[PATCH u-boot-marvell] arm: mvebu: turris_omnia: Fix setting switch CONFIG pins on new board design
It seems that waiting only 10 ms after releasing LAN switch from reset is not enough for the strapping pins to latch the requested values. P6_MODE[0] is latched to 0 instead of 1.
Increasing the delay to 50 ms fixes this issue.
Signed-off-by: Marek Behún kabel@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index a7f96e5b77..19c5043fcb 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -654,7 +654,7 @@ static void initialize_switch(void) ctrl[1] = EXT_CTL_nRES_LAN; err = omnia_mcu_write(CMD_EXT_CONTROL, ctrl, sizeof(ctrl));
- mdelay(10); + mdelay(50);
/* Change RGMII pins back to RGMII mode */
- mdelay(10);
mdelay(50);
I forgot to add
Fixes: 1da53ae26afc ("arm: mvebu: turris_omnia: Add support for design with SW reset signals")
Thanks, Stefan
- mdelay(10);
mdelay(50);
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
- mdelay(10);
mdelay(50);
Marek Behún
Stefan Roese
