[U-Boot] Problem in loading rootfs
I am facing problem in loading my image on Netgear GSM7353S switch. Let me give you some context
1. I started with following link http://www.openflowhub.org/display/Indigo/Upgrading+the+Flash+of+the+Netgear... . 2. Link said to copy the image using command *flashcp -v gsm73xxso-of-1.1.0.2.image /dev/mtd0* 3. Then it sets the bootargs using following command. *setenv ofboot 'setenv bootargs console=ttyS0,115200 init=/etc/preinit rw; bootm fe000000 fe180000'* 4. All things went fine and I get the appropriate prompt. 5. Then I prepared my own image and tried to burn it using the same above command and reboot the switch. 6. It shows me following message
Data Size: 1039259 Bytes = 1014.9 KB Load Adress: 00400000 Entry point: 004005b0 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Wrong Ramdisk image format ... VFS: Cannot open root device "<NULL>" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 28416 mtdblock0 (driver?) 1f01 256 mtdblock1 (driver?) 1f02 4096 mtdblock2 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Can anybody tells me what is going on? Any help will be highly appreciated. Thanks in advance.
Regards
Tahir Rauf
