[U-Boot] [PATCH 1/2] Kconfig: Add entry for VF610 NAND NFC device tree aware driver
This commit provides code to add proper entry to Kconfig to enable support for VF610 device tree aware driver.
Signed-off-by: Lukasz Majewski lukma@denx.de
drivers/mtd/nand/raw/Kconfig | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 008f7b4b4b..fd1723feda 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -88,6 +88,15 @@ config NAND_VF610_NFC The driver supports a maximum 2k page size. The driver currently does not support hardware ECC.
+if NAND_VF610_NFC + +config NAND_VF610_NFC_DT + bool "Support Vybrid's vf610 NAND controller as a DT device" + depends on OF_CONTROL && MTD + help + Enable the driver for Vybrid's vf610 NAND flash on platforms + using device tree. + choice prompt "Hardware ECC strength" depends on NAND_VF610_NFC @@ -103,6 +112,8 @@ config SYS_NAND_VF610_NFC_60_ECC_BYTES
endchoice
+endif + config NAND_PXA3XX bool "Support for NAND on PXA3xx and Armada 370/XP/38x" select SYS_NAND_SELF_INIT
This commit adds support for device tree and enumeration via device model for the Vybrid's NFC NAND driver.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/mtd/nand/raw/vf610_nfc.c | 47 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/drivers/mtd/nand/raw/vf610_nfc.c b/drivers/mtd/nand/raw/vf610_nfc.c index 619d0403e9..fce7e5f299 100644 --- a/drivers/mtd/nand/raw/vf610_nfc.c +++ b/drivers/mtd/nand/raw/vf610_nfc.c @@ -31,6 +31,11 @@ #include <nand.h> #include <errno.h> #include <asm/io.h> +#if CONFIG_NAND_VF610_NFC_DT +#include <dm.h> +#include <linux/io.h> +#include <linux/ioport.h> +#endif
/* Register Offsets */ #define NFC_FLASH_CMD1 0x3F00 @@ -760,9 +765,51 @@ error: return err; }
+#if CONFIG_NAND_VF610_NFC_DT +static const struct udevice_id vf610_nfc_dt_ids[] = { + { + .compatible = "fsl,vf610-nfc", + }, + { /* sentinel */ } +}; + +static int vf610_nfc_dt_probe(struct udevice *dev) +{ + struct resource res; + int ret; + + ret = dev_read_resource(dev, 0, &res); + if (ret) + return ret; + + return vf610_nfc_nand_init(0, devm_ioremap(dev, res.start, + resource_size(&res))); +} + +U_BOOT_DRIVER(vf610_nfc_dt) = { + .name = "vf610-nfc-dt", + .id = UCLASS_MTD, + .of_match = vf610_nfc_dt_ids, + .probe = vf610_nfc_dt_probe, +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(vf610_nfc_dt), + &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize NAND controller. (error %d)\n", + ret); +} +#else void board_nand_init(void) { int err = vf610_nfc_nand_init(0, (void __iomem *)CONFIG_SYS_NAND_BASE); if (err) printf("VF610 NAND init failed (err %d)\n", err); } +#endif /* CONFIG_NAND_VF610_NFC_DT */
Looks like a start, but ideally we should also move all the board/system specific properties to device-tree (e.g. CONFIG_SYS_NAND_VF610_NFC_45_ECC_BYTES).
-- Stefan
+if NAND_VF610_NFC
help
using device tree.
endchoice
+endif
Hi Stefan,
Looks like a start,
Indeed - this is a start. Vybrid is a bit behind the current u-boot peace of development.
I'm trying to give it some momentum.
Yes, that would be a long term goal. However, those configs are already moved to Kconfig, so there is no urgent need to make the conversion now.
-- Stefan
+if NAND_VF610_NFC
device"
help
platforms
using device tree.
endchoice
+endif
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
Stefan Agner
