[U-Boot] [PATCH] tegra: colibri_t30: asix usb ethernet reset regression
Fix ASIX USB to Ethernet reset which due to the new driver model Tegra GPIO driver changes now requires a label string to be provided otherwise the reservation and subsequent direction/value calls will fail.
This fixes a regression introduced by commit:
2fccd2d96badcdf6165658a99771a4c475586279 tegra: Convert tegra GPIO driver to use driver model
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- board/toradex/colibri_t30/colibri_t30.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c index ed043f4..f4bc7d8 100644 --- a/board/toradex/colibri_t30/colibri_t30.c +++ b/board/toradex/colibri_t30/colibri_t30.c @@ -35,7 +35,7 @@ void pinmux_init(void) void pin_mux_usb(void) { /* Reset ASIX using LAN_RESET */ - gpio_request(GPIO_PDD0, NULL); + gpio_request(GPIO_PDD0, "LAN_RESET"); gpio_direction_output(GPIO_PDD0, 0); udelay(5); gpio_set_value(GPIO_PDD0, 1);
This limitation is removed by some pending patches (moving the request/free logic to the uclass). Even then this patch improves things.
-- 1.9.3
Marcel Ziswiler
