[PATCH v2] ARM: dts: renesas: Remove leading 0x from rpc node
Remove the leading "0x" from rpc node to fix the below dtc warning:
Warning (simple_bus_reg): Node /soc/rpc@0xee200000 simple-bus unit address format error, expected "ee200000"
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- Squashed the changes into single patch. --- arch/arm/dts/r7s72100-gr-peach-u-boot.dts | 2 +- arch/arm/dts/r8a77950-u-boot.dtsi | 2 +- arch/arm/dts/r8a77960-u-boot.dtsi | 2 +- arch/arm/dts/r8a77965-u-boot.dtsi | 2 +- arch/arm/dts/r8a77970-u-boot.dtsi | 2 +- arch/arm/dts/r8a77980-u-boot.dtsi | 2 +- arch/arm/dts/r8a77990-u-boot.dtsi | 2 +- arch/arm/dts/r8a77995-u-boot.dtsi | 2 +- 8 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/r7s72100-gr-peach-u-boot.dts b/arch/arm/dts/r7s72100-gr-peach-u-boot.dts index 30e35e47d6..f48121a9a8 100644 --- a/arch/arm/dts/r7s72100-gr-peach-u-boot.dts +++ b/arch/arm/dts/r7s72100-gr-peach-u-boot.dts @@ -46,7 +46,7 @@ };
- rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r7s72100", "renesas,rpc"; reg = <0x3fefa000 0x100>, <0x18000000 0x08000000>; bank-width = <2>; diff --git a/arch/arm/dts/r8a77950-u-boot.dtsi b/arch/arm/dts/r8a77950-u-boot.dtsi index 0317f47f0f..5a11651464 100644 --- a/arch/arm/dts/r8a77950-u-boot.dtsi +++ b/arch/arm/dts/r8a77950-u-boot.dtsi @@ -13,7 +13,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a7795", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77960-u-boot.dtsi b/arch/arm/dts/r8a77960-u-boot.dtsi index 826c2384bc..f1cae1c359 100644 --- a/arch/arm/dts/r8a77960-u-boot.dtsi +++ b/arch/arm/dts/r8a77960-u-boot.dtsi @@ -13,7 +13,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a7796", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77965-u-boot.dtsi b/arch/arm/dts/r8a77965-u-boot.dtsi index 33ff5b148b..9cc6f20537 100644 --- a/arch/arm/dts/r8a77965-u-boot.dtsi +++ b/arch/arm/dts/r8a77965-u-boot.dtsi @@ -13,7 +13,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a77965", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77970-u-boot.dtsi b/arch/arm/dts/r8a77970-u-boot.dtsi index eabab7ce58..ac3c6be4ad 100644 --- a/arch/arm/dts/r8a77970-u-boot.dtsi +++ b/arch/arm/dts/r8a77970-u-boot.dtsi @@ -13,7 +13,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a77970", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77980-u-boot.dtsi b/arch/arm/dts/r8a77980-u-boot.dtsi index 1050f6e991..365d40ac49 100644 --- a/arch/arm/dts/r8a77980-u-boot.dtsi +++ b/arch/arm/dts/r8a77980-u-boot.dtsi @@ -13,7 +13,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a77980", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77990-u-boot.dtsi b/arch/arm/dts/r8a77990-u-boot.dtsi index ddf8b62627..6655abe875 100644 --- a/arch/arm/dts/r8a77990-u-boot.dtsi +++ b/arch/arm/dts/r8a77990-u-boot.dtsi @@ -9,7 +9,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a77990", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>; diff --git a/arch/arm/dts/r8a77995-u-boot.dtsi b/arch/arm/dts/r8a77995-u-boot.dtsi index 8e9f6b7a7d..0917a80f09 100644 --- a/arch/arm/dts/r8a77995-u-boot.dtsi +++ b/arch/arm/dts/r8a77995-u-boot.dtsi @@ -9,7 +9,7 @@
/ { soc { - rpc: rpc@0xee200000 { + rpc: rpc@ee200000 { compatible = "renesas,rpc-r8a77995", "renesas,rpc"; reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0>; clocks = <&cpg CPG_MOD 917>;
Lad Prabhakar
