[U-Boot] [Patch v6 8/9] armv8: ls1046ardb: Add LS1046ARDB board support
LS1046ARDB Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 512 Mbyte NAND flash * Two 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card * On-board 4G eMMC
Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports
PCIe: * PCIe1 (SerDes2 Lane0) to miniPCIe slot * PCIe2 (SerDes2 Lane1) to x2 PCIe slot * PCIe3 (SerDes2 Lane2) to x4 PCIe slot
SATA: * SerDes2 Lane3 to SATA port
USB 3.0: one super speed USB 3.0 type A port one Micro-AB port
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- v6: - Move CONFIG_FSL_QSPI to defconfig and select DM_SPI_FLASH in Kconfig. v5: - Adjust the SPL BSS and MALLOC address. v4: - Extend SPL max size and pad_to size for SD boot. v3: - Remove redundant sd rcw .cfg files. - Adjust the format of memory map. - Add emmc boot support. v2: - Add >60 characters' paragraph for the board help. - Fix the memory map in readme. - Remove unused flash r/w functions. - Remove DDR3 defines.
arch/arm/Kconfig | 13 ++ arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1046a-rdb.dts | 44 ++++ arch/arm/dts/fsl-ls1046a.dtsi | 166 ++++++++++++++ board/freescale/ls1046ardb/Kconfig | 16 ++ board/freescale/ls1046ardb/MAINTAINERS | 9 + board/freescale/ls1046ardb/Makefile | 10 + board/freescale/ls1046ardb/README | 76 +++++++ board/freescale/ls1046ardb/cpld.c | 158 ++++++++++++++ board/freescale/ls1046ardb/cpld.h | 49 +++++ board/freescale/ls1046ardb/ddr.c | 140 ++++++++++++ board/freescale/ls1046ardb/ddr.h | 44 ++++ board/freescale/ls1046ardb/eth.c | 77 +++++++ board/freescale/ls1046ardb/ls1046ardb.c | 136 ++++++++++++ board/freescale/ls1046ardb/ls1046ardb_pbi.cfg | 22 ++ board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg | 7 + board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg | 7 + configs/ls1046ardb_emmc_defconfig | 27 +++ configs/ls1046ardb_qspi_defconfig | 26 +++ configs/ls1046ardb_sdcard_defconfig | 27 +++ include/configs/ls1046a_common.h | 175 +++++++++++++++ include/configs/ls1046ardb.h | 240 +++++++++++++++++++++ 22 files changed, 1470 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c871eaf..8c59c42 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -837,6 +837,18 @@ config TARGET_LS1043ARDB help Support for Freescale LS1043ARDB platform.
+config TARGET_LS1046ARDB + bool "Support ls1046ardb" + select ARM64 + select ARMV8_MULTIENTRY + select SUPPORT_SPL + select DM_SPI_FLASH if DM_SPI + help + Support for Freescale LS1046ARDB platform. + The LS1046A Reference Design Board (RDB) is a high-performance + development platform that supports the QorIQ LS1046A + Layerscape Architecture processor. + config TARGET_H2200 bool "Support h2200" select CPU_PXA @@ -981,6 +993,7 @@ source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" source "board/freescale/ls1043ardb/Kconfig" +source "board/freescale/ls1046ardb/Kconfig" source "board/freescale/ls1012aqds/Kconfig" source "board/freescale/ls1012ardb/Kconfig" source "board/freescale/ls1012afrdm/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 756535b..b646aa0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -143,6 +143,7 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ + fsl-ls1046a-rdb.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-frdm.dtb diff --git a/arch/arm/dts/fsl-ls1046a-rdb.dts b/arch/arm/dts/fsl-ls1046a-rdb.dts new file mode 100644 index 0000000..4902454 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-rdb.dts @@ -0,0 +1,44 @@ +/* + * Device Tree Include file for Freescale Layerscape-1046A family SoC. + * + * Copyright 2016, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@freescale.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/dts-v1/; +/include/ "fsl-ls1046a.dtsi" + +/ { + model = "LS1046A RDB Board"; + + aliases { + spi0 = &qspi; + }; + +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi new file mode 100644 index 0000000..87dd997 --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -0,0 +1,166 @@ +/* + * Device Tree Include file for Freescale Layerscape-1046A family SoC. + * + * Copyright (C) 2016, Freescale Semiconductor + * + * Mingkai Hu mingkai.hu@nxp.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/include/ "skeleton64.dtsi" + +/ { + compatible = "fsl,ls1046a"; + interrupt-parent = <&gic>; + + sysclk: sysclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + clock-output-names = "sysclk"; + }; + + gic: interrupt-controller@1400000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1410000 0 0x10000>, /* GICD */ + <0x0 0x1420000 0 0x10000>, /* GICC */ + <0x0 0x1440000 0 0x20000>, /* GICH */ + <0x0 0x1460000 0 0x20000>; /* GICV */ + interrupts = <1 9 0xf08>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clockgen: clocking@1ee1000 { + compatible = "fsl,ls1046a-clockgen"; + reg = <0x0 0x1ee1000 0x0 0x1000>; + #clock-cells = <2>; + clocks = <&sysclk>; + }; + + dspi0: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <0 64 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + + dspi1: dspi@2110000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2110000 0x0 0x10000>; + interrupts = <0 65 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + + ifc: ifc@1530000 { + compatible = "fsl,ifc", "simple-bus"; + reg = <0x0 0x1530000 0x0 0x10000>; + interrupts = <0 43 0x4>; + }; + + i2c0: i2c@2180000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2180000 0x0 0x10000>; + interrupts = <0 56 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c1: i2c@2190000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2190000 0x0 0x10000>; + interrupts = <0 57 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c2: i2c@21a0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21a0000 0x0 0x10000>; + interrupts = <0 58 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c3: i2c@21b0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21b0000 0x0 0x10000>; + interrupts = <0 59 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + duart0: serial@21c0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0500 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart1: serial@21c0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0600 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart2: serial@21d0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0500 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart3: serial@21d0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0600 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + + qspi: quadspi@1550000 { + compatible = "fsl,vf610-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x1550000 0x0 0x10000>, + <0x0 0x40000000 0x0 0x10000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; + num-cs = <4>; + big-endian; + status = "disabled"; + }; + }; +}; diff --git a/board/freescale/ls1046ardb/Kconfig b/board/freescale/ls1046ardb/Kconfig new file mode 100644 index 0000000..a62255c --- /dev/null +++ b/board/freescale/ls1046ardb/Kconfig @@ -0,0 +1,16 @@ + +if TARGET_LS1046ARDB + +config SYS_BOARD + default "ls1046ardb" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1046ardb" + +endif diff --git a/board/freescale/ls1046ardb/MAINTAINERS b/board/freescale/ls1046ardb/MAINTAINERS new file mode 100644 index 0000000..ff42bef --- /dev/null +++ b/board/freescale/ls1046ardb/MAINTAINERS @@ -0,0 +1,9 @@ +LS1046A BOARD +M: Mingkai Hu mingkai.hu@nxp.com +S: Maintained +F: board/freescale/ls1046ardb/ +F: board/freescale/ls1046ardb/ls1046ardb.c +F: include/configs/ls1046ardb.h +F: configs/ls1046ardb_qspi_defconfig +F: configs/ls1046ardb_sdcard_defconfig +F: configs/ls1046ardb_emmc_defconfig diff --git a/board/freescale/ls1046ardb/Makefile b/board/freescale/ls1046ardb/Makefile new file mode 100644 index 0000000..348eb76 --- /dev/null +++ b/board/freescale/ls1046ardb/Makefile @@ -0,0 +1,10 @@ +# +# Copyright 2016 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cpld.o +obj-y += ddr.o +obj-y += ls1046ardb.o +obj-$(CONFIG_SYS_DPAA_FMAN) += eth.o diff --git a/board/freescale/ls1046ardb/README b/board/freescale/ls1046ardb/README new file mode 100644 index 0000000..1ef7d47 --- /dev/null +++ b/board/freescale/ls1046ardb/README @@ -0,0 +1,76 @@ +Overview +-------- +The LS1046A Reference Design Board (RDB) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The LS1046ARDB provides SW development +platform for the Freescale LS1046A processor series, with a complete +debugging environment. The LS1046A RDB is lead-free and RoHS-compliant. + +LS1046A SoC Overview +-------------------- +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS1046A +SoC overview. + + LS1046ARDB board Overview + ----------------------- + - SERDES1 Connections, 4 lanes supporting: + - Lane0: XFI with x1 RJ45 connector + - Lane1: XFI Cage + - Lane2: SGMII.5 + - Lane3: SGMII.6 + - SERDES2 Connections, 4 lanes supporting: + - Lane0: PCIe1 with miniPCIe slot + - Lane1: PCIe2 with PCIe x2 slot + - Lane2: PCIe3 with PCIe x4 slot + - Lane3: SATA + - DDR Controller + - 8GB 64bits DDR4 SDRAM. Support rates of up to 2133MT/s + -IFC/Local Bus + - One 512 MB NAND flash with ECC support + - CPLD connection + - USB 3.0 + - one Type A port, one Micro-AB port + - SDHC: connects directly to a full SD/MMC slot + - DSPI: 64 MB high-speed flash Memory for boot code and storage (up to 108MHz) + - 4 I2C controllers + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB +0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - CPLD 4KB +0x00_8000_0000 - 0x00_FFFF_FFFF DRAM1 2GB +0x05_0000_0000 - 0x05_07FF_FFFF QMAN S/W Portal 128M +0x05_0800_0000 - 0x05_0FFF_FFFF BMAN S/W Portal 128M +0x08_8000_0000 - 0x09_FFFF_FFFF DRAM2 6GB +0x40_0000_0000 - 0x47_FFFF_FFFF PCI Express1 32G +0x48_0000_0000 - 0x4F_FFFF_FFFF PCI Express2 32G +0x50_0000_0000 - 0x57_FFFF_FFFF PCI Express3 32G + +QSPI flash map: +Start Address End Address Description Size +0x00_4000_0000 - 0x00_400F_FFFF RCW + PBI 1MB +0x00_4010_0000 - 0x00_401F_FFFF U-Boot 1MB +0x00_4020_0000 - 0x00_402F_FFFF U-Boot Env 1MB +0x00_4030_0000 - 0x00_403F_FFFF FMan ucode 1MB +0x00_4040_0000 - 0x00_404F_FFFF UEFI 1MB +0x00_4050_0000 - 0x00_406F_FFFF PPA 2MB +0x00_4070_0000 - 0x00_408F_FFFF Secure boot header + + bootscript 2MB +0x00_4090_0000 - 0x00_40FF_FFFF Reserved 7MB +0x00_4100_0000 - 0x00_43FF_FFFF FIT Image 48MB + +Booting Options +--------------- +a) QSPI boot +b) SD boot +c) eMMC boot diff --git a/board/freescale/ls1046ardb/cpld.c b/board/freescale/ls1046ardb/cpld.c new file mode 100644 index 0000000..81a646e --- /dev/null +++ b/board/freescale/ls1046ardb/cpld.c @@ -0,0 +1,158 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Freescale LS1046ARDB board-specific CPLD controlling supports. + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> +#include "cpld.h" + +u8 cpld_read(unsigned int reg) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + return in_8(p + reg); +} + +void cpld_write(unsigned int reg, u8 value) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + out_8(p + reg, value); +} + +/* Set the boot bank to the alternate bank */ +void cpld_set_altbank(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_QSPI; + u8 reg4 = CPLD_READ(soft_mux_on); + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + u8 reg7 = CPLD_READ(vbank); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, reg4 | CPLD_SW_MUX_BANK_SEL | 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + reg7 = (reg7 & ~CPLD_BANK_SEL_MASK) | CPLD_BANK_SEL_ALTBANK; + CPLD_WRITE(vbank, reg7); + + CPLD_WRITE(system_rst, 1); +} + +/* Set the boot bank to the default bank */ +void cpld_set_defbank(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_QSPI; + u8 reg4 = CPLD_READ(soft_mux_on); + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, reg4 | CPLD_SW_MUX_BANK_SEL | 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(vbank, 0); + + CPLD_WRITE(system_rst, 1); +} + +void cpld_set_sd(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_SD; + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(system_rst, 1); +} +#ifdef DEBUG +static void cpld_dump_regs(void) +{ + printf("cpld_ver = %x\n", CPLD_READ(cpld_ver)); + printf("cpld_ver_sub = %x\n", CPLD_READ(cpld_ver_sub)); + printf("pcba_ver = %x\n", CPLD_READ(pcba_ver)); + printf("soft_mux_on = %x\n", CPLD_READ(soft_mux_on)); + printf("cfg_rcw_src1 = %x\n", CPLD_READ(cfg_rcw_src1)); + printf("cfg_rcw_src2 = %x\n", CPLD_READ(cfg_rcw_src2)); + printf("vbank = %x\n", CPLD_READ(vbank)); + printf("sysclk_sel = %x\n", CPLD_READ(sysclk_sel)); + printf("uart_sel = %x\n", CPLD_READ(uart_sel)); + printf("sd1refclk_sel = %x\n", CPLD_READ(sd1refclk_sel)); + printf("rgmii_1588_sel = %x\n", CPLD_READ(rgmii_1588_sel)); + printf("1588_clk_sel = %x\n", CPLD_READ(reg_1588_clk_sel)); + printf("status_led = %x\n", CPLD_READ(status_led)); + printf("sd_emmc = %x\n", CPLD_READ(sd_emmc)); + printf("vdd_en = %x\n", CPLD_READ(vdd_en)); + printf("vdd_sel = %x\n", CPLD_READ(vdd_sel)); + putc('\n'); +} +#endif + +void cpld_rev_bit(unsigned char *value) +{ + u8 rev_val, val; + int i; + + val = *value; + rev_val = val & 1; + for (i = 1; i <= 7; i++) { + val >>= 1; + rev_val <<= 1; + rev_val |= val & 1; + } + + *value = rev_val; +} + +int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int rc = 0; + + if (argc <= 1) + return cmd_usage(cmdtp); + + if (strcmp(argv[1], "reset") == 0) { + if (strcmp(argv[2], "altbank") == 0) + cpld_set_altbank(); + else if (strcmp(argv[2], "sd") == 0) + cpld_set_sd(); + else + cpld_set_defbank(); +#ifdef DEBUG + } else if (strcmp(argv[1], "dump") == 0) { + cpld_dump_regs(); +#endif + } else { + rc = cmd_usage(cmdtp); + } + + return rc; +} + +U_BOOT_CMD( + cpld, CONFIG_SYS_MAXARGS, 1, do_cpld, + "Reset the board or alternate bank", + "reset: reset to default bank\n" + "cpld reset altbank: reset to alternate bank\n" + "cpld reset sd: reset to boot from SD card\n" +#ifdef DEBUG + "cpld dump - display the CPLD registers\n" +#endif +); diff --git a/board/freescale/ls1046ardb/cpld.h b/board/freescale/ls1046ardb/cpld.h new file mode 100644 index 0000000..458da7e --- /dev/null +++ b/board/freescale/ls1046ardb/cpld.h @@ -0,0 +1,49 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CPLD_H__ +#define __CPLD_H__ + +/* + * CPLD register set of LS1046ARDB board-specific. + * CPLD Revision: V2.1 + */ +struct cpld_data { + u8 cpld_ver; /* 0x0 - CPLD Major Revision Register */ + u8 cpld_ver_sub; /* 0x1 - CPLD Minor Revision Register */ + u8 pcba_ver; /* 0x2 - PCBA Revision Register */ + u8 system_rst; /* 0x3 - system reset register */ + u8 soft_mux_on; /* 0x4 - Switch Control Enable Register */ + u8 cfg_rcw_src1; /* 0x5 - RCW Source Location POR Regsiter 1 */ + u8 cfg_rcw_src2; /* 0x6 - RCW Source Location POR Regsiter 2 */ + u8 vbank; /* 0x7 - QSPI Flash Bank Setting Register */ + u8 sysclk_sel; /* 0x8 - System clock POR Register */ + u8 uart_sel; /* 0x9 - UART1 Connection Control Register */ + u8 sd1refclk_sel; /* 0xA - */ + u8 rgmii_1588_sel; /* 0xB - */ + u8 reg_1588_clk_sel; /* 0xC - */ + u8 status_led; /* 0xD - */ + u8 global_rst; /* 0xE - */ + u8 sd_emmc; /* 0xF - SD/EMMC Interface Control Regsiter */ + u8 vdd_en; /* 0x10 - VDD Voltage Control Enable Register */ + u8 vdd_sel; /* 0x11 - VDD Voltage Control Register */ +}; + +u8 cpld_read(unsigned int reg); +void cpld_write(unsigned int reg, u8 value); +void cpld_rev_bit(unsigned char *value); + +#define CPLD_READ(reg) cpld_read(offsetof(struct cpld_data, reg)) +#define CPLD_WRITE(reg, value) \ + cpld_write(offsetof(struct cpld_data, reg), value) + +/* CPLD on IFC */ +#define CPLD_SW_MUX_BANK_SEL 0x40 +#define CPLD_BANK_SEL_MASK 0x07 +#define CPLD_BANK_SEL_ALTBANK 0x04 +#define CPLD_CFG_RCW_SRC_QSPI 0x044 +#define CPLD_CFG_RCW_SRC_SD 0x040 +#endif diff --git a/board/freescale/ls1046ardb/ddr.c b/board/freescale/ls1046ardb/ddr.c new file mode 100644 index 0000000..a9b7dbd --- /dev/null +++ b/board/freescale/ls1046ardb/ddr.c @@ -0,0 +1,140 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include "ddr.h" +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + popts->data_bus_width = 0; /* 64-bit data bus */ + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + return fsl_ddr_sdram_size(); +#else + puts("Initializing DDR....using SPD\n"); + + dram_size = fsl_ddr_sdram(); +#endif + + erratum_a008850_post(); + + return dram_size; +} + +void dram_init_banksize(void) +{ + /* + * gd->arch.secure_ram tracks the location of secure memory. + * It was set as if the memory starts from 0. + * The address needs to add the offset of its bank. + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + if (gd->ram_size > CONFIG_SYS_DDR_BLOCK1_SIZE) { + gd->bd->bi_dram[0].size = CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->bd->bi_dram[1].start = CONFIG_SYS_DDR_BLOCK2_BASE; + gd->bd->bi_dram[1].size = gd->ram_size - + CONFIG_SYS_DDR_BLOCK1_SIZE; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[1].start + + gd->arch.secure_ram - + CONFIG_SYS_DDR_BLOCK1_SIZE; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } else { + gd->bd->bi_dram[0].size = gd->ram_size; +#ifdef CONFIG_SYS_MEM_RESERVE_SECURE + gd->arch.secure_ram = gd->bd->bi_dram[0].start + + gd->arch.secure_ram; + gd->arch.secure_ram |= MEM_RESERVE_SECURE_MAINTAINED; +#endif + } +} diff --git a/board/freescale/ls1046ardb/ddr.h b/board/freescale/ls1046ardb/ddr.h new file mode 100644 index 0000000..9e440f6 --- /dev/null +++ b/board/freescale/ls1046ardb/ddr.h @@ -0,0 +1,44 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ + +void erratum_a008850_post(void); + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 + */ + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x08090A0C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 8, 9, 0x0A0B0C10, 0x1213140E,}, + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +#endif diff --git a/board/freescale/ls1046ardb/eth.c b/board/freescale/ls1046ardb/eth.c new file mode 100644 index 0000000..ac8bbec --- /dev/null +++ b/board/freescale/ls1046ardb/eth.c @@ -0,0 +1,77 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_dtsec.h> +#include <fsl_mdio.h> +#include <malloc.h> + +#include "../common/fman.h" + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + int i; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + struct mii_dev *dev; + u32 srds_s1; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + + /* Set the two on-board SGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_PHY2_ADDR); + + /* Set the on-board AQ PHY address */ + fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); + + switch (srds_s1) { + case 0x1133: + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1046ARDB\n", + srds_s1); + break; + } + + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) + fm_info_set_mdio(i, dev); + + /* XFI on lane A, MAC 9 */ + dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); + fm_info_set_mdio(FM1_10GEC1, dev); + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c new file mode 100644 index 0000000..585c807 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -0,0 +1,136 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/ppa.h> +#include <asm/arch/soc.h> +#include <hwconfig.h> +#include <ahci.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + static const char *freq[2] = {"100.00MHZ", "156.25MHZ"}; + u8 cfg_rcw_src1, cfg_rcw_src2; + u16 cfg_rcw_src; + u8 sd1refclk_sel; + + puts("Board: LS1046ARDB, boot from "); + + cfg_rcw_src1 = CPLD_READ(cfg_rcw_src1); + cfg_rcw_src2 = CPLD_READ(cfg_rcw_src2); + cpld_rev_bit(&cfg_rcw_src1); + cfg_rcw_src = cfg_rcw_src1; + cfg_rcw_src = (cfg_rcw_src << 1) | cfg_rcw_src2; + + if (cfg_rcw_src == 0x44) + printf("QSPI vBank %d\n", CPLD_READ(vbank)); + else if (cfg_rcw_src == 0x40) + puts("SD\n"); + else + puts("Invalid setting of SW5\n"); + + printf("CPLD: V%x.%x\nPCBA: V%x.0\n", CPLD_READ(cpld_ver), + CPLD_READ(cpld_ver_sub), CPLD_READ(pcba_ver)); + + puts("SERDES Reference Clocks:\n"); + sd1refclk_sel = CPLD_READ(sd1refclk_sel); + printf("SD1_CLK1 = %s, SD1_CLK2 = %s\n", freq[sd1refclk_sel], freq[0]); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = initdram(0); + + return 0; +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +int board_init(void) +{ + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + +#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif + + /* invert AQR105 IRQ pins polarity */ + out_be32(&scfg->intpcr, AQR105_IRQ_MASK); + + return 0; +} + +void config_board_mux(void) +{ +#ifdef CONFIG_HAS_FSL_XHCI_USB + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; + + /* USB3 is not used, configure mux to IIC4_SCL/IIC4_SDA */ + out_be32(&scfg->rcwpmuxcr0, 0x3300); + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << + SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); +#endif +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + config_board_mux(); + return 0; +} +#endif + +int ft_board_setup(void *blob, bd_t *bd) +{ + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + /* fixup DT for the two DDR banks */ + base[0] = gd->bd->bi_dram[0].start; + size[0] = gd->bd->bi_dram[0].size; + base[1] = gd->bd->bi_dram[1].start; + size[1] = gd->bd->bi_dram[1].size; + + fdt_fixup_memory_banks(blob, base, size, 2); + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); +#endif + + return 0; +} diff --git a/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg b/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg new file mode 100644 index 0000000..5478217 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_pbi.cfg @@ -0,0 +1,22 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#Serdes SATA +09eb1300 80104e20 +09eb08dc 00502880 +#PEX gen3 link +09570158 00000300 +89400890 01048000 +89500890 01048000 +89600890 01048000 +#Alt base register +09570158 00001000 +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg b/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg new file mode 100644 index 0000000..6a5076e --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150010 0e000000 00000000 00000000 +11335559 40000012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003000 00000096 00000001 diff --git a/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg b/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg new file mode 100644 index 0000000..d5265b8 --- /dev/null +++ b/board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150010 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003101 00000096 00000001 diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig new file mode 100644 index 0000000..2daddf4 --- /dev/null +++ b/configs/ls1046ardb_emmc_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4,CONFIG_EMMC_BOOT" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig new file mode 100644 index 0000000..67ef3ce --- /dev/null +++ b/configs/ls1046ardb_qspi_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_QSPI=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig new file mode 100644 index 0000000..6272d75 --- /dev/null +++ b/configs/ls1046ardb_sdcard_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046ARDB=y +CONFIG_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_QSPI=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h new file mode 100644 index 0000000..9ee29b4 --- /dev/null +++ b/include/configs/ls1046a_common.h @@ -0,0 +1,175 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046A_COMMON_H +#define __LS1046A_COMMON_H + +#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE +#define CONFIG_FSL_LSCH2 +#define CONFIG_LS1046A +#define CONFIG_MP +#define CONFIG_SYS_FSL_CLK +#define CONFIG_GICV2 + +#include <asm/arch/config.h> +#ifdef CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_HAS_SERDES +#endif + +/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F 1 + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_SYS_DDR_BLOCK2_BASE 0x880000000ULL + +#define CPU_RELEASE_ADDR secondary_boot_func + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* SD boot SPL */ +#ifdef CONFIG_SD_BOOT +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT + +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x110 +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x500 +#define CONFIG_SPL_TEXT_BASE 0x10000000 +#define CONFIG_SPL_MAX_SIZE 0x1f000 /* 124 KiB */ +#define CONFIG_SPL_STACK 0x10020000 +#define CONFIG_SPL_PAD_TO 0x21000 /* 132 KiB */ +#define CONFIG_SPL_BSS_START_ADDR 0x8f000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SYS_MONITOR_LEN 0xa0000 +#endif + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_MXC_I2C2 +#define CONFIG_SYS_I2C_MXC_I2C3 +#define CONFIG_SYS_I2C_MXC_I2C4 + +/* Command line configuration */ +#define CONFIG_CMD_ENV + +/* MMC */ +#define CONFIG_MMC +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ + +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ + +/* FMan ucode */ +#define CONFIG_SYS_DPAA_FMAN +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_FM_MURAM_SIZE 0x60000 + +#ifdef CONFIG_SD_BOOT +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 1MB (2048 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080(0x820). + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) +#else +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_FMAN_FW_ADDR 0x40300000 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 1000000 +#define CONFIG_ENV_SPI_MODE 0x03 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) +#define CONFIG_ARCH_EARLY_INIT_R +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 128 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1000000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "console=ttyS0,115200\0" \ + MTDPARTS_DEFAULT "\0" + +#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ + "earlycon=uart8250,mmio,0x21c0500 " \ + MTDPARTS_DEFAULT +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +/* Hash command with SHA acceleration supported in hardware */ +#ifdef CONFIG_FSL_CAAM +#define CONFIG_CMD_HASH +#define CONFIG_SHA_HW_ACCEL +#endif + +#endif /* __LS1046A_COMMON_H */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h new file mode 100644 index 0000000..693cc8d --- /dev/null +++ b/include/configs/ls1046ardb.h @@ -0,0 +1,240 @@ +/* + * Copyright 2016 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1046ARDB_H__ +#define __LS1046ARDB_H__ + +#include "ls1046a_common.h" + +#if defined(CONFIG_FSL_LS_PPA) +#define CONFIG_ARMV8_PSCI +#define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT +#define CONFIG_SYS_LS_PPA_DRAM_BLOCK_MIN_SIZE (1UL * 1024 * 1024) + +#define CONFIG_SYS_LS_PPA_FW_IN_XIP +#ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP +#define CONFIG_SYS_LS_PPA_FW_ADDR 0x40500000 +#endif +#endif + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_TEXT_BASE 0x82000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x40100000 +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define CONFIG_LAYERSCAPE_NS_ACCESS +#define CONFIG_MISC_INIT_R + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_NR_DRAM_BANKS 2 + +#define CONFIG_DDR_SPD +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define CONFIG_FSL_DDR_BIST /* enable built-in memory test */ +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1046ardb/ls1046ardb_pbi.cfg +#endif + +#ifdef CONFIG_SD_BOOT +#ifdef CONFIG_EMMC_BOOT +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046ardb/ls1046ardb_rcw_emmc.cfg +#else +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1046ardb/ls1046ardb_rcw_sd.cfg +#endif +#endif + +/* No NOR flash */ +#define CONFIG_SYS_NO_FLASH + +/* IFC */ +#define CONFIG_FSL_IFC + +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_8 /* 8-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ + | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* + * CPLD + */ +#define CONFIG_SYS_CPLD_BASE 0x7fb00000 +#define CPLD_BASE_PHYS CONFIG_SYS_CPLD_BASE + +#define CONFIG_SYS_CPLD_CSPR_EXT (0x0) +#define CONFIG_SYS_CPLD_CSPR (CSPR_PHYS_ADDR(CPLD_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_CPLD_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_CPLD_CSOR CSOR_NOR_ADM_SHIFT(16) + +/* CPLD Timing parameters for IFC GPCM */ +#define CONFIG_SYS_CPLD_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CPLD_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CPLD_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define CONFIG_SYS_CPLD_FTIM3 0x0 + +/* IFC Timing Params */ +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_CPLD_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_CPLD_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_CPLD_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_CPLD_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_CPLD_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_CPLD_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_CPLD_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_CPLD_FTIM3 + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x53 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +#define I2C_RETIMER_ADDR 0x18 + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ +#endif + +/* FMan */ +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_AQUANTIA +#define AQR105_IRQ_MASK 0x80000000 + +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 + +#define SGMII_PHY1_ADDR 0x3 +#define SGMII_PHY2_ADDR 0x4 + +#define FM1_10GEC1_PHY_ADDR 0x0 + +#define CONFIG_ETHPRIME "FM1@DTSEC3" +#endif + +/* QSPI device */ +#ifdef CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SPI_FLASH_BAR +#endif + +/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SCSI +#define CONFIG_DOS_PARTITION +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read $kernel_load" \ + "$kernel_start $kernel_size;" \ + "bootm $kernel_load" + +#define MTDPARTS_DEFAULT "mtdparts=1550000.quadspi:1m(rcw)," \ + "15m(u-boot),48m(kernel.itb);" \ + "7e800000.flash:16m(nand_uboot)," \ + "48m(nand_kernel),448m(nand_free)" + +#endif /* __LS1046ARDB_H__ */
Gong Qianyu
