[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Here is the fist pull request from me for the v2016.11 development cycle.
The following UniPhier updates are included:
- DM migration * remove legacy xHCI driver * convert MMC driver to CONFIG_BLOCK - Pinctrl driver improvements * New pin-group * Macro cleanup - Misc fixes, cleanups * Fix DRAM size of LD21 SoC * Consolidate board init functions
Please pull!
The following changes since commit 8cbb389bb3da80cbf8911f8386cbff92c6a78afe:
Prepare v2016.09 (2016-09-12 10:05:51 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to c55b84c37654e4bf6118d7e37893fdc55f0565e3:
ARM: uniphier: introduce flags to adjust DRAM timing for LD20/LD21 (2016-09-14 22:54:20 +0900)
---------------------------------------------------------------- Masahiro Yamada (12): ARM: uniphier: sort select:s alphabetically usb: uniphier: remove UniPhier xHCI driver and select DM_USB ARM: uniphier: delete unnecessary xHCI pin-mux settings ARM: uniphier: enable Generic EHCI driver for Pro4 SoC mmc: uniphier-sd: migrate to CONFIG_BLK pinctrl: uniphier: add System Bus pin-mux settings pinctrl: uniphier: move register base macros from header to .c file ARM: uniphier: remove IECTRL setup code of LD4 SoC ARM: uniphier: use checkboard() instead of misc_init_f() ARM: uniphier: merge board init functions into board_init() ARM: uniphier: fix DRAM size of LD21 SoC package ARM: uniphier: introduce flags to adjust DRAM timing for LD20/LD21
arch/arm/Kconfig | 16 ++-- arch/arm/mach-uniphier/Makefile | 5 +- arch/arm/mach-uniphier/board_common.c | 20 ----- arch/arm/mach-uniphier/board_early_init_r.c | 15 ---- .../{board_early_init_f.c => board_init.c} | 16 +++- arch/arm/mach-uniphier/boards.c | 29 +++++++- arch/arm/mach-uniphier/init.h | 12 ++- arch/arm/mach-uniphier/micro-support-card.c | 2 +- arch/arm/mach-uniphier/micro-support-card.h | 16 ++-- arch/arm/mach-uniphier/pinctrl/pinctrl-ld20.c | 12 --- arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c | 6 -- arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c | 11 --- arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c | 7 -- arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c | 7 -- arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c | 11 --- arch/arm/mach-uniphier/print_misc_info.c | 12 --- configs/uniphier_ld4_sld8_defconfig | 1 - configs/uniphier_pro4_defconfig | 2 + configs/uniphier_sld3_defconfig | 1 - drivers/mmc/Kconfig | 1 + drivers/mmc/uniphier-sd.c | 50 ++++++------- drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 4 + drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 9 +++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 9 +++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 18 +++++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 21 ++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 30 ++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 30 ++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 9 +++ drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 21 ++++++ drivers/pinctrl/uniphier/pinctrl-uniphier.h | 4 - drivers/usb/host/Kconfig | 7 -- drivers/usb/host/Makefile | 1 - drivers/usb/host/xhci-uniphier.c | 85 ---------------------- include/configs/uniphier.h | 3 - include/fdtdec.h | 1 - lib/fdtdec.c | 1 - 37 files changed, 244 insertions(+), 261 deletions(-) delete mode 100644 arch/arm/mach-uniphier/board_common.c delete mode 100644 arch/arm/mach-uniphier/board_early_init_r.c rename arch/arm/mach-uniphier/{board_early_init_f.c => board_init.c} (88%) delete mode 100644 arch/arm/mach-uniphier/print_misc_info.c delete mode 100644 drivers/usb/host/xhci-uniphier.c
Hi Tom,
I found a bug in this series. If you have not pulled it in yet, I'd like to cancel it and do the 2nd round later.
Thanks,
2016-09-14 23:13 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Hi Tom,
- DM migration
- remove legacy xHCI driver
- convert MMC driver to CONFIG_BLOCK
- New pin-group
- Macro cleanup
- Fix DRAM size of LD21 SoC
- Consolidate board init functions
Please pull!
On Thu, Sep 15, 2016 at 05:40:52PM +0900, Masahiro Yamada wrote:
Hi Tom,
OK, thanks!
Thanks,
Hi Tom,
- DM migration
- New pin-group
- Macro cleanup
Please pull!
-- Best Regards Masahiro Yamada
Masahiro Yamada
