[U-Boot-Users] [PATCH] Fix duplicated flash state
Move to one place I just compiled test. Please check other NAND users.
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 05ba375..ce9d937 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -19,6 +19,20 @@ #define MTD_ERASE_DONE 0x08 #define MTD_ERASE_FAILED 0x10
+/* + * Enumeration for NAND/OneNAND flash chip state + */ +enum { + FL_READY, + FL_READING, + FL_WRITING, + FL_ERASING, + FL_SYNCING, + FL_CACHEDPRG, + FL_UNLOCKING, + FL_LOCKING, +}; + /* If the erase fails, fail_addr might indicate exactly which block failed. If fail_addr = 0xffffffff, the failure was not at the device level or was not specific to any particular block. */ diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index e2a25a6..0b64d3c 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -195,20 +195,6 @@ extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_ /* Nand scan has allocated data_buf */ #define NAND_DATABUF_ALLOC 0x80000000
- -/* - * nand_state_t - chip states - * Enumeration for NAND flash chip state - */ -typedef enum { - FL_READY, - FL_READING, - FL_WRITING, - FL_ERASING, - FL_SYNCING, - FL_CACHEDPRG, -} nand_state_t; - /* Keep gcc happy */ struct nand_chip;
diff --git a/include/linux/mtd/nand_legacy.h b/include/linux/mtd/nand_legacy.h index b05e726..bb66e45 100644 --- a/include/linux/mtd/nand_legacy.h +++ b/include/linux/mtd/nand_legacy.h @@ -55,18 +55,6 @@ #define NAND_CMD_RESET 0xff
/* - * Enumeration for NAND flash chip state - */ -typedef enum { - FL_READY, - FL_READING, - FL_WRITING, - FL_ERASING, - FL_SYNCING -} nand_state_t; - - -/* * NAND Private Flash Chip Data * * Structure overview: diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 4b0c2df..903c3af 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -17,6 +17,7 @@ /* Note: The header order is impoertant */ #include <onenand_uboot.h>
+#include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
#define MAX_BUFFERRAM 2 @@ -28,20 +29,6 @@ extern int onenand_scan (struct mtd_info *mtd, int max_chips); extern void onenand_release (struct mtd_info *mtd);
/** - * onenand_state_t - chip states - * Enumeration for OneNAND flash chip state - */ -typedef enum { - FL_READY, - FL_READING, - FL_WRITING, - FL_ERASING, - FL_SYNCING, - FL_UNLOCKING, - FL_LOCKING, -} onenand_state_t; - -/** * struct onenand_bufferram - OneNAND BufferRAM Data * @param block block address in BufferRAM * @param page page address in BufferRAM @@ -106,7 +93,7 @@ struct onenand_chip {
spinlock_t chip_lock; wait_queue_head_t wq; - onenand_state_t state; + int state;
struct nand_oobinfo *autooob;
--- Added to GNATS database as unassigned-patches/4
Responsible: patch-coord Message-Id: 20080722080919.GA14956@july In-Reply-To: References: Patch-Date: Tue Jul 22 10:09:19 +0200 2008
------------------------------------------------------------------------- This SF.Net email is sponsored by the Moblin Your Move Developer's challenge Build the coolest Linux based applications with Moblin SDK & win great prizes Grand prize is a trip for two to an Open Source event anywhere in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Shouldn't this be <linux/mtd/mtd.h>?
Also, as this is not a regression fix (if it is, please say so explicitly), please post a patch against the testing branch of u-boot-nand-flash. For all NAND patches, please CC me, and include NAND in the subject.
-Scott
It fails to build, redefinition of id: jffs2_1pass.c: In function 'put_fl_mem': jffs2_1pass.c:466: error: redefinition of 'id' jffs2_1pass.c:459: error: previous definition of 'id' was here
Relevant piece of code:
static inline void put_fl_mem(void *buf) { #if defined(CONFIG_JFFS2_NAND) && \ defined(CONFIG_CMD_NAND) struct mtdids *id = current_part->dev->id;
if (id->type == MTD_DEV_TYPE_NAND) return put_fl_mem_nand(buf); #endif
#if defined(CONFIG_CMD_ONENAND) struct mtdids *id = current_part->dev->id;
if (id->type == MTD_DEV_TYPE_ONENAND) return put_fl_mem_onenand(buf); #endif }
cheers,
Fathi
#endif
#endif }
It's not this patch contents. I'ts related with the previous patch "JFFS2 support on OneNAND" Anyway, it should be below.
static inline void put_fl_mem(void *buf) { -#if defined(CONFIG_JFFS2_NAND) && \ - defined(CONFIG_CMD_NAND) +#if (defined(CONFIG_JFFS2_NAND) && defined(CONFIG_CMD_NAND)) || \ + defined(CONFIG_CMD_ONENAND) struct mtdids *id = current_part->dev->id; +#endif
+#if defined(CONFIG_JFFS2_NAND) && \ + defined(CONFIG_CMD_NAND) if (id->type == MTD_DEV_TYPE_NAND) return put_fl_mem_nand(buf); #endif + +#if defined(CONFIG_CMD_ONENAND) + if (id->type == MTD_DEV_TYPE_ONENAND) + return put_fl_mem_onenand(buf); +#endif
Next time it will be clean-uped with next patches.
Thank you, Kyungmin Park
- defined(CONFIG_CMD_ONENAND) struct mtdids *id = current_part->dev->id;
- defined(CONFIG_CMD_NAND) if (id->type == MTD_DEV_TYPE_NAND) return put_fl_mem_nand(buf);
#endif
nand_bbt_descr is duplicated: In file included from /u-boot-1.3.3/include/linux/mtd/onenand.h:21, from jffs2_1pass.c:279: /u-boot-1.3.3/include/linux/mtd/bbm.h:49: error: redefinition of 'struct nand_bbt_descr' make[1]: *** [jffs2_1pass.o] Error 1
It is defined in iinclude/linux/mtd/bbm.h
sorry, mail sent too fast...
nand_bbt_desc structure is defined in include/linux/mtd/bbm.h and iinclude/linux/mtd/nand.h
cheers,
Fathi
participants (5)
Fathi Boudra
Jean-Christophe PLAGNIOL-VILLARD
Kyungmin Park
Scott Wood
u-boot@bugs.denx.de
