[U-Boot] [PATCH v2] ppc4xx: Add DLVision-10G board support
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- Replaces - 0001-ppc4xx-Add-DLVision-10G-board-support.patch - 0002-ppc4xx-Support-multiple-FPGAs.patch - 0003-ppc4xx-Support-dual-link-OSD.patch
Changes for v2: - define EBC register values through appropriate macros - fix condition for extension of struct global_data
Conversion to struct based register access will follow in a sperate patch.
MAINTAINERS | 1 + arch/powerpc/include/asm/global_data.h | 3 + board/gdsys/405ep/405ep.c | 64 ++++++-- board/gdsys/405ep/Makefile | 1 + board/gdsys/405ep/dlvision-10g.c | 243 +++++++++++++++++++++++++ board/gdsys/405ep/io.c | 8 +- board/gdsys/405ep/iocon.c | 14 +- board/gdsys/common/Makefile | 1 + board/gdsys/common/fpga.h | 16 ++- board/gdsys/common/osd.c | 303 ++++++++++++++++++++++++-------- board/gdsys/common/osd.h | 2 +- boards.cfg | 1 + include/configs/dlvision-10g.h | 261 +++++++++++++++++++++++++++ include/configs/io.h | 7 +- include/configs/iocon.h | 27 +++- 15 files changed, 846 insertions(+), 106 deletions(-) create mode 100644 board/gdsys/405ep/dlvision-10g.c create mode 100644 include/configs/dlvision-10g.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0590ad9..ea882c8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -142,6 +142,7 @@ Dirk Eibach eibach@gdsys.de
devconcenter PPC460EX dlvision PPC405EP + dlvision-10g PPC405EP gdppc440etx PPC440EP/GR intip PPC460EX io PPC405EP diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index 2e218de..fb7da21 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -172,6 +172,9 @@ typedef struct global_data { #if defined(CONFIG_LWMON) || defined(CONFIG_LWMON5) unsigned long kbd_status; #endif +#ifdef CONFIG_405EP + unsigned fpga_state[CONFIG_SYS_FPGA_COUNT]; +#endif #if defined(CONFIG_WD_MAX_RATE) unsigned long long wdt_last; /* trace watch-dog triggering rate */ #endif diff --git a/board/gdsys/405ep/405ep.c b/board/gdsys/405ep/405ep.c index d3bd233..84ea573 100644 --- a/board/gdsys/405ep/405ep.c +++ b/board/gdsys/405ep/405ep.c @@ -26,6 +26,7 @@ #include <asm/processor.h> #include <asm/io.h> #include <asm/ppc4xx-gpio.h> +#include <asm/global_data.h>
#include "../common/fpga.h"
@@ -36,8 +37,29 @@ #define REFLECTION_TESTPATTERN 0xdede #define REFLECTION_TESTPATTERN_INV (~REFLECTION_TESTPATTERN & 0xffff)
+DECLARE_GLOBAL_DATA_PTR; + +int get_fpga_state(unsigned dev) +{ + return gd->fpga_state[dev]; +} + +void print_fpga_state(unsigned dev) +{ + if (gd->fpga_state[dev] & FPGA_STATE_DONE_FAILED) + puts(" Waiting for FPGA-DONE timed out.\n"); + if (gd->fpga_state[dev] & FPGA_STATE_REFLECTION_FAILED) + puts(" FPGA reflection test failed.\n"); +} + int board_early_init_f(void) { + unsigned k; + unsigned ctr; + + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) + gd->fpga_state[k] = 0; + mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ mtdcr(UIC0ER, 0x00000000); /* disable all ints */ mtdcr(UIC0CR, 0x00000000); /* set all to be non-critical */ @@ -66,10 +88,18 @@ int board_early_init_f(void)
/* * wait for fpga-done - * fail ungraceful if fpga is not configuring properly */ - while (!(in_le16((void *)LATCH2_BASE) & 0x0010)) - ; + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) { + ctr = 0; + while (!(in_le16((void *)LATCH2_BASE) + & CONFIG_SYS_FPGA_DONE(k))) { + udelay(100000); + if (ctr++ > 5) { + gd->fpga_state[k] |= FPGA_STATE_DONE_FAILED; + break; + } + } + }
/* * setup io-latches for boot (stop reset) @@ -78,15 +108,25 @@ int board_early_init_f(void) out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT);
- /* - * wait for fpga out of reset - * fail ungraceful if fpga is not working properly - */ - while (1) { - fpga_set_reg(CONFIG_SYS_FPGA_RFL_LOW, REFLECTION_TESTPATTERN); - if (fpga_get_reg(CONFIG_SYS_FPGA_RFL_HIGH) == - REFLECTION_TESTPATTERN_INV) - break; + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) { + /* + * wait for fpga out of reset + * fail ungraceful if fpga is not working properly + */ + ctr = 0; + while (1) { + fpga_set_reg(k, CONFIG_SYS_FPGA_RFL_LOW, + REFLECTION_TESTPATTERN); + if (fpga_get_reg(k, CONFIG_SYS_FPGA_RFL_HIGH) == + REFLECTION_TESTPATTERN_INV) + break; + udelay(100000); + if (ctr++ > 5) { + gd->fpga_state[k] |= + FPGA_STATE_REFLECTION_FAILED; + break; + } + } }
return 0; diff --git a/board/gdsys/405ep/Makefile b/board/gdsys/405ep/Makefile index ed31207..169418c 100644 --- a/board/gdsys/405ep/Makefile +++ b/board/gdsys/405ep/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(BOARD).o
COBJS-$(CONFIG_IO) += io.o COBJS-$(CONFIG_IOCON) += iocon.o +COBJS-$(CONFIG_DLVISION_10G) += dlvision-10g.o
COBJS := $(BOARD).o $(COBJS-y) SOBJS = diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c new file mode 100644 index 0000000..740cceb --- /dev/null +++ b/board/gdsys/405ep/dlvision-10g.c @@ -0,0 +1,243 @@ +/* + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/ppc4xx-gpio.h> + +#include "../common/fpga.h" +#include "../common/osd.h" + +enum { + REG_VERSIONS = 0x0002, + REG_FPGA_VERSION = 0x0004, + REG_FPGA_FEATURES = 0x0006, +}; + +enum { + UNITTYPE_VIDEO_USER = 0, + UNITTYPE_MAIN_USER = 1, + UNITTYPE_VIDEO_SERVER = 2, + UNITTYPE_MAIN_SERVER = 3, +}; + +enum { + HWVER_101 = 0, + HWVER_110 = 1, +}; + +enum { + AUDIO_NONE = 0, + AUDIO_TX = 1, + AUDIO_RX = 2, + AUDIO_RXTX = 3, +}; + +enum { + SYSCLK_156250 = 2, +}; + +enum { + RAM_NONE = 0, + RAM_DDR2_32 = 1, + RAM_DDR2_64 = 2, +}; + +static void print_fpga_info(unsigned dev) +{ + u16 versions = fpga_get_reg(dev, REG_VERSIONS); + u16 fpga_version = fpga_get_reg(dev, REG_FPGA_VERSION); + u16 fpga_features = fpga_get_reg(dev, REG_FPGA_FEATURES); + unsigned unit_type; + unsigned hardware_version; + unsigned feature_compression; + unsigned feature_rs232; + unsigned feature_audio; + unsigned feature_sysclock; + unsigned feature_ramconfig; + unsigned feature_carrier_speed; + unsigned feature_carriers; + unsigned feature_video_channels; + int fpga_state = get_fpga_state(dev); + + printf("FPGA%d: ", dev); + + hardware_version = versions & 0x000f; + + if (fpga_state + && !((hardware_version == HWVER_101) + && (fpga_state == FPGA_STATE_DONE_FAILED))) { + puts("not available\n"); + print_fpga_state(dev); + return; + } + + unit_type = (versions >> 4) & 0x000f; + hardware_version = versions & 0x000f; + feature_compression = (fpga_features >> 13) & 0x0003; + feature_rs232 = fpga_features & (1<<11); + feature_audio = (fpga_features >> 9) & 0x0003; + feature_sysclock = (fpga_features >> 7) & 0x0003; + feature_ramconfig = (fpga_features >> 5) & 0x0003; + feature_carrier_speed = fpga_features & (1<<4); + feature_carriers = (fpga_features >> 2) & 0x0003; + feature_video_channels = fpga_features & 0x0003; + + switch (unit_type) { + case UNITTYPE_VIDEO_USER: + printf("Videochannel Userside"); + break; + + case UNITTYPE_MAIN_USER: + printf("Mainchannel Userside"); + break; + + case UNITTYPE_VIDEO_SERVER: + printf("Videochannel Serverside"); + break; + + case UNITTYPE_MAIN_SERVER: + printf("Mainchannel Serverside"); + break; + + default: + printf("UnitType %d(not supported)", unit_type); + break; + } + + switch (hardware_version) { + case HWVER_101: + printf(" HW-Ver 1.01\n"); + break; + + case HWVER_110: + printf(" HW-Ver 1.10\n"); + break; + + default: + printf(" HW-Ver %d(not supported)\n", + hardware_version); + break; + } + + printf(" FPGA V %d.%02d, features:", + fpga_version / 100, fpga_version % 100); + + printf(" %sRS232", feature_rs232 ? "" : "no "); + + switch (feature_audio) { + case AUDIO_NONE: + printf(", no audio"); + break; + + case AUDIO_TX: + printf(", audio tx"); + break; + + case AUDIO_RX: + printf(", audio rx"); + break; + + case AUDIO_RXTX: + printf(", audio rx+tx"); + break; + + default: + printf(", audio %d(not supported)", feature_audio); + break; + } + + switch (feature_sysclock) { + case SYSCLK_156250: + printf(", clock 156.25 MHz"); + break; + + default: + printf(", clock %d(not supported)", feature_sysclock); + break; + } + + puts(",\n "); + + switch (feature_ramconfig) { + case RAM_NONE: + printf("no RAM"); + break; + + case RAM_DDR2_32: + printf("RAM 32 bit DDR2"); + break; + + case RAM_DDR2_64: + printf("RAM 64 bit DDR2"); + break; + + default: + printf("RAM %d(not supported)", feature_ramconfig); + break; + } + + printf(", %d carrier(s) %s", feature_carriers, + feature_carrier_speed ? "10 Gbit/s" : "of unknown speed"); + + printf(", %d video channel(s)\n", feature_video_channels); +} + +/* + * Check Board Identity: + */ +int checkboard(void) +{ + unsigned k; + char *s = getenv("serial#"); + + printf("Board: "); + + printf("DLVision 10G"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + + puts("\n"); + + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) + print_fpga_info(k); + + return 0; +} + +int last_stage_init(void) +{ + unsigned k; + + for (k = 0; k < CONFIG_SYS_OSD_SCREENS; ++k) + if (!get_fpga_state(k) + || (get_fpga_state(k) == FPGA_STATE_DONE_FAILED)) + osd_probe(k); + + return 0; +} diff --git a/board/gdsys/405ep/io.c b/board/gdsys/405ep/io.c index 80877b6..b2c02bf 100644 --- a/board/gdsys/405ep/io.c +++ b/board/gdsys/405ep/io.c @@ -95,9 +95,9 @@ err_out: int checkboard(void) { char *s = getenv("serial#"); - u16 versions = fpga_get_reg(REG_VERSIONS); - u16 fpga_version = fpga_get_reg(REG_FPGA_VERSION); - u16 fpga_features = fpga_get_reg(REG_FPGA_FEATURES); + u16 versions = fpga_get_reg(0, REG_VERSIONS); + u16 fpga_version = fpga_get_reg(0, REG_FPGA_VERSION); + u16 fpga_features = fpga_get_reg(0, REG_FPGA_FEATURES); unsigned unit_type; unsigned hardware_version; unsigned feature_channels; @@ -175,7 +175,7 @@ int last_stage_init(void) configure_gbit_phy(k);
/* take fpga serdes blocks out of reset */ - fpga_set_reg(REG_QUAD_SERDES_RESET, 0); + fpga_set_reg(0, REG_QUAD_SERDES_RESET, 0);
return 0; } diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index ecd6cb2..d5196c1 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -75,9 +75,9 @@ enum { int checkboard(void) { char *s = getenv("serial#"); - u16 versions = fpga_get_reg(REG_VERSIONS); - u16 fpga_version = fpga_get_reg(REG_FPGA_VERSION); - u16 fpga_features = fpga_get_reg(REG_FPGA_FEATURES); + u16 versions = fpga_get_reg(0, REG_VERSIONS); + u16 fpga_version = fpga_get_reg(0, REG_FPGA_VERSION); + u16 fpga_features = fpga_get_reg(0, REG_FPGA_FEATURES); unsigned unit_type; unsigned hardware_version; unsigned feature_compression; @@ -214,7 +214,7 @@ int checkboard(void)
int last_stage_init(void) { - return osd_probe(); + return osd_probe(0); }
/* @@ -222,15 +222,15 @@ int last_stage_init(void) */ void fpga_gpio_set(int pin) { - out_le16((void *)(CONFIG_SYS_FPGA_BASE + 0x18), pin); + out_le16((void *)(CONFIG_SYS_FPGA0_BASE + 0x18), pin); }
void fpga_gpio_clear(int pin) { - out_le16((void *)(CONFIG_SYS_FPGA_BASE + 0x16), pin); + out_le16((void *)(CONFIG_SYS_FPGA0_BASE + 0x16), pin); }
int fpga_gpio_get(int pin) { - return in_le16((void *)(CONFIG_SYS_FPGA_BASE + 0x14)) & pin; + return in_le16((void *)(CONFIG_SYS_FPGA0_BASE + 0x14)) & pin; } diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 2257037..4c7fc99 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -31,6 +31,7 @@ LIB = $(obj)lib$(VENDOR).o
COBJS-$(CONFIG_IO) += miiphybb.o COBJS-$(CONFIG_IOCON) += osd.o +COBJS-$(CONFIG_DLVISION_10G) += osd.o
COBJS := $(COBJS-y) SOBJS = diff --git a/board/gdsys/common/fpga.h b/board/gdsys/common/fpga.h index c1434e7..29846b7 100644 --- a/board/gdsys/common/fpga.h +++ b/board/gdsys/common/fpga.h @@ -24,14 +24,22 @@ #ifndef _FPGA_H_ #define _FPGA_H_
-static inline u16 fpga_get_reg(unsigned reg) +enum { + FPGA_STATE_DONE_FAILED = 1 << 0, + FPGA_STATE_REFLECTION_FAILED = 1 << 1, +}; + +int get_fpga_state(unsigned dev); +void print_fpga_state(unsigned dev); + +static inline u16 fpga_get_reg(unsigned dev, unsigned reg) { - return in_le16((void *)(CONFIG_SYS_FPGA_BASE + reg)); + return in_le16((void *)(CONFIG_SYS_FPGA_BASE(dev) + reg)); }
-static inline void fpga_set_reg(unsigned reg, u16 val) +static inline void fpga_set_reg(unsigned dev, unsigned reg, u16 val) { - return out_le16((void *)(CONFIG_SYS_FPGA_BASE + reg), val); + return out_le16((void *)(CONFIG_SYS_FPGA_BASE(dev) + reg), val); }
#endif diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 239c870..9968dbf 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -29,6 +29,12 @@
#define CH7301_I2C_ADDR 0x75
+#define ICS8N3QV01_I2C_ADDR 0x6E +#define ICS8N3QV01_FREF 114285 + +#define SIL1178_MASTER_I2C_ADDRESS 0x38 +#define SIL1178_SLAVE_I2C_ADDRESS 0x39 + #define PIXCLK_640_480_60 25180000
#define BASE_WIDTH 32 @@ -38,12 +44,18 @@ enum { REG_CONTROL = 0x0010, REG_MPC3W_CONTROL = 0x001a, + REG_EXT_INTERRUPT = 0x001c, + REG_EXT_INTERRUPT_ENABLE = 0x001e, + REG_IIC_WRITE_MAILBOX = 0x0030, + REG_IIC_WRITE_MAILBOX_EXT = 0x0032, + REG_IIC_READ_MAILBOX = 0x0034, + REG_IIC_READ_MAILBOX_EXT = 0x0036, REG_VIDEOCONTROL = 0x0042, - REG_OSDVERSION = 0x0100, - REG_OSDFEATURES = 0x0102, - REG_OSDCONTROL = 0x0104, - REG_XY_SIZE = 0x0106, - REG_VIDEOMEM = 0x0800, + REG_OSDVERSION = CONFIG_SYS_FPGA_OSD_BASE + 0x0000, + REG_OSDFEATURES = CONFIG_SYS_FPGA_OSD_BASE + 0x0002, + REG_OSDCONTROL = CONFIG_SYS_FPGA_OSD_BASE + 0x0004, + REG_XY_SIZE = CONFIG_SYS_FPGA_OSD_BASE + 0x0006, + REG_VIDEOMEM = CONFIG_SYS_FPGA_OSD_MEM, };
enum { @@ -67,6 +79,37 @@ enum { CH7301_DSP = 0x56, /* DVI Sync polarity Register */ };
+#if defined(CONFIG_SYS_ICS8N3QV01) || defined(CONFIG_SYS_SIL1178) +static void fpga_iic_write(unsigned screen, u8 slave, u8 reg, u8 data) +{ + while (fpga_get_reg(screen, REG_EXT_INTERRUPT) & (1 << 12)) + ; + fpga_set_reg(screen, REG_IIC_WRITE_MAILBOX_EXT, + reg | (data << 8)); + fpga_set_reg(screen, REG_IIC_WRITE_MAILBOX, + 0xc400 | (slave << 1)); +} + +static u8 fpga_iic_read(unsigned screen, u8 slave, u8 reg) +{ + unsigned int ctr = 0; + while (fpga_get_reg(screen, REG_EXT_INTERRUPT) & (1 << 12)) + ; + fpga_set_reg(screen, REG_EXT_INTERRUPT, 1 << 14); + fpga_set_reg(screen, REG_IIC_WRITE_MAILBOX_EXT, reg); + fpga_set_reg(screen, REG_IIC_WRITE_MAILBOX, 0xc000 | (slave << 1)); + while (!(fpga_get_reg(screen, REG_EXT_INTERRUPT) & (1 << 14))) { + udelay(100000); + if (ctr++ > 5) { + printf("iic receive timeout\n"); + break; + } + } + return fpga_get_reg(screen, REG_IIC_READ_MAILBOX_EXT) >> 8; +} +#endif + +#ifdef CONFIG_SYS_MPC92469AC static void mpc92469ac_calc_parameters(unsigned int fout, unsigned int *post_div, unsigned int *feedback_div) { @@ -92,7 +135,7 @@ static void mpc92469ac_calc_parameters(unsigned int fout, *feedback_div = m; }
-static void mpc92469ac_set(unsigned int fout) +static void mpc92469ac_set(unsigned screen, unsigned int fout) { unsigned int n; unsigned int m; @@ -114,17 +157,83 @@ static void mpc92469ac_set(unsigned int fout) break; }
- fpga_set_reg(REG_MPC3W_CONTROL, (bitval << 9) | m); + fpga_set_reg(screen, REG_MPC3W_CONTROL, (bitval << 9) | m); } +#endif
-static int osd_write_videomem(unsigned offset, u16 *data, size_t charcount) +#ifdef CONFIG_SYS_ICS8N3QV01 +static void ics8n3qv01_calc_parameters(unsigned int fout, + unsigned int *_mint, unsigned int *_mfrac, + unsigned int *_n) +{ + unsigned int n; + unsigned int foutiic; + unsigned int fvcoiic; + unsigned int mint; + unsigned long long mfrac; + + n = 2550000000U / fout; + if ((n & 1) && (n > 5)) + n -= 1; + + foutiic = fout - (fout / 10000); + fvcoiic = foutiic * n; + + mint = fvcoiic / 114285000; + if ((mint < 17) || (mint > 63)) + printf("ics8n3qv01_calc_parameters: cannot determine mint\n"); + + mfrac = ((unsigned long long)fvcoiic % 114285000LL) * 262144LL + / 114285000LL; + + *_mint = mint; + *_mfrac = mfrac; + *_n = n; +} + +static void ics8n3qv01_set(unsigned screen, unsigned int fout) +{ + unsigned int n; + unsigned int mint; + unsigned int mfrac; + u8 reg0, reg4, reg8, reg12, reg18, reg20; + + ics8n3qv01_calc_parameters(fout, &mint, &mfrac, &n); + + reg0 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 0) & 0xc0; + reg0 |= (mint & 0x1f) << 1; + reg0 |= (mfrac >> 17) & 0x01; + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 0, reg0); + + reg4 = mfrac >> 9; + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 4, reg4); + + reg8 = mfrac >> 1; + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 8, reg8); + + reg12 = mfrac << 7; + reg12 |= n & 0x7f; + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 12, reg12); + + reg18 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 18) & 0x03; + reg18 |= 0x20; + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 18, reg18); + + reg20 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 20) & 0x1f; + reg20 |= mint & (1 << 5); + fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 20, reg20); +} +#endif + +static int osd_write_videomem(unsigned screen, unsigned offset, + u16 *data, size_t charcount) { unsigned int k;
for (k = 0; k < charcount; ++k) { if (offset + k >= BUFSIZE) return -1; - fpga_set_reg(REG_VIDEOMEM + 2 * (offset + k), data[k]); + fpga_set_reg(screen, REG_VIDEOMEM + 2 * (offset + k), data[k]); }
return charcount; @@ -132,46 +241,57 @@ static int osd_write_videomem(unsigned offset, u16 *data, size_t charcount)
static int osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - unsigned x; - unsigned y; - unsigned charcount; - unsigned len; - u8 color; - unsigned int k; - u16 buf[BUFSIZE]; - char *text; - - if (argc < 5) { - return cmd_usage(cmdtp); + unsigned screen; + + for (screen = 0; screen < CONFIG_SYS_OSD_SCREENS; ++screen) { + unsigned x; + unsigned y; + unsigned charcount; + unsigned len; + u8 color; + unsigned int k; + u16 buf[BUFSIZE]; + char *text; + int res; + + if (argc < 5) { + cmd_usage(cmdtp); + return 1; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + color = simple_strtoul(argv[3], NULL, 16); + text = argv[4]; + charcount = strlen(text); + len = (charcount > BUFSIZE) ? BUFSIZE : charcount; + + for (k = 0; k < len; ++k) + buf[k] = (text[k] << 8) | color; + + res = osd_write_videomem(screen, y * BASE_WIDTH + x, buf, len); + if (res < 0) + return res; }
- x = simple_strtoul(argv[1], NULL, 16); - y = simple_strtoul(argv[2], NULL, 16); - color = simple_strtoul(argv[3], NULL, 16); - text = argv[4]; - charcount = strlen(text); - len = (charcount > BUFSIZE) ? BUFSIZE : charcount; - - for (k = 0; k < len; ++k) - buf[k] = (text[k] << 8) | color; - - return osd_write_videomem(y * BASE_WIDTH + x, buf, len); + return 0; }
-int osd_probe(void) +int osd_probe(unsigned screen) { - u8 value; - u16 version = fpga_get_reg(REG_OSDVERSION); - u16 features = fpga_get_reg(REG_OSDFEATURES); + u16 version = fpga_get_reg(screen, REG_OSDVERSION); + u16 features = fpga_get_reg(screen, REG_OSDFEATURES); unsigned width; unsigned height; + u8 value;
width = ((features & 0x3f00) >> 8) + 1; height = (features & 0x001f) + 1;
- printf("OSD: Digital-OSD version %01d.%02d, %d" "x%d characters\n", - version/100, version%100, width, height); + printf("OSD%d: Digital-OSD version %01d.%02d, %d" "x%d characters\n", + screen, version/100, version%100, width, height);
+#ifdef CONFIG_SYS_CH7301 value = i2c_reg_read(CH7301_I2C_ADDR, CH7301_DID); if (value != 0x17) { printf(" Probing CH7301 failed, DID %02x\n", value); @@ -182,51 +302,86 @@ int osd_probe(void) i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); +#endif
- mpc92469ac_set(PIXCLK_640_480_60); - fpga_set_reg(REG_VIDEOCONTROL, 0x0002); - fpga_set_reg(REG_OSDCONTROL, 0x0049); +#ifdef CONFIG_SYS_MPC92469AC + mpc92469ac_set(screen, PIXCLK_640_480_60); +#endif
- fpga_set_reg(REG_XY_SIZE, ((32 - 1) << 8) | (16 - 1)); +#ifdef CONFIG_SYS_ICS8N3QV01 + ics8n3qv01_set(screen, PIXCLK_640_480_60); +#endif + +#ifdef CONFIG_SYS_SIL1178 + value = fpga_iic_read(screen, SIL1178_SLAVE_I2C_ADDRESS, 0x02); + if (value != 0x06) { + printf(" Probing CH7301 SIL1178, DEV_IDL %02x\n", value); + return -1; + } + /* magic initialization sequence adapted from datasheet */ + fpga_iic_write(screen, SIL1178_SLAVE_I2C_ADDRESS, 0x08, 0x36); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x44); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x4c); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0e, 0x10); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0a, 0x80); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x09, 0x30); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0c, 0x89); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0d, 0x60); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x36); + fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x37); +#endif + + fpga_set_reg(screen, REG_VIDEOCONTROL, 0x0002); + fpga_set_reg(screen, REG_OSDCONTROL, 0x0049); + + fpga_set_reg(screen, REG_XY_SIZE, ((32 - 1) << 8) | (16 - 1));
return 0; }
int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - unsigned x; - unsigned y; - unsigned k; - u16 buffer[BASE_WIDTH]; - char *rp; - u16 *wp = buffer; - unsigned count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1; - - if ((argc < 4) || (strlen(argv[3]) % 4)) { - return cmd_usage(cmdtp); - } - - x = simple_strtoul(argv[1], NULL, 16); - y = simple_strtoul(argv[2], NULL, 16); - rp = argv[3]; - - - while (*rp) { - char substr[5]; - - memcpy(substr, rp, 4); - substr[4] = 0; - *wp = simple_strtoul(substr, NULL, 16); - - rp += 4; - wp++; - if (wp - buffer > BASE_WIDTH) - break; - } - - for (k = 0; k < count; ++k) { - unsigned offset = y * BASE_WIDTH + x + k * (wp - buffer); - osd_write_videomem(offset, buffer, wp - buffer); + unsigned screen; + + for (screen = 0; screen < CONFIG_SYS_OSD_SCREENS; ++screen) { + unsigned x; + unsigned y; + unsigned k; + u16 buffer[BASE_WIDTH]; + char *rp; + u16 *wp = buffer; + unsigned count = (argc > 4) ? + simple_strtoul(argv[4], NULL, 16) : 1; + + if ((argc < 4) || (strlen(argv[3]) % 4)) { + cmd_usage(cmdtp); + return 1; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + rp = argv[3]; + + + while (*rp) { + char substr[5]; + + memcpy(substr, rp, 4); + substr[4] = 0; + *wp = simple_strtoul(substr, NULL, 16); + + rp += 4; + wp++; + if (wp - buffer > BASE_WIDTH) + break; + } + + for (k = 0; k < count; ++k) { + unsigned offset = + y * BASE_WIDTH + x + k * (wp - buffer); + osd_write_videomem(screen, offset, buffer, + wp - buffer); + } }
return 0; diff --git a/board/gdsys/common/osd.h b/board/gdsys/common/osd.h index 4431cbc..c59d9c3 100644 --- a/board/gdsys/common/osd.h +++ b/board/gdsys/common/osd.h @@ -24,6 +24,6 @@ #ifndef _OSD_H_ #define _OSD_H_
-int osd_probe(void); +int osd_probe(unsigned screen);
#endif diff --git a/boards.cfg b/boards.cfg index dcd5a12..4a40685 100644 --- a/boards.cfg +++ b/boards.cfg @@ -713,6 +713,7 @@ VOM405 powerpc ppc4xx vom405 esd WUH405 powerpc ppc4xx wuh405 esd devconcenter powerpc ppc4xx intip gdsys - intip:DEVCONCENTER dlvision powerpc ppc4xx - gdsys +dlvision-10g powerpc ppc4xx 405ep gdsys gdppc440etx powerpc ppc4xx - gdsys intip powerpc ppc4xx intip gdsys - intip:INTIB io powerpc ppc4xx 405ep gdsys diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h new file mode 100644 index 0000000..64da23d --- /dev/null +++ b/include/configs/dlvision-10g.h @@ -0,0 +1,261 @@ +/* + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_405EP 1 /* this is a PPC405 CPU */ +#define CONFIG_4xx 1 /* member of PPC4xx family */ +#define CONFIG_DLVISION_10G 1 /* on a DLVision-10G board */ + +#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 + +/* + * Include common defines/options for all AMCC eval boards + */ +#define CONFIG_HOSTNAME dlvsion-10g +#define CONFIG_IDENT_STRING " dlvision-10g 0.01" +#include "amcc-common.h" + +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ +#define CONFIG_LAST_STAGE_INIT + +#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ + +/* + * Configure PLL + */ +#define PLLMR0_DEFAULT PLLMR0_266_133_66 +#define PLLMR1_DEFAULT PLLMR1_266_133_66 + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +#define CONFIG_ENV_IS_IN_FLASH /* use FLASH for environment vars */ + +/* + * Default environment variables + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_AMCC_DEF_ENV \ + CONFIG_AMCC_DEF_ENV_POWERPC \ + CONFIG_AMCC_DEF_ENV_NOR_UPD \ + "kernel_addr=fc000000\0" \ + "fdt_addr=fc1e0000\0" \ + "ramdisk_addr=fc200000\0" \ + "" + +#define CONFIG_PHY_ADDR 4 /* PHY address */ +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 +#define CONFIG_PHY1_ADDR 0xc /* EMAC1 PHY address */ +#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ + +/* + * Commands additional to the ones defined in amcc-common.h + */ +#define CONFIG_CMD_CACHE +#undef CONFIG_CMD_EEPROM + +/* + * SDRAM configuration (please see cpu/ppc/sdram.[ch]) + */ +#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ + +/* SDRAM timings used in datasheet */ +#define CONFIG_SYS_SDRAM_CL 3 /* CAS latency */ +#define CONFIG_SYS_SDRAM_tRP 20 /* PRECHARGE command period */ +#define CONFIG_SYS_SDRAM_tRC 66 /* ACTIVE-to-ACTIVE period */ +#define CONFIG_SYS_SDRAM_tRCD 20 /* ACTIVE-to-READ delay */ +#define CONFIG_SYS_SDRAM_tRFC 66 /* Auto refresh period */ + +/* + * If CONFIG_SYS_EXT_SERIAL_CLOCK, then the UART divisor is 1. + * If CONFIG_SYS_405_UART_ERRATA_59, then UART divisor is 31. + * Otherwise, UART divisor is determined by CPU Clock and CONFIG_SYS_BASE_BAUD. + * The Linux BASE_BAUD define should match this configuration. + * baseBaud = cpuClock/(uartDivisor*16) + * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, + * set Linux BASE_BAUD to 403200. + */ +#define CONFIG_CONS_INDEX 1 /* Use UART0 */ +#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ +#undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ +#define CONFIG_SYS_BASE_BAUD 691200 + +/* + * I2C stuff + */ +#define CONFIG_SYS_I2C_SPEED 100000 + +/* Temp sensor/hwmon/dtt */ +#define CONFIG_DTT_LM63 1 /* National LM63 */ +#define CONFIG_DTT_SENSORS { 0 } /* Sensor addresses */ +#define CONFIG_DTT_PWM_LOOKUPTABLE \ + { { 40, 10 }, { 50, 20 }, { 60, 40 } } +#define CONFIG_DTT_TACH_LIMIT 0xa10 + +/* + * FLASH organization + */ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ +#define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CONFIG_SYS_FLASH_BASE 0xFC000000 +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sectors per chip*/ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase/ms */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write/ms */ + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buff'd writes */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* use hardware flash protect */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO /* 'E' for empty sector on flinfo */ +#define CONFIG_SYS_FLASH_QUIET_TEST 1 /* no warn upon unknown flash */ + +#ifdef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#endif + +/* + * PPC405 GPIO Configuration + */ +#define CONFIG_SYS_4xx_GPIO_TABLE { /* GPIO Alternate1 */ \ +{ \ +/* GPIO Core 0 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO0 PerBLast */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO1 TS1E */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO2 TS2E */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO3 TS1O */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO4 TS2O */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_1 }, /* GPIO5 TS3 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO6 TS4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_1 }, /* GPIO7 TS5 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO8 TS6 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO9 TrcClk */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO10 PerCS1 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO11 PerCS2 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO12 PerCS3 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO13 PerCS4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO14 PerAddr03 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO15 PerAddr04 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO16 PerAddr05 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO17 IRQ0 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO18 IRQ1 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO19 IRQ2 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO20 IRQ3 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO21 IRQ4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO22 IRQ5 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO23 IRQ6 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO24 UART0_DCD */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO25 UART0_DSR */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO26 UART0_RI */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO27 UART0_DTR */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO28 UART1_Rx */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO29 UART1_Tx */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO30 RejectPkt0 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO31 RejectPkt1 */ \ +} \ +} + +/* + * Definitions for initial stack pointer and data area (in data cache) + */ +/* use on chip memory (OCM) for temperary stack until sdram is tested */ +#define CONFIG_SYS_TEMP_STACK_OCM 1 + +/* On Chip Memory location */ +#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 +#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ +#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */ + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size/bytes res'd for init data*/ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* + * External Bus Controller (EBC) Setup + */ + +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CONFIG_SYS_EBC_PB0AP 0xa382a880 +/* BAS=0xFC0,BS=64MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB0CR 0xFC0DA000 + +/* Memory Bank 1 (FPGA0) initialization */ +#define CONFIG_SYS_FPGA0_BASE 0x7f100000 +#define CONFIG_SYS_EBC_PB1AP 0x02825080 +/* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB1CR 0x7f11a000 + +/* Memory Bank 2 (FPGA1) initialization */ +#define CONFIG_SYS_FPGA1_BASE 0x7f200000 +#define CONFIG_SYS_EBC_PB2AP 0x03025080 +/* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB2CR 0x7f21a000 + +#define CONFIG_SYS_FPGA_BASE(k) \ + (k ? CONFIG_SYS_FPGA1_BASE : CONFIG_SYS_FPGA0_BASE) + +#define CONFIG_SYS_FPGA_DONE(k) \ + (k ? 0x2000 : 0x10000) + +#define CONFIG_SYS_FPGA_RFL_LOW 0x0000 +#define CONFIG_SYS_FPGA_RFL_HIGH 0x007e + +#define CONFIG_SYS_FPGA_OSD_BASE 0x0200 +#define CONFIG_SYS_FPGA_OSD_MEM 0x0800 + +#define CONFIG_SYS_FPGA_COUNT 2 + +/* Memory Bank 3 (Latches) initialization */ +#define CONFIG_SYS_LATCH_BASE 0x7f300000 +#define CONFIG_SYS_EBC_PB3AP 0xa2015480 +/* BAS=0x7f2,BS=1MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB3CR 0x7f31a000 + +#define CONFIG_SYS_LATCH0_RESET 0xffff +#define CONFIG_SYS_LATCH0_BOOT 0xffff +#define CONFIG_SYS_LATCH1_RESET 0xffcf +#define CONFIG_SYS_LATCH1_BOOT 0xffff + +/* + * OSD Setup + */ +#define CONFIG_SYS_ICS8N3QV01 +#define CONFIG_SYS_SIL1178 +#define CONFIG_SYS_OSD_SCREENS CONFIG_SYS_FPGA_COUNT + +#endif /* __CONFIG_H */ diff --git a/include/configs/io.h b/include/configs/io.h index a66c704..e287ad9 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -229,14 +229,19 @@ #define CONFIG_SYS_EBC_PB1CR 0x7f318000
/* Memory Bank 2 (FPGA) initialization */ -#define CONFIG_SYS_FPGA_BASE 0x7f100000 +#define CONFIG_SYS_FPGA0_BASE 0x7f100000 #define CONFIG_SYS_EBC_PB2AP 0x02025080 /* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */ #define CONFIG_SYS_EBC_PB2CR 0x7f11a000
+#define CONFIG_SYS_FPGA_BASE(k) CONFIG_SYS_FPGA0_BASE +#define CONFIG_SYS_FPGA_DONE(k) 0x0010 + #define CONFIG_SYS_FPGA_RFL_LOW 0x0000 #define CONFIG_SYS_FPGA_RFL_HIGH 0x3ffe
+#define CONFIG_SYS_FPGA_COUNT 1 + /* Memory Bank 3 (Latches) initialization */ #define CONFIG_SYS_LATCH_BASE 0x7f200000 #define CONFIG_SYS_EBC_PB3AP 0xa2015480 diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 5e61b11..c713915 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -131,6 +131,12 @@ int fpga_gpio_get(int pin); #define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */
/* + * OSD hardware + */ +#define CONFIG_SYS_MPC92469AC +#define CONFIG_SYS_CH7301 + +/* * FLASH organization */ #define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ @@ -231,14 +237,22 @@ int fpga_gpio_get(int pin); #define CONFIG_SYS_EBC_PB1AP 0x92015480 #define CONFIG_SYS_EBC_PB1CR 0xFB858000
-/* Memory Bank 2 (FPGA) initialization */ -#define CONFIG_SYS_FPGA_BASE 0x7f100000 +/* Memory Bank 2 (FPGA0) initialization */ +#define CONFIG_SYS_FPGA0_BASE 0x7f100000 #define CONFIG_SYS_EBC_PB2AP 0x02825080 -#define CONFIG_SYS_EBC_PB2CR (CONFIG_SYS_FPGA_BASE | 0x1a000) +#define CONFIG_SYS_EBC_PB2CR (CONFIG_SYS_FPGA0_BASE | 0x1a000) + +#define CONFIG_SYS_FPGA_BASE(k) CONFIG_SYS_FPGA0_BASE +#define CONFIG_SYS_FPGA_DONE(k) 0x0010
#define CONFIG_SYS_FPGA_RFL_LOW 0x0000 #define CONFIG_SYS_FPGA_RFL_HIGH 0x00fe
+#define CONFIG_SYS_FPGA_OSD_BASE 0x0100 +#define CONFIG_SYS_FPGA_OSD_MEM 0x0800 + +#define CONFIG_SYS_FPGA_COUNT 1 + /* Memory Bank 3 (Latches) initialization */ #define CONFIG_SYS_LATCH_BASE 0x7f200000 #define CONFIG_SYS_EBC_PB3AP 0x02025080 @@ -249,4 +263,11 @@ int fpga_gpio_get(int pin); #define CONFIG_SYS_LATCH1_RESET 0xffff #define CONFIG_SYS_LATCH1_BOOT 0xffff
+/* + * OSD Setup + */ +#define CONFIG_SYS_MPC92469AC +#define CONFIG_SYS_CH7301 +#define CONFIG_SYS_OSD_SCREENS CONFIG_SYS_FPGA_COUNT + #endif /* __CONFIG_H */
Dirk Eibach
