[U-Boot] [PATCH 02/15][v4] imx: usb: ehci-mx7 add usb driver for i.MX7D
Add support for usb driver for i.MX7D SoC
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- Changes for V2: Resend Changes for V3: - Integrate review obserbations - Add comments for fucntions board_ehci_hcd_init/board_ehci_power Changes for V4: - Follow kernel doc comments style
drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mx7.c | 113 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 114 insertions(+) create mode 100644 drivers/usb/host/ehci-mx7.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 4d35d3e..7267160 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -36,6 +36,7 @@ obj-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o obj-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o obj-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o obj-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o +obj-$(CONFIG_USB_EHCI_MX7) += ehci-mx7.o obj-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o obj-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o diff --git a/drivers/usb/host/ehci-mx7.c b/drivers/usb/host/ehci-mx7.c new file mode 100644 index 0000000..da6b4dc --- /dev/null +++ b/drivers/usb/host/ehci-mx7.c @@ -0,0 +1,113 @@ +/* + * Copyright (c) 2009 Daniel Mack daniel@caiaq.de + * Copyright (C) 2010-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <usb.h> +#include <errno.h> +#include <linux/compiler.h> +#include <usb/ehci-fsl.h> +#include <asm/io.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/imx-common/iomux-v3.h> + +#include "ehci.h" + +#define USB_NC_OFFSET 0x200 + +#define UCTRL_PM (1 << 9) /* OTG Power Mask */ +#define UCTRL_OVER_CUR_POL (1 << 8) /* OTG Polarity of Overcurrent */ +#define UCTRL_OVER_CUR_DIS (1 << 7) /* Disable OTG Overcurrent Detection */ + +/* USBCMD */ +#define UCMD_RUN_STOP (1 << 0) /* controller run/stop */ +#define UCMD_RESET (1 << 1) /* controller reset */ + +/* Base address for this IP block is 0x02184800 */ +struct usbnc_regs { + u32 ctrl1; + u32 ctrl2; + u32 reserve1[11]; + u32 phy_ctrl2; + u32 reserve2[6]; + u32 adp_cfg1; + u32 reserve3; + u32 adp_status; +}; + +static void usb_oc_config(int index) +{ + struct usbnc_regs *usbnc = (struct usbnc_regs *)(USB_BASE_ADDR + + (0x10000 * index) + USB_NC_OFFSET); + void __iomem *ctrl = (void __iomem *)(&usbnc->ctrl1); + + setbits_le32(ctrl, UCTRL_OVER_CUR_POL); + setbits_le32(ctrl, UCTRL_OVER_CUR_DIS | UCTRL_PM); +} + +/* + * board_ehci_hcd_init - set usb vbus voltage + * @port: usb otg port + * + * Setup iomux pad to setup supply vbus voltage for usb otg port. + * Machine board file overrides board_ehci_hcd_init + */ +int __weak board_ehci_hcd_init(int port) +{ + return 0; +} + +/* + * board_ehci_power - enables/disables usb vbus voltage + * @port: usb otg port + * @on: on/off vbus voltage + * + * Enables/disables supply vbus voltage for usb otg port. + * Machine board file overrides board_ehci_power + * + */ +int __weak board_ehci_power(int port, int on) +{ + return 0; +} + +int ehci_hcd_init(int index, enum usb_init_type init, + struct ehci_hccr **hccr, struct ehci_hcor **hcor) +{ + struct usb_ehci *ehci = (struct usb_ehci *)(USB_BASE_ADDR + + (0x10000 * index)); + + if (index > 3) + return -EINVAL; + enable_usboh3_clk(1); + mdelay(1); + + /* Do board specific initialization */ + board_ehci_hcd_init(index); + + usb_oc_config(index); + + *hccr = (struct ehci_hccr *)((uint32_t)&ehci->caplength); + *hcor = (struct ehci_hcor *)((uint32_t)*hccr + + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + + board_ehci_power(index, (init == USB_INIT_DEVICE) ? 0 : 1); + if (init == USB_INIT_DEVICE) + return 0; + setbits_le32(&ehci->usbmode, CM_HOST); + writel(CONFIG_MXC_USB_PORTSC, &ehci->portsc); + setbits_le32(&ehci->portsc, USB_EN); + + mdelay(10); + + return 0; +} + +int ehci_hcd_stop(int index) +{ + return 0; +}
So errr, why exactly can ehci-mx6 not be used here ? The code looks almost like a copy of ehci-mx6 with minor tweaks here and there.
Best regards, Marek Vasut
Hi Marek,
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Friday, July 24, 2015 4:44 AM To: Alonso Lazcano Adrian-B38018 Cc: u-boot@lists.denx.de; sbabic@denx.de; otavio@ossystems.com.br; Estevam Fabio-R49496; Li Frank-B20596; Garg Nitin-B37173 Subject: Re: [PATCH 02/15][v4] imx: usb: ehci-mx7 add usb driver for i.MX7D
[Adrian] We can definitely have a single driver to support imx7 and imx6, but we mainly decide to have a driver for each SoC to try to make easier to maintain, there are so many variants of imx6 (Quad/Dual/Solo/SoloX/QuadPlus/UL) and imx7 (Dual/Solo); while there are several similarities in USB IP for iMX6 and iMX7, USB PHY Control and clock settings differ slightly making code harder to Understand and maintain in a single driver for imx7 and imx6.
Regards Adrian
On Friday, July 24, 2015 at 05:34:27 PM, Alonso Adrian wrote:
Hi Marek,
Hi!
I just took a look into ehci-mx6.c and I see 1 (one) bogus conditional which involves a board type. I see zero conditionals there which would check CPU type.
The downside of having multiple copies of the code is that if you fix bug in one copy and not in the other, the bug will remain unfixed on many of the other machines. I don't like that. I am also not convinced that there is justification for having separate drivers for MX6 and MX7 EHCI. I would like to see a patch adding MX7 support into ehci-mx6 and in case it is really as hairy as you say, I'd pick a separate one.
Hi Adrian,
On 24/07/2015 17:34, Alonso Adrian wrote:
Hi Marek,
This is exactly we do not want to have in U-Boot mainline. We try as much as püossible to duplicate code, and when it is possible to have a single driver across more platforms or event architectures.
This could mean that some parts should be extracted and move into a separate SOC specific file, but it is not a reson for duplicating code.
Best regards, Stefano Babic
I think you're missing one "NOT" there ;-) [...]
Adrian Alonso
Alonso Adrian
Stefano Babic
