpio (the whole series 1-7): https://patchwork.ozlabs.org/cover/1158255/
Applied on top of -master branch: SHA1: 448f11f7503995746a7b71e5e3b3a831c4651be9
--- arch/arm/dts/Makefile | 3 + arch/arm/dts/imx28-xea-u-boot.dtsi | 46 ++++++ arch/arm/dts/imx28-xea.dts | 110 ++++++++++++++ arch/arm/mach-imx/mxs/Kconfig | 4 + board/liebherr/xea/Kconfig | 24 +++ board/liebherr/xea/MAINTAINERS | 6 + board/liebherr/xea/Makefile | 12 ++ board/liebherr/xea/README | 63 ++++++++ board/liebherr/xea/spl_xea.c | 303 +++++++++++++++++++++++++++++++++++++ board/liebherr/xea/xea.c | 152 +++++++++++++++++++ configs/imx28_xea_defconfig | 110 ++++++++++++++ include/configs/xea.h | 192 +++++++++++++++++++++++ 12 files changed, 1025 insertions(+) create mode 100644 arch/arm/dts/imx28-xea-u-boot.dtsi create mode 100644 arch/arm/dts/imx28-xea.dts create mode 100644 board/liebherr/xea/Kconfig create mode 100644 board/liebherr/xea/MAINTAINERS create mode 100644 board/liebherr/xea/Makefile create mode 100644 board/liebherr/xea/README create mode 100644 board/liebherr/xea/spl_xea.c create mode 100644 board/liebherr/xea/xea.c create mode 100644 configs/imx28_xea_defconfig create mode 100644 include/configs/xea.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aac1b83d49..82a0379c13 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -547,6 +547,9 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ vf610-pcm052.dtb \ vf610-bk4r1.dtb
+dtb-$(CONFIG_MX28) += \ + imx28-xea.dtb + dtb-$(CONFIG_MX53) += imx53-cx9020.dtb \ imx53-kp.dtb \ imx53-m53menlo.dtb diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi new file mode 100644 index 0000000000..cc2ced5d2d --- /dev/null +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +/* + * The minimal augmentation DTS U-Boot file to allow eMMC driver + * configuration in SPL for falcon boot. + */ +#include "imx28-u-boot.dtsi" +/ { + apb@80000000 { + u-boot,dm-spl; + + apbh@80000000 { + u-boot,dm-spl; + }; + + apbx@80040000 { + u-boot,dm-spl; + }; + }; +}; + +&clks { + u-boot,dm-spl; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&pinctrl { + u-boot,dm-spl; +}; + +&ssp0 { + u-boot,dm-spl; +}; + +&ssp3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx28-xea.dts b/arch/arm/dts/imx28-xea.dts new file mode 100644 index 0000000000..5de6774c5a --- /dev/null +++ b/arch/arm/dts/imx28-xea.dts @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + * + */ + +/dts-v1/; + +#include "imx28.dtsi" + +/ { + model = "Liebherr (LWE) XEA i.MX28 Board"; + compatible = "lwe,xea", "fsl,imx28"; + + aliases { + spi3 = &ssp3; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x40000000 0x10000000>; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_fec_3v3: regulator-fec-3v3 { + compatible = "regulator-fixed"; + regulator-name = "fec-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; + }; +}; + +&mac0 { + phy-mode = "rmii"; + pinctrl-names = "default"; + pinctrl-0 = <&mac0_pins_a>; + phy-supply = <®_fec_3v3>; + phy-reset-gpios = <&gpio2 13 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + phy-reset-post-delay = <1>; + status = "okay"; + + fixed-link { + speed = <100>; + full-duplex; + }; +}; + +&ssp0 { + compatible = "fsl,imx28-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_8bit_pins_a>; + bus-width = <8>; + vmmc-supply = <®_3p3v>; + non-removable; + status = "okay"; +}; + +&ssp3 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_pins_b>; + status = "okay"; + spi-max-frequency = <40000000>; + num-cs = <2>; + + flash0: s25fl256s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <40000000>; + reg = <0>; + + partition@0 { + label = "SPL (spi)"; + reg = <0x0 0x10000>; + read-only; + }; + partition@1 { + label = "u-boot (spi)"; + reg = <0x10000 0x70000>; + read-only; + }; + partition@2 { + label = "uboot-env (spi)"; + reg = <0x80000 0x20000>; + }; + partition@3 { + label = "kernel (spi)"; + reg = <0x100000 0x400000>; + }; + partition@4 { + label = "swupdate (spi)"; + reg = <0x50000 0x800000>; + }; + }; +}; diff --git a/arch/arm/mach-imx/mxs/Kconfig b/arch/arm/mach-imx/mxs/Kconfig index 68072d5a1f..b90d7b6e41 100644 --- a/arch/arm/mach-imx/mxs/Kconfig +++ b/arch/arm/mach-imx/mxs/Kconfig @@ -60,6 +60,9 @@ config TARGET_SC_SPS_1 config TARGET_TS4600 bool "Support TS4600"
+config TARGET_XEA + bool "Support XEA" + endchoice
config SYS_SOC @@ -67,6 +70,7 @@ config SYS_SOC
source "board/bluegiga/apx4devkit/Kconfig" source "board/freescale/mx28evk/Kconfig" +source "board/liebherr/xea/Kconfig" source "board/ppcag/bg0900/Kconfig" source "board/schulercontrol/sc_sps_1/Kconfig" source "board/technologic/ts4600/Kconfig" diff --git a/board/liebherr/xea/Kconfig b/board/liebherr/xea/Kconfig new file mode 100644 index 0000000000..5428de4646 --- /dev/null +++ b/board/liebherr/xea/Kconfig @@ -0,0 +1,24 @@ +if TARGET_XEA + +config SYS_BOARD + default "xea" + +config SYS_VENDOR + default "liebherr" + +config SYS_SOC + default "mxs" + +config SYS_CONFIG_NAME + default "xea" + +config ENV_SIZE + default 0x2000 + +config ENV_SECT_SIZE + default 0x10000 if ENV_IS_IN_SPI_FLASH + +config ENV_OFFSET + default 0x80000 if ENV_IS_IN_SPI_FLASH + +endif diff --git a/board/liebherr/xea/MAINTAINERS b/board/liebherr/xea/MAINTAINERS new file mode 100644 index 0000000000..623184d0f8 --- /dev/null +++ b/board/liebherr/xea/MAINTAINERS @@ -0,0 +1,6 @@ +XEA BOARD +M: Lukasz Majewski lukma@denx.de +S: Maintained +F: board/liebherr/xea/ +F: include/configs/xea.h +F: configs/imx28_xea_defconfig diff --git a/board/liebherr/xea/Makefile b/board/liebherr/xea/Makefile new file mode 100644 index 0000000000..abf500857f --- /dev/null +++ b/board/liebherr/xea/Makefile @@ -0,0 +1,12 @@ +# +# (C) Copyright 2019 +# Lukasz Majewski, DENX Software Engineering, lukma@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := xea.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl_xea.o +endif diff --git a/board/liebherr/xea/README b/board/liebherr/xea/README new file mode 100644 index 0000000000..3e55d3ea43 --- /dev/null +++ b/board/liebherr/xea/README @@ -0,0 +1,63 @@ +Building SPL/U-Boot for xea board +================================= + +Setup environment, configure and build, e.g. by: + + $ make imx28_xea_defconfig + $ make -j4 u-boot.sb u-boot.img + +Now you should see u-boot.sb and u-boot.img files in the build directory. + + +Booting +======= + +The boot ROM loads SPL from SPI NOR flash into SRAM. SPL configures +DRAM and loads either a Linux kernel (falcon mode) or, if the rescue +pin is asserted, the main U-Boot. Both kernel and U-Boot reside in +eMMC boot partition 0. For redundancy, a copy of U-Boot is also +stored in SPI flash. If a valid kernel image is not found, U-Boot is +loaded from eMMC or, if this fails, SPI flash. + +Boot area layout +---------------- + +SPI NOR +Offset Function File +------------------------------------------ +0x00000000 SPL u-boot.sb +0x00010000 U-Boot u-boot.img +0x00080000 Environment + +eMMC +Offset Function File +------------------------------------------ +0x00000000 U-Boot u-boot.img +0x00080000 Devicetree imx28-bttc.dtb +0x00100000 Kernel uImage + + +Falcon mode +=========== + +In falcon mode, the default, SPL loads the kernel and devicetree +directly. For this to work, the stored devicetree must include +correct "memory" and "chosen" nodes as these are not updated by SPL +before booting the kernel. + + +Updating from U-Boot +==================== + +The default U-Boot environment includes command sequences to update +SPL, U-Boot, and kernel over TFTP. These are as follows: + +- update_spl: writes u-boot.sb to SPI NOR +- update_uboot: writes u-boot.img to eMMC and SPI NOR +- update_kernel: writes kernel and devicetree to eMMC + +They can be invoked at the U-Boot prompt using the "run" command, +e.g. "run update_spl" to update the SPL. + +These update commands download the above-named files from the +${hostname} directory on the server provided by DHCP. diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c new file mode 100644 index 0000000000..d88b75bb3a --- /dev/null +++ b/board/liebherr/xea/spl_xea.c @@ -0,0 +1,303 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * DENX M28 Boot setup + * + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) +#define MUX_CONFIG_BOOT (MXS_PAD_3V3 | MXS_PAD_PULLUP) +#define MUX_CONFIG_TSC (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP2 (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_NOPULL) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* AUART0 IRDA */ + MX28_PAD_AUART0_RX__AUART0_RX, + MX28_PAD_AUART0_TX__AUART0_TX, + + /* AUART 4 RS422 */ + MX28_PAD_AUART0_CTS__AUART4_RX, + MX28_PAD_AUART0_RTS__AUART4_TX, + + /* USB0 */ + MX28_PAD_AUART1_CTS__USB0_OVERCURRENT, + MX28_PAD_AUART1_RTS__USB0_ID, + MX28_PAD_LCD_VSYNC__GPIO_1_28, /* PRW_On */ + + /* USB1 */ + MX28_PAD_PWM2__USB1_OVERCURRENT, + + /* eMMC */ + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__GPIO_2_9, /* Reset for eMMC */ + MX28_PAD_SSP0_SCK__SSP0_SCK | MUX_CONFIG_SSP0, + + /* DIG Keys */ + MX28_PAD_GPMI_D00__GPIO_0_0, + MX28_PAD_GPMI_D01__GPIO_0_1, + MX28_PAD_GPMI_D02__GPIO_0_2, + MX28_PAD_GPMI_D03__GPIO_0_3, + MX28_PAD_GPMI_D04__GPIO_0_4, + MX28_PAD_GPMI_D05__GPIO_0_5, + MX28_PAD_GPMI_D06__GPIO_0_6, + MX28_PAD_GPMI_D07__GPIO_0_7, + + /* ADR_0-2 */ + MX28_PAD_GPMI_CE1N__GPIO_0_17, + MX28_PAD_GPMI_CE2N__GPIO_0_18, + MX28_PAD_GPMI_CE3N__GPIO_0_19, + + /* Read Keys */ + MX28_PAD_GPMI_RDY0__GPIO_0_20, + + /* LATCH_EN */ + MX28_PAD_GPMI_RDY1__GPIO_0_21, + + /* Power off */ + MX28_PAD_GPMI_RDN__GPIO_0_24, + + /* I2C1 Touch */ + MX28_PAD_AUART2_CTS__GPIO_3_10, + MX28_PAD_AUART2_RTS__GPIO_3_11, + MX28_PAD_GPMI_RDY2__GPIO_0_22, /* Touch Reset */ + + /* TIVA */ + MX28_PAD_AUART1_RX__SSP2_CARD_DETECT, + MX28_PAD_SSP2_MISO__SSP2_D0, + MX28_PAD_SSP2_MOSI__SSP2_CMD, + MX28_PAD_SSP2_SCK__SSP2_SCK, + MX28_PAD_SSP2_SS0__SSP2_D3, + MX28_PAD_SSP2_SS1__GPIO_2_20, + MX28_PAD_SSP2_SS2__GPIO_2_21, + + /* SPI3 NOR-Flash */ + MX28_PAD_AUART1_TX__SSP3_CARD_DETECT, + MX28_PAD_AUART2_RX__SSP3_D1, + MX28_PAD_AUART2_TX__SSP3_D2, + MX28_PAD_SSP3_MISO__SSP3_D0, + MX28_PAD_SSP3_MOSI__SSP3_CMD, + MX28_PAD_SSP3_SCK__SSP3_SCK, + MX28_PAD_SSP3_SS0__SSP3_D3, + + /* NOR-Flash CMD */ + MX28_PAD_LCD_RS__GPIO_1_26, /* Hold */ + MX28_PAD_LCD_WR_RWN__GPIO_1_25, /* write protect */ + + /* I2C0 Codec */ + MX28_PAD_I2C0_SCL__I2C0_SCL, + MX28_PAD_I2C0_SDA__I2C0_SDA, + + /* I2S Codec */ + MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK, + MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK, + MX28_PAD_SAIF0_MCLK__SAIF0_MCLK, + MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0, + MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0, + + /* PWR-Hold */ + MX28_PAD_SPDIF__GPIO_3_27, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, + + /* Uart3 Bluetooth-Interface */ + MX28_PAD_AUART3_CTS__AUART3_CTS, + MX28_PAD_AUART3_RTS__AUART3_RTS, + MX28_PAD_AUART3_RX__AUART3_RX, + MX28_PAD_AUART3_TX__AUART3_TX, + + /* framebuffer */ + MX28_PAD_LCD_CS__LCD_CS | MUX_CONFIG_LCD, + MX28_PAD_LCD_D00__LCD_D0 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D01__LCD_D1 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D02__LCD_D2 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D03__LCD_D3 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D04__LCD_D4 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D05__LCD_D5 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D06__LCD_D6 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D07__LCD_D7 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D08__LCD_D8 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D09__LCD_D9 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D10__LCD_D10 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D11__LCD_D11 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D12__LCD_D12 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D13__LCD_D13 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D14__LCD_D14 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D15__LCD_D15 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D16__LCD_D16 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D17__LCD_D17 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D18__LCD_D18 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D19__LCD_D19 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D20__LCD_D20 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D21__LCD_D21 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D22__LCD_D22 | MUX_CONFIG_LCD, + MX28_PAD_LCD_D23__LCD_D23 | MUX_CONFIG_LCD, + MX28_PAD_LCD_DOTCLK__LCD_DOTCLK | MUX_CONFIG_LCD, + MX28_PAD_LCD_ENABLE__LCD_ENABLE | MUX_CONFIG_LCD, + MX28_PAD_LCD_HSYNC__LCD_HSYNC | MUX_CONFIG_LCD, + MX28_PAD_LCD_RD_E__LCD_VSYNC | MUX_CONFIG_LCD, + MX28_PAD_LCD_RESET__LCD_RESET | MUX_CONFIG_LCD, + + /* DUART RS232 */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* FEC Ethernet */ + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_CLK__GPIO_4_13, /* Phy Interrupt */ + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_CLK__GPIO_4_5, /* n.c. */ + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_SSP1_CMD__GPIO_2_13, /* PHY reset */ + + /* TIVA boot control */ + MX28_PAD_GPMI_RDY3__GPIO_0_23 | MUX_CONFIG_BOOT, /* TIVA0 */ + MX28_PAD_GPMI_WRN__GPIO_0_25 | MUX_CONFIG_BOOT, /* TIVA1 */ +}; + +u32 mxs_dram_vals[] = { + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000100, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010101, 0x01010101, + 0x000f0f01, 0x0f02010a, 0x00000000, 0x00010101, + 0x00000100, 0x00000100, 0x00000000, 0x00000002, + 0x01010000, 0x07080403, 0x07005303, 0x0b0000c8, + 0x0200a0c1, 0x0002040c, 0x0038430a, 0x04290322, + 0x02040203, 0x00c8002b, 0x00000000, 0x00000000, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00012100, 0xffff0303, 0x00012100, 0xffff0303, + 0x00000003, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000612, 0x01000102, + 0x06120612, 0x00000200, 0x00020007, 0xf4004a27, + 0xf4004a27, 0xf4004a27, 0xf4004a27, 0x07400300, + 0x07400300, 0x07400300, 0x07400300, 0x00000005, + 0x00000000, 0x00000000, 0x01000000, 0x00000000, + 0x00000001, 0x000f1133, 0x00000000, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00001f04, + 0x00001f04, 0x00001f04, 0x00001f04, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00010000, 0x00030404, + 0x00000002, 0x00000000, 0x00000000, 0x00000000, + 0x00000000, 0x00000000, 0x00000000, 0x01010000, + 0x01000000, 0x03030000, 0x00010303, 0x01020202, + 0x00000000, 0x02040101, 0x21002103, 0x00061200, + 0x06120612, 0x00000642, 0x00000000, 0x00000004, + 0x00000000, 0x00000080, 0x00000000, 0x00000000, + 0x00000000, 0xffffffff +}; + +void lowlevel_init(void) +{ + struct mxs_pinctrl_regs *pinctrl_regs = + (struct mxs_pinctrl_regs *)MXS_PINCTRL_BASE; + + /* Set EMI drive strength */ + writel(0x00003fff, &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_clr); + writel(0x00002aaa, &pinctrl_regs->hw_pinctrl_emi_ds_ctrl_set); + + mxs_common_spl_init(0, NULL, iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c new file mode 100644 index 0000000000..7291313e95 --- /dev/null +++ b/board/liebherr/xea/xea.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * XEA iMX28 board + * + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> +#include <usb.h> + +#ifdef CONFIG_SPL_BUILD +#include <spl.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ + +static void init_clocks(void) +{ + /* IO0 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 160MHz */ + mxs_set_sspclk(MXC_SSPCLK2, 160000, 0); + /* SSP3 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK3, 96000, 0); +} + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong arg) +{ + init_clocks(); + preloader_console_init(); +} + +static int boot_tiva0, boot_tiva1; + +/* Check if TIVAs request booting via U-Boot proper */ +void spl_board_init(void) +{ + struct gpio_desc btiva0, btiva1; + int ret; + + ret = dm_gpio_lookup_name("GPIO0_23", &btiva0); + if (ret) + printf("Cannot get GPIO0_23\n"); + + ret = dm_gpio_lookup_name("GPIO0_25", &btiva1); + if (ret) + printf("Cannot get GPIO0_25\n"); + + ret = dm_gpio_request(&btiva0, "boot-tiva0"); + if (ret) + printf("Cannot request GPIO0_23\n"); + + ret = dm_gpio_request(&btiva1, "boot-tiva1"); + if (ret) + printf("Cannot request GPIO0_25\n"); + + dm_gpio_set_dir_flags(&btiva0, GPIOD_IS_IN); + dm_gpio_set_dir_flags(&btiva1, GPIOD_IS_IN); + + udelay(1000); + + boot_tiva0 = dm_gpio_get_value(&btiva0); + boot_tiva1 = dm_gpio_get_value(&btiva1); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_MMC1; + spl_boot_list[1] = BOOT_DEVICE_SPI; +} + +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + debug("%s: btiva0: %d btiva1: %d\n", __func__, boot_tiva0, boot_tiva1); + return !boot_tiva0 || !boot_tiva1; +} +#else + +int board_early_init_f(void) +{ + init_clocks(); + + return 0; +} + +int board_init(void) +{ + struct gpio_desc phy_rst; + int ret; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + cpu_eth_init(NULL); + + /* PHY INT#/PWDN# */ + ret = dm_gpio_lookup_name("GPIO4_13", &phy_rst); + if (ret) { + printf("Cannot get GPIO4_13\n"); + return ret; + } + + ret = dm_gpio_request(&phy_rst, "phy-rst"); + if (ret) { + printf("Cannot request GPIO4_13\n"); + return ret; + } + + dm_gpio_set_dir_flags(&phy_rst, GPIOD_IS_IN); + udelay(1000); + + return 0; +} + +int dram_init(void) +{ + return mxs_dram_init(); +} + +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig new file mode 100644 index 0000000000..33ec7a80c5 --- /dev/null +++ b/configs/imx28_xea_defconfig @@ -0,0 +1,110 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_THUMB_BUILD=y +CONFIG_ARCH_MX28=y +CONFIG_SYS_TEXT_BASE=0x40002000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_TARGET_XEA=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x1000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x1000 +CONFIG_FIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0 +CONFIG_SPL_DMA_SUPPORT=y +CONFIG_SPL_DM_GPIO=y +CONFIG_SPL_MMC_TINY=y +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_SPL=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +# CONFIG_CMD_PINMUX is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi3.0" +CONFIG_MTDPARTS_DEFAULT="spi3.0:64k(SPL),448k(uboot),128k(envs),384k(unused1),4096k(kernel),8192k(swupdate),-(unused2)" +CONFIG_DOS_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx28-xea" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent interrupts" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=3 +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=40000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x0 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_DEVRES=y +CONFIG_DM_GPIO=y +CONFIG_MXS_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_MXS=y +CONFIG_MTD=y +CONFIG_MTD_DEVICE=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ADDR=1 +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MXS=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=0 +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXS_SPI=y +CONFIG_FS_FAT=y +# CONFIG_SPL_OF_LIBFDT is not set +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/xea.h b/include/configs/xea.h new file mode 100644 index 0000000000..1edc5e268e --- /dev/null +++ b/include/configs/xea.h @@ -0,0 +1,192 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * Copyright (C) 2018 DENX Software Engineering + * Måns Rullgård, DENX Software Engineering, mans@mansr.com + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + */ +#ifndef __CONFIGS_XEA_H__ +#define __CONFIGS_XEA_H__ + +#include <linux/sizes.h> + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ + +/* SPL */ +#define CONFIG_SPL_STACK 0x20000 + +#define CONFIG_SYS_SPL_ARGS_ADDR 0x44000000 + +#define CONFIG_SYS_SPI_KERNEL_OFFS SZ_1M +#define CONFIG_SYS_SPI_ARGS_OFFS SZ_512K +#define CONFIG_SYS_SPI_ARGS_SIZE SZ_32K + +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR (SZ_512K / 0x200) +#define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (SZ_32K / 0x200) +#define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR (SZ_1M / 0x200) + +/* Memory configuration */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x10000000 /* Max 256 MB RAM */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Environment */ +#define CONFIG_ENV_OVERWRITE + +/* Booting Linux */ +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyAMA0,115200n8 " +#define CONFIG_BOOTCOMMAND "run ${bootpri} ; run ${bootsec}" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* Extra Environment */ +#define CONFIG_PREBOOT "run prebootcmd" +#define CONFIG_HOSTNAME "xea" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootmode=update\0" \ + "bootpri=mmc_mmc\0" \ + "bootsec=sf_swu\0" \ + "consdev=ttyAMA0\0" \ + "baudrate=115200\0" \ + "dtbaddr=0x44000000\0" \ + "dtbfile=imx28-xea.dtb\0" \ + "rootdev=/dev/mmcblk0p2\0" \ + "netdev=eth0\0" \ + "rdaddr=0x43000000\0" \ + "swufile=swupdate.img\0" \ + "sf_kernel_offset=0x100000\0" \ + "sf_kernel_size=0x400000\0" \ + "sf_swu_offset=0x500000\0" \ + "sf_swu_size=0x800000\0" \ + "rootpath=/opt/eldk-5.5/armv5te/rootfs-qte-sdk\0" \ + "do_update_mmc=" \ + "if mmc rescan ; then " \ + "mmc dev 0 ${update_mmc_part} ; " \ + "if dhcp ${hostname}/${update_filename} ; then " \ + "setexpr fw_sz ${filesize} / 0x200 ; " /* SD block size */ \ + "setexpr fw_sz ${fw_sz} + 1 ; " \ + "mmc write ${loadaddr} ${update_offset} ${fw_sz} ; " \ + "fi ; " \ + "fi\0" \ + "do_update_sf=" \ + "if sf probe ; then " \ + "if dhcp ${hostname}/${update_filename} ; then " \ + "sf erase ${update_offset} +${filesize} ; " \ + "sf write ${loadaddr} ${update_offset} ${filesize} ; " \ + "fi ; " \ + "fi\0" \ + "update_spl_filename=u-boot.sb\0" \ + "update_spl=" \ + "setenv update_filename ${update_spl_filename} ; " \ + "setenv update_offset 0 ; " \ + "run do_update_sf\0" \ + "update_uboot_filename=u-boot.img\0" \ + "update_uboot=" \ + "setenv update_filename ${update_uboot_filename} ; " \ + "setenv update_offset 0x10000 ; " \ + "run do_update_sf ; " \ + "setenv update_mmc_part 1 ; " \ + "setenv update_offset 0 ; " \ + "run do_update_mmc\0" \ + "update_kernel_filename=uImage\0" \ + "update_kernel=" \ + "setenv update_mmc_part 1 ; " \ + "setenv update_filename ${update_kernel_filename} ; " \ + "setenv update_offset 0x800 ; " \ + "run do_update_mmc ; " \ + "setenv update_filename ${dtbfile} ; " \ + "setenv update_offset 0x400 ; " \ + "run do_update_mmc\0" \ + "update_sfkernel=" \ + "setenv update_filename fitImage ; " \ + "setenv update_offset ${sf_kernel_offset} ; " \ + "run do_update_sf\0" \ + "update_swu=" \ + "setenv update_filename ${swufile} ; " \ + "setenv update_offset ${sf_swu_offset} ; " \ + "run do_update_sf\0" \ + "addcons=" \ + "setenv bootargs ${bootargs} " \ + "console=${consdev},${baudrate}\0" \ + "addip=" \ + "setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:${hostname}:${netdev}:off\0" \ + "addmisc=" \ + "setenv bootargs ${bootargs} ${miscargs}\0" \ + "addargs=run addcons addmisc\0" \ + "mmcload=" \ + "mmc rescan ; " \ + "mmc dev 0 1 ; " \ + "mmc read ${loadaddr} 0x800 0x2000 ; " \ + "mmc read ${dtbaddr} 0x400 0x80\0" \ + "netload=" \ + "dhcp ${loadaddr} ${hostname}/${bootfile} ; " \ + "tftp ${dtbaddr} ${hostname}/${dtbfile}\0" \ + "sfload=" \ + "sf probe ; " \ + "sf read ${loadaddr} ${sf_kernel_offset} ${sf_kernel_size}\0" \ + "usbload=" \ + "usb start ; " \ + "load usb 0:1 ${loadaddr} ${bootfile}\0" \ + "miscargs=panic=1\0" \ + "mmcargs=setenv bootargs root=${rootdev} rw rootwait\0" \ + "nfsargs=" \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath},v3,tcp\0" \ + "mmc_mmc=" \ + "if run mmcload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "mmc_nfs=" \ + "if run mmcload nfsargs addip addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "sf_mmc=" \ + "if run sfload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "sf_swu=" \ + "if run sfload ; then " \ + "sf read ${rdaddr} ${sf_swu_offset} ${sf_swu_size} ; " \ + "setenv bootargs root=/dev/ram0 rw ; " \ + "run addargs ; " \ + "bootm ${loadaddr} ${rdaddr} ; " \ + "fi\0" \ + "net_mmc=" \ + "if run netload mmcargs addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "net_nfs=" \ + "if run netload nfsargs addip addargs ; then " \ + "bootm ${loadaddr} - ${dtbaddr} ; " \ + "fi\0" \ + "prebootcmd=" \ + "if test "${envsaved}" != y ; then ; " \ + "setenv envsaved y ; " \ + "saveenv ; " \ + "fi ; " \ + "if test "${bootmode}" = normal ; then " \ + "setenv bootdelay 0 ; " \ + "setenv bootpri mmc_mmc ; " \ + "elif test "${bootmode}" = devel ; then " \ + "setenv bootdelay 3 ; " \ + "setenv bootpri net_mmc ; " \ + "else " \ + "if test "${bootmode}" != update ; then " \ + "echo Warning: unknown bootmode "${bootmode}" ; " \ + "fi ; " \ + "setenv bootdelay 1 ; " \ + "setenv bootpri sf_swu ; " \ + "fi\0" + +/* The rest of the configuration is shared */ +#include <configs/mxs.h> + +#endif /* __CONFIGS_XEA_H__ */
Lukasz Majewski
