[PATCH 1/3] dt-bindings: nvmem: u-boot, env: add MAC's #nvmem-cell-cells
U-Boot's "ethaddr" environment variable is very often used to store *base* MAC address. It's used as a base for calculating addresses for multiple interfaces. It's done by adding proper values. Actual offsets are picked by manufacturers and vary across devices.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- Documentation/devicetree/bindings/nvmem/u-boot,env.yaml | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml index cbc5c69fd405..1c139bd689ea 100644 --- a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +++ b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml @@ -50,7 +50,11 @@ properties:
ethaddr: type: object - description: Ethernet interface's MAC address + description: + Ethernet interfaces base MAC address. The first argument is an offset. + properties: + "#nvmem-cell-cells": + const: 1
additionalProperties: false
@@ -72,6 +76,7 @@ examples: reg = <0x40000 0x10000>;
mac: ethaddr { + #nvmem-cell-cells = <1>; }; }; };
Sometimes reading NVMEM cell value involves some data reformatting. It requires passing updated size value to the caller. Support that.
It's required e.g. to provide properly formatted MAC address in case it's stored in a non-binary format (e.g. using ASCII).
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/nvmem/core.c | 5 +++-- drivers/nvmem/imx-ocotp.c | 6 +++--- drivers/nvmem/layouts/onie-tlv.c | 2 +- drivers/nvmem/layouts/sl28vpd.c | 4 ++-- include/linux/nvmem-provider.h | 2 +- 5 files changed, 10 insertions(+), 9 deletions(-)
diff --git a/drivers/nvmem/core.c b/drivers/nvmem/core.c index 1b61c8bf0de4..1daf5a1d3ec7 100644 --- a/drivers/nvmem/core.c +++ b/drivers/nvmem/core.c @@ -1537,6 +1537,7 @@ static int __nvmem_cell_read(struct nvmem_device *nvmem, struct nvmem_cell_entry *cell, void *buf, size_t *len, const char *id, int index) { + size_t bytes = cell->bytes; int rc;
rc = nvmem_reg_read(nvmem, cell->offset, buf, cell->bytes); @@ -1550,13 +1551,13 @@ static int __nvmem_cell_read(struct nvmem_device *nvmem,
if (cell->read_post_process) { rc = cell->read_post_process(cell->priv, id, index, - cell->offset, buf, cell->bytes); + cell->offset, buf, &bytes); if (rc) return rc; }
if (len) - *len = cell->bytes; + *len = bytes;
return 0; } diff --git a/drivers/nvmem/imx-ocotp.c b/drivers/nvmem/imx-ocotp.c index ac0edb6398f1..ebd0e9e0314e 100644 --- a/drivers/nvmem/imx-ocotp.c +++ b/drivers/nvmem/imx-ocotp.c @@ -223,15 +223,15 @@ static int imx_ocotp_read(void *context, unsigned int offset, }
static int imx_ocotp_cell_pp(void *context, const char *id, int index, - unsigned int offset, void *data, size_t bytes) + unsigned int offset, void *data, size_t *bytes) { u8 *buf = data; int i;
/* Deal with some post processing of nvmem cell data */ if (id && !strcmp(id, "mac-address")) - for (i = 0; i < bytes / 2; i++) - swap(buf[i], buf[bytes - i - 1]); + for (i = 0; i < *bytes / 2; i++) + swap(buf[i], buf[*bytes - i - 1]);
return 0; } diff --git a/drivers/nvmem/layouts/onie-tlv.c b/drivers/nvmem/layouts/onie-tlv.c index 074c7c700845..2cb7112229ba 100644 --- a/drivers/nvmem/layouts/onie-tlv.c +++ b/drivers/nvmem/layouts/onie-tlv.c @@ -76,7 +76,7 @@ static const char *onie_tlv_cell_name(u8 type)
static int onie_tlv_mac_read_cb(void *priv, const char *id, int index, unsigned int offset, void *buf, - size_t bytes) + size_t *bytes) { eth_addr_add(buf, index);
diff --git a/drivers/nvmem/layouts/sl28vpd.c b/drivers/nvmem/layouts/sl28vpd.c index a36800f201a3..63c0da58ad60 100644 --- a/drivers/nvmem/layouts/sl28vpd.c +++ b/drivers/nvmem/layouts/sl28vpd.c @@ -23,9 +23,9 @@ struct sl28vpd_v1 {
static int sl28vpd_mac_address_pp(void *priv, const char *id, int index, unsigned int offset, void *buf, - size_t bytes) + size_t *bytes) { - if (bytes != ETH_ALEN) + if (*bytes != ETH_ALEN) return -EINVAL;
if (index < 0) diff --git a/include/linux/nvmem-provider.h b/include/linux/nvmem-provider.h index 0cf9f9490514..5d896eec2f1c 100644 --- a/include/linux/nvmem-provider.h +++ b/include/linux/nvmem-provider.h @@ -21,7 +21,7 @@ typedef int (*nvmem_reg_write_t)(void *priv, unsigned int offset, /* used for vendor specific post processing of cell data */ typedef int (*nvmem_cell_post_process_t)(void *priv, const char *id, int index, unsigned int offset, void *buf, - size_t bytes); + size_t *bytes);
enum nvmem_type { NVMEM_TYPE_UNKNOWN = 0,
Am 2023-01-05 18:10, schrieb Rafał Miłecki:
Wouldn't it make more sense to convert that driver to proper nvmem layouts, where (1) you get that for free, (2) support others storages than just mtd (3) don't duplicate the mtd read code
-michael
U-Boot environment variables are stored in ASCII format so "ethaddr" requires parsing into binary to make it work with Ethernet interfaces.
This includes support for indexes to support #nvmem-cell-cells = <1>.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/nvmem/u-boot-env.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c index 2a87dda45188..54283f8061b0 100644 --- a/drivers/nvmem/u-boot-env.c +++ b/drivers/nvmem/u-boot-env.c @@ -4,6 +4,8 @@ */
#include <linux/crc32.h> +#include <linux/etherdevice.h> +#include <linux/if_ether.h> #include <linux/mod_devicetable.h> #include <linux/module.h> #include <linux/mtd/mtd.h> @@ -70,6 +72,26 @@ static int u_boot_env_read(void *context, unsigned int offset, void *val, return 0; }
+static int u_boot_env_read_post_process_ethaddr(void *context, const char *id, int index, + unsigned int offset, void *data, size_t *bytes) +{ + u8 mac[ETH_ALEN]; + + if (*bytes != 3 * ETH_ALEN - 1) + return -EINVAL; + + if (!mac_pton(data, mac)) + return -EINVAL; + + if (index) + eth_addr_add(mac, index); + + ether_addr_copy(data, mac); + *bytes = ETH_ALEN; + + return 0; +} + static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, size_t data_offset, size_t data_len) { @@ -101,6 +123,8 @@ static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, priv->cells[idx].offset = data_offset + value - data; priv->cells[idx].bytes = strlen(value); priv->cells[idx].np = of_get_child_by_name(dev->of_node, priv->cells[idx].name); + if (!strcmp(var, "ethaddr")) + priv->cells[idx].read_post_process = u_boot_env_read_post_process_ethaddr; }
if (WARN_ON(idx != priv->ncells))
Hi Rafał,
I love your patch! Yet something to improve:
[auto build test ERROR on next-20230105] [cannot apply to robh/for-next shawnguo/for-next krzk-dt/for-next linus/master v6.2-rc2 v6.2-rc1 v6.1 v6.2-rc2] [If your patch is applied to the wrong git tree, kindly drop us a note. And when submitting patch, we suggest to use '--base' as documented in https://git-scm.com/docs/git-format-patch#_base_tree_information]
url: https://github.com/intel-lab-lkp/linux/commits/Rafa-Mi-ecki/nvmem-core-allow... patch link: https://lore.kernel.org/r/20230105171038.13649-3-zajec5%40gmail.com patch subject: [PATCH 3/3] nvmem: u-boot-env: post process "ethaddr" env variable config: nios2-buildonly-randconfig-r005-20230105 compiler: nios2-linux-gcc (GCC) 12.1.0 reproduce (this is a W=1 build): wget https://raw.githubusercontent.com/intel/lkp-tests/master/sbin/make.cross -O ~/bin/make.cross chmod +x ~/bin/make.cross # https://github.com/intel-lab-lkp/linux/commit/c87cc9dc60051170044407765ab613... git remote add linux-review https://github.com/intel-lab-lkp/linux git fetch --no-tags linux-review Rafa-Mi-ecki/nvmem-core-allow-read_post_process-callbacks-to-adjust-data-length/20230106-012141 git checkout c87cc9dc60051170044407765ab613e77c55b348 # save the config file mkdir build_dir && cp config build_dir/.config COMPILER_INSTALL_PATH=$HOME/0day COMPILER=gcc-12.1.0 make.cross W=1 O=build_dir ARCH=nios2 olddefconfig COMPILER_INSTALL_PATH=$HOME/0day COMPILER=gcc-12.1.0 make.cross W=1 O=build_dir ARCH=nios2 SHELL=/bin/bash
If you fix the issue, kindly add following tag where applicable | Reported-by: kernel test robot lkp@intel.com
All errors (new ones prefixed by >>):
nios2-linux-ld: drivers/nvmem/u-boot-env.o: in function `u_boot_env_read_post_process_ethaddr':
u-boot-env.c:(.text+0x2ec): undefined reference to `mac_pton'
u-boot-env.c:(.text+0x2ec): relocation truncated to fit: R_NIOS2_CALL26 against `mac_pton'
- description:
The 2nd sentence belongs in the '#nvmem-cell-cells' description.
- properties:
const: 1
mac: ethaddr {
};#nvmem-cell-cells = <1>; }; };
-- 2.34.1
kernel test robot
Michael Walle
Rafał Miłecki
Rob Herring
