[U-Boot-Users] LZMA support
Hi people,
I have a stupid question: why does u-boot not support the LZMA algorithm?
(Anyway, I have a self-made and untested patch that introduces this compression algorithm).
Thanks a lot.
luigi
Industrie Dial Face S.p.A. Luigi Mantellini R&D - Software Industrie Dial Face S.p.A. Via Canzo, 4 20068 Peschiera Borromeo (MI), Italy Tel.: +39 02 5167 2813 Fax: +39 02 5167 2459 E-mail: luigi.mantellini@idf-hit.com GPG fingerprint: 3DD1 7B71 FBDF 6376 1B4A B003 175F E979 907E 1650
Hi everyone,
this patch adds the lzma support with the following constraints:
- it doesn't install the LZMA SDK files. I provide the import_lzma.sh script to import the needs file from a lzma sdk release - the imported lzma sdk files are _not touched_ - the lzma support is enabled defining the CONFIG_LZMA define - I haven't tested this patch - Use this patch at your own risk
The patch creates:
- the lib_lzma directory with the import_lzmasdk.sh script and a simple front-end to LzmaDecode() fuction - the include/lzma directory with some include files to use in the U-Boot code
modifies:
- common/do_bootm.c file - common/image.c file - include/image.h file
Please read the lib_lzma/README.txt file.
Luigi
On ven, 2008-03-28 at 16:42 +0100, Luigi 'Comio' Mantellini wrote:
Hi people,
Thanks a lot.
luigi
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi everyone,
The patch creates:
U-Boot code
modifies:
Luigi
Hi Luigi,
I have a stupid question in return: why do we want lzma (7zip) added to u-boot? The linux/uboot world is dominated by gzip. I realize 7zip has advantages over gzip albeit incremental, not revolutionary IIRC.
I am not aware of proposals or implementations of kernels compressed with lzma (could well be my ignorance). Adding more code for minimal benefits is a hard sell (we already have plenty of bloat :-O).
Best regards, gvb
On Fri, Mar 28, 2008 at 12:31 PM, Jerry Van Baren gerald.vanbaren@ge.com wrote:
Hi everyone,
The patch creates:
U-Boot code
modifies:
Luigi
Hi Luigi,
Best regards, gvb
Would be great if it's being used for squashfs-lzma support.
Thanks Donald
Hi Jerry,
see inline comments.
Hi everyone,
The patch creates:
U-Boot code
modifies:
Luigi
Hi Luigi,
LZMA usually performs better than gzip in terms compression ratio. My application has a small flash memory and I need to keep two (2) kernel images...
From these observations born my need to save as much memory as possible.
luigi
Best regards, gvb
Sorry, but I will not accept this.
U-Boot has always been self-contained, and I don't intend to change this.
Please make sure that a patch contains all files that belong to it.
Also, please explain what this new code is useful for. So far I don;t see any real-life use cases ?
Running the contained script the directory will be populated with all need files (LzmaTypes.h, LzmaDecode.*). Anyway, I can resubmit the patch including all files. The LZMA SDK is released under LGPL with exceptions but I don't understand if the license is compatible with the u-boot's license. For this reason I omitted the sources from the SDK.
LMZA performs better than LZ on binary files. I will switch to LZMA to save flash memory space on my appliance. Of course, the LZMA is slower than LZ.
Anyway, if the LZMA SDK license is compatible with U-boot , I think that LZMA should be chosen by firmware developer when the flash memory space is a critical resource.
My 2 Cents,
luigi
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "I like your game but we have to change the rules."
In message 5566.213.156.35.235.1206739577.webmail@webmail.idf-hit.com you wrote:
This makes no sense to me.
Either the license is compatible, and the code can be included, or it is not, then it cannot. In the latter case, the whole patch makes no sense.
Please check for compatibility of licenses berfore resubmitting.
But so far there is no code (board support) in U-Boot to use this feature, right? And it's not used by the Linux kernel either?
And your patch does not even enable support for it in the mkimage tool, so you cannot even create images that use the feature?
How exactly is this code supposed to be used?
Frankly, if you are so short with flash you have a h/w dsign problem.
I think there should be no problem from a license point of view.
The home page says that you can use unmodified source in your own code without having to release it to the public.
Since U-boot is open source to start with, this cannot be a problem.
It goes on and says that if the LZMA lib is modified, then the resulting code has to be released as open source. Again, no problem for U-boot, since it is open source to start with.
There are also commercial licenses available, but that is not applicable since noone signed a commerical license.
There are kernel patches for LZMA compression available. Can be selected at least in buildroot.
Maybe the patches for Linux creates an image??? Never saw any need to use it myself.
Frankly, if you are so short with flash you have a h/w design problem.
Lots of applications are cost sensitive, and shaving 50 cents here, 50 cents there could be important. Hard to judge without knowing the details.
Best Regards Ulf Samuelsson
Hi Wolfgang,
I'm not expert in legalese questions.
I think that the license is compatible (see the http://www.7-zip.org/sdk.html). I just share my code with community...
The code is used (eventually) by do_bootm routine to uncompress a lzma-ed kernel image. The patch provides the opportune image.c/cmd_bootm.c changes for this.
mkimage doesn't compress anything! As well as gzipped images, the lzma-ed images are created by an external tool (7z?): mkimage adds just a simple identification header to identify the used compression method. The proposed patch permits to mkimage to set the opportune compression type (id=3) in the uImage to recognize the lzma images.
The project constraints require a cheap flash memory to reduce the final cost (and prize) of the device. This is not a design problem...
luigi
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de core error - bus dumped
ive seen patches floating around to add lzma support akin to gzip/bzip2 in the uImage format. makes sense to me, and some people are very interested in shaving off flash space in return for slightly longer boot time. linux kernel is irrelevant here. someone else doing this means i dont have to at some point ;). -mike
Hi All,
I will rework the patch in order to include all files from LZMA SDK and some fix. I'll send the patch on Tuesday (I'm in vacation). These are the implemented features:
- LZMA SDK 4.57 Decode code (vanilla) - A Buff2Buff wrapper to decode the image (LZMA_Alone format) - Fixes for mkimage (option -C lzma) and do_bootm - small footprint and small impact on the u-boot sources.
To use the LZMA algorithm: just #define CONFIG_LZMA in your board config file.
Ciao.
luigi
On 21:21 Sat 29 Mar , Luigi 'Comio' Mantellini wrote:
Hi All,
Please update the README
Best Regards, J.
Hi Wolfgang, Luigi,
Given my expertise with license compliance, I volunteer to look into the legal issues, to the point that if I have any doubt I will consult with my legal counsel on that subject.
As for board support / LZMA: I don't know. But I'm pretty sure that I've seen LZMA compressed u-boot images before. LZMA is really popular with cheap consumer-grade embedded linux equipment, particularly DSL CPE and Wifi Routers. Most of them don't use u-boot, but only use it for the kernel image and the flash filesystem. They're using quite simple out-of-tree patches for that, though.
I think this has come up on lkml before, and Linus didn't like it very much. Probably related to the fact that many core kernel hackers look at embedded as sort of a special case, when in reality I am quite sure that the total quantity of embedded systems running Linux is significantly larger than the number of Linux servers + desktops together...
That has obviously to be fixed.
some documentation would certainly be fine, yes.
Yes and no. I tend to agree, but I also realize that there are economic incentives to keep the bom cost as low as possible, especially in large-quantity consumer equipment...
You can just as well claim: If you're using suboptimal compression and wasting flash space, you have a software design problem ;)
I think it makes a lot of sense to add LZMA support to u-boot, but obviously in a clean, consistent, documented way. It doesn't hurt, will not be compiled unless explicitly selected, and the API is zlib like, i.e. the code changes it requires are non-intrusive.
Just my thoughs...
-- - Harald Welte laforge@gnumonks.org http://laforge.gnumonks.org/ ============================================================================ "Privacy in residential applications is a desirable marketing option." (ETSI EN 300 175-7 Ch. A6)
participants (8)
Harald Welte
Hoi-Ho Chan
Jean-Christophe PLAGNIOL-VILLARD
Jerry Van Baren
Mike Frysinger
Ulf Samuelsson
