[U-Boot] Help Falcon Mode on Wanboard
Hi Stefano,
I downloaded the patch about Falcon Mode from:
https://www.amazon.com/clouddrive/share/hVlzRXoJv1Jq4DJdgDcVnfmOWjARqR06eCfh...
Then, as the README file says I did a checkout on commit 587c3f8ebe356b558f1876414885c1b4a31294ab and applied the patch.
$ git am 0001-wandboard-changes-for-EW-2016-demo.patch
I compiled without errors and then I've tried to upload to the SD card, by doing:
$ sudo dd if=SPL of=/dev/sdb bs=1k seek=1; sync
$ sudo dd if=u-boot.img of=/dev/sdb bs=1k seek=69; sync
But, everytime I try to turn on the board I got this error:
U-Boot 2016.01-rc4-26067-g0ff7f76 (Aug 08 2016 - 09:41:44 -0300)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR initcall sequence 178290cc failed at call 178038bd (err=394279101) ### ERROR ### Please RESET the board ###
I'm using wanboard quad rev: B1.
Does anybody know how to solve this?
Regards, Diego Dorta
Hi Diego,
On 08/08/2016 18:12, Diego Dorta wrote:
Hi Stefano,
It was quite a while ago, but the patch sets Falcon mode, and it tries to boot the kernel. Kernel is not in filesystem, but stored at a fixed address on the SD card (0x1000). The error you reported seems when U-Boot is starting - by pressing 'c' or if no kernel is stored.
I have to find back the wandboard I used to try a run...
Best regards, Stefano Babic
Hi Diego,
Hi Stefano,
Hi Stefano,
When I use your falcon mode pre-built image everything works fine, but when I try to replace to use the binaries I've compiled, the normal mode (pressing C) doesn't work and shows this error:
U-Boot 2016.01-rc4-26067-g04df0e7-dirty (Aug 12 2016 - 10:31:08 -0300)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR initcall sequence 178290d4 failed at call 178038bd (err=394279101) ### ERROR ### Please RESET the board ###
I use the following commands to copy the binaries:
$ sudo dd if=SPL of=/dev/sdb bs=1K seek=1 oflag=sync status=none && sync
$ sudo dd if=u-boot.img of=/dev/sdb bs=1K seek=69 oflag=sync status=none && sync
How can I understand this error message? Does anyone know how to fix it?
Hi Diego,
Hi Stefano,
This does not seem an issue when you write inot the SD card, else SPL is not started. But SPL works as expected and load correctly u-boot.img, that crashes.
I do not know if this makes a difference, but I check my logs and I have seen that I built with gcc 4.9.2 (Yocto-fido). This should not be an issue, but...
You should take a look at u-boot.map, and check the address where it happens. 0x00000000178290d4 should be init_sequence_f, you have to see in which function is 178038bd to make supposition.
For example, in my original u-boot.map (that I have still found on my PC), I see:
.text.initr_malloc 0x00000000178038a8 0x16 common/built-in.o .text.initr_caches 0x00000000178038be 0xa common/built-in.o
If binary was identical, it means a failure in initr_malloc. But your build is surely different and you have to find it.
Diego Dorta
Stefano Babic
